  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
    1.0k
    6.1k
1.6k Beiträge 101 Kommentatoren 725.0k Aufrufe 95 Beobachtet
  • F Fichte
    @ilovegym
    Auch hier (2.12.6) habe ich den selben Fehler.
    Liebe Grüße
    ilovegymI Offline
    ilovegymI Offline
    ilovegym
    #1481
    @fichte
    zeig bitte mal die Ausgabe von "iob diag" komplett, hier in Code Tags gesetzt.
    • F Offline
      Fichte
      #1482
      @ilovegym
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.8-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-9500T CPU @ 2.20GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       13:08:29 up 6 days,  1:46,  3 users,  load average: 0.42, 0.45, 0.51
      CPU threads: 6
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-09-04 13:08:29 CEST
                 Universal time: Thu 2025-09-04 11:08:29 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      Fichte
      HOME=/home/Fichte
      GROUPS=Fichte adm dialout sudo audio video plugdev users iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.6G         65M        4.7G        139K        3.8G        8.5G
      Swap:             0B          0B          0B
      Total:          8.6G         65M        4.7G
      Active iob-Instances:   1
               8192 M total memory
                 62 M used memory
                147 M active memory
               3374 M inactive memory
               4486 M free memory
                  0 M buffer memory
               3642 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 13:08:29 up 6 days,  1:46,  3 users,  load average: 0.42, 0.45, 0.51
      Tasks:  63 total,   1 running,  62 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   4485.2 free,     64.0 used,   3643.0 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8128.0 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      * iobroker.service     loaded failed failed ioBroker Server
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      /dev/loop0     ext4       16G  6.5G  8.4G  44% /
      none           tmpfs     492K  4.0K  488K   1% /dev
      none           tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-path/pci-0000:00:14.0-usb-0:1:1.0-port0
      udev           devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs          tmpfs      32G     0   32G   0% /dev/shm
      tmpfs          tmpfs      13G  132K   13G   1% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
      Show mounted filesystems:
      TARGET SOURCE     FSTYPE OPTIONS
      /      /dev/loop0 ext4   rw,relatime
      /var:
      489M    /var/
      292M    /var/cache
      288M    /var/cache/apt
      213M    /var/cache/apt/archives
      147M    /var/lib
      Archived and active journals take up 48.0M in the file system.
      /opt/iobroker/backups:
      616M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.9G    /opt/iobroker/iobroker-data/
      1.3G    /opt/iobroker/iobroker-data/history
      528M    /opt/iobroker/iobroker-data/files
      130M    /opt/iobroker/iobroker-data/backup-objects
      104M    /opt/iobroker/iobroker-data/files/vis
      find: Failed to change directory: /root: Permission denied
      find: Failed to restore initial working directory: /root: Permission denied
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      HINT:
      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.19.0
      /usr/bin/node           v22.19.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.19.0-1nodesource1
        Candidate: 22.19.0-1nodesource1
        Version table:
       *** 22.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 1022)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     2
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
      Adapter State
        system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
        system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
        system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
        system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: ioBroker                                 -  enabled
        system.adapter.espresense.0             : espresense            : ioBroker                                 - disabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
        system.adapter.history.0                : history               : ioBroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
        system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
        system.adapter.onvif.0                  : onvif                 : ioBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
        system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
        system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 4500, bind: 0.0.0.0
        system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
        system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : ioBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
        system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 -  enabled
        system.adapter.zigbee.0                 : zigbee                : ioBroker
        system.adapter.zigbee.1                 : zigbee                : ioBroker
        system.adapter.zigbee.2                 : zigbee                : ioBroker
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "ankersolix2"  : 2.3.0    , installed 2.3.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.6
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
      Adapter    "espresense"   : 0.6.3    , installed 0.6.3
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.4.0    , installed 2.4.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "radar2"       : 2.3.0    , installed 2.3.0
      Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        32937
      States:         29257
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12881      1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13829      295/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12883      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11939      1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13830      295/master
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12882      1/init
      udp6       0      0 :::111                  :::*                                0          12884      1/init
      2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.zigbee.1 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.energiefluss-erweitert.1 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.linux-control.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.onvif.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.156  - info: host.ioBroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.156  - info: host.ioBroker instance system.adapter.device-watcher.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:28.156  - warn: host.ioBroker instance system.adapter.pushover.0 terminated due to SIGKILL
      2025-09-04 13:05:28.156  - info: host.ioBroker instance system.adapter.pushover.0 terminated with code null ()
      2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.telegram.0 terminated due to SIGKILL
      2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.telegram.0 terminated with code null ()
      2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.sonoff.0 terminated due to SIGKILL
      2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.sonoff.0 terminated with code null ()
      2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.echarts.0 terminated due to SIGKILL
      2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.echarts.0 terminated with code null ()
      2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
      2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
      2025-09-04 13:05:29.065  - info: tuya.0 (124862) terminating
      2025-09-04 13:05:29.066  - info: tuya.0 (124862) Terminated (NO_ERROR): Without reason
      2025-09-04 13:05:29.622  - info: host.ioBroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
      2025-09-04 13:05:29.622  - info: host.ioBroker All instances are stopped.
      2025-09-04 13:05:29.681  - info: host.ioBroker terminated
      iob diag has finished.
      • F Fichte
        @ilovegym
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 6
                         RTC time: n/a
                  RTC in local TZ: no
        Fichte
        HOME=/home/Fichte
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                 8192 M total memory
                   62 M used memory
                  147 M active memory
                 4486 M free memory
                    0 M buffer memory
                 3642 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        489M    /var/
        292M    /var/cache
        288M    /var/cache/apt
        147M    /var/lib
        USB-Devices by-id:
        HINT:
        tcp
        HINT:
        tcp
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        32937
        States:         29257
        Pending Updates: 0
        #1483
        @fichte sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
        Mit laufendem ioBroker könnte man mehr sehen.
        F 1 Antwort Letzte Antwort
          Fichte
          schrieb am zuletzt editiert von Fichte
          #1484
          Ja Sorry habs gesehen 🙄
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           13:22:09 up 6 days,  2:00,  3 users,  load average: 0.88, 0.74, 0.71
          CPU threads: 6
                         Local time: Thu 2025-09-04 13:22:09 CEST
                     Universal time: Thu 2025-09-04 11:22:09 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:            8.6G        3.3G        1.4G        143K        3.9G        5.3G
          Swap:             0B          0B          0B
          Total:          8.6G        3.3G        1.4G
          Active iob-Instances:   40
                   8192 M total memory
                   3154 M used memory
                   3126 M active memory
                   3416 M inactive memory
                   1350 M free memory
                      0 M buffer memory
                   3687 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 13:22:10 up 6 days,  2:00,  3 users,  load average: 0.88, 0.74, 0.71
          Tasks:  74 total,   2 running,  72 sleeping,   0 stopped,   0 zombie
          MiB Mem :   8192.0 total,   1348.6 free,   3155.9 used,   3687.7 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   5036.1 avail Mem
          1 loaded units listed.
          *** FILESYSTEM ***
          /dev/loop0     ext4       16G  6.5G  8.3G  44% /
          tmpfs          tmpfs      13G  136K   13G   1% /run
          /var:
          489M    /var/
          292M    /var/cache
          288M    /var/cache/apt
          147M    /var/lib
          2.0G    /opt/iobroker/iobroker-data/
          USB-Devices by-id:
          HINT:
          tcp
          HINT:
          tcp
          HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 691)
          admin:          7.6.17
          javascript:     8.9.2
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
          + system.adapter.history.0                : history               : ioBroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
          + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
          + system.adapter.onvif.0                  : onvif                 : ioBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
          + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
          + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
          + system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 4500, bind: 0.0.0.0
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
          + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : ioBroker
          + system.adapter.zigbee.1                 : zigbee                : ioBroker
          + instance is alive
          Objects and States
          Objects:        32934
          States:         29677
          Hit:2 http://security.debian.org bookworm-security InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       46074353   128666/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       46075511   128735/io.shelly.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       46074691   128769/io.sonoff.0
          tcp        0      0 0.0.0.0:4500            0.0.0.0:*               LISTEN      1000       46092954   129380/io.sainlogic
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       46072354   128346/iobroker.js-
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       46069613   128346/iobroker.js-
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46071412   128365/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46090902   129460/io.web.0
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       46074129   128561/io.broadlink
          udp        0      0 0.0.0.0:55076           0.0.0.0:*                           1000       46074132   128561/io.broadlink
          udp        0      0 0.0.0.0:56116           0.0.0.0:*                           1000       46074189   128561/io.broadlink
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       46077311   128711/io.radar2.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       46076891   128787/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       46076892   128787/io.tuya.0
          2025-09-04 13:20:25.687  - info: host.ioBroker instance system.adapter.dwd.0 having pid 129670 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-09-04 13:21:00.005  - info: device-watcher.0 (129650) Scheduled restart.
          2025-09-04 13:21:00.005  - info: device-watcher.0 (129650) cleaned everything up...
          2025-09-04 13:21:00.047  - info: device-watcher.0 (129650) terminating
          2025-09-04 13:21:00.048  - info: device-watcher.0 (129650) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2025-09-04 13:21:00.508  - info: device-watcher.0 (129650) terminating
          2025-09-04 13:21:00.602  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
          2025-09-04 13:21:00.602  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
          2025-09-04 13:21:01.909  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 129689
          2025-09-04 13:21:02.748  - info: device-watcher.0 (129689) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
          2025-09-04 13:21:02.782  - info: device-watcher.0 (129689) Number of selected adapters to monitor devices: 5. Loading data from: Nut, Shelly, Sonoff, Unifi, Zigbee ...
          2025-09-04 13:22:00.004  - info: device-watcher.0 (129689) Scheduled restart.
          2025-09-04 13:22:00.005  - info: device-watcher.0 (129689) cleaned everything up...
          2025-09-04 13:22:00.008  - info: device-watcher.0 (129689) terminating
          2025-09-04 13:22:00.008  - info: device-watcher.0 (129689) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2025-09-04 13:22:00.507  - info: device-watcher.0 (129689) terminating
          2025-09-04 13:22:00.560  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
          2025-09-04 13:22:00.560  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
          2025-09-04 13:22:01.876  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 129801
          2025-09-04 13:22:02.680  - info: device-watcher.0 (129801) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
          2025-09-04 13:22:02.716  - info: device-watcher.0 (129801) Number of selected adapters to monitor devices: 5. Loading data from: Nut, Shelly, Sonoff, Unifi, Zigbee ...
          2025-09-04 13:22:18.582  - info: zigbee.0 (128834) checking configure on message :  next attempt in -161707 seconds
          2025-09-04 13:22:18.582  - info: zigbee.0 (128834) Configure on Message for 0x00124b00234e5828
          2025-09-04 13:22:18.582  - info: zigbee.0 (128834) Configuring 0x00124b00234e5828 SNZB-03
          2025-09-04 13:22:28.595  - info: zigbee.0 (128834) Timeout trying to configure 0x00124b00234e5828 SNZB-03 (0).
          ilovegymI Thomas BraunT 2 Antworten Letzte Antwort
          • F Fichte
            Script v.2025-08-09
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 6
                             RTC time: n/a
                      RTC in local TZ: no
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     8192 M total memory
                     3154 M used memory
                     1350 M free memory
                        0 M buffer memory
                     3687 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            489M    /var/
            292M    /var/cache
            288M    /var/cache/apt
            147M    /var/lib
            USB-Devices by-id:
            HINT:
            tcp
            HINT:
            tcp
            HINT:
            tcp
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.6.17
            javascript:     8.9.2
            Adapter State
            + instance is alive
            Objects and States
            Objects:        32934
            States:         29677
            Pending Updates: 0
            ilovegymI Offline
            ilovegymI Offline
            ilovegym
            #1485
            @fichte na bei sovielen permission denied solltest du mal dein system gerade biegen oder besser neu aufsetzen..da ist grundsaetzlich viel viel schief...
            • ilovegymI ilovegym
              Fichte
              #1486
              @ilovegym sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
              Das system ist eine woche alt ohne Backup zurückspielen
              da_WoodyD ilovegymI 2 Antworten Letzte Antwort
              • F Fichte
                da_WoodyD Offline
                da_WoodyD Offline
                da_Woody
                #1487
                @fichte fummelst du da als root rum?
                gruß vom Woody
                • F Fichte
                  ilovegymI Offline
                  ilovegymI Offline
                  ilovegym
                  schrieb am zuletzt editiert von ilovegym
                  #1488
                  Dann ging vor ner Woche so einiges schief, deshalb jetzt auch die Probleme.. schau dir die Diagnose doch mal an..
                  Mein Tip: iobroker backup starten, datei sichern, komplettes System neu aufsetzen (aber richtig, schau bei Thomas Braun's Tipps) und dann iobroker wieder restoren.
                  Edit: ist ne Arbeit von 2h, evtl sogar schneller, je nach System und hardware
                  • F Fichte
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 6
                                     RTC time: n/a
                              RTC in local TZ: no
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:             0B          0B          0B
                             8192 M total memory
                             3154 M used memory
                             1350 M free memory
                                0 M buffer memory
                             3687 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    /var:
                    489M    /var/
                    292M    /var/cache
                    288M    /var/cache/apt
                    147M    /var/lib
                    USB-Devices by-id:
                    HINT:
                    tcp
                    HINT:
                    tcp
                    HINT:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.9.3
                    /usr/bin/npx            10.9.3
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        32934
                    States:         29677
                    Pending Updates: 0
                    #1489
                    Da stimmt ohnehin irgendwas grundsätzliches nicht mit deinen usern:
                    Da muss der user auftauchen, der 'iob diag' aufruft.
                    Und auch die Meldungen zu /root: Permission denied sollten auf einem richtig aufgesetzten LXC nicht erscheinen.
                    Da hätte ich auch gleich Debian 13 'Trixie' hergenommen.
                    • F Offline
                      Fichte
                      #1490
                      Da gebe ich dir Recht.! Ich setz gerade einen neuen LXC auf und mach es noch mal von vorn. Ich hab irgendwo letzte Woche etwas in den USer falsch gemacht 🙄 Ich geb rückmeldung
                      • F Offline
                        Fichte
                        #1491
                        Noch immer das selbe.
                        Habe das ding jetzt per Hand installiert und alle einstellungen händisch eingetragen.
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         22:58:56 up 3 min,  2 users,  load average: 2.07, 1.43, 1.40
                        CPU threads: 4
                                       Local time: Thu 2025-09-04 22:58:56 CEST
                                   Universal time: Thu 2025-09-04 20:58:56 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        andre
                        HOME=/home/andre
                        GROUPS=andre sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            8.6G        3.4G        4.4G        147K        774M        5.2G
                        Swap:             0B          0B          0B
                        Total:          8.6G        3.4G        4.4G
                        Active iob-Instances:   39
                                 8192 M total memory
                                 3253 M used memory
                                 3279 M active memory
                                  551 M inactive memory
                                 4199 M free memory
                                    0 M buffer memory
                                  739 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        top - 22:58:56 up 3 min,  2 users,  load average: 2.07, 1.43, 1.40
                        Tasks:  71 total,   1 running,  70 sleeping,   0 stopped,   0 zombie
                        MiB Mem :   8192.0 total,   4198.3 free,   3254.6 used,    739.3 buff/cache
                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4937.4 avail Mem
                        *** FILESYSTEM ***
                        /dev/loop0     ext4       16G  4.4G   11G  30% /
                        tmpfs          tmpfs      13G  140K   13G   1% /run
                        tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
                        /var:
                        437M    /var/
                        256M    /var/cache
                        252M    /var/cache/apt
                        175M    /var/cache/apt/archives
                        155M    /var/lib
                        Archived and active journals take up 8.0M in the file system.
                        124M    /opt/iobroker/backups/
                        576M    /opt/iobroker/iobroker-data/
                        96M     /opt/iobroker/iobroker-data/files/vis/widgets
                        67M     /opt/iobroker/iobroker-data/files/echarts.admin
                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                        31M     /opt/iobroker/iobroker-data/objects.jsonl
                        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                        24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                        USB-Devices by-id:
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.3
                        /usr/bin/npx            10.9.3
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 182)
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://10.10.10.17:20108
                        + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://10.10.10.18:20108
                          system.adapter.zigbee.2                 : zigbee                : ioBroker                                 - disabled, port: tcp://10.10.10.160:6638
                        + instance is alive
                        Objects and States
                        Objects:        28232
                        States:         26499
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       50671491   128/iobroker.js-con
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       50673829   128/iobroker.js-con
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       50681075   767/io.sonoff.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       50673641   621/io.shelly.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       50677030   651/io.mqtt.0
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          50671128   1/init
                        tcp        0      0 0.0.0.0:4500            0.0.0.0:*               LISTEN      1001       50692938   1387/io.sainlogic.0
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          50671366   295/master
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          50673752   1/init
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          50671130   1/init
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50669194   306/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       50684708   984/io.web.0
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          50671367   295/master
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       50677143   726/io.radar2.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          50671129   1/init
                        udp        0      0 0.0.0.0:33407           0.0.0.0:*                           1001       50674505   501/io.broadlink2.0
                        udp        0      0 0.0.0.0:36640           0.0.0.0:*                           1001       50669565   501/io.broadlink2.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       50677329   786/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       50677330   786/io.tuya.0
                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       50673340   501/io.broadlink2.0
                        udp6       0      0 :::111                  :::*                                0          50671131   1/init
                        Proxmox:  ioBroker (22:58)
                        2025-09-04 22:58:48.577  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist nicht mehr erreichbar: \nProxmox:  ioBroker (22:58)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                        2025-09-04 22:59:00.004  - info: device-watcher.0 (1071) Scheduled restart.
                        2025-09-04 22:59:00.004  - info: device-watcher.0 (1071) cleaned everything up...
                        2025-09-04 22:59:00.006  - info: device-watcher.0 (1071) terminating
                        2025-09-04 22:59:00.007  - info: device-watcher.0 (1071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2025-09-04 22:59:00.507  - info: device-watcher.0 (1071) terminating
                        2025-09-04 22:59:00.554  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
                        2025-09-04 22:59:00.554  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
                        2025-09-04 22:59:01.850  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 1806
                        2025-09-04 22:59:02.767  - info: device-watcher.0 (1806) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
                        2025-09-04 22:59:02.801  - info: device-watcher.0 (1806) Number of selected adapters to monitor devices: 6. Loading data from: Nut, Proxmox, Sonoff, Tuya, Unifi, Zigbee ...
                        2025-09-04 22:59:03.010  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:03.060  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:03.112  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:03.162  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:03.205  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:03.248  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:03.326  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 22:59:11.978  - info: device-watcher.0 (1806) Das folgende Gerät ist wieder verfügbar:
                        Proxmox:  ioBroker (22:59)
                        2025-09-04 22:59:12.023  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist wieder verfügbar: \nProxmox:  ioBroker (22:59)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                        2025-09-04 22:59:12.192  - info: device-watcher.0 (1806) Das folgende Gerät ist nicht mehr erreichbar:
                        2025-09-04 22:59:12.237  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist nicht mehr erreichbar: \nProxmox:  ioBroker (22:59)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                        • F Fichte
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          andre
                          HOME=/home/andre
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:             0B          0B          0B
                                   8192 M total memory
                                   3253 M used memory
                                   4199 M free memory
                                      0 M buffer memory
                                    739 M swap cache
                                      0 M total swap
                                      0 M used swap
                                      0 M free swap
                          *** FILESYSTEM ***
                          /var:
                          437M    /var/
                          256M    /var/cache
                          252M    /var/cache/apt
                          155M    /var/lib
                          USB-Devices by-id:
                          HINT:
                          tcp
                          HINT:
                          tcp
                          HINT:
                          tcp
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.3
                          /usr/bin/npx            10.9.3
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.6.17
                          javascript:     8.9.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        28232
                          States:         26499
                          Pending Updates: 0
                          #1492
                          Zumindest die grundsätzlichen Kinken sind jetzt raus.
                          Was sagt denn
                          cd /opt/iobroker/ && npm ls cron-parser
                          • F Offline
                            Fichte
                            #1493
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├─┬ iobroker.backitup@3.3.5
                            │ ├── cron-parser@5.3.1
                            │ └─┬ node-schedule@2.1.1
                            │   └── cron-parser@4.9.0
                            ├─┬ iobroker.js-controller@7.0.7
                            └─┬ iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                              └─┬ node-schedule@1.3.3
                                └── cron-parser@2.18.0
                            • F Fichte
                              #1494
                              @fichte
                              Hab den Adapter auch gerade mal installiert. Schaut hier ähnlich aus:
                              2025-09-04 23:21:15.515  - info: device-watcher.0 (1054123) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v24.7.0, js-controller: 7.0.7
                              2025-09-04 23:21:15.547  - info: device-watcher.0 (1054123) Number of selected adapters to monitor devices: 1. Loading data from: Alexa2 ...
                              2025-09-04 23:21:16.753  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 23:21:16.763  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 23:21:16.867  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              F 2 Antworten Letzte Antwort
                                @fichte
                                Fichte
                                #1495
                                Dank deines Tipps hab ich jetzt erst mal ein Sauberes System 👍
                                Jetzt Lösche ich gerade alle Adapter Rückwärts um zu sehen ob es an einem Adapter liegt.
                                  @fichte
                                  Fichte
                                  #1496
                                  Also wenn ich alle Instanzen mit CRON Job Lösche ist der Fehler nach und nach weg wie zbs. bei mir:
                                  ical
                                  feiertage
                                  dwd
                                  das wetter
                                  Der Fehler tritt auch auf wenn man die Zeiten zum Abrufen der Daten wie ical ändern möchte.
                                  Wie ich gesehen habe ist der Entwickler des Adapters nicht mehr hier.
                                  Wird dieser Adapter von jemand anderen weitere geführt oder war es das damit.?
                                  Liebe Grüße
                                  • F Fichte
                                    ical
                                    feiertage
                                    dwd
                                    das wetter
                                    Liebe Grüße
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #1497
                                    wenn du RICHTIG geschaut hättest würdest du festgestellt haben dass ich den pflege..
                                    ich kann dir nicht folgen welche Einstellungen du meinst.. zeigmal screenshot
                                    • arteckA arteck
                                      Fichte
                                      #1498
                                      @arteck
                                      Es war eine normale frage und wollte hier keinen Ankreiten, Sorry.
                                      Der Fehler Erscheint bei Instanzen mit CronJobs
                                      Lösche ich die Instanz ist der Fehler nach und nach weg.
                                      Ich hatte Anfangs 7 solcher Instanzen und nach löschen der der einzellnen Instanzen wurden die fehler immer weniger bis gaanz weg.
                                      da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                                      • F Fichte
                                        @arteck
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        da_Woody
                                        #1499
                                        @fichte Instanzen oder Adapter?
                                        gruß vom Woody
                                        • da_WoodyD da_Woody
                                          Fichte
                                          #1500
                                          @da_woody
                                          Hab es Korrigiert, ich meinte instanzen.
