  4. IO Broker auf 8081 nicht aufrufbar nach wiederherstellung
112 Beiträge 3 Kommentatoren 11.3k Aufrufe 2 Beobachtet
  • U user4711
    @homoran ok seit mehr als 10min passiert jetz nix mehr im log :
    2022-08-20 15:04:25.491  - error: host.buanet-iobroker6 iobroker npm-install: host.buanet-iobroker6 Cannot install iobroker.vis@1.4.15: 6
    2022-08-20 15:04:26.504  - info: host.buanet-iobroker6 iobroker npm-install: exit 25
    2022-08-20 15:04:27.504  - warn: host.buanet-iobroker6 startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
    2022-08-20 15:04:27.505  - info: host.buanet-iobroker6 iobroker install vis@1.4.15 using installedVersion
    2022-08-20 15:04:28.811  - info: host.buanet-iobroker6 iobroker npm-install: NPM version: 8.11.0
    2022-08-20 15:04:28.812  - info: host.buanet-iobroker6 iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2022-08-20 15:04:32.183  - info: vis.0 (3209) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.15.1, js-controller: 4.0.23
    2022-08-20 15:04:32.312  - info: vis.0 (3209) vis license is OK.
    2022-08-20 15:04:32.514  - error: vis.0 (3209) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was n
    ot handled with .catch().
    2022-08-20 15:04:32.515  - error: vis.0 (3209) unhandled promise rejection: Not exists
    2022-08-20 15:04:32.517  - error: vis.0 (3209) Error: Not exists
        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
        at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
        at processImmediate (node:internal/timers:468:21)
    2022-08-20 15:04:32.517  - error: vis.0 (3209) Not exists
    2022-08-20 15:04:33.020  - info: vis.0 (3209) terminating
    2022-08-20 15:04:33.021  - warn: vis.0 (3209) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-08-20 15:04:33.688  - error: host.buanet-iobroker6 iobroker npm-install: host.buanet-iobroker6 Cannot install iobroker.vis@1.4.15: 6
    2022-08-20 15:04:34.701  - info: host.buanet-iobroker6 iobroker npm-install: exit 25
    2022-08-20 15:04:35.702  - error: host.buanet-iobroker6 Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2022-08-20 15:09:38.695  - info: host.buanet-iobroker6 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-08-20 15:16:24.391  - info: host.buanet-iobroker6 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    #81
    @user4711 und wie sieht es unter Instanzen aus?
    ggf. nach einem Reload
    • GlasfaserG Glasfaser
      @user4711 sagte in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
      Dazu habe ich dir oben ... schon etwas geschrieben , was du machen sollst !
      U Offline
      U Offline
      user4711
      #82
      @glasfaser said in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
      hab ich gemacht und dann die ganzen instanzen gestartet, aber nach wie vor JS läuft VIS wieder verstümmelt .
      auch neu gestrartet.
      GlasfaserG HomoranH 3 Antworten Letzte Antwort
      • U user4711
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #83
        Zeigen ...
        kann damit nichts anfangen
        • U user4711
          #84
          hab ich gemacht
          wie immer: zeigen! 😡
          U 1 Antwort Letzte Antwort
          • U user4711
            #85
            warum wenn sie noch nicht installiert waren?
              hab ich gemacht
              U Offline
              U Offline
              user4711
              schrieb am zuletzt editiert von user4711
              #86
              @homoran ok
              sonst sieht es aus (mit alten Version wo der admin nicht funktioniert
              HomoranH GlasfaserG 2 Antworten Letzte Antwort
              • U user4711
                @homoran ok
                #87
                @user4711
                @homoran sagte in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
                  @user4711
                  U Offline
                  U Offline
                  user4711
                  #88
                  @homoran alles normal soweit denke ich :
                  • U user4711
                    #89
                    @user4711 war das schon zum Zeitpunktcdes Screenshots der vis soweit?
                    hast du bei der vis mal einen Forced Refresh des Browsers gemacht?
                    • U user4711
                      @homoran ok
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #90
                      @homoran ok
                      im Vis Editor .
                      sind da Widget in der Liste dabei mit undefined am Ende der Bezeichnung .
                      das fehlt zb. !?
                      https://github.com/ioBroker/ioBroker.vis-canvas-gauges
                      HomoranH U 2 Antworten Letzte Antwort
                        @homoran ok
                        im Vis Editor .
                        das fehlt zb. !?
                        #91
                        @glasfaser bitte eins nach dem anderen.
                        Ich fürchte sonst beantwortet mit @user4711 meine eben nochmal gestellte Frage wieder nicht
                          @homoran ok
                          im Vis Editor .
                          das fehlt zb. !?
                          U Offline
                          U Offline
                          user4711
                          #92
                          das fehlt zb. !?
                          ja das sind die die fehlen
                          • U user4711
                            das fehlt zb. !?
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #93
                            @user4711
                            Erst die Frage von @Homoran beantworten ...
                              @user4711
                              #94
                              @glasfaser hat sich erledigt!
                              besser ist jetzt die Ausgabe von
                              iobroker update -i und iobroker list instances sowie iobroker list adapters
                                U Offline
                                U Offline
                                user4711
                                #95
                                @homoran said in IO Broker auf 8081 nicht aufrufbar nach wiederherstellung:
                                ja
                                  U Offline
                                  U Offline
                                  user4711
                                  #96
                                  @homoran ok das war das Problem das einige Adapter nicht installiert waren, muss jetz mal schauen ob es korrekt funktioniert .
                                  Aber eigentlich hätten die doch vom Backup aus aktiviert werden müssen oder ?
                                  • U user4711
                                    #97
                                    das versuche ich ja gerade herauszufinden
                                    • U user4711
                                      #98
                                      hast du das jetzt etwa manuell nachgeholt?
                                        U Offline
                                        U Offline
                                        user4711
                                        #99
                                        ja hab geschaut welche das sind im VIS mit endung undefined und dann den Namen gesucht und manuell nachinstalliert
                                        • U user4711
                                          #100
                                          dann kann ich dir nicht mehr helfen
