  4. [gelöst] Probleme bei Update von admin
    apollon77A
  • NEWS Räume und Funktionen in einem Durchlauf: der Assistent in Admin 8 (mit Video)
admin-adapterehostunreachfehlermeldungupdateupdate adapter
85 Beiträge 6 Kommentatoren 14.6k Aufrufe 3 Beobachtet
  • M Markus Faltermeier
    das ist die Ausgabe:
    pi@raspberrypi:/opt/iobroker $ iobroker update -u
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
    Adapter    "backitup"      : 2.3.3    , installed 2.2.3 [Updateable]
    Adapter    "discovery"     : 2.7.5    , installed 2.7.3 [Updateable]
    Adapter    "hue"           : 3.6.5    , installed 3.5.31 [Updateable]
    Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
    Adapter    "mihome-vacuum" : 3.3.1    , installed 1.1.5 [Updateable]
    Adapter    "shelly"        : 5.3.2    , installed 4.0.7 [Updateable]
    Thomas BraunT
    Thomas BraunT
    #61
    @markus-faltermeier
    Okay, und
    iobroker upgrade
    macht nun?
      @markus-faltermeier
      Okay, und
      iobroker upgrade
      macht nun?
      M
      M
      Markus Faltermeier
      #62
      bekam folgende Ausgabe:
      update done
      pi@raspberrypi:/opt/iobroker $ ^C
      pi@raspberrypi:/opt/iobroker $ iobroker upgrade
      This upgrade of "hue" will introduce the following changes:
      -> 3.6.5:
      correctly identify third party switches (closes #273)
      -> 3.6.3:
      added `info.connection` state (closes #268)
      -> 3.6.2:
      -> 3.6.1:
      ct values of groups can be even lower due to third party lights
      -> 3.6.0:
      allow to trigger scenes via `command` state, this allows to start a scene with `transitiontime`
      Would you like to upgrade hue from @3.5.31 to @3.6.5 now? [(y)es, (n)o]: y
      Update hue from @3.5.31 to @3.6.5
      NPM version: 6.14.16
      npm install iobroker.hue@3.6.5 --loglevel error --prefix "/opt/iobroker" (System call)
      Traceback (most recent call last):
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
          import gyp
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
          import gyp.input
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
          import ast
      ImportError: No module named ast
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
      gyp ERR! System Linux 5.10.103-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      gyp ERR! node -v v14.19.0
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
      gyp ERR! not ok
      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
          import gyp
          import gyp.input
          import ast
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
      node-pre-gyp ERR! System Linux 5.10.103-v7l+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v14.19.0
      node-pre-gyp ERR! node-pre-gyp -v v1.0.8
      node-pre-gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! cwd /opt/iobroker/node_modules/sharp
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the @serialport/bindings@9.2.8 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_53_08_366Z-debug.log
      upload [14] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
      Update "system.adapter.hue.0"
      upload [13] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
      upload [12] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
      upload [11] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
      upload [10] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
      Adapter "hue" updated
      This upgrade of "discovery" will introduce the following changes:
      -> 2.7.5:
      Fix kecontact detection (Sentry IOBROKER-DISCOVERY-3P)
      -> 2.7.4:
      Replaced flot with eCharts
      info Adapter removed
      Would you like to upgrade discovery from @2.7.3 to @2.7.5 now? [(y)es, (n)o]: y
      Update discovery from @2.7.3 to @2.7.5
      npm install iobroker.discovery@2.7.5 --loglevel error --prefix "/opt/iobroker" (System call)
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_54_11_360Z-debug.log
      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      Adapter "discovery" updated
      This upgrade of "admin" will introduce the following changes:
      -> 5.3.1:
      Support of IPv6 address by links (vis, material, end so on)
      Corrected errors in the base settings
      Corrected error with the pre-selected language in wizard
      -> 5.3.0:
      Enable http compression in webserver
      Removed deprecated package "request"
      Added JSONL option for base settings
      Added small improvements
      Added the file viewer for binary states
      Would you like to upgrade admin from @5.2.3 to @5.3.1 now? [(y)es, (n)o]: y
      Update admin from @5.2.3 to @5.3.1
      host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
      npm install iobroker.admin@5.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_55_22_755Z-debug.log
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      Adapter "admin" updated
      host.raspberrypi Adapter "system.adapter.admin.0" is started
      This upgrade of "shelly" will at least introduce the following changes:
      -> 5.3.2:
      Added cover position status for generation 2 devices
      Added cover power, voltage, current and energy for generation 2 devices
      Updated switch roles for material ui (switch.power to switch)
      -> 5.3.1:
      Don't ack new values directly after change
      -> 5.3.0:
      Added Shelly Plus I4
      Added more objects for power metering channels (current, voltage, limits, ...)
      Moved device temperature of generation 2 devices to relays (this is the official way)
      Added Sys channel (eco mode, timezone, ...) for generation 1 devices
      Fixed datatype error of Shelly 1/PM ext switch
      Added option to enable/disable WiFi access point (generation 2 devices)
      Added power limits and position control for covers (generation 2 devices)
      Removed colors for online state indication on device objects
      -> 5.2.0:
      Added Shelly Pro 1
      Added Shelly Pro 1 PM
      Added Shelly Pro 2
      Added Shelly Pro 2 PM
      Added Shelly Plus 2 PM
      Allow to change device and channel names of generation 2 devices
      Added auto on/off timers for generation 2 devices
      Added input mode, events and initial state for generation 2 devices
      Added support of covers / shutters for generation 2 devices
      Replaced node-fetch with axios (also for digest auth)
      -> 5.1.3:
      Changed common.states strings to objects
      Just perform firmware update if an available update was detected
      Extended logging for CoAP
      -> 5.1.2:
      Fixed Shelly UNI ADC voltage
      Fixed dimmer brightness values handling
      Logging improvements for offline devices
      -> 5.1.1:
      Fixed firmware auto update
      Updated timeouts
      Added command source for shelly 2.5
      Added color for device objects as online indicator
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade shelly from @4.0.7 to @5.3.2 now? [(y)es, (n)o]: y
      Update shelly from @4.0.7 to @5.3.2
      npm install iobroker.shelly@5.3.2 --loglevel error --prefix "/opt/iobroker" (System call)
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_56_39_294Z-debug.log
      upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
      Adapter "shelly" updated
      This upgrade of "mihome-vacuum" will at least introduce the following changes:
      -> 3.3.1:
      fix IOBROKER-MIHOME-VACUUM-Z
      fix some errors
      -> 3.3.0:
      fix no rooms for S5
      fix IOBROKER-MIHOME-VACUUM-4 DB closed
      fix connection error
      -> 3.2.2:
      the communication is corrected
      Added roles to be detected by type-detector
      -> 3.2.1:
      Adjust several crash cases (IOBROKER-MIHOME-VACUUM-K, IOBROKER-MIHOME-VACUUM-J, IOBROKER-MIHOME-VACUUM-F, IOBROKER-MIHOME-VACUUM-7, IOBROKER-MIHOME-VACUUM-A, IOBROKER-MIHOME-VACUUM-4, IOBROKER-MIHOME-VACUUM-G, IOBROKER-MIHOME-VACUUM-C, IOBROKER-MIHOME-VACUUM-B, IOBROKER-MIHOME-VACUUM-Q, IOBROKER-MIHOME-VACUUM-M)
      -> 3.2.0:
      fixed error
      -> 3.1.7:
      added Sentry, minimize messages, fix disk I/O
      -> 3.1.5:
      Breaking changes, Map format changed, added wifi state, added multimap support, added mopstate, fixed objects, show zones and points when selectiong in app, minmize disk I/O, minimize Messages clear and extend log,
      Would you like to upgrade mihome-vacuum from @1.1.5 to @3.3.1 now? [(y)es, (n)o]: y
      Update mihome-vacuum from @1.1.5 to @3.3.1
      npm install iobroker.mihome-vacuum@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_57_43_910Z-debug.log
      upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
      Update "system.adapter.mihome-vacuum.0"
      upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
      upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
      upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
      upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
      upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
      upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
      upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
      upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
      upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
      upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
      Adapter "mihome-vacuum" updated
      This upgrade of "backitup" will introduce the following changes:
      -> 2.3.3:
      small GUI fixes
      Docker restore tunning
      -> 2.3.2:
      Bugfix Restore Interface for http
      Fix json history
      -> 2.3.1:
      Bugfix Grafana
      Bugfix Restore for Docker System
      Restore Interface with https Support
      use iobroker SSL Certificates for https
      -> 2.3.0:
      Influxdb2 Backup added
      Influxdb2 Restore added
      Bugfix Grafana Backup
      Bugfix GUI
      Bugfix Redis Restore
      New Restore WebIf added
      dependencies updated
      Bugfix start after Restore
      redis remote Backup added
      Error messages configurable
      Translations added
      Adjustments to js-controller 4
      -> 2.2.4:
      Restore backup of different controller version added
      Fix YAHKA Backup for more Instances
      Would you like to upgrade backitup from @2.2.3 to @2.3.3 now? [(y)es, (n)o]: y
      Update backitup from @2.2.3 to @2.3.3
      npm install iobroker.backitup@2.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
          import gyp
          import gyp.input
          import ast
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_59_12_369Z-debug.log
      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      Adapter "backitup" updated
        update done
        -> 3.6.5:
        -> 3.6.3:
        -> 3.6.2:
        -> 3.6.1:
        -> 3.6.0:
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        -> 2.7.5:
        -> 2.7.4:
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        -> 5.3.1:
        -> 5.3.0:
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        -> 5.3.2:
        -> 5.3.1:
        -> 5.3.0:
        -> 5.2.0:
        Added Shelly Pro 1
        Added Shelly Pro 2
        -> 5.1.3:
        -> 5.1.2:
        -> 5.1.1:
        Updated timeouts
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        -> 3.3.1:
        fix some errors
        -> 3.3.0:
        fix no rooms for S5
        -> 3.2.2:
        -> 3.2.1:
        -> 3.2.0:
        fixed error
        -> 3.1.7:
        -> 3.1.5:
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        -> 2.3.3:
        small GUI fixes
        -> 2.3.2:
        Fix json history
        -> 2.3.1:
        Bugfix Grafana
        -> 2.3.0:
        Bugfix GUI
        Translations added
        -> 2.2.4:
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
            import gyp
            import gyp.input
            import ast
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        Thomas BraunT
        Thomas BraunT
        #63
        @markus-faltermeier
        iobroker stop
        iobroker fix
        iobroker start
          @markus-faltermeier
          iobroker stop
          iobroker fix
          iobroker start
          M
          M
          Markus Faltermeier
          #64
          das lief jetzt zumindest mal ohne Fehler durch
          pi@raspberrypi:/opt/iobroker $ iobroker fix
          library: loaded
          Library version=2022-02-10
              Welcome to the ioBroker installation fixer!
              Script version: 2022-02-13
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
          Installed gcc-c++
          Installed python-dev
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            Thomas BraunT
            Thomas BraunT
            #65
            @markus-faltermeier
            Editiere /opt/iobroker/node_modules/canvas/package.json:
            Suche nach der "scripts" sektion und dort "install"
            Das install kommando ist
            node-pre-gyp install --fallback-to-build
            hänge mal noch
            --update-binary
            dran.
            Also
            node-pre-gyp install --fallback-to-build --update-binary
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              Thomas BraunT
              Thomas BraunT
              #66
              @markus-faltermeier
              Ist der terminal-Adapter jetzt auch deinstalliert?
                @markus-faltermeier
                M
                M
                Markus Faltermeier
                #67
                ich kann den nicht löschen. da bekomme ich die gleichen Fehlermeldungen wie beim updaten:
                $ iobroker del terminal
                Delete adapter "terminal"
                host.raspberrypi object terminal deleted
                host.raspberrypi object terminal.admin deleted
                npm uninstall iobroker.terminal --loglevel error --prefix "/opt/iobroker" (System call)
                npm ERR! code ENOENTnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-streamnpm ERR! errno -2
                npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-stream'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T13_22_31_721Z-debug.log
                Error deleting adapter terminal from disk: Error: host.raspberrypi: Cannot uninstall iobroker.terminal: 254
                You might have to delete it yourself!
                Process exited with code 0
                  #68
                  @markus-faltermeier sagte in Probleme bei Update von admin:
                  dann mach das
                    @markus-faltermeier
                    hänge mal noch
                    --update-binary
                    dran.
                    Also
                    M
                    M
                    Markus Faltermeier
                    #69
                    Hi ich habe jetzt alles durchsucht. Aber ich habe kein Verzeichnis "Canvas"
                    pi@raspberrypi:/opt/iobroker/node_modules $ ls
                    abab                        har-schema                             object-hash
                    abort-controller            har-validator                          object-inspect
                    accepts                     has                                    object-keys
                    acme-http-01-standalone     has-bigints                            once
                    acorn                       has-binary                             one-time
                    acorn-globals               has-binary2                            on-finished
                    acorn-walk                  has-cors                               on-headers
                    after                       has-symbols                            optionator
                    agent-base                  has-tostringtag                        options
                    ajv                         has-unicode                            ordered-read-streams
                    @alcalzone                  hawk                                   os-locale
                    alcalzone-shared            he                                     ospath
                    alexa-cookie2               help-me                                otplib
                    alexa-remote2               hoek                                   owlintuition
                    ansi-regex                  homematic-xmlrpc                       pako
                    ansi-styles                 hosted-git-info                        parse5
                    anymatch                    hot-patcher                            parse-json
                    @apollon                    html-encoding-sniffer                  parsejson
                    aproba                      http-errors                            parseqs
                    are-we-there-yet            http-proxy                             parseuri
                    argparse                    http-proxy-agent                       parseurl
                    arraybuffer.slice           http-proxy-middleware                  parsexmlresponse
                    array-ext                   http-proxy-response-rewrite            passport
                    array-flatten               https                                  passport-local
                    array.prototype.findindex   http-signature                         passport.socketio
                    arrify                      https-proxy-agent                      passport-strategy
                    asap                        iconv-lite                             path-dirname
                    asn1                        ieee754                                path-exists
                    asn1-ber                    immediate                              path-is-absolute
                    assert-plus                 indexof                                path-parse
                    async                       inflight                               path-posix
                    asynckit                    inherits                               path-to-regexp
                    async-limiter               ini                                    path-type
                    async-retry                 internal-slot                          pause
                    at-least-node               invert-kv                              pause-stream
                    autobind-decorator          @iobroker                              performance-now
                    aws4                        iobroker                               picocolors
                    aws-iot-device-sdk          iobroker.admin                         picomatch
                    aws-sign2                   iobroker.alexa2                        pidusage
                    axios                       iobroker.backitup                      pify
                    backo2                      iobroker.cloud                         ping
                    balanced-match              iobroker.daswetter                     pinkie
                    base-64                     iobroker.deconz                        pinkie-promise
                    base64-arraybuffer          iobroker.denon                         pluralize
                    base64id                    iobroker.discovery                     p-map
                    base64-js                   iobroker.dwd                           portfinder
                    bcrypt-pbkdf                iobroker.email                         prelude-ls
                    bent                        iobroker.fhem                          process-nextick-args
                    better-assert               iobroker.flot                          promise
                    bignumber.js                iobroker.fritzbox                      promisify-child-process
                    binary                      iobroker.geofency                      prompt
                    binary-extensions           iobroker.harmony                       proper-lockfile
                    bindings                    iobroker.heatingcontrol                proxy-addr
                    binrpc                      iobroker.history                       psl
                    bl                          iobroker.hm-rega                       pump
                    blob                        iobroker.hm-rpc                        pumpify
                    bluebird                    iobroker.hue                           punycode
                    body-parser                 iobroker.ical                          pushover-notifications
                    boom                        iobroker.icons-icons8                  put
                    bottleneck                  iobroker.icons-mfd-svg                 q
                    brace-expansion             iobroker.icons-ultimate-png            qs
                    braces                      iobroker.info                          querystring
                    browser-process-hrtime      iobroker.iot                           querystringify
                    buffer                      iobroker.javascript                    random-bytes
                    buffer-equal-constant-time  iobroker.js-controller                 range-parser
                    buffer-from                 iobroker.lightify                      rasha
                    bufferhelper                iobroker.mihome                        raw-body
                    buffers                     iobroker.mihome-vacuum                 rc
                    busboy                      iobroker.mobile                        read
                    button-events               iobroker.mqtt                          readable-stream
                    bytes                       iobroker.mqtt-client                   readdirp
                    bytesish                    iobroker.nut                           readline-sync
                    callback-stream             iobroker.octoprint                     read-pkg
                    call-bind                   iobroker.ping                          read-pkg-up
                    callsite                    iobroker.pushover                      redirect-https
                    camelcase                   iobroker.rpi2                          redis-commands
                    capitalize                  iobroker.scenes                        redis-errors
                    caseless                    iobroker.shelly                        redis-parser
                    cert-info                   iobroker.simple-api                    reinterval
                    chainsaw                    iobroker.snmp                          remove-trailing-separator
                    charenc                     iobroker.socketio                      request
                    chokidar                    iobroker.sonoff                        request-promise
                    chownr                      iobroker.spotify-premium               request-promise-core
                    ci-info                     iobroker.statistics                    request-promise-native
                    cli                         iobroker.synology                      require-directory
                    cliff                       iobroker.tankerkoenig                  require-main-filename
                    cliui                       iobroker.telegram                      requires-port
                    cloneextend                 iobroker.terminal                      resolve
                    cluster-key-slot            iobroker.text2command                  respjs
                    co                          iobroker.tr-064                        retry
                    coap                        iobroker.type-detector                 revalidator
                    coap-packet                 iobroker.upnp                          rfdc
                    code-point-at               iobroker.vis                           @root
                    coffee-compiler             iobroker.vis-bars                      rpi-gpio
                    coffee-script               iobroker.vis-colorpicker               rpi-gpio-buttons
                    coiot-coap                  iobroker.vis-fancyswitch               rrule
                    color                       iobroker.vis-google-fonts              safe-buffer
                    color-convert               iobroker.vis-hqwidgets                 safer-buffer
                    color-name                  iobroker.vis-jqui-mfd                  safe-replace
                    @colors                     iobroker.vis-metro                     safe-stable-stringify
                    colors                      iobroker.vis-players                   sax
                    colorspace                  iobroker.vis-plumb                     saxes
                    color-string                iobroker.vis-timeandweather            secure-keys
                    combined-stream             iobroker.vis-weather                   semaphore
                    commander                   iobroker.web                           semver
                    commist                     ioredis                                send
                    component-bind              ip                                     @sentry
                    component-emitter           ipaddr.js                              seq-logging
                    component-inherit           is                                     @serialport
                    concat-map                  is-absolute                            serialport
                    concat-stream               isarray                                serve-static
                    connect                     is-arrayish                            set-blocking
                    connect-flash               is-bigint                              set-immediate-shim
                    console-control-strings     is-binary-path                         setprototypeof
                    content-disposition         is-boolean-object                      shelly-iot
                    content-type                is-callable                            side-channel
                    cookie                      is-date-object                         signal-exit
                    cookie-parser               isemail                                simple-concat
                    cookie-signature            is-extglob                             simple-get
                    core-util-is                is-fullwidth-code-point                simple-swizzle
                    cron                        is-glob                                sntp
                    cron-parser                 is-nan                                 socket.io
                    crypt                       is-negated-glob                        socket.io-adapter
                    cryptiles                   is-negative-zero                       socket.io-client
                    crypto-js                   is-number                              socket.io-parser
                    cssom                       is-number-object                       socksv5
                    cssstyle                    is-plain-obj                           soef
                    cycle                       is-potential-custom-element-name       sorted-array-functions
                    d                           is-regex                               source-map
                    @dabh                       is-relative                            source-map-support
                    daemonize2                  is-shared-array-buffer                 spdx-correct
                    dashdash                    is-stream                              spdx-exceptions
                    data-urls                   isstream                               spdx-expression-parse
                    debug                       is-string                              spdx-license-ids
                    decache                     is-symbol                              split
                    decamelize                  is-typedarray                          split2
                    decimal.js                  is-unc-path                            sprintf-js
                    decompress-response         is-utf8                                sshpk
                    deep-clone                  is-weakref                             stack-trace
                    deep-extend                 is-windows                             standard-as-callback
                    deep-is                     joi                                    statuses
                    define-properties           jsbn                                   stealthy-require
                    delayed-stream              jsdom                                  stream-combiner
                    delegates                   jshashes                               streamsearch
                    denque                      json3                                  stream-shift
                    depd                        jsonata                                string_decoder
                    destroy                     json-bigint                            string.prototype.trimend
                    detect-libc                 jsonc-parser                           string.prototype.trimstart
                    dgram                       jsonfile                               stringstream
                    dicer                       json-schema                            string-width
                    diskusage                   json-schema-traverse                   strip-ansi
                    dns-packet                  json-stable-stringify-without-jsonify  strip-bom
                    domexception                json-stringify-safe                    strip-json-comments
                    dropbox-v2-api              jsonwebtoken                           strnum
                    duplexer                    jsprim                                 suncalc2
                    duplexify                   js-sdsl                                symbol-tree
                    ecc-jsbn                    js-yaml                                sync-exec
                    ecdsa-sig-formatter         jszip                                  syno
                    echarts                     jwa                                    systeminformation
                    eckles                      jws                                    tar
                    ee-first                    keypairs                               tar-fs
                    emoji-regex                 kuler                                  tar-stream
                    enabled                     layerr                                 tcp-ping
                    encodeurl                   lcid                                   text-hex
                    end-of-stream               le-acme-core                           thirty-two
                    engine.io                   le-challenge-fs                        through
                    engine.io-client            le-sni-auto                            through2
                    engine.io-parser            leven                                  through2-filter
                    epoll                       levn                                   to-absolute-glob
                    error-ex                    lie                                    to-array
                    es5-ext                     loadavg-windows                        toidentifier
                    es6-iterator                load-json-file                         @tootallnate
                    es6-map                     localforage                            topo
                    es6-promise                 lodash                                 to-regex-range
                    es6-set                     lodash.defaults                        tough-cookie
                    es6-symbol                  lodash.flatten                         tr46
                    es-abstract                 lodash.includes                        traverse
                    esbuild                     lodash.isarguments                     triple-beam
                    escalade                    lodash.isboolean                       tslib
                    escape-html                 lodash.isinteger                       tunnel-agent
                    escodegen                   lodash.isnumber                        tweetnacl
                    esprima                     lodash.isplainobject                   type
                    es-to-primitive             lodash.isstring                        type-check
                    estraverse                  lodash.once                            typedarray
                    esutils                     logform                                type-is
                    etag                        long-timeout                           @types
                    event-emitter               lru-cache                              typescript
                    eventemitter3               lru_map                                uid-number
                    event-stream                luxon                                  uid-safe
                    event-target-shim           map-stream                             ultron
                    expand-template             md5                                    unbox-primitive
                    express                     mdns-discovery                         unc-path-regex
                    express-fileupload          media-typer                            underscore
                    express-session             merge-descriptors                      unique-stream
                    ext                         methods                                universalify
                    extend                      micromatch                             unpipe
                    extsprintf                  mime                                   uri-js
                    eyes                        mime-db                                url-join
                    fast-deep-equal             mime-types                             url-parse
                    fast-json-stable-stringify  mimic-response                         url-template
                    fast-levenshtein            minimatch                              ursa-optional
                    fastseries                  minimist                               util-deprecate
                    fast-text-encoding          minipass                               utils-merge
                    fast-xml-parser             minizlib                               uuid
                    fecha                       mkdirp                                 validate-npm-package-license
                    file-stream-rotator         mkdirp-classic                         vary
                    file-type                   moment                                 verror
                    file-uri-to-path            moment-timezone                        virtual-tsc
                    fill-range                  mqtt                                   vm2
                    finalhandler                mqtt-connection                        w3c-hr-time
                    find-up                     mqtt-packet                            w3c-xmlserializer
                    fn.name                     ms                                     wake_on_lan
                    follow-redirects            mute-stream                            weak-daemon
                    forever-agent               nan                                    webdav
                    form-data                   napi-build-utils                       webidl-conversions
                    forwarded                   nconf                                  websocket-stream
                    fresh                       ncp                                    whatwg-encoding
                    from                        nearest-color                          whatwg-mimetype
                    fs-constants                negotiator                             whatwg-url
                    fs-extra                    nested-property                        which-boxed-primitive
                    fs-minipass                 netmask                                which-module
                    fs.realpath                 net-snmp                               wide-align
                    ftp                         next-tick                              window-size
                    function-bind               node-dht-sensor                        winston
                    gauge                       node-expat                             winston-daily-rotate-file
                    gaxios                      node.extend                            winston-seq-updated
                    gcp-metadata                node-fetch                             winston-syslog
                    get-caller-file             node-forge                             winston-transport
                    get-intrinsic               node-hue-api                           word-wrap
                    getpass                     node-ical                              wrap-ansi
                    get-ssl-certificate         node-inspect                           wrappy
                    get-symbol-description      nodemailer                             ws
                    github-from-package         node-mndp                              wtf-8
                    glob                        node-nut                               xml2js
                    glob-parent                 node-rest-client                       xml2json
                    glob-stream                 node-schedule                          xml2json-light
                    glossy                      node-ssdp                              xmlbuilder
                    @googleapis                 node-telegram-bot-api                  xmlchars
                    googleapis-common           node-wol                               xmldom
                    google-auth-library         normalize-package-data                 xmlhttprequest-ssl
                    google-p12-pem              normalize-path                         xml-name-validator
                    graceful-fs                 npmlog                                 xregexp
                    @greenlock                  number-allocator                       xtend
                    greenlock                   number-is-nan                          y18n
                    greenlock-express           nwsapi                                 yallist
                    greenlock-manager-fs        oauth                                  yargs
                    greenlock-store-fs          oauth-sign                             yargs-parser
                    gtoken                      object-assign                          yeast
                    @harmonyhub                 object.assign                          zigbee-herdsman
                    harmonyhubws                object-component                       zrender
                    pi@raspberrypi:/opt/iobroker/node_modules $ cd /canvas
                    -bash: cd: /canvas: Datei oder Verzeichnis nicht gefunden
                    pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker/node_modules/canvas
                    -bash: cd: /opt/iobroker/node_modules/canvas: Datei oder Verzeichnis nicht gefunden
                      cron                        is-glob                                sntp
                      eckles                      jws                                    tar
                      fill-range                  mqtt                                   vm2
                      Thomas BraunT
                      Thomas BraunT
                      #70
                      @markus-faltermeier
                      Komisch. Da sehe ich eigentlich entsprechende Meldungen in deinem Log die auf canvas hindeuten würden.
                      cd /opt/iobroker
                      npm ls canvas
                      M 2 Antworten Letzte Antwort
                        @markus-faltermeier
                        cd /opt/iobroker
                        npm ls canvas
                        M
                        M
                        Markus Faltermeier
                        #71
                        @thomas-braun Hi,
                        da bekomme ich diese Ausgabe
                        pi@raspberrypi:/opt/iobroker $ npm ls canvas
                        npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                        iobroker.inst@2.0.3 /opt/iobroker
                        └─┬ iobroker.iot@1.8.24
                          └── UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                          @thomas-braun Hi,
                          Thomas BraunT
                          Thomas BraunT
                          #72
                          @markus-faltermeier
                          Da hängt schon mal eines deiner Probleme.
                          npm ls
                          bringt?
                          HomoranH M 2 Antworten Letzte Antwort
                            @markus-faltermeier
                            cd /opt/iobroker
                            npm ls canvas
                            M
                            M
                            Markus Faltermeier
                            #73
                            Ich hab jetzt nochmal versucht nach dem anderen thread vorzugehen.
                            mit "npm list" taucht der tr064 immer noch auf. Und ich krieg den nicht gelöscht
                             semver@5.7.1
                            ├── UNMET DEPENDENCY tr-O64@0.2.4
                            └─┬ yargs@7.1.0
                              ├── camelcase@3.0.0
                              ├─┬ cliui@3.2.0
                              │ ├── string-width@1.0.2 deduped
                              │ ├─┬ strip-ansi@3.0.1
                              │ │ └── ansi-regex@2.1.1
                              │ └─┬ wrap-ansi@2.1.0
                              │   └── strip-ansi@3.0.1 deduped
                              ├── decamelize@1.2.0
                              ├── get-caller-file@1.0.3
                              ├─┬ os-locale@1.4.0
                              │ └─┬ lcid@1.0.0
                              │   └── invert-kv@1.0.0
                            sieht zwar so aus, als ob er dann mit dem angegebenen Befehl:
                            cd /opt/iobroker/node_modules/iobroker.tr-064
                            npm uninstall tr-O64
                            deinstalliert. Aber anschließend ist er immer noch da.
                            ich bekomm da folgende Ausgabe:
                            pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.tr-064
                            pi@raspberrypi:/opt/iobroker/node_modules/iobroker.tr-064 $ npm uninstall tr-O64
                            > es5-ext@0.10.57 postinstall /opt/iobroker/node_modules/iobroker.tr-064/node_modules/es5-ext
                            > node -e "try{require('./_postinstall')}catch(e){}"
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            added 564 packages from 408 contributors and audited 570 packages in 29.66s
                            43 packages are looking for funding
                              run `npm fund` for details
                            found 3 vulnerabilities (1 low, 2 high)
                              run `npm audit fix` to fix them, or `npm audit` for details
                              @markus-faltermeier
                              npm ls
                              bringt?
                              #74
                              @thomas-braun sagte in Probleme bei Update von admin:
                              und das zweite ist die falsche Version von der package-lock.json wegen npm v8.
                                @markus-faltermeier
                                npm ls
                                bringt?
                                M
                                M
                                Markus Faltermeier
                                #75
                                │ │ │ ├── component-emitter@1.2.1
                                │ │ │ ├── component-inherit@0.0.3
                                │ │ │ ├─┬ debug@2.3.3
                                │ │ │ │ └── ms@0.7.2
                                │ │ │ ├── engine.io-parser@1.3.2 deduped
                                │ │ │ ├── has-cors@1.1.0
                                │ │ │ ├── indexof@0.0.1 deduped
                                │ │ │ ├─┬ parsejson@0.0.3
                                │ │ │ │ └── better-assert@1.0.2 deduped
                                │ │ │ ├─┬ parseqs@0.0.5
                                │ │ │ ├── parseuri@0.0.5 deduped
                                │ │ │ ├── ws@1.1.1 deduped
                                │ │ │ ├── xmlhttprequest-ssl@1.5.3
                                │ │ │ └── yeast@0.1.2
                                │ │ ├── has-binary@0.1.7 deduped
                                │ │ ├── object-component@0.0.3
                                │ │ ├─┬ parseuri@0.0.5
                                │ │ │ └─┬ better-assert@1.0.2
                                │ │ │   └── callsite@1.0.0 deduped
                                │ │ ├── socket.io-parser@2.3.1 deduped
                                │ │ └── to-array@0.1.4
                                │ └── ws@7.5.7
                                ├─┬ iobroker.daswetter@3.0.9
                                │ ├─┬ @iobroker/adapter-core@2.5.1
                                │ │ └─┬ @types/iobroker@3.3.4
                                │ │   └── @types/node@13.13.5 deduped
                                │ ├─┬ @sentry/node@6.14.1
                                │ │ ├─┬ @sentry/core@6.14.1
                                │ │ │ ├── @sentry/hub@6.14.1 deduped
                                │ │ │ ├─┬ @sentry/minimal@6.14.1
                                │ │ │ │ ├── @sentry/hub@6.14.1 deduped
                                │ │ │ │ ├── @sentry/types@6.14.1 deduped
                                │ │ │ │ └── tslib@1.11.2 deduped
                                │ │ │ ├── @sentry/utils@6.14.1 deduped
                                │ │ ├─┬ @sentry/hub@6.14.1
                                │ │ ├─┬ @sentry/tracing@6.14.1
                                │ │ │ ├─┬ @sentry/hub@6.14.1
                                │ │ │ │ ├── @sentry/utils@6.14.1 deduped
                                │ │ │ ├─┬ @sentry/utils@6.14.1
                                │ │ ├── cookie@0.4.1 deduped
                                │ │ ├── https-proxy-agent@5.0.0 deduped
                                │ │ ├── lru_map@0.3.3 deduped
                                │ ├─┬ bent@7.3.12
                                │ │ ├── bytesish@0.4.4
                                │ │ ├── caseless@0.12.0 deduped
                                │ │ └── is-stream@2.0.1
                                │ └── xml2json-light@1.0.6
                                ├─┬ iobroker.deconz@1.3.19
                                │ ├── @sentry/integrations@6.16.1 deduped
                                │ ├── @sentry/node@6.16.1 deduped
                                │ ├── request@2.88.2 deduped
                                │ ├── source-map-support@0.5.21 deduped
                                │ └── ws@7.5.6
                                ├─┬ iobroker.denon@1.12.1
                                │ └─┬ @iobroker/adapter-core@2.5.1
                                ├─┬ iobroker.discovery@2.7.3
                                │ ├─┬ mdns-discovery@0.2.6
                                │ │ ├─┬ debug@2.2.0
                                │ │ │ └── ms@0.7.1
                                │ │ ├── dgram@1.0.1
                                │ │ └─┬ dns-packet@1.3.1
                                │ │   ├── ip@1.1.5 deduped
                                │ │   └── safe-buffer@5.1.2 deduped
                                │ ├── netmask@2.0.2
                                │ ├── node-mndp@0.0.3
                                │ ├─┬ node-ssdp@4.0.1
                                │ │ ├─┬ async@2.6.3
                                │ │ │ └── lodash@4.17.21 deduped
                                │ │ ├── bluebird@3.7.2
                                │ │ ├─┬ debug@3.2.7
                                │ │ │ └── ms@2.1.3
                                │ │ ├── extend@3.0.2 deduped
                                │ │ └── ip@1.1.5 deduped
                                │ └─┬ serialport@9.2.8
                                │   ├─┬ @serialport/binding-mock@9.2.4
                                │   │ ├─┬ @serialport/binding-abstract@9.2.3
                                │   │ │ └─┬ debug@4.3.3
                                │   │ │   └── ms@2.1.2
                                │   │ └─┬ debug@4.3.3
                                │   │   └── ms@2.1.2
                                │   ├─┬ UNMET OPTIONAL DEPENDENCY @serialport/bindings@9.2.8
                                │   │ ├── @serialport/binding-abstract@9.2.3 deduped
                                │   │ ├── @serialport/parser-readline@9.2.4 deduped
                                │   │ ├─┬ bindings@1.5.0
                                │   │ │ └── file-uri-to-path@1.0.0
                                │   │ ├─┬ UNMET OPTIONAL DEPENDENCY debug@4.3.3
                                │   │ │ └── UNMET OPTIONAL DEPENDENCY ms@2.1.2
                                │   │ ├── nan@2.15.0 deduped
                                │   │ └─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@7.0.1
                                │   │   ├── UNMET OPTIONAL DEPENDENCY detect-libc@2.0.1
                                │   │   ├── expand-template@2.0.3 deduped
                                │   │   ├── github-from-package@0.0.0 deduped
                                │   │   ├── minimist@1.2.5 deduped
                                │   │   ├── mkdirp-classic@0.5.3 deduped
                                │   │   ├── napi-build-utils@1.0.2 deduped
                                │   │   ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@3.8.0
                                │   │   │ └─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                                │   │   │   └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                                │   │   │     └── yallist@4.0.0 deduped
                                │   │   ├── npmlog@4.1.2 deduped
                                │   │   ├── pump@3.0.0 deduped
                                │   │   ├── rc@1.2.8 deduped
                                │   │   ├─┬ UNMET OPTIONAL DEPENDENCY simple-get@4.0.1
                                │   │   │ ├─┬ UNMET OPTIONAL DEPENDENCY decompress-response@6.0.0
                                │   │   │ │ └── UNMET OPTIONAL DEPENDENCY mimic-response@3.1.0
                                │   │   │ ├── once@1.4.0 deduped
                                │   │   │ └── simple-concat@1.0.0 deduped
                                │   │   ├── tar-fs@2.1.1 deduped
                                │   │   └── tunnel-agent@0.6.0 deduped
                                │   ├── @serialport/parser-byte-length@9.2.4
                                │   ├── @serialport/parser-cctalk@9.2.4
                                │   ├── @serialport/parser-delimiter@9.2.4
                                │   ├── @serialport/parser-inter-byte-timeout@9.2.4
                                │   ├─┬ @serialport/parser-readline@9.2.4
                                │   │ └── @serialport/parser-delimiter@9.2.4 deduped
                                │   ├── @serialport/parser-ready@9.2.4
                                │   ├── @serialport/parser-regex@9.2.4
                                │   ├─┬ @serialport/stream@9.2.4
                                │   │ └─┬ debug@4.3.3
                                │   │   └── ms@2.1.2
                                │   └─┬ debug@4.3.3
                                │     └── ms@2.1.2
                                ├─┬ iobroker.dwd@2.7.7
                                │ ├─┬ @iobroker/adapter-core@2.5.0
                                │ │ └─┬ @types/iobroker@3.3.0
                                │ └─┬ axios@0.21.4
                                │   └── follow-redirects@1.14.8 deduped
                                ├─┬ iobroker.email@1.0.10
                                │ └── nodemailer@6.7.2
                                ├─┬ iobroker.fhem@1.6.3
                                ├─┬ iobroker.flot@1.10.7
                                ├─┬ iobroker.fritzbox@0.2.1
                                │ └─┬ xml2js@0.4.23
                                │   ├── sax@1.2.4
                                │   └── xmlbuilder@11.0.1
                                ├─┬ iobroker.geofency@1.0.3
                                │ └── request@2.88.2 deduped
                                ├─┬ iobroker.harmony@1.2.2
                                │ ├─┬ @harmonyhub/discover@1.0.8
                                │ │ ├── autobind-decorator@2.4.0
                                │ │ └─┬ debug@4.1.1
                                │ │   └── ms@2.1.2
                                │ ├─┬ @iobroker/adapter-core@1.0.3
                                │ │ └─┬ @types/iobroker@1.4.13
                                │ ├─┬ harmonyhubws@1.0.6
                                │ │ ├── request@2.88.2 deduped
                                │ │ ├─┬ request-promise-native@1.0.8
                                │ │ │ ├─┬ request-promise-core@1.1.3
                                │ │ │ │ └── lodash@4.17.21 deduped
                                │ │ │ ├── stealthy-require@1.1.1
                                │ │ │ └── tough-cookie@2.5.0 deduped
                                │ │ ├── semver@5.7.1 deduped
                                │ │ └─┬ ws@6.2.1
                                │ │   └── async-limiter@1.0.1
                                │ └── semaphore@1.0.5
                                ├─┬ iobroker.heatingcontrol@2.7.2
                                │ │ ├── @sentry/tracing@6.14.1 deduped
                                │ └─┬ cron@1.8.2
                                │   └─┬ moment-timezone@0.5.34
                                │     └── moment@2.29.1 deduped
                                ├─┬ iobroker.history@1.10.5
                                ├─┬ iobroker.hm-rega@3.0.35
                                │ ├─┬ iconv-lite@0.6.3
                                │ │ └── safer-buffer@2.1.2
                                │ └── xml2js@0.4.23 deduped
                                ├─┬ iobroker.hm-rpc@1.15.0
                                │ ├─┬ binrpc@3.3.1
                                │ │ ├─┬ binary@0.3.0
                                │ │ │ ├── buffers@0.1.1
                                │ │ │ └─┬ chainsaw@0.1.0
                                │ │ │   └── traverse@0.3.9
                                │ │ └── put@0.0.6
                                │ └─┬ homematic-xmlrpc@1.0.2
                                │   ├── sax@0.4.3
                                │   └── xmlbuilder@0.4.2
                                ├─┬ UNMET DEPENDENCY iobroker.hue@3.5.31
                                │ ├─┬ UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
                                │ │ └─┬ UNMET DEPENDENCY @types/iobroker@3.3.4
                                │ └─┬ node-hue-api@4.0.11
                                │   ├── axios@0.21.4 deduped
                                │   ├── bottleneck@2.19.5
                                │   └── get-ssl-certificate@2.3.3
                                ├─┬ iobroker.ical@1.11.4
                                │ ├── cloneextend@0.0.3
                                │ ├─┬ node-ical@0.13.0
                                │ │ ├── moment-timezone@0.5.34 deduped
                                │ │ ├─┬ node-fetch@2.6.7
                                │ │ │ └─┬ whatwg-url@5.0.0
                                │ │ │   ├── tr46@0.0.3
                                │ │ │   └── webidl-conversions@3.0.1
                                │ │ ├── rrule@2.6.8 deduped
                                │ │ └── uuid@8.3.2
                                │ └─┬ rrule@2.6.8
                                │   ├── luxon@1.27.0
                                ├── iobroker.icons-icons8@0.0.1
                                ├── iobroker.icons-mfd-svg@1.0.2
                                ├── iobroker.icons-ultimate-png@1.0.1
                                ├─┬ iobroker.info@1.9.8
                                │ ├── jshashes@1.0.8
                                │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@1.0.7
                                │ ├─┬ semver@7.3.5
                                │ │ └─┬ lru-cache@6.0.0
                                │ └── systeminformation@5.11.3
                                ├─┬ iobroker.iot@1.8.24
                                │ ├─┬ aws-iot-device-sdk@2.2.11
                                │ │ ├── crypto-js@4.0.0
                                │ │ ├─┬ mqtt@4.2.8
                                │ │ │ ├── commist@1.1.0 deduped
                                │ │ │ ├─┬ concat-stream@2.0.0
                                │ │ │ │ ├── buffer-from@1.1.1 deduped
                                │ │ │ │ ├── inherits@2.0.4 deduped
                                │ │ │ │ ├── readable-stream@3.6.0 deduped
                                │ │ │ │ └── typedarray@0.0.6 deduped
                                │ │ │ ├─┬ debug@4.3.3
                                │ │ │ │ └── ms@2.1.2
                                │ │ │ ├─┬ duplexify@4.1.2
                                │ │ │ │ ├── end-of-stream@1.4.4 deduped
                                │ │ │ │ └── stream-shift@1.0.1 deduped
                                │ │ │ ├─┬ help-me@3.0.0
                                │ │ │ │ ├── glob@7.1.6 deduped
                                │ │ │ │ └── readable-stream@3.6.0 deduped
                                │ │ │ ├── minimist@1.2.5 deduped
                                │ │ │ ├─┬ mqtt-packet@6.10.0
                                │ │ │ │ ├── bl@4.1.0 deduped
                                │ │ │ │ ├── debug@4.3.3 deduped
                                │ │ │ │ └── process-nextick-args@2.0.1 deduped
                                │ │ │ ├── pump@3.0.0 deduped
                                │ │ │ ├─┬ readable-stream@3.6.0
                                │ │ │ │ ├── string_decoder@1.1.1 deduped
                                │ │ │ │ └── util-deprecate@1.0.2 deduped
                                │ │ │ ├── reinterval@1.1.0 deduped
                                │ │ │ ├─┬ split2@3.2.2
                                │ │ │ ├── ws@7.5.7
                                │ │ │ └── xtend@4.0.2 deduped
                                │ │ └── websocket-stream@5.5.2 deduped
                                │ ├─┬ UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @mapbox/node-pre-gyp@1.0.8
                                │ │ │ ├── detect-libc@1.0.3 deduped
                                │ │ │ ├── https-proxy-agent@5.0.0 deduped
                                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY make-dir@3.1.0
                                │ │ │ │ └── UNMET OPTIONAL DEPENDENCY semver@6.3.0
                                │ │ │ ├── node-fetch@2.6.7 deduped
                                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY nopt@5.0.0
                                │ │ │ │ └── UNMET OPTIONAL DEPENDENCY abbrev@1.1.1
                                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY npmlog@5.0.1
                                │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY are-we-there-yet@2.0.0
                                │ │ │ │ │ ├── delegates@1.0.0
                                │ │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY readable-stream@3.6.0
                                │ │ │ │ │   ├── inherits@2.0.4 deduped
                                │ │ │ │ │   ├── string_decoder@1.1.1 deduped
                                │ │ │ │ │   └── util-deprecate@1.0.2 deduped
                                │ │ │ │ ├── console-control-strings@1.1.0
                                │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY gauge@3.0.2
                                │ │ │ │ │ ├── aproba@1.2.0
                                │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY color-support@1.1.3
                                │ │ │ │ │ ├── console-control-strings@1.1.0 deduped
                                │ │ │ │ │ ├── has-unicode@2.0.1
                                │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY object-assign@4.1.1
                                │ │ │ │ │ ├── signal-exit@3.0.3 deduped
                                │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY string-width@4.2.3
                                │ │ │ │ │ │ ├── emoji-regex@8.0.0 deduped
                                │ │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY is-fullwidth-code-point@3.0.0
                                │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                                │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                                │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY ansi-regex@5.0.1
                                │ │ │ │ │ └─┬ wide-align@1.1.3
                                │ │ │ │ │   └── string-width@1.0.2 deduped
                                │ │ │ │ └── set-blocking@2.0.0 deduped
                                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY rimraf@3.0.2
                                │ │ │ │ └── glob@7.1.6 deduped
                                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                                │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                                │ │ │ │   └── yallist@4.0.0 deduped
                                │ │ │ └── tar@6.1.11 deduped
                                │ │ └─┬ simple-get@3.1.0
                                │ │   ├─┬ decompress-response@4.2.1
                                │ │   │ └── mimic-response@2.1.0
                                │ ├─┬ echarts@4.9.0
                                │ │ └── zrender@4.3.2
                                │ ├── iobroker.type-detector@1.0.17
                                │ ├─┬ jsdom@17.0.0
                                │ │ ├── abab@2.0.5
                                │ │ ├── acorn@8.7.0
                                │ │ ├─┬ acorn-globals@6.0.0
                                │ │ │ ├── acorn@7.4.1
                                │ │ │ └── acorn-walk@7.2.0
                                │ │ ├── cssom@0.5.0
                                │ │ ├─┬ cssstyle@2.3.0
                                │ │ │ └── cssom@0.3.8
                                │ │ ├─┬ data-urls@3.0.1
                                │ │ │ ├── abab@2.0.5 deduped
                                │ │ │ ├── whatwg-mimetype@3.0.0
                                │ │ │ └─┬ whatwg-url@10.0.0
                                │ │ │   ├─┬ tr46@3.0.0
                                │ │ │   │ └── punycode@2.1.1 deduped
                                │ │ │   └── webidl-conversions@7.0.0
                                │ │ ├── decimal.js@10.3.1
                                │ │ ├─┬ domexception@2.0.1
                                │ │ │ └── webidl-conversions@5.0.0
                                │ │ ├─┬ escodegen@2.0.0
                                │ │ │ ├── esprima@4.0.1
                                │ │ │ ├── estraverse@5.3.0
                                │ │ │ ├── esutils@2.0.3
                                │ │ │ ├─┬ optionator@0.8.3
                                │ │ │ │ ├── deep-is@0.1.4
                                │ │ │ │ ├── fast-levenshtein@2.0.6
                                │ │ │ │ ├─┬ levn@0.3.0
                                │ │ │ │ │ ├── prelude-ls@1.1.2 deduped
                                │ │ │ │ │ └── type-check@0.3.2 deduped
                                │ │ │ │ ├─┬ type-check@0.3.2
                                │ │ │ │ │ └── prelude-ls@1.1.2 deduped
                                │ │ │ │ └── word-wrap@1.2.3
                                │ │ │ └── source-map@0.6.1 deduped
                                │ │ ├─┬ form-data@4.0.0
                                │ │ │ ├── asynckit@0.4.0 deduped
                                │ │ │ ├── combined-stream@1.0.8 deduped
                                │ │ │ └── mime-types@2.1.34 deduped
                                │ │ ├─┬ html-encoding-sniffer@2.0.1
                                │ │ │ └── whatwg-encoding@1.0.5 deduped
                                │ │ ├─┬ http-proxy-agent@4.0.1
                                │ │ │ ├── @tootallnate/once@1.1.2
                                │ │ │ ├── agent-base@6.0.2 deduped
                                │ │ │   └── ms@2.1.2
                                │ │ ├── is-potential-custom-element-name@1.0.1
                                │ │ ├── nwsapi@2.2.0
                                │ │ ├── parse5@6.0.1
                                │ │ ├─┬ saxes@5.0.1
                                │ │ │ └── xmlchars@2.2.0
                                │ │ ├── symbol-tree@3.2.4
                                │ │ ├─┬ tough-cookie@4.0.0
                                │ │ │ ├── psl@1.8.0 deduped
                                │ │ │ ├── punycode@2.1.1 deduped
                                │ │ │ └── universalify@0.1.2 deduped
                                │ │ ├─┬ w3c-hr-time@1.0.2
                                │ │ │ └── browser-process-hrtime@1.0.0
                                │ │ ├─┬ w3c-xmlserializer@2.0.0
                                │ │ │ └── xml-name-validator@3.0.0 deduped
                                │ │ ├── webidl-conversions@6.1.0
                                │ │ ├─┬ whatwg-encoding@1.0.5
                                │ │ │ └── iconv-lite@0.4.24 deduped
                                │ │ ├── whatwg-mimetype@2.3.0
                                │ │ ├─┬ whatwg-url@9.1.0
                                │ │ │ ├─┬ tr46@2.1.0
                                │ │ │ └── webidl-conversions@6.1.0 deduped
                                │ │ ├── ws@8.5.0
                                │ ├── moment@2.29.1
                                │ ├─┬ UNMET OPTIONAL DEPENDENCY sharp@0.28.1
                                │ │ ├─┬ color@3.2.1
                                │ │ │ ├─┬ color-convert@1.9.3
                                │ │ │ │ └── color-name@1.1.3
                                │ │ │ └─┬ color-string@1.9.0
                                │ │ │   ├── color-name@1.1.3 deduped
                                │ │ │   └─┬ simple-swizzle@0.2.2
                                │ │ │     └── is-arrayish@0.3.2
                                │ │ ├── UNMET OPTIONAL DEPENDENCY node-addon-api@3.2.1
                                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@6.1.4
                                │ │ │ ├── expand-template@2.0.3
                                │ │ │ ├── github-from-package@0.0.0
                                │ │ │ ├── mkdirp-classic@0.5.3 deduped
                                │ │ │ ├── napi-build-utils@1.0.2
                                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@2.30.1
                                │ │ │ │ └── semver@5.7.1 deduped
                                │ │ │ ├─┬ npmlog@4.1.2
                                │ │ │ │ ├─┬ are-we-there-yet@1.1.5
                                │ │ │ │ │ ├── delegates@1.0.0 deduped
                                │ │ │ │ │ └── readable-stream@2.3.7 deduped
                                │ │ │ │ ├─┬ gauge@2.7.4
                                │ │ │ │ │ ├── aproba@1.2.0 deduped
                                │ │ │ │ │ ├── has-unicode@2.0.1 deduped
                                │ │ │ │ │ ├── object-assign@4.1.0 deduped
                                │ │ │ │ │ ├── string-width@1.0.2 deduped
                                │ │ │ │ │ ├── strip-ansi@3.0.1 deduped
                                │ │ │ │ │ └── wide-align@1.1.3 deduped
                                │ │ │ ├─┬ rc@1.2.8
                                │ │ │ │ ├── deep-extend@0.6.0
                                │ │ │ │ ├── ini@1.3.5 deduped
                                │ │ │ │ ├── minimist@1.2.5 deduped
                                │ │ │ │ └── strip-json-comments@2.0.1
                                │ │ │ ├── simple-get@3.1.0 deduped
                                │ │ │ ├── tar-fs@2.1.1 deduped
                                │ │ │ └── tunnel-agent@0.6.0 deduped
                                │ └── uuid@8.3.2
                                ├─┬ iobroker.javascript@5.2.21
                                │ │   └── @types/node@10.17.60 deduped
                                │ ├── @types/node@10.17.60
                                │ ├─┬ @types/request@2.48.8
                                │ │ ├── @types/caseless@0.12.2
                                │ │ ├── @types/node@13.13.5
                                │ │ ├── @types/tough-cookie@4.0.1
                                │ │ └─┬ form-data@2.5.1
                                │ ├── coffee-compiler@0.3.2
                                │ ├── coffee-script@1.12.7
                                │ ├── jsonata@1.8.6
                                │ ├── node-inspect@2.0.0
                                │ ├─┬ node-schedule@2.0.0
                                │ │ ├── cron-parser@3.5.0 deduped
                                │ │ ├── long-timeout@0.1.1 deduped
                                │ │ └── sorted-array-functions@1.3.0 deduped
                                │ ├── oauth@0.9.15
                                │ ├─┬ owlintuition@0.4.0
                                │ │ └─┬ xml2json@0.12.0
                                │ │   ├── hoek@4.2.1
                                │ │   ├─┬ joi@13.7.0
                                │ │   │ ├── hoek@5.0.4
                                │ │   │ ├─┬ isemail@3.2.0
                                │ │   │ └─┬ topo@3.0.3
                                │ │   │   └── hoek@6.1.3
                                │ │   └─┬ node-expat@2.4.0
                                │ │     ├── bindings@1.5.0 deduped
                                │ │     └── nan@2.15.0 deduped
                                │ ├─┬ semver@7.3.5
                                │ ├── suncalc2@1.8.1
                                │ ├── typescript@4.5.5
                                │ ├─┬ virtual-tsc@0.6.2
                                │ │ ├─┬ debug@4.3.3
                                │ │ │ └── ms@2.1.2
                                │ │ └── picocolors@1.0.0
                                │ ├─┬ vm2@3.9.7
                                │ │ ├── acorn@8.7.0 deduped
                                │ │ └── acorn-walk@8.2.0
                                │ ├─┬ wake_on_lan@1.0.0
                                │ │ └── minimist@1.2.5 deduped
                                ├─┬ iobroker.js-controller@3.3.22
                                │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                                │ │ ├── esbuild@0.11.23
                                │ │ └── jsonc-parser@3.0.0
                                │ ├─┬ @iobroker/db-objects-file@1.2.7
                                │ │ ├─┬ @iobroker/db-base@1.2.4
                                │ │ │ ├── deep-clone@3.0.3 deduped
                                │ │ │ ├─┬ fs-extra@9.1.0
                                │ │ │ │ ├── at-least-node@1.0.0 deduped
                                │ │ │ │ ├── graceful-fs@4.2.4 deduped
                                │ │ │ │ ├─┬ jsonfile@6.1.0
                                │ │ │ │ │ ├── graceful-fs@4.2.4 deduped
                                │ │ │ │ │ └── universalify@2.0.0 deduped
                                │ │ │ ├── node.extend@2.0.2 deduped
                                │ │ │ └── respjs@4.2.0
                                │ │ ├── @iobroker/db-objects-redis@1.2.7 deduped
                                │ │ └── node.extend@2.0.2 deduped
                                │ ├─┬ @iobroker/db-objects-jsonl@1.2.7
                                │ │ ├─┬ @alcalzone/jsonl-db@1.3.0
                                │ │ │ ├─┬ alcalzone-shared@3.0.4
                                │ │ │ │ └─┬ debug@4.3.3
                                │ │ │ └─┬ proper-lockfile@4.1.2
                                │ │ │   ├── retry@0.12.0
                                │ │ │   └── signal-exit@3.0.3
                                │ │ ├── @iobroker/db-base@1.2.4 deduped
                                │ │ ├── @iobroker/db-objects-file@1.2.7 deduped
                                │ ├─┬ @iobroker/db-objects-redis@1.2.7
                                │ │ ├─┬ ioredis@4.28.5
                                │ │ │ ├── cluster-key-slot@1.1.0
                                │ │ │ ├── denque@1.5.1
                                │ │ │ ├── lodash.defaults@4.2.0
                                │ │ │ ├── lodash.flatten@4.4.0
                                │ │ │ ├── lodash.isarguments@3.1.0
                                │ │ │ ├── p-map@2.1.0
                                │ │ │ ├── redis-commands@1.7.0
                                │ │ │ ├── redis-errors@1.2.0
                                │ │ │ ├─┬ redis-parser@3.0.0
                                │ │ │ │ └── redis-errors@1.2.0 deduped
                                │ │ │ └── standard-as-callback@2.1.0
                                │ ├─┬ @iobroker/db-states-file@1.2.7
                                │ │ └── @iobroker/db-states-redis@1.2.7 deduped
                                │ ├─┬ @iobroker/db-states-jsonl@1.2.7
                                │ │ ├── @alcalzone/jsonl-db@1.3.0 deduped
                                │ │ ├── @iobroker/db-states-file@1.2.7 deduped
                                │ ├─┬ @iobroker/db-states-redis@1.2.7
                                │ │ └── ioredis@4.28.5 deduped
                                │ ├── @iobroker/plugin-base@1.2.1
                                │ ├─┬ @iobroker/plugin-sentry@1.1.10
                                │ │ ├── @iobroker/plugin-base@1.2.1 deduped
                                │ │ ├── @sentry/integrations@6.16.1 deduped
                                │ │ ├── @sentry/node@6.16.1 deduped
                                │ │ └── source-map-support@0.5.21 deduped
                                │ ├─┬ chokidar@3.5.3
                                │ │ ├─┬ anymatch@3.1.2
                                │ │ │ ├── normalize-path@3.0.0 deduped
                                │ │ │ └── picomatch@2.3.1
                                │ │ ├─┬ braces@3.0.2
                                │ │ │ └─┬ fill-range@7.0.1
                                │ │ │   └─┬ to-regex-range@5.0.1
                                │ │ │     └── is-number@7.0.0
                                │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@2.3.2
                                │ │ ├─┬ glob-parent@5.1.2
                                │ │ │ └── is-glob@4.0.1 deduped
                                │ │ ├─┬ is-binary-path@2.1.0
                                │ │ │ └── binary-extensions@2.2.0
                                │ │ ├─┬ is-glob@4.0.1
                                │ │ │ └── is-extglob@2.1.1
                                │ │ └─┬ readdirp@3.6.0
                                │ │   └── picomatch@2.3.1 deduped
                                │ ├── ci-info@3.3.0
                                │ ├── daemonize2@0.4.2
                                │ ├─┬ debug@4.3.3
                                │ │ └── ms@2.1.2
                                │ ├─┬ decache@4.6.1
                                │ ├─┬ diskusage@1.1.3
                                │ │ ├── es6-promise@4.2.8
                                │ ├─┬ event-stream@4.0.1
                                │ │ ├── duplexer@0.1.1
                                │ │ ├── from@0.1.7
                                │ │ ├── map-stream@0.0.7
                                │ │ ├─┬ pause-stream@0.0.11
                                │ │ │ └── through@2.3.8 deduped
                                │ │ ├─┬ split@1.0.1
                                │ │ ├─┬ stream-combiner@0.2.2
                                │ │ │ ├── duplexer@0.1.1 deduped
                                │ ├─┬ greenlock@4.0.4
                                │ │ ├─┬ @greenlock/manager@3.1.0
                                │ │ │ └─┬ greenlock-manager-fs@3.1.1
                                │ │ │   ├── @root/mkdirp@1.0.0 deduped
                                │ │ │   └── safe-replace@1.1.0 deduped
                                │ │ ├─┬ @root/acme@3.1.0
                                │ │ │ ├── @root/csr@0.8.1 deduped
                                │ │ │ ├── @root/encoding@1.0.1
                                │ │ │ ├─┬ @root/keypairs@0.10.3
                                │ │ │ │ ├── @root/encoding@1.0.1 deduped
                                │ │ │ │ ├── @root/pem@1.0.4 deduped
                                │ │ │ │ └── @root/x509@0.7.2 deduped
                                │ │ │ ├── @root/request@1.8.1 deduped
                                │ │ │ └─┬ @root/x509@0.7.2
                                │ │ │   ├── @root/asn1@1.0.0 deduped
                                │ │ │   └── @root/encoding@1.0.1 deduped
                                │ │ ├─┬ @root/csr@0.8.1
                                │ │ │ ├─┬ @root/asn1@1.0.0
                                │ │ │ │ └── @root/encoding@1.0.1 deduped
                                │ │ ├─┬ @root/greenlock@4.0.5
                                │ │ │ ├── @greenlock/manager@3.1.0 deduped
                                │ │ │ ├── @root/acme@3.1.0 deduped
                                │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
                                │ │ │ ├── cert-info@1.5.1 deduped
                                │ │ │ ├── greenlock-store-fs@3.2.2 deduped
                                │ │ ├─┬ @root/keypairs@0.9.0
                                │ │ ├─┬ greenlock-store-fs@3.2.2
                                │ ├─┬ greenlock-express@4.0.3
                                │ │ ├── @root/greenlock@4.0.5 deduped
                                │ │ ├─┬ @root/greenlock-express@4.0.4
                                │ │ │ ├── @root/greenlock@4.0.5 deduped
                                │ │ │ └── redirect-https@1.3.1 deduped
                                │ │ └─┬ redirect-https@1.3.1
                                │ │   └── escape-html@1.0.3 deduped
                                │ ├─┬ jsonwebtoken@8.5.1
                                │ │ ├─┬ jws@3.2.2
                                │ │ │ ├─┬ jwa@1.4.1
                                │ │ │ │ ├── buffer-equal-constant-time@1.0.1 deduped
                                │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
                                │ │ │ │ └── safe-buffer@5.1.2 deduped
                                │ │ ├── lodash.includes@4.3.0
                                │ │ ├── lodash.isboolean@3.0.3
                                │ │ ├── lodash.isinteger@4.0.4
                                │ │ ├── lodash.isnumber@3.0.3
                                │ │ ├── lodash.isplainobject@4.0.6
                                │ │ ├── lodash.isstring@4.0.1
                                │ │ ├── lodash.once@4.1.1
                                │ │ ├── ms@2.1.2
                                │ ├─┬ jszip@3.7.1
                                │ │ ├─┬ lie@3.3.0
                                │ │ │ └── immediate@3.0.6
                                │ │ ├── pako@1.0.11
                                │ │ ├─┬ readable-stream@2.3.7
                                │ │ │ ├── core-util-is@1.0.2 deduped
                                │ │ │ ├── isarray@1.0.0
                                │ │ │ ├── process-nextick-args@2.0.1
                                │ │ │ ├── safe-buffer@5.1.2 deduped
                                │ │ │ ├─┬ string_decoder@1.1.1
                                │ │ └── set-immediate-shim@1.0.1
                                │ ├─┬ le-acme-core@2.1.4
                                │ │ └─┬ rsa-compat@1.9.4
                                │ │   ├─┬ keypairs@1.2.14
                                │ │   │ ├── eckles@1.4.1
                                │ │   │ └── rasha@1.2.5
                                │ │   ├── node-forge@0.7.6
                                │ │   └─┬ ursa-optional@0.9.10
                                │ ├─┬ le-challenge-fs@2.0.9
                                │ │ └── @root/mkdirp@1.0.0 deduped
                                │ ├── le-sni-auto@2.1.9
                                │ ├─┬ loadavg-windows@1.1.1
                                │ │ └── weak-daemon@1.0.3
                                │ ├── mime@2.6.0
                                │ ├── ncp@2.0.0
                                │ ├── node-forge@0.10.0
                                │ ├── node-schedule@2.1.0 deduped
                                │ ├─┬ node.extend@2.0.2
                                │ │ ├─┬ has@1.0.3
                                │ │ │ └── function-bind@1.1.1
                                │ │ └── is@3.3.0
                                │ ├─┬ pidusage@2.0.21
                                │ │ └── safe-buffer@5.2.1
                                │ ├── promisify-child-process@4.1.1
                                │ ├─┬ prompt@1.2.1
                                │ │ ├── async@0.9.2
                                │ │ ├── colors@1.4.0 deduped
                                │ │ ├─┬ read@1.0.7
                                │ │ │ └── mute-stream@0.0.8
                                │ │ ├── revalidator@0.1.8
                                │ │ └─┬ winston@2.4.5
                                │ │   ├── async@1.0.0
                                │ │   ├── colors@1.0.3
                                │ │   ├── cycle@1.0.3
                                │ │   ├── eyes@0.1.8
                                │ │   ├── isstream@0.1.2 deduped
                                │ │   └── stack-trace@0.0.10 deduped
                                │ ├── readline-sync@1.4.10
                                │ ├─┬ semver@7.3.5
                                │ ├─┬ tar@6.1.11
                                │ │ ├── chownr@2.0.0
                                │ │ ├─┬ fs-minipass@2.1.0
                                │ │ │ └── minipass@3.1.1 deduped
                                │ │ ├─┬ minipass@3.1.1
                                │ │ ├─┬ minizlib@2.1.2
                                │ │ │ ├── minipass@3.1.1 deduped
                                │ │ ├── mkdirp@1.0.4
                                │ ├─┬ winston@3.6.0
                                │ │ ├─┬ @dabh/diagnostics@2.0.3
                                │ │ │ ├─┬ colorspace@1.1.4
                                │ │ │ │ ├── color@3.2.1 deduped
                                │ │ │ │ └── text-hex@1.0.0
                                │ │ │ ├── enabled@2.0.0
                                │ │ │ └── kuler@2.0.0
                                │ │ ├── async@3.2.3
                                │ │ ├── is-stream@2.0.1 deduped
                                │ │ ├─┬ logform@2.4.0
                                │ │ │ ├── @colors/colors@1.5.0
                                │ │ │ ├── fecha@4.2.1
                                │ │ │ ├── ms@2.1.3
                                │ │ │ ├── safe-stable-stringify@2.3.1 deduped
                                │ │ │ └── triple-beam@1.3.0 deduped
                                │ │ ├─┬ one-time@1.0.0
                                │ │ │ └── fn.name@1.1.0
                                │ │ ├── stack-trace@0.0.10
                                │ │ ├── triple-beam@1.3.0
                                │ │ └─┬ winston-transport@4.5.0
                                │ │   ├── logform@2.4.0 deduped
                                │ ├─┬ winston-daily-rotate-file@4.6.1
                                │ │ ├─┬ file-stream-rotator@0.6.1
                                │ │ │ └── moment@2.29.1 deduped
                                │ │ ├── object-hash@2.2.0
                                │ │ ├── triple-beam@1.3.0 deduped
                                │ │ └── winston-transport@4.5.0 deduped
                                │ ├─┬ winston-seq-updated@1.0.4
                                │ │ ├── seq-logging@0.4.6
                                │ ├─┬ winston-syslog@2.4.4
                                │ │ ├── glossy@0.1.7
                                │ │ └─┬ UNMET OPTIONAL DEPENDENCY unix-dgram@2.0.3
                                │ └─┬ yargs@16.2.0
                                │   ├─┬ cliui@7.0.4
                                │   │ ├── string-width@4.2.3 deduped
                                │   │ ├─┬ strip-ansi@6.0.1
                                │   │ │ └── ansi-regex@5.0.1
                                │   │ └─┬ wrap-ansi@7.0.0
                                │   │   ├─┬ ansi-styles@4.3.0
                                │   │   │ └─┬ color-convert@2.0.1
                                │   │   │   └── color-name@1.1.4
                                │   │   └── strip-ansi@6.0.1 deduped
                                │   ├── escalade@3.1.1
                                │   ├── get-caller-file@2.0.5
                                │   ├── require-directory@2.1.1 deduped
                                │   ├─┬ string-width@4.2.3
                                │   │ ├── is-fullwidth-code-point@3.0.0
                                │   ├── y18n@5.0.8
                                │   └── yargs-parser@20.2.9
                                ├─┬ iobroker.lightify@0.2.16
                                │ ├── mdns-discovery@0.2.6 deduped
                                │ ├── moment@2.29.1 deduped
                                │ ├─┬ promise@8.0.1
                                │ │ └── asap@2.0.6
                                │ └─┬ soef@0.4.15
                                │   ├── array-ext@0.1.5
                                │   └── sprintf-js@1.1.2
                                ├─┬ iobroker.mihome@1.3.7
                                ├── iobroker.mihome-vacuum@1.1.5
                                ├─┬ iobroker.mobile@1.0.1
                                ├─┬ iobroker.mqtt@2.4.1
                                │ ├─┬ mqtt@2.18.9
                                │ │ ├─┬ commist@1.1.0
                                │ │ │ ├── leven@2.1.0
                                │ │ │ └── minimist@1.2.5 deduped
                                │ │ ├─┬ concat-stream@1.6.2
                                │ │ │ ├── readable-stream@2.3.7 deduped
                                │ │ ├─┬ end-of-stream@1.4.4
                                │ │ │ └── once@1.4.0 deduped
                                │ │ ├─┬ es6-map@0.1.5
                                │ │ │ ├─┬ d@1.0.1
                                │ │ │ │ ├── es5-ext@0.10.53 deduped
                                │ │ │ │ └── type@1.2.0
                                │ │ │ ├─┬ es5-ext@0.10.53
                                │ │ │ │ ├── es6-iterator@2.0.3 deduped
                                │ │ │ │ ├── es6-symbol@3.1.3 deduped
                                │ │ │ │ └── next-tick@1.0.0
                                │ │ │ ├─┬ es6-iterator@2.0.3
                                │ │ │ │ ├── d@1.0.1 deduped
                                │ │ │ │ └── es6-symbol@3.1.3 deduped
                                │ │ │ ├─┬ es6-set@0.1.5
                                │ │ │ │ ├─┬ es6-symbol@3.1.1
                                │ │ │ │ │ ├── d@1.0.1 deduped
                                │ │ │ │ │ └── es5-ext@0.10.53 deduped
                                │ │ │ │ └── event-emitter@0.3.5 deduped
                                │ │ │ ├─┬ es6-symbol@3.1.3
                                │ │ │ │ └─┬ ext@1.4.0
                                │ │ │ │   └── type@2.0.0
                                │ │ │ └─┬ event-emitter@0.3.5
                                │ │ ├─┬ help-me@1.1.0
                                │ │ │ ├─┬ callback-stream@1.1.0
                                │ │ │ ├─┬ glob-stream@6.1.0
                                │ │ │ │ ├── extend@3.0.2 deduped
                                │ │ │ │ ├─┬ glob-parent@3.1.0
                                │ │ │ │ │ ├─┬ is-glob@3.1.0
                                │ │ │ │ │ │ └── is-extglob@2.1.1 deduped
                                │ │ │ │ │ └── path-dirname@1.0.2
                                │ │ │ │ ├── is-negated-glob@1.0.0
                                │ │ │ │ ├─┬ ordered-read-streams@1.0.1
                                │ │ │ │ ├─┬ pumpify@1.5.1
                                │ │ │ │ │ ├── duplexify@3.7.1 deduped
                                │ │ │ │ │ └─┬ pump@2.0.1
                                │ │ │ │ │   ├── end-of-stream@1.4.4 deduped
                                │ │ │ │ │   └── once@1.4.0 deduped
                                │ │ │ │ ├── readable-stream@2.3.7 deduped
                                │ │ │ │ ├── remove-trailing-separator@1.1.0
                                │ │ │ │ ├─┬ to-absolute-glob@2.0.2
                                │ │ │ │ │ ├─┬ is-absolute@1.0.0
                                │ │ │ │ │ │ ├─┬ is-relative@1.0.0
                                │ │ │ │ │ │ │ └─┬ is-unc-path@1.0.0
                                │ │ │ │ │ │ │   └── unc-path-regex@0.1.2
                                │ │ │ │ │ │ └── is-windows@1.0.2
                                │ │ │ │ │ └── is-negated-glob@1.0.0 deduped
                                │ │ │ │ └─┬ unique-stream@2.3.1
                                │ │ │ │   ├── json-stable-stringify-without-jsonify@1.0.1
                                │ │ │ │   └─┬ through2-filter@3.0.0
                                │ │ │ │     ├── through2@2.0.5 deduped
                                │ │ │ │     └── xtend@4.0.2 deduped
                                • M Markus Faltermeier
                                  │ └── ws@7.5.7
                                  │ ├─┬ bent@7.3.12
                                  │ └── ws@7.5.6
                                  │ │ ├─┬ debug@2.2.0
                                  │ │ │ └── ms@0.7.1
                                  │ │ ├── dgram@1.0.1
                                  │ ├── netmask@2.0.2
                                  │ │ ├─┬ async@2.6.3
                                  │ │ ├─┬ debug@3.2.7
                                  │ │ │ └── ms@2.1.3
                                  │   │ │   └── ms@2.1.2
                                  │   │ └─┬ debug@4.3.3
                                  │   │   └── ms@2.1.2
                                  │   │ └─┬ debug@4.3.3
                                  │   │   └── ms@2.1.2
                                  │   └─┬ debug@4.3.3
                                  │     └── ms@2.1.2
                                  │ └─┬ axios@0.21.4
                                  │ └─┬ xml2js@0.4.23
                                  │   ├── sax@1.2.4
                                  │ │ └─┬ debug@4.1.1
                                  │ │   └── ms@2.1.2
                                  │ │ └─┬ ws@6.2.1
                                  │ └─┬ cron@1.8.2
                                  │ ├─┬ binrpc@3.3.1
                                  │ │ └── put@0.0.6
                                  │   ├── sax@0.4.3
                                  │ │ └── uuid@8.3.2
                                  │ └─┬ rrule@2.6.8
                                  │   ├── luxon@1.27.0
                                  │ ├─┬ semver@7.3.5
                                  │ │ ├─┬ mqtt@4.2.8
                                  │ │ │ ├── ws@7.5.7
                                  │ ├─┬ echarts@4.9.0
                                  │ ├─┬ jsdom@17.0.0
                                  │ │ ├── abab@2.0.5
                                  │ │ ├── acorn@8.7.0
                                  │ │ ├── cssom@0.5.0
                                  │ │ │   └── ms@2.1.2
                                  │ │ ├─┬ saxes@5.0.1
                                  │ │ ├── ws@8.5.0
                                  │ ├── moment@2.29.1
                                  │ │ ├─┬ color@3.2.1
                                  │ │ │ ├─┬ rc@1.2.8
                                  │ └── uuid@8.3.2
                                  │ ├── jsonata@1.8.6
                                  │ ├── oauth@0.9.15
                                  │ │   ├── hoek@4.2.1
                                  │ │   ├─┬ joi@13.7.0
                                  │ ├─┬ semver@7.3.5
                                  │ │ ├─┬ debug@4.3.3
                                  │ │ │ └── ms@2.1.2
                                  │ ├─┬ vm2@3.9.7
                                  │ ├── ci-info@3.3.0
                                  │ ├─┬ debug@4.3.3
                                  │ │ └── ms@2.1.2
                                  │ ├─┬ decache@4.6.1
                                  │ │ ├── from@0.1.7
                                  │ │ ├─┬ split@1.0.1
                                  │ │ ├─┬ jws@3.2.2
                                  │ │ │ ├─┬ jwa@1.4.1
                                  │ │ ├── ms@2.1.2
                                  │ ├─┬ jszip@3.7.1
                                  │ │ ├─┬ lie@3.3.0
                                  │ │ ├── pako@1.0.11
                                  │ ├── mime@2.6.0
                                  │ ├── ncp@2.0.0
                                  │ │ ├─┬ has@1.0.3
                                  │ │ └── is@3.3.0
                                  │ ├─┬ prompt@1.2.1
                                  │ │ ├── async@0.9.2
                                  │ │ ├─┬ read@1.0.7
                                  │ │   ├── async@1.0.0
                                  │ │   ├── cycle@1.0.3
                                  │ │   ├── eyes@0.1.8
                                  │ ├─┬ semver@7.3.5
                                  │ ├─┬ tar@6.1.11
                                  │ ├─┬ winston@3.6.0
                                  │ │ ├── async@3.2.3
                                  │ │ │ ├── ms@2.1.3
                                  │ └─┬ yargs@16.2.0
                                  │   ├─┬ cliui@7.0.4
                                  │   ├── y18n@5.0.8
                                  │ ├─┬ promise@8.0.1
                                  │ │ └── asap@2.0.6
                                  │ └─┬ soef@0.4.15
                                  │ ├─┬ mqtt@2.18.9
                                  │ │ │ ├─┬ d@1.0.1
                                  M
                                  M
                                  Markus Faltermeier
                                  #76
                                  @markus-faltermeier
                                  und der zweite Teil
                                  │ │ ├─┬ mqtt-packet@5.6.1
                                  │ │ │ ├─┬ bl@1.2.2
                                  │ │ │ ├── process-nextick-args@2.0.1 deduped
                                  │ │ ├─┬ split2@2.2.0
                                  │ │ │ └── through2@2.0.5 deduped
                                  │ │ ├─┬ websocket-stream@5.2.0
                                  │ │ │ ├─┬ ws@6.2.2
                                  │ │ │ │ └── async-limiter@1.0.1 deduped
                                  │ ├─┬ mqtt-connection@4.1.0
                                  │ │ ├─┬ duplexify@3.7.1
                                  │ │ └─┬ through2@2.0.5
                                  │ ├─┬ websocket-stream@5.5.2
                                  │ │ ├─┬ ws@3.3.3
                                  │ │ │ ├── async-limiter@1.0.1 deduped
                                  │ │ │ └── ultron@1.1.1
                                  │ └── ws@8.5.0
                                  ├─┬ iobroker.mqtt-client@1.5.0
                                  │ ├─┬ @iobroker/adapter-core@2.6.0
                                  │ │ └─┬ @types/iobroker@4.0.1
                                  │ └── mqtt@2.18.9 deduped
                                  ├─┬ iobroker.nut@1.5.0
                                  │ └── node-nut@1.0.3
                                  ├─┬ iobroker.octoprint@2.1.0
                                  │ └─┬ axios@0.24.0
                                  ├─┬ iobroker.ping@1.5.0
                                  ├─┬ iobroker.pushover@2.0.5
                                  │ └── pushover-notifications@1.2.2
                                  ├─┬ iobroker.rpi2@1.3.1
                                  │ ├─┬ node-dht-sensor@0.4.3
                                  │ │ └── node-addon-api@1.7.2
                                  │ ├─┬ rpi-gpio@2.1.7
                                  │ │ ├─┬ async-retry@1.3.3
                                  │ │ │ └── retry@0.13.1
                                  │ │ ├─┬ debug@3.2.7
                                  │ │ │ └── ms@2.1.3
                                  │ │ └─┬ epoll@2.0.10
                                  │ ├─┬ rpi-gpio-buttons@2.0.1
                                  │ │ ├── button-events@1.0.2
                                  │ │ └── rpi-gpio@2.1.7 deduped
                                  │ └── sync-exec@0.6.2
                                  ├─┬ iobroker.scenes@2.3.8
                                  │ └── node-schedule@2.1.0 deduped
                                  ├─┬ iobroker.shelly@4.0.7
                                  │ ├── @apollon/iobroker-tools@0.2.0
                                  │ ├─┬ coiot-coap@1.0.0
                                  │ │ ├─┬ coap@0.24.0
                                  │ │ │ ├── capitalize@2.0.4
                                  │ │ │ ├── coap-packet@0.1.14
                                  │ │ │ ├── fastseries@2.0.0
                                  │ │ │ ├─┬ lru-cache@5.1.1
                                  │ │ │ │ └── yallist@3.1.1
                                  │ │ │ └─┬ readable-stream@3.6.0
                                  │ │ └── commander@6.2.1
                                  │ ├─┬ mqtt@4.3.5
                                  │ │ ├─┬ debug@4.3.3
                                  │ │ │ └── ms@2.1.2
                                  │ │ │ ├─┬ glob@7.1.6
                                  │ │ │ │ ├── fs.realpath@1.0.0
                                  │ │ │ │ ├─┬ inflight@1.0.6
                                  │ │ │ │ │ ├── once@1.4.0 deduped
                                  │ │ │ │ │ └── wrappy@1.0.2 deduped
                                  │ │ │ │ ├── minimatch@3.0.4 deduped
                                  │ │ │ │ └── path-is-absolute@1.0.1
                                  │ │ ├─┬ lru-cache@6.0.0
                                  │ │ ├─┬ number-allocator@1.0.9
                                  │ │ │ └── js-sdsl@2.1.4
                                  │ │ ├── rfdc@1.3.0
                                  │ │ ├── ws@7.5.7
                                  │ ├── mqtt-connection@4.1.0 deduped
                                  │ ├─┬ ping@0.4.1
                                  │ │ ├── q@1.5.1
                                  │ │ └── underscore@1.13.2
                                  │ ├─┬ shelly-iot@1.1.2
                                  │ │ ├─┬ coap@0.26.0
                                  │ │ │ ├─┬ @types/bl@5.0.2
                                  │ │ │ │ ├── @types/node@13.13.5 deduped
                                  │ │ │ │ └─┬ @types/readable-stream@2.3.13
                                  │ │ │ ├── @types/node@16.11.25
                                  │ │ │ ├─┬ bl@5.0.0
                                  │ │ │ │ ├─┬ buffer@6.0.3
                                  │ │ │ │ │ ├── base64-js@1.3.1 deduped
                                  │ │ │ │ │ └── ieee754@1.2.1
                                  │ │ │ ├── capitalize@2.0.4 deduped
                                  │ │ │ ├── coap-packet@1.1.1
                                  │ │ │ ├── fastseries@2.0.0 deduped
                                  │ │ │ ├─┬ lru-cache@6.0.0
                                  │ │ └─┬ node-rest-client@3.1.1
                                  │ │   ├─┬ debug@4.3.3
                                  │ │   │ └── ms@2.1.2
                                  │ │   ├── follow-redirects@1.14.8 deduped
                                  │ │   └── xml2js@0.4.23 deduped
                                  │ ├── tcp-ping@0.1.1
                                  │ ├── xml2js@0.4.23 deduped
                                  │ └── xmlbuilder@15.1.1
                                  ├─┬ iobroker.simple-api@2.6.2
                                  ├─┬ iobroker.snmp@0.5.0
                                  │ └─┬ net-snmp@1.2.5
                                  │   └── asn1-ber@1.0.9
                                  ├─┬ iobroker.socketio@3.1.5
                                  │ ├─┬ axios@0.23.0
                                  │ │ └── follow-redirects@1.14.8 deduped
                                  │ ├── cookie-parser@1.4.6 deduped
                                  │ ├── express-session@1.17.2 deduped
                                  │ └─┬ socket.io@2.4.1
                                  │   ├─┬ debug@4.1.1
                                  │   │ └── ms@2.1.3
                                  │   ├─┬ engine.io@3.5.0
                                  │   │ ├── accepts@1.3.8 deduped
                                  │   │ ├── base64id@2.0.0
                                  │   │ ├─┬ debug@4.1.1
                                  │   │ │ └── ms@2.1.3 deduped
                                  │   │ ├─┬ engine.io-parser@2.2.1
                                  │   │ │ ├── after@0.8.2 deduped
                                  │   │ │ ├── arraybuffer.slice@0.0.7
                                  │   │ │ ├── base64-arraybuffer@0.1.4
                                  │   │ │ ├── blob@0.0.5
                                  │   │ │ └── has-binary2@1.0.3 deduped
                                  │   │ └── ws@7.4.6
                                  │   ├─┬ has-binary2@1.0.3
                                  │   │ └── isarray@2.0.1
                                  │   ├── socket.io-adapter@1.1.2
                                  │   ├─┬ socket.io-client@2.4.0
                                  │   │ ├── backo2@1.0.2 deduped
                                  │   │ ├── component-bind@1.0.0 deduped
                                  │   │ ├── component-emitter@1.3.0
                                  │   │ ├─┬ debug@3.1.0
                                  │   │ │ └── ms@2.0.0
                                  │   │ ├─┬ engine.io-client@3.5.2
                                  │   │ │ ├── component-emitter@1.3.0 deduped
                                  │   │ │ ├── component-inherit@0.0.3 deduped
                                  │   │ │ ├─┬ debug@3.1.0
                                  │   │ │ │ └── ms@2.0.0
                                  │   │ │ ├── engine.io-parser@2.2.1 deduped
                                  │   │ │ ├── has-cors@1.1.0 deduped
                                  │   │ │ ├── parseqs@0.0.6 deduped
                                  │   │ │ ├── parseuri@0.0.6 deduped
                                  │   │ │ ├── ws@7.4.6 deduped
                                  │   │ │ ├── xmlhttprequest-ssl@1.6.3
                                  │   │ │ └── yeast@0.1.2 deduped
                                  │   │ ├── has-binary2@1.0.3 deduped
                                  │   │ ├─┬ socket.io-parser@3.3.2
                                  │   │ │ ├── debug@3.1.0 deduped
                                  │   │ │ └── isarray@2.0.1 deduped
                                  │   │ └── to-array@0.1.4 deduped
                                  │   └─┬ socket.io-parser@3.4.1
                                  │     ├─┬ debug@4.1.1
                                  │     └── isarray@2.0.1
                                  ├─┬ iobroker.sonoff@2.4.7
                                  │ └── mqtt-connection@4.1.0 deduped
                                  ├─┬ iobroker.spotify-premium@1.0.0
                                  │ ├─┬ @iobroker/adapter-core@1.0.1
                                  │ │ └── @types/iobroker@1.4.13 deduped
                                  │ ├── promise@8.0.1 deduped
                                  │ ├── querystring@0.2.0
                                  │ └─┬ request@2.83.0
                                  │   ├── aws-sign2@0.7.0 deduped
                                  │   ├── aws4@1.9.1 deduped
                                  │   ├── forever-agent@0.6.1 deduped
                                  │   ├── form-data@2.3.3 deduped
                                  │   ├─┬ har-validator@5.0.3
                                  │   │ ├─┬ ajv@5.5.2
                                  │   │ │ ├── co@4.6.0
                                  │   │ │ ├── fast-deep-equal@1.1.0
                                  │   │ │ ├── fast-json-stable-stringify@2.1.0 deduped
                                  │   │ │ └── json-schema-traverse@0.3.1
                                  │   │ └── har-schema@2.0.0 deduped
                                  │   ├─┬ hawk@6.0.2
                                  │   │ ├─┬ boom@4.3.1
                                  │   │ │ └── hoek@4.2.1 deduped
                                  │   │ ├─┬ cryptiles@3.1.4
                                  │   │ │ └─┬ boom@5.2.0
                                  │   │ ├── hoek@4.2.1 deduped
                                  │   │ └─┬ sntp@2.1.0
                                  │   ├── http-signature@1.2.0 deduped
                                  │   ├── is-typedarray@1.0.0 deduped
                                  │   ├── json-stringify-safe@5.0.1 deduped
                                  │   ├── mime-types@2.1.34 deduped
                                  │   ├── oauth-sign@0.8.2
                                  │   ├── performance-now@2.1.0 deduped
                                  │   ├── qs@6.5.2
                                  │   ├── stringstream@0.0.6
                                  │   ├─┬ tough-cookie@2.3.4
                                  │   │ └── punycode@1.4.1
                                  │   ├── tunnel-agent@0.6.0 deduped
                                  │   └── uuid@3.4.0 deduped
                                  ├─┬ iobroker.statistics@1.0.9
                                  │ └── cron@1.8.2 deduped
                                  ├─┬ iobroker.synology@1.1.3
                                  │ ├─┬ @iobroker/adapter-core@2.4.0
                                  │ │ └─┬ @types/iobroker@3.2.4
                                  │ └─┬ syno@3.0.0
                                  │   ├── commander@4.1.1
                                  │   ├─┬ js-yaml@3.14.1
                                  │   │ ├─┬ argparse@1.0.10
                                  │   │ │ └── sprintf-js@1.0.3
                                  │   │ └── esprima@4.0.1 deduped
                                  │   ├── lodash@4.17.21 deduped
                                  │   ├── minimist@0.2.1
                                  │   ├─┬ nconf@0.10.0
                                  │   │ ├── async@1.5.2
                                  │   │ ├── ini@1.3.5
                                  │   │ ├── secure-keys@1.0.0
                                  │   │ └─┬ yargs@3.32.0
                                  │   │   ├── camelcase@2.1.1
                                  │   │   ├── cliui@3.2.0 deduped
                                  │   │   ├── decamelize@1.2.0 deduped
                                  │   │   ├── os-locale@1.4.0 deduped
                                  │   │   ├── window-size@0.1.4
                                  │   │   └── y18n@3.2.1 deduped
                                  │   ├── ospath@1.2.2
                                  │   ├─┬ otplib@11.0.1
                                  │   │ └── thirty-two@1.0.2
                                  │   ├── pluralize@8.0.0
                                  ├─┬ iobroker.tankerkoenig@2.1.1
                                  ├─┬ iobroker.telegram@1.11.1
                                  │ ├─┬ axios@0.25.0
                                  │ ├─┬ node-telegram-bot-api@0.56.0
                                  │ │ ├─┬ array.prototype.findindex@2.1.0
                                  │ │ │ ├─┬ define-properties@1.1.3
                                  │ │ │ │ └── object-keys@1.1.1
                                  │ │ │ └─┬ es-abstract@1.19.1
                                  │ │ │   ├── call-bind@1.0.2 deduped
                                  │ │ │   ├─┬ es-to-primitive@1.2.1
                                  │ │ │   │ ├── is-callable@1.2.4 deduped
                                  │ │ │   │ ├─┬ is-date-object@1.0.5
                                  │ │ │   │ │ └── has-tostringtag@1.0.0 deduped
                                  │ │ │   │ └─┬ is-symbol@1.0.4
                                  │ │ │   │   └── has-symbols@1.0.2 deduped
                                  │ │ │   ├── function-bind@1.1.1 deduped
                                  │ │ │   ├─┬ get-intrinsic@1.1.1
                                  │ │ │   │ ├── function-bind@1.1.1 deduped
                                  │ │ │   │ ├── has@1.0.3 deduped
                                  │ │ │   ├─┬ get-symbol-description@1.0.0
                                  │ │ │   │ ├── call-bind@1.0.2 deduped
                                  │ │ │   │ └── get-intrinsic@1.1.1 deduped
                                  │ │ │   ├── has-symbols@1.0.2
                                  │ │ │   ├─┬ internal-slot@1.0.3
                                  │ │ │   │ ├── get-intrinsic@1.1.1 deduped
                                  │ │ │   │ └─┬ side-channel@1.0.4
                                  │ │ │   │   └── object-inspect@1.12.0 deduped
                                  │ │ │   ├── is-negative-zero@2.0.2
                                  │ │ │   ├─┬ is-regex@1.1.4
                                  │ │ │   │ └─┬ has-tostringtag@1.0.0
                                  │ │ │   ├── is-shared-array-buffer@1.0.1
                                  │ │ │   ├─┬ is-string@1.0.7
                                  │ │ │   ├─┬ is-weakref@1.0.2
                                  │ │ │   │ └── call-bind@1.0.2 deduped
                                  │ │ │   ├── object-inspect@1.12.0
                                  │ │ │   ├── object-keys@1.1.1 deduped
                                  │ │ │   ├─┬ object.assign@4.1.2
                                  │ │ │   │ ├── define-properties@1.1.3 deduped
                                  │ │ │   │ ├── has-symbols@1.0.2 deduped
                                  │ │ │   │ └── object-keys@1.1.1 deduped
                                  │ │ │   ├─┬ string.prototype.trimend@1.0.4
                                  │ │ │   │ └── define-properties@1.1.3 deduped
                                  │ │ │   ├─┬ string.prototype.trimstart@1.0.4
                                  │ │ │   └─┬ unbox-primitive@1.0.1
                                  │ │ │     ├── has-bigints@1.0.1
                                  │ │ │     └─┬ which-boxed-primitive@1.0.2
                                  │ │ │       ├─┬ is-bigint@1.0.4
                                  │ │ │       │ └── has-bigints@1.0.1 deduped
                                  │ │ │       ├─┬ is-boolean-object@1.1.2
                                  │ │ │       ├─┬ is-number-object@1.0.6
                                  │ │ │       ├── is-string@1.0.7 deduped
                                  │ │ │       └── is-symbol@1.0.4 deduped
                                  │ │ ├─┬ bl@1.2.3
                                  │ │ ├── bluebird@3.7.2 deduped
                                  │ │ ├─┬ debug@3.2.7
                                  │ │ │ └── ms@2.1.3
                                  │ │ ├── depd@1.1.2 deduped
                                  │ │ ├── eventemitter3@3.1.2
                                  │ │ ├── file-type@3.9.0
                                  │ │ ├── mime@1.6.0
                                  │ │ ├─┬ pump@2.0.1
                                  │ │ └─┬ request-promise@4.2.6
                                  │ │   ├─┬ request-promise-core@1.1.4
                                  │ │   ├── stealthy-require@1.1.1 deduped
                                  │ └─┬ socksv5@0.0.6
                                  │   └─┬ ipv6@3.1.1
                                  │     ├─┬ cli@0.4.5
                                  │     ├─┬ cliff@0.1.10
                                  │     │ ├── eyes@0.1.8 deduped
                                  │     │ └─┬ winston@0.8.3
                                  │     │   ├── async@0.2.10
                                  │     │   ├── colors@0.6.2
                                  │     │   ├── cycle@1.0.3 deduped
                                  │     │   ├── pkginfo@0.3.1
                                  │     └── sprintf@0.1.3
                                  ├─┬ iobroker.terminal@0.1.2
                                  │ ├─┬ UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
                                  │ ├── body-parser@1.19.2 deduped
                                  │ ├── commander@5.1.0
                                  │ ├─┬ connect@3.7.0
                                  │ │ ├── debug@2.6.9 deduped
                                  │ │ ├── finalhandler@1.1.2 deduped
                                  │ │ ├── parseurl@1.3.3 deduped
                                  │ │ └── utils-merge@1.0.1 deduped
                                  │ ├── connect-flash@0.1.1 deduped
                                  │ ├── express@4.17.3 deduped
                                  │ ├── nan@2.15.0
                                  │ ├─┬ passport@0.2.2
                                  │ │ ├── passport-strategy@1.0.0 deduped
                                  │ │ └── pause@0.0.1 deduped
                                  │ ├── passport-local@1.0.0 deduped
                                  │ ├─┬ send@0.17.2
                                  │ │ ├── destroy@1.0.4
                                  │ │ ├── encodeurl@1.0.2 deduped
                                  │ │ ├── escape-html@1.0.3 deduped
                                  │ │ ├── etag@1.8.1 deduped
                                  │ │ ├── fresh@0.5.2 deduped
                                  │ │ ├── http-errors@1.8.1 deduped
                                  │ │ ├── mime@1.6.0 deduped
                                  │ │ ├── ms@2.1.3
                                  │ │ ├── on-finished@2.3.0 deduped
                                  │ │ ├── range-parser@1.2.1 deduped
                                  │ │ └── statuses@1.5.0 deduped
                                  │ ├── socket.io@1.7.2 deduped
                                  │ ├── uid-number@0.0.6
                                  │ └── xtend@4.0.2
                                  ├─┬ iobroker.text2command@2.1.1
                                  ├─┬ iobroker.tr-064@4.2.15
                                  ├─┬ iobroker.upnp@1.0.19
                                  │ ├── ip@1.1.5
                                  │ ├── node-ssdp@4.0.1 deduped
                                  │ ├─┬ parsexmlresponse@0.0.5
                                  │ ├─┬ portfinder@1.0.28
                                  │ │ ├── async@2.6.3 deduped
                                  │ │ ├─┬ debug@3.2.7
                                  │ │ │ └── ms@2.1.3
                                  │ │ └─┬ mkdirp@0.5.5
                                  │ └── xmldom@0.6.0
                                  ├─┬ iobroker.vis@1.4.5
                                  │ └── jsonwebtoken@8.5.1 deduped
                                  ├── iobroker.vis-bars@0.1.4
                                  ├─┬ iobroker.vis-colorpicker@1.2.0
                                  ├── iobroker.vis-fancyswitch@1.1.0
                                  ├─┬ iobroker.vis-google-fonts@1.0.3
                                  ├── iobroker.vis-hqwidgets@1.1.9
                                  ├── iobroker.vis-jqui-mfd@1.0.12
                                  ├── iobroker.vis-metro@1.1.2
                                  ├─┬ iobroker.vis-players@0.1.6
                                  │ └── @iobroker/adapter-core@1.0.3 deduped
                                  ├─┬ iobroker.vis-plumb@1.0.2
                                  ├── iobroker.vis-timeandweather@1.1.7
                                  ├── iobroker.vis-weather@2.5.5
                                  ├─┬ iobroker.web@3.4.16
                                  │ ├── iobroker.simple-api@2.6.2 deduped
                                  │ ├── iobroker.socketio@3.1.5 deduped
                                  │ ├─┬ mime-types@2.1.34
                                  │ │ └── mime-db@1.51.0
                                  │ ├── passport@0.5.2 deduped
                                  │ ├── passport.socketio@3.7.0 deduped
                                  │ │ ├─┬ debug@3.1.0
                                  │ │ │ └── ms@2.0.0 deduped
                                  │ │ │ ├─┬ engine.io-parser@2.2.1
                                  │ │ │ │ ├── after@0.8.2 deduped
                                  │ │ │ │ ├── arraybuffer.slice@0.0.7
                                  │ │ │ │ ├── base64-arraybuffer@0.1.4
                                  │ │ │ │ ├── blob@0.0.5
                                  │ │ │ │ └── has-binary2@1.0.3 deduped
                                  │ │ │ ├── ws@7.4.6
                                  ├─┬ UNMET DEPENDENCY iobroker.zigbee@1.6.16
                                  │ ├── tar@6.1.11 deduped
                                  │ ├── UNMET DEPENDENCY typescript@4.5.4
                                  │ ├─┬ zigbee-herdsman@0.14.16
                                  │ │ ├── debounce@1.2.1
                                  │ │ ├─┬ debug@4.3.3
                                  │ │ │ └── ms@2.1.2
                                  │ │ ├── fast-deep-equal@3.1.3
                                  │ │ ├── mixin-deep@2.0.1
                                  │ │ ├─┬ mz@2.7.0
                                  │ │ │ ├── any-promise@1.3.0
                                  │ │ │ ├── object-assign@4.1.1
                                  │ │ │ └─┬ thenify-all@1.6.0
                                  │ │ │   └─┬ thenify@3.3.1
                                  │ │ │     └── any-promise@1.3.0 deduped
                                  │ │ ├─┬ serialport@9.2.8
                                  │ │ │ ├─┬ @serialport/binding-mock@9.2.4
                                  │ │ │ │ ├─┬ @serialport/binding-abstract@9.2.3
                                  │ │ │ │ │ └── debug@4.3.3 deduped
                                  │ │ │ ├─┬ @serialport/bindings@9.2.8
                                  │ │ │ │ ├── @serialport/binding-abstract@9.2.3 deduped
                                  │ │ │ │ ├── @serialport/parser-readline@9.2.4 deduped
                                  │ │ │ │ ├─┬ bindings@1.5.0
                                  │ │ │ │ │ └── file-uri-to-path@1.0.0
                                  │ │ │ │ ├── nan@2.15.0
                                  │ │ │ │ └─┬ prebuild-install@7.0.1
                                  │ │ │ │   ├── detect-libc@2.0.0
                                  │ │ │ │   ├── expand-template@2.0.3
                                  │ │ │ │   ├── github-from-package@0.0.0
                                  │ │ │ │   ├── mkdirp-classic@0.5.3
                                  │ │ │ │   ├── napi-build-utils@1.0.2
                                  │ │ │ │   ├─┬ node-abi@3.8.0
                                  │ │ │ │   │ └─┬ semver@7.3.5
                                  │ │ │ │   │   └─┬ lru-cache@6.0.0
                                  │ │ │ │   │     └── yallist@4.0.0
                                  │ │ │ │   ├─┬ npmlog@4.1.2
                                  │ │ │ │   │ ├─┬ are-we-there-yet@1.1.7
                                  │ │ │ │   │ │ ├── delegates@1.0.0
                                  │ │ │ │   │ │ └─┬ readable-stream@2.3.7
                                  │ │ │ │   │ │   ├── core-util-is@1.0.3
                                  │ │ │ │   │ │   ├── inherits@2.0.4 deduped
                                  │ │ │ │   │ │   ├── isarray@1.0.0
                                  │ │ │ │   │ │   ├── process-nextick-args@2.0.1
                                  │ │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
                                  │ │ │ │   │ │   ├─┬ string_decoder@1.1.1
                                  │ │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                                  │ │ │ │   │ │   └── util-deprecate@1.0.2
                                  │ │ │ │   │ ├─┬ gauge@2.7.4
                                  │ │ │ │   │ │ ├── aproba@1.2.0
                                  │ │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
                                  │ │ │ │   │ │ ├── has-unicode@2.0.1
                                  │ │ │ │   │ │ ├── object-assign@4.1.1 deduped
                                  │ │ │ │   │ │ ├── signal-exit@3.0.7
                                  │ │ │ │   │ │ ├─┬ string-width@1.0.2
                                  │ │ │ │   │ │ │ ├── code-point-at@1.1.0
                                  │ │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                  │ │ │ │   │ │ │ │ └── number-is-nan@1.0.1
                                  │ │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                                  │ │ │ │   │ │ ├─┬ strip-ansi@3.0.1
                                  │ │ │ │   │ │ │ └── ansi-regex@2.1.1
                                  │ │ │ │   │ │ └─┬ wide-align@1.1.5
                                  │ │ │ │   │ │   └── string-width@1.0.2 deduped
                                  │ │ │ │   │ └── set-blocking@2.0.0
                                  │ │ │ │   ├─┬ pump@3.0.0
                                  │ │ │ │   │ ├─┬ end-of-stream@1.4.4
                                  │ │ │ │   │ │ └── once@1.4.0 deduped
                                  │ │ │ │   │ └─┬ once@1.4.0
                                  │ │ │ │   ├─┬ rc@1.2.8
                                  │ │ │ │   │ ├── deep-extend@0.6.0
                                  │ │ │ │   │ ├── ini@1.3.8
                                  │ │ │ │   │ ├── minimist@1.2.5 deduped
                                  │ │ │ │   │ └── strip-json-comments@2.0.1
                                  │ │ │ │   ├─┬ simple-get@4.0.1
                                  │ │ │ │   │ ├─┬ decompress-response@6.0.0
                                  │ │ │ │   │ │ └── mimic-response@3.1.0
                                  │ │ │ │   │ └── simple-concat@1.0.1
                                  │ │ │ │   ├─┬ tar-fs@2.1.1
                                  │ │ │ │   │ ├── chownr@1.1.4
                                  │ │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
                                  │ │ │ │   │ ├── pump@3.0.0 deduped
                                  │ │ │ │   │ └─┬ tar-stream@2.2.0
                                  │ │ │ │   │   ├─┬ bl@4.1.0
                                  │ │ │ │   │   │ ├─┬ buffer@5.7.1
                                  │ │ │ │   │   │ │ ├── base64-js@1.5.1
                                  │ │ │ │   │   │ │ └── ieee754@1.2.1
                                  │ │ │ │   │   │ └─┬ readable-stream@3.6.0
                                  │ │ │ │   │   │   ├── string_decoder@1.1.1 deduped
                                  │ │ │ │   │   │   └── util-deprecate@1.0.2 deduped
                                  │ │ │ │   │   ├── fs-constants@1.0.0
                                  │ │ │ │   └─┬ tunnel-agent@0.6.0
                                  │ │ │ ├── @serialport/parser-byte-length@9.2.4
                                  │ │ │ ├── @serialport/parser-cctalk@9.2.4
                                  │ │ │ ├── @serialport/parser-delimiter@9.2.4
                                  │ │ │ ├── @serialport/parser-inter-byte-timeout@9.2.4
                                  │ │ │ ├─┬ @serialport/parser-readline@9.2.4
                                  │ │ │ │ └── @serialport/parser-delimiter@9.2.4 deduped
                                  │ │ │ ├── @serialport/parser-ready@9.2.4
                                  │ │ │ ├── @serialport/parser-regex@9.2.4
                                  │ │ │ ├─┬ @serialport/stream@9.2.4
                                  │ │ └── slip@1.0.2
                                  │ └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.422
                                  │   ├─┬ UNMET DEPENDENCY axios@0.25.0
                                  │   │ └── UNMET DEPENDENCY follow-redirects@1.14.8
                                  │   ├── UNMET DEPENDENCY buffer-crc32@0.2.13
                                  │   ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
                                  │   │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
                                  │   │ │ └── UNMET DEPENDENCY debug@4.3.3
                                  │   │ └─┬ UNMET DEPENDENCY debug@4.3.3
                                  │   │   └── UNMET DEPENDENCY ms@2.1.2
                                  │   ├─┬ UNMET DEPENDENCY tar-stream@2.2.0
                                  │   │ ├─┬ UNMET DEPENDENCY bl@4.1.0
                                  │   │ │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                                  │   │ │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                                  │   │ │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                                  │   │ │ ├── UNMET DEPENDENCY inherits@2.0.4
                                  │   │ │ └── UNMET DEPENDENCY readable-stream@3.6.0
                                  │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                                  │   │ │ └─┬ UNMET DEPENDENCY once@1.4.0
                                  │   │ │   └── UNMET DEPENDENCY wrappy@1.0.2
                                  │   │ ├── UNMET DEPENDENCY fs-constants@1.0.0
                                  │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                                  │   │   ├─┬ UNMET DEPENDENCY string_decoder@1.3.0
                                  │   │   │ └── UNMET DEPENDENCY safe-buffer@5.2.1
                                  │   │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                                  │   └─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.14
                                  │     ├── UNMET DEPENDENCY debounce@1.2.1
                                  │     ├─┬ UNMET DEPENDENCY debug@4.3.3
                                  │     ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
                                  │     ├── UNMET DEPENDENCY mixin-deep@2.0.1
                                  │     ├─┬ UNMET DEPENDENCY mz@2.7.0
                                  │     │ ├── UNMET DEPENDENCY any-promise@1.3.0
                                  │     │ ├── UNMET DEPENDENCY object-assign@4.1.1
                                  │     │ └─┬ UNMET DEPENDENCY thenify-all@1.6.0
                                  │     │   └─┬ UNMET DEPENDENCY thenify@3.3.1
                                  │     │     └── UNMET DEPENDENCY any-promise@1.3.0
                                  │     ├─┬ UNMET DEPENDENCY serialport@9.2.8
                                  │     │ ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
                                  │     │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                                  │     │ │ │ └── UNMET DEPENDENCY debug@4.3.3
                                  │     │ ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.8
                                  │     │ │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                                  │     │ │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                                  │     │ │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
                                  │     │ │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
                                  │     │ │ ├── UNMET DEPENDENCY debug@4.3.3
                                  │     │ │ ├── UNMET DEPENDENCY nan@2.15.0
                                  │     │ │ └─┬ UNMET DEPENDENCY prebuild-install@7.0.1
                                  │     │ │   ├── UNMET DEPENDENCY detect-libc@2.0.0
                                  │     │ │   ├── UNMET DEPENDENCY expand-template@2.0.3
                                  │     │ │   ├── UNMET DEPENDENCY github-from-package@0.0.0
                                  │     │ │   ├── UNMET DEPENDENCY minimist@1.2.5
                                  │     │ │   ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                                  │     │ │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
                                  │     │ │   ├─┬ UNMET DEPENDENCY node-abi@3.8.0
                                  │     │ │   │ └─┬ UNMET DEPENDENCY semver@7.3.5
                                  │     │ │   │   └─┬ UNMET DEPENDENCY lru-cache@6.0.0
                                  │     │ │   │     └── UNMET DEPENDENCY yallist@4.0.0
                                  │     │ │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
                                  │     │ │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
                                  │     │ │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
                                  │     │ │   │ │ └─┬ UNMET DEPENDENCY readable-stream@2.3.7
                                  │     │ │   │ │   ├── UNMET DEPENDENCY core-util-is@1.0.3
                                  │     │ │   │ │   ├── UNMET DEPENDENCY inherits@2.0.4
                                  │     │ │   │ │   ├── UNMET DEPENDENCY isarray@1.0.0
                                  │     │ │   │ │   ├── UNMET DEPENDENCY process-nextick-args@2.0.1
                                  │     │ │   │ │   ├── UNMET DEPENDENCY safe-buffer@5.1.2
                                  │     │ │   │ │   ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
                                  │     │ │   │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
                                  │     │ │   │ │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                                  │     │ │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                                  │     │ │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
                                  │     │ │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
                                  │     │ │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                                  │     │ │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
                                  │     │ │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
                                  │     │ │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.7
                                  │     │ │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
                                  │     │ │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
                                  │     │ │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
                                  │     │ │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
                                  │     │ │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
                                  │     │ │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
                                  │     │ │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
                                  │     │ │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
                                  │     │ │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
                                  │     │ │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
                                  │     │ │   ├─┬ UNMET DEPENDENCY pump@3.0.0
                                  │     │ │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                                  │     │ │   │ │ └── UNMET DEPENDENCY once@1.4.0
                                  │     │ │   │ └─┬ UNMET DEPENDENCY once@1.4.0
                                  │     │ │   │   └── UNMET DEPENDENCY wrappy@1.0.2
                                  │     │ │   ├─┬ UNMET DEPENDENCY rc@1.2.8
                                  │     │ │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
                                  │     │ │   │ ├── UNMET DEPENDENCY ini@1.3.8
                                  │     │ │   │ ├── UNMET DEPENDENCY minimist@1.2.5
                                  │     │ │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
                                  │     │ │   ├─┬ UNMET DEPENDENCY simple-get@4.0.1
                                  │     │ │   │ ├─┬ UNMET DEPENDENCY decompress-response@6.0.0
                                  │     │ │   │ │ └── UNMET DEPENDENCY mimic-response@3.1.0
                                  │     │ │   │ ├── UNMET DEPENDENCY once@1.4.0
                                  │     │ │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
                                  │     │ │   ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
                                  │     │ │   │ ├── UNMET DEPENDENCY chownr@1.1.4
                                  │     │ │   │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                                  │     │ │   │ ├── UNMET DEPENDENCY pump@3.0.0
                                  │     │ │   │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
                                  │     │ │   │   ├─┬ UNMET DEPENDENCY bl@4.1.0
                                  │     │ │   │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                                  │     │ │   │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                                  │     │ │   │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                                  │     │ │   │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                                  │     │ │   │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
                                  │     │ │   │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
                                  │     │ │   │   ├── UNMET DEPENDENCY fs-constants@1.0.0
                                  │     │ │   └─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
                                  │     │ ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
                                  │     │ ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
                                  │     │ ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                                  │     │ ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
                                  │     │ ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                                  │     │ │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                                  │     │ ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
                                  │     │ ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
                                  │     │ ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
                                  │     └── UNMET DEPENDENCY slip@1.0.2
                                  ├── semver@5.7.1
                                  └─┬ yargs@7.1.0
                                    ├── camelcase@3.0.0
                                    ├─┬ cliui@3.2.0
                                    ├─┬ os-locale@1.4.0
                                    │ └─┬ lcid@1.0.0
                                    ├─┬ read-pkg-up@1.0.1
                                    │ ├─┬ find-up@1.1.2
                                    │ │ ├─┬ path-exists@2.1.0
                                    │ │ │ └── pinkie-promise@2.0.1 deduped
                                    │ │ └─┬ pinkie-promise@2.0.1
                                    │ │   └── pinkie@2.0.4
                                    │ └─┬ read-pkg@1.1.0
                                    │   ├─┬ load-json-file@1.1.0
                                    │   │ ├─┬ parse-json@2.2.0
                                    │   │ │ └─┬ error-ex@1.3.2
                                    │   │ │   └── is-arrayish@0.2.1
                                    │   │ ├── pify@2.3.0
                                    │   │ ├── pinkie-promise@2.0.1 deduped
                                    │   │ └─┬ strip-bom@2.0.0
                                    │   │   └── is-utf8@0.2.1
                                    │   ├─┬ normalize-package-data@2.5.0
                                    │   │ ├── hosted-git-info@2.8.8
                                    │   │ ├─┬ resolve@1.17.0
                                    │   │ │ └── path-parse@1.0.6
                                    │   │ └─┬ validate-npm-package-license@3.0.4
                                    │   │   ├─┬ spdx-correct@3.1.0
                                    │   │   │ ├── spdx-expression-parse@3.0.0 deduped
                                    │   │   │ └── spdx-license-ids@3.0.5
                                    │   │   └─┬ spdx-expression-parse@3.0.0
                                    │   │     ├── spdx-exceptions@2.3.0
                                    │   │     └── spdx-license-ids@3.0.5 deduped
                                    │   └─┬ path-type@1.1.0
                                    │     ├── pify@2.3.0 deduped
                                    ├── require-main-filename@1.0.1
                                    ├── set-blocking@2.0.0
                                    ├── which-module@1.0.0
                                    ├── y18n@3.2.1
                                    └─┬ yargs-parser@5.0.0
                                      └── camelcase@3.0.0 deduped
                                  npm ERR! missing: tr-O64@0.2.4, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.hue@3.5.31, required by iobroker.inst@2.0.3
                                  npm ERR! missing: iobroker.zigbee@1.6.16, required by iobroker.inst@2.0.3
                                  npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
                                  npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.hue@3.5.31
                                  npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.1
                                  npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.zigbee@1.6.16
                                  npm ERR! missing: typescript@4.5.4, required by iobroker.zigbee@1.6.16
                                  npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigbee@1.6.16
                                  npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
                                  npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14.0.422
                                  npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converters@14.0.422
                                  npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.422
                                  npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converters@14.0.422
                                  npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
                                  npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
                                  npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
                                  npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
                                  npm ERR! missing: ms@2.1.2, required by debug@4.3.3
                                  npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
                                  npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
                                  npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
                                  npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
                                  npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
                                  npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
                                  npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
                                  npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
                                  npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
                                  npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
                                  npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
                                  npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
                                  npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
                                  npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
                                  npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
                                  npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
                                  npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
                                  npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
                                  npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
                                  npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
                                  npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
                                  npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
                                  npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
                                  npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
                                  npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/binding-mock@9.2.4
                                  npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
                                  npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
                                  npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bindings@9.2.8
                                  npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bindings@9.2.8
                                  npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
                                  npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
                                  npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
                                  npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
                                  npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
                                  npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
                                  npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
                                  npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
                                  npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
                                  npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
                                  npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
                                  npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
                                  npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
                                  npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
                                  npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
                                  npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
                                  npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
                                  npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
                                  npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
                                  npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
                                  npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
                                  npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
                                  npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
                                  npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
                                  npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
                                  npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
                                  npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
                                  npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
                                  npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
                                  npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
                                  npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
                                  npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
                                  npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
                                  npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
                                  npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
                                  npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
                                  npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
                                  npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
                                  npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
                                  npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
                                  npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
                                  npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
                                  npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
                                  npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
                                  npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
                                  npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
                                  npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
                                  npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
                                  npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
                                  npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
                                  npm ERR! missing: once@1.4.0, required by pump@3.0.0
                                  npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
                                  npm ERR! missing: ini@1.3.8, required by rc@1.2.8
                                  npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
                                  npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
                                  npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
                                  npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
                                  npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
                                  npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
                                  npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
                                  npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
                                  npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
                                  npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
                                  npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
                                  npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
                                  npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/parser-readline@9.2.4
                                  npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
                                    M
                                    M
                                    Markus Faltermeier
                                    #77
                                    wieso npm v8?
                                    Ich dachte ich habe v6 drauf. Das zeigt mir zumindest "npm -v" an
                                      wieso npm v8?
                                      #78
                                      @markus-faltermeier sagte in Probleme bei Update von admin:
                                      wieso npm v8?
                                      und vorher war kein npm >6 drauf?
                                        wieso npm v8?
                                        M
                                        M
                                        Markus Faltermeier
                                        #79
                                        vorher hatte ich v7 drauf. Das haben wir aber ganz am anfang geändert. Da hatte ich den node js auf V14 upgedated und der npm war danach auf V6.14.16
                                          #80
                                          und npm v7 war ja nicht untätig. Damit wurde die package-lock.json in version2 geschrieben.
                                          npm v6 braucht diese aber in v1
                                          hab dir extra nochmal die Meldung aus dem Log zitiert
                                          Lösch die package-lock.json. Die wird dann beim nächsten Aufruf von npm in der richtigen Version neu angelegt.
                                          83.9k
                                          1.4m
