  4. esphome - ERROR: Process exited with code 25
162 Beiträge 12 Kommentatoren 29.4k Aufrufe 5 Beobachtet
  • L Offline
    LE-R.Kelly
    Systemdata
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Raspian Buster
    Node-Version: 14.19.1
    Nodejs-Version: 14.19.1
    NPM-Version: 6.14.16
    ich habe versucht, den esphome-Adapter zu installieren. Die Installation scheitert aber mit dem Code 25. Ich sehe im Log aber das Problem nicht. Kann einer von Euch mal drüberschauen? Danke
    $ iobroker add esphome auto --host raspberrypi
    NPM version: 6.14.16
    Installing iobroker.esphome@0.2.4... (System call)
    > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome> npip install
    No python_modules directory; installing pip locally if needed.
    Successfully completed pip check.
    Collecting esphome>=2021.8
    Using cached esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
    Collecting tornado>=3.2
    Using cached tornado-6.1.tar.gz (497 kB)
    Preparing metadata (setup.py): started
    Preparing metadata (setup.py): finished with status 'done'
    Collecting tzdata>=2021.1
    Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
    Collecting platformio==5.2.5
    Using cached platformio-5.2.5.tar.gz (218 kB)
    Collecting aioesphomeapi==10.8.2
    Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
    Collecting PyYAML==6.0
    Using cached PyYAML-6.0.tar.gz (124 kB)
    Installing build dependencies: started
    Installing build dependencies: finished with status 'done'
    Getting requirements to build wheel: started
    Getting requirements to build wheel: finished with status 'done'
    Preparing metadata (pyproject.toml): started
    Preparing metadata (pyproject.toml): finished with status 'done'
    Collecting colorama==0.4.4
    Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
    Collecting esptool==3.2
    Using cached esptool-3.2.tar.gz (206 kB)
    Collecting zeroconf==0.38.3
    Using cached zeroconf-0.38.3-py3-none-any.whl (106 kB)
    Collecting kconfiglib==13.7.1
    Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
    Collecting pyserial==3.5
    Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
    Collecting paho-mqtt==1.6.1
    Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
    Collecting tzlocal==4.1
    Using cached tzlocal-4.1-py3-none-any.whl (19 kB)
    Collecting click==8.0.3
    Using cached click-8.0.3-py3-none-any.whl (97 kB)
    Collecting voluptuous==0.12.2
    Using cached voluptuous-0.12.2.tar.gz (48 kB)
    Collecting esphome-dashboard==20220209.0
    Using cached esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
    Collecting noiseprotocol<1.0,>=0.3.1
    Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
    Collecting protobuf<4.0,>=3.12.2
    Using cached protobuf-3.20.0-py2.py3-none-any.whl (162 kB)
    Collecting importlib-metadata
    Using cached importlib_metadata-4.11.3-py3-none-any.whl (18 kB)
    Collecting bitstring>=3.1.6
    Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
    Collecting cryptography>=2.1.4
    Using cached cryptography-36.0.2.tar.gz (572 kB)
    Installing build dependencies: still running...
    Installing build dependencies: finished with status 'error'
    host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
    • L LE-R.Kelly
      Systemdata
      Hardwaresystem: Pi4
      @le-r-kelly
      python --version
      python3 --version
      Liefert?
      L 1 Antwort Letzte Antwort
        @le-r-kelly
        python --version
        python3 --version
        Liefert?
        LE-R.Kelly
        pi@raspberrypi:~ $ python --version
        Python 2.7.16
        pi@raspberrypi:~ $ python3 --version
        Python 3.7.3
        Ok, da ist wohl meine Python-Version zu alt...
        L Thomas BraunT 2 Antworten Letzte Antwort
        • L LE-R.Kelly
          Python 2.7.16
          Python 3.7.3
          LE-R.Kelly
          @le-r-kelly
          Wenn ich das bei meiner Netzrecherche richtig verstanden habe ist Python = Python2 und auf einem Raspbian der Standard. Python3 ist zwar drauf, aber wird standardmäßig nicht verwendet, oder?
          Da die Version von Python3 genügt, reicht es diese zum Standard zu machen? Ich habe dazu diese Seite gefunden: https://raspberrytips.com/install-latest-python-raspberry-pi/ unter "Make Python 3 the Default Version on Raspberry Pi OS"
          • L LE-R.Kelly
            Python 2.7.16
            Python 3.7.3
            @le-r-kelly
            Ja. Und python sollte auch zu python3 verlinkt werden.
            Da gab es aber soweit ich mich erinnere einen 'besseren' Weg als der von dir da aufgetriebene.
            update-alternatives --config python
              @le-r-kelly
              LE-R.Kelly
              schrieb am zuletzt editiert von LE-R.Kelly
              Ich hab noch das gefunden: https://wiki.ico.de/display/WIKI/Python+3+als+Standard+einstellen
              Das mit dem Verlinken verstehe ich nicht :-(
              pi@raspberrypi:~ $ update-alternatives --config python
              update-alternatives: Fehler: keine Alternativen für python
              Achso: Danke für Deine Hilfe 👍
              • L LE-R.Kelly
                @le-r-kelly
                https://linuxconfig.org/how-to-change-from-default-to-alternative-python-version-on-debian-linux
                Ab
                Change python version system-wide with update-alternatives python
                wird es interessant.
                • L LE-R.Kelly
                  @le-r-kelly
                  update-alternatives setzt die Links richtig. Mach das nach den beiden letzten HowTos, die machen beide das gleiche.
                  • L Offline
                    LE-R.Kelly
                    Das war wohl nicht das Problem:
                    Python 3.7.3
                    Die Installation des esphome-Adapters endet aber noch immer mit dem Fehlercode 25 :-(
                    • L LE-R.Kelly
                      Python 3.7.3
                      @le-r-kelly
                      Mit welchen Meldungen?
                        @le-r-kelly
                        LE-R.Kelly
                        @thomas-braun sagte in esphome - ERROR: Process exited with code 25:
                        @le-r-kelly
                        • L LE-R.Kelly
                          @le-r-kelly
                          haus-automatisierungH Offline
                          @le-r-kelly sagte in esphome - ERROR: Process exited with code 25:
                          Nicht unbedingt. Auf einer frischen Bullseye Installation ist python 3 installiert und der Befehl python führt dann auch python3 aus:
                          python --version
                          Python 3.9.2
                          Das Problem ist, dass der ioBroker installer aktuell python-dev installiert.
                          Das wiederum installiert python, was auf stable (aktuell bullseye) dazu führt, dass python-is-python2 installiert wird.
                          Also hat man danach einen Symlink von python auf python2, obwohl vorher alles gut war:
                          python --version
                          Python 2.7.18
                          Zu dem Thema habe ich gerade auch einen Issue geöffnet:
                          https://github.com/ioBroker/ioBroker/issues/383
                          (heute getestet mit Raspbian Lite OS 64-Bit)
                          📚 Meine Dokumentation
                          S HomoranH 2 Antworten Letzte Antwort
                            python --version
                            Python 3.9.2
                            python --version
                            Python 2.7.18
                            Sushibomba
                            @haus-automatisierung
                            Verstehe ich noch nicht so ganz. Bei mir schlägt die Installation von ESP Home auch fehl.
                            Was muss ich denn jetzt tun um ESP Home installieren zu können? :-S
                              python --version
                              Python 3.9.2
                              python --version
                              Python 2.7.18
                              HomoranH Offline
                              HomoranH Offline
                              @haus-automatisierung sagte in esphome - ERROR: Process exited with code 25:
                              Nicht unbedingt.
                              das wird eine ältere Information gewesen sein. Bei Aufkommen von python3 wurde noch von sehr vielen Programmen python2 benutzt, resp. waren diese nicht python3 kompatibel.
                              Deswegen blieb der Aufruf python für python2 bestehen und python3 musste explizit so aufgerufen werden.
                              Mittlerweile sieht dies anders aus.
                              • S Sushibomba
                                HomoranH Offline
                                HomoranH Offline
                                @sushibomba mach es mal in der konsole mit zusätzlichem --debug und poste den Output in code-tags
                                • S Sushibomba
                                  @sushibomba
                                  sudo apt update
                                  sudo apt install python-is-python3 python-dev-is-python3
                                  S 2 Antworten Letzte Antwort
                                    Sushibomba
                                    schrieb am zuletzt editiert von Sushibomba
                                    @Homoran Soll ich das erst mal probieren was @Thomas-braun vorgeschlagen hat?
                                      @sushibomba
                                      sudo apt update
                                      Sushibomba
                                      Also das machen und danach nochmal versuchen über die Beta Repo zu installieren?
                                      • S Sushibomba
                                        @sushibomba python kannst du wie oben geschrieben sauber installieren.
                                        Von Beta würde ich ohne triftigen Grund die Finger lassen. Versuch erstmal mit der stable Version dein Glück.
                                        Die mit --debug-Option installieren.
                                        FredFF 1 Antwort Letzte Antwort
                                          FredFF Offline
                                          FredFF Offline
                                          FredF
                                          Most Active Forum Testing
                                          Den ESPHome Adapter gibt es nur als beta
                                          2021.02.27
                                          github:	0.2.4
                                          latest:	0.2.4 for 11 months
                                          stable:	-.-.-
