  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • E Elluminatus
    Hallo liebe Community, ich versuche hier gerade ein weiteres NSPanel mit dem aktuellen TS Skript zum laufen zu bringen. Alle Schritte waren bisher erfolgreich. Nur beim Starten des Skriptes bekomme ich folgende Meldung:
    script.js.common.NSPanel.WT_KE_WS: TypeScript compilation failed: let ChartDemo: PageChart = { ^ ERROR: Cannot find name 'PageChart'. SendToPanel(GenerateChartPage(<PageChart>page)); ^ ERROR: Cannot find name 'PageChart'. function GenerateChartPage(page: PageChart): Payload[] { ^ ERROR: Cannot find name 'PageChart'. pages: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart)[]; ^ ERROR: Cannot find name 'PageChart'. subPages: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart)[]; ^ ERROR: Cannot find name 'PageChart'. button1Page: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart | null); ^ ERROR: Cannot find name 'PageChart'. button2Page: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart | null); ^ ERROR: Cannot find name 'PageChart'. pages: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart)[]; ^ ERROR: Property 'pages' of exported interface has or is using private name 'PageChart'. subPages: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart)[]; ^ ERROR: Property 'subPages' of exported interface has or is using private name 'PageChart'. button1Page: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart | null); ^ ERROR: Property 'button1Page' of exported interface has or is using private name 'PageChart'. button2Page: (PageThermo | PageMedia | PageAlarm | PageQR | PageEntities | PageGrid | PagePower | PageChart | null); ^ ERROR: Property 'button2Page' of exported interface has or is using private name 'PageChart'.
    Dies läßt mich vermuten, das ich hier noch irgendwo eine Änderung vornehmen muss, weil scheinbar die Button von meinem NSPanel noch mit den Relais verknüpft sind?
    rule2 0
    habe ich aber ausgeführt. Könnt Ihr mir helfen, in der Suche konnte ich mittels Suchaufrufen wie NSPanel Pagechart oder NSPanel Property nichts passendes finden. Ach so Javascript 6.1.3 ist installiert.
    Danke für Eure Hilfe.
    Gruß Elluminatus
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #881
    @elluminatus
    Das aktuelle TS-Script hat einen Fehler aus dem letzten "Pull Request". Es ist anscheinend nicht ganz vollständig. Daher das nachfolgende 3.5.0.5 aus der Historie benutzen. Mit dem cardChart sind nicht alle Parameter in den Types gelandet.
    https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/5f51d9ad0cdee1ebcec83ad649b60d74f1d3d9b0/ioBroker/NsPanelTs.ts
    E 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @elluminatus
      Elluminatus
      #882
      @armilar WIe immer lieben Dank!
      • E Elluminatus
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #883
        @elluminatus
        Sorry, hatte es heute ebenfalls bemerkt, aber aufgrund des anstehenden Updates noch keine Änderung eingespielt.
        • E Offline
          Elluminatus
          schrieb am zuletzt editiert von Elluminatus
          #884
          @armilar na ja es gibt ja nun wirklich schlimmeres und vor allem auch wichtigeres. Nicht der Rede wert.
          Zweite kleine Frage: Ich bekomme in Javaskript die Warnung:
          script.js.common.NSPanel.WT_KE_WS: get_tasmota_status0Unexpected token u in JSON at position 0
          script.js.common.NSPanel.WT_KE_WS: get_current_berry_driver_version: Unexpected token u in JSON at position 0
          Gibt es da auch so eine schnelle Lösung für? :-)
          Lieben Gruß Elluminatus
          • E Elluminatus
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #885
            @elluminatus
            Ja, warten bis morgen... Das Skript führt mit jedem Start eine Überprüfung der Versionen durch. Github ist aber in der Anzahl der Anfragen beschränkt und liefert irgendwann keine Daten mehr. Daher die Warnung. Kannst du ignorieren. Nach einer gewissen Zeit hört das wieder auf...
            • K Kuckuckmann
              @matze_hh
              eigentlich musst Du nur die Basissettings konfigurieren, dann funktioniert das Skript schon. Die Meldungen sind darauf ausgelegt, dass die PIN Eingabe geprüft wird und dann eine Ausgabe erfolgt ob diese erfolgreich war oder nicht.
              Zusätzlich wird dann der Alarmstatus mit ausgegeben. Das ist sind die NotifyText Blöcke wie zb. dieser:
              Wenn Du andere texte anzeigen lassen willst für die verschiedenen Status, dann musst Du eigentlich nur die grünen Textblöcke ändern. Es gibt vier verschiedene Textblöcke in dem Sinne für die verschiedenen Status.
              Ok, dieses Skript deckt nicht zu 100% Deinen Nutzungsfall, weil es auf die CardAlarm des Panels ausgelegt ist, es zeigt aber, dass man anhand von verschiedenen Abhängigkeiten, ein Info-Popup auf dem Panel aufgehen lassen kann.
              Je nachdem welche Alarmanlage Du angebunden hat musst Du natürlich den Datenpunkt abgreifen, der den Status Nacht Modus wiedergibt und dann im Änderungsfall entsprechend das Popup auf die Panels bringt.
              Bzgl. der Hintergrundfarbe musst Du mal hier einen andren Thread verfolgen, da ist @Armilar dabei etwas einzubauen.
              Ich hoffe das hilft dennoch.
              LG
              Matze_HH
              #886
              @kuckuckmann
              Ich hab dein Skript als Anlass genommen, mich da mal daran auszuprobieren.
              Das kam dabei raus:
              Jetzt müsste sich nur noch die Hintergrungfarbe wechseln, aber wenn da @Armilar dran ist, warte ich nochmal :)
              Vielen Dank für die Hilfe und Motivation
              K ArmilarA 2 Antworten Letzte Antwort
              • M Matze_HH
                @kuckuckmann
                Das kam dabei raus:
                Kuckuckmann
                #887
                @matze_hh
                Coole Sache, freut mich dass ich Dir eine Anregung geben konnte.
                Bzgl. der Hintergrundfarbe hoffe ich, dass ich da keine falsche Erwartungen geweckt habe. Ich glaube @Armilar hat das aktuell nur für den Screensaver vorbereitet, aber (noch) nicht für das NotifyPopup. Aber was nicht ist....Du weißt schon ;-)
                Vlt. noch ein ganz anderer Gedankenanstoß. Wie wäre es denn statt einer Farbe einfach ein Icon zu nutzen?
                Schau mal in der Wiki habe ich eine Doku angefangen für das NotifyPopup Layout 2. Dieses bietet die Möglichkeit ein Icon links neben dem Text einzublenden und das wiederum kann eine beliebige Farbe haben ;-)
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#popupnotify---layout-2
                LG
                NSPanel Dokumentation im GitHub Wiki:
                M ArmilarA 2 Antworten Letzte Antwort
                • K Kuckuckmann
                  @matze_hh
                  LG
                  Matze_HH
                  schrieb am zuletzt editiert von Matze_HH
                  #888
                  @kuckuckmann
                  Sehr guter Vorschlag, der Abend wird lang :)
                  P.S. Kann ich das "PopUp" auch wieder beenden durch das Blockly?
                  K 1 Antwort Letzte Antwort
                  • ArmilarA Armilar
                    @elluminatus
                    Elluminatus
                    #889
                    @armilar Fein, das ist prima. Dann basteln wir mal alle weiter....
                    Gruß Elluminatus
                    • M Matze_HH
                      @kuckuckmann
                      Kuckuckmann
                      schrieb am zuletzt editiert von Kuckuckmann
                      #890
                      @matze_hh
                      Wie wäre es z.B. mit dem Icon: 90bb42c6-334c-41af-96c2-dcf17f45d5dc-image.png
                      Icobs gibt es übrigens hier: https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
                      Zu Deiner Frage: ja das geht, Du musst halt nur die Textfelder leeren. Oder Du nutzt den Timer Datenpunkt popupNotifySleepTimeout, dann geht es nach einer definierten Zeit wieder weg oder durch einen Klick auf OK.
                      Update: By the way: Wenn Du mit der Doku arbeitetest, lass mich mal wissen was ggf. fehlt oder wo Du stolperts, damit ich das versvollständigen kann ;-)
                      LG
                      • M Matze_HH
                        @kuckuckmann
                        Das kam dabei raus:
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #891
                        @matze_hh sagte in SONOFF NSPanel mit Lovelace UI:
                        Ja warte noch... ich gebe schon Gas... ;-)
                        • K Kuckuckmann
                          @matze_hh
                          LG
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #892
                          @kuckuckmann sagte in SONOFF NSPanel mit Lovelace UI:
                          Nehmt bei der popupNotify Icons oder Schriftfarben. Die popUpNotify hat per Definition in der HMI keine Backgroundcolors
                          • J Offline
                            joBr99
                            #893
                            @matze_hh said in SONOFF NSPanel mit Lovelace UI:
                            Es sollte auch möglich sein exitPopup zum Panel zu senden, das sollte die popupNotificantion auch beenden.
                            • ArmilarA Armilar
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #894
                              Der erste Teil ist erledigt. Morgen etwas mehr Beschreibungen und Dokumentationen...
                              • VumerV Vumer
                                @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                                @ravenst0ne
                                gibt da keine langen Diskussionen. Ist eine etwas aufwendigere Geschichte und auch schon des Öfteren erörtert.
                                Daher
                                • entweder selbst machen und "Pull Request" auf github einstellen
                                • warten bis jemand einen Adapter schreibt
                                • oder warten bis ich Zeit dafür finde...
                                VG
                                Hallo armilar,
                                bitte nicht böse sein. Jeder weiß dass das nicht einfach ist. Aber wie Du hier feststellen kannst ist nicht jeder mit dem Script vertraut, alle möchten aber mitspielen. Und wenn man für sich alles angepasst hat, dabei nicht immer wissen was man da genau macht, ist es von unsere Seite wünschenswert wenn die User Einstellungen getrennt vom Hauptscript sind. Dann braucht man auch keine Angst haben neue Scripts zu testen. Aber nochmal, es ist ein Wunsch und nicht Verlangen.
                                Ich Z.B. hab mit dem Nextion Editor im cardMedia einen shuffle butten erstellt. Kann mit dem button shuffle auch an und ausschalten, aber er leuchtet nicht wenn shuffle an ist :(.
                                Oder hab noch immer nicht hinbekommen über MQTT-Adapter die beide Relais zu steuern ;)
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #895
                                @vumer sagte in SONOFF NSPanel mit Lovelace UI:
                                Shuffle ist gestern noch in die DEV gekommen... Also mit Release 3.6.1 demnächst
                                VumerV 1 Antwort Letzte Antwort
                                • ArmilarA Armilar
                                  VumerV Offline
                                  VumerV Offline
                                  Vumer
                                  schrieb am zuletzt editiert von Vumer
                                  #896
                                  Supper! :+1: Danke
                                  Aber wie kann ich über dem MQTT-Adapter die beiden Relais steuern? Über mqtt.0.SmartHome.NSPanel-1.stat funktioniert es bei mir nicht.
                                  • ArmilarA Armilar
                                    @vumer
                                    Bin nicht böse :blush: Wäre auch ein Wunsch von mir ;-)
                                    Aber der muss sich auch erst umsetzen lassen, ohne sich weitere Möglichkeiten zu verbauen. Was wäre denn die Beste Methode? Namespaces vs. Module vs. Adapter? Und wenn Adapter, wie müsste das Frontend aussehen bzw. wie mächtig müsste es sein? Oder wenn Adapter, dann nur einen Backendadapter mit herkömmlichen Config-Skripten? Oder funktioniert bei Modulen der Austausch der Variablen und Konstanten zwischen beiden Teilen Bereichen, ohne dass irgendwelche festverdrahteten Namen und Verzeichnisse eingetragen werden müssen?
                                    Habe noch nicht den Ansatz gefunden, wie es leichter werden würde. Im Moment sieht es danach aus, als würde es eher schwieriger für den Endanwender werden und das sollte es aus meiner Sicht nicht sein... Wäre also kein großer Vorteil...
                                    Also wenn jemand (globalgalaktisch für alle) gut umsetzbare Vorschläge, dann bin ich dafür offen. Noch besser wäre es aus zeitlicher Sicht, wenn er es dann auch noch umsetzen würde und als "Pull Request" bereitstellt.
                                    Du weißt schon, dass du den Button dann immer wieder in die HMI einbauen musst, wenn du upgrade-fähig bleiben willst ;-) ? Ist aber prinzipiell eine gute Sache an sich, denn jeder kann am Projekt mitarbeiten. Wenn es da Probleme gibt, kann man das doch auch mit @joBr99 in einem Issue oder evtl. auch direkt besprechen. Und wenn dann alles rund ist, in das nächste Release mitnehmen. Ich könnte mir auch vorstellen, dass andere an einer Shuffle-Funktion interessiert sind.
                                    Wir hängen aktuell noch etwas in der ioBroker TS-Script-Entwicklung hinterher (HA ist da schon etwas weiter) und jetzt kommen zunächst die Erweiterungen aus der 3.6.0 dran. Ich bin mir aber auch sicher, dass es relativ schnell eine 3.6.1 gibt, da das Panel künftig eine cardChart bekommen wird, die sich bereits im Test befindet. Ich spoiler mal kurz:
                                    In diesem Fall hat fumanchi (ioBroker User aber nicht im Forum) eine mega-dynamische Programmierung in der Nextion-HMI gemacht. Das Ding ist hochdynamisch und kann im Datenpunkt direkt aus z.B. influx befüllt werden.
                                    Aber mit dem kommenden Release (Ich Informiere euch, wenn die hochgeladen wird) kommen ebenfalls unglaublich viele neue Gimmicks. Und die Umsetzung und der Support erfolgt immer noch neben dem regulären Job... und die Doku muss dann ja auch noch erweitert werden.
                                    Das kommende Release beinhaltet ebenfalls eine separate Relais-Steuerung.
                                    So und jetzt arbeite ich noch etwas am Release 3.6.0 - sonst wird's Weihnachten ;-)
                                    VumerV Offline
                                    VumerV Offline
                                    Vumer
                                    #897
                                    Du weißt schon, dass du den Button dann immer wieder in die HMI einbauen musst, wenn du upgrade-fähig bleiben willst ?
                                    Ja, klar ;) Die Relais-Status Icons habe ich auch vergrößert
                                    • VumerV Vumer
                                      Supper! :+1: Danke
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #898
                                      @vumer
                                      Habe es zwar noch nicht beschrieben, aber ich versuche es mal, sofern die neue TS-Script-Version 3.6.0 gestartet ist...
                                      übrigens über .stat konnte noch nie irgendein Relais gesteuert werden. Also:
                                      nachdem das Script 3.6.0 gestartet wurde, hast du 2 neue Datenpunkte. Ich denke der Rest ist selbstsprechend. Ändere einfach die Datenepunkte von true auf false oder von false nach true ;-)
                                      • ArmilarA Armilar
                                        @vumer
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #899
                                        @armilar
                                        Übrigens noch drei Gimmicks die schnell beschrieben sind:
                                        Trigger_Dimmode:
                                        Dieser Datenpunkt schaltet das Display des Screensavers bei true auf 100% und bei false wieder in den regulären Dimm-Modus
                                        bExitPage:
                                        Default auf null. Wird hier eine Seite des Seitenzählers eingegeben, dann wird diese Seite beim verlassen des Screensavers immer aufgeschaltet. Beispiel 0 für die erste Seite oder 1 für die zweite Seite, usw.
                                        bgColorIndicator:
                                        Es gibt 4 Farb-Konstanten für die Hintergrundfarbe des Screensavers:
                                        • 0 - Standard Background --> scbackground
                                        • 1-3 - weitere (neue) Farbkonstanten --> scbackgroundInd(1-3)
                                        Die Konstanten können natürlich an eigene RGB-Werte angepasst werden...
                                        • ArmilarA Armilar
                                          @armilar
                                          Trigger_Dimmode:
                                          bExitPage:
                                          bgColorIndicator:
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #900
                                          noch eine kleine Neuerung für die cardMedia seit TS-Script 3.6.0
                                          Es gibt im PageItem jetzt drei neue Farb-Parameter
                                          let SpotifyPremium: PageMedia =
                                              "type": "cardMedia",
                                              "heading": "Spotify-Premium",
                                              "useColor": true,
                                              "subPage": false,
                                              "parent": undefined,
                                              "items": [<PageItem>{
                                                          id: AliasPath + 'Media.PlayerSpotifyPremium',
                                                          adapterPlayerInstance: "spotify-premium.0.",
                                                          speakerList: ['LENOVO-W11-01','Terrasse','Überall','Gartenhaus','Esszimmer','Heimkino','Echo Dot Küche','Echo Spot Buero'],
                                                          colorMediaIcon: colorSpotify,
                                                          colorMediaArtist: Yellow,
                                                          colorMediaTitle: Yellow,
                                                          autoCreateALias : true
                                          funktioniert natürlich auch mit Alexa und Sonos, etc.
                                          (P.S.: Shuffle erst ab v3.6.1 demnächst)
                                          Euch allen noch einen schönen restlichen ersten Advent
                                          VG
                                          Armilar
                                          C 1 Antwort Letzte Antwort
                                          32.6k
                                          82.1k
