  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • ArmilarA Armilar
    @elluminatus sagte in SONOFF NSPanel mit Lovelace UI:
    @armilar Habe einen Fehler bekommen:
    22:59:38.608	error	javascript.0 (10558) script.js.common.NSPanel.LMS: ReferenceError: aliasPath is not defined
    22:59:38.608	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:39:13
    22:59:38.608	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:51:3
    Versuche noch mal das... Hatte auch vergessen zu sagen, dass im JavaScript-Adapter 1c74d935-efdc-4f16-acd0-2fceb3f11c10-image.png aktiviert sein muss.
    const aliasPath = 'alias.0.NSPanel_1.Media';  // ggfs. Anpassen
    const aliasDevice = 'SqueezeBoxRPC';       // ggfs. Anpassen
    //Ergibt alias.0.NSPanel_1.Media.SqueezeBoxRPC
    const squeezeBoxInstanz = 'squeezeboxrpc.0.Players.'; // Anpasssen, wenn nicht Instanz 0
    const squeezeBoxDevice = 'piCoreKUE'; // Anpassen an dein eigenes Device
    var typeAlias, read, write, nameAlias, role, desc, min, max, unit, states, custom;
    function createAlias(idDst, idName,idSrc, idRd, idType, idRole, idAliasType) {
      if(existsState(idDst)) log(idDst + ' schon vorhanden !', 'warn');
      else {
         var obj = {};
         obj.type = idType;
         obj.common = getObject(idSrc).common;
         obj.common.alias = {};
         if(idRd) {
             obj.common.alias.id = {};
             obj.common.alias.id.read = idRd;
             obj.common.alias.id.write = idSrc;
             obj.common.read = true;
         } else obj.common.alias.id = idSrc;
         obj.common.type = idAliasType;
         if(obj.common.read !== false && read) obj.common.alias.read = read;
         if(obj.common.write !== false && write) obj.common.alias.write = write;
         obj.common.name = idName;
         obj.common.role = idRole;
         obj.common.desc = idDst;
         if(min !== undefined) obj.common.min = min;
         if(max !== undefined) obj.common.max = max;
         if(unit) obj.common.unit = unit;
         obj.common.states = states;
         if(custom && obj.common.custom) obj.common.custom = custom;
         obj.native = {};
         setObject(idDst, obj);
    createAlias(aliasPath + '.' + aliasDevice, '', squeezeBoxInstanz + squeezeBoxDevice, '', 'channel', 'media', 'string');
    createAlias(aliasPath + '.' + aliasDevice + '.ALBUM', 'ALBUM',  squeezeBoxInstanz + squeezeBoxDevice + '.Album', '', 'state', 'media.album', 'string');
    createAlias(aliasPath + '.' + aliasDevice + '.ARTIST', 'ARTIST', squeezeBoxInstanz + squeezeBoxDevice + '.Artist', '', 'state', 'media.artist', 'string');
    createAlias(aliasPath + '.' + aliasDevice + '.TITLE', 'TITLE', squeezeBoxInstanz + squeezeBoxDevice + '.Title', '', 'state', 'media.title', 'string');
    createAlias(aliasPath + '.' + aliasDevice + '.NEXT', 'NEXT', squeezeBoxInstanz + squeezeBoxDevice + '.btnForward', '', 'state', 'button.forward', 'boolean');
    createAlias(aliasPath + '.' + aliasDevice + '.PREV', 'PREV', squeezeBoxInstanz + squeezeBoxDevice + '.btnRewind', '', 'state', 'button.reverse', 'boolean');
    createAlias(aliasPath + '.' + aliasDevice + '.PLAY', 'PLAY', squeezeBoxInstanz + squeezeBoxDevice + '.state', '', 'state', 'media.state', 'boolean');
    createAlias(aliasPath + '.' + aliasDevice + '.PAUSE', 'PAUSE', squeezeBoxInstanz + squeezeBoxDevice + '.state', '', 'state', 'media.state', 'boolean');
    createAlias(aliasPath + '.' + aliasDevice + '.STOP', 'STOP', squeezeBoxInstanz + squeezeBoxDevice + '.state', '', 'state', 'media.state', 'boolean');
    createAlias(aliasPath + '.' + aliasDevice + '.STATE', 'STATE', squeezeBoxInstanz + squeezeBoxDevice + '.Power', '', 'state', 'switch', 'boolean');
    createAlias(aliasPath + '.' + aliasDevice + '.VOLUME', 'VOLUME', squeezeBoxInstanz + squeezeBoxDevice + '.Volume', '', 'state', 'level.volume', 'number');
    createAlias(aliasPath + '.' + aliasDevice + '.VOLUME_ACTUAL', 'VOLUME_ACTUAL', squeezeBoxInstanz + squeezeBoxDevice + '.Volume', '', 'state', 'value.volume', 'number');
    Danach sollte unter alias.0.NSPanel_1.Media dieser Alias stehen.
    Wenn das funktioniert, dann aus den Beispielen im TS-Script einfach einen Media-Player nehmen und den Alias unter pageItems eintragen.
    Danach kommt das eigentliche Problem des Adapters...
    Du suchst in den alias.0.NSPanel_1.Media... Objekten nach den PAUSE, PLAY und STOP und klickst hinten auf den Stift und gehtst dann in den 3. Tab ALIAS. Dort den Haken in "Konvertierungsfunktionen benutzen"
    Folgende Werte eintragen:
    Das sollte es eigentlich gewesen sein
    Elluminatus
    schrieb am zuletzt editiert von Elluminatus
    #161
    @armilar Ich bekomme einen Fehler. Den Pfad squeezeboxrpc.0.Players.piCoreKUE gibt es aber, habe gerade nachgeschaut, hmm
    00:10:22.196	info	javascript.0 (10558) Start javascript script.js.common.NSPanel.LMS
    00:10:22.207	warn	javascript.0 (10558) script.js.common.NSPanel.LMS: Object "squeezeboxrpc.0.Players.piCoreKUE" does not exist
    00:10:22.208	info	javascript.0 (10558) script.js.common.NSPanel.LMS: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    00:10:22.210	error	javascript.0 (10558) script.js.common.NSPanel.LMS: TypeError: Cannot read properties of null (reading 'common')
    00:10:22.210	error	javascript.0 (10558) at createAlias (script.js.common.NSPanel.LMS:15:35)
    00:10:22.210	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:39:1
    00:10:22.211	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:51:3
    Der Haken bei SetObject ist bereits gesetzt
    • E Elluminatus
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #162
      Kopier es nochmal. Habe noch Änderungen in den Rollen gemacht. Kann es ja leider nicht selbst testen
      E 1 Antwort Letzte Antwort
      • ArmilarA Armilar
        Elluminatus
        #163
        @armilar Hab es nochmal kopiert, leider derselbe Fehler:
        00:27:57.980	info	javascript.0 (10558) Start javascript script.js.common.NSPanel.LMS
        00:27:57.991	warn	javascript.0 (10558) script.js.common.NSPanel.LMS: Object "squeezeboxrpc.0.Players.piCoreKUE" does not exist
        00:27:57.992	info	javascript.0 (10558) script.js.common.NSPanel.LMS: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        00:27:57.994	error	javascript.0 (10558) script.js.common.NSPanel.LMS: TypeError: Cannot read properties of null (reading 'common')
        00:27:57.995	error	javascript.0 (10558) at createAlias (script.js.common.NSPanel.LMS:15:35)
        00:27:57.995	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:39:1
        00:27:57.995	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:51:3
        Hier nochmal zur Kontrolle was ich eingefügt habe:
        const aliasPath = 'alias.0.Media.WT_KE_HWR';  // ggfs. Anpassen
          else {
             var obj = {};
             obj.type = idType;
             if(idRd) {
             obj.native = {};
        • E Elluminatus
            else {
               var obj = {};
               obj.type = idType;
               if(idRd) {
               obj.native = {};
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #164
            else {
               var obj = {};
               obj.type = idType;
               if(idRd) {
               obj.native = {};
          kommentiere das erste createAlias´mal aus (Zeile 39)
          //createAlias(aliasPath + '.' + aliasDevice, '', squeezeBoxInstanz + squeezeBoxDevice, '', 'channel', 'media', 'string');
          • ArmilarA Armilar
              else {
                 var obj = {};
                 obj.type = idType;
                 if(idRd) {
                 obj.native = {};
            Elluminatus
            #165
            @armilar Das ist jetzt ohne Fehler durchgelaufen. Kannst Du mir kurz helfen, was als nächstes gemacht werden muss? Muss ich jetzt einenAlias mit Media anlegen oder im Vorfeld den Erfolg nochmal überprüfen? Danke für Deinen Einsatz.
            • E Elluminatus
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #166
              Unter Objekte Alias findest du deinen neuen Media-Alias (der im Moment aber keiner ist)
              Gehe mal in den Ordner (hier im Bild blau) und klicke auf den Stift am Ende. Im ersten Tab sollte "media" unter Rolle eingetragen werden
              Jetzt ist es ein Media-Alias
              Im Anschluss folgst du der Beschreibung von gestern:
              https://forum.iobroker.net/post/867924
              Das hatten wir aber auch schon einfacher ;-)
              • ArmilarA Armilar
                Elluminatus
                #167
                @armilar Jetzt muss ich doch nochmal nachfragen, also ich habe da in den Alias jetzt die ganzen Einträge wie bspw. Album etc.
                Aber ich sehe den von Dir benannten Stift nicht am Ende?
                • E Elluminatus
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #168
                  Schalte mal in den Expertenmodus...
                  Kannst du wahrscheinlich dann auch schon mit klick auf den Bereich erledigen
                  oder unter Objektdaten wäre es dann in etwa so:
                    "type": "channel",
                    "common": {
                      "name": "",
                      "alias": {
                        "id": "squeezeboxrpc.0.Players.piCoreKUE"
                      "type": "string",
                      "role": "media",
                      "desc": "alias.0.NSPanel_1.Media.SqueezeBoxRPC"
                    "native": {},
                    "from": "system.adapter.javascript.0",
                    "user": "system.user.admin",
                    "ts": 1664852646982,
                    "_id": "alias.0.NSPanel_1.Media.SqueezeBoxRPC",
                    "acl": {
                      "object": 1636,
                      "owner": "system.user.admin",
                  Dann kannst du auch gleich als type "channel" mitgeben.
                  • ArmilarA Armilar
                      "type": "channel",
                      "common": {
                        "name": "",
                        "alias": {
                        "type": "string",
                        "role": "media",
                      "native": {},
                      "acl": {
                        "object": 1636,
                    Elluminatus
                    #169
                    @armilar
                    Ich kann leider nichts davon machen, ich habe kein Zahnrad, keinen Stift und kann nicht auf die Objektdaten zugreifen und auch nicht direkt auf den State. Bei den anderen geht es...?
                    • E Elluminatus
                      @armilar
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #170
                      @armilar
                      64ae6eaa-f86a-4847-ab96-67026caa706f-image.png Der ist an?
                      • ArmilarA Armilar
                        @armilar
                        Elluminatus
                        #171
                        @armilar ja ist er
                        ArmilarA 2 Antworten Letzte Antwort
                        • E Elluminatus
                          @armilar ja ist er
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #172
                          @armilar ja ist er
                          Bist du von den Berechtigungen limitiert?
                          • E Elluminatus
                            @armilar ja ist er
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #173
                            @armilar ja ist er
                            Könntest du mal versuchen den Alias mit dem Alias-Manager zu öffnen?
                            Da dürfte es auch gehen
                            • ArmilarA Armilar
                              @armilar ja ist er
                              Elluminatus
                              #174
                              @armilar Wie kann ich dies erkennen, bzw. wo kann ich dies überprüfen?
                              • E Elluminatus
                                Elluminatus
                                #175
                                @elluminatus Dort ist er nicht angelegt
                                Das Bild ist dort auch zuende.
                                Hab jetzt nochmal eine neue Struktur angelegt
                                Kann aber trotzdem nicht mehr sehen oder machen
                                • E Elluminatus
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #176
                                  Da bist du richtig. Jetzt nach Aktionen wie in meinem Bild oben "Gewählter Alias". Unter common.role media wählen und dann speichern
                                  E 2 Antworten Letzte Antwort
                                  • ArmilarA Armilar
                                    Elluminatus
                                    #177
                                    @armilar So das hat jetzt geklappt wenn ich das richtig sehe:
                                    • ArmilarA Armilar
                                      @icemanmw sagte in SONOFF NSPanel mit Lovelace UI:
                                      @armilar said in SONOFF NSPanel mit Lovelace UI:
                                      Hi, ich habe die Aliase : Licht , Hue Licht , Dimmer (und für das Radio auch eine Taste).
                                      Licht -> nur AN AUS Lichtschalter
                                      Dimmer -> AN AUS und Helligkeit Lichtschalter
                                      Hue -> vollständig HUE-Light Farbe
                                      soweit geht auch alles, bis auf die Darstellung der Farben der GRID
                                      Es gibt dazu wohl auch ein abgeschlossenes ISSUE auf GITHUB
                                      /joBr99/nspanel-lovelace-ui/issues/433
                                      Muss das mal nachbauen - kann einen Tag dauern. Eigentlich geht das... ioBroker ist da ne ecke flexibler als Home Assistant (dazu gehört übrigens auch der Punkt 433) Der Issue hat nix mit ioBroker zu tun - separate Farben konnten wir immer schon.
                                      AMBIENTE ist auch eine TASTE die eine Lichter-Gruppe steuert, hab ich oben vergessen
                                      hier noch die Bilder wenn :
                                      alles ist AUS
                                      alles ist AN:
                                      So, Test ist durchgelaufen und das ist das Ergebnis:
                                      • Bei dem Alias Licht habe ich keine Probleme mit deiner Einstellung
                                      • Bei dem Alias Dimmer ist ein Bug im Skript. Es arbeitet aktuell nur mit der defaultColor aus der Config nicht mit der OffColor aus dem PageItem.
                                      • Bei dem Alias Hue ist ebenfalls ein Bug. Solange der DP Hue verdrahtet ist, wird die verwendete Farbe berechnet.
                                      • Bei der Taste gibt es keinen "Off" Zustand und wird es auch nie geben. Der ist nur für für Szenen, etc. gedacht. Solange man darauf drückt, kann der auch nur diese eine Aktion durchführen. Ergo auch nur die onColor
                                      Für deinen Workaround (Bis es eine neue Version des TS-Skript gibt), solltest du in der
                                      export const config: Config = {
                                          defaultOffColor: Blue,
                                          defaultOnColor: Green,
                                          defaultColor: Blue,
                                      verwenden. Damit sollten alle Zustände bis auf den HUE korrekt sein.
                                      Mit dem HUE musst du bis zur nächsten Version (sollte aber bald kommen) warten.
                                      Die Originalfarbe für aus (lovelace) wäre übrigens im Skript "HMIOff", statt Blue
                                      Wenn du stattdessen Ambient nicht als Szene setzten möchtest, sondern Szene On/Off, dann solltest du einen Alias Schalter benutzen, in 0_userdata einen Datenpunkt (boolean) setzten und z.B. ein Blockly verwenden, mit dem du die Szene bei true und bei false unterschiedlich steuern kannst.
                                      Gleiches dann für das Radio. Bei Trigger true dann in den Alexa2 Adapter schreiben. Bei Trigger false --> pause (oder DeviceStop) im Alexa2 auf true setzten
                                      Dann kannst du alles an- und ausschalten oder zwischen gedimmt (Ambient) und Normal schalten.
                                      I Offline
                                      I Offline
                                      icemanmw
                                      #178
                                      @armilar
                                      vielen Dank. Das probiere ich gleich aus.
                                      Super erklärt und verständlich
                                      Ich melde mich wenn es alles klappt.
                                      Grüße
                                      I 1 Antwort Letzte Antwort
                                      • ArmilarA Armilar
                                        Elluminatus
                                        #179
                                        @armilar So es ist fast geschafft! Anzeige läuft:
                                        Jetzt ist lediglich noch die letzte Einstellung:
                                        "items": [<PageItem>{
                                                        adapterPlayerInstance: "squeezeboxrpc.0.Players.piCoreKUE.",
                                                        speakerList: ['LENOVO-W11-X','Terrasse','Überall','Gartenhaus','Esszimmer','Heimkino','Echo Dot Küche','Echo Spot Buero']
                                        Was muss ich unten in der Speaker List eintragen? Den Playernamen? piCoreKUE bspw?
                                        Und was hat im Display das Icon mit den drei Strichen und der Note normalerweise für eine Funktion?
                                        • E Elluminatus
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #180
                                          Das sieht doch schon ganz ordentlich aus...
                                          Unter Speaker würde ich mal nachsehen, wenn etwas abspielt, welcher Datenpunkt mit sinnvollen Geräten gefüllt ist. Das könntest du dann ebenfalls mal posten. Ebenfalls würde mich interessieren, wie der Wechsel von einem Raum zum anderen funktioniert. Dann könnte der Fall squeezeboxrpc das später korrekt verarbeiten. Aktuell gibt es ja keine Umschaltlogik für squeezebox im TS-Script. Aber ich denke fürs erste könnte da piCoreKUE drinstehen. Falls du so eine Umschaltlogik z.B. in Blockly hast, dann einfach hier posten. Falls du weißt welcher Datenpunkt mit welchem Inhalt gefüllt werden muss, könnte ich dir dabei ebenfalls helfen.
                                          Ja die Note mit einer Liste ist eine Note mit einer Liste. Einfach nur ein Icon ohne Funktion. Bei Spotitfy ist es das SpotifyLogo, bei Alexa gab es auch mal ein icon, heute nicht mehr und das Sonos Logo gibt es auch nicht. Wenn du ein passendes Logo in den 6500 icons findest, könnte ich das reinsetzen.
                                          32.6k
                                          82.1k
