  4. Raspi Permission denied
    5.8k
59 Beiträge 12 Kommentatoren 7.5k Aufrufe 9 Beobachtet
  • Damrak2022D Damrak2022
    @liv-in-sky Ich wollte gerade über Instanzen die Vis aufrufen, bekomme da aber eine leere Seite angezeigt, wo steht: File edit.html not found: {}
    Was tun?
    Diese Fehler stehen im Log
    host.raspberrypi
    2022-03-28 08:19:05.368	error	Cannot download and install adapter "vis@1.4.12". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    host.raspberrypi
    2022-03-28 08:19:03.342	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
    vis.0
    2022-03-28 08:18:57.795	error	Not exists
    vis.0
    2022-03-28 08:18:57.794	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
    vis.0
    2022-03-28 08:18:57.792	error	unhandled promise rejection: Not exists
    vis.0
    2022-03-28 08:18:57.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi
    2022-03-28 08:18:20.122	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
    vis.0
    2022-03-28 08:18:16.632	error	Not exists
    vis.0
    2022-03-28 08:18:16.631	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
    vis.0
    2022-03-28 08:18:16.629	error	unhandled promise rejection: Not exists
    vis.0
    2022-03-28 08:18:16.628	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi
    2022-03-28 08:17:33.303	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
    vis.0
    2022-03-28 08:17:29.341	error	Not exists
    vis.0
    2022-03-28 08:17:29.340	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
    vis.0
    2022-03-28 08:17:29.338	error	unhandled promise rejection: Not exists
    vis.0
    2022-03-28 08:17:29.337	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi
    2022-03-28 08:16:52.412	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
    vis.0
    2022-03-28 08:16:43.538	error	Not exists
    vis.0
    2022-03-28 08:16:43.537	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
    vis.0
    2022-03-28 08:16:43.531	error	unhandled promise rejection: Not exists
    vis.0
    2022-03-28 08:16:43.530	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    liv-in-skyL Offline
    liv-in-skyL Offline
    @damrak2022
    evtl vis nochmal uploaden
    • Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      @liv-in-sky Da tut sich garnichts.
      Wenn ich in die Instanzeinstellungen der Vis gehe sehe ich das hier
      Bin mal 15 Minuten weg
      Mit besten Grüßen
      Andy
        liv-in-skyL Offline
        liv-in-skyL Offline
        @damrak2022
        in der iobroker console (iterm) mal folgendes eingeben
        iobroker upload vis
        • liv-in-skyL liv-in-sky
          @damrak2022
          iobroker upload vis
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          @liv-in-sky Inn bekomme ich folgende Meldung:
          pi@raspberrypi:~ $ iobroker upload vis
          INFO: Directory "for vis.admin" was not found! Nothing was uploaded or deleted.
          Cannot find io-package.json for "vis"
          INFO: Directory "for vis" was not found! Nothing was uploaded or deleted.
          pi@raspberrypi:~ $ upload vis
          -bash: upload: command not found
          pi@raspberrypi:~ $
          Dann habe ich noch das versucht:
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ iobroker stop vis
          The adapter "vis.0" was stopped.
          pi@raspberrypi:/opt/iobroker $ iobroker upload vis
          Mit besten Grüßen
          Andy
          B 2 Antworten Letzte Antwort
          • crunchipC Offline
            crunchipC Offline
            @damrak2022 probier es mit
            iob del vis.0
            iob add vis
            haselchenH Damrak2022D 2 Antworten Letzte Antwort
              iob del vis.0
              iob add vis
              haselchenH Offline
              haselchenH Offline
              haselchen
              Irrtum , deswegen gelöscht
              • liv-in-skyL Offline
                liv-in-skyL Offline
                wir arbeiten gerade daran ........
                  iob del vis.0
                  iob add vis
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  @crunchip So mit Hilfe von @liv-in-sky geht wieder alles. Das eine Problem as ich hatte war das mir die Vis nicht angezeigt wurde. Zum Glück ist jetzt alles wieder vorhanden. Danke an alle!
                  Mit besten Grüßen
                  Andy
                    crunchipC Offline
                    crunchipC Offline
                    @damrak2022 und woran lag es nun bzw was habt ihr gemacht?
                    • sigi234S Online
                      sigi234S Online
                      @damrak2022
                      Wie gelöst?
                      • sigi234S sigi234
                        @damrak2022
                        Wie gelöst?
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        @sigi234 das kann @liv-in-sky besser beantworten. Es hatte wohl etwas mit einer falschen repositiry zu tun. Da hat ersann einiges umgestellt und dann konnte auch die vis neu installiert werden.
                        Mit besten Grüßen
                        Andy
                        • LatziL Online
                          LatziL Online
                          Latzi
                          @liv-in-sky
                          ich habe exakt das gleiche Problem (nur kein Raspi sondern VM unter proxmox):
                          latzi@ioBroker:/opt/iobroker$ iobroker upload vis
                          Ich hab zuvor den Server getauscht und ein Backup eingespielt, bis auf vis funktioniert soweit mal alles.
                          Kannst du mir hier bitte weiterhelfen?
                          • LatziL Latzi
                            @liv-in-sky
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @latzi
                            Soweit ich mich erinnere habe ich die repo Einstellungen wieder gerade biegen müssen
                            Siehe hier
                            https://forum.iobroker.net/post/784483
                            Weiss aber nicht, ob das auch dein Problem ist
                              pi@raspberrypi:~ $
                              babl
                              schrieb am zuletzt editiert von babl
                              gelöscht
                                pi@raspberrypi:~ $
                                babl
                                Dieser Beitrag wurde gelöscht!
                                liv-in-skyL GlasfaserG 2 Antworten Letzte Antwort
                                • B babl
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                    babl
                                    Thomas BraunT liv-in-skyL 3 Antworten Letzte Antwort
                                    • B babl
                                      • B babl
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
