  4. [gelöst] Jeelink funktioniert nach Update nicht mehr
    5.8k
jeelink-adapterupdates
78 Beiträge 3 Kommentatoren 8.6k Aufrufe 3 Beobachtet
  • GregorSG GregorS
    @glasfaser
    ost.TinkerboardS
    	2022-08-15 19:01:30.470	info	Rebuild for adapter system.adapter.jeelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.TinkerboardS
    	2022-08-15 19:01:30.470	error	instance system.adapter.jeelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.TinkerboardS
    	2022-08-15 19:01:30.469	error	Caught by controller[0]: }
    host.TinkerboardS
    	2022-08-15 19:01:30.469	error	Caught by controller[0]: ]
    host.TinkerboardS
    	2022-08-15 19:01:30.469	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/jeelink.js'
    host.TinkerboardS
    	2022-08-15 19:01:30.469	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/lib/index.js',
    host.TinkerboardS
    	2022-08-15 19:01:30.469	error	Caught by controller[0]: requireStack: [
    host.TinkerboardS
    	2022-08-15 19:01:30.469	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.TinkerboardS
    	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) {
    host.TinkerboardS
    	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    host.TinkerboardS
    	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    host.TinkerboardS
    	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    host.TinkerboardS
    	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
    host.TinkerboardS
    	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/lib/index.js:2:17)
    host.TinkerboardS
    	2022-08-15 19:01:30.467	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.TinkerboardS
    	2022-08-15 19:01:30.467	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.TinkerboardS
    	2022-08-15 19:01:30.467	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    host.TinkerboardS
    	2022-08-15 19:01:30.467	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
    host.TinkerboardS
    	2022-08-15 19:01:30.467	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.jeelink/jeelink.js
    host.TinkerboardS
    	2022-08-15 19:01:30.467	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/lib/index.js
    host.TinkerboardS
    	2022-08-15 19:01:30.466	error	Caught by controller[0]: Require stack:
    host.TinkerboardS
    	2022-08-15 19:01:30.466	error	Caught by controller[0]: Error: Cannot find module '@serialport/bindings'
    host.TinkerboardS
    	2022-08-15 19:01:30.466	error	Caught by controller[0]: ^
    host.TinkerboardS
    	2022-08-15 19:01:30.466	error	Caught by controller[0]: throw err;
    host.TinkerboardS
    	2022-08-15 19:01:30.465	error	Caught by controller[0]: node:internal/modules/cjs/loader:936
    host.TinkerboardS
    	2022-08-15 19:01:29.921	info	instance system.adapter.jeelink.0 started with pid 26824
    host.TinkerboardS
    	2022-08-15 19:01:29.856	info	iobroker npm-rebuild: exit 1
    host.TinkerboardS
    	2022-08-15 19:01:28.839	error	iobroker npm-rebuild: Rebuilding native modules failed
    host.TinkerboardS
    	2022-08-15 19:01:16.318	info	iobroker npm-rebuild: Rebuilding native modules ...
    host.TinkerboardS
    	2022-08-15 19:01:14.757	info	iobroker rebuild
    host.TinkerboardS
    	2022-08-15 19:01:14.756	warn	adapter "jeelink" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @gregors
    Finde es auf die schnelle nicht mehr ...
    Nur als gesamtes ..
    cd /opt/iobroker
    iobroker stop
    npm rebuild
    sudo reboot
    • GlasfaserG Glasfaser
      @gregors sagte in Jeelink funktioniert nach Update nicht mehr:
      Hat 3 x versucht , dann aufgegeben .
      Da war mal was ...
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @GregorS
      https://forum.iobroker.net/topic/26403/nach-node-update-serialport-adapter-hinüber/2
      GregorSG 1 Antwort Letzte Antwort
        @GregorS
        GregorSG Offline
        GregorSG Offline
        GregorS
        @glasfaser
        Hat leider nichts gebracht.
        Jeelink bleibt rot mit den gleichen Fehlern
        INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
        • GregorSG GregorS
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Auch nicht ...was im Link ist !?
          • GregorSG GregorS
            @glasfaser
            ost.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            host.TinkerboardS
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            Und was ist hier mit , was in deinem Log steht !?
            • GregorSG Offline
              GregorSG Offline
              GregorS
              @glasfaser
              was bedeutet das?
              • GregorSG GregorS
                @glasfaser
                was bedeutet das?
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @gregors
                Du sollst ins Verzeichniss jeelink ...
                mußt du nachschauen ob es so richtig geschrieben wird ...
                cd /opt/iobroker/iobroker-data/files/jeelink
                dann darin
                EDIT :
                oder im
                cd /opt/iobroker/node_modules/iobroker.jeelink
                dann darin
                  @gregors
                  dann darin
                  EDIT :
                  oder im
                  dann darin
                  GregorSG Offline
                  GregorSG Offline
                  GregorS
                  @glasfaser
                  Habe ich gemacht, aber jetztr soll ich eine Verzeichnis umbenennen, dass ich nicht finde.
                  npm WARN config production Use `--omit=dev` instead.
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/abab
                  npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T17_43_56_474Z-debug-0.log
                  Es gibt bereits ein Verzeichnis .abab-bvmibCm3
                  • GregorSG GregorS
                    @glasfaser
                    npm ERR! errno -39
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    rm -r /opt/iobroker/node_modules/.abab-bvmibCm3
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      schrieb am zuletzt editiert von GregorS
                      @glasfaser
                      pi@TinkerboardS:/opt/iobroker/iobroker-data/files/jeelink$ npm install --production
                      npm ERR! path /opt/iobroker/node_modules/abort-controller
                      npm ERR! dest /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abort-controller' -> '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa'
                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T18_46_11_223Z-debug-0.log
                      pi@TinkerboardS:/opt/iobroker/iobroker-data/files/jeelink$ .abort-controller-x3pdLVqa
                      Das Verzeichnis ist bereits richtig umbenannt
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        nicht umbenennen !
                        Nächste löschen
                        rm -r  /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                          nicht umbenennen !
                          Nächste löschen
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          @glasfaser
                          War der Meinung rename ...
                          pi@TinkerboardS:~$ rm -r  /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                          rm: das Entfernen von '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                          • GregorSG GregorS
                            @glasfaser
                            npm ERR! errno -39
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            sind dort viele mit einem Punkt vorraus !?
                            • GregorSG Offline
                              GregorSG Offline
                              GregorS
                              @glasfaser
                              Ja, 747 Verzeichnisse
                              • GregorSG GregorS
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                @gregors
                                Dann :
                                for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                                Zitat von Thomas
                                (Bitte Befehl KOPIEREN, nicht eintippen, ein Vertipper kann und wird da 'tödlich' sein).
                                  @gregors
                                  Dann :
                                  GregorSG Offline
                                  GregorSG Offline
                                  GregorS
                                  @glasfaser
                                  jetzt gibt es nur noch .bin
                                  • GregorSG GregorS
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    @gregors
                                    Ja ... den lassen !!!!!!
                                      @gregors
                                      GregorSG Offline
                                      GregorSG Offline
                                      GregorS
                                      @glasfaser
                                      Jetzt nochmal:
                                      dann darin
                                      EDIT :
                                      oder im
                                      dann darin
                                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                      • GregorSG GregorS
                                        @glasfaser
                                        Jetzt nochmal:
                                        dann darin
                                        EDIT :
                                        oder im
                                        dann darin
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        @gregors
                                        Nimm erstmal den im EDIT
                                        • GregorSG GregorS
                                          @glasfaser
                                          Jetzt nochmal:
                                          dann darin
                                          EDIT :
                                          oder im
                                          dann darin
                                          Die neue Syntax seit npm8 ist übrigens
                                          npm install --omit=dev
