  4. ZigBee neue Version 1.7.x
    3.0k
    3.0k
1.7backupiconszigbee
217 Beiträge 40 Kommentatoren 45.9k Aufrufe 47 Beobachtet
  • nukleuzN nukleuz
    @arteck
    Da zeigt er 1.7.5... Mhhh - in der Instanz aber 1.7.6
    zigbee.1
       2022-11-11 17:15:42.775	error	Device 0x00212effff0a6524 "Kobold" not described in statesMapping.
    zigbee.1
       2022-11-11 17:15:41.365	info	Zigbee started
    zigbee.1
       2022-11-11 17:15:27.936	info	Currently 90 devices are joined:
    zigbee.1
       2022-11-11 17:15:27.917	info	Unable to set transmit power, unsupported function.
    zigbee.1
       2022-11-11 17:15:27.767	info	--> transmitPower : normal
    zigbee.1
       2022-11-11 17:15:27.747	info	Unable to disable LED, unsupported function.
    zigbee.1
       2022-11-11 17:15:27.689	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
    zigbee.1
       2022-11-11 17:15:27.613	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.1
       2022-11-11 17:15:27.109	info	Starting Zigbee npm ...
    zigbee.1
       2022-11-11 17:15:26.904	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
    zigbee.1
       2022-11-11 17:15:17.265	info	terminating with timeout
    zigbee.1
       2022-11-11 17:15:16.163	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.1
       2022-11-11 17:15:16.161	info	terminating
    zigbee.1
       2022-11-11 17:15:16.085	info	Zigbee: disabling joining new devices.
    zigbee.1
       2022-11-11 17:15:15.764	info	cleaned everything up...
    zigbee.1
       2022-11-11 17:15:15.762	info	Got terminate signal TERMINATE_YOURSELF
    Im Adapter Tab zeigt er mir das:
    In den Instanzinfos 1.7.5...
    Wie komme ich nun auf 1.7.6 -> habe doch die Installation über Github gemacht...
    #121
    @nukleuz
    cd /opt/iobroker
    npm ls | grep zigbee
    nukleuzN 1 Antwort Letzte Antwort
      @nukleuz
      cd /opt/iobroker
      nukleuzN Offline
      nukleuzN Offline
      nukleuz
      #122
      @arteck
      Danke für den Hinweis. :)
      Da bei mir der Zigbee-Adapter inkl. Coordinator auf einem meiner Slaves läuft und ich die Github-Aktualisierung über den Master eingespielt habe, war der Adapter nicht aktuell!
      Habe da ein wenig für gebraucht 🙄
      Nach Aktualisierung über Github auf dem richtigen Host läuft der Kobold nun endlich.
      Danke an euch...
      Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
      • nukleuzN nukleuz
        @arteck
        Danke an euch...
        arteckA Offline
        arteckA Offline
        arteck
        #123
        @nukleuz lösch bitte den nichtgebrauchten adapter von dem Host .. also da wo es NICHT läuft..sonst gibts probleme mit dem Update
        • arteckA arteck
          nukleuzN Offline
          nukleuzN Offline
          nukleuz
          schrieb am zuletzt editiert von nukleuz
          #124
          @arteck
          Ist erledigt - danke…
          Wenn ich den Datenpunkt effect mit den Werten des Dropdowns wähle passiert nichts… Wie kann ich die zum Laufen bekommen oder prüfen, warum es so ist?
          EDIT: Nach dem Update gestern habe ich zwei Aktoren, die nicht mehr funktionieren, aber noch als online/erreichbar angezeigt werden. Das Schalten funktioniert nicht mehr. Das Bild des Geräts hat sich ebenfalls geändert.
          Wie gehe ich hier am besten vor?
          A 1 Antwort Letzte Antwort
          • nukleuzN nukleuz
            @arteck
            Aragon
            #125
            @arteck Ich habe einen Rauchmelder den der Zigbee Adapter nicht richtig erkennt.
            kann mir jemand Helfen?
            A 2 Antworten Letzte Antwort
            • A Aragon
              Aragon
              #126
              @aragon Gibt es die Möglichkeit oder ist es eventuell geplant, die deaktivieren Funktion in die Objekte zu schreiben, damit man diesen Datenpunkt dann per Tablet steuern kann?
              Oder gibt es bereits eine Möglichkeit auf den DP zuzugreifen?
              • A Aragon
                arteckA Offline
                arteckA Offline
                arteck
                #127
                @aragon mit dieser funktion deaktivierst du das Gerät komplett.. vom Netz.
                ist eugentlich nur für Weihnachtzeug gedacht.. und nein in die Visu bekommst du den nicht rein
                • A Aragon
                  Aragon
                  #128
                  @aragon Guten Morgen,
                  vielen Dank, der Rauchmelder wird nun erkannt und funktioniert bis jetzt gut.
                  Ich habe Temperatursensoren von MOES, bei diesen wird die Luftfeuchtigkeit nicht richtig angezeigt.
                  Statt 55,6 % wird 5,56 % Angezeigt im ioBroker unter Objekten und in der Gerätekachel.
                  Der Wert zwischen Display des Sensors und der des ioBrokers stimmen nicht überein.
                  Bitte um Prüfung, ich nutze die Quadratische Variante des Sensors.
                    Muchul
                    #129
                    ich wollte mit noch 1-2 Sensoren auf Lager legen und nin gerade beim ali über diese hier gestolpert:
                    https://a.aliexpress.com/_EzwUTUt
                    Hat die jemand schon?
                    Taugen die LUX Werte was?
                    In Z2M konnte ich sie nicht finden, da ich die Bezeichnung nicht kenne.
                    • arteckA arteck
                      Es ist mal wieder Zeit für eine neue Version
                      der @Asgothian war mal wieder nicht untätig und hat paar neue Sachen programmiert.. die schon zwr länger im Adapter drin sind aber ich finde man sollte es erwähnen
                      Geräte können deaktiviert werden .. somit stören sie das Netz nicht.. nützlich für die Weihnachtsbeleuchtung
                      die Kachel wird dann grau
                      zum einschalten Kachel drehen
                      Die Gruppenfunktionen wurde neu geschrieben und verbessert
                      von mir wurden im Admin die fehlenden Icons hinzugefügt. der Adapter lädt diese runter ..
                      sollte im Log nach Adapter Start solche Zeile als Warning stehen
                      download icon from https://www.zigbee2mqtt.io/images/devices/929002398602.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/929002398602.png
                      ist ein manueller upload notwendig
                      danach sollte das Icon im Admin zur verfügung stehen
                      der Object Baum wird laut dem available status eingefärbt. man kann direkt erkennen welche Geräte offline sind
                      die Möglichkeit der Adapter internen Backups wurde hinzugefügt. nützlich wenn man ehh mit dem BackItUp Adapter seine Sicherung regelmässig macht. Falls nicht werden nur die letzten 10 Files behalten..
                      für den Rest siehe Readme
                      gelberlemmyG Offline
                      gelberlemmy
                      #130
                      @arteck moin, aktuell habe ich einige Phänomene im meinem System.
                      Aktuell sind zwei Bewegungsmelder von Sonoff nicht mehr erreichbar. Fand ich schon komisch. Aber gut. Aber jetzt bekomme ich folgende Meldungen im LOG:
                      zigbee.0
                      2022-11-21 10:07:00.369	warn	zigbee-herdsman-converters:WooxR7060: Unrecognized DP #106 with data {"dp":106,"datatype":3,"data":{"type":"Buffer","data":[48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48,48]}}
                      und
                      zigbee-herdsman-converters:WooxR7060: Unrecognized DP #107 with data {"dp":107,"datatype":4,"data":{"type":"Buffer","data":[0]}}
                      Dieses Ventil hat nie Probleme gemacht. Habe daran auch nichts geändert. Was sagt denn diese Meldung aus ? Warum sind auf einem mal die Melder nicht mehr erreichbar.
                      Aktuelles System:
                      Plattform
                      linux
                      Betriebssystem
                      linux
                      Architektur
                      x64
                      CPUs
                      Geschwindigkeit
                      1697 MHz
                      Modell
                      Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
                      RAM
                      6 GB
                      System-Betriebszeit
                      14:11:05
                      Node.js
                      v16.18.1
                      NPM
                      8.19.2
                      jscontroller
                      4.0.23
                      Aktive Instanzen
                      48
                      Gruß André
                      • gelberlemmyG gelberlemmy
                        zigbee.0
                        und
                        Aktuelles System:
                        Plattform
                        linux
                        Betriebssystem
                        linux
                        Architektur
                        x64
                        CPUs
                        Geschwindigkeit
                        1697 MHz
                        Modell
                        RAM
                        6 GB
                        System-Betriebszeit
                        14:11:05
                        Node.js
                        v16.18.1
                        NPM
                        8.19.2
                        jscontroller
                        4.0.23
                        Aktive Instanzen
                        48
                        Gruß André
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #131
                        @gelberlemmy das ding hab ich auch .. es gab da ein Bug.. installier mal die GIT Version
                        gelberlemmyG 2 Antworten Letzte Antwort
                        • arteckA arteck
                          gelberlemmy
                          #132
                          @arteck sagte in ZigBee neue Version 1.7.x:
                          Alles klar, mache ich einmal
                          • arteckA arteck
                            gelberlemmy
                            #133
                            @arteck so getan. jetzt bekomme ich folgende Fehler :
                            zigbee.0
                            2022-11-21 13:48:23.216	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x847127fffed08605 TS0101 (Error: Read 0x847127fffed08605/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 22988 - 1 - 2 - 0 - 1 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7))
                              zigbee.0
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #134
                              @gelberlemmy sagte in ZigBee neue Version 1.7.x:
                              0x847127fffed08605
                              und as ist wasfür ein Device
                              gelberlemmyG 1 Antwort Letzte Antwort
                              • arteckA arteck
                                0x847127fffed08605
                                gelberlemmy
                                #135
                                0x847127fffed08605
                                • nukleuzN Offline
                                  nukleuzN Offline
                                  nukleuz
                                  #136
                                  ich erhalte im Log diese Meldung in regelmäßigen Abständen:
                                  zigbee.1
                                  2022-11-24 16:01:07.098	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x5c0272fffe16ae9f TS0202
                                  (Error: Bind 0x5c0272fffe16ae9f/1 genPowerCfg from '0x00212effff0485f5/1' failed (Error: status: 140) at DeconzAdapter.bind
                                  (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:768:19) at Endpoint.bind
                                  (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:567:13) at Object.bind (/opt/iobroker
                                  /node_modules/zigbee-herdsman-converters/lib/reporting.js:40:9) at Object.configure (/opt/iobroker/node_modules/zigbee-
                                  herdsman-converters/devices/tuya.js:1032:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee
                                  /lib/zbDeviceConfigure.js:146:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee
                                  /lib/zbDeviceConfigure.js:124:17))
                                  zigbee.1
                                  2022-11-24 16:01:06.098	info	Configuring 0x5c0272fffe16ae9f TS0202
                                  Wie kann ich hier vorgehen?
                                  Danke für eure Unterstützung...
                                  • nukleuzN nukleuz
                                    zigbee.1
                                    zigbee.1
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #137
                                    @nukleuz
                                    am conbee ??
                                    • arteckA arteck
                                      @nukleuz
                                      am conbee ??
                                      nukleuzN Offline
                                      nukleuzN Offline
                                      nukleuz
                                      #138
                                      @arteck
                                      Ja, genau - der ConBee II.
                                      • nukleuzN nukleuz
                                        @arteck
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #139
                                        @nukleuz der zickt halt rum..da kann ich nix machen
                                        • arteckA arteck
                                          nukleuzN Offline
                                          nukleuzN Offline
                                          nukleuz
                                          #140
                                          @arteck
                                          OK - welchen ZigBee-Stick (Coordinator) empfiehlst du bzw. welcher wird am besten unterstützt?
                                          arteckA B 2 Antworten Letzte Antwort
