  4. [gelöst] Jeelink funktioniert nach Update nicht mehr
    5.8k
jeelink-adapterupdates
78 Beiträge 3 Kommentatoren 8.6k Aufrufe 3 Beobachtet
  • GlasfaserG Offline
    GlasfaserG Offline
    @gregors
    Puhh .... kenne den Adapter nicht ...
    Zeige nochmal den aktuellen Log dazu
    GregorSG 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @gregors
      GregorSG Offline
      GregorSG Offline
      GregorS
      @glasfaser
      ost.TinkerboardS
      	2022-08-15 19:01:30.470	info	Rebuild for adapter system.adapter.jeelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.TinkerboardS
      	2022-08-15 19:01:30.470	error	instance system.adapter.jeelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.TinkerboardS
      	2022-08-15 19:01:30.469	error	Caught by controller[0]: }
      host.TinkerboardS
      	2022-08-15 19:01:30.469	error	Caught by controller[0]: ]
      host.TinkerboardS
      	2022-08-15 19:01:30.469	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/jeelink.js'
      host.TinkerboardS
      	2022-08-15 19:01:30.469	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/lib/index.js',
      host.TinkerboardS
      	2022-08-15 19:01:30.469	error	Caught by controller[0]: requireStack: [
      host.TinkerboardS
      	2022-08-15 19:01:30.469	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.TinkerboardS
      	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) {
      host.TinkerboardS
      	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
      host.TinkerboardS
      	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
      host.TinkerboardS
      	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
      host.TinkerboardS
      	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
      host.TinkerboardS
      	2022-08-15 19:01:30.468	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/lib/index.js:2:17)
      host.TinkerboardS
      	2022-08-15 19:01:30.467	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
      host.TinkerboardS
      	2022-08-15 19:01:30.467	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
      host.TinkerboardS
      	2022-08-15 19:01:30.467	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
      host.TinkerboardS
      	2022-08-15 19:01:30.467	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
      host.TinkerboardS
      	2022-08-15 19:01:30.467	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.jeelink/jeelink.js
      host.TinkerboardS
      	2022-08-15 19:01:30.467	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/lib/index.js
      host.TinkerboardS
      	2022-08-15 19:01:30.466	error	Caught by controller[0]: Require stack:
      host.TinkerboardS
      	2022-08-15 19:01:30.466	error	Caught by controller[0]: Error: Cannot find module '@serialport/bindings'
      host.TinkerboardS
      	2022-08-15 19:01:30.466	error	Caught by controller[0]: ^
      host.TinkerboardS
      	2022-08-15 19:01:30.466	error	Caught by controller[0]: throw err;
      host.TinkerboardS
      	2022-08-15 19:01:30.465	error	Caught by controller[0]: node:internal/modules/cjs/loader:936
      host.TinkerboardS
      	2022-08-15 19:01:29.921	info	instance system.adapter.jeelink.0 started with pid 26824
      host.TinkerboardS
      	2022-08-15 19:01:29.856	info	iobroker npm-rebuild: exit 1
      host.TinkerboardS
      	2022-08-15 19:01:28.839	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.TinkerboardS
      	2022-08-15 19:01:16.318	info	iobroker npm-rebuild: Rebuilding native modules ...
      host.TinkerboardS
      	2022-08-15 19:01:14.757	info	iobroker rebuild
      host.TinkerboardS
      	2022-08-15 19:01:14.756	warn	adapter "jeelink" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
      INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
      GlasfaserG 3 Antworten Letzte Antwort
      • GregorSG GregorS
        @glasfaser
        ost.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        host.TinkerboardS
        GlasfaserG Offline
        GlasfaserG Offline
        @gregors sagte in Jeelink funktioniert nach Update nicht mehr:
        Hat 3 x versucht , dann aufgegeben .
        Da war mal was ...
        • GregorSG GregorS
          @glasfaser
          ost.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          host.TinkerboardS
          GlasfaserG Offline
          GlasfaserG Offline
          @gregors
          Finde es auf die schnelle nicht mehr ...
          Nur als gesamtes ..
          cd /opt/iobroker
          iobroker stop
          npm rebuild
          sudo reboot
            Da war mal was ...
            GlasfaserG Offline
            GlasfaserG Offline
            @GregorS
            https://forum.iobroker.net/topic/26403/nach-node-update-serialport-adapter-hinüber/2
              @GregorS
              GregorSG Offline
              GregorSG Offline
              GregorS
              @glasfaser
              Hat leider nichts gebracht.
              Jeelink bleibt rot mit den gleichen Fehlern
              • GregorSG GregorS
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Auch nicht ...was im Link ist !?
                • GregorSG GregorS
                  @glasfaser
                  ost.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Und was ist hier mit , was in deinem Log steht !?
                  • GregorSG Offline
                    GregorSG Offline
                    GregorS
                    @glasfaser
                    was bedeutet das?
                    • GregorSG GregorS
                      @glasfaser
                      was bedeutet das?
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @gregors
                      Du sollst ins Verzeichniss jeelink ...
                      mußt du nachschauen ob es so richtig geschrieben wird ...
                      cd /opt/iobroker/iobroker-data/files/jeelink
                      dann darin
                      EDIT :
                      oder im
                      cd /opt/iobroker/node_modules/iobroker.jeelink
                      dann darin
                        @gregors
                        dann darin
                        EDIT :
                        oder im
                        dann darin
                        GregorSG Offline
                        GregorSG Offline
                        GregorS
                        @glasfaser
                        Habe ich gemacht, aber jetztr soll ich eine Verzeichnis umbenennen, dass ich nicht finde.
                        npm WARN config production Use `--omit=dev` instead.
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/abab
                        npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T17_43_56_474Z-debug-0.log
                        Es gibt bereits ein Verzeichnis .abab-bvmibCm3
                        • GregorSG GregorS
                          @glasfaser
                          npm ERR! errno -39
                          GlasfaserG Offline
                          GlasfaserG Offline
                          rm -r /opt/iobroker/node_modules/.abab-bvmibCm3
                            GregorSG Offline
                            GregorSG Offline
                            GregorS
                            schrieb am zuletzt editiert von GregorS
                            @glasfaser
                            pi@TinkerboardS:/opt/iobroker/iobroker-data/files/jeelink$ npm install --production
                            npm ERR! path /opt/iobroker/node_modules/abort-controller
                            npm ERR! dest /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abort-controller' -> '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa'
                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T18_46_11_223Z-debug-0.log
                            pi@TinkerboardS:/opt/iobroker/iobroker-data/files/jeelink$ .abort-controller-x3pdLVqa
                            Das Verzeichnis ist bereits richtig umbenannt
                              GlasfaserG Offline
                              nicht umbenennen !
                              Nächste löschen
                              rm -r  /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                                nicht umbenennen !
                                Nächste löschen
                                GregorSG Offline
                                GregorSG Offline
                                GregorS
                                @glasfaser
                                War der Meinung rename ...
                                pi@TinkerboardS:~$ rm -r  /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
                                rm: das Entfernen von '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                • GregorSG GregorS
                                  @glasfaser
                                  npm ERR! errno -39
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  sind dort viele mit einem Punkt vorraus !?
                                  • GregorSG Offline
                                    GregorSG Offline
                                    GregorS
                                    @glasfaser
                                    Ja, 747 Verzeichnisse
                                    • GregorSG GregorS
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @gregors
                                      Dann :
                                      for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                                      Zitat von Thomas
                                      (Bitte Befehl KOPIEREN, nicht eintippen, ein Vertipper kann und wird da 'tödlich' sein).
                                        @gregors
                                        Dann :
                                        GregorSG Offline
                                        GregorSG Offline
                                        GregorS
                                        @glasfaser
                                        jetzt gibt es nur noch .bin
                                        • GregorSG GregorS
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @gregors
                                          Ja ... den lassen !!!!!!
