    1.9k
  • Weihnachtsangebot 2025! 🎄
    2.2k
lovelace uinspanelsonoff
  • wendy2702W Online
    wendy2702W Online
    wendy2702
    #2101
    @armilar Danke. Das hat erstmal funktioniert.
    Allerdings bekomme ich im log des Scripts diese Meldungen wenn der Screensaver aktiv wird:
    18:26:00.792	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    18:26:19.879	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
    18:26:19.880	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
    18:26:19.880	warn	javascript.1 (77070) at HandleScreensaver (script.js.common.NSPanel.NSPanel_Dev:7268:5)
    18:26:19.880	warn	javascript.1 (77070) at HandleMessage (script.js.common.NSPanel.NSPanel_Dev:3467:21)
    18:26:19.880	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3401:25)
    18:26:19.880	warn	javascript.1 (77070) at step (script.js.common.NSPanel.NSPanel_Dev:33:23)
    18:26:19.880	warn	javascript.1 (77070) at Object.next (script.js.common.NSPanel.NSPanel_Dev:14:53)
    18:26:19.880	warn	javascript.1 (77070) at script.js.common.NSPanel.NSPanel_Dev:8:71
    18:26:19.880	warn	javascript.1 (77070) at __awaiter (script.js.common.NSPanel.NSPanel_Dev:4:12)
    18:26:19.880	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3393:12)
    18:26:19.880	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    18:26:20.837	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
    18:26:20.837	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
    18:26:20.837	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
    18:26:20.838	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    18:26:22.221	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
    18:26:22.221	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
    18:26:22.221	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
    18:26:22.221	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    18:26:23.604	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
    18:26:23.604	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
    18:26:23.604	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
    18:26:23.605	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    18:26:24.889	warn	javascript.1 (77070) at HandleScreensaverStatusIcons (script.js.common.NSPanel.NSPanel_Dev:7473:39)
    18:26:24.889	warn	javascript.1 (77070) at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanel_Dev:7393:13)
    18:26:24.889	warn	javascript.1 (77070) at Object.<anonymous> (script.js.common.NSPanel.NSPanel_Dev:3389:9)
    18:26:24.889	info	javascript.1 (77070) script.js.common.NSPanel.NSPanel_Dev: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    18:26:25.534	info	javascript.1 (77070) Stop script script.js.common.NSPanel.NSPanel_Dev
    Ich habe das Script vom richtigen Panel nur in eine neue Instanz kopiert und die Datenpunkte angepasst. Habe ich dabei noch etwas vergessen?
    EDIT:
    Ich sehe gerade das ich zumindest eine der Zeilen auch beim echten Panel bekomme:
    17:50:10.133	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:11.508	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:12.814	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:14.128	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:15.499	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:16.847	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:18.158	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:19.496	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:20.821	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:22.215	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:23.472	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:24.777	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:26.102	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:27.441	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:28.764	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:30.010	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:30.070	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:31.407	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:32.723	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:34.062	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    17:50:35.376	info	javascript.0 (77055) script.js.common.NSPanel.NSPANEL_1_3_9_0: HandleScreensaverStatusIcons: Cannot read properties of null (reading 'toFixed')
    • wendy2702W wendy2702
      EDIT:
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #2102
      @wendy2702
      Ja, du hast vergessen, dass das NSPanel als Emulator keine Relais hat ;-)
      Kannst entweder die MRIcons auf null setzten, oder auf das andere NSPanel
      • ArmilarA Armilar
        @wendy2702
        wendy2702W Online
        wendy2702W Online
        wendy2702
        #2103
        @armilar Hm,
        habe das Script ja wie geschrieben 1zu1 kopiert und an der stelle nichts geändert. Für dass DEV sieht das so aus:
        Ich denke du meinst die beiden markierten Einträge, oder?
        Für das echte Panel sieht das so aus:
        Oder meinst du noch einen anderen Eintrag?
          @armilar Hm,
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #2104
          @wendy2702
          Könntest du mir auch jeweils einen Verbindungsstring geben? Z.B. den für den CustomSend. Macht es dann einfacher zu raten, ob dein MQTT-String so ist wie meiner oder ob da Abweichungen sind ;-)
          Und ja, das sind die beiden Übeltäter :blush:
          • ArmilarA Armilar
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            wendy2702
            #2105
            @armilar Sorry, dauert was.
            Nachdem ich den Rechner aus gemacht hatte und den ESP dadurch natürlich Stromlos bekomme ich es jetzt überhaupt nicht mehr zum laufen. Auch die WLAN Verbindung zum ESP bricht ständig ab. Da ich neu im ESP Thema bin muss ich da erstmal probieren.
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #2106
              @wendy2702
              Lasse dir Zeit...
              • wendy2702W Online
                wendy2702W Online
                wendy2702
                #2107
                @armilar Ich hoffe du meinst das aus CustomSend:
                weatherUpdate~~~~19017~~1 °C~~~~65168~Leistung~1090 W~~~~34351~Wind~3.3km/h~~~~26095~UV~0~~~~64750~Luft~93%~
                Bei dem echten Panel sieht das so aus:
                statusUpdate~~17299~梅20.4°~65504~~~
                Ich habe diese zwei Unterschiede im Script: Links echtes Panel, Rechts Emulator
                Hier habe ich lediglich den Namen in der Anzeige geändert:
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #2108
                  @wendy2702
                  Ich meinte tatsächlich die Infos aus dem mittleren Screenshot. Also alles da...
                  Das DEV-Emu-Panel dürfte keine Analog Temperatur bekommen, da es keinen Temperatursensor hat. Also funktioniert die Suche vom
                  NSPanel_Path + 'Sensor.ANALOG.Temperature'
                  nicht. Trage bitte in den Datenpunkt unter Objekte des DEV-Panels mal eine fiktive Temperatur (z.B. 22,1) ein.
                  • ArmilarA Armilar
                    @wendy2702
                    wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    #2109
                    @armilar OK.
                    Teste ich morgen früh.
                    Danke abermals für deine schnelle Hilfe.
                    Habe ich das in der Anleitung eigentlich überlesen?
                      @armilar OK.
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #2110
                      @wendy2702
                      Hat sich viel getan in der Zwischenzeit. Und der 2. Datenpunkt in den MRIcons ist neu... Wird also nicht explizit drin stehen.
                      Fakt ist: der EMU-ESP32 hat keine Relais und keine Sensoren. Bis auf die ESP-Temperatur mit
                      setOption146 1
                      Demnach bleibt die Temperatur im Datenpunkt auch ungefüllt. Wenn du jetzt auf den Datenpunkt zugreifst und mit toFixed() eine Nachkommastelle mitgibst, dann hast du 2 Fehler auf einmal.
                      1. Der Datenpunkt ist null
                      2. Die Nachommastelle von null ist nicht da
                      Also: einmal unter:
                      0_userdate.0.NSPanel.Dev.Sensor.ANALOG.Temperature
                      irgendeine Zahl für irgendeine Sensortemperatur reinschreiben und der Spuk sollte ein Ende haben.
                      • ArmilarA Armilar
                        @wendy2702
                        setOption146 1
                        Also: einmal unter:
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        #2111
                        @armilar ok.
                        Wie geschrieben mache ich morgen früh.
                        Habe die Anleitung so oft gelesen das ich schon sorge hatte ich habe das überlesen.
                        EDIT: Object angelegt, Wert eingetragen und ruhe ist im Log.
                        DANKE!
                          @armilar ok.
                          DANKE!
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #2112
                          @wendy2702 sagte in SONOFF NSPanel mit Lovelace UI:
                          So habe die Wiki für den Emulator mal kurz an den aktuellen Stand angepasst.
                          • ArmilarA Armilar
                            @gargano
                            @wendy2702
                            Kommt vom letzten Update des Nextion Editor's
                            https://nextion.tech/download/nextion-setup-v1-63-3.exe
                            https://nextion.tech/download/nextion-setup-v1-63-3.zip
                            Installiert mal die Version... Die aber dann nicht uppen...
                            GarganoG Offline
                            GarganoG Offline
                            Gargano
                            #2113
                            @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                            Fehlermeldung im Editor:
                            Error:Invalid number of arguments:qrcode m1.x,m1.y,200,defaultBcoColor,65535,-1,vaQR.txt( Double click to jump to code)
                            Error:Invalid number of arguments:qrcode m0.x,m0.y,200,defaultBcoColor,65535,-1,vaQR.txt( Double click to jump to code)
                            Error:Compile failed! 2 Errors, 1 Warnings,
                            Wie ist denn dann die Syntax mit der aktuellen Version des Nextion Editor's ?
                            ArmilarA J 2 Antworten Letzte Antwort
                            • GarganoG Gargano
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #2114
                              @gargano
                              Es gibt keine Syntax für einen Bug im Nextion Editor...
                              Deinstallieren und die 1.63.3 installieren.
                              • GarganoG Gargano
                                joBr99
                                #2115
                                @gargano
                                qrcode 8,m1.x,m1.y,200,defaultBcoColor,65535,-1,vaQR.txt
                                qrcode 8,m0.x,m0.y,200,defaultBcoColor,65535,-1,vaQR.txt
                                Diese Änderung ist seitens Nextion aber nirgends dokumentiert und da neue Editor Versionen in der Vergangenheit lustige Seiteneffekte hatten werde ich mit dem Update von dem Editor noch etwas warten, die Version .1 mit Bugfixes kam ja auch schon, erstmal abwarten, was da sonst noch so kommt.
                                • N Offline
                                  N Offline
                                  niiccooo1
                                  #2116
                                  Hallo Zusammen,
                                  ich bin gerade dabei meine Aliase etwas aufzuräumen. Dabei möchte ich die NSPanel Aliase in eine höhere Ebene bringen.
                                  Da die notwenidgen Aliase selbstständig angelegt werden, habe ich einfach nur den Alias Pfad geändert.
                                  Jedoch werden nicht Aliase automatisch angelegt. Anbei zwei Bilder:
                                  Alter Pfad
                                  Neuer Pfad
                                  Als Beispiel hier der Alias Config. Es wird nur ein Bruchteil von dem angelegt was vorher da war.
                                  Woran liegt das?
                                  Skriptversion 3.9.0.2
                                  VG
                                  Nico
                                  ravenst0neR 1 Antwort Letzte Antwort
                                  • N niiccooo1
                                    Hallo Zusammen,
                                    Alter Pfad
                                    Neuer Pfad
                                    Woran liegt das?
                                    VG
                                    Nico
                                    ravenst0neR Offline
                                    ravenst0neR Offline
                                    ravenst0ne
                                    #2117
                                    @niiccooo1 Lösche mal die entsprechenden Datenpunkte unter 0_userdata. Im Skript wird oftmals abgefragt ob userdata existiert, falls nein wird der Datenpunkt dort erzeugt und anschließend das Alias angelegt.
                                    N 1 Antwort Letzte Antwort
                                    • V Offline
                                      V Offline
                                      Venice
                                      schrieb am zuletzt editiert von Venice
                                      #2118
                                      Hallo zusammen, ich komme leider nicht weiter .
                                      Aktuell sieht mein Screensaver so aus und ich weiß leider nicht warum?
                                      • V Venice
                                        ravenst0neR Offline
                                        ravenst0neR Offline
                                        ravenst0ne
                                        #2119
                                        @venice Sieht aus, als ob die verwendete Skriptversion und TFT Firmware nicht zusammenpasst. Kannst du mal deine verwendeten Versionen posten?
                                        V 1 Antwort Letzte Antwort
                                        • ravenst0neR ravenst0ne
                                          V Offline
                                          V Offline
                                          Venice
                                          #2120
                                          @ravenst0ne Super Danke dir es hat geklappt.:+1:
                                          32.6k
                                          82.2k
