    apollon77A
lovelace uinspanelsonoff
8.1k Beiträge 281 Kommentatoren 10.3m Aufrufe 260 Beobachtet
  • M michael_4358
    @tt-tom
    die software..
    das panel zeigt nur noch den wait for content Kreisel... kann den Fehler arm nicht finden..
    T
    T
    TT-Tom
    #5779
    @michael_4358
    was kommt den auf der Tasmota Konsole so als Meldungen?
    deine MQTT einstellungen geprüft in Tasmota?
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      @michael_4358
      M
      M
      michael_4358
      #5780
      @tt-tom said in SONOFF NSPanel mit Lovelace UI:
      @michael_4358
      script.js.NSPanel.panel_14: AxiosError: getaddrinfo EAI_AGAIN undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:610:25) at RedirectableRequest.emit (node:events:514:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:526:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'EAI_AGAIN', errno: -3001, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: f46b7c2a61424bbb93184ac7b44ac888-bf1d9b097c857475\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.3.1,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=f46b7c2a61424bbb93184ac7b44ac888\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 16384, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo EAI_AGAIN undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:108:26) { errno: -3001, code: 'EAI_AGAIN', syscall: 'getaddrinfo', hostname: 'undefined' } }
      das schmeisst mir der Broker aus...
      • M michael_4358
        @michael_4358
        M
        M
        michael_4358
        #5781
        @TT-Tom
        das is auf der panel Konsole
        17:39:18.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:24.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:30.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:36.103 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:42.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:48.103 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:53.998 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:39:59.999 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:05.899 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:11.899 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:17.799 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:23.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:29.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:35.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:41.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:47.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:47.891 MQT: tele/tasmota_C6C160/STATE = {"Time":"2024-06-03T17:40:47","Uptime":"0T00:15:10","UptimeSec":910,"Heap":107,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":54,"Objects":660},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Datenbremse","BSSId":"68:D7:9A:14:06:1B","Channel":1,"Mode":"HT40","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:05"}}
        17:40:47.901 MQT: tele/tasmota_C6C160/SENSOR = {"Time":"2024-06-03T17:40:47","ANALOG":{"Temperature1":27.0},"TempUnit":"C"}
        17:40:53.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:40:59.497 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:05.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:11.398 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:17.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:23.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:29.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:35.197 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:41.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:47.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:53.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:41:58.999 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:05.002 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:10.898 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:16.898 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:22.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:28.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:34.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:40.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:46.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:52.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:42:58.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:04.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:10.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:16.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:22.400 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:28.302 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:34.304 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:40.197 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:46.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        17:43:52.108 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
        • M michael_4358
          @TT-Tom
          T
          T
          TT-Tom
          #5782
          @michael_4358 sagte in SONOFF NSPanel mit Lovelace UI:
          stimmt der Pfad vom MQTT noch mit dem Script überein?
          Gruß Tom
          Public Transport
          • T TT-Tom
            M
            M
            michael_4358
            #5783
            @tt-tom
            tatsächlich❗️
            aber costum send wird nicht erzeugt...
            • T
              T
              TT-Tom
              #5784
              @michael_4358
              Stell in Tasmota die alte Verzeichnis Struktur wieder ein, dann sollte alles wieder funktionieren.
              zeig mal deine alten Datenpunkte
              Gruß Tom
              Public Transport
              • T TT-Tom
                @michael_4358
                M
                M
                michael_4358
                #5785
                @michael_4358
                das ist zu spät ich hab die gelöscht da ich dachte dort kommt es zu Problemen,.
                • M michael_4358
                  @michael_4358
                  T
                  T
                  TT-Tom
                  #5786
                  @michael_4358
                  Die steht doch noch im Script, oder? Ansonsten ist im Wiki eine Beschreibung.
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @michael_4358
                    M
                    M
                    michael_4358
                    #5787
                    @michael_4358
                    habe es wie im wiki gemacht aber der Datenpunkt fehlt..
                    • M michael_4358
                      @michael_4358
                      T
                      T
                      TT-Tom
                      #5788
                      @michael_4358
                      Zeige mal deine MQTT Einstellungen von Tasmota und die von mqtt.0
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        @michael_4358
                        M
                        M
                        michael_4358
                        #5789
                        @tt-tom Bildschirmfoto 2024-06-03 um 19.53.56.png Bildschirmfoto 2024-06-03 um 19.54.34.png Bildschirmfoto 2024-06-03 um 19.54.41.png
                        • M michael_4358
                          T
                          T
                          TT-Tom
                          #5790
                          @michael_4358
                          Vom objektbaum mqtt meinte ich.
                          Gruß Tom
                          Public Transport
                          • T TT-Tom
                            @michael_4358
                            M
                            M
                            michael_4358
                            #5791
                            • M michael_4358
                              T
                              T
                              TT-Tom
                              #5792
                              @michael_4358
                              da passt schon etwas nicht, dein Fulltopic in Tasmota fängt doch mit NSPanel14 an. hast du noch mehr Einträge unter mqtt.0
                              EDIT: da ist ein Fehler in deiner Tasmota Config
                              Dein Fulltopic fehlt ein / und du hast das %topic% auch NSPanel14 genannt
                              Schreibe mal Smarthome/%topic%/%prefix% und poste dann die Ausgabe von der Tasmota Konsole und den Objektbaum von mqtt.0
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                @michael_4358
                                M
                                M
                                michael_4358
                                #5793
                                @tt-tom
                                nach den ganzen neustarten zeigt das display nur noch "system data erorr"....
                                alles auf anfang..
                                • M michael_4358
                                  @tt-tom
                                  alles auf anfang..
                                  T
                                  T
                                  TT-Tom
                                  #5794
                                  @michael_4358
                                  Tasmota läuft noch? Dann solltest du die TFT Firmware nochmal neu installieren.
                                  Bin heute nur am Handy erreichbar und kann dir nur bedingt weiterhelfen. Ggf heute Abend über Discord.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @australien
                                    Gehe mal auf die alte Version zurück. Wir sind mit den Entwicklern schon am arbeiten.
                                    A
                                    A
                                    australien
                                    #5795
                                    @tt-tom gibt es dazu schon Neuigkeiten?
                                    • F
                                      F
                                      Foradh 0
                                      #5796
                                      funktioniert bei euch eigentlich ein Tasmota-Update über die Bestätigung am Panel?
                                      Falls ich das Update über das Nspanel starte bleibt dieses im Safeboot stehen und führt das Update nicht durch.
                                      Problem tritt bei allen 4 Panels auf die ich aktuell betreibe. Gerade nochmal probiert für das Update von 14.0 auf 14.1.
                                      Im Iobroker wird unter Javascript log auch angezeigt dass er das Panel in den Safeboot wechselt, dann passiert allerdings nichts mehr.
                                      Ich habe die aktuelle tasmota32.bin dann heruntergeladen und unter dem Safeboot Webinterface die Panels damit manuell aktualisiert.
                                      Ist das bei euch auch so oder gibt es hier eine Lösung dass das Update von alleine druchläuft?
                                      • T TT-Tom
                                        @michael_4358
                                        M
                                        M
                                        michael_4358
                                        #5797
                                        @michael_4358
                                        habe den Treiber neu installiert bekomme aber keine Verbindung zum panel...
                                        • F Foradh 0
                                          T
                                          T
                                          TT-Tom
                                          #5798
                                          @foradh-0
                                          bei mir lief das Update von 13.4.1 auf 14.1 ohne Probleme direkt am Panel.
                                          am Testsystem wurde von 14.0 auf 14.1 auch ohne Probleme aktualisiert.
                                          Gruß Tom
                                          Public Transport
                                          F 1 Antwort Letzte Antwort
                                          84.0k
