  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.3k Aufrufe 40 Beobachtet
  • skvarelS skvarel
    ./iob_diag.sh
    ```bash
    Script v.2026-05-20
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.4 LTS
     Static hostname: ioBroker
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.8.0-117-generic
        Architecture: x86-64
     Hardware Vendor: Dell Inc.
      Hardware Model: OptiPlex 3050
    Firmware Version: 1.6.5
       Firmware Date: Sat 2017-09-09
        Firmware Age: 8y 8month 1w 3d
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : x86_64
    Userland        : 64bit
    System was installed 243 days ago (on 2025-09-19).
    Systemuptime and Load:
     11:17:00 up 3 days,  4:15,  1 user,  load average: 0.54, 0.66, 0.76
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-05-21 11:17:00 CEST
               Universal time: Thu 2026-05-21 09:17:00 UTC
                     RTC time: Thu 2026-05-21 09:17:00
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm cdrom sudo dip plugdev lxd iobroker
    iobroker[sudo] password for pi:
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:             16G        9.7G        2.9G        5.0M        4.5G        7.0G
    Swap:           4.3G          0B        4.3G
    Total:           20G        9.7G        7.2G
    Active iob-Instances:   53
            15877 M total memory
             9220 M used memory
             9344 M active memory
             2736 M inactive memory
             2735 M free memory
              800 M buffer memory
             3461 M swap cache
             4095 M total swap
                0 M used swap
             4095 M free swap
    top - 11:17:11 up 3 days,  4:15,  1 user,  load average: 0.68, 0.68, 0.76
    Tasks: 233 total,   1 running, 232 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  9.8 us,  5.9 sy,  0.0 ni, 82.4 id,  0.0 wa,  0.0 hi,  2.0 si,  0.0 st
    MiB Mem :  15877.7 total,   2734.3 free,   9222.2 used,   4262.3 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6655.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  1.6G  4.6M  1.6G   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4   467G   20G  428G   5% /
    tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/nvme0n1p2                    ext4   2.0G  200M  1.6G  11% /boot
    tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Mon May 18 07:01:29 2026] Btrfs loaded, zoned=yes, fsverity=yes
    [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): mounted filesystem a547182b-43b5-440e-b6fe-09323774b05c ro with ordered data mode. Quota mode: none.
    [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): re-mounted a547182b-43b5-440e-b6fe-09323774b05c r/w.
    [Mon May 18 07:01:30 2026] EXT4-fs (nvme0n1p2): mounted filesystem 7a71a3d0-fb5e-4ed0-8d6d-dc24002c0eef r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE                            FSTYPE OPTIONS
    /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
    `-/boot /dev/nvme0n1p2                    ext4   rw,relatime
    /var:
    5.3G    /var/
    4.4G    /var/log
    4.2G    /var/log/journal/b521ee0ca8cb46db87113e33c1d11d82
    760M    /var/lib
    Archived and active journals take up 4.1G in the file system.
    /opt/iobroker/backups:
    190M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    502M    /opt/iobroker/iobroker-data/
    329M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    56M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.1+dfsg-6ubuntu5 500
            500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152296)
    Core adapters versions
    js-controller:  7.1.2
    admin:          7.8.25
    javascript:     9.2.2
    nodejs modules from github:     3
    +-- iobroker.energiefluss-erweitert@0.8.2 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#89dbb71bf0fc70044249fd6453c25194130d9971)
    +-- iobroker.foxesscloud@0.4.0 (git+ssh://git@github.com/inventwo/ioBroker.foxesscloud.git#9c22623f35cd02277a4a3dcc145ada655b4e9080)
    +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.autodarts.0              : autodarts             : ioBroker                                 -  enabled, port: 3180
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
    + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
    + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.enpal.0                  : enpal                 : ioBroker                                 -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.foxesscloud.0            : foxesscloud           : ioBroker                                 - disabled
    + system.adapter.foxesscloud.1            : foxesscloud           : ioBroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
    + system.adapter.javascript.2             : javascript            : ioBroker                                 -  enabled
    + system.adapter.javascript.3             : javascript            : ioBroker                                 -  enabled
    + system.adapter.javascript.5             : javascript            : ioBroker                                 -  enabled
    + system.adapter.life360ng.0              : life360ng             : ioBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
    + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ioBroker                                 - disabled, port: 16021
    + system.adapter.operating-hours.0        : operating-hours       : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.reolink.5                : reolink               : ioBroker                                 -  enabled
    + system.adapter.reolink.6                : reolink               : ioBroker                                 -  enabled
    + system.adapter.reolink.7                : reolink               : ioBroker                                 -  enabled
    + system.adapter.reolink.8                : reolink               : ioBroker                                 -  enabled
      system.adapter.reolink.9                : reolink               : ioBroker                                 - disabled
      system.adapter.seq.0                    : seq                   : ioBroker                                 - disabled, port: 443
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
    + system.adapter.sureflap.0               : sureflap              : ioBroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tidy.0                   : tidy                  : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
    + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
    + system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 -  enabled, port: 5000
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'Beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 1       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    Active repo(s): Beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                      │ name                     │ version   │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.25'  │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.27.4'  │ 'none'         │
    │ 2       │ 'system.adapter.autodarts'              │ 'autodarts'              │ '1.0.8'   │ 'none'         │
    │ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'  │ 'none'         │
    │ 4       │ 'system.adapter.bambulab'               │ 'bambulab'               │ '0.4.3'   │ 'none'         │
    │ 5       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.0.1'   │ 'none'         │
    │ 6       │ 'system.adapter.brightsky'              │ 'brightsky'              │ '1.1.0'   │ 'none'         │
    │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
    │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
    │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.1.1'   │ 'none'         │
    │ 10      │ 'system.adapter.discovergy'             │ 'discovergy'             │ '0.7.0'   │ 'none'         │
    │ 11      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
    │ 12      │ 'system.adapter.enpal'                  │ 'enpal'                  │ '0.2.0'   │ 'none'         │
    │ 13      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.2'   │ 'none'         │
    │ 14      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'   │ 'none'         │
    │ 15      │ 'system.adapter.foxesscloud'            │ 'foxesscloud'            │ '0.4.0'   │ 'none'         │
    │ 16      │ 'system.adapter.harmony'                │ 'harmony'                │ '2.1.0'   │ 'none'         │
    │ 17      │ 'system.adapter.hmip'                   │ 'hmip'                   │ '1.27.0'  │ 'none'         │
    │ 18      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
    │ 19      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
    │ 20      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'   │ 'none'         │
    │ 21      │ 'system.adapter.life360ng'              │ 'life360ng'              │ '1.9.1'   │ 'none'         │
    │ 22      │ 'system.adapter.linux-control'          │ 'linux-control'          │ '1.1.6'   │ 'none'         │
    │ 23      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'   │ 'none'         │
    │ 24      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'   │ 'none'         │
    │ 25      │ 'system.adapter.nanoleaf-lightpanels'   │ 'nanoleaf-lightpanels'   │ '1.6.0'   │ 'none'         │
    │ 26      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
    │ 27      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
    │ 28      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'   │ 'none'         │
    │ 29      │ 'system.adapter.seq'                    │ 'seq'                    │ '1.0.2'   │ 'none'         │
    │ 30      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
    │ 31      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
    │ 32      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '3.4.0'   │ 'none'         │
    │ 33      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
    │ 34      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14'  │ 'none'         │
    │ 35      │ 'system.adapter.spotify-premium'        │ 'spotify-premium'        │ '2.0.3'   │ 'none'         │
    │ 36      │ 'system.adapter.sureflap'               │ 'sureflap'               │ '3.4.2'   │ 'none'         │
    │ 37      │ 'system.adapter.tankerkoenig'           │ 'tankerkoenig'           │ '3.4.0'   │ 'none'         │
    │ 38      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
    │ 39      │ 'system.adapter.tidy'                   │ 'tidy'                   │ '0.1.1'   │ 'none'         │
    │ 40      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'   │ 'none'         │
    │ 41      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
    │ 42      │ 'system.adapter.tuya'                   │ 'tuya'                   │ '3.17.0'  │ 'none'         │
    │ 43      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.19' │ 'none'         │
    │ 44      │ 'system.adapter.vis-2-widgets-icontwo'  │ 'vis-2-widgets-icontwo'  │ '1.40.0'  │ 'none'         │
    │ 45      │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.0.0'   │ 'none'         │
    │ 46      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
    │ 47      │ 'system.adapter.wallpanel'              │ 'wallpanel'              │ '0.3.11'  │ 'none'         │
    │ 48      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
    │ 49      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'   │ 'none'         │
    │ 50      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'   │ 'none'         │
    │ 51      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'   │ 'none'         │
    │ 52      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
    │ 53      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.1'   │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: Beta
    Adapter    "admin"        : 7.8.25   , installed 7.8.25
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "autodarts"    : 1.0.8    , installed 1.0.8
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
    Adapter    "birthdays"    : 6.0.1    , installed 6.0.1
    Adapter    "brightsky"    : 1.1.0    , installed 1.1.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.15.15 , installed 2.15.15
    Adapter    "devices"      : 2.1.1    , installed 2.1.1
    Adapter    "discovergy"   : 0.7.0    , installed 0.7.0
    Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
    Adapter    "enpal"        : 0.2.0    , installed 0.2.0
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
    Adapter    "foxesscloud"  : 0.4.0    , installed 0.4.0
    Adapter    "harmony"      : 2.1.0    , installed 2.1.0
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "javascript"   : 9.2.2    , installed 9.2.2
    Controller "js-controller": 7.1.2    , installed 7.1.2
    Adapter    "life360ng"    : 1.9.1    , installed 1.9.1
    Adapter    "linux-control": 1.1.5    , installed 1.1.6
    Adapter    "matter"       : 1.0.0    , installed 1.0.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "nanoleaf-lightpanels": 1.6.0, installed 1.6.0
    Adapter    "operating-hours": 1.5.1  , installed 1.5.1
    Adapter    "ping"         : 2.2.4    , installed 2.2.4
    Adapter    "reolink"      : 1.4.2    , installed 1.4.2
    Adapter    "seq"          : 1.0.2    , installed 1.0.2
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "snmp"         : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
    Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 5.3.0    , installed 5.3.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
    Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
    Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
    Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "web"          : 8.1.0    , installed 8.1.0
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.9.2    , installed 0.9.2
    Adapter    "worx"         : 3.3.0    , installed 3.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
    Objects and States
    Objects:        22292
    States:         22954
    Hit:1 https://apt.grafana.com stable InRelease
    Get:2 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
    Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
    Hit:8 https://packages.redis.io/deb noble InRelease
    Fetched 6922 B in 1s (7313 B/s)
    Reading package lists... Done
    Pending systemupdates: 2
    *** Listening Ports ***
    Netid     State      Recv-Q     Send-Q                              Local Address:Port                  Peer Address:Port    Process
    udp       UNCONN     0          0                                         0.0.0.0:61991                      0.0.0.0:*        users:(("io.harmony.0",pid=612834,fd=30))
    udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=42))
    udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=40))
    udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.wled.0",pid=614951,fd=22))
    udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=38))
    udp       UNCONN     0          0                                         0.0.0.0:5540                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=46))
    udp       UNCONN     0          0                                         0.0.0.0:5541                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=37))
    udp       UNCONN     0          0                                         0.0.0.0:5542                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=47))
    udp       UNCONN     0          0                                         0.0.0.0:6666                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=53))
    udp       UNCONN     0          0                                         0.0.0.0:6667                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=54))
    udp       UNCONN     0          0                                      127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=16))
    udp       UNCONN     0          0                                   127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=14))
    udp       UNCONN     0          0                          192.168.130.130%enp2s0:bootpc                     0.0.0.0:*        users:(("systemd-network",pid=512,fd=24))
    udp       UNCONN     0          0                                         0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=5),("systemd",pid=1,fd=270))
    udp       UNCONN     0          0                                  172.18.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=25))
    udp       UNCONN     0          0                                      172.18.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=24))
    udp       UNCONN     0          0                                  172.17.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=21))
    udp       UNCONN     0          0                                      172.17.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=20))
    udp       UNCONN     0          0                                 192.168.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=16))
    udp       UNCONN     0          0                                 192.168.130.130:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=15))
    udp       UNCONN     0          0                                         0.0.0.0:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=13))
    udp       UNCONN     0          0                                  172.18.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=27))
    udp       UNCONN     0          0                                      172.18.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=26))
    udp       UNCONN     0          0                                  172.17.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=23))
    udp       UNCONN     0          0                                      172.17.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=22))
    udp       UNCONN     0          0                                 192.168.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=18))
    udp       UNCONN     0          0                                 192.168.130.130:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=17))
    udp       UNCONN     0          0                                         0.0.0.0:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=14))
    udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=44))
    udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=43))
    udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=41))
    udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=39))
    udp       UNCONN     0          0                                            [::]:5540                          [::]:*        users:(("io.matter.0",pid=614373,fd=45))
    udp       UNCONN     0          0                                            [::]:5541                          [::]:*        users:(("io.matter.0",pid=614373,fd=36))
    udp       UNCONN     0          0                                            [::]:5542                          [::]:*        users:(("io.matter.0",pid=614373,fd=35))
    udp       UNCONN     0          0                                            [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=7),("systemd",pid=1,fd=272))
    udp       UNCONN     0          0              [fe80::da9e:f3ff:fe78:3132]%enp2s0:dhcpv6-client                 [::]:*        users:(("systemd-network",pid=512,fd=22))
    tcp       LISTEN     0          50                                        0.0.0.0:netbios-ssn                0.0.0.0:*        users:(("smbd",pid=1007,fd=31))
    tcp       LISTEN     0          4096                                      0.0.0.0:ssh                        0.0.0.0:*        users:(("sshd",pid=2422,fd=3),("systemd",pid=1,fd=101))
    tcp       LISTEN     0          4096                                      0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=4),("systemd",pid=1,fd=269))
    tcp       LISTEN     0          4096                                   127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=17))
    tcp       LISTEN     0          4096                                      0.0.0.0:http                       0.0.0.0:*        users:(("docker-proxy",pid=1323,fd=7))
    tcp       LISTEN     0          50                                        0.0.0.0:microsoft-ds               0.0.0.0:*        users:(("smbd",pid=1007,fd=30))
    tcp       LISTEN     0          511                                       0.0.0.0:1885                       0.0.0.0:*        users:(("io.mqtt.0",pid=613007,fd=34))
    tcp       LISTEN     0          511                                       0.0.0.0:1883                       0.0.0.0:*        users:(("io.sonoff.0",pid=613163,fd=40))
    tcp       LISTEN     0          511                                       0.0.0.0:1882                       0.0.0.0:*        users:(("io.shelly.0",pid=614225,fd=36))
    tcp       LISTEN     0          511                                     127.0.0.1:9001                       0.0.0.0:*        users:(("iobroker.js-con",pid=612180,fd=23))
    tcp       LISTEN     0          4096                                    127.0.0.1:34169                      0.0.0.0:*        users:(("containerd",pid=764,fd=15))
    tcp       LISTEN     0          511                                     127.0.0.1:redis                      0.0.0.0:*        users:(("redis-server",pid=720,fd=20))
    tcp       LISTEN     0          4096                                127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=15))
    tcp       LISTEN     0          50                                           [::]:netbios-ssn                   [::]:*        users:(("smbd",pid=1007,fd=29))
    tcp       LISTEN     0          4096                                         [::]:ssh                           [::]:*        users:(("sshd",pid=2422,fd=4),("systemd",pid=1,fd=102))
    tcp       LISTEN     0          4096                                         [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=6),("systemd",pid=1,fd=271))
    tcp       LISTEN     0          4096                                         [::]:http                          [::]:*        users:(("docker-proxy",pid=1330,fd=7))
    tcp       LISTEN     0          50                                           [::]:microsoft-ds                  [::]:*        users:(("smbd",pid=1007,fd=28))
    tcp       LISTEN     0          4096                                            *:3000                             *:*        users:(("grafana",pid=1463,fd=26))
    tcp       LISTEN     0          511                                             *:61991                            *:*        users:(("io.harmony.0",pid=612834,fd=29))
    tcp       LISTEN     0          511                                         [::1]:redis                         [::]:*        users:(("redis-server",pid=720,fd=21))
    tcp       LISTEN     0          511                                             *:8087                             *:*        users:(("io.simple-api.0",pid=614626,fd=35))
    tcp       LISTEN     0          4096                                            *:8086                             *:*        users:(("influxd",pid=946,fd=358))
    tcp       LISTEN     0          511                                             *:8084                             *:*        users:(("io.ws.0",pid=614776,fd=34))
    tcp       LISTEN     0          511                                             *:8082                             *:*        users:(("io.web.0",pid=612361,fd=35))
    tcp       LISTEN     0          511                                             *:tproxy                           *:*        users:(("io.admin.0",pid=612200,fd=39))
    2026-05-21 11:00:07.069  - info: ical.1 (1343691) processing URL: xxx
    2026-05-21 11:00:08.171  - info: host.ioBroker instance system.adapter.ical.3 in version "1.20.1" started with pid 1343725
    2026-05-21 11:00:08.497  - info: ical.0 (1343653) Terminated (NO_ERROR): Without reason
    2026-05-21 11:00:09.021  - info: host.ioBroker instance system.adapter.ical.0 having pid 1343653 terminated with code 0 (NO_ERROR)
    2026-05-21 11:00:10.036  - info: ical.3 (1343725) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
    2026-05-21 11:00:10.837  - info: ical.3 (1343725) processing URL: Jannis https://calendar.google.com/calendar/ical/0815%40group.calendar.google.com/private-0815/basic.ics
    2026-05-21 11:00:12.326  - info: ical.1 (1343691) Terminated (NO_ERROR): Without reason
    2026-05-21 11:00:12.852  - info: host.ioBroker instance system.adapter.ical.1 having pid 1343691 terminated with code 0 (NO_ERROR)
    2026-05-21 11:00:16.030  - info: ical.3 (1343725) Terminated (NO_ERROR): Without reason
    2026-05-21 11:00:16.592  - info: host.ioBroker instance system.adapter.ical.3 having pid 1343725 terminated with code 0 (NO_ERROR)
    2026-05-21 11:00:31.696  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
    2026-05-21 11:00:57.303  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Home → in der Ladestation
    2026-05-21 11:04:57.953  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
    2026-05-21 11:10:13.946  - info: alexa2.0 (869734) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
    2026-05-21 11:10:15.455  - info: alexa2.0 (869734) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2026-05-21 11:15:00.094  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 1347962
    2026-05-21 11:15:01.965  - info: ical.1 (1347962) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
    2026-05-21 11:15:02.781  - info: ical.1 (1347962) processing URL: xxx
    2026-05-21 11:15:04.113  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 1348018
    2026-05-21 11:15:05.832  - info: ical.0 (1348018) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
    2026-05-21 11:15:06.610  - info: ical.0 (1348018) processing URL: xxx
    2026-05-21 11:15:08.103  - info: ical.1 (1347962) Terminated (NO_ERROR): Without reason
    2026-05-21 11:15:08.658  - info: host.ioBroker instance system.adapter.ical.1 having pid 1347962 terminated with code 0 (NO_ERROR)
    2026-05-21 11:15:11.941  - info: ical.0 (1348018) Terminated (NO_ERROR): Without reason
    2026-05-21 11:15:12.502  - info: host.ioBroker instance system.adapter.ical.0 having pid 1348018 terminated with code 0 (NO_ERROR)
    ./iob_diag.sh --de
    ```bash
    Script v.2026-05-20
    *** GRUNDSYSTEM ***
             Chassis: desktop 🖥️
    Docker          : false
    Unknown
    Kernel          : x86_64
    Userland        : 64bit
    Das System wurde vor 243 Tagen installiert (am 19.09.2025).
     11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
    CPU threads     : 4
    *** LEBENSZYKLUS STATUS ***
    Die Unterstützung für das Betriebssystem mit dem Codenamen 'noble' läuft aus. Es sollte in nächster Zeit auf die aktuelle Version 'resolute' mit Langzeitunterstützung gebracht werden.
    *** ZEIT UND ZEITZONEN ***
                   Local time: Thu 2026-05-21 11:21:33 CEST
               Universal time: Thu 2026-05-21 09:21:33 UTC
                     RTC time: Thu 2026-05-21 09:21:33
                  NTP service: active
              RTC in local TZ: no
    *** User und Gruppen ***
    User der 'iob diag' aufgerufen hat:
    pi
    HOME=/home/pi
    User der den 'js-controller' ausführt:
    iobrokerHOME=/home/iobroker
    Desktop:
    Session:                tty
    *** MEMORY ***
    Swap:           4.3G          0B        4.3G
             9221 M used memory
             9345 M active memory
             2737 M inactive memory
             2733 M free memory
              801 M buffer memory
             3462 M swap cache
             4095 M total swap
                0 M used swap
             4095 M free swap
    top - 11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
    Tasks: 235 total,   2 running, 233 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 18.6 us,  9.3 sy,  0.0 ni, 72.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15877.7 total,   2737.4 free,   9218.2 used,   4263.2 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6659.5 avail Mem
    Es wurden keine kritischen Fehler gefunden
    *** FILESYSTEM ***
    /var:
    5.3G    /var/
    4.4G    /var/log
    760M    /var/lib
    USB-Devices by-id:
    USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
    bevorzuge immer die Links 'by-id':
    Keine Geräte gefunden 'by-id'
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js ist korrekt installiert
    nodejs:
      Version table:
    Keine bekannten Sicherheitslücken in der Node.js-Version erkannt!
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152566)
    admin:          7.8.25
    javascript:     9.2.2
    Adapter State
    + instance is alive
    Objects and States
    Objects:        22292
    States:         22954
    Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
    Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
    Get:4 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 1s (7184 B/s)
    Offene Systemupdates: 2
    EDIT:
    Mit internem Zigbee kann ich nicht dienen. Ich nutze Zigbee2mqqt auf einer separaten Hardware
    #861
    @skvarel
    Ich hätte dich angechattet, aber das funktioniert nicht.
    Du hast im Ausschnitt des Logs private Daten drin.
    skvarelS 1 Antwort Letzte Antwort
      @skvarel
      skvarelS Offline
      skvarelS Offline
      skvarel
      #862
      @Thomas-Braun .. jetzt solltest du mit mir chatten können
      #TeamInventwo
      Unsere Adapter:
      • NashraN Offline
        NashraN Offline
        Nashra
        Most Active Forum Testing
        schrieb am zuletzt editiert von Nashra
        #863
        Hier von dem aktuellen Script...
        ```bash
        Script v.2026-05-20
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 7.0.2-4-pve
        OS is similar to:
        model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64bit
        System was installed 163 days ago (on 2025-12-08).
         11:54:32 up 18:17,  0 users,  load average: 2.96, 2.91, 2.78
        CPU threads     : 4
        Operating System is the current Debian stable version codenamed 'trixie'!
                       Local time: Thu 2026-05-21 11:54:32 CEST
                   Universal time: Thu 2026-05-21 09:54:32 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        jack
        HOME=/home/jack
        GROUPS=jack sudo users iobroker
        iobroker[sudo] password for jack:
        HOME=/home/iobroker
        Desktop:
        Session:
        *** MEMORY ***
        Mem:             12G        6.5G        5.2G        3.2M        1.2G        6.4G
        Swap:             0B          0B          0B
        Total:           12G        6.5G        5.2G
        Active iob-Instances:   51
                12288 M total memory
                 6165 M used memory
                 1229 M active memory
                 5857 M inactive memory
                 4936 M free memory
                    0 M buffer memory
                 1189 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 11:54:37 up 18:17,  0 users,  load average: 2.80, 2.88, 2.77
        Tasks:  77 total,   2 running,  75 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 48.8 us,  7.3 sy,  0.0 ni, 41.5 id,  0.0 wa,  0.0 hi,  2.4 si,  0.0 st
        MiB Mem :  12288.0 total,   4933.0 free,   6167.9 used,   1189.9 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6120.1 avail Mem
        dmesg: read kernel buffer failed: Operation not permitted
        *** FILESYSTEM ***
        /dev/mapper/pve-vm--100--disk--0 ext4       25G   12G   12G  52% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        none                             tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
        udev                             devtmpfs  6.9G     0  6.9G   0% /dev/tty
        tmpfs                            tmpfs     3.2G  104K  3.2G   1% /run
        tmpfs                            tmpfs     7.8G  3.0M  7.8G   1% /tmp
        /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
        /var:
        2.4G    /var/
        2.1G    /var/log/journal/d283c01113b6426689c9fe48dd9c672b
        2.1G    /var/log
        169M    /var/lib
        Archived and active journals take up 551M in the file system.
        1.7G    /opt/iobroker/backups/
        2.7G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/backup-objects
        816M    /opt/iobroker/iobroker-data/files
        655M    /opt/iobroker/iobroker-data/history
        269M    /opt/iobroker/iobroker-data/files/vis.0
        97M     /opt/iobroker/iobroker-data/states.jsonl
        58M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_11-37_states.jsonl.gz
        35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_09-37_states.jsonl.gz
        35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_07-37_states.jsonl.gz
        USB-Devices by-id:
        *** ZigBee Settings ***
        ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        Zigbee Network Settings on your coordinator / in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        === ZigBee Port Overview ===
        Instance        Configured Port                     Available by-id Port                Status
        zigbee.0        ...936c4ce259fb3e-if00-port0        ...936c4ce259fb3e-if00-port0        ✓ Matching
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
             20.19.2+dfsg-1+deb13u2 500
                500 http://security.debian.org trixie-security/main amd64 Packages
                500 http://deb.debian.org/debian trixie/main amd64 Packages
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 65841)
        js-controller:  7.0.7
        admin:          7.8.23
        javascript:     9.0.18
        nodejs modules from github:     10
        +-- iobroker.dwd@2.8.5 (git+ssh://git@github.com/arteck/ioBroker.dwd.git#d01fd75bacd6f2bd2c7b0612181e6118693bab71)
        +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
        +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
        +-- iobroker.logparser@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.logparser.git#266cccca93fd6f272ebce95e8f9e936363c30263)
        +-- iobroker.openmeteo-notify@0.1.3 (git+ssh://git@github.com/ipod86/ioBroker.openmeteo-notify.git#60b75eafea469372d5b30239f90b78adc67a5ef4)
        +-- iobroker.parcel@0.3.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#c579b7c8e878e72c56ae1c30c2fed9292b469895)
        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        +-- iobroker.tidy@0.1.1 (git+ssh://git@github.com/inventwo/ioBroker.tidy.git#3920e88695d8032773a7066efd0b4b4afdacbcfc)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
        Adapter State
          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
        + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
          system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
        + system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
          system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
        + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          system.adapter.labcom.0                 : labcom                : ioBroker                                 - disabled
        + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
        + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
        + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
          system.adapter.nut.2                    : nut                   : ioBroker                                 - disabled
        + system.adapter.nut.3                    : nut                   : ioBroker                                 -  enabled
        + system.adapter.open-meteo-weather.0     : open-meteo-weather    : ioBroker                                 -  enabled
          system.adapter.open-meteo-weather.1     : open-meteo-weather    : ioBroker                                 - disabled
        + system.adapter.openmeteo-notify.0       : openmeteo-notify      : ioBroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
        + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
        + system.adapter.pirate-weather.0         : pirate-weather        : ioBroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
        + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
          system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
        + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
          system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
        + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
          system.adapter.synology.2               : synology              : ioBroker                                 - disabled, port: 5000
        + system.adapter.tagesschau.0             : tagesschau            : ioBroker                                 -  enabled
          system.adapter.tidy.0                   : tidy                  : ioBroker                                 - disabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 443
          system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
          system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
          system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
          system.adapter.wettercom.0              : wettercom             : ioBroker                                 - disabled
        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
        + instance is alive
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
        │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
        │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
        │ 2       │ 'system.adapter.alias-manager'               │ 'alias-manager'               │ '2.1.0'  │ 'none'         │
        │ 3       │ 'system.adapter.ankersolix2'                 │ 'ankersolix2'                 │ '2.4.1'  │ 'none'         │
        │ 4       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.14' │ 'none'         │
        │ 5       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '5.0.0'  │ 'none'         │
        │ 6       │ 'system.adapter.brightsky'                   │ 'brightsky'                   │ '1.0.1'  │ 'none'         │
        │ 7       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
        │ 8       │ 'system.adapter.deyeidc'                     │ 'deyeidc'                     │ '0.3.1'  │ 'none'         │
        │ 9       │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
        │ 10      │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
        │ 11      │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'  │ 'none'         │
        │ 12      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.2'  │ 'none'         │
        │ 13      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
        │ 14      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
        │ 15      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
        │ 16      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.20.0' │ 'none'         │
        │ 17      │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0'  │ 'none'         │
        │ 18      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
        │ 19      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
        │ 20      │ 'system.adapter.icons-material-svg'          │ 'icons-material-svg'          │ '0.1.0'  │ 'none'         │
        │ 21      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
        │ 22      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
        │ 23      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
        │ 24      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
        │ 25      │ 'system.adapter.iot'                         │ 'iot'                         │ '5.0.12' │ 'none'         │
        │ 26      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
        │ 27      │ 'system.adapter.labcom'                      │ 'labcom'                      │ '0.1.4'  │ 'none'         │
        │ 28      │ 'system.adapter.lgtv'                        │ 'lgtv'                        │ '2.5.0'  │ 'none'         │
        │ 29      │ 'system.adapter.linux-control'               │ 'linux-control'               │ '1.1.5'  │ 'none'         │
        │ 30      │ 'system.adapter.logparser'                   │ 'logparser'                   │ '2.4.0'  │ 'none'         │
        │ 31      │ 'system.adapter.nut'                         │ 'nut'                         │ '1.7.0'  │ 'none'         │
        │ 32      │ 'system.adapter.open-meteo-weather'          │ 'open-meteo-weather'          │ '3.1.0'  │ 'none'         │
        │ 33      │ 'system.adapter.openmeteo-notify'            │ 'openmeteo-notify'            │ '0.1.3'  │ 'none'         │
        │ 34      │ 'system.adapter.openweathermap'              │ 'openweathermap'              │ '1.4.0'  │ 'none'         │
        │ 35      │ 'system.adapter.parcel'                      │ 'parcel'                      │ '0.3.1'  │ 'none'         │
        │ 36      │ 'system.adapter.ping'                        │ 'ping'                        │ '2.0.0'  │ 'none'         │
        │ 37      │ 'system.adapter.pirate-weather'              │ 'pirate-weather'              │ '0.8.0'  │ 'none'         │
        │ 38      │ 'system.adapter.pollenflug'                  │ 'pollenflug'                  │ '2.0.0'  │ 'none'         │
        │ 39      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.4.10' │ 'none'         │
        │ 40      │ 'system.adapter.rest-api'                    │ 'rest-api'                    │ '4.0.1'  │ 'none'         │
        │ 41      │ 'system.adapter.rssfeed'                     │ 'rssfeed'                     │ '4.0.3'  │ 'none'         │
        │ 42      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
        │ 43      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
        │ 44      │ 'system.adapter.snmp'                        │ 'snmp'                        │ '3.4.0'  │ 'none'         │
        │ 45      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
        │ 46      │ 'system.adapter.synology'                    │ 'synology'                    │ '3.1.0'  │ 'none'         │
        │ 47      │ 'system.adapter.tagesschau'                  │ 'tagesschau'                  │ '0.6.0'  │ 'none'         │
        │ 48      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
        │ 49      │ 'system.adapter.tidy'                        │ 'tidy'                        │ '0.1.1'  │ 'none'         │
        │ 50      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'  │ 'none'         │
        │ 51      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'  │ 'none'         │
        │ 52      │ 'system.adapter.tuya'                        │ 'tuya'                        │ '3.17.0' │ 'none'         │
        │ 53      │ 'system.adapter.unifi'                       │ 'unifi'                       │ '0.7.0'  │ 'none'         │
        │ 54      │ 'system.adapter.unifi-network'               │ 'unifi-network'               │ '1.4.0'  │ 'none'         │
        │ 55      │ 'system.adapter.upnp'                        │ 'upnp'                        │ '1.1.0'  │ 'none'         │
        │ 56      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
        │ 57      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'  │ 'none'         │
        │ 58      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'  │ 'none'         │
        │ 59      │ 'system.adapter.vis-fancyswitch'             │ 'vis-fancyswitch'             │ '1.1.0'  │ 'none'         │
        │ 60      │ 'system.adapter.vis-google-fonts'            │ 'vis-google-fonts'            │ '1.0.4'  │ 'none'         │
        │ 61      │ 'system.adapter.vis-history'                 │ 'vis-history'                 │ '1.0.0'  │ 'none'         │
        │ 62      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
        │ 63      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.3' │ 'none'         │
        │ 64      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '3.3.5'  │ 'none'         │
        │ 65      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'  │ 'none'         │
        │ 66      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
        │ 67      │ 'system.adapter.vis-map'                     │ 'vis-map'                     │ '1.1.2'  │ 'none'         │
        │ 68      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.94' │ 'none'         │
        │ 69      │ 'system.adapter.vis-owl'                     │ 'vis-owl'                     │ '0.2.13' │ 'none'         │
        │ 70      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'  │ 'none'         │
        │ 71      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
        │ 72      │ 'system.adapter.weather-warnings'            │ 'weather-warnings'            │ '0.10.1' │ 'none'         │
        │ 73      │ 'system.adapter.weatherunderground'          │ 'weatherunderground'          │ '3.7.0'  │ 'none'         │
        │ 74      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
        │ 75      │ 'system.adapter.wettercom'                   │ 'wettercom'                   │ '0.1.5'  │ 'none'         │
        │ 76      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.0.0'  │ 'none'         │
        │ 77      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.3.5'  │ 'none'         │
        Adapter    "admin"        : 7.8.23   , installed 7.8.23
        Adapter    "alias-manager": 2.1.0    , installed 2.1.0
        Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
        Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
        Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
        Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.2
        Adapter    "history"      : 4.0.0    , installed 4.0.0
        Adapter    "ical"         : 1.20.0   , installed 1.20.0
        Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "iot"          : 5.0.12   , installed 5.0.12
        Adapter    "javascript"   : 9.0.18   , installed 9.0.18
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.4.0    , installed 2.4.0
        Adapter    "nut"          : 1.7.0    , installed 1.7.0
        Adapter    "open-meteo-weather": 3.1.0, installed 3.1.0
        Adapter    "openweathermap": 1.4.0   , installed 1.4.0
        Adapter    "ping"         : 1.7.9    , installed 2.0.0
        Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
        Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
        Adapter    "rssfeed"      : 4.0.3    , installed 4.0.3
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "tagesschau"   : 0.6.0    , installed 0.6.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "unifi-network": 1.4.0    , installed 1.4.0
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
        Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "weather-warnings": 0.10.1, installed 0.10.1
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 8.0.0    , installed 8.0.0
        Adapter    "ws"           : 4.0.0    , installed 4.0.0
        Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
        Objects and States
        Objects:        58986
        States:         51570
        Hit:1 http://security.debian.org trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
        Pending systemupdates: 0
        udp        UNCONN      0            0                        0.0.0.0:sunrpc                  0.0.0.0:*          users:(("rpcbind",pid=133,fd=5),("systemd",pid=1,fd=35))
        udp        UNCONN      0            0                        0.0.0.0:49687                   0.0.0.0:*          users:(("io.snmp.0",pid=1075,fd=31))
        udp        UNCONN      0            0                        0.0.0.0:33873                   0.0.0.0:*          users:(("io.upnp.0",pid=1628,fd=30))
        udp        UNCONN      0            0                        0.0.0.0:1900                    0.0.0.0:*          users:(("io.upnp.0",pid=1628,fd=31))
        udp        UNCONN      0            0                   192.168.1.14:mdns                    0.0.0.0:*          users:(("io.tr-064.0",pid=1153,fd=62))
        udp        UNCONN      0            0                        0.0.0.0:coap                    0.0.0.0:*          users:(("io.shelly.0",pid=1032,fd=39))
        udp        UNCONN      0            0                        0.0.0.0:55521                   0.0.0.0:*          users:(("io.snmp.0",pid=1075,fd=30))
        udp        UNCONN      0            0                        0.0.0.0:6666                    0.0.0.0:*          users:(("io.tuya.0",pid=1169,fd=44))
        udp        UNCONN      0            0                        0.0.0.0:6667                    0.0.0.0:*          users:(("io.tuya.0",pid=1169,fd=45))
        udp        UNCONN      0            0                           [::]:sunrpc                     [::]:*          users:(("rpcbind",pid=133,fd=7),("systemd",pid=1,fd=37))
        tcp        LISTEN      0            511                 192.168.1.14:8082                    0.0.0.0:*          users:(("io.web.0",pid=1768,fd=30))
        tcp        LISTEN      0            1                        0.0.0.0:9999                    0.0.0.0:*          users:(("nc",pid=492379,fd=3))
        tcp        LISTEN      0            511                      0.0.0.0:1882                    0.0.0.0:*          users:(("io.shelly.1",pid=1048,fd=31))
        tcp        LISTEN      0            511                      0.0.0.0:9000                    0.0.0.0:*          users:(("iobroker.js-con",pid=153,fd=29))
        tcp        LISTEN      0            511                      0.0.0.0:9001                    0.0.0.0:*          users:(("iobroker.js-con",pid=153,fd=23))
        tcp        LISTEN      0            100                    127.0.0.1:smtp                    0.0.0.0:*          users:(("master",pid=308,fd=13))
        tcp        LISTEN      0            4096                     0.0.0.0:sunrpc                  0.0.0.0:*          users:(("rpcbind",pid=133,fd=4),("systemd",pid=1,fd=34))
        tcp        LISTEN      0            511                            *:8093                          *:*          users:(("io.rest-api.0",pid=1510,fd=29))
        tcp        LISTEN      0            511                            *:8087                          *:*          users:(("io.simple-api.0",pid=1527,fd=30))
        tcp        LISTEN      0            511                            *:8084                          *:*          users:(("io.ws.0",pid=1799,fd=29))
        tcp        LISTEN      0            511                            *:tproxy                        *:*          users:(("io.admin.0",pid=330,fd=30))
        tcp        LISTEN      0            100                        [::1]:smtp                       [::]:*          users:(("master",pid=308,fd=14))
        tcp        LISTEN      0            4096                           *:ssh                           *:*          users:(("sshd",pid=184,fd=3),("systemd",pid=1,fd=59))
        tcp        LISTEN      0            4096                        [::]:sunrpc                     [::]:*          users:(("rpcbind",pid=133,fd=6),("systemd",pid=1,fd=36))
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Arbeitszimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Arbeitszimmer: 18.31 g/m³
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Arbeitszimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Arbeitszimmer: 24.09 °C
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Arbeitszimmer] Fixed Calculation: RH_in=86%, Threshold=60 -> Empfehlung Lüften: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Arbeitszimmer] Absolute Humidity Calculation: AH_in=18.31 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Waeschezimmer: 13.09 g/m³
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Waeschezimmer: 18.57 °C
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Waeschezimmer] Fixed Calculation: RH_in=67%, Threshold=60 -> Empfehlung Lüften: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Waeschezimmer] Absolute Humidity Calculation: AH_in=13.09 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Flur gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Flur: 15.34 g/m³
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Flur gespeichert in 0_userdata.0.Raumklima.Taupunkt.Flur: 21.17 °C
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Flur] Fixed Calculation: RH_in=71.5%, Threshold=60 -> Empfehlung Lüften: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Flur] Absolute Humidity Calculation: AH_in=15.34 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Schlafzimmer: 13.14 g/m³
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Schlafzimmer: 18.66 °C
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Schlafzimmer] Fixed Calculation: RH_in=63%, Threshold=60 -> Empfehlung Lüften: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Schlafzimmer] Absolute Humidity Calculation: AH_in=13.14 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Werkstatt gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Werkstatt: 10.95 g/m³
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Werkstatt gespeichert in 0_userdata.0.Raumklima.Taupunkt.Werkstatt: 15.81 °C
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Werkstatt] Fixed Calculation: RH_in=50%, Threshold=60 -> Empfehlung Lüften: false
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Werkstatt] Absolute Humidity Calculation: AH_in=10.95 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: false
        2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: runCalculation ausgelöst (10-Minuten-Intervall)
        2026-05-21 11:50:44.476  - info: javascript.0 (452) script.js.Heizungen.Wohnzimmer: Stopping script
        2026-05-21 11:50:45.925  - info: javascript.0 (452) script.js.Heizungen.Büro: Stopping script
        2026-05-21 11:52:07.611  - info: parcel.0 (1855) Relogin to Amazon successful
        Gruß Ralf
        Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
