  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.7k Aufrufe 40 Beobachtet
  • Meister MopperM Online
    Meister Mopper
    #619
    Hier das Ergebnis meines Master-LXC (trixie habe ich aber auf keinem lxc laufen).
    bash
    Skript v.2024-08-18
    *** BASE SYSTEM ***
    Static hostname: iobroker
          Icon name: computer-container
            Chassis: container ☐
     Virtualization: lxc
             Kernel: Linux 6.8.12-1-pve
       Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    18:04:19 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Your Operating System is the current Debian stable version 'bookworm'!
    *** Time and Time Zones ***
                  Local time: Sun 2024-08-18 18:04:19 CEST
              Universal time: Sun 2024-08-18 16:04:19 UTC
                    RTC time: n/a
                 NTP service: inactive
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    thomas
    HOME=/home/thomas
    GROUPS=thomas adm dialout sudo systemd-journal redis iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video redis
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            6.4G        3.2G        3.1G        126K        161M        3.3G
    Swap:             0B          0B          0B
    Total:          6.4G        3.2G        3.1G
    Active iob-Instances:   54
            6144 M total memory
            3022 M used memory
            2280 M active memory
             781 M inactive memory
            2967 M free memory
               0 M buffer memory
             154 M swap cache
               0 M total swap
               0 M used swap
               0 M free swap
    top - 18:04:20 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
    Tasks:  63 total,   2 running,  61 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   6144.0 total,   2966.1 free,   3023.8 used,    154.2 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   3120.2 avail Mem
    *** FAILED SERVICES ***
     UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                   Type      Size  Used Avail Use% Mounted on
    rpool/data/subvol-100-disk-1 zfs        32G  8.5G   24G  27% /
    none                         tmpfs     492K  4.0K  488K   1% /dev
    udev                         devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                        tmpfs     6.3G  120K  6.3G   1% /run
    tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1000
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET SOURCE                       FSTYPE OPTIONS
    /      rpool/data/subvol-100-disk-1 zfs    rw,noatime,xattr,posixacl,casesensitive
    /var:
    872M    /var/
    544M    /var/cache
    541M    /var/cache/apt
    494M    /var/cache/apt/archives
    212M    /var/log
    Archived and active journals take up 200.2M in the file system.
    /opt/iobroker/backups:
    138M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    832M    /opt/iobroker/iobroker-data/
    518M    /opt/iobroker/iobroker-data/files
    276M    /opt/iobroker/iobroker-data/backup-objects
    185M    /opt/iobroker/iobroker-data/files/javascript.admin
    169M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    15M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
    8.4M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
     Installed: 20.16.0-1nodesource1
     Candidate: 20.16.0-1nodesource1
     Version table:
    *** 20.16.0-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2 500
           500 http://deb.debian.org/debian bookworm/main amd64 Packages
        18.19.0+dfsg-6~deb12u1 500
           500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     4
    +-- iobroker.bluelink@2.3.6 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#cfdb728c50b2373f05766dba34797a220302d309)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#fcdfef2d5daac95190d5ab2ba2ab5e213f937a41)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.alias-manager.0          : alias-manager         : rpizigbee                                -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : rpizigbee                                -  enabled
    + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
     system.adapter.daswetter.0              : daswetter             : rpizigbee                                -  enabled
    + system.adapter.denon.0                  : denon                 : rpizigbee                                -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
     system.adapter.dwd.0                    : dwd                   : rpizigbee                                -  enabled
    + system.adapter.enigma2.0                : enigma2               : rpizigbee                                -  enabled
    + system.adapter.enigma2.1                : enigma2               : rpizigbee                                -  enabled
     system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.heos.0                   : heos                  : rpizigbee                                -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
    + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
     system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
     system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
     system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
     system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
     system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : rpizigbee                                -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.nut.1                    : nut                   : iobroker                                 -  enabled
    + system.adapter.ocpp.0                   : ocpp                  : rpizigbee                                -  enabled, port: 9220
    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
    + system.adapter.pi-hole.1                : pi-hole               : rpizigbee                                -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.rpi2.0                   : rpi2                  : rpizigbee                                -  enabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : rpizigbee                                -  enabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.5                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : rpizigbee                                -  enabled
    + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 8883, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : rpizigbee                                -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : rpizigbee                                -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.vaillant.0               : vaillant              : rpizigbee                                -  enabled
     system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
     system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
     system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
     system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
     system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
     system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
     system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : rpizigbee                                -  enabled
    + system.adapter.zigbee.0                 : zigbee                : rpizigbee                                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ '(beta) latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'stable-live'   │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 3       │ 'latest-live'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "backitup"     : 3.0.16   , installed 3.0.16
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "harmony"      : 1.4.0    , installed 1.4.0
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
    Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "samsung"      : 0.6.0    , installed 0.6.0
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scenes"       : 3.2.1    , installed 3.2.1
    Adapter    "solax"        : 0.9.9    , installed 0.9.9
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        23058
    States:         24327
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          35104      131/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32330      1/init
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      110        32536      124/redis-server 0.
    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       39136      393/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       34416      137/iobroker.js-con
    tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      1001       67265983   3623001/io.sonoff.0
    tcp        0      0 192.168.178.10:2001     0.0.0.0:*               LISTEN      1001       39803      568/io.hm-rpc.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44592      880/io.fullybrowser
    tcp6       0      0 :::22                   :::*                    LISTEN      0          35115      131/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          32332      1/init
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       47625      1034/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9871275    531497/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34578      156/io.admin.0
    tcp6       0      0 :::6556                 :::*                    LISTEN      0          32456      1/init
    tcp6       0      0 ::1:6379                :::*                    LISTEN      110        32537      124/redis-server 0.
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       39003      268/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       92149192   770498/io.chromecas
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       39004      268/io.harmony.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32331      1/init
    udp6       0      0 :::111                  :::*                                0          32333      1/init
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 10: Fenster Konferenzraum:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 11: Fenster Gästezimmer oben:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 12: Fenster Bad oben:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 13: Fenster Fitness:0.LOW_BAT: false
    2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 14: Fenster Gäste unten:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 15: Postkasten:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 16: Heizung Küche:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 17: Heizung Bad unten:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 18: Heizung Schlafzimmer:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 19: Heizung Wohnzimmer:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 20: Heizung Gästezimmer oben:0.LOW_BAT: false
    2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 21: Heizung Konferenzraum:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 22: Heizung Bad oben:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 23: Heizung Büro:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 24: Heizung Fitnessraum:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 25: Heizung Gästezimmer unten:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 26: Presence Kueche:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 27: Lichtsensor:0.LOW_BAT: false
    2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 28: Sensor Bad unten:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 29: Sensor Wohnzimmer:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 30: Außenthermometer:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 31: Wetterstation:0.LOW_BAT: true
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 32: Heizung Bad oben 2:0.LOW_BAT: false
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Text: Wetterstation:0.LOW_BAT
    2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Anzahl Geräte: 34 # davon LOWBAT erkannt: 1
    Proxmox und HA ...
    • DolomitiD Offline
      DolomitiD Offline
      Dolomiti
      #620
      @Thomas-Braun
      OK. In der Langfassung kommt der Text weiter oben.
      Bei mir also ok
      Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
        bash
        Skript v.2024-08-18
        *** BASE SYSTEM ***
         Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                        RTC time: n/a
                 RTC in local TZ: no
        thomas
        HOME=/home/thomas
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                6144 M total memory
                3022 M used memory
                2967 M free memory
                   0 M buffer memory
                 154 M swap cache
                   0 M total swap
                   0 M used swap
                   0 M free swap
        *** FILESYSTEM ***
        /var:
        872M    /var/
        544M    /var/cache
        541M    /var/cache/apt
        212M    /var/log
        USB-Devices by-id:
        HINT:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        nodejs:
         Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        admin:          7.0.22
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        23058
        States:         24327
        Pending Updates: 0
        #621
        @meister-mopper sagte in iob diag - Skript:
        Trixie ist ja auch eine Ausgabe von meinem System....
          Meister Mopper
          #622
          @thomas-braun sagte in iob diag - Skript:
          I know, es war nur eine Ergänzung für Mitleser.
          Proxmox und HA ...
            Neuer Diagnosepunkt
            'Life Cycle Status'
            ist drin. Können bitte User von Dockern und LXCs da mal schauen ob und mit welchen Meldungen da im Langtext und in der Zusammenfassung da sowas erscheint?
            (Bitte wie im ersten Eröffungsposting in diesem Thread gezeigt direkt vom github laden).
            Your Operating System codenamed 'trixie' is a testing release! Please use it only for testing purposes!
            Gleiche Meldung dann in der Summary.
            Danke schön!
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #623
            @thomas-braun Hi,
            bei mir wird das ausgegeben:
            ```bash
            Skript v.2024-08-18
            *** BASE SYSTEM ***
             Static hostname: ioB-Prod-Testsystem
                     Chassis: container
              Virtualization: lxc
            Operating System: Ubuntu 22.04.4 LTS
                      Kernel: Linux 6.5.13-1-pve
            OS is similar to: debian
            model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             19:30:53 up 15 days,  5:33,  1 user,  load average: 3.39, 2.72, 2.50
            CPU threads: 4
            Your Operating System 'jammy focal' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
            Das ist das OS auf dem Testsystem
            Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 6.5.13-1-pve x86_64)
             * Documentation:  https://help.ubuntu.com
             * Management:     https://landscape.canonical.com
             * Support:        https://ubuntu.com/pro
            Last login: Sun Aug 18 19:27:48 2024 from 192.168.178.128
            proxmox@ioB-Prod-Testsystem:~$ ^C
            proxmox@ioB-Prod-Testsystem:~$ lsb_release -a
            No LSB modules are available.
            Distributor ID: Ubuntu
            Description:    Ubuntu 22.04.4 LTS
            Release:        22.04
            Codename:       jammy
            • Ist die Ausgabe jammy focal von iob diag richtig oder müsste es nur jammy sein?
            • Laut dieser Liste https://wiki.ubuntu.com/Releases wird jammy noch bis 2027 gepflegt. Prüft iob diag ob es nur eine aktuellere Version gibt oder auf welcher Basis wird die Aussage "is an aging Ubuntu LTS release" generiert?
            • FeuersturmF Feuersturm
              @thomas-braun Hi,
              ```bash
              Skript v.2024-08-18
              *** BASE SYSTEM ***
                       Chassis: container
                Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
              Release:        22.04
              Codename:       jammy
              #624
              @feuersturm sagte in iob diag - Skript:
              Das ist die Ausgabe von
              lsb_release -sc
              Ja, deswegen ja auch die Aussage, dass deine Distribution nicht das aktuelle LTS-Release ist, aber noch unterhalten wird.
                lsb_release -sc
                FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                #625
                @thomas-braun Der Befehl
                proxmox@ioB-Prod-Testsystem:~$ lsb_release -sc
                jammy
                gibt aber nur jammy aus und nicht jammy focal
                  jammy
                  #626
                  @feuersturm
                  Muss ich mal schauen wo das herkommt. Bist bislang der erste bei dem das passiert.
                    jammy
                    #627
                    Hab es im Code gefixt. Variablen vertauscht... ;-)
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #628
                      @thomas-braun Das sieht besser aus :-)
                      Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to
                        #629
                        @feuersturm
                        In der Summary gleichlautend?
                        Ich hab da noch einen Knoten drin, scheint mir.
                          @feuersturm
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #630
                          @thomas-braun Sieht gut aus bei mir:
                          Skript v.2024-08-18
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           21:22:28 up 15 days,  7:24,  1 user,  load average: 1.95, 2.04, 2.25
                          CPU threads: 4
                          Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                          und Summary
                                                  v.2024-08-18
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               64 bit
                          User-ID:                1001
                          Pending OS-Updates:     0
                          Pending iob updates:    2
                          Nodejs-Installation:
                          /usr/bin/npm            10.8.1
                          /usr/bin/npx            10.8.1
                          Recommended versions are nodejs 20.16.0 and npm 10.8.1
                          MEMORY:
                          Mem:            8.0G        2.2G        4.8G        0.0K        1.0G        5.8G
                          Swap:           2.0G        1.1G        976M
                          Total:           10G        3.3G        5.8G
                          Active iob-Instances:   31
                          ioBroker Core:          js-controller           6.0.10
                                                  admin                   7.0.23
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
                          + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                          Objects:                14532
                          States:                 12032
                          Size of iob-Database:
                          27M     /opt/iobroker/iobroker-data/objects.jsonl
                          17M     /opt/iobroker/iobroker-data/objects.json.migrated
                          17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
                          1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
                          19M     /opt/iobroker/iobroker-data/states.jsonl
                          6.3M    /opt/iobroker/iobroker-data/states.json.migrated
                          6.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                          0       /opt/iobroker/iobroker-data/states.json.broken
                            Skript v.2024-08-18
                            *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                            und Summary
                                                    v.2024-08-18
                                     Chassis: container
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1001
                            /usr/bin/npm            10.8.1
                            /usr/bin/npx            10.8.1
                            MEMORY:
                                                    admin                   7.0.23
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                14532
                            States:                 12032
                            #631
                            @feuersturm rein aus Neugier
                            welche Farbe hat die Zeile?
                              Skript v.2024-08-18
                              *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                              und Summary
                                                      v.2024-08-18
                                       Chassis: container
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              User-ID:                1001
                              /usr/bin/npm            10.8.1
                              /usr/bin/npx            10.8.1
                              MEMORY:
                                                      admin                   7.0.23
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                14532
                              States:                 12032
                              #632
                              @feuersturm
                              Danke. Bei 'testing releases' wird da warum auch immer was unterschiedliches angezeigt. Und ich verstehe gerade nicht warum...
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #633
                                @homoran sagte in iob diag - Skript:
                                Bei der Langfassung und Summary ist die Information Gelb,
                                  #634
                                  So soll es sein. Stabile Releases wären Grün, abgekündigte wären Rot.
                                  NashraN NegaleinN 2 Antworten Letzte Antwort
                                    NashraN Offline
                                    NashraN Offline
                                    Nashra
                                    Most Active Forum Testing
                                    #635
                                    Moin, hier mit LXC
                                                            v.2024-08-18_5
                                     Static hostname: ioBroker
                                      Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1000
                                    /usr/bin/npm            10.8.1
                                    /usr/bin/npx            10.8.1
                                    MEMORY:
                                    Mem:             12G        4.1G        7.9G        122K        873M        8.7G
                                    Swap:             0B          0B          0B
                                    Total:           12G        4.1G        7.9G
                                    Active iob-Instances:   45
                                    ioBroker Core:          js-controller           6.0.9
                                                            admin                   7.0.22
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                                    Objects:                54190
                                    States:                 50980
                                    86M     /opt/iobroker/iobroker-data/objects.jsonl
                                    88M     /opt/iobroker/iobroker-data/states.jsonl
                                    Gruß Ralf
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #636
                                      hier ein LXC
                                                              v.2024-08-18_5
                                               Chassis: container
                                        Virtualization: lxc
                                                Kernel: Linux 5.15.30-2-pve
                                      Installation:           lxc
                                      Kernel:                 x86_64
                                      Userland:               64 bit
                                      Timezone:               Europe/Vienna (CEST, +0200)
                                      User-ID:                1001
                                      Pending OS-Updates:     31
                                      Pending iob updates:    4
                                      /usr/bin/nodejs         v20.15.0
                                      /usr/bin/node           v20.15.0
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.1
                                      MEMORY:
                                      Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
                                      Swap:           3.1G        1.1G        2.0G
                                      Total:           13G        5.8G        6.4G
                                      Active iob-Instances:   60
                                      Active repo(s): Beta (latest)
                                      ioBroker Core:          js-controller           5.0.19
                                                              admin                   7.0.24
                                      Objects type: jsonl
                                      States  type: jsonl
                                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                32233
                                      States:                 31404
                                      53M     /opt/iobroker/iobroker-data/objects.jsonl
                                      29M     /opt/iobroker/iobroker-data/objects.json.migrated
                                      29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                      0       /opt/iobroker/iobroker-data/objects.json.broken
                                      54M     /opt/iobroker/iobroker-data/states.jsonl
                                      9.4M    /opt/iobroker/iobroker-data/states.json.migrated
                                      9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                      Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                                      ° Fixer ---> iob fix
                                      • S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        #637
                                        Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
                                        Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
                                        USB-Devices by-id:
                                        HINT:
                                        tcp
                                        HINT:
                                        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        HINT:
                                        Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                        ioBroker Backup Analyzer
                                        • S Shadowhunter23
                                          USB-Devices by-id:
                                          HINT:
                                          tcp
                                          HINT:
                                          tcp
                                          HINT:
                                          tcp
                                          #638
                                          @shadowhunter23
                                          Ich war davon ausgeganen, das 3 zigbee-Instanzen ausreichend sein sollten.
                                          Ich würde da auch eher per Router ein Zigbee-Netz draus weben, an deiner Stelle.
                                          Und ich vergleiche auch nur die EInträge von 'by-id' mit den Ports aus dem Adapter.
                                          Ob die Einstellungen dann die richtigen sind musst du selber prüfen.
                                          Ist ja auch nur ein Hinweis.
                                          Kurz: Won't fix.
