  4. esphome - ERROR: Process exited with code 25
    1.0k
    6.1k
162 Beiträge 12 Kommentatoren 29.1k Aufrufe 5 Beobachtet
    @sushibomba
    sudo apt update
    sudo apt install python-is-python3 python-dev-is-python3
    Sushibomba
    sudo apt install python-is-python3 python-dev-is-python3                  Reading package lists... Done
    Building dependency tree... Done
    The following packages were automatically installed and are no longer required:
      libpython2-dev libpython2.7 libpython2.7-dev python2-dev python2.7-dev
    Use 'sudo apt autoremove' to remove them.
    The following additional packages will be installed:
      libpython3-dev libpython3.9-dev python3-dev python3.9-dev
    The following packages will be REMOVED:
      python-dev-is-python2 python-is-python2
    The following NEW packages will be installed:
      libpython3-dev libpython3.9-dev python-dev-is-python3 python-is-python3 python3-dev
      python3.9-dev
    0 upgraded, 6 newly installed, 2 to remove and 90 not upgraded.
    Need to get 3,606 kB of archives.
    After this operation, 14.7 MB of additional disk space will be used.
    Do you want to continue? [Y/n]
    Soll ich die Installation durchführen?
    • S Sushibomba
        python3.9-dev
      @sushibomba
      Ja.
        @sushibomba
        Ja.
        Sushibomba
        schrieb am zuletzt editiert von Sushibomba
        Ok hab ich. Muss ich danach noch irgendwelche Befehle ausführen um alte Dateien zu löschen oder so? Und sollte ich den Pi dann noch neustarten?
        • S Sushibomba
          @sushibomba
          Aber lös den Update-Stau mal endlich auf:
          iobroker stop
          sudo apt update
          sudo apt full-upgrade
          sudo apt autoremove
          sudo reboot
            @sushibomba
            iobroker stop
            sudo apt update
            sudo apt autoremove
            sudo reboot
            Sushibomba
            @thomas-braun sagte in esphome - ERROR: Process exited with code 25:
            sudo reboot
            Hab ich gemacht.
            Jetzt habe ich ein Problem dadurch in Grafana :(
            InfluxDB plugin failed
            ChunkLoadError: Loading chunk 5783 failed. (error: http://192.xxx.xxx.xx:3000/public/build/influxdbPlugin.94c35fd39f967eb67896.js)
            • S Sushibomba
              sudo reboot
              Hab ich gemacht.
              @sushibomba sagte in esphome - ERROR: Process exited with code 25:
              Nein, nicht dadurch.
                Sushibomba
                Ok. Das heißt?
                Also wie bekomme ich es jetzt wieder zum laufen?
                InfluxDB nochmal neu starten?
                • S Sushibomba
                  Ok. Das heißt?
                  Welche influx wie installiert?
                  S 2 Antworten Letzte Antwort
                    Sushibomba
                    Schon ne Zeit her und so firm bin ich mit dem ganzen leider nicht.
                    Wie schaue ich das nochmal nach?
                    Habe das damals nach einem youtube Video gemacht.
                    • S Sushibomba
                      HomoranH Offline
                      HomoranH Offline
                      dann mach einen neuen Thread auf mit vernünftigem Titel
                      • S Sushibomba
                        @sushibomba
                        apt policy influxdb*
                        und mal über das Ganze drüberschauen....
                        sudo apt update
                          Sushibomba
                          Ah geht wieder. Musste nur malt einen Hard-Reload der Seite machen. Also Cache löschen und dann ging es wieder :)
                          Danke dir.
                          Jetzt probiere ich es nochmal mit ESPhome ;)
                            @sushibomba
                            sudo apt update
                            Sushibomba
                            Hat leider wieder nicht geklappt:
                            $ iobroker add esphome --host Pi4ioBroker
                            NPM version: 8.11.0Installing iobroker.esphome@0.2.4... (System call)
                            host.Pi4ioBroker Cannot install iobroker.esphome@0.2.4: 126
                            • S Sushibomba
                              Da sollte auch nix klappen.
                              iobroker add esphome --host Pi4ioBroker --debug
                              sagt?
                                sagt?
                                Sushibomba
                                NPM version: 8.11.0
                                npm ERR! code 126
                                npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
                                npm ERR! command failed
                                npm ERR! command sh -c npip install
                                npm ERR! sh: 1: npip: Permission denied
                                npm ERR!     /home/iobroker/.npm/_logs/2022-08-03T13_03_43_923Z-debug-0.log
                                • S Sushibomba
                                  NPM version: 8.11.0
                                  npm ERR! code 126
                                  @sushibomba
                                  Die Meldung hatten wir schon mal hier. Such mal danach, ich weiß nicht ob das gelöst wurde.
                                    @sushibomba
                                    Sushibomba
                                    Hier hat der @Tontechniker was mit pip geschrieben.
                                    Meinst du das? https://forum.iobroker.net/topic/55555/probleme-mit-installation-von-esp-home-0-2-4/100?lang=en-GB
                                    • S Sushibomba
                                      @sushibomba
                                      Nein, das meinte ich nicht.
                                      Aber ich vermute, das hat mit dem in seinen Rechten beschränkten user 'iobroker' zu tun. Der darf nicht viel außerhalb von /opt/iobroker, ich denke auf python-pip darf der nicht zugreifen.
                                      Das müsste man vermutlich in dessen sudoers eintragen. Kann ich mir evtl. heute abend mal anschauen, hab ich jetzt keine Zeit für.
                                        @sushibomba
                                        Sushibomba
                                        Ok alles klar. Erst mal vielen Dank für deine Hilfe und dann bis heute Abend :)
                                        Viel Erfolg bei dem was du tust!
                                        • S Sushibomba
                                          @sushibomba
                                          Schau mal ob die drei Pakete installiert sind:
                                          apt policy python3-pip python-dev-is-python3 python-is-python3
                                          Wenn was fehlt: Nachinstallieren.
                                          Ich konnte den Adapter jetzt einwandfrei installieren.
