  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • M michael_4358
    @tt-tom said in SONOFF NSPanel mit Lovelace UI:
    @michael_4358
    was kommt den auf der Tasmota Konsole so als Meldungen?
    deine MQTT einstellungen geprüft in Tasmota?
    script.js.NSPanel.panel_14: AxiosError: getaddrinfo EAI_AGAIN undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:610:25) at RedirectableRequest.emit (node:events:514:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:526:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'EAI_AGAIN', errno: -3001, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: f46b7c2a61424bbb93184ac7b44ac888-bf1d9b097c857475\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.3.1,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=f46b7c2a61424bbb93184ac7b44ac888\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 16384, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo EAI_AGAIN undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:108:26) { errno: -3001, code: 'EAI_AGAIN', syscall: 'getaddrinfo', hostname: 'undefined' } }
    das schmeisst mir der Broker aus...
    michael_4358
    #5781
    @TT-Tom
    das is auf der panel Konsole
    17:39:18.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:24.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:30.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:36.103 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:42.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:48.103 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:53.998 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:39:59.999 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:05.899 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:11.899 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:17.799 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:23.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:29.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:35.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:41.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:47.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:47.891 MQT: tele/tasmota_C6C160/STATE = {"Time":"2024-06-03T17:40:47","Uptime":"0T00:15:10","UptimeSec":910,"Heap":107,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":54,"Objects":660},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Datenbremse","BSSId":"68:D7:9A:14:06:1B","Channel":1,"Mode":"HT40","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:05"}}
    17:40:47.901 MQT: tele/tasmota_C6C160/SENSOR = {"Time":"2024-06-03T17:40:47","ANALOG":{"Temperature1":27.0},"TempUnit":"C"}
    17:40:53.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:40:59.497 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:05.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:11.398 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:17.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:23.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:29.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:35.197 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:41.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:47.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:53.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:41:58.999 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:05.002 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:10.898 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:16.898 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:22.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:28.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:34.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:40.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:46.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:52.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:42:58.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:04.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:10.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:16.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:22.400 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:28.302 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:34.304 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:40.197 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:46.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    17:43:52.108 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
    • M michael_4358
      @TT-Tom
      TT-Tom
      #5782
      @michael_4358 sagte in SONOFF NSPanel mit Lovelace UI:
      stimmt der Pfad vom MQTT noch mit dem Script überein?
      Gruß Tom
      https://github.com/tt-tom17
      NSPanel Script Wiki
      NSPanel Adapter Wiki
      • T TT-Tom
        michael_4358
        #5783
        @tt-tom
        tatsächlich❗️
        aber costum send wird nicht erzeugt...
          TT-Tom
          #5784
          @michael_4358
          Stell in Tasmota die alte Verzeichnis Struktur wieder ein, dann sollte alles wieder funktionieren.
          zeig mal deine alten Datenpunkte
          Gruß Tom
          NSPanel Script Wiki
          • T TT-Tom
            @michael_4358
            michael_4358
            #5785
            @michael_4358
            das ist zu spät ich hab die gelöscht da ich dachte dort kommt es zu Problemen,.
            • M michael_4358
              @michael_4358
              TT-Tom
              #5786
              @michael_4358
              Die steht doch noch im Script, oder? Ansonsten ist im Wiki eine Beschreibung.
              Gruß Tom
              NSPanel Script Wiki
              • T TT-Tom
                @michael_4358
                michael_4358
                #5787
                @michael_4358
                habe es wie im wiki gemacht aber der Datenpunkt fehlt..
                • M michael_4358
                  @michael_4358
                  TT-Tom
                  #5788
                  @michael_4358
                  Zeige mal deine MQTT Einstellungen von Tasmota und die von mqtt.0
                  Gruß Tom
                  NSPanel Script Wiki
                  • T TT-Tom
                    @michael_4358
                    michael_4358
                    #5789
                    @tt-tom Bildschirmfoto 2024-06-03 um 19.53.56.png Bildschirmfoto 2024-06-03 um 19.54.34.png Bildschirmfoto 2024-06-03 um 19.54.41.png
                    • M michael_4358
                      TT-Tom
                      #5790
                      @michael_4358
                      Vom objektbaum mqtt meinte ich.
                      Gruß Tom
                      NSPanel Script Wiki
                      • T TT-Tom
                        @michael_4358
                        michael_4358
                        #5791
                        • M michael_4358
                          TT-Tom
                          #5792
                          @michael_4358
                          da passt schon etwas nicht, dein Fulltopic in Tasmota fängt doch mit NSPanel14 an. hast du noch mehr Einträge unter mqtt.0
                          EDIT: da ist ein Fehler in deiner Tasmota Config
                          Dein Fulltopic fehlt ein / und du hast das %topic% auch NSPanel14 genannt
                          Schreibe mal Smarthome/%topic%/%prefix% und poste dann die Ausgabe von der Tasmota Konsole und den Objektbaum von mqtt.0
                          Gruß Tom
                          NSPanel Script Wiki
                          • T TT-Tom
                            @michael_4358
                            michael_4358
                            #5793
                            @tt-tom
                            nach den ganzen neustarten zeigt das display nur noch "system data erorr"....
                            alles auf anfang..
                            • M michael_4358
                              @tt-tom
                              alles auf anfang..
                              TT-Tom
                              #5794
                              @michael_4358
                              Tasmota läuft noch? Dann solltest du die TFT Firmware nochmal neu installieren.
                              Bin heute nur am Handy erreichbar und kann dir nur bedingt weiterhelfen. Ggf heute Abend über Discord.
                              Gruß Tom
                              NSPanel Script Wiki
                              • T TT-Tom
                                @australien
                                Gehe mal auf die alte Version zurück. Wir sind mit den Entwicklern schon am arbeiten.
                                australien
                                #5795
                                @tt-tom gibt es dazu schon Neuigkeiten?
                                • F Offline
                                  Foradh 0
                                  #5796
                                  funktioniert bei euch eigentlich ein Tasmota-Update über die Bestätigung am Panel?
                                  Falls ich das Update über das Nspanel starte bleibt dieses im Safeboot stehen und führt das Update nicht durch.
                                  Problem tritt bei allen 4 Panels auf die ich aktuell betreibe. Gerade nochmal probiert für das Update von 14.0 auf 14.1.
                                  Im Iobroker wird unter Javascript log auch angezeigt dass er das Panel in den Safeboot wechselt, dann passiert allerdings nichts mehr.
                                  Ich habe die aktuelle tasmota32.bin dann heruntergeladen und unter dem Safeboot Webinterface die Panels damit manuell aktualisiert.
                                  Ist das bei euch auch so oder gibt es hier eine Lösung dass das Update von alleine druchläuft?
                                  • T TT-Tom
                                    @michael_4358
                                    michael_4358
                                    #5797
                                    @michael_4358
                                    habe den Treiber neu installiert bekomme aber keine Verbindung zum panel...
                                    • F Foradh 0
                                      TT-Tom
                                      #5798
                                      @foradh-0
                                      bei mir lief das Update von 13.4.1 auf 14.1 ohne Probleme direkt am Panel.
                                      am Testsystem wurde von 14.0 auf 14.1 auch ohne Probleme aktualisiert.
                                      Gruß Tom
                                      NSPanel Script Wiki
                                      F 1 Antwort Letzte Antwort
                                      • M michael_4358
                                        @michael_4358
                                        TT-Tom
                                        #5799
                                        @michael_4358
                                        wollen wir auf Discord gehen?
                                        Gruß Tom
                                        NSPanel Script Wiki
                                        • T TT-Tom
                                          @foradh-0
                                          Foradh 0
                                          #5800
                                          @tt-tom
                                          Kann ich da irgendetwas falsch eingestellt haben?
                                          Ich nutze die aktuellste Version v4.4.0.1 vom TypeScript und unter der Version folgendes eingetragen
                                          32.6k
                                          82.1k
