  3. Einsteigerfragen
  4. iobroker läuft nicht mehr
    5.6k
87 Beiträge 4 Kommentatoren 9.2k Aufrufe 3 Beobachtet
    @emi-0 sagte in iobroker läuft nicht mehr:
    nodeJS passt nun.
    Die beiden Updates noch einspielen:
    2 packages can be upgraded
    sudo apt full-upgrade
    Emi 0
    #41
    das hat funktioniert:
    micros02@smartmeter:~ $ sudo apt full-upgrade
    Reading package lists... Done
    Building dependency tree... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      gyp javascript-common libc-ares2 libjs-highlight.js libjs-inherits
      libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libnode-dev
      libnode72 libssl-dev libuv1-dev xdg-utils
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      libexpat1 libexpat1-dev
    2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 198 kB of archives.
    After this operation, 3,072 B of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libexpat1-dev armhf 2.2.10-2+deb11u3 [123 kB]
    Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libexpat1 armhf 2.2.10-2+deb11u3 [74.9 kB]
    Fetched 198 kB in 1s (182 kB/s)
    Reading changelogs... Done
    (Reading database ... 49910 files and directories currently installed.)
    Preparing to unpack .../libexpat1-dev_2.2.10-2+deb11u3_armhf.deb ...
    Unpacking libexpat1-dev:armhf (2.2.10-2+deb11u3) over (2.2.10-2+deb11u2) ...
    Preparing to unpack .../libexpat1_2.2.10-2+deb11u3_armhf.deb ...
    Unpacking libexpat1:armhf (2.2.10-2+deb11u3) over (2.2.10-2+deb11u2) ...
    Setting up libexpat1:armhf (2.2.10-2+deb11u3) ...
    Setting up libexpat1-dev:armhf (2.2.10-2+deb11u3) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
    • E Emi 0
      #42
      Jetzt noch
      sudo apt autoremove
      um den überflüssigen Rest auch noch loszuwerden.
      E 1 Antwort Letzte Antwort
        Jetzt noch
        sudo apt autoremove
        Emi 0
        #43
        das hat jetzt auch funktioniert:
        micros02@smartmeter:~ $ sudo apt autoremove
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        • E Emi 0
          #44
          @emi-0
          Dann dürfte die nodeJS-Laufzeitumgebung jetzt sauber sein.
            @emi-0
            Emi 0
            #45
            leider lässt sich iobroker immer noch nicht starten
            micros02@smartmeter:~ $ iobroker fix
            library: loaded
            Library version=2022-02-10
                Welcome to the ioBroker installation fixer!
                Script version: 2022-02-13
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Installed gcc-c++
            Installed python-dev
                Checking ioBroker user and directory permissions (2/3)
            Created /etc/sudoers.d/iobroker
                Checking autostart (3/3)
            Enabling autostart...
            Autostart enabled!
            micros02@smartmeter:~ $ iobroker start
            micros02@smartmeter:~ $ iob status
            Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            • E Emi 0
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              #46
              ls  -l /opt/iobroker/iobroker-data/objects.jsonl
              sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                Emi 0
                #47
                micros02@smartmeter:~ $ ls  -l /opt/iobroker/iobroker-data/objects.jsonl
                -rw-rwxr--+ 1 iobroker iobroker 120034159 Apr 25 21:05 /opt/iobroker/iobroker-data/objects.jsonl
                micros02@smartmeter:~ $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                COMMAND    PID     USER   FD   TYPE DEVICE  SIZE/OFF   NODE NAME
                iobroker. 1919 iobroker   19u   REG  179,2 120034159 268535 /opt/iobroker/iobroker-data/objects.jsonl
                micros02@smartmeter:~ $ iob start
                • E Emi 0
                  #48
                  @emi-0
                  getfacl /opt/iobroker/iobroker-data/objects.jsonl
                    @emi-0
                    Emi 0
                    #49
                    geht noch nicht:
                    -bash: micros02@smartmeter:~: command not found
                    -bash: -rw-rwxr--+: command not found
                    -bash: COMMAND: command not found
                    -bash: iobroker.: command not found
                    -bash: Server: command not found
                    getfacl: Removing leading '/' from absolute path names
                    # file: opt/iobroker/iobroker-data/objects.jsonl
                    # owner: iobroker
                    # group: iobroker
                    user::rw-
                    group::r--
                    group:iobroker:rwx
                    mask::rwx
                    other::r--
                    • E Emi 0
                      geht noch nicht:
                      # owner: iobroker
                      # group: iobroker
                      user::rw-
                      group::r--
                      group:iobroker:rwx
                      mask::rwx
                      other::r--
                      #50
                      @emi-0
                      Da stimmen die Rechte nicht.
                      Auf meinem System schauen die anders aus.
                      Aber erstmal Sportschau gucken...
                      E 2 Antworten Letzte Antwort
                        @emi-0
                        Emi 0
                        #51
                        erstmal vielen Dank
                        Viel Spaß bei der Sportschau.
                        Bis Morgen ....
                          @emi-0
                          Emi 0
                          #52
                          Hallo Thomas,
                          kannst Du bitte noch etwas zu den Rechten sagen, wie sie aussehen müssen, dass iobroker wieder gestartet werden kann?
                          • E Emi 0
                            Hallo Thomas,
                            #53
                            @emi-0
                            Bei mir sehen die so aus:
                            echad@chet:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                            # owner: iobroker
                            # group: iobroker
                            user::rw-
                            group::r-x                      #effective:r--
                            group:iobroker:rwx              #effective:rw-
                            mask::rw-
                            other::r--
                              @emi-0
                              # owner: iobroker
                              # group: iobroker
                              user::rw-
                              mask::rw-
                              other::r--
                              Emi 0
                              #54
                              also müssen die Rechte für group: und mask: angepasst werden.
                              Wie kann ich das machen?
                              • E Emi 0
                                #55
                                eigentlich müsste das der Fixer machen:
                                iobroker stop
                                iobroker fix
                                iobroker start
                                • E Emi 0
                                  #56
                                  @emi-0
                                  Eigentlich sollte das der Fixer machen.
                                  Hier sind ACLs gesetzt worden.
                                  Manuell ist das das etwas aufwändiger.
                                  Stefan Kania erklärt es hier:
                                  https://www.informatik-aktuell.de/betrieb/betriebssysteme/rechte-im-dateisystem-mehr-als-nur-rwx.html
                                    iobroker stop
                                    iobroker fix
                                    iobroker start
                                    Emi 0
                                    #57
                                    Anscheinend macht der fixer bei mir nicht das Richtige
                                    library: loaded
                                    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
                                    Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
                                    Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
                                    Fetched 321 kB in 4s (89.5 kB/s)
                                    Installed gcc-c++
                                    Autostart enabled!
                                    micros02@smartmeter:~ $ iobroker status
                                    No connection to databases possible ...
                                    micros02@smartmeter:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                    # owner: iobroker
                                    # group: iobroker
                                    user::rw-
                                    group::r--
                                    group:iobroker:rwx
                                    mask::rwx
                                    other::r--
                                    • E Emi 0
                                      library: loaded
                                      Installed gcc-c++
                                      Autostart enabled!
                                      # owner: iobroker
                                      # group: iobroker
                                      user::rw-
                                      group::r--
                                      group:iobroker:rwx
                                      mask::rwx
                                      other::r--
                                      #58
                                      @emi-0
                                      systemctl status iobroker.service
                                      sagt?
                                        @emi-0
                                        sagt?
                                        Emi 0
                                        #59
                                        micros02@smartmeter:~ $ systemctl status iobroker.service
                                        ● iobroker.service - ioBroker Server
                                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                                             Active: active (running) since Tue 2022-05-03 17:35:03 CEST; 40s ago
                                               Docs: http://iobroker.net
                                           Main PID: 27228 (iobroker.js-con)
                                              Tasks: 18 (limit: 415)
                                                CPU: 40.513s
                                             CGroup: /system.slice/iobroker.service
                                                     ├─27228 iobroker.js-controller
                                                     └─27241 node /opt/iobroker/node_modules/iobroker.js-controller/iob>
                                        May 03 17:35:03 smartmeter systemd[1]: Started ioBroker Server.
                                        May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Main process exited, c>
                                        May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Failed with result 'ex>
                                        May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Consumed 40.716s CPU t>
                                        lines 1-15/15 (END)
                                        • E Emi 0
                                                  CPU: 40.513s
                                          lines 1-15/15 (END)
                                          #60
                                          @emi-0
                                          Mach das Fenster mal breiter, damit man alles sieht.
