  4. Test Adapter TP-Link Tapo
    6.6k
885 Beiträge 123 Kommentatoren 403.8k Aufrufe 107 Beobachtet
  • B BenjaminCz
    @ro75
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: IOBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-4-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) N100
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:57:06 up 1 day, 20:17,  2 users,  load average: 1.05, 0.91, 0.90
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-11-24 20:57:06 CET
               Universal time: Sun 2024-11-24 19:57:06 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video plugdev users
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.3G        2.5G        985M        106K        853M        1.8G
    Swap:           536M         16K        536M
    Total:          4.8G        2.5G        1.5G
    Active iob-Instances:   27
             4096 M total memory
             2342 M used memory
             2447 M active memory
              565 M inactive memory
              939 M free memory
                0 M buffer memory
              814 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    top - 20:57:06 up 1 day, 20:17,  2 users,  load average: 1.05, 0.91, 0.90
    Tasks:  57 total,   2 running,  55 sleeping,   0 stopped,   0 zombie
    %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,    938.2 free,   2343.6 used,    814.3 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1752.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--106--disk--0 ext4    25G  6.0G   18G  26% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs   16G     0   16G   0% /dev/shm
    tmpfs                            tmpfs  6.3G  116K  6.3G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    [Fri Nov 22 06:03:56 2024] EXT4-fs (dm-1): mounted filesystem bab69836-57a4-493a-91ea-1c5b9d41a592 ro with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:03:56 2024] EXT4-fs (dm-1): re-mounted bab69836-57a4-493a-91ea-1c5b9d41a592 r/w. Quota mode: none.
    [Fri Nov 22 06:04:05 2024] EXT4-fs (dm-7): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:04:07 2024] EXT4-fs (dm-18): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:04:19 2024] EXT4-fs (dm-6): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:04:31 2024] EXT4-fs (dm-17): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:04:43 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:04:57 2024] EXT4-fs (dm-19): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:05:10 2024] EXT4-fs (dm-9): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:05:23 2024] EXT4-fs (dm-10): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:05:36 2024] EXT4-fs (dm-16): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:05:49 2024] EXT4-fs (dm-11): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:06:02 2024] EXT4-fs (dm-12): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:06:15 2024] EXT4-fs (dm-13): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:06:28 2024] EXT4-fs (dm-14): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:08:22 2024] EXT4-fs (dm-8): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
    [Fri Nov 22 06:08:23 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:10:34 2024] EXT4-fs (dm-19): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
    [Fri Nov 22 06:10:34 2024] EXT4-fs (dm-19): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:12:41 2024] EXT4-fs (dm-9): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
    [Fri Nov 22 06:12:42 2024] EXT4-fs (dm-9): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:14:23 2024] EXT4-fs (dm-10): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
    [Fri Nov 22 06:14:24 2024] EXT4-fs (dm-10): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:16:20 2024] EXT4-fs (dm-18): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
    [Fri Nov 22 06:16:21 2024] EXT4-fs (dm-18): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:18:36 2024] EXT4-fs (dm-16): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
    [Fri Nov 22 06:18:37 2024] EXT4-fs (dm-16): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:20:45 2024] EXT4-fs (dm-11): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
    [Fri Nov 22 06:20:46 2024] EXT4-fs (dm-11): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:22:35 2024] EXT4-fs (dm-12): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
    [Fri Nov 22 06:22:36 2024] EXT4-fs (dm-12): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:24:26 2024] EXT4-fs (dm-13): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
    [Fri Nov 22 06:24:27 2024] EXT4-fs (dm-13): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 06:26:28 2024] EXT4-fs (dm-14): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
    [Fri Nov 22 06:26:29 2024] EXT4-fs (dm-14): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 22:31:37 2024] EXT4-fs (dm-15): mounted filesystem cbc8784a-0388-41b5-b643-b7c71966fea4 ro with ordered data mode. Quota mode: none.
    [Fri Nov 22 22:31:37 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 22:31:43 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
    [Fri Nov 22 22:31:43 2024] EXT4-fs (dm-15): unmounting filesystem cbc8784a-0388-41b5-b643-b7c71966fea4.
    [Fri Nov 22 22:31:43 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 22:31:46 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 22:33:36 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
    [Fri Nov 22 22:33:37 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 22:34:18 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
    [Fri Nov 22 22:34:19 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 23:44:35 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
    [Fri Nov 22 23:55:56 2024] EXT4-fs (dm-18): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
    [Fri Nov 22 23:55:57 2024] EXT4-fs (dm-18): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a r/w with ordered data mode. Quota mode: none.
    [Fri Nov 22 23:57:18 2024] EXT4-fs (dm-7): unmounting filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53.
    [Fri Nov 22 23:57:19 2024] EXT4-fs (dm-7): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:00:00 2024] EXT4-fs (dm-17): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
    [Sat Nov 23 00:00:01 2024] EXT4-fs (dm-17): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:00:29 2024] EXT4-fs (dm-8): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
    [Sat Nov 23 00:00:30 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:06:26 2024] EXT4-fs (dm-10): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
    [Sat Nov 23 00:06:27 2024] EXT4-fs (dm-10): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:06:29 2024] EXT4-fs (dm-9): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
    [Sat Nov 23 00:06:31 2024] EXT4-fs (dm-9): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:06:33 2024] EXT4-fs (dm-19): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
    [Sat Nov 23 00:06:35 2024] EXT4-fs (dm-19): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:06:38 2024] EXT4-fs (dm-8): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
    [Sat Nov 23 00:06:39 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:06:43 2024] EXT4-fs (dm-6): unmounting filesystem 24325513-9afd-49c7-b755-47d861370a58.
    [Sat Nov 23 00:06:44 2024] EXT4-fs (dm-6): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:06:55 2024] EXT4-fs (dm-16): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
    [Sat Nov 23 00:06:56 2024] EXT4-fs (dm-16): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:07:18 2024] EXT4-fs (dm-11): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
    [Sat Nov 23 00:07:19 2024] EXT4-fs (dm-11): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:07:21 2024] EXT4-fs (dm-12): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
    [Sat Nov 23 00:07:23 2024] EXT4-fs (dm-12): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:07:25 2024] EXT4-fs (dm-13): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
    [Sat Nov 23 00:07:26 2024] EXT4-fs (dm-13): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:07:28 2024] EXT4-fs (dm-14): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
    [Sat Nov 23 00:07:29 2024] EXT4-fs (dm-14): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 00:39:53 2024] EXT4-fs (dm-17): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
    [Sat Nov 23 00:39:54 2024] EXT4-fs (dm-17): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 03:59:58 2024] EXT4-fs (dm-21): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 ro without journal. Quota mode: none.
    [Sat Nov 23 04:00:13 2024] EXT4-fs (dm-21): unmounting filesystem 24325513-9afd-49c7-b755-47d861370a58.
    [Sat Nov 23 04:00:14 2024] EXT4-fs (dm-21): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 ro without journal. Quota mode: none.
    [Sat Nov 23 04:01:19 2024] EXT4-fs (dm-21): unmounting filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53.
    [Sat Nov 23 04:01:20 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sat Nov 23 04:01:20 2024] EXT4-fs (dm-21): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc ro without journal. Quota mode: none.
    [Sat Nov 23 04:02:16 2024] EXT4-fs (dm-21): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
    [Sat Nov 23 04:02:17 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sat Nov 23 04:02:17 2024] EXT4-fs (dm-21): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 ro without journal. Quota mode: none.
    [Sat Nov 23 04:03:39 2024] EXT4-fs (dm-21): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
    [Sat Nov 23 04:03:40 2024] EXT4-fs (dm-21): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d ro without journal. Quota mode: none.
    [Sat Nov 23 04:03:55 2024] EXT4-fs (dm-21): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
    [Sat Nov 23 04:03:55 2024] EXT4-fs (dm-21): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f ro without journal. Quota mode: none.
    [Sat Nov 23 04:04:19 2024] EXT4-fs (dm-21): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
    [Sat Nov 23 04:04:20 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sat Nov 23 04:04:20 2024] EXT4-fs (dm-21): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b ro without journal. Quota mode: none.
    [Sat Nov 23 04:05:12 2024] EXT4-fs (dm-21): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
    [Sat Nov 23 04:05:13 2024] EXT4-fs (dm-21): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a ro without journal. Quota mode: none.
    [Sat Nov 23 04:05:25 2024] EXT4-fs (dm-21): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
    [Sat Nov 23 04:05:26 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sat Nov 23 04:05:26 2024] EXT4-fs (dm-21): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b ro without journal. Quota mode: none.
    [Sat Nov 23 04:06:07 2024] EXT4-fs (dm-21): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
    [Sat Nov 23 04:06:08 2024] EXT4-fs (dm-21): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b ro without journal. Quota mode: none.
    [Sat Nov 23 04:06:26 2024] EXT4-fs (dm-21): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
    [Sat Nov 23 04:06:27 2024] EXT4-fs (dm-21): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc ro without journal. Quota mode: none.
    [Sat Nov 23 04:06:45 2024] EXT4-fs (dm-21): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
    [Sat Nov 23 04:06:46 2024] EXT4-fs (dm-21): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 ro without journal. Quota mode: none.
    [Sat Nov 23 04:07:08 2024] EXT4-fs (dm-21): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
    [Sat Nov 23 04:07:08 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sat Nov 23 04:07:08 2024] EXT4-fs (dm-21): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 ro without journal. Quota mode: none.
    [Sat Nov 23 04:08:03 2024] EXT4-fs (dm-21): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
    [Sat Nov 23 04:08:04 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Sat Nov 23 04:08:33 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
    [Sun Nov 24 03:59:58 2024] EXT4-fs (dm-21): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 ro without journal. Quota mode: none.
    [Sun Nov 24 04:00:14 2024] EXT4-fs (dm-21): unmounting filesystem 24325513-9afd-49c7-b755-47d861370a58.
    [Sun Nov 24 04:00:14 2024] EXT4-fs (dm-21): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 ro without journal. Quota mode: none.
    [Sun Nov 24 04:01:23 2024] EXT4-fs (dm-21): unmounting filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53.
    [Sun Nov 24 04:01:23 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sun Nov 24 04:01:23 2024] EXT4-fs (dm-21): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc ro without journal. Quota mode: none.
    [Sun Nov 24 04:02:19 2024] EXT4-fs (dm-21): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
    [Sun Nov 24 04:02:20 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sun Nov 24 04:02:20 2024] EXT4-fs (dm-21): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 ro without journal. Quota mode: none.
    [Sun Nov 24 04:03:38 2024] EXT4-fs (dm-21): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
    [Sun Nov 24 04:03:39 2024] EXT4-fs (dm-21): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d ro without journal. Quota mode: none.
    [Sun Nov 24 04:03:54 2024] EXT4-fs (dm-21): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
    [Sun Nov 24 04:03:54 2024] EXT4-fs (dm-21): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f ro without journal. Quota mode: none.
    [Sun Nov 24 04:04:18 2024] EXT4-fs (dm-21): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
    [Sun Nov 24 04:04:18 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sun Nov 24 04:04:18 2024] EXT4-fs (dm-21): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b ro without journal. Quota mode: none.
    [Sun Nov 24 04:05:11 2024] EXT4-fs (dm-21): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
    [Sun Nov 24 04:05:12 2024] EXT4-fs (dm-21): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a ro without journal. Quota mode: none.
    [Sun Nov 24 04:05:24 2024] EXT4-fs (dm-21): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
    [Sun Nov 24 04:05:25 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sun Nov 24 04:05:25 2024] EXT4-fs (dm-21): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b ro without journal. Quota mode: none.
    [Sun Nov 24 04:06:06 2024] EXT4-fs (dm-21): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
    [Sun Nov 24 04:06:07 2024] EXT4-fs (dm-21): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b ro without journal. Quota mode: none.
    [Sun Nov 24 04:06:26 2024] EXT4-fs (dm-21): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
    [Sun Nov 24 04:06:26 2024] EXT4-fs (dm-21): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc ro without journal. Quota mode: none.
    [Sun Nov 24 04:06:44 2024] EXT4-fs (dm-21): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
    [Sun Nov 24 04:06:45 2024] EXT4-fs (dm-21): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 ro without journal. Quota mode: none.
    [Sun Nov 24 04:07:08 2024] EXT4-fs (dm-21): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
    [Sun Nov 24 04:07:09 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
    [Sun Nov 24 04:07:09 2024] EXT4-fs (dm-21): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 ro without journal. Quota mode: none.
    [Sun Nov 24 04:08:09 2024] EXT4-fs (dm-21): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
    [Sun Nov 24 04:08:09 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
    [Sun Nov 24 04:08:39 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
    /var:
    866M    /var/
    577M    /var/log
    569M    /var/log/journal/da7db0d5e1f14d77a2dded5aef8843b3
    207M    /var/lib
    Archived and active journals take up 446.4M in the file system.
    /opt/iobroker/backups:
    5.9M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    966M    /opt/iobroker/iobroker-data/
    778M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    find: Failed to change directory: /root: Permission denied
    find: Failed to restore initial working directory: /root: Permission denied
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IOBroker            IOBroker (version: 6.0.11, hostname: IOBroker      , alive, uptime: 159430)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     3
    +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#1de8967c7f7150dfdc1c281899adc5d01777b050)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    +-- iobroker.tapo@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#a0e9a3b930c67eceaee5f97d2a48094434838d36)
    Adapter State
    + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : IOBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : IOBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : IOBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : IOBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : IOBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker                                 -  enabled, port: 18701
    + system.adapter.hs100.0                  : hs100                 : IOBroker                                 -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : IOBroker                                 -  enabled
    + system.adapter.hue-extended.1           : hue-extended          : IOBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : IOBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : IOBroker                                 -  enabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : IOBroker                                 -  enabled, port: 8082, bind: 192.168.178.12 (SSL), run as: admin
    + system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : IOBroker                                 -  enabled, port: 1883, bind: 192.168.178.12
    + system.adapter.node-red.0               : node-red              : IOBroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
    + system.adapter.shelly.0                 : shelly                : IOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : IOBroker                                 -  enabled, port: 18479, bind: 192.168.178.12
    + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : IOBroker                                 -  enabled, port: 5432
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBroker                                 -  enabled
    + system.adapter.tapo.0                   : tapo                  : IOBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : IOBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : IOBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : IOBroker                                 -  enabled, port: 8082, bind: 192.168.178.12 (SSL), run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hs100"        : 2.2.2    , installed 2.2.2
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        18101
    States:         14167
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/crowdsec/crowdsec/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 192.168.178.12:18701    0.0.0.0:*               LISTEN      1000       12326646   626/io.hm-rpc.2
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12315949   1/init
    tcp        0      0 192.168.178.12:18479    0.0.0.0:*               LISTEN      1000       12331095   701/io.shelly.1
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          12317900   322/master
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       12323127   487/node-red
    tcp        0      0 192.168.178.12:49292    0.0.0.0:*               LISTEN      1000       12327006   611/io.hm-rpc.1
    tcp        0      0 192.168.178.12:1883     0.0.0.0:*               LISTEN      1000       12328941   671/io.mqtt.0
    tcp        0      0 127.0.0.1:6060          0.0.0.0:*               LISTEN      0          12318055   335/crowdsec
    tcp        0      0 192.168.178.12:8082     0.0.0.0:*               LISTEN      1000       19945625   2719/io.web.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       12318014   151/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       12316111   151/iobroker.js-con
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       19956216   2749/io.jarvis.0
    tcp        0      0 192.168.178.12:42010    0.0.0.0:*               LISTEN      1000       12326279   593/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12316801   1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      1000       12322032   487/node-red
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12316730   1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       12316363   343/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          12317901   322/master
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       12327616   686/io.shelly.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12315950   1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       12323128   487/node-red
    udp6       0      0 :::111                  :::*                                0          12315951   1/init
    2024-11-24 20:45:31.598  - info: tapo.0 (7482) Wait for connections for non camera devices
    2024-11-24 20:45:37.482  - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.86
    2024-11-24 20:45:41.599  - info: tapo.0 (7482) Start first Update
    2024-11-24 20:46:45.763  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:46:45.764  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:47:22.501  - info: tapo.0 (7482) false
    2024-11-24 20:47:26.531  - info: tapo.0 (7482) false
    2024-11-24 20:48:15.811  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:48:15.812  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:49:45.796  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:49:45.797  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:50:57.032  - info: host.IOBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 7515
    2024-11-24 20:50:57.637  - info: dwd.0 (7515) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 6.0.11
    2024-11-24 20:50:58.068  - info: dwd.0 (7515) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-11-24 20:50:58.579  - info: host.IOBroker instance system.adapter.dwd.0 having pid 7515 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-24 20:51:15.779  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:51:15.780  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:52:45.763  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:52:45.764  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:54:15.812  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:54:15.812  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:55:45.796  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:55:45.796  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    2024-11-24 20:57:15.780  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
    2024-11-24 20:57:15.780  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
    iob diag has finished.
    Copy text starting here:
                            v.2024-10-19
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Pending OS-Updates:     1
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            4.3G        2.5G        952M        106K        864M        1.8G
    Swap:           536M         16K        536M
    ioBroker Core:          js-controller           6.0.11
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                18101
    States:                 14167
    Size of iob-Database:
    Firmware der Steckdosen 1.5.5
    Ich habe ja noch den hs100 adapter dort laufen die TPLInk Steckosen normal (sind keine KASA sondern TP Link Steckdosen)
    Ro75R Offline
    Ro75R Offline
    Ro75
    #601
    @benjamincz sagte in Test Adapter TP-Link Tapo:
    HS100 (KASA) habe ich auch 4 Stück. Die laufen aber nur dort und die TAPO nur unter TAPO. Vermischen ist nicht. Wobei die Verbindung bei den HS100 auch nicht so gut aussieht.
    Du setzt einen Container ein. Vielleicht mal einen neuen aufsetzen. Aber da bin ich raus.
    Ro75.
    B 2 Antworten Letzte Antwort
    • Ro75R Ro75
      Ro75.
      BenjaminCz
      #602
      @ro75 Ja die anderen Steckdosen sind noch nicht eingesteckt deshalb die fehlermeldung. Ich habe jetzt einen workaround über alexa2 adapter. Damit ich ich die steuern aktuell aber ist ja nicht lokal sondern cloud lösung. COntainer habe ich gestern einen gemacht mit 2gb ram aber da war das dass gleiche Problem. Wo kann ich sehen welchen dns server die steckdosen haben evtl liegt es noch daran ?
      • N nimsoc
        @sigi234 said in Test Adapter TP-Link Tapo:
        @nimsoc
        Bitte benutzt die Code Tags Funktion -> </>
        Hier gehts zur Hilfe.
        Hi, sorry, hier nochmal der 'debug' Log für @tombox mit Code Tags.
        Bin dankbar für jeden Tipp.
        tapo.0
        2024-11-23 21:29:23.876 info Start first Update
        tapo.0
        2024-11-23 21:29:13.875 info Wait for connections for non camera devices
        tapo.0
        2024-11-23 21:29:13.869 debug initResult 8022351778BC1F7F570D99814A2CFE072104474A undefined
        tapo.0
        2024-11-23 21:29:13.869 error 52 - Get Device Info failed
        tapo.0
        2024-11-23 21:29:13.869 error {}
        tapo.0
        2024-11-23 21:29:13.869 info Initialized 8022351778BC1F7F570D99814A2CFE072104474A
        tapo.0
        2024-11-23 21:29:13.869 debug undefined
        tapo.0
        2024-11-23 21:29:13.869 debug Init cipher successful
        tapo.0
        2024-11-23 21:29:13.868 debug Handshake 2 successful:
        tapo.0
        2024-11-23 21:29:13.868 debug Received request on host response: 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.857 debug Handshake 1 successful
        tapo.0
        2024-11-23 21:29:13.857 debug Handshake 1 cookie: "TP_SESSIONID=94C1082CB75A8E19ACCB8B1ABDC60818;TIMEOUT=86400"
        tapo.0
        2024-11-23 21:29:13.856 debug Received request on host response: 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.845 debug Trying new habdshake
        tapo.0
        2024-11-23 21:29:13.845 debug Detected KLAP device
        tapo.0
        2024-11-23 21:29:13.845 info Trying KLAP Auth
        tapo.0
        2024-11-23 21:29:13.845 debug Received Handshake P100 on host response: 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.823 debug Handshake P100 on host: 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.823 info Constructing P110 on host: 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.779 debug Constructing P100 on host: 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.779 info Init device 8022351778BC1F7F570D99814A2CFE072104474A type P110 with ip 192.168.188.125
        tapo.0
        2024-11-23 21:29:13.778 debug {"hwVer":"1.0","category":"plug","model":"P110","ssid":"RlJJVFohQm94IDc0OTA=","mac":"4822546428BE","hwId":"2FB30EF5BF920C44099401D396C6B55B","fwId":"00000000000000000000000000000000","oemId":"18BDC6C734AF8407B3EF871EACFCECF5","fwVer":"1.3.1 Build 240621 Rel.162048","ip":"192.168.188.125","onboardingTime":1702323054,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
        tapo.0
        2024-11-23 21:29:13.560 debug Found device 8022351778BC1F7F570D99814A2CFE072104474A VFYgRWNrZQ==
        tapo.0
        2024-11-23 21:29:13.560 debug initResult 80225FFE25B13340A9EE576950434B472104B7F1 undefined
        tapo.0
        2024-11-23 21:29:13.560 error 52 - Get Device Info failed
        tapo.0
        2024-11-23 21:29:13.560 error {}
        tapo.0
        2024-11-23 21:29:13.559 info Initialized 80225FFE25B13340A9EE576950434B472104B7F1
        tapo.0
        2024-11-23 21:29:13.559 debug undefined
        tapo.0
        2024-11-23 21:29:13.559 debug Init cipher successful
        tapo.0
        2024-11-23 21:29:13.558 debug Handshake 2 successful:
        tapo.0
        2024-11-23 21:29:13.558 debug Received request on host response: 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.549 debug Handshake 1 successful
        tapo.0
        2024-11-23 21:29:13.548 debug Handshake 1 cookie: "TP_SESSIONID=3CA5EBC869D9E9C695F3E7C7BF8DE6C0;TIMEOUT=86400"
        tapo.0
        2024-11-23 21:29:13.548 debug Received request on host response: 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.537 debug Trying new habdshake
        tapo.0
        2024-11-23 21:29:13.537 debug Detected KLAP device
        tapo.0
        2024-11-23 21:29:13.537 info Trying KLAP Auth
        tapo.0
        2024-11-23 21:29:13.537 debug Received Handshake P100 on host response: 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.515 debug Handshake P100 on host: 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.515 info Constructing P110 on host: 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.421 debug Constructing P100 on host: 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.420 info Init device 80225FFE25B13340A9EE576950434B472104B7F1 type P110 with ip 192.168.188.116
        tapo.0
        2024-11-23 21:29:13.419 debug {"hwVer":"1.0","category":"plug","model":"P110","ssid":"RlJJVFohQm94IDc0OTA=","mac":"48225464204A","hwId":"2FB30EF5BF920C44099401D396C6B55B","fwId":"00000000000000000000000000000000","oemId":"18BDC6C734AF8407B3EF871EACFCECF5","fwVer":"1.3.1 Build 240621 Rel.162048","ip":"192.168.188.116","onboardingTime":1697298596,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
        tapo.0
        2024-11-23 21:29:13.184 debug Found device 80225FFE25B13340A9EE576950434B472104B7F1 Raspberry Pi
        tapo.0
        2024-11-23 21:29:13.183 info Found 2 devices
        tapo.0
        2024-11-23 21:29:13.183 debug {"error_code":0,"result":{"totalNum":2,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.3.1 Build 240621 Rel.162048","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80225FFE25B13340A9EE576950434B472104B7F1","deviceName":"P110","deviceHwVer":"1.0","alias":"UmFzcGJlcnJ5IFBp","deviceMac":"48225464204A","oemId":"18BDC6C734AF8407B3EF871EACFCECF5","deviceModel":"P110(EU)","hwId":"2FB30EF5BF920C44099401D396C6B55B","fwId":"00000000000000000000000000000000","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.3.1 Build 240621 Rel.162048","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022351778BC1F7F570D99814A2CFE072104474A","deviceName":"P110","deviceHwVer":"1.0","alias":"VFYgRWNrZQ==","deviceMac":"4822546428BE","oemId":"18BDC6C734AF8407B3EF871EACFCECF5","deviceModel":"P110(EU)","hwId":"2FB30EF5BF920C44099401D396C6B55B","fwId":"00000000000000000000000000000000","isSameRegion":true,"status":0}],"currentIndex":1}}
        tapo.0
        2024-11-23 21:29:12.996 debug yfoQzXVQIYQWjRDZuXyppQ==
        tapo.0
        2024-11-23 21:29:12.995 info Login succesfull
        tapo.0
        2024-11-23 21:29:12.995 debug {"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Sat Nov 23 11:17:39 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"058029a9-BT7To9zBFLWlo5xNP2cooJ2","accountId":"15*****","regionCode":"","regTime":"2023-10-14 15:47:20","nickname":"c***","email":"c****@**","refreshToken":"21c415b6e9ac468c9fd608d5e2fb7737"}}
        tapo.0
        2024-11-23 21:29:12.716 debug Nu5mbssUcSfg778xhNYYFw==
        tapo.0
        2024-11-23 21:29:12.671 info Login tp TAPO App
        tapo.0
        2024-11-23 21:29:12.652 info starting. Version 0.3.4 (non-npm: TA2k/ioBroker.tapo#0eb45d794d70c5df51c8755c2907b8d42d8e3140) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.1, js-controller: 6.0.11
        tapo.0
        2024-11-23 21:29:12.522 debug Plugin sentry Initialize Plugin (enabled=true)
        tapo.0
        2024-11-23 21:29:12.510 debug States connected to redis: 127.0.0.1:9000
        tapo.0
        2024-11-23 21:29:12.463 debug States create User PubSub Client
        tapo.0
        2024-11-23 21:29:12.462 debug States create System PubSub Client
        tapo.0
        2024-11-23 21:29:12.458 debug Redis States: Use Redis connection: 127.0.0.1:9000
        tapo.0
        2024-11-23 21:29:12.448 debug Objects connected to redis: 127.0.0.1:9001
        tapo.0
        2024-11-23 21:29:12.444 debug Objects client initialize lua scripts
        tapo.0
        2024-11-23 21:29:12.431 debug Objects create User PubSub Client
        tapo.0
        2024-11-23 21:29:12.430 debug Objects create System PubSub Client
        tapo.0
        2024-11-23 21:29:12.429 debug Objects client ready ... initialize now
        tapo.0
        2024-11-23 21:29:12.416 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.raspberrypi5
        2024-11-23 21:29:11.812 info instance system.adapter.tapo.0 in version "0.3.4" (non-npm: TA2k/ioBroker.tapo#0eb45d794d70c5df51c8755c2907b8d42d8e3140) started with pid 107034
        tombox
        #603
        @nimsoc Das ist nicht die aktuelle GitHub version
        N 1 Antwort Letzte Antwort
        • Hant0rH Hant0r
          Wäre es eigentlich möglich, in den DP von Tapo den Namen mit anzuzeigen, der in der App vergeben wurde?
          So ist es immer schwer rauszufinden, welcher Stecker was ist....
          tombox
          #604
          @hant0r In welchem Datenpunkt ist der Name gespeichert
          Hant0rH 1 Antwort Letzte Antwort
          • Ro75R Ro75
            @hant0r also bei mir finde ich den passenden über die Datenpunkte. Es kommt auch darauf an, wie das Gerät in der App eingerichtet und welchen Räumen zugeordnet wurde. Diese Infos findet man in den Datenpunkten wieder.
            Ro75
            Hant0rH Offline
            Hant0rH Offline
            Hant0r
            schrieb am zuletzt editiert von Hant0r
            #605
            @ro75 sagte in Test Adapter TP-Link Tapo:
            Ro75
            Erwartet hätte ich die Namen unter "Namen" beim Hauptordner oder zumindest unter dem DP "alias".
            Aber der Name des Gerätes wird in keinem der vorhanden DP angezeigt. Auch der zugeordnete Raum nicht.
            Mache ich etwas falsch?
            • T tombox
              N Offline
              N Offline
              nimsoc
              #606
              @tombox said in Test Adapter TP-Link Tapo:
              Ich konnte bislang nur folgendes installieren:
              Erstmal unter "benutzerdefiniert" den 0.3.4 Adapter mit diesem Link:
              https://github.com/TA2k/ioBroker.tapo
              Erst dann erscheint unter "von Github" im Dropdownmenu unter TA2k: "TP-Link Tapo [TA2k]", den ich zusätzlich installiert habe.
              Dann den Adapter instanziiert, es tut sich aber nach wie vor nichts bei der Anzeige vom Energieverbrauch. Alles sieht genauso aus wie im Debug Code von oben.
              • N nimsoc
                tombox
                #607
                @nimsoc Einfach via GitHub installieren und neustarten dann nochmal den log posten
                • Hant0rH Offline
                  Hant0rH Offline
                  Hant0r
                  #608
                  Und was mir noch aufgefallen ist, kann es sein, dass der Adapter es gar nicht mag, wenn ein Gerät plözlich nicht mehr am Strom hängt?
                  Meine Frau hatte einen Stecker gezogen und später wieder eingesteckt. Das Log im ioBroker war übersäht mit den Meldungen und funktionierte erst nach einem Neustart wieder:
                  tapo.0 2024-11-25 15:06:36.766	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:06:26.761	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:06:16.761	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:06:06.763	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:56.760	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:46.757	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:36.757	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:26.762	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:16.759	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:06.758	error	Request failed with status code 403
                  tapo.0 2024-11-25 15:05:04.332	error	Request failed with status code 403
                  oder auch schön:
                  tapo.0 2024-11-26 08:55:02.239	info	true
                  tapo.0 2024-11-26 08:55:02.232	info	true
                  tapo.0 2024-11-26 08:55:02.208	info	true
                  tapo.0 2024-11-26 08:50:02.241	info	true
                  tapo.0 2024-11-26 08:50:02.239	info	true
                  tapo.0 2024-11-26 08:50:02.224	info	true
                  tapo.0 2024-11-26 08:45:02.265	info	true
                  tapo.0 2024-11-26 08:45:02.263	info	true
                  tapo.0 2024-11-26 08:45:02.260	info	true
                  tapo.0 2024-11-26 08:40:02.232	info	true
                  tapo.0 2024-11-26 08:40:02.226	info	true
                  tapo.0 2024-11-26 08:40:02.218	info	true
                  kann man das abstellen?
                  • T tombox
                    Hant0rH Offline
                    Hant0rH Offline
                    Hant0r
                    #609
                    @tombox sagte in Test Adapter TP-Link Tapo:
                    So wie es aussieht, leider in keinen :(
                    • Ro75R Ro75
                      Ro75.
                      BenjaminCz
                      #610
                      @ro75 Hi kann es zusammen hängen das ich die Konten von TPLInk und Tapo Fusioniert habe ? Ich habe aktuell ein Tapo Konto mit der Tapo Android app und dort habe ich die TP-Link Steckdosen und die Tapo Steckdosen und kann beide Typen Schalten. Ich habe echt alles Probiert auch ohne schnick schnack direkt neuen router eingerichtet iobroker aufgesetzt und tapo adapter installiert aber auch hier gleiches Problem er findet die Steckdosen ruft diese auch ab aber ich kann diese wenn ich true oder false schalte am datenpunkt unter remote passiert einfach nix.
                      Funktionieren bei allen anderen die Steckdosen nur bei mir nicht ? Hatt einer die gleiche Konstelation wie ich mit der Firmware der Steckdose wie oben beschrieben und IOBroker auf Aktuellstem Stand ?
                      B T 2 Antworten Letzte Antwort
                      • B BenjaminCz
                        BenjaminCz
                        #611
                        Nachtrag:
                        bzw. gibt es einen anderen adapter oder kann man die Steckdosen irgendwie flashen das die nur lokal Funktionieren ?
                        • B BenjaminCz
                          tombox
                          schrieb am zuletzt editiert von tombox
                          #612
                          @benjamincz Schaue mir das alles am Wochenende intensiv an mit eigner P100
                          • Ro75R Offline
                            Ro75R Offline
                            Ro75
                            #613
                            @benjamincz die Kazan Steckdosen laufen im hs100. In der Android App im der tapo und in der kaza. Also sowohl als auch. Und im iobroker die einen mit dem hs100 und die anderen im tapo. Lassen sich schalten und alles ok.
                            Ro75
                            • N nimsoc
                              @nimsoc
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              tapo.0
                              host.raspberrypi5
                              tombox
                              #614
                              @nimsoc @BenjaminCz @Walter-White
                              bitte 0.4.1 testen
                              N M 2 Antworten Letzte Antwort
                              • T tombox
                                bitte 0.4.1 testen
                                N Offline
                                N Offline
                                nimsoc
                                #615
                                bitte 0.4.0 testen
                                Strommessung funktioniert jetzt! Besten Dank!
                                • T tombox
                                  bitte 0.4.1 testen
                                  mbw
                                  #616
                                  @tombox
                                  Hi zusammen, bei mir funktioniert die P100 leider nicht mit der Version 0.4.1
                                  tapo.0 2024-11-29 14:52:46.529	info	starting. Version 0.4.1 (non-npm: TA2k/ioBroker.tapo#259c74d007bc086f3f508243dd2c523c5c74ded4) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 6.0.11
                                  tapo.0 2024-11-29 14:52:46.581	info	Login tp TAPO App
                                  tapo.0 2024-11-29 14:52:46.597	debug	QNPZ/8BSviD1DAjHLsWv7Q==
                                  tapo.0 2024-11-29 14:52:47.005	debug	{"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Fri Nov 29 12:20:16 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"XXXX-XXXX","accountId":"XXXX","regionCode":"DE","regTime":"2020-08-12 21:31:15","nickname":"XXXX","email":"XXXX","refreshToken":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"}}
                                  tapo.0 2024-11-29 14:52:47.007	info	Login succesfull
                                  tapo.0 2024-11-29 14:52:47.009	debug	yfoQzXVQIYQWjRDZuXyppQ==
                                  tapo.0 2024-11-29 14:52:47.229	debug	{"error_code":0,"result":{"totalNum":1,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.3.7 Build 20230711 Rel. 61904","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01","deviceName":"P100","deviceHwVer":"1.0","alias":"U21hcnRlIFN0ZWNrZG9zZQ==","deviceMac":"B09575BA1B94","oemId":"9552772F906C60A9AEEA36A3347B6EBC","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0}],"currentIndex":0}}
                                  tapo.0 2024-11-29 14:52:47.231	info	Found 1 devices
                                  tapo.0 2024-11-29 14:52:47.233	debug	Found device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 Smarte Steckdose
                                  tapo.0 2024-11-29 14:52:47.493	debug	{"hwVer":"1.0","category":"plug","model":"P100","ssid":"ZmF3by5uZXQuaG9tZQ==","mac":"B09575BA1B94","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"9552772F906C60A9AEEA36A3347B6EBC","fwVer":"1.3.7 Build 20230711 Rel. 61904","ip":"192.168.6.134","onboardingTime":1732888328,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  tapo.0 2024-11-29 14:52:47.496	info	Init device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 type P100 with ip 192.168.6.134
                                  tapo.0 2024-11-29 14:52:47.498	debug	Constructing P100 on host: 192.168.6.134
                                  tapo.0 2024-11-29 14:52:47.578	debug	Handshake P100 on host: 192.168.6.134
                                  tapo.0 2024-11-29 14:52:47.626	debug	Received Handshake P100 on host response: 192.168.6.134
                                  tapo.0 2024-11-29 14:52:47.631	error	106 Error Code: 0, Success 192.168.6.134
                                  tapo.0 2024-11-29 14:52:47.632	debug	Detected KLAP device
                                  tapo.0 2024-11-29 14:52:47.633	debug	Trying new habdshake
                                  tapo.0 2024-11-29 14:52:47.852	error	276 Error: Request failed with status code 404
                                  tapo.0 2024-11-29 14:52:47.854	error	TypeError: res.subarray is not a function
                                  tapo.0 2024-11-29 14:52:47.854	error	KLAP Handshake failed
                                  tapo.0 2024-11-29 14:52:47.855	error	undefined
                                  tapo.0 2024-11-29 14:52:47.856	error	52 - Get Device Info failed
                                  tapo.0 2024-11-29 14:52:47.856	info	Initialized 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01
                                  tapo.0 2024-11-29 14:52:47.856	debug	initResult 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 undefined
                                  tapo.0 2024-11-29 14:52:47.878	info	Wait for connections for non camera devices
                                  tapo.0 2024-11-29 14:52:57.879	info	Start first Update
                                  tapo.0 2024-11-29 14:52:57.880	debug	Update done
                                  • Hant0rH Hant0r
                                    oder auch schön:
                                    Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    #617
                                    @hant0r sagte in Test Adapter TP-Link Tapo:
                                    oder auch schön:
                                    Moin @tombox , konntest du schon herausfinden, was es damit auf sich hat?
                                    • Hant0rH Hant0r
                                      oder auch schön:
                                      tombox
                                      #618
                                      @hant0r bitte mit 0.4.1 testen
                                      • M mbw
                                        @tombox
                                        tombox
                                        #619
                                        @mbw bitte die GitHub version testen
                                        Firmware update ist nicht verfügbar?
                                        • T tombox
                                          mbw
                                          #620
                                          @tombox ich habe die Version von github installiert. Firmware ist auf dem neuesten Stand.
