  4. js-controller läuft auf Volllast
    1.9k
42 Beiträge 6 Kommentatoren 4.1k Aufrufe 2 Beobachtet
  • apollon77A apollon77
    @th3rockyeah sagte in js-controller 4.0 jetzt im BETA/LATEST!:
    2022-03-21 09:59:53.061 - error: radar2.0 (12164) States database error: write EPIPE
    Da "geht es los" ... zuerst EPIPE ... danach ECONNRESET ...
    Was steht zu dem Zeitpunkt in /var/log/syslog ??
    Th3RockYeah
    schrieb am zuletzt editiert von Th3RockYeah
    @apollon77 Hier ein Auszug aus dem Syslog
    Mar 21 09:44:04 raspberrypi bash[511]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
    Mar 21 09:44:19 raspberrypi kernel: [53765.769082] device eth0 entered promiscuous mode
    Mar 21 09:44:25 raspberrypi kernel: [53771.614524] device eth0 left promiscuous mode
    Mar 21 09:44:44 raspberrypi kernel: [53790.761404] device eth0 entered promiscuous mode
    Mar 21 09:44:50 raspberrypi kernel: [53796.609895] device eth0 left promiscuous mode
    Mar 21 09:45:06 raspberrypi systemd[1]: Stopping ioBroker Server...
    Mar 21 09:45:08 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
    Mar 21 09:45:08 raspberrypi bash[511]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    Mar 21 09:45:08 raspberrypi bash[511]: Error: DB closed
    Mar 21 09:45:08 raspberrypi bash[511]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    Mar 21 09:45:08 raspberrypi bash[511]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
    Mar 21 09:45:08 raspberrypi bash[511]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
    Mar 21 09:45:08 raspberrypi bash[511]:     at Shelly.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
    Mar 21 09:45:08 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [Process stopped]
    Mar 21 09:45:08 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
    Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
    Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [system.adapter.cloud.0.logging]
    Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Mar 21 09:45:09 raspberrypi bash[511]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Mar 21 09:45:11 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
    Mar 21 09:45:11 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Mar 21 09:45:11 raspberrypi systemd[1]: Stopped ioBroker Server.
    Mar 21 09:46:08 raspberrypi systemd[1]: Starting Daily apt download activities...
    Mar 21 09:46:09 raspberrypi systemd[1]: apt-daily.service: Succeeded.
    Mar 21 09:46:09 raspberrypi systemd[1]: Started Daily apt download activities.
    Mar 21 09:46:21 raspberrypi systemd[1]: Started ioBroker Server.
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.owntracks.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.feiertage.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.iqontrol.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.jarvis.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.mercedesme.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.nina.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.pi-hole.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.radar2.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.tado.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
    Mar 21 09:46:24 raspberrypi bash[11917]: host.raspberrypi check instance "system.adapter.schoolfree.0" for host "raspberrypi"
    Mar 21 09:46:30 raspberrypi bash[11917]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
    Mar 21 09:46:31 raspberrypi bash[11917]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: bits received from HRNG source: 500064
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: bits sent to kernel pool: 453824
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: entropy added to kernel pool: 453824
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2 successes: 25
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2 failures: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Monobit: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Poker: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Runs: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Long run: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: HRNG source speed: (min=486.239; avg=517.092; max=525.910)Kibits/s
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: FIPS tests speed: (min=10.782; avg=19.883; max=31.423)Mibits/s
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: Lowest ready-buffers level: 2
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: Entropy starvations: 0
    Mar 21 09:48:22 raspberrypi rngd[452]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
    Mar 21 09:58:43 raspberrypi kernel: [54629.900292] device eth0 entered promiscuous mode
    Mar 21 09:58:43 raspberrypi kernel: [54629.925672] device eth0 left promiscuous mode
    Mar 21 09:58:45 raspberrypi kernel: [54631.777967] CIFS: Attempting to mount //192.168.170.109/ioBrokerBackup/ioBroker
    Mar 21 09:58:57 raspberrypi kernel: [54643.888861] device eth0 entered promiscuous mode
    Mar 21 09:59:03 raspberrypi kernel: [54649.763197] device eth0 left promiscuous mode
    Mar 21 09:59:52 raspberrypi kernel: [54692.150897] ping invoked oom-killer: gfp_mask=0x400dc0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), order=0, oom_score_adj=0
    Mar 21 09:59:52 raspberrypi kernel: [54692.150921] CPU: 2 PID: 12502 Comm: ping Tainted: G         C        5.10.103-v8+ #1529
    Mar 21 09:59:52 raspberrypi kernel: [54692.150927] Hardware name: Raspberry Pi 4 Model B Rev 1.2 (DT)
    Mar 21 09:59:52 raspberrypi kernel: [54692.150934] Call trace:
    Mar 21 09:59:52 raspberrypi kernel: [54692.150954]  dump_backtrace+0x0/0x1b8
    Mar 21 09:59:52 raspberrypi kernel: [54692.150963]  show_stack+0x20/0x30
    Mar 21 09:59:52 raspberrypi kernel: [54692.150974]  dump_stack+0xf0/0x158
    Mar 21 09:59:52 raspberrypi kernel: [54692.150981]  dump_header+0x4c/0x204
    Mar 21 09:59:52 raspberrypi kernel: [54692.150993]  oom_kill_process+0x1f8/0x200
    Mar 21 09:59:52 raspberrypi kernel: [54692.150999]  out_of_memory+0xf0/0x330
    Mar 21 09:59:52 raspberrypi kernel: [54692.151010]  __alloc_pages_slowpath.constprop.134+0x820/0xb80
    Mar 21 09:59:52 raspberrypi kernel: [54692.151017]  __alloc_pages_nodemask+0x2bc/0x330
    Mar 21 09:59:52 raspberrypi kernel: [54692.151025]  handle_mm_fault+0xbc8/0xcb8
    Mar 21 09:59:52 raspberrypi kernel: [54692.151035]  do_page_fault+0x148/0x3e8
    Mar 21 09:59:52 raspberrypi kernel: [54692.151043]  do_translation_fault+0x58/0x70
    Mar 21 09:59:52 raspberrypi kernel: [54692.151053]  do_mem_abort+0x48/0xa8
    Mar 21 09:59:52 raspberrypi kernel: [54692.151059]  el0_da+0x40/0x58
    Mar 21 09:59:52 raspberrypi kernel: [54692.151066]  el0_sync_compat_handler+0xfc/0x110
    Mar 21 09:59:52 raspberrypi kernel: [54692.151072]  el0_sync_compat+0x184/0x1c0
    Mar 21 09:59:52 raspberrypi kernel: [54692.151079] Mem-Info:
    Mar 21 09:59:52 raspberrypi kernel: [54692.151098] active_anon:372700 inactive_anon:560327 isolated_anon:0
    Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  active_file:899 inactive_file:1086 isolated_file:0
    Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  unevictable:4 dirty:1 writeback:0
    Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  slab_reclaimable:4848 slab_unreclaimable:6882
    Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  mapped:1447 shmem:646 pagetables:5758 bounce:0
    Mar 21 09:59:52 raspberrypi kernel: [54692.151098]  free:8689 free_pcp:11 free_cma:389
    Mar 21 09:59:52 raspberrypi kernel: [54692.151113] Node 0 active_anon:1490800kB inactive_anon:2241308kB active_file:3596kB inactive_file:4344kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:5788kB dirty:4kB writeback:0kB shmem:2584kB writeback_tmp:0kB kernel_stack:5920kB all_unreclaimable? no
    Mar 21 09:59:52 raspberrypi kernel: [54692.151132] DMA free:15940kB min:3736kB low:4668kB high:5600kB reserved_highatomic:0KB active_anon:928kB inactive_anon:855204kB active_file:168kB inactive_file:376kB unevictable:0kB writepending:0kB present:970752kB managed:886672kB mlocked:0kB pagetables:1792kB bounce:0kB free_pcp:8kB local_pcp:0kB free_cma:1556kB
    Mar 21 09:59:52 raspberrypi kernel: [54692.151139] lowmem_reserve[]: 0 2929 2929 2929
    Mar 21 09:59:52 raspberrypi kernel: [54692.151189] DMA32 free:18816kB min:41088kB low:44248kB high:47408kB reserved_highatomic:0KB active_anon:1489872kB inactive_anon:1386104kB active_file:3692kB inactive_file:4316kB unevictable:16kB writepending:4kB present:3080192kB managed:2999432kB mlocked:16kB pagetables:21240kB bounce:0kB free_pcp:36kB local_pcp:0kB free_cma:0kB
    Mar 21 09:59:52 raspberrypi kernel: [54692.151196] lowmem_reserve[]: 0 0 0 0
    Mar 21 09:59:52 raspberrypi kernel: [54692.151235] DMA: 83*4kB (UMEC) 46*8kB (UMEC) 36*16kB (UEC) 49*32kB (UEC) 20*64kB (UEC) 11*128kB (UEC) 9*256kB (UEC) 4*512kB (UC) 2*1024kB (U) 2*2048kB (UE) 0*4096kB = 16028kB
    Mar 21 09:59:52 raspberrypi kernel: [54692.151391] DMA32: 1466*4kB (UME) 647*8kB (UME) 265*16kB (UME) 39*32kB (UME) 38*64kB (UE) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 18960kB
    Mar 21 09:59:52 raspberrypi kernel: [54692.151514] 3025 total pagecache pages
    Mar 21 09:59:52 raspberrypi kernel: [54692.151524] 365 pages in swap cache
    Mar 21 09:59:52 raspberrypi kernel: [54692.151533] Swap cache stats: add 27088, delete 26764, find 597/1024
    Mar 21 09:59:52 raspberrypi kernel: [54692.151541] Free swap  = 0kB
    Mar 21 09:59:52 raspberrypi kernel: [54692.151548] Total swap = 102396kB
    Mar 21 09:59:52 raspberrypi kernel: [54692.151556] 1012736 pages RAM
    Mar 21 09:59:52 raspberrypi kernel: [54692.151564] 0 pages HighMem/MovableOnly
    Mar 21 09:59:52 raspberrypi kernel: [54692.151571] 41210 pages reserved
    Mar 21 09:59:52 raspberrypi kernel: [54692.151578] 81920 pages cma reserved
    Mar 21 09:59:52 raspberrypi kernel: [54692.151586] Tasks state (memory values in pages):
    Mar 21 09:59:52 raspberrypi kernel: [54692.151594] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
    Mar 21 09:59:52 raspberrypi kernel: [54692.151621] [    138]     0   138     5310      224   143360      160             0 systemd-journal
    Mar 21 09:59:52 raspberrypi kernel: [54692.151632] [    160]     0   160     4657       51    49152      172         -1000 systemd-udevd
    Mar 21 09:59:52 raspberrypi kernel: [54692.151648] [    349]   100   349     5603       11    53248      157             0 systemd-timesyn
    Mar 21 09:59:52 raspberrypi kernel: [54692.151658] [    407]     0   407     3260       21    57344      150             0 systemd-logind
    Mar 21 09:59:52 raspberrypi kernel: [54692.151669] [    412]   104   412     1680       68    40960       73          -900 dbus-daemon
    Mar 21 09:59:52 raspberrypi kernel: [54692.151679] [    423]   108   423     1506      122    40960       46             0 avahi-daemon
    Mar 21 09:59:52 raspberrypi kernel: [54692.151691] [    430]     0   430     1986       11    40960       35             0 cron
    Mar 21 09:59:52 raspberrypi kernel: [54692.151701] [    433] 65534   433     1079        5    40960       40             0 thd
    Mar 21 09:59:52 raspberrypi kernel: [54692.151711] [    439]     0   439     2685       13    49152       89             0 wpa_supplicant
    Mar 21 09:59:52 raspberrypi kernel: [54692.151722] [    444]     0   444     6377       72    61440      159             0 rsyslogd
    Mar 21 09:59:52 raspberrypi kernel: [54692.151732] [    452]     0   452     6913        0    40960       30             0 rngd
    Mar 21 09:59:52 raspberrypi kernel: [54692.151742] [    460]   108   460     1441        6    36864       57             0 avahi-daemon
    Mar 21 09:59:52 raspberrypi kernel: [54692.151753] [    508]     0   508     2156        0    40960       57             0 vncserver-x11-s
    Mar 21 09:59:52 raspberrypi kernel: [54692.151764] [    525]     0   525     8825       34    90112      402             0 vncserver-x11-c
    Mar 21 09:59:52 raspberrypi kernel: [54692.151774] [    526]     0   526     1076        0    36864       25             0 agetty
    Mar 21 09:59:52 raspberrypi kernel: [54692.151784] [    527]     0   527     2681        2    49152      143         -1000 sshd
    Mar 21 09:59:52 raspberrypi kernel: [54692.151795] [    628]     0   628      534        1    28672       32             0 hciattach
    Mar 21 09:59:52 raspberrypi kernel: [54692.152590] [   4782]     0  4782     7351        1    73728      667             0 cupsd
    Mar 21 09:59:52 raspberrypi kernel: [54692.152610] [   4783]     0  4783    10123        0    77824      279             0 cups-browsed
    Mar 21 09:59:52 raspberrypi kernel: [54692.152623] [   4791]   114  4791    11944        0    86016      718             0 colord
    Mar 21 09:59:52 raspberrypi kernel: [54692.152637] [  11639]     0 11639     3059       22    49152      178             0 sshd
    Mar 21 09:59:52 raspberrypi kernel: [54692.152649] [  11642]  1000 11642     3682       92    57344      158             0 systemd
    Mar 21 09:59:52 raspberrypi kernel: [54692.152661] [  11643]  1000 11643     8842       76    73728      379             0 (sd-pam)
    Mar 21 09:59:52 raspberrypi kernel: [54692.152672] [  11657]  1000 11657     3092       48    53248      188             0 sshd
    Mar 21 09:59:52 raspberrypi kernel: [54692.152683] [  11658]  1000 11658      513        0    24576       49             0 sftp-server
    Mar 21 09:59:52 raspberrypi kernel: [54692.152694] [  11691]     0 11691     3059       25    49152      175             0 sshd
    Mar 21 09:59:52 raspberrypi kernel: [54692.152705] [  11697]  1000 11697     3059       55    49152      148             0 sshd
    Mar 21 09:59:52 raspberrypi kernel: [54692.152715] [  11698]  1000 11698     2119        2    40960      228             0 bash
    Mar 21 09:59:52 raspberrypi kernel: [54692.152728] [  11917]  1001 11917   669273   617733  6283264    14411             0 iobroker.js-con
    Mar 21 09:59:52 raspberrypi kernel: [54692.152739] [  11929]  1000 11929     2606       93    49152       43             0 top
    Mar 21 09:59:52 raspberrypi kernel: [54692.152750] [  11936]  1001 11936   216603   178212  3272704     1752             0 io.admin.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152761] [  11952]  1001 11952    43552     1956   585728     2594             0 io.email.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152771] [  11967]  1001 11967    44603     5406   610304       25             0 io.history.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152782] [  11978]  1001 11978    63452    21823  1044480       78             0 io.javascript.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152792] [  11993]  1001 11993    43540     4191   573440        1             0 io.pushover.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152803] [  11999]  1001 11999    45959     6225   651264       40             0 io.alexa2.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152814] [  12002]  1001 12002    44289     5382   593920       16             0 io.hue.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152825] [  12026]  1001 12026    47897     9516   749568       36             0 io.shelly.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152835] [  12028]  1001 12028    45810     6998   704512       31             0 io.shelly.1
    Mar 21 09:59:52 raspberrypi kernel: [54692.152845] [  12044]  1001 12044    45985     6906   696320       54             0 io.tr-064.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152856] [  12087]  1001 12087    49303    10040   815104       25             0 io.zigbee.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152866] [  12109]  1001 12109    43212     3952   577536        6             0 io.discovery.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152877] [  12124]  1001 12124    45483     6747   696320        8             0 io.backitup.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152889] [  12164]  1001 12164    44765     5353   667648       75             0 io.radar2.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152899] [  12172]  1001 12172    44677     5863   638976        8             0 io.info.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152968] [  12173]  1001 12173    45035     5408   655360      120             0 io.cloud.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.152980] [  12186]  1001 12186    43349     4531   573440       16             0 io.text2command
    Mar 21 09:59:52 raspberrypi kernel: [54692.152998] [  12188]  1001 12188    51190    15675   880640       23             0 io.iot.0
    Mar 21 09:59:52 raspberrypi kernel: [54692.153015] [  12430]  1001 12430      484       14    28672        0             0 sh
    Mar 21 09:59:52 raspberrypi kernel: [54692.153027] [  12436]  1001 12436    30552     2832   352256        0             0 npm
    Mar 21 09:59:52 raspberrypi kernel: [54692.153038] [  12462]  1001 12462      484       13    32768        0             0 sh
    Mar 21 09:59:52 raspberrypi kernel: [54692.153052] [  12463]  1001 12463     7979     4260    90112        0             0 pip
    Mar 21 09:59:52 raspberrypi kernel: [54692.153065] [  12465]  1001 12465      484       14    32768        0             0 sh
    Mar 21 09:59:52 raspberrypi kernel: [54692.153076] [  12466]  1001 12466     7240     3047    86016        0             0 pip3
    Mar 21 09:59:52 raspberrypi kernel: [54692.153087] [  12502]  1001 12502     1026       72    32768        0             0 ping
    Mar 21 09:59:52 raspberrypi kernel: [54692.153100] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=iobroker.js-con,pid=11917,uid=1001
    Mar 21 09:59:52 raspberrypi kernel: [54692.153207] Out of memory: Killed process 11917 (iobroker.js-con) total-vm:2677092kB, anon-rss:2470216kB, file-rss:716kB, shmem-rss:0kB, UID:1001 pgtables:6136kB oom_score_adj:0
    Mar 21 09:59:52 raspberrypi kernel: [54692.532210] oom_reaper: reaped process 11917 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
    Mar 21 09:59:53 raspberrypi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
    Mar 21 10:00:09 raspberrypi systemd[1]: iobroker.service: Failed with result 'signal'.
    Mar 21 10:00:13 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
    Mar 21 10:00:13 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
    Mar 21 10:00:13 raspberrypi systemd[1]: Stopped ioBroker Server.
    Mar 21 10:00:13 raspberrypi systemd[1]: Started ioBroker Server.
    Mar 21 10:00:17 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.email.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.owntracks.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.feiertage.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.iqontrol.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.jarvis.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.lgtv.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.mercedesme.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.nina.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.pi-hole.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.radar2.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.tado.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
    Mar 21 10:00:18 raspberrypi bash[12504]: host.raspberrypi check instance "system.adapter.schoolfree.0" for host "raspberrypi"
    Mar 21 10:00:21 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Mar 21 10:00:21 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Mar 21 10:00:34 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
    Mar 21 10:00:34 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Mar 21 10:01:00 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Mar 21 10:01:01 raspberrypi bash[12504]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
    Mar 21 10:01:38 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
    Mar 21 10:01:38 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [Process stopped]
    Mar 21 10:01:38 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
    Mar 21 10:01:39 raspberrypi bash[12504]: ================================== > LOG REDIRECT system.adapter.cloud.0 => false [system.adapter.cloud.0.logging]
    Mar 21 10:01:42 raspberrypi bash[12504]: Send diag info: {"uuid":"dbe50d02-68fa-f6f2-71c6-83f4ae4fc370","language":"de","country":"Germany","hosts":[{"version":"4.0.19","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.1","arch":"arm","docker":false,"adapters":{"admin":{"version":"5.3.3","platform":"Javascript/Node.js"},"discovery":{"version":"2.8.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.3.5","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.1","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.11.0","platform":"Javascript/Node.js"},"hue":{"version":"3.6.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.11.2","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.0.1","platform":"Javascript/Node.js"},"jarvis":{"version":"3.0.11","platform":"Javascript/Node.js"},"javascript":{"version":"5.4.5","platform":"Javascript/Node.js"},"lgtv":{"version":"1.1.10","platform":"Javascript/Node.js"},"mercedesme":{"version":"0.0.56","platform":"Javascript/Node.js"},"nina":{"version":"0.0.25","platform":"Javascript/Node.js"},"owntracks":{"version":"1.0.1","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.4","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pushover":{"version":"2.1.0","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"shelly":{"version":"5.3.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.3","platform":"Javascript/Node.js"},"socketio":{"version":"4.1.4","platform":"Javascript/Node.js"},"systeminfo":{"version":"0.3.1","platform":"Javascript/Node.js"},"tado":{"version":"0.3.15","platform":"Javascript/Node.js"},"text2command":{"version":"2.2.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"vis":{"version":"1.4.12","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.4.1","platform":"Javascript/Node.js"},"web":{"version":"4.2.1","platform":"Javascript/Node.js"},"ws":{"version":"1.2.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"schoolfree":{"version":"1.0.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":32,"compactMode":false,"noCompactInstances":0,"model":"unknown","cpus":4,"mem":3979370496,"ostype":"Linux","vis":12}
    Mar 21 10:05:01 raspberrypi kernel: [55008.133171] device eth0 entered promiscuous mode
    Mar 21 10:05:01 raspberrypi kernel: [55008.150810] device eth0 left promiscuous mode
    Mar 21 10:05:04 raspberrypi kernel: [55010.224024] CIFS: Attempting to mount //xxx.xxx.xxx.xxx/ioBrokerBackup/ioBroker
    Mar 21 10:05:05 raspberrypi kernel: [55011.621251] CIFS: Attempting to mount //xxx.xxx.xxx.xxx/ioBrokerBackup/ioBroker
    Mar 21 10:05:05 raspberrypi kernel: [55011.621322] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
    Mar 21 10:05:15 raspberrypi systemd[1]: opt-iobroker-backups.mount: Succeeded.
    Mar 21 10:05:15 raspberrypi systemd[11642]: opt-iobroker-backups.mount: Succeeded.
    jfyi: Der js-controller läuft immer noch auf 100%
    • T Th3RockYeah
      DiginixD Offline
      DiginixD Offline
      Diginix
      Dem geht der RAM aus.
      ..:: So long! Tom ::..
      • DiginixD Diginix
        Th3RockYeah
        @diginix Aktuell "frisst" der JS-Controller auch permanent. zB 58,7% MEM
        • apollon77A Offline
          Genau wie @Diginix schreibt ... irgendwas ist passiert und der js-controller
          wurde wegen RAM issues vom System gekillt.
          Welche mqtt Version hast Du drauf? Beta oder Stable?
          Bei javsscript habe ich oben gesehen das eine Logzeile doppelt kam ... was auch nicht sein sollte
          Ich schlage Dir folgendes vor.
          • Stoppe iobroker
          • schau das wirklich alles weg ist
          • setze (falls nicht geschehen) die connectTimeout hoch das idealerweise CLI wieder tut. Hattest Du gesagt wie groß die jsonl Files sind?
          • dann per cli mit "iob stop adapter.X" alle instanzen stoppen, ausser admin.0
          • Dann iobroker starten ... wie geht es ihm dann? Schauen das Admin wieder lädt und mal durch die objekte schauen wo vlt diese massen herkommen
          • Dann einen adapter nach dem anderen starten und immer schauen was passiert. sobald es wieder anfängt den Adapter stoppen und schauen ob dann ruhiger wird.
          • T Th3RockYeah
            @th3rockyeah
            Teil 2
            es ist fortführend...
            2022-03-21 10:03:43.856 - info: javascript.0 (12683) received all objects
            2022-03-21 10:03:45.047 - info: javascript.0 (12683) received all states
            2022-03-21 10:03:45.386 - info: javascript.0 (12683) Start javascript script.js.common.BatteryCheck
            2022-03-21 10:03:45.451 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12924
            2022-03-21 10:03:45.514 - info: javascript.0 (12683) script.js.common.BatteryCheck: starting Batterieüberwachung V.1.8.5
            2022-03-21 10:03:45.520 - info: javascript.0 (12683) script.js.common.BatteryCheck: registered 0 subscriptions and 0 schedules
            2022-03-21 10:03:45.603 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12930
            2022-03-21 10:03:45.683 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12937
            2022-03-21 10:03:45.533 - info: javascript.0 (12683) Start javascript script.js.common.BewegungsmelderV2
            2022-03-21 10:03:45.561 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: *** Bewegungsmelder-Script gestartet *** Folgende Bewegungsmelder werden überwacht: BadGaeste, SchlafzimmerNew, Laundry, BadFirstFloor, FirstFloorLightNew, FirstFloorLightTom, StairsToFirstFloor, BeerCellar, ToolCellar, CellarFloor, StepToCellarFloor, AlarmTest3
            2022-03-21 10:03:45.567 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: registered 12 subscriptions and 0 schedules
            2022-03-21 10:03:45.569 - info: javascript.0 (12683) Start javascript script.js.common.CommonMix
            2022-03-21 10:03:45.577 - info: javascript.0 (12683) script.js.common.CommonMix: registered 8 subscriptions and 0 schedules
            2022-03-21 10:03:45.578 - info: javascript.0 (12683) Start javascript script.js.common.FritzBox
            2022-03-21 10:03:45.584 - info: javascript.0 (12683) script.js.common.FritzBox: registered 1 subscription and 0 schedules
            2022-03-21 10:03:45.585 - info: javascript.0 (12683) Start javascript script.js.common.LeavingHouse
            2022-03-21 10:03:45.608 - info: javascript.0 (12683) script.js.common.LeavingHouse: registered 2 subscriptions and 0 schedules
            2022-03-21 10:03:45.610 - info: javascript.0 (12683) Start javascript script.js.common.OpenDoorsWindows
            2022-03-21 10:03:45.659 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: registered 0 subscriptions and 0 schedules
            2022-03-21 10:03:45.660 - info: javascript.0 (12683) Start javascript script.js.common.Shellys
            2022-03-21 10:03:45.680 - info: javascript.0 (12683) script.js.common.Shellys: registered 9 subscriptions and 0 schedules
            2022-03-21 10:03:45.807 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12944
            2022-03-21 10:03:45.872 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12946
            2022-03-21 10:03:45.979 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12957
            2022-03-21 10:03:46.064 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12961
            2022-03-21 10:03:46.120 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12966
            2022-03-21 10:03:46.357 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: Alle Fenster geschlossen.
            2022-03-21 10:03:59.998 - warn: discovery.0 (12937) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:00.427 - warn: text2command.0 (12966) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:00.527 - warn: radar2.0 (12924) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:00.805 - warn: iot.0 (12946) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:00.827 - warn: backitup.0 (12944) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:00.965 - warn: cloud.0 (12957) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:02.625 - warn: info.0 (12961) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:02.633 - warn: zigbee.0 (12930) slow connection to objects DB. Still waiting ...
            2022-03-21 10:04:54.290 - info: feiertage.0 (12747) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:04:58.146 - info: feiertage.0 (12747) Next holiday: Karfreitag is in 25 days on 15.04.2022
            2022-03-21 10:04:58.476 - info: tr-064.0 (12889) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:04:58.744 - info: feiertage.0 (12747) adapter feiertage objects written
            2022-03-21 10:04:59.180 - info: schoolfree.0 (12878) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:04:59.320 - info: feiertage.0 (12747) Terminated (NO_ERROR): Without reason
            2022-03-21 10:04:59.385 - info: shelly.0 (12768) Starting in CoAP mode.
            2022-03-21 10:04:59.630 - info: shelly.0 (12768) [CoAP] Listening for packets in the network
            2022-03-21 10:04:59.709 - info: shelly.1 (12777) Starting in MQTT mode. Listening on Y.X.C..31:1882
            2022-03-21 10:04:59.767 - info: radar2.0 (12924) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:04:59.713 - warn: schoolfree.0 (12878) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
            2022-03-21 10:05:00.167 - info: shelly.0 (12768) [CoAP] Device Y.X.C..28 (shelly1pm / shelly1pm-F27634 / SHSW-PM#F27634#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:00.437 - info: schoolfree.0 (12878) schoolfree request done
            2022-03-21 10:05:00.485 - info: shelly.0 (12768) [CoAP] Device Y.X.C..47 (shellydimmer / shellydimmer-D463D3 / SHDM-1#D463D3#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:00.754 - info: radar2.0 (12924) radar2 initialization started...
            2022-03-21 10:05:00.800 - info: radar2.0 (12924) Will use l2Ping for BT scans.
            2022-03-21 10:05:00.893 - info: radar2.0 (12924) Will run hcitool-mode and not noble on device []!
            2022-03-21 10:05:01.103 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
            2022-03-21 10:05:01.190 - info: radar2.0 (12924) arp-scan will use the following interfaces: [ 'eth0' ]
            2022-03-21 10:05:01.217 - info: radar2.0 (12924) Connected with '0.0.0.0' for DHCP Scan
            2022-03-21 10:05:02.201 - info: text2command.0 (12966) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:02.412 - info: discovery.0 (12937) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:02.476 - info: cloud.0 (12957) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:02.660 - info: zigbee.0 (12930) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:03.212 - info: backitup.0 (12944) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:03.240 - info: cloud.0 (12957) Connecting with https://iobroker.pro:10555 with "@pro_lars@lars-keller.net_a56c8fe0-59a6-11ea-bbb9-a3d45e2d176f"
            2022-03-21 10:05:03.339 - info: iot.0 (12946) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:03.452 - info: backitup.0 (12944) [iobroker] backup was activated at 02:53 every 1 day(s)
            2022-03-21 10:05:03.517 - info: iot.0 (12946) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2022-03-21 10:05:02.984 - info: zigbee.0 (12930) Starting Zigbee npm ...
            2022-03-21 10:05:03.929 - info: shelly.0 (12768) [CoAP] Device Y.X.C..36 (shelly1 / shelly1-98F4ABF3CF6C / SHSW-1#98F4ABF3CF6C#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:04.474 - info: iot.0 (12946) Connection changed: connect
            2022-03-21 10:05:04.982 - info: zigbee.0 (12930) Installed Version: ioBroker/ioBroker.zigbee
            2022-03-21 10:05:05.086 - info: shelly.0 (12768) [CoAP] Device Y.X.C..67 (shellydimmer / shellydimmer-D3E31B / SHDM-1#D3E31B#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:05.100 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:05:05.152 - info: zigbee.0 (12930) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
            2022-03-21 10:05:05.171 - info: zigbee.0 (12930) Unable to disable LED, unsupported function.
            2022-03-21 10:05:05.181 - info: shelly.0 (12768) [CoAP] Device Y.X.C..44 (shellyplug-s / shellyplug-s-DE15FC / SHPLG-S#DE15FC#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:05.224 - info: zigbee.0 (12930) --> transmitPower : normal
            2022-03-21 10:05:05.254 - info: zigbee.0 (12930) Currently 53 devices are joined:
            2022-03-21 10:05:05.568 - error: backitup.0 (12944) Error: Command failed: sudo mount -t cifs -o username=iobrokerUser,password=****,rw,file_mode=0777,dir_mode=0777 //Y.X.C..109/ioBrokerBackup/ioBroker /opt/iobroker/backups
            mount error(16): Device or resource busy
            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
            2022-03-21 10:05:05.619 - info: shelly.0 (12768) [CoAP] Device Y.X.C..32 (shellyplug-s / shellyplug-s-8D010E / SHPLG-S#8D010E#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:05.977 - info: zigbee.0 (12930) 0x00158d0007b7ddc0 (addr 51404): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            2022-03-21 10:05:05.979 - info: zigbee.0 (12930) 0x000d6ffffea61fe1 (addr 8521): E1746 - IKEA TRADFRI signal repeater (Router)
            2022-03-21 10:05:05.980 - info: zigbee.0 (12930) Zigbee started
            2022-03-21 10:05:06.418 - info: shelly.0 (12768) [CoAP] Device Y.X.C..30 (shelly1 / shelly1-767AC8 / SHSW-1#767AC8#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:07.055 - info: shelly.0 (12768) [CoAP] Device Y.X.C..33 (shellyplug-s / shellyplug-s-80116A / SHPLG-S#80116A#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:07.606 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater
            2022-03-21 10:05:07.612 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
            2022-03-21 10:05:08.159 - info: shelly.1 (12777) [MQTT] Device Y.X.C..104 (shellyplus1 / shellyplus1-a8032abeb1e4 / shellyplus1#a8032abeb1e4#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:08.487 - info: shelly.0 (12768) [CoAP] Device Y.X.C..110 (shellyplug-s / shellyplug-s-4BA36E / SHPLG2-1#4BA36E#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:08.734 - info: radar2.0 (12924) Init item YYYY with {name: 'YYYY',bluetooth: [],enabled: -1,id: 'YYYY',type: 'IP',hasMAC: [ '9a:ce:10:0a:71:2e' ],ipVendor: 'N/A',rip: [ 'Y.X.C..114' ],lasthere: '2022-03-21T05:14:19.102Z'}
            2022-03-21 10:05:08.998 - error: cloud.0 (12957) Cloud says: timeout
            2022-03-21 10:05:09.496 - info: shelly.0 (12768) [CoAP] Device Y.X.C..38 (shellydimmer2 / shellydimmer2-D8BFC019EECE / SHDM-2#D8BFC019EECE#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:10.005 - info: cloud.0 (12957) Connection changed: io server disconnect
            2022-03-21 10:05:10.505 - info: shelly.0 (12768) [CoAP] Device Y.X.C..29 (shelly1pm / shelly1pm-F27119 / SHSW-PM#F27119#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:10.772 - info: info.0 (12961) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:05:11.032 - info: info.0 (12961) Reading/updating systemdata.
            2022-03-21 10:05:13.277 - info: shelly.0 (12768) [CoAP] Device Y.X.C..98 (shellyplug-s / shellyplug-s-E435C4 / SHPLG-S#E435C4#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:13.542 - info: shelly.0 (12768) [CoAP] Device Y.X.C..39 (shellyplug-s / shellyplug-s-B4B41F / SHPLG-S#B4B41F#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:14.158 - info: shelly.0 (12768) [CoAP] Device Y.X.C..24 (shellyplug-s / shellyplug-s-577BFA / SHPLG-S#577BFA#1) connected! Polltime set to 5 sec.
            2022-03-21 10:05:14.529 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
            2022-03-21 10:05:15.380 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
            2022-03-21 10:05:15.533 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
            2022-03-21 10:05:15.621 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
            2022-03-21 10:05:15.725 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
            2022-03-21 10:05:16.578 - info: info.0 (12961) cpu Temp res = {"main":75.471,"cores":[],"max":75.471,"socket":[],"chipset":null}
            2022-03-21 10:05:17.656 - info: info.0 (12961) State value to set for "info.0.sysinfo.memory.memLayout.ram0.ecc" has to be stringified but received type "boolean"
            2022-03-21 10:05:18.108 - info: radar2.0 (12924) Init item XXX with {name: 'XXX',bluetooth: [],enabled: -1,id: 'XXX',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2021-12-14T03:02:35.263Z'}
            2022-03-21 10:05:18.497 - info: radar2.0 (12924) Init item CCC with {name: 'CCC',bluetooth: [],enabled: -1,id: 'CCC',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2022-03-21T08:59:12.329Z'}
            2022-03-21 10:05:18.501 - info: radar2.0 (12924) Adapter identified macs: (IPV6),
            ips: (Y.X.C.V,Y.X.C.V,Y.X.C.V),
            bts LE: (),
            bts norm: ()
            2022-03-21 10:05:18.828 - info: radar2.0 (12924) radar2 found 3 devices in config (XXX,YYY,CCC) and 3 enabled.
            2022-03-21 10:05:18.830 - info: radar2.0 (12924) radar2 set use of noble(false), doArp("-lgq --retry=5 --timeout=400" on eth0), btid(-1) and doUwz(undefined,30,0,de,true).
            2022-03-21 10:05:31.945 - info: schoolfree.0 (12878) Terminated (NO_ERROR): Without reason
            2022-03-21 10:05:38.446 - error: cloud.0 (12957) Cloud says: timeout
            2022-03-21 10:06:08.453 - error: cloud.0 (12957) Cloud says: timeout
            2022-03-21 10:06:38.469 - error: cloud.0 (12957) Cloud says: timeout
            2022-03-21 10:06:41.946 - warn: schoolfree.0 (12878) get state error: Connection is closed.
            2022-03-21 10:06:41.948 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.949 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.950 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.951 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.952 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.953 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.954 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.955 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:41.956 - warn: schoolfree.0 (12878) get state error: DB closed
            2022-03-21 10:06:43.427 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:06:43.429 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:06:43.431 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:06:43.874 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13310
            2022-03-21 10:06:44.533 - info: host.raspberrypi instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
            2022-03-21 10:06:47.598 - info: radar2.0 (12924) first scan took 88.765 seconds
            2022-03-21 10:06:47.601 - warn: radar2.0 (12924) scanDelay increased to 90.765 seconds, delayAway to 4 minutes!
            2022-03-21 10:06:48.192 - info: weatherunderground.0 (13310) starting. Version 3.4.1 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:06:48.209 - info: radar2.0 (12924) Adapter initialization finished!
            2022-03-21 10:07:03.303 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:07:03.460 - info: cloud.0 (12957) Connection changed: connect
            2022-03-21 10:07:03.494 - info: cloud.0 (12957) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
            2022-03-21 10:07:05.559 - error: backitup.0 (12944) umount: /opt/iobroker/backups: not mounted.
            2022-03-21 10:10:20.992 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:10:20.994 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:10:20.995 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:27:49.612 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:27:49.615 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:27:49.616 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:29:04.597 - info: cloud.0 (12957) Trying to connect as system.user.admin
            2022-03-21 10:29:05.276 - info: cloud.0 (12957) Connection changed: connect
            2022-03-21 10:29:15.627 - error: info.0 (12961) States database error: read ECONNRESET
            2022-03-21 10:29:15.609 - error: alexa2.0 (12723) States database error: read ECONNRESET
            2022-03-21 10:29:15.625 - error: weatherunderground.0 (13310) States database error: read ECONNRESET
            2022-03-21 10:29:15.630 - error: discovery.0 (12937) States database error: read ECONNRESET
            2022-03-21 10:29:15.628 - error: shelly.1 (12777) States database error: read ECONNRESET
            2022-03-21 10:29:15.629 - error: text2command.0 (12966) States database error: read ECONNRESET
            2022-03-21 10:29:15.609 - error: zigbee.0 (12930) States database error: read ECONNRESET
            2022-03-21 10:29:15.632 - error: email.0 (12636) States database error: read ECONNRESET
            2022-03-21 10:29:15.640 - error: history.0 (12669) States database error: read ECONNRESET
            2022-03-21 10:29:15.624 - error: pushover.0 (12697) States database error: read ECONNRESET
            2022-03-21 10:29:15.631 - error: tr-064.0 (12889) States database error: read ECONNRESET
            2022-03-21 10:29:15.633 - error: cloud.0 (12957) States database error: read ECONNRESET
            2022-03-21 10:29:15.684 - error: alexa2.0 (12723) Objects database error: read ECONNRESET
            2022-03-21 10:29:15.684 - error: shelly.1 (12777) Objects database error: read ECONNRESET
            2022-03-21 10:29:15.633 - error: backitup.0 (12944) States database error: read ECONNRESET
            2022-03-21 10:29:15.693 - error: zigbee.0 (12930) Objects database error: read ECONNRESET
            2022-03-21 10:29:15.644 - error: radar2.0 (12924) States database error: write ECONNRESET
            2022-03-21 10:29:15.697 - error: weatherunderground.0 (13310) Objects database error: read ECONNRESET
            2022-03-21 10:29:15.634 - error: hue.0 (12760) States database error: read ECONNRESET
            2022-03-21 10:29:15.714 - error: cloud.0 (12957) Objects database error: read ECONNRESET
            2022-03-21 10:29:15.640 - error: iot.0 (12946) States database error: read ECONNRESET
            2022-03-21 10:29:15.913 - info: zigbee.0 (12930) cleaned everything up...
            2022-03-21 10:29:15.910 - info: info.0 (12961) cleaned everything up...
            2022-03-21 10:29:15.912 - info: backitup.0 (12944) cleaned everything up...
            2022-03-21 10:29:15.914 - info: shelly.1 (12777) Closing Adapter
            2022-03-21 10:29:15.923 - error: shelly.0 (12768) Objects database error: write ECONNRESET
            2022-03-21 10:29:15.942 - error: shelly.0 (12768) States database error: read ECONNRESET
            2022-03-21 10:29:15.957 - info: cloud.0 (12957) Connection changed: io client disconnect
            2022-03-21 10:29:15.958 - info: cloud.0 (12957) Connection lost
            2022-03-21 10:29:15.953 - info: shelly.0 (12768) Closing Adapter
            2022-03-21 10:29:16.073 - info: iot.0 (12946) Connection changed: disconnect
            2022-03-21 10:29:16.075 - info: iot.0 (12946) Connection lost
            2022-03-21 10:29:16.089 - info: radar2.0 (12924) Unload adapter now with null
            2022-03-21 10:29:16.091 - info: radar2.0 (12924) Adapter disconnected and stopped with dostop(null) and callback(true)
            2022-03-21 10:29:16.163 - info: zigbee.0 (12930) Zigbee: disabling joining new devices.
            2022-03-21 10:29:16.134 - error: admin.0 (12617) States database error: read ECONNRESET
            2022-03-21 10:29:16.269 - error: javascript.0 (12683) States database error: write ECONNRESET
            2022-03-21 10:29:16.274 - error: javascript.0 (12683) Objects database error: read ECONNRESET
            2022-03-21 10:29:16.280 - info: javascript.0 (12683) Stop script script.js.common.BatteryCheck
            2022-03-21 10:29:16.284 - info: javascript.0 (12683) Stop script script.js.common.BewegungsmelderV2
            2022-03-21 10:29:16.286 - info: javascript.0 (12683) Stop script script.js.common.CommonMix
            2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.FritzBox
            2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.LeavingHouse
            2022-03-21 10:29:16.288 - info: javascript.0 (12683) Stop script script.js.common.OpenDoorsWindows
            2022-03-21 10:29:16.290 - info: javascript.0 (12683) Stop script script.js.common.Shellys
            2022-03-21 10:29:16.230 - error: admin.0 (12617) Objects database error: read ECONNRESET
            2022-03-21 10:29:16.334 - info: admin.0 (12617) terminating http server on port 8081
            2022-03-21 10:29:16.928 - error: radar2.0 (12924) uncaught exception: Cannot read property 'init' of null
            2022-03-21 10:29:16.929 - error: radar2.0 (12924) TypeError: Cannot read property 'init' of null
            at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
            at listOnTimeout (internal/timers.js:557:17)
            at processTimers (internal/timers.js:500:7)
            2022-03-21 10:29:16.930 - error: radar2.0 (12924) Cannot read property 'init' of null
            2022-03-21 10:29:16.931 - warn: radar2.0 (12924) Uncaught Exception: Cannot read property 'init' of null
            2022-03-21 10:29:17.409 - info: email.0 (12636) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.412 - info: discovery.0 (12937) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.414 - info: weatherunderground.0 (13310) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.414 - info: pushover.0 (12697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.415 - info: text2command.0 (12966) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.418 - info: info.0 (12961) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.418 - info: zigbee.0 (12930) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.420 - info: backitup.0 (12944) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.423 - info: tr-064.0 (12889) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.423 - info: shelly.1 (12777) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.433 - info: iot.0 (12946) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.457 - info: shelly.0 (12768) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.462 - info: cloud.0 (12957) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.463 - info: alexa2.0 (12723) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.589 - info: radar2.0 (12924) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.780 - info: javascript.0 (12683) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:17.847 - info: admin.0 (12617) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:20.699 - error: shelly.1 (12777) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.702 - warn: info.0 (12961) get state error: DB closed
            2022-03-21 10:29:20.717 - error: discovery.0 (12937) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.724 - error: alexa2.0 (12723) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.751 - error: weatherunderground.0 (13310) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.753 - error: backitup.0 (12944) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.767 - error: zigbee.0 (12930) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.749 - warn: radar2.0 (12924) get state error: Connection is closed.
            2022-03-21 10:29:20.753 - error: hue.0 (12760) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.763 - error: cloud.0 (12957) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.775 - warn: tr-064.0 (12889) get state error: DB closed
            2022-03-21 10:29:20.797 - warn: email.0 (12636) get state error: DB closed
            2022-03-21 10:29:20.710 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.807 - warn: pushover.0 (12697) get state error: DB closed
            2022-03-21 10:29:20.816 - error: text2command.0 (12966) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.849 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2022-03-21 10:29:20.884 - warn: weatherunderground.0 (13310) get state error: DB closed
            2022-03-21 10:29:20.887 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.920 - error: iot.0 (12946) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.947 - error: shelly.0 (12768) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.992 - warn: shelly.0 (12768) get state error: Connection is closed.
            2022-03-21 10:29:20.798 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.845 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#C383EB#1.online, error - DB closed
            2022-03-21 10:29:20.846 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.847 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.961 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.962 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.982 - warn: shelly.1 (12777) redis get shelly.1.SHSW-1#98F4ABF3CF6C#1.hostname, error - DB closed
            2022-03-21 10:29:20.983 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#DE15FC#1.online, error - DB closed
            2022-03-21 10:29:20.984 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.985 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.986 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.987 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.988 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:20.989 - warn: shelly.1 (12777) get state error: DB closed
            2022-03-21 10:29:21.085 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27119#1.hostname, error - Connection is closed.
            2022-03-21 10:29:21.125 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27634#1.hostname, error - Connection is closed.
            2022-03-21 10:29:21.127 - warn: shelly.1 (12777) redis get shelly.1.shellyplus1#a8032abeb1e4#1.hostname, error - Connection is closed.
            2022-03-21 10:29:21.140 - warn: shelly.1 (12777) redis get shelly.1.undefined#undefined#1.hostname, error - Connection is closed.
            2022-03-21 10:29:21.151 - warn: shelly.1 (12777) setTimeout called, but adapter is shutting down
            2022-03-21 10:29:20.969 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:20.970 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:20.972 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:21.263 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:21.264 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:21.265 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:21.266 - warn: iot.0 (12946) get state error: DB closed
            2022-03-21 10:29:21.367 - error: javascript.0 (12683) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:21.417 - error: admin.0 (12617) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:20.993 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.687 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#DE15FC#1.online, error - DB closed
            2022-03-21 10:29:21.688 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.689 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.690 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.690 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#C383EB#1.online, error - DB closed
            2022-03-21 10:29:21.691 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.715 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.717 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#767AC8#1.hostname, error - DB closed
            2022-03-21 10:29:21.720 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.721 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.914 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:21.915 - warn: shelly.0 (12768) get state error: DB closed
            2022-03-21 10:29:22.093 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#98F4ABF3CF6C#1.hostname, error - Connection is closed.
            2022-03-21 10:29:22.115 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27119#1.hostname, error - Connection is closed.
            2022-03-21 10:29:22.117 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27634#1.hostname, error - Connection is closed.
            2022-03-21 10:29:22.119 - warn: shelly.0 (12768) setTimeout called, but adapter is shutting down
            2022-03-21 10:29:25.704 - error: shelly.1 (12777) Cannot find view "system" for search "device" : Connection is closed.
            2022-03-21 10:29:25.911 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:25.915 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2022-03-21 10:29:25.952 - error: shelly.0 (12768) Cannot find view "system" for search "device" : DB closed
            2022-03-21 10:29:27.034 - info: history.0 (12669) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2022-03-21 10:29:30.927 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2022-03-21 10:29:36.867 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
            2022-03-21 10:29:36.875 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-03-21 10:29:36.876 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
            2022-03-21 10:29:36.876 - info: host.raspberrypi ip addresses: Y.X.C.V IPV6
            2022-03-21 10:29:38.900 - info: host.raspberrypi connected to Objects and States
            2022-03-21 10:29:38.972 - info: host.raspberrypi added notifications configuration of host
            2022-03-21 10:29:39.802 - info: host.raspberrypi 32 instances found
            2022-03-21 10:29:39.863 - info: host.raspberrypi starting 21 instances
            2022-03-21 10:29:40.093 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13720
            2022-03-21 10:29:42.077 - error: admin.0 (13720) admin.0 already running
            2022-03-21 10:29:42.081 - warn: admin.0 (13720) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:29:42.717 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:29:42.718 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
            2022-03-21 10:29:43.901 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13731
            2022-03-21 10:29:45.441 - error: email.0 (13731) email.0 already running
            2022-03-21 10:29:45.445 - warn: email.0 (13731) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:29:46.064 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:29:46.065 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
            2022-03-21 10:29:48.020 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13743
            2022-03-21 10:29:49.579 - error: history.0 (13743) history.0 already running
            2022-03-21 10:29:49.583 - warn: history.0 (13743) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:29:50.203 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:29:50.205 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
            2022-03-21 10:29:51.992 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13755
            2022-03-21 10:29:55.495 - error: javascript.0 (13755) javascript.0 already running
            2022-03-21 10:29:55.499 - warn: javascript.0 (13755) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:29:55.983 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 13766
            2022-03-21 10:29:56.133 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:29:56.134 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
            2022-03-21 10:29:57.600 - error: pushover.0 (13766) pushover.0 already running
            2022-03-21 10:29:57.604 - warn: pushover.0 (13766) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:29:58.272 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:29:58.273 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
            2022-03-21 10:29:59.978 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 13777
            2022-03-21 10:30:01.640 - error: alexa2.0 (13777) alexa2.0 already running
            2022-03-21 10:30:01.644 - warn: alexa2.0 (13777) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:30:02.263 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:30:02.264 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
            2022-03-21 10:30:04.036 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 13788
            2022-03-21 10:30:05.962 - error: hue.0 (13788) hue.0 already running
            2022-03-21 10:30:06.590 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:30:06.590 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
            2022-03-21 10:30:08.001 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 13799
            2022-03-21 10:30:10.386 - error: shelly.0 (13799) shelly.0 already running
            2022-03-21 10:30:10.390 - warn: shelly.0 (13799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:30:11.012 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:30:11.012 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
            2022-03-21 10:30:11.987 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 13810
            2022-03-21 10:30:12.836 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13817
            2022-03-21 10:30:14.257 - error: shelly.1 (13810) shelly.1 already running
            2022-03-21 10:30:14.262 - warn: shelly.1 (13810) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:30:15.043 - error: host.raspberrypi instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:30:15.044 - info: host.raspberrypi Restart adapter system.adapter.shelly.1 because enabled
            2022-03-21 10:30:15.288 - info: admin.0 (13817) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:30:15.336 - info: admin.0 (13817) requesting all states
            2022-03-21 10:30:15.337 - info: admin.0 (13817) requesting all objects
            2022-03-21 10:30:16.895 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13836
            2022-03-21 10:30:16.978 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 13843
            2022-03-21 10:30:17.468 - info: admin.0 (13817) received all objects
            2022-03-21 10:30:18.021 - info: admin.0 (13817) Request actual repository...
            2022-03-21 10:30:18.051 - info: admin.0 (13817) http server listening on port 8081
            2022-03-21 10:30:18.053 - info: admin.0 (13817) Use link "http://localhost:8081" to configure.
            2022-03-21 10:30:18.927 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
            2022-03-21 10:30:19.880 - error: tr-064.0 (13843) tr-064.0 already running
            2022-03-21 10:30:19.884 - warn: tr-064.0 (13843) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:30:20.369 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
            2022-03-21 10:30:20.399 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13858
            2022-03-21 10:30:23.820 - info: admin.0 (13817) Repository received successfully.
            2022-03-21 10:30:24.716 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:30:24.717 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2022-03-21 10:30:24.752 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13869
            2022-03-21 10:30:24.849 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 13875
            2022-03-21 10:30:24.969 - error: weatherunderground.0 (13858) weatherunderground.0 already running
            2022-03-21 10:30:24.974 - warn: weatherunderground.0 (13858) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2022-03-21 10:30:25.084 - info: email.0 (13836) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
            2022-03-21 10:30:25.651 - error: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2022-03-21 10:30:26.272 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13891
            crunchipC Offline
            crunchipC Offline
            @th3rockyeah sagte in js-controller 4.0 jetzt im BETA/LATEST!:
            non-npm
            @apollon77 kann es sein das da mit npm etwas nicht passt?
              non-npm
              @crunchip Ne das sind GitHub installs ... aber habs nur für email und weatherunderground gesehen, da sollte es eher irrelevant sein ... Javascript 5.4 wäre eher ein Kandidat weil der Ordner anlegt, aber bei den 5 Skripten sollte das fast egal sein
              Denke man muss jetzt mal strukturiert rangehen weil ausser dem controller nichts irklich auffällig ist
              • apollon77A apollon77
                • Stoppe iobroker
                Th3RockYeah
                @apollon77
                Ok, mach ich. ich starte nach und nach die Adapter und schaue, ob etwas auffällig ist.
                Den MQTT Adapter nutze ich nicht, nur Shelly.
                Nun hat sich der JS-Controller beruhigt und ich kann den IOBroker wieder normal nutzen. Das hier waren die letzten Fehler im Log:
                	Zeit
                warn
                Nachricht
                zigbee.0
                2022-03-21 11:49:59.635	warn	DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
                zigbee.0
                2022-03-21 11:45:23.370	warn	State value to set for "zigbee.0.00158d00042176ed.pressure" has value "95992" greater than max "10000"
                radar2.0
                2022-03-21 11:34:11.290	warn	State "radar2.0._uIPs.SonosZP_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                radar2.0
                2022-03-21 11:34:11.273	warn	State "radar2.0._uIPs.SonosZP_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                radar2.0
                2022-03-21 11:34:11.119	warn	State "radar2.0._uIPs.shellyplug-s-DE15FC_xxx-xxx--xxx-xx" has no existing object, this might lead to an error in future versions
                radar2.0
                2022-03-21 11:34:11.040	warn	State "radar2.0._uIPs.shellyplug-s-DE15FC_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                radar2.0
                2022-03-21 11:34:10.070	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                radar2.0
                2022-03-21 11:34:10.034	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                radar2.0
                2022-03-21 11:34:10.032	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
                zigbee.0
                2022-03-21 11:25:12.257	warn	DeviceAvailability:Stopping to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater after 4 ping attempts
                zigbee.0
                2022-03-21 11:19:39.577	warn	State value to set for "zigbee.0.00158d000464c66d.pressure" has value "96079" greater than max "10000"
                radar2.0
                2022-03-21 11:12:30.875	warn	scanDelay increased to 71.119 seconds, delayAway to 2 minutes!
                host.raspberrypi
                2022-03-21 11:07:54.826	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                radar2.0
                2022-03-21 11:07:54.333	warn	Error {} is setState for _uIPs with {"val":"[]","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                radar2.0
                2022-03-21 11:07:54.330	warn	get state error: Connection is closed.
                radar2.0
                2022-03-21 11:07:54.329	warn	Could not perform strict object check of state radar2.0._uIPs: DB closed
                radar2.0
                2022-03-21 11:07:53.861	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.860	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.859	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
                radar2.0
                2022-03-21 11:07:53.858	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.854	warn	redis get radar2.0._uIPs.192-168-170-210, error - Connection is closed.
                radar2.0
                2022-03-21 11:07:53.853	warn	Error {} is setState for radar2.0._uIPs.xxx-xxx-xxx-xxx with {"val":"{ ipAddress: 'xxx.xxx.xxxx.xxxx', macAddress: '8:33:4d:ca', by: 'arp', hosts: [], getMacVendor: 'N/A'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                radar2.0
                2022-03-21 11:07:53.852	warn	get state error: Connection is closed.
                radar2.0
                2022-03-21 11:07:53.851	warn	Error {} is setState for info.connection with {"val":false,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                radar2.0
                2022-03-21 11:07:53.850	warn	get state error: Connection is closed.
                radar2.0
                2022-03-21 11:07:53.652	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.651	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.650	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
                radar2.0
                2022-03-21 11:07:53.650	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.649	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.647	warn	redis get radar2.0._uIPs.xxx-xxx-xxx-xxx, error - Connection is closed.
                radar2.0
                2022-03-21 11:07:53.646	warn	Error {} is setState for _uIPs.xxx-xxx-xxx-xxx with {"val":"{ ipAddress: 'xxx.xxx.xxx.xxx', macAddress: '33:4d:ca', by: 'arp', hosts: [], getMacVendor: 'N/A'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                radar2.0
                2022-03-21 11:07:53.645	warn	get state error: Connection is closed.
                radar2.0
                2022-03-21 11:07:53.332	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.331	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.331	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
                radar2.0
                2022-03-21 11:07:53.330	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.329	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.320	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.320	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.319	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                radar2.0
                2022-03-21 11:07:53.319	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.318	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.316	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.315	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.315	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                radar2.0
                2022-03-21 11:07:53.314	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.313	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.311	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.289	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.288	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                radar2.0
                2022-03-21 11:07:53.287	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.286	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.283	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.281	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.279	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                radar2.0
                2022-03-21 11:07:53.278	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.277	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.275	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.275	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.274	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                radar2.0
                2022-03-21 11:07:53.273	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.272	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.270	warn	Unhandled rejection at
                radar2.0
                2022-03-21 11:07:53.269	error	Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.268	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
                radar2.0
                2022-03-21 11:07:53.268	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
                radar2.0
                2022-03-21 11:07:53.267	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                radar2.0
                2022-03-21 11:07:53.264	warn	redis get radar2.0._uIPs.XXX-XXX-XXX-XXX, error - Connection is closed.
                Nur damit ich es gefragt habe, weil es mich nicht "loslässt". Kann die SD-Card kaputt sein?
                • T Th3RockYeah
                  @apollon77
                  	Zeit
                  warn
                  Nachricht
                  zigbee.0
                  zigbee.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  zigbee.0
                  zigbee.0
                  radar2.0
                  host.raspberrypi
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  radar2.0
                  Möglich. Die eine Karte, die mir mal verreckt ist hat sich in den Logfiles sang- und klanglos verabschiedet.
                  Schau mal mit
                  dmesg -T | grep -i ext4
                  danach.
                    Schau mal mit
                    danach.
                    Th3RockYeah
                    Das kommt als Antwort. Was bedeutet das?
                    [Mo Mär 21 10:52:17 2022]  ext4_filemap_fault+0x3c/0x818
                    • T Th3RockYeah
                      @th3rockyeah
                      Nur die eine Zeile?
                      Da muss mehr kommen.
                      Aber ext4_filemap_fault ist schon mal schlecht, das sollte nicht kommen.
                        @th3rockyeah
                        Nur die eine Zeile?
                        Th3RockYeah
                        Ja nur die eine Zeile:
                        • T Th3RockYeah
                          @th3rockyeah
                          Dann würde ich sagen, die Karte/das Dateisystem ist fehlerhaft.
                            @th3rockyeah
                            Th3RockYeah
                            @thomas-braun Ok, dann setze ich hier einmal ebenfalls an.
                            Was müsste denn dort normalerweise stehen, wenn die SD-Card OK wäre?
                            • T Th3RockYeah
                              @th3rockyeah
                              Da tauchen dann 4 Zeilen auf.
                              Ich komme gerade an mein System nicht ran, sonst hätte ich es gezeigt.
                              Aus deinem obigen Log:
                              ping invoked oom-killer: gfp_mask=0x400dc0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), order=0, oom_score_adj=0
                              gfp_mask ist auch nah am System/RAM/Dateisystem. Ich würde sagen, das Ding schwimmt schon nicht mehr, das ist abgesoffen.
                                @th3rockyeah
                                Th3RockYeah
                                schrieb am zuletzt editiert von Th3RockYeah
                                @thomas-braun ok, danke dir! Ich habe jetzt auch mehrere Zeilen bei dem Aufruf in der Console.
                                Ich habe nun den IoBroker auf einem USB Stick neu aufgesetzt und aktuell läuft er total smooth. Ich beobachte es noch eine Weile, aber nach einem Iobroker restart ist das Verhalten normal, der js-controller läuft ohne starke CPU oder Memory last.
                                Es scheint die SD-Card gewesen zu sein #fingercrossed.
                                @apollon77 , @thomas-braun, @Diginix , @crunchip: DANKE für euren Support!!! Kudos to you all! :-)
                                Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                • T Th3RockYeah
                                  Welche?
                                    Welche?
                                    Th3RockYeah
                                    diese hier:
                                    pi@raspberrypiNew:~ $ dmesg -T | grep -i ext4
                                    [Mon Mar 21 15:27:04 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:4F:DD:06 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=dc01fa95-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Mon Mar 21 15:27:07 2022] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                    [Mon Mar 21 15:27:07 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                    [Mon Mar 21 15:27:08 2022] EXT4-fs (sda2): re-mounted. Opts: (null)
                                    • T Th3RockYeah
                                      diese hier:
                                      @th3rockyeah
                                      Ja, so muss das aussehen.
                                        @th3rockyeah
                                        Th3RockYeah
                                        @thomas-braun Yihaa! Danke :-)
                                        • T Th3RockYeah
                                          @th3rockyeah Interessant ...
