  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 285.6k Aufrufe 40 Beobachtet
    Hier das Ergebnis meines Master-LXC (trixie habe ich aber auf keinem lxc laufen).
    bash
    Skript v.2024-08-18
    *** BASE SYSTEM ***
    Static hostname: iobroker
          Icon name: computer-container
            Chassis: container ☐
     Virtualization: lxc
             Kernel: Linux 6.8.12-1-pve
       Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    18:04:19 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Your Operating System is the current Debian stable version 'bookworm'!
    *** Time and Time Zones ***
                  Local time: Sun 2024-08-18 18:04:19 CEST
              Universal time: Sun 2024-08-18 16:04:19 UTC
                    RTC time: n/a
                 NTP service: inactive
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    thomas
    HOME=/home/thomas
    GROUPS=thomas adm dialout sudo systemd-journal redis iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video redis
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            6.4G        3.2G        3.1G        126K        161M        3.3G
    Swap:             0B          0B          0B
    Total:          6.4G        3.2G        3.1G
    Active iob-Instances:   54
            6144 M total memory
            3022 M used memory
            2280 M active memory
             781 M inactive memory
            2967 M free memory
               0 M buffer memory
             154 M swap cache
               0 M total swap
               0 M used swap
               0 M free swap
    top - 18:04:20 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
    Tasks:  63 total,   2 running,  61 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   6144.0 total,   2966.1 free,   3023.8 used,    154.2 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   3120.2 avail Mem
    *** FAILED SERVICES ***
     UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                   Type      Size  Used Avail Use% Mounted on
    rpool/data/subvol-100-disk-1 zfs        32G  8.5G   24G  27% /
    none                         tmpfs     492K  4.0K  488K   1% /dev
    udev                         devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                        tmpfs     6.3G  120K  6.3G   1% /run
    tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1000
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET SOURCE                       FSTYPE OPTIONS
    /      rpool/data/subvol-100-disk-1 zfs    rw,noatime,xattr,posixacl,casesensitive
    /var:
    872M    /var/
    544M    /var/cache
    541M    /var/cache/apt
    494M    /var/cache/apt/archives
    212M    /var/log
    Archived and active journals take up 200.2M in the file system.
    /opt/iobroker/backups:
    138M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    832M    /opt/iobroker/iobroker-data/
    518M    /opt/iobroker/iobroker-data/files
    276M    /opt/iobroker/iobroker-data/backup-objects
    185M    /opt/iobroker/iobroker-data/files/javascript.admin
    169M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    15M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
    8.4M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
     Installed: 20.16.0-1nodesource1
     Candidate: 20.16.0-1nodesource1
     Version table:
    *** 20.16.0-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           100 /var/lib/dpkg/status
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2 500
           500 http://deb.debian.org/debian bookworm/main amd64 Packages
        18.19.0+dfsg-6~deb12u1 500
           500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     4
    +-- iobroker.bluelink@2.3.6 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#cfdb728c50b2373f05766dba34797a220302d309)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#fcdfef2d5daac95190d5ab2ba2ab5e213f937a41)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.alias-manager.0          : alias-manager         : rpizigbee                                -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : rpizigbee                                -  enabled
    + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
     system.adapter.daswetter.0              : daswetter             : rpizigbee                                -  enabled
    + system.adapter.denon.0                  : denon                 : rpizigbee                                -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
     system.adapter.dwd.0                    : dwd                   : rpizigbee                                -  enabled
    + system.adapter.enigma2.0                : enigma2               : rpizigbee                                -  enabled
    + system.adapter.enigma2.1                : enigma2               : rpizigbee                                -  enabled
     system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.heos.0                   : heos                  : rpizigbee                                -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
    + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
     system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
     system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
     system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
     system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
     system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : rpizigbee                                -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.nut.1                    : nut                   : iobroker                                 -  enabled
    + system.adapter.ocpp.0                   : ocpp                  : rpizigbee                                -  enabled, port: 9220
    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
    + system.adapter.pi-hole.1                : pi-hole               : rpizigbee                                -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.rpi2.0                   : rpi2                  : rpizigbee                                -  enabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : rpizigbee                                -  enabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.5                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : rpizigbee                                -  enabled
    + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 8883, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : rpizigbee                                -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : rpizigbee                                -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.vaillant.0               : vaillant              : rpizigbee                                -  enabled
     system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
     system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
     system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
     system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
     system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
     system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
     system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yeelight-2.0             : yeelight-2            : rpizigbee                                -  enabled
    + system.adapter.zigbee.0                 : zigbee                : rpizigbee                                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ '(beta) latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'stable-live'   │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 3       │ 'latest-live'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "backitup"     : 3.0.16   , installed 3.0.16
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "harmony"      : 1.4.0    , installed 1.4.0
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
    Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "samsung"      : 0.6.0    , installed 0.6.0
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scenes"       : 3.2.1    , installed 3.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "solax"        : 0.9.9    , installed 0.9.9
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        23058
    States:         24327
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          35104      131/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32330      1/init
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      110        32536      124/redis-server 0.
    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       39136      393/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       34416      137/iobroker.js-con
    tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      1001       67265983   3623001/io.sonoff.0
    tcp        0      0 192.168.178.10:2001     0.0.0.0:*               LISTEN      1001       39803      568/io.hm-rpc.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44592      880/io.fullybrowser
    tcp6       0      0 :::22                   :::*                    LISTEN      0          35115      131/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          32332      1/init
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       47625      1034/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9871275    531497/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34578      156/io.admin.0
    tcp6       0      0 :::6556                 :::*                    LISTEN      0          32456      1/init
    tcp6       0      0 ::1:6379                :::*                    LISTEN      110        32537      124/redis-server 0.
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       39003      268/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       92149192   770498/io.chromecas
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       39004      268/io.harmony.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32331      1/init
    udp6       0      0 :::111                  :::*                                0          32333      1/init
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 10: Fenster Konferenzraum:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 11: Fenster Gästezimmer oben:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 12: Fenster Bad oben:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 13: Fenster Fitness:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 14: Fenster Gäste unten:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 15: Postkasten:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 16: Heizung Küche:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 17: Heizung Bad unten:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 18: Heizung Schlafzimmer:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 19: Heizung Wohnzimmer:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 20: Heizung Gästezimmer oben:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 21: Heizung Konferenzraum:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 22: Heizung Bad oben:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 23: Heizung Büro:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 24: Heizung Fitnessraum:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 25: Heizung Gästezimmer unten:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 26: Presence Kueche:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 27: Lichtsensor:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 28: Sensor Bad unten:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 29: Sensor Wohnzimmer:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 30: Außenthermometer:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 31: Wetterstation:0.LOW_BAT: true
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 32: Heizung Bad oben 2:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Text: Wetterstation:0.LOW_BAT
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Anzahl Geräte: 34 # davon LOWBAT erkannt: 1
    #621
    @meister-mopper sagte in iob diag - Skript:
    Trixie ist ja auch eine Ausgabe von meinem System....
      Meister MopperM Offline
      Meister Mopper
      #622
      @thomas-braun sagte in iob diag - Skript:
      I know, es war nur eine Ergänzung für Mitleser.
      Proxmox und HA ...
        Neuer Diagnosepunkt
        'Life Cycle Status'
        ist drin. Können bitte User von Dockern und LXCs da mal schauen ob und mit welchen Meldungen da im Langtext und in der Zusammenfassung da sowas erscheint?
        (Bitte wie im ersten Eröffungsposting in diesem Thread gezeigt direkt vom github laden).
        Your Operating System codenamed 'trixie' is a testing release! Please use it only for testing purposes!
        Gleiche Meldung dann in der Summary.
        Danke schön!
        FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        #623
        @thomas-braun Hi,
        bei mir wird das ausgegeben:
        ======== Start marking the full check here =========
        ```bash
        Skript v.2024-08-18
        *** BASE SYSTEM ***
         Static hostname: ioB-Prod-Testsystem
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 6.5.13-1-pve
        OS is similar to: debian
        model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         19:30:53 up 15 days,  5:33,  1 user,  load average: 3.39, 2.72, 2.50
        CPU threads: 4
        Your Operating System 'jammy focal' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
        Das ist das OS auf dem Testsystem
        Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 6.5.13-1-pve x86_64)
         * Documentation:  https://help.ubuntu.com
         * Management:     https://landscape.canonical.com
         * Support:        https://ubuntu.com/pro
        Last login: Sun Aug 18 19:27:48 2024 from 192.168.178.128
        proxmox@ioB-Prod-Testsystem:~$ ^C
        proxmox@ioB-Prod-Testsystem:~$ lsb_release -a
        No LSB modules are available.
        Distributor ID: Ubuntu
        Description:    Ubuntu 22.04.4 LTS
        Release:        22.04
        Codename:       jammy
        • Ist die Ausgabe jammy focal von iob diag richtig oder müsste es nur jammy sein?
        • Laut dieser Liste https://wiki.ubuntu.com/Releases wird jammy noch bis 2027 gepflegt. Prüft iob diag ob es nur eine aktuellere Version gibt oder auf welcher Basis wird die Aussage "is an aging Ubuntu LTS release" generiert?
        • FeuersturmF Feuersturm
          @thomas-braun Hi,
          ```bash
          Skript v.2024-08-18
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          Release:        22.04
          Codename:       jammy
          #624
          @feuersturm sagte in iob diag - Skript:
          Das ist die Ausgabe von
          lsb_release -sc
          Ja, deswegen ja auch die Aussage, dass deine Distribution nicht das aktuelle LTS-Release ist, aber noch unterhalten wird.
            lsb_release -sc
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #625
            @thomas-braun Der Befehl
            proxmox@ioB-Prod-Testsystem:~$ lsb_release -sc
            jammy
            gibt aber nur jammy aus und nicht jammy focal
              jammy
              #626
              @feuersturm
              Muss ich mal schauen wo das herkommt. Bist bislang der erste bei dem das passiert.
                jammy
                #627
                Hab es im Code gefixt. Variablen vertauscht... ;-)
                  FeuersturmF Offline
                  FeuersturmF Offline
                  Feuersturm
                  #628
                  @thomas-braun Das sieht besser aus :-)
                  Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to
                    #629
                    @feuersturm
                    In der Summary gleichlautend?
                    Ich hab da noch einen Knoten drin, scheint mir.
                      @feuersturm
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #630
                      @thomas-braun Sieht gut aus bei mir:
                      Skript v.2024-08-18
                      *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       21:22:28 up 15 days,  7:24,  1 user,  load average: 1.95, 2.04, 2.25
                      CPU threads: 4
                      Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                      und Summary
                                              v.2024-08-18
                               Chassis: container
                        Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               64 bit
                      Timezone:               Europe/Berlin (CEST, +0200)
                      User-ID:                1001
                      Pending OS-Updates:     0
                      Pending iob updates:    2
                      Nodejs-Installation:
                      /usr/bin/npm            10.8.1
                      /usr/bin/npx            10.8.1
                      Recommended versions are nodejs 20.16.0 and npm 10.8.1
                      MEMORY:
                      Mem:            8.0G        2.2G        4.8G        0.0K        1.0G        5.8G
                      Swap:           2.0G        1.1G        976M
                      Total:           10G        3.3G        5.8G
                      Active iob-Instances:   31
                      ioBroker Core:          js-controller           6.0.10
                                              admin                   7.0.23
                      Objects type: jsonl
                      States  type: jsonl
                      + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
                      + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                      Objects:                14532
                      States:                 12032
                      Size of iob-Database:
                      27M     /opt/iobroker/iobroker-data/objects.jsonl
                      17M     /opt/iobroker/iobroker-data/objects.json.migrated
                      17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
                      1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
                      19M     /opt/iobroker/iobroker-data/states.jsonl
                      6.3M    /opt/iobroker/iobroker-data/states.json.migrated
                      6.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                      0       /opt/iobroker/iobroker-data/states.json.broken
                        Skript v.2024-08-18
                        *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                        und Summary
                                                v.2024-08-18
                                 Chassis: container
                          Virtualization: lxc
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               64 bit
                        User-ID:                1001
                        /usr/bin/npm            10.8.1
                        /usr/bin/npx            10.8.1
                        MEMORY:
                                                admin                   7.0.23
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                14532
                        States:                 12032
                        #631
                        @feuersturm rein aus Neugier
                        welche Farbe hat die Zeile?
                          Skript v.2024-08-18
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                          und Summary
                                                  v.2024-08-18
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               64 bit
                          User-ID:                1001
                          /usr/bin/npm            10.8.1
                          /usr/bin/npx            10.8.1
                          MEMORY:
                                                  admin                   7.0.23
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                14532
                          States:                 12032
                          #632
                          @feuersturm
                          Danke. Bei 'testing releases' wird da warum auch immer was unterschiedliches angezeigt. Und ich verstehe gerade nicht warum...
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #633
                            @homoran sagte in iob diag - Skript:
                            Bei der Langfassung und Summary ist die Information Gelb,
                              #634
                              So soll es sein. Stabile Releases wären Grün, abgekündigte wären Rot.
                              NashraN NegaleinN 2 Antworten Letzte Antwort
                                NashraN Offline
                                NashraN Offline
                                Nashra
                                Most Active Forum Testing
                                #635
                                Moin, hier mit LXC
                                                        v.2024-08-18_5
                                 Static hostname: ioBroker
                                  Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1000
                                /usr/bin/npm            10.8.1
                                /usr/bin/npx            10.8.1
                                MEMORY:
                                Mem:             12G        4.1G        7.9G        122K        873M        8.7G
                                Swap:             0B          0B          0B
                                Total:           12G        4.1G        7.9G
                                Active iob-Instances:   45
                                ioBroker Core:          js-controller           6.0.9
                                                        admin                   7.0.22
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                                Objects:                54190
                                States:                 50980
                                86M     /opt/iobroker/iobroker-data/objects.jsonl
                                88M     /opt/iobroker/iobroker-data/states.jsonl
                                Gruß Ralf
                                Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #636
                                  hier ein LXC
                                                          v.2024-08-18_5
                                           Chassis: container
                                    Virtualization: lxc
                                            Kernel: Linux 5.15.30-2-pve
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               64 bit
                                  Timezone:               Europe/Vienna (CEST, +0200)
                                  User-ID:                1001
                                  Pending OS-Updates:     31
                                  Pending iob updates:    4
                                  /usr/bin/nodejs         v20.15.0
                                  /usr/bin/node           v20.15.0
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  /usr/bin/corepack       0.28.1
                                  MEMORY:
                                  Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
                                  Swap:           3.1G        1.1G        2.0G
                                  Total:           13G        5.8G        6.4G
                                  Active iob-Instances:   60
                                  Active repo(s): Beta (latest)
                                  ioBroker Core:          js-controller           5.0.19
                                                          admin                   7.0.24
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                32233
                                  States:                 31404
                                  53M     /opt/iobroker/iobroker-data/objects.jsonl
                                  29M     /opt/iobroker/iobroker-data/objects.json.migrated
                                  29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  0       /opt/iobroker/iobroker-data/objects.json.broken
                                  54M     /opt/iobroker/iobroker-data/states.jsonl
                                  9.4M    /opt/iobroker/iobroker-data/states.json.migrated
                                  9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                                  ° Fixer ---> iob fix
                                  • S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #637
                                    Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
                                    Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    HINT:
                                    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                    tcp
                                    HINT:
                                    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                    tcp
                                    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                    ioBroker Backup Analyzer
                                    • S Shadowhunter23
                                      USB-Devices by-id:
                                      HINT:
                                      tcp
                                      HINT:
                                      tcp
                                      HINT:
                                      tcp
                                      #638
                                      @shadowhunter23
                                      Ich war davon ausgeganen, das 3 zigbee-Instanzen ausreichend sein sollten.
                                      Ich würde da auch eher per Router ein Zigbee-Netz draus weben, an deiner Stelle.
                                      Und ich vergleiche auch nur die EInträge von 'by-id' mit den Ports aus dem Adapter.
                                      Ob die Einstellungen dann die richtigen sind musst du selber prüfen.
                                      Ist ja auch nur ein Hinweis.
                                      Kurz: Won't fix.
                                        @shadowhunter23
                                        Kurz: Won't fix.
                                        S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        schrieb am zuletzt editiert von Shadowhunter23
                                        #639
                                        Auch hier, Won't fix 🙂 . Das ist schon mit Absicht so gemacht.
                                        Kurz: Won't fix.
                                        OK, war ja auch nur ein Hinweis.
                                        • S Shadowhunter23
                                          Kurz: Won't fix.
                                          #640
                                          Da ich das Skript in den letzten Tagen um einige Funktionen (Anlage eines users, wenn es als root oder 'iobroker' aufgerufen wird; setzen der Zeitzone, wenn eine vermutlich falsche (wie Europe/London oder UTC) erkannt wird) und kritische Fehler im Kernel Ring Puffer (dmesg) jetzt gemeldet werden würde ich gerne ein paar Läufe auf anderen Systemen als meinen Testkisten sehen. Insbesondere LXC und Docker ist da interessant für mich.
                                          Es gibt auch ein paar Meldungen auf deutsch, wenn das Skript mit der Option '--de' aufgerufen wird. Auch dazu wäre Feedback willkommen. Gleich vorweg: Es kann keine vollständige Übersetzung geben, da einige Kommandos nur englische Ausgaben liefern.
                                          Bitte diese Beta-Version wie im ersten Beitrag gezeigt lokal ausführen, im ioBroker selber ist diese Version v.2024-09-07 natürlich noch nicht implementiert.
