  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.8k Aufrufe 40 Beobachtet
    @feuersturm
    In der Summary gleichlautend?
    Ich hab da noch einen Knoten drin, scheint mir.
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    #630
    @thomas-braun Sieht gut aus bei mir:
    Skript v.2024-08-18
    *** BASE SYSTEM ***
     Static hostname: ioB-Prod-Testsystem
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 6.5.13-1-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:22:28 up 15 days,  7:24,  1 user,  load average: 1.95, 2.04, 2.25
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
    und Summary
                            v.2024-08-18
             Chassis: container
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    User-ID:                1001
    Display-Server:         false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    Recommended versions are nodejs 20.16.0 and npm 10.8.1
    MEMORY:
    Mem:            8.0G        2.2G        4.8G        0.0K        1.0G        5.8G
    Swap:           2.0G        1.1G        976M
    Total:           10G        3.3G        5.8G
    Active iob-Instances:   31
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.10
                            admin                   7.0.23
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
    + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    Objects:                14532
    States:                 12032
    Size of iob-Database:
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    17M     /opt/iobroker/iobroker-data/objects.json.migrated
    17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
    1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
    19M     /opt/iobroker/iobroker-data/states.jsonl
    6.3M    /opt/iobroker/iobroker-data/states.json.migrated
    6.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    • FeuersturmF Feuersturm
      Skript v.2024-08-18
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
      und Summary
                              v.2024-08-18
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1001
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      MEMORY:
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                14532
      States:                 12032
      #631
      @feuersturm rein aus Neugier
      welche Farbe hat die Zeile?
        Skript v.2024-08-18
        *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
        und Summary
                                v.2024-08-18
                 Chassis: container
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        User-ID:                1001
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        MEMORY:
                                admin                   7.0.23
        Objects type: jsonl
        States  type: jsonl
        Objects:                14532
        States:                 12032
        #632
        @feuersturm
        Danke. Bei 'testing releases' wird da warum auch immer was unterschiedliches angezeigt. Und ich verstehe gerade nicht warum...
          FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          #633
          @homoran sagte in iob diag - Skript:
          Bei der Langfassung und Summary ist die Information Gelb,
            #634
            @feuersturm sagte in iob diag - Skript:
            So soll es sein. Stabile Releases wären Grün, abgekündigte wären Rot.
            NashraN NegaleinN 2 Antworten Letzte Antwort
              NashraN Offline
              NashraN Offline
              Nashra
              Most Active Forum Testing
              #635
              Moin, hier mit LXC
                                      v.2024-08-18_5
               Static hostname: ioBroker
                       Chassis: container ☐
                Virtualization: lxc
                        Kernel: Linux 6.8.12-1-pve
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              User-ID:                1000
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              MEMORY:
              Mem:             12G        4.1G        7.9G        122K        873M        8.7G
              Swap:             0B          0B          0B
              Total:           12G        4.1G        7.9G
              Active iob-Instances:   45
              ioBroker Core:          js-controller           6.0.9
                                      admin                   7.0.22
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
              Objects:                54190
              States:                 50980
              86M     /opt/iobroker/iobroker-data/objects.jsonl
              88M     /opt/iobroker/iobroker-data/states.jsonl
              Your Operating System is the current Debian stable version 'bookworm'!
              Gruß Ralf
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #636
                hier ein LXC
                                        v.2024-08-18_5
                         Chassis: container
                  Virtualization: lxc
                          Kernel: Linux 5.15.30-2-pve
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               64 bit
                Timezone:               Europe/Vienna (CEST, +0200)
                User-ID:                1001
                Pending OS-Updates:     31
                Pending iob updates:    4
                /usr/bin/nodejs         v20.15.0
                /usr/bin/node           v20.15.0
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.1
                MEMORY:
                Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
                Swap:           3.1G        1.1G        2.0G
                Total:           13G        5.8G        6.4G
                Active iob-Instances:   60
                Active repo(s): Beta (latest)
                ioBroker Core:          js-controller           5.0.19
                                        admin                   7.0.24
                Objects type: jsonl
                States  type: jsonl
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects:                32233
                States:                 31404
                53M     /opt/iobroker/iobroker-data/objects.jsonl
                29M     /opt/iobroker/iobroker-data/objects.json.migrated
                29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                0       /opt/iobroker/iobroker-data/objects.json.broken
                54M     /opt/iobroker/iobroker-data/states.jsonl
                9.4M    /opt/iobroker/iobroker-data/states.json.migrated
                9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                ° Fixer ---> iob fix
                • S Abwesend
                  S Abwesend
                  Shadowhunter23
                  #637
                  Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
                  Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  tcp
                  HINT:
                  Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                  tcp
                  HINT:
                  Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                  tcp
                  Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                  ioBroker Backup Analyzer
                  • S Shadowhunter23
                    USB-Devices by-id:
                    HINT:
                    tcp
                    HINT:
                    tcp
                    HINT:
                    tcp
                    #638
                    @shadowhunter23
                    Ich war davon ausgeganen, das 3 zigbee-Instanzen ausreichend sein sollten.
                    Ich würde da auch eher per Router ein Zigbee-Netz draus weben, an deiner Stelle.
                    Und ich vergleiche auch nur die EInträge von 'by-id' mit den Ports aus dem Adapter.
                    Ob die Einstellungen dann die richtigen sind musst du selber prüfen.
                    Ist ja auch nur ein Hinweis.
                    Kurz: Won't fix.
                      @shadowhunter23
                      Kurz: Won't fix.
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      schrieb am zuletzt editiert von Shadowhunter23
                      #639
                      Auch hier, Won't fix 🙂 . Das ist schon mit Absicht so gemacht.
                      Kurz: Won't fix.
                      OK, war ja auch nur ein Hinweis.
                      • S Shadowhunter23
                        Kurz: Won't fix.
                        #640
                        Da ich das Skript in den letzten Tagen um einige Funktionen (Anlage eines users, wenn es als root oder 'iobroker' aufgerufen wird; setzen der Zeitzone, wenn eine vermutlich falsche (wie Europe/London oder UTC) erkannt wird) und kritische Fehler im Kernel Ring Puffer (dmesg) jetzt gemeldet werden würde ich gerne ein paar Läufe auf anderen Systemen als meinen Testkisten sehen. Insbesondere LXC und Docker ist da interessant für mich.
                        Es gibt auch ein paar Meldungen auf deutsch, wenn das Skript mit der Option '--de' aufgerufen wird. Auch dazu wäre Feedback willkommen. Gleich vorweg: Es kann keine vollständige Übersetzung geben, da einige Kommandos nur englische Ausgaben liefern.
                        Bitte diese Beta-Version wie im ersten Beitrag gezeigt lokal ausführen, im ioBroker selber ist diese Version v.2024-09-07 natürlich noch nicht implementiert.
                          TT-Tom
                          #641
                          Hallo Thomas,
                          habe das Script aus dem Standartuser Ordner Tom gestartet. Musste zwischen durch das Password für sudo eingeben. System LXC-Container mit einem Testsystem auf Beta-Repro.
                          Script v.2024-09-07
                          *** BASE SYSTEM ***
                           Static hostname: iobtest
                            Virtualization: lxc
                          OS is similar to:
                          model name	: Intel(R) N100
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           14:11:14 up 24 days, 36 min,  1 user,  load average: 0.06, 0.08, 0.01
                          CPU threads: 4
                          Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                          *** TIME AND TIMEZONES ***
                                         Local time: Sun 2024-09-08 14:11:14 CEST
                                     Universal time: Sun 2024-09-08 12:11:14 UTC
                                           RTC time: n/a
                                        NTP service: inactive
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          tom
                          HOME=/home/tom
                          GROUPS=tom sudo users iobroker
                          iobroker
                          [sudo] password for tom:
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video plugdev
                          *** DISPLAY-SERVER SETUP ***
                          Desktop:
                          Terminal: 	tty
                          Boot Target: 	graphical.target
                          *** MEMORY ***
                          Mem:            8.4G        1.6G        5.2G        131K        1.6G        6.8G
                          Swap:           536M          0B        536M
                          Total:          8.9G        1.6G        5.7G
                          Active iob-Instances: 	10
                                   8000 M total memory
                                   1507 M used memory
                                   1442 M active memory
                                   1464 M inactive memory
                                   4944 M free memory
                                      0 M buffer memory
                                   1547 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          top - 14:11:34 up 24 days, 36 min,  1 user,  load average: 0.05, 0.07, 0.01
                          Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   8000.0 total,   4944.3 free,   1508.0 used,   1547.8 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6492.0 avail Mem
                          *** FAILED SERVICES ***
                            UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                          2 loaded units listed.
                          *** DMESG CRITICAL ERRORS ***
                          dmesg: read kernel buffer failed: Operation not permitted
                          No critical errors detected
                          *** FILESYSTEM ***
                          Filesystem                       Type      Size  Used Avail Use% Mounted on
                          /dev/mapper/pve-vm--101--disk--0 ext4       63G  6.0G   54G  10% /
                          none                             tmpfs     492K  4.0K  488K   1% /dev
                          udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                          tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                          tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
                          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                          tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                          Show mounted filesystems:
                          TARGET SOURCE                           FSTYPE OPTIONS
                          /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                          /var:
                          463M	/var/
                          250M	/var/cache
                          246M	/var/cache/apt
                          170M	/var/cache/apt/archives
                          154M	/var/lib
                          Archived and active journals take up 16.4M in the file system.
                          /opt/iobroker/backups:
                          46M	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          767M	/opt/iobroker/iobroker-data/
                          645M	/opt/iobroker/iobroker-data/files
                          493M	/opt/iobroker/iobroker-data/files/javascript.admin
                          461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                          460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          30M	/opt/iobroker/iobroker-data/objects.jsonl
                          19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                          14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                          8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                          USB-Devices by-id:
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs 	v20.17.0
                          /usr/bin/node 		v20.17.0
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          /usr/bin/corepack 	0.29.3
                          nodejs:
                            Installed: 20.17.0-1nodesource1
                            Candidate: 20.17.0-1nodesource1
                            Version table:
                           *** 20.17.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                               18.19.0+dfsg-6~deb12u2 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                               18.19.0+dfsg-6~deb12u1 500
                                  500 http://security.debian.org bookworm-security/main amd64 Packages
                          No problems detected
                          Errors in npm tree: 0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310623)
                          Core adapters versions
                          js-controller: 	6.0.11
                          admin: 		7.1.0
                          javascript: 	8.8.2
                          nodejs modules from github: 	2
                          +-- iobroker.iosapp@1.0.3 (git+ssh://git@github.com/tt-tom17/ioBroker.iosapp.git#57aa9615040d4d80b735ca0fb4beddc5aee69c9d)
                          +-- iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
                          Adapter State
                            system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
                          + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                          + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                            system.adapter.devices.0                : devices               : iobtest                                  - disabled
                          + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                            system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                          + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                          + system.adapter.iosapp.0                 : iosapp                : iobtest                                  -  enabled
                          + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                          + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                            system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
                            system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                          + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                            system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                            system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): beta
                          Installed ioBroker-Instances
                          Used repository: beta
                          Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                          Adapter    "admin"        : 7.1.0    , installed 7.1.0
                          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                          Adapter    "devices"      : 1.1.5    , installed 1.1.5
                          Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                          Adapter    "javascript"   : 8.8.3    , installed 8.8.2  [Updatable]
                          Controller "js-controller": 6.0.11   , installed 6.0.11
                          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                          Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                          Adapter    "sql"          : 3.0.1    , installed 3.0.1
                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                          Adapter    "web"          : 6.3.0    , installed 6.3.0
                          Adapter    "yahka"        : 1.0.8    , installed 1.0.8
                          Objects and States
                          Objects: 	4034
                          States: 	3519
                          Hit:1 http://security.debian.org bookworm-security InRelease
                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                          Reading package lists... Done
                          Pending Updates: 2
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13079      1/systemd
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13990      296/master
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29389306   35190/iobroker.js-c
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29389311   35190/iobroker.js-c
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13991      296/master
                          tcp6       0      0 :::9192                 :::*                    LISTEN      1001       29392405   35471/io.iosapp.0
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          13081      1/systemd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13201      1/systemd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60327454   91363/io.admin.0
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13080      1/systemd
                          udp6       0      0 :::111                  :::*                                0          13082      1/systemd
                          2024-09-08 14:02:49.853  - info: javascript.1 (61255) Start JavaScript script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch (JavaScript/js)
                          2024-09-08 14:02:49.860  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2024-09-08 14:02:49.864  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Connected!
                          2024-09-08 14:02:49.899  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch:  ist das eine zahl false
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Tagesverbrauch: 5.1 kWh
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Wochenverbrauch: 39.3 kWh
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Monatsverbrauch: 47.3 kWh
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Quartalsverbrauch: 455.6 kWh
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Jahrsverbrauch: 2018.2 kWh
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Betroffene Zeilen: 0
                          2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Serverstatus: 34
                          2024-09-08 14:05:39.663  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                          2024-09-08 14:05:39.895  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2024-09-08 14:05:48.012  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127484
                          2024-09-08 14:05:48.620  - info: netatmo-crawler.0 (127484) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                          2024-09-08 14:05:48.637  - info: netatmo-crawler.0 (127484) Getting data for stationid:70:ee:50:35:dc:b6
                          2024-09-08 14:06:07.272  - info: netatmo-crawler.0 (127484) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                          2024-09-08 14:06:07.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127484 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-09-08 14:10:44.041  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                          2024-09-08 14:10:44.229  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2024-09-08 14:10:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127529
                          2024-09-08 14:10:48.618  - info: netatmo-crawler.0 (127529) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                          2024-09-08 14:10:48.635  - info: netatmo-crawler.0 (127529) Getting data for stationid:70:ee:50:35:dc:b6
                          2024-09-08 14:10:59.398  - info: netatmo-crawler.0 (127529) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                          2024-09-08 14:10:59.907  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127529 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          			v.2024-09-07
                            Virtualization: lxc
                          Installation: 		lxc
                          Kernel: 		x86_64
                          Userland: 		64 bit
                          User-ID: 		1000
                          Pending OS-Updates: 	2
                          Pending iob updates: 	1
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          Recommended versions are nodejs 20.17.0 and npm 10.8.2
                          nodeJS installation is correct
                          MEMORY:
                          Mem:            8.4G        1.7G        5.0G        131K        1.6G        6.7G
                          Swap:           536M          0B        536M
                          Total:          8.9G        1.7G        5.6G
                          ioBroker Core: 		js-controller 		6.0.11
                          			admin 			7.1.0
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		4034
                          States: 		3519
                          6.0M	/opt/iobroker/iobroker-data/states.jsonl
                          in deutsch
                          *** ioBroker Diagnose ***
                          Das Fenster des Terminalprogramms (puTTY) bitte so groß wie möglich ziehen oder den Vollbildmodus verwenden.
                          Die nachfolgenden Prüfungen liefern Hinweise zu etwaigen Fehlern, bitte im Forum hochladen:
                          https://forum.iobroker.net
                          Bitte die vollständige Ausgabe, einschließlich der ``` Zeichen am Anfang und am Ende markieren und kopieren.
                          Es hilft beim helfen!
                          Bitte eine Taste drücken
                          ========== Langfassung ab hier markieren und kopieren ===========
                          Skript v.2024-09-07
                          *** GRUNDSYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           14:17:19 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                          CPU threads: 4
                          *** LEBENSZYKLUS STATUS ***
                          Das Betriebssystem mit dem Codenamen '' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
                          *** ZEIT UND ZEITZONEN ***
                                         Local time: Sun 2024-09-08 14:17:19 CEST
                                     Universal time: Sun 2024-09-08 12:17:19 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          *** User und Gruppen ***
                          User der 'iob diag' aufgerufen hat:
                          tom
                          HOME=/home/tom
                          User der den 'js-controller' ausführt:
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal: 	tty
                          *** MEMORY ***
                          Swap:           536M          0B        536M
                                   8000 M total memory
                                   1507 M used memory
                                   1439 M active memory
                                   1471 M inactive memory
                                   4936 M free memory
                                      0 M buffer memory
                                   1555 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          top - 14:17:20 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                          MiB Mem :   8000.0 total,   4935.5 free,   1509.3 used,   1555.3 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6490.7 avail Mem
                          Es wurden keine kritischen Fehler gefunden
                          *** FILESYSTEM ***
                          /var:
                          463M	/var/
                          250M	/var/cache
                          246M	/var/cache/apt
                          154M	/var/lib
                          768M	/opt/iobroker/iobroker-data/
                          USB-Devices by-id:
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310968)
                          admin: 		7.1.0
                          javascript: 	8.8.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects: 	3978
                          States: 	3463
                          Hit:2 http://security.debian.org bookworm-security InRelease
                          Offene Systemupdates: 2
                          2024-09-08 14:15:47.449  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                          2024-09-08 14:15:47.640  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2024-09-08 14:15:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 128557
                          2024-09-08 14:15:48.614  - info: netatmo-crawler.0 (128557) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                          2024-09-08 14:15:48.630  - info: netatmo-crawler.0 (128557) Getting data for stationid:70:ee:50:35:dc:b6
                          2024-09-08 14:15:58.272  - info: netatmo-crawler.0 (128557) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                          2024-09-08 14:15:58.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 128557 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          ============ Langfassung bis hier markieren =============
                          iob diag hat das System inspiziert.
                          Beliebige Taste für eine Zusammenfassung drücken
                          Zusammfassung ab hier markieren und kopieren:
                          ===================== ZUSAMMENFASSUNG =====================
                          			v.2024-09-07
                            Virtualization: lxc
                          Installation: 		lxc
                          Kernel: 		x86_64
                          Userland: 		64 bit
                          User-ID: 		1000
                          Offene OS-Updates: 	2
                          Offene iob updates: 	1
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          Empfohlene Versionen sind zurzeit nodejs 20.17.0 und npm 10.8.2
                          nodeJS ist korrekt installiert
                          MEMORY:
                          Mem:            8.4G        1.6G        5.1G        131K        1.6G        6.8G
                          Swap:           536M          0B        536M
                          			admin 			7.1.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		3978
                          States: 		3463
                          6.4M	/opt/iobroker/iobroker-data/states.jsonl
                          =================== ENDE DER ZUSAMMENFASSUNG ====================
                          === Ausgabe bis hier markieren und kopieren ===
                          tom@iobtest:~$
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • T TT-Tom
                            Hallo Thomas,
                            Script v.2024-09-07
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            tom
                            HOME=/home/tom
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:           536M          0B        536M
                                     8000 M total memory
                                     1507 M used memory
                                     4944 M free memory
                                        0 M buffer memory
                                     1547 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            *** FILESYSTEM ***
                            /var:
                            463M	/var/
                            250M	/var/cache
                            246M	/var/cache/apt
                            154M	/var/lib
                            USB-Devices by-id:
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin: 		7.1.0
                            javascript: 	8.8.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	4034
                            States: 	3519
                            Pending Updates: 2
                            			v.2024-09-07
                              Virtualization: lxc
                            Installation: 		lxc
                            Kernel: 		x86_64
                            Userland: 		64 bit
                            User-ID: 		1000
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            MEMORY:
                            Swap:           536M          0B        536M
                            			admin 			7.1.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		4034
                            States: 		3519
                            in deutsch
                            Skript v.2024-09-07
                            *** GRUNDSYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            tom
                            HOME=/home/tom
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:           536M          0B        536M
                                     8000 M total memory
                                     1507 M used memory
                                     4936 M free memory
                                        0 M buffer memory
                                     1555 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            *** FILESYSTEM ***
                            /var:
                            463M	/var/
                            250M	/var/cache
                            246M	/var/cache/apt
                            154M	/var/lib
                            USB-Devices by-id:
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin: 		7.1.0
                            javascript: 	8.8.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	3978
                            States: 	3463
                            			v.2024-09-07
                              Virtualization: lxc
                            Installation: 		lxc
                            Kernel: 		x86_64
                            Userland: 		64 bit
                            User-ID: 		1000
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            MEMORY:
                            Swap:           536M          0B        536M
                            			admin 			7.1.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		3978
                            States: 		3463
                            tom@iobtest:~$
                            #642
                            @tt-tom sagte in iob diag - Skript:
                            Hm. Da sollte eigentlich dann 'bookworm' gemeldet werden. Muss ich dann im LXC mal schauen, ob und wo ich die Info anderweitig bekomme.
                            Kannst du mal bitte
                            lsb_release -a
                            cat /etc/debian_version
                            hostnamectl
                            im Container ausführen?
                              Kannst du mal bitte
                              lsb_release -a
                              hostnamectl
                              TT-Tom
                              #643
                              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, permitted by applicable law.
                              Letzte Anmeldung: Sonntag, den 08. September 2024,
                              tom@iobtest:~$ lsb_release
                              -bash: Isb_release: Kommando nicht gefunden.
                              tom@iobtest:~$ lsb_release -a
                              tom@iobtest:~$cat /etc/debian_version
                              12.7
                              tom@iobtest:*$ hostnamectl
                              Chassis: container
                              Machine ID: 661945b8c6614fe89d03fba976fb627e
                              Boot ID: 9650d956e3ce42b185dda1a4dcaa22f4
                              Virtualization: lxc
                              Operating System: ;;https://www.debian.org/Debian GNU/Linux 12 (bookworm);;
                              tom@iobtest:~$
                              Edit: hostnamectl aktualisiert.
                              Gruß Tom
                              Public Transport
                              • S Abwesend
                                S Abwesend
                                Shadowhunter23
                                #644
                                Proxmox lxc
                                Script v.2024-09-07
                                *** BASE SYSTEM ***
                                 Static hostname: iobroker
                                  Virtualization: lxc
                                OS is similar to:
                                model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 16:16:01 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                                CPU threads: 4
                                Operating System is the current Debian stable version codenamed 'bookworm'!
                                               Local time: Sun 2024-09-08 16:16:01 CEST
                                           Universal time: Sun 2024-09-08 14:16:01 UTC
                                                 RTC time: n/a
                                              NTP service: n/a
                                          RTC in local TZ: no
                                tobias
                                HOME=/home/tobias
                                GROUPS=tobias sudo users iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev redis
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:             10G        4.4G        4.9G        499K        1.4G        6.4G
                                Swap:             0B          0B          0B
                                Total:           10G        4.4G        4.9G
                                Active iob-Instances:   50
                                        10240 M total memory
                                         4176 M used memory
                                         1435 M active memory
                                         3875 M inactive memory
                                         4689 M free memory
                                            0 M buffer memory
                                         1374 M swap cache
                                            0 M total swap
                                            0 M used swap
                                            0 M free swap
                                top - 16:16:02 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                                Tasks:  80 total,   1 running,  79 sleeping,   0 stopped,   0 zombie
                                MiB Mem :  10240.0 total,   4687.7 free,   4178.0 used,   1374.8 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6062.0 avail Mem
                                1 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/mapper/pve-vm--400--disk--0 ext4       16G   11G  4.1G  73% /
                                udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
                                /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                                /var:
                                1.1G    /var/
                                491M    /var/lib
                                340M    /var/lib/redis
                                307M    /var/cache
                                303M    /var/cache/apt
                                Archived and active journals take up 48.9M in the file system.
                                248M    /opt/iobroker/backups/
                                706M    /opt/iobroker/iobroker-data/
                                573M    /opt/iobroker/iobroker-data/files
                                299M    /opt/iobroker/iobroker-data/files/javascript.admin
                                265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                40M     /opt/iobroker/iobroker-data/objects.jsonl
                                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.448016d7.js.map
                                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                                19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                USB-Devices by-id:
                                HINT:
                                tcp
                                HINT:
                                tcp
                                HINT:
                                tcp
                                HINT:
                                Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                                tcp
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                At least one iobroker host is running.
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848141)
                                admin:          7.1.0
                                javascript:     8.8.3
                                nodejs modules from github:     0
                                Adapter State
                                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                                + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                                + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                                + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                  system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                                  system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                                + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                                + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                                + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                                + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                                  system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
                                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                                + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                                + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                                + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                                + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                                + instance is alive
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                                Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                Adapter    "email"        : 1.3.1    , installed 1.3.1
                                Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                Adapter    "iot"          : 3.4.0    , installed 3.4.0
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
                                Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                Adapter    "notification-manager": 1.2.1, installed 1.2.1
                                Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                                Adapter    "ping"         : 1.7.3    , installed 1.7.3
                                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                Adapter    "shelly"       : 8.1.1    , installed 8.1.1
                                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
                                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                Objects and States
                                Objects:        11315
                                States:         10115
                                Hit:5 https://packages.redis.io/deb bookworm InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118935115  1/systemd
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       156490584  651521/io.mqtt.0
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       118947555  877/io.shelly.1
                                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        118941820  170/redis-server 12
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118940237  404/master
                                tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       118943133  781/io.nuki.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          118937351  1/systemd
                                tcp6       0      0 :::80                   :::*                    LISTEN      0          135858214  294782/apache2
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          118935117  1/systemd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      1001       118951273  1120/io.fullybrowse
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118940238  404/master
                                tcp6       0      0 ::1:6379                :::*                    LISTEN      106        118941821  170/redis-server 12
                                tcp6       0      0 :::8093                 :::*                    LISTEN      1001       118953403  1186/io.rest-api.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       118953652  1281/io.simple-api.
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       149284472  525475/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       118956323  1397/io.web.0
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          118935218  90/dhclient
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118935116  1/systemd
                                udp        0      0 192.168.0.222:123       0.0.0.0:*                           0          118937414  180/ntpd
                                udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          118937412  180/ntpd
                                udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          118937408  180/ntpd
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       118946983  661/io.chromecast.0
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       118947492  857/io.shelly.0
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       118943201  897/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       118943202  897/io.tuya.0
                                udp6       0      0 :::111                  :::*                                0          118935118  1/systemd
                                udp6       0      0 fe80::8c62:1cff:fe4:123 :::*                                105        118940387  180/ntpd
                                udp6       0      0 ::1:123                 :::*                                0          118937416  180/ntpd
                                udp6       0      0 :::123                  :::*                                0          118937405  180/ntpd
                                2024-09-08 14:00:00.013  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1049671
                                2024-09-08 14:00:04.018  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1049691
                                2024-09-08 14:00:08.105  - info: host.iobroker instance system.adapter.ical.1 having pid 1049671 terminated with code 0 (NO_ERROR)
                                2024-09-08 14:00:10.686  - info: host.iobroker instance system.adapter.ical.0 having pid 1049691 terminated with code 0 (NO_ERROR)
                                2024-09-08 14:30:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1051935
                                2024-09-08 14:30:04.019  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1051950
                                2024-09-08 14:30:06.665  - info: host.iobroker instance system.adapter.ical.0 having pid 1051935 terminated with code 0 (NO_ERROR)
                                2024-09-08 14:30:12.176  - info: host.iobroker instance system.adapter.ical.1 having pid 1051950 terminated with code 0 (NO_ERROR)
                                2024-09-08 15:00:00.022  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1054104
                                2024-09-08 15:00:04.027  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1054124
                                2024-09-08 15:00:08.093  - info: host.iobroker instance system.adapter.ical.1 having pid 1054104 terminated with code 0 (NO_ERROR)
                                2024-09-08 15:00:10.660  - info: host.iobroker instance system.adapter.ical.0 having pid 1054124 terminated with code 0 (NO_ERROR)
                                2024-09-08 15:30:00.016  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1056283
                                2024-09-08 15:30:04.021  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1056303
                                2024-09-08 15:30:06.698  - info: host.iobroker instance system.adapter.ical.0 having pid 1056283 terminated with code 0 (NO_ERROR)
                                2024-09-08 15:30:12.224  - info: host.iobroker instance system.adapter.ical.1 having pid 1056303 terminated with code 0 (NO_ERROR)
                                2024-09-08 16:00:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1058656
                                2024-09-08 16:00:04.021  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1058676
                                2024-09-08 16:00:08.144  - info: host.iobroker instance system.adapter.ical.1 having pid 1058656 terminated with code 0 (NO_ERROR)
                                2024-09-08 16:00:10.674  - info: host.iobroker instance system.adapter.ical.0 having pid 1058676 terminated with code 0 (NO_ERROR)
                                                        v.2024-09-07
                                  Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1000
                                Pending iob updates:    0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Mem:             10G        4.4G        4.9G        524K        1.4G        6.3G
                                Swap:             0B          0B          0B
                                                        admin                   7.1.0
                                Objects type: redis
                                States  type: redis
                                Objects:                11315
                                States:                 10115
                                4.0M    /opt/iobroker/iobroker-data/states.jsonl
                                Deutsch:
                                Skript v.2024-09-07
                                *** GRUNDSYSTEM ***
                                  Virtualization: lxc
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                                CPU threads: 4
                                Das Betriebssystem ist das aktuelle, stabile Debian 'bookworm'!
                                               Local time: Sun 2024-09-08 16:20:31 CEST
                                           Universal time: Sun 2024-09-08 14:20:31 UTC
                                                 RTC time: n/a
                                              NTP service: n/a
                                          RTC in local TZ: no
                                tobias
                                HOME=/home/tobias
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:             0B          0B          0B
                                         4186 M used memory
                                         1444 M active memory
                                         4678 M free memory
                                            0 M buffer memory
                                         1375 M swap cache
                                            0 M total swap
                                            0 M used swap
                                            0 M free swap
                                top - 16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                                Tasks:  86 total,   2 running,  83 sleeping,   0 stopped,   1 zombie
                                %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :  10240.0 total,   4677.1 free,   4187.5 used,   1375.9 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6052.5 avail Mem
                                *** FILESYSTEM ***
                                tmpfs                            tmpfs     3.1G  168K  3.1G   1% /run
                                tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/0
                                /var:
                                1.1G    /var/
                                491M    /var/lib
                                340M    /var/lib/redis
                                307M    /var/cache
                                303M    /var/cache/apt
                                USB-Devices by-id:
                                HINT:
                                tcp
                                HINT:
                                tcp
                                HINT:
                                tcp
                                HINT:
                                tcp
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848411)
                                admin:          7.1.0
                                javascript:     8.8.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        11315
                                States:         10115
                                Offene Systemupdates: 0
                                (Not all processes could be identified, non-owned process info
                                 will not be shown, you would have to be root to see it all.)
                                                        v.2024-09-07
                                  Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1000
                                Offene OS-Updates:      0
                                Offene iob updates:     0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Swap:             0B          0B          0B
                                                        admin                   7.1.0
                                Objects type: redis
                                States  type: redis
                                Objects:                11315
                                States:                 10115
                                • S Shadowhunter23
                                  Proxmox lxc
                                  Script v.2024-09-07
                                  *** BASE SYSTEM ***
                                    Virtualization: lxc
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                                   RTC time: n/a
                                                NTP service: n/a
                                            RTC in local TZ: no
                                  tobias
                                  HOME=/home/tobias
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:             0B          0B          0B
                                           4176 M used memory
                                           4689 M free memory
                                              0 M buffer memory
                                           1374 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.1G    /var/
                                  491M    /var/lib
                                  340M    /var/lib/redis
                                  307M    /var/cache
                                  303M    /var/cache/apt
                                  USB-Devices by-id:
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: redis
                                  States  type: redis
                                  Hosts:
                                  admin:          7.1.0
                                  javascript:     8.8.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        11315
                                  States:         10115
                                  Pending Updates: 0
                                                          v.2024-09-07
                                    Virtualization: lxc
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               64 bit
                                  User-ID:                1000
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  MEMORY:
                                  Swap:             0B          0B          0B
                                                          admin                   7.1.0
                                  Objects type: redis
                                  States  type: redis
                                  Objects:                11315
                                  States:                 10115
                                  Deutsch:
                                  Skript v.2024-09-07
                                  *** GRUNDSYSTEM ***
                                    Virtualization: lxc
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                                   RTC time: n/a
                                                NTP service: n/a
                                            RTC in local TZ: no
                                  tobias
                                  HOME=/home/tobias
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:             0B          0B          0B
                                           4186 M used memory
                                           4678 M free memory
                                              0 M buffer memory
                                           1375 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.1G    /var/
                                  491M    /var/lib
                                  340M    /var/lib/redis
                                  307M    /var/cache
                                  303M    /var/cache/apt
                                  USB-Devices by-id:
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: redis
                                  States  type: redis
                                  Hosts:
                                  admin:          7.1.0
                                  javascript:     8.8.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        11315
                                  States:         10115
                                                          v.2024-09-07
                                    Virtualization: lxc
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               64 bit
                                  User-ID:                1000
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  MEMORY:
                                  Swap:             0B          0B          0B
                                                          admin                   7.1.0
                                  Objects type: redis
                                  States  type: redis
                                  Objects:                11315
                                  States:                 10115
                                  #645
                                  @shadowhunter23 sagte in iob diag - Skript:
                                  fehlende Gruppe für den user (adm?)
                                    Meister MopperM Online
                                    Meister Mopper
                                    #646
                                    Habe mal einen Proxmox Test LXC angeschmissen und das Skript laufen lassen:
                                    Langfassung:
                                    Script v.2024-09-07
                                    *** BASE SYSTEM ***
                                    Static hostname: ioTest
                                     Virtualization: lxc
                                    OS is similar to:
                                    model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                                    CPU threads: 1
                                                  Local time: Sun 2024-09-08 17:01:44 CEST
                                              Universal time: Sun 2024-09-08 15:01:44 UTC
                                                    RTC time: n/a
                                             RTC in local TZ: no
                                    thomas
                                    HOME=/home/thomas
                                    GROUPS=thomas adm sudo iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            2.1G        1.1G        982M        118K        102M        1.1G
                                    Swap:             0B          0B          0B
                                    Total:          2.1G        1.1G        982M
                                            2048 M total memory
                                            1013 M used memory
                                            1090 M active memory
                                               0 M inactive memory
                                             936 M free memory
                                               0 M buffer memory
                                              98 M swap cache
                                               0 M total swap
                                               0 M used swap
                                               0 M free swap
                                    top - 17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                                    Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
                                    MiB Mem :   2048.0 total,    935.0 free,   1014.9 used,     98.1 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1033.1 avail Mem
                                    * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                                    3 loaded units listed.
                                    *** FILESYSTEM ***
                                    rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
                                    udev                         devtmpfs   16G     0   16G   0% /dev/tty
                                    tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
                                    tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
                                    tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
                                    /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
                                    /var:
                                    1.1G    /var/
                                    603M    /var/log
                                    602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
                                    369M    /var/lib
                                    Archived and active journals take up 601.0M in the file system.
                                    489M    /opt/iobroker/backups/
                                    8.5K    /opt/iobroker/backups/scripte0
                                    164M    /opt/iobroker/iobroker-data/
                                    105M    /opt/iobroker/iobroker-data/files
                                    47M     /opt/iobroker/iobroker-data/files/javascript.admin
                                    40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                                    3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
                                    3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
                                    3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
                                    3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                     Version table:
                                           500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                    ioBroker Status
                                    Objects type: redis
                                    States  type: redis
                                    Hosts:
                                    ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
                                    admin:          7.0.23
                                    javascript:     8.7.6
                                    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                     system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
                                    + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
                                     system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
                                     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
                                    + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
                                     system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
                                     system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
                                     system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
                                     system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
                                     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
                                     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
                                     system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
                                     system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
                                     system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
                                     system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
                                     system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
                                    + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    Active repo(s): stable
                                    Used repository: stable
                                    Adapter    "admin"        : 7.0.23   , installed 7.0.23
                                    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                                    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                                    Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                    Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                    Adapter    "heos"         : 2.2.1    , installed 2.2.1
                                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                    Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
                                    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                    Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                    Adapter    "solax"        : 0.9.9    , installed 0.9.9
                                    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
                                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                    Adapter    "web"          : 6.2.5    , installed 6.2.5
                                    Objects and States
                                    Objects:        453
                                    States:         337
                                    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
                                    tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146671441  166/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146672892  237/io.web.0
                                    tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
                                    udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
                                    2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
                                    2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
                                    2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
                                    2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
                                    Kurzfassung:
                                                           v.2024-09-07
                                     Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1001
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    MEMORY:
                                    Mem:            2.1G        1.1G        1.0G        118K         62M        1.1G
                                    Swap:             0B          0B          0B
                                    Total:          2.1G        1.1G        1.0G
                                                           admin                   7.0.23
                                    Objects type: redis
                                    States  type: redis
                                    Objects:                453
                                    States:                 337
                                    1.9M    /opt/iobroker/iobroker-data/objects.json.bak
                                    221K    /opt/iobroker/iobroker-data/states.json.bak
                                    Langfassung DE:
                                    Skript v.2024-09-07
                                    *** GRUNDSYSTEM ***
                                     Virtualization: lxc
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                                    CPU threads: 1
                                                  Local time: Sun 2024-09-08 17:04:41 CEST
                                              Universal time: Sun 2024-09-08 15:04:41 UTC
                                                    RTC time: n/a
                                             RTC in local TZ: no
                                    thomas
                                    HOME=/home/thomas
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:             0B          0B          0B
                                            2048 M total memory
                                            1018 M used memory
                                            1055 M active memory
                                               0 M inactive memory
                                             970 M free memory
                                               0 M buffer memory
                                              59 M swap cache
                                               0 M total swap
                                               0 M used swap
                                               0 M free swap
                                    top - 17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                                    %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   2048.0 total,    968.4 free,   1020.2 used,     59.6 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1027.8 avail Mem
                                    *** FILESYSTEM ***
                                    /var:
                                    1.1G    /var/
                                    603M    /var/log
                                    369M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                     Version table:
                                    ioBroker Status
                                    Objects type: redis
                                    States  type: redis
                                    Hosts:
                                    ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 466)
                                    admin:          7.0.23
                                    javascript:     8.7.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        453
                                    States:         337
                                    Kurzfassung DE:
                                                           v.2024-09-07
                                     Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1001
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    MEMORY:
                                    Swap:             0B          0B          0B
                                                           admin                   7.0.23
                                    Objects type: redis
                                    States  type: redis
                                    Objects:                453
                                    States:                 337
                                    Proxmox und HA ...
                                      #647
                                      Nee, LXC-Eigenheit.
                                      Bei Meister Mopper wird auch richtig Bookworm erkannt...
                                      Meister MopperM T 3 Antworten Letzte Antwort
                                        Nee, LXC-Eigenheit.
                                        Meister Mopper
                                        #648
                                        Jetzt mal die Variante als root user:
                                        Script v.2024-09-07
                                        *** BASE SYSTEM ***
                                         Virtualization: lxc
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
                                        CPU threads: 1
                                                      Local time: Sun 2024-09-08 17:46:56 CEST
                                                  Universal time: Sun 2024-09-08 15:46:56 UTC
                                                        RTC time: n/a
                                                 RTC in local TZ: no
                                        root
                                        HOME=/root
                                        GROUPS=root
                                        iobroker
                                        HOME=/home/iobroker
                                        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                                        A root login is not required in most Linux Distributions.
                                        Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
                                        Enter the password for the new user:
                                        Confirm the password for the new user:
                                        Adding new user account...
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
                                        Swap:             0B          0B          0B
                                                2048 M total memory
                                                1022 M used memory
                                                1048 M active memory
                                                   0 M inactive memory
                                                 964 M free memory
                                                   0 M buffer memory
                                                  61 M swap cache
                                                   0 M total swap
                                                   0 M used swap
                                                   0 M free swap
                                        top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
                                        Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                                        MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
                                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
                                        *** FILESYSTEM ***
                                        tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
                                        /var:
                                        1.1G    /var/
                                        603M    /var/log
                                        369M    /var/lib
                                        Archived and active journals take up 601.1M in the file system.
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                         Version table:
                                        ioBroker Status
                                        Objects type: redis
                                        States  type: redis
                                        Hosts:
                                        ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
                                        admin:          7.0.23
                                        javascript:     8.7.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        453
                                        States:         337
                                        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                        Pending Updates: 0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
                                        2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
                                        2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
                                        2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
                                        2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
                                        2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                        2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
                                        2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
                                        2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
                                        2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
                                        Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
                                        testuser@ioTest:~$ groups
                                        testuser adm dialout sudo audio video plugdev users iobroker
                                        Proxmox und HA ...
                                          Nee, LXC-Eigenheit.
                                          TT-Tom
                                          #649
                                          @Meister-Mopper
                                          @Shadowhunter23
                                          von welcher Konsole habt ihr das script gestartet? aus der Proxmox oder per ssh aus einem Terminal?
                                          Gruß Tom
                                          Public Transport
                                          Meister MopperM W 2 Antworten Letzte Antwort
