  4. Raspi Permission denied
    5.8k
59 Beiträge 12 Kommentatoren 7.5k Aufrufe 9 Beobachtet
  • Damrak2022D Damrak2022
    @liv-in-sky So, es gibt Neuigkeiten. Ich habe nun meine SD Karte am iMac formatiert und dann Raspberry light und anschließend Biobroker über die Konsole installiert.
    Im Abschnitt 3 von 4 bei der Iobroker Installation gab es eine Menge Warnmeldungen mit denen ich nichts anfangen kann - siehe hier:
    In file included from ../../nan/nan.h:58,
                     from ../src/main.cpp:3:
    /home/pi/.cache/node-gyp/12.22.11/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      736 |       (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/12.22.11/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
      770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
      433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
      452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:58,
                     from ../src/./serialport.h:13,
                     from ../src/serialport.cpp:1:
    /home/pi/.cache/node-gyp/12.22.11/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
      486 | NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
      179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
       89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    Danach habe ich es geschafft das iobroker Backup von Google Drive wieder einzuspielen.
    Die Backups von "historydb" und "javascript" habe ich noch nicht eingespielt.
    Ich kann iobroker nun über die IP Adresse aufrufen, allerdings wird mir beim Aufrufen der Instanzen unten "Session timeout und Cannot read host Information timeout" usw angezeigt.
    Ich als Laie vermute mal es liegt an den Warmeldungen im 3. Installationsteil von IOBroker.
    Mit welchen Befehlen kann ich das nun über die Konsole in Ordnung bringen?
    liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    @damrak2022
    gute lösung, dass alles neu zu machen
    wegen instanze-tab - schon browser cache gelöscht ?
      @damrak2022 sagte in Raspi Permission denied:
      das ist doch schon im Backup beinhaltet
      das kommt, denk ich, wenn er gerade ausgelastet ist bzw am "arbeiten " ist(hab ich auch gelegentlich)
      die sind normal, alles ok
      die alte, oder eine neue?
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      @crunchip Formatiert habe ich die alte, da eine neue im Moment nicht verfügbar ist.
      Momentan sieht es gut aus. Auch die Instanzen sind da und ich starte gerade alle Adapter neu.
      Mit besten Grüßen
      Andy
      • liv-in-skyL liv-in-sky
        @damrak2022
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        schrieb am zuletzt editiert von Damrak2022
        @liv-in-sky Ich wollte gerade über Instanzen die Vis aufrufen, bekomme da aber eine leere Seite angezeigt, wo steht: File edit.html not found: {}
        Was tun?
        Diese Fehler stehen im Log
        host.raspberrypi
        2022-03-28 08:19:05.368	error	Cannot download and install adapter "vis@1.4.12". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        host.raspberrypi
        2022-03-28 08:19:03.342	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
        vis.0
        2022-03-28 08:18:57.795	error	Not exists
        vis.0
        2022-03-28 08:18:57.794	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
        vis.0
        2022-03-28 08:18:57.792	error	unhandled promise rejection: Not exists
        vis.0
        2022-03-28 08:18:57.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.raspberrypi
        2022-03-28 08:18:20.122	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
        vis.0
        2022-03-28 08:18:16.632	error	Not exists
        vis.0
        2022-03-28 08:18:16.631	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
        vis.0
        2022-03-28 08:18:16.629	error	unhandled promise rejection: Not exists
        vis.0
        2022-03-28 08:18:16.628	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.raspberrypi
        2022-03-28 08:17:33.303	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
        vis.0
        2022-03-28 08:17:29.341	error	Not exists
        vis.0
        2022-03-28 08:17:29.340	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
        vis.0
        2022-03-28 08:17:29.338	error	unhandled promise rejection: Not exists
        vis.0
        2022-03-28 08:17:29.337	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.raspberrypi
        2022-03-28 08:16:52.412	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
        vis.0
        2022-03-28 08:16:43.538	error	Not exists
        vis.0
        2022-03-28 08:16:43.537	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
        vis.0
        2022-03-28 08:16:43.531	error	unhandled promise rejection: Not exists
        vis.0
        2022-03-28 08:16:43.530	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Mit besten Grüßen
        Andy
          Was tun?
          host.raspberrypi
          host.raspberrypi
          vis.0
          vis.0
          vis.0
          vis.0
          host.raspberrypi
          vis.0
          vis.0
          vis.0
          vis.0
          host.raspberrypi
          vis.0
          vis.0
          vis.0
          vis.0
          host.raspberrypi
          vis.0
          vis.0
          vis.0
          vis.0
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          @damrak2022
          evtl vis nochmal uploaden
          • Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            @liv-in-sky Da tut sich garnichts.
            Wenn ich in die Instanzeinstellungen der Vis gehe sehe ich das hier
            Bin mal 15 Minuten weg
            Mit besten Grüßen
            Andy
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              @damrak2022
              in der iobroker console (iterm) mal folgendes eingeben
              iobroker upload vis
                @damrak2022
                iobroker upload vis
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                @liv-in-sky Inn bekomme ich folgende Meldung:
                pi@raspberrypi:~ $ iobroker upload vis
                INFO: Directory "for vis.admin" was not found! Nothing was uploaded or deleted.
                Cannot find io-package.json for "vis"
                INFO: Directory "for vis" was not found! Nothing was uploaded or deleted.
                pi@raspberrypi:~ $ upload vis
                -bash: upload: command not found
                pi@raspberrypi:~ $
                Dann habe ich noch das versucht:
                pi@raspberrypi:~ $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ iobroker stop vis
                The adapter "vis.0" was stopped.
                pi@raspberrypi:/opt/iobroker $ iobroker upload vis
                Mit besten Grüßen
                Andy
                B 2 Antworten Letzte Antwort
                • crunchipC Offline
                  crunchipC Offline
                  @damrak2022 probier es mit
                  iob del vis.0
                  iob add vis
                  haselchenH Damrak2022D 2 Antworten Letzte Antwort
                    iob del vis.0
                    iob add vis
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    Irrtum , deswegen gelöscht
                    • liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      wir arbeiten gerade daran ........
                        iob del vis.0
                        iob add vis
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        @crunchip So mit Hilfe von @liv-in-sky geht wieder alles. Das eine Problem as ich hatte war das mir die Vis nicht angezeigt wurde. Zum Glück ist jetzt alles wieder vorhanden. Danke an alle!
                        Mit besten Grüßen
                        Andy
                          crunchipC Offline
                          crunchipC Offline
                          @damrak2022 und woran lag es nun bzw was habt ihr gemacht?
                          • sigi234S Online
                            sigi234S Online
                            sigi234
                            @damrak2022
                            Wie gelöst?
                            Immer Daten sichern!
                            • sigi234S sigi234
                              @damrak2022
                              Wie gelöst?
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              @sigi234 das kann @liv-in-sky besser beantworten. Es hatte wohl etwas mit einer falschen repositiry zu tun. Da hat ersann einiges umgestellt und dann konnte auch die vis neu installiert werden.
                              Mit besten Grüßen
                              Andy
                              • LatziL Online
                                LatziL Online
                                Latzi
                                @liv-in-sky
                                ich habe exakt das gleiche Problem (nur kein Raspi sondern VM unter proxmox):
                                latzi@ioBroker:/opt/iobroker$ iobroker upload vis
                                Ich hab zuvor den Server getauscht und ein Backup eingespielt, bis auf vis funktioniert soweit mal alles.
                                Kannst du mir hier bitte weiterhelfen?
                                • LatziL Latzi
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  @latzi
                                  Soweit ich mich erinnere habe ich die repo Einstellungen wieder gerade biegen müssen
                                  Siehe hier
                                  https://forum.iobroker.net/post/784483
                                  Weiss aber nicht, ob das auch dein Problem ist
                                    pi@raspberrypi:~ $
                                    babl
                                    schrieb am zuletzt editiert von babl
                                    gelöscht
                                      pi@raspberrypi:~ $
                                      babl
                                      Dieser Beitrag wurde gelöscht!
                                      liv-in-skyL GlasfaserG 2 Antworten Letzte Antwort
                                      • B babl
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        B 1 Antwort Letzte Antwort
                                          babl
                                          Thomas BraunT liv-in-skyL 3 Antworten Letzte Antwort
