  4. [gelöst] Probleme bei Update von admin
admin-adapterehostunreachfehlermeldungupdateupdate adapter
85 Beiträge 6 Kommentatoren 15.0k Aufrufe 3 Beobachtet
  • M Markus Faltermeier
    hab ich probiert. Ich bekomme bei diesem Befehl auch jede Menge Fehler:
      │   │ ├─┬ parse-json@2.2.0
      │   │ │ └─┬ error-ex@1.3.2
      │   │ │   └── is-arrayish@0.2.1
      │   │ ├── pify@2.3.0
      │   │ ├── pinkie-promise@2.0.1 deduped
      │   │ └─┬ strip-bom@2.0.0
      │   │   └── is-utf8@0.2.1
      │   ├─┬ normalize-package-data@2.5.0
      │   │ ├── hosted-git-info@2.8.8
      │   │ ├─┬ resolve@1.17.0
      │   │ │ └── path-parse@1.0.6
      │   │ ├── semver@5.7.1 deduped
      │   │ └─┬ validate-npm-package-license@3.0.4
      │   │   ├─┬ spdx-correct@3.1.0
      │   │   │ ├── spdx-expression-parse@3.0.0 deduped
      │   │   │ └── spdx-license-ids@3.0.5
      │   │   └─┬ spdx-expression-parse@3.0.0
      │   │     ├── spdx-exceptions@2.3.0
      │   │     └── spdx-license-ids@3.0.5 deduped
      │   └─┬ path-type@1.1.0
      │     ├── graceful-fs@4.2.4 deduped
      │     ├── pify@2.3.0 deduped
      │     └── pinkie-promise@2.0.1 deduped
      ├── require-directory@2.1.1
      ├── require-main-filename@1.0.1
      ├── set-blocking@2.0.0
      ├─┬ string-width@1.0.2
      │ ├── code-point-at@1.1.0
      │ ├─┬ is-fullwidth-code-point@1.0.0
      │ │ └── number-is-nan@1.0.1
      │ └── strip-ansi@3.0.1 deduped
      ├── which-module@1.0.0
      ├── y18n@3.2.1
      └─┬ yargs-parser@5.0.0
        └── camelcase@3.0.0 deduped
    npm ERR! missing: iobroker.terminal@0.1.2, required by iobroker.inst@2.0.3
    npm ERR! missing: iobroker.zigbee@1.6.16, required by iobroker.inst@2.0.3
    npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
    npm ERR! missing: commander@5.1.0, required by iobroker.terminal@0.1.2
    npm ERR! missing: connect@3.7.0, required by iobroker.terminal@0.1.2
    npm ERR! missing: passport@0.2.2, required by iobroker.terminal@0.1.2
    npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.zigbee@1.6.        16
    npm ERR! missing: typescript@4.5.4, required by iobroker.zigbee@1.6.16
    npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigb        ee@1.6.16
    npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.        1
    npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
    npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14        .0.422
    npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converter        s@14.0.422
    npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.        422
    npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converter        s@14.0.422
    npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
    npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
    npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
    npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
    npm ERR! missing: ms@2.1.2, required by debug@4.3.3
    npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
    npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
    npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
    npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
    npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
    npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
    npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
    npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
    npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
    npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
    npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
    npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
    npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
    npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
    npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
    npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
    npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
    npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
    npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
    npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
    npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
    npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
    npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
    npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
    npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
    npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
    npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
    npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
    npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
    npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
    npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9        .2.8
    npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
    npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2        .8
    npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by seria        lport@9.2.8
    npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.        8
    npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
    npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
    npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
    npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
    npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bi        nding-mock@9.2.4
    npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
    npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
    npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bi        ndings@9.2.8
    npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bin        dings@9.2.8
    npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
    npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
    npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
    npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
    npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
    npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
    npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
    npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
    npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
    npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
    npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
    npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
    npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
    npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
    npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
    npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
    npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
    npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
    npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
    npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
    npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
    npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
    npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
    npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
    npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
    npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
    npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
    npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
    npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
    npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
    npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
    npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
    npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
    npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
    npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
    npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
    npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
    npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
    npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
    npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
    npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
    npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
    npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
    npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
    npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
    npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
    npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
    npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
    npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
    npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
    npm ERR! missing: once@1.4.0, required by pump@3.0.0
    npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
    npm ERR! missing: ini@1.3.8, required by rc@1.2.8
    npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
    npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
    npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
    npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
    npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
    npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
    npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
    npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
    npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
    npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
    npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
    npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
    npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/pa        rser-readline@9.2.4
    npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
    @markus-faltermeier sagte in Probleme bei Update von admin:
    dann ist bei dir wahrscheinlich auch deine node und npm Installation verbogen.
    Da fehlt doch was
    Bitte vollständige Ein- und Ausgabe posten!
    Da kenne ich mich aber nicht aus. Vielleicht kann dir da @Thomas-Braun helfen
    M 2 Antworten Letzte Antwort
      Da fehlt doch was
      M
      M
      Markus Faltermeier
      wie kann ich das machen. Das Terminal schneidet oben was weg...
      Die Ausgabe ist scheinbar zu lang
        Da fehlt doch was
        M
        M
        Markus Faltermeier
        ich hab jetzt mal alles kopiert soweit wie das terminal es mir noch anzeigt.
        │ │ ├── https-proxy-agent@5.0.0 deduped
        │ │ ├── lru_map@0.3.3 deduped
        │ │ └── tslib@1.11.2 deduped
        │ ├─┬ bent@7.3.12
        │ │ ├── bytesish@0.4.4
        │ │ ├── caseless@0.12.0 deduped
        │ │ └── is-stream@2.0.1
        │ └── xml2json-light@1.0.6
        ├─┬ iobroker.deconz@1.3.19
        │ ├─┬ @iobroker/adapter-core@2.5.1
        │ │ └─┬ @types/iobroker@3.3.4
        │ │   └── @types/node@13.13.5 deduped
        │ ├── @sentry/integrations@6.16.1 deduped
        │ ├── @sentry/node@6.16.1 deduped
        │ ├── request@2.88.2 deduped
        │ ├── source-map-support@0.5.21 deduped
        │ └── ws@7.5.6
        ├─┬ iobroker.denon@1.12.1
        │ └─┬ @iobroker/adapter-core@2.5.1
        ├─┬ iobroker.discovery@2.7.3
        │ ├─┬ mdns-discovery@0.2.6
        │ │ ├─┬ debug@2.2.0
        │ │ │ └── ms@0.7.1
        │ │ ├── dgram@1.0.1
        │ │ └─┬ dns-packet@1.3.1
        │ │   ├── ip@1.1.5 deduped
        │ │   └── safe-buffer@5.1.2 deduped
        │ ├── netmask@2.0.2
        │ ├── node-mndp@0.0.3
        │ ├─┬ node-ssdp@4.0.1
        │ │ ├─┬ async@2.6.3
        │ │ │ └── lodash@4.17.21 deduped
        │ │ ├── bluebird@3.7.2
        │ │ ├─┬ debug@3.2.7
        │ │ │ └── ms@2.1.3
        │ │ ├── extend@3.0.2 deduped
        │ │ └── ip@1.1.5 deduped
        │ └─┬ serialport@9.2.8
        │   ├─┬ @serialport/binding-mock@9.2.4
        │   │ ├─┬ @serialport/binding-abstract@9.2.3
        │   │ │ └─┬ debug@4.3.3
        │   │ │   └── ms@2.1.2
        │   │ └─┬ debug@4.3.3
        │   │   └── ms@2.1.2
        │   ├─┬ UNMET OPTIONAL DEPENDENCY @serialport/bindings@9.2.8
        │   │ ├── @serialport/binding-abstract@9.2.3 deduped
        │   │ ├── @serialport/parser-readline@9.2.4 deduped
        │   │ ├─┬ bindings@1.5.0
        │   │ │ └── file-uri-to-path@1.0.0
        │   │ ├─┬ UNMET OPTIONAL DEPENDENCY debug@4.3.3
        │   │ │ └── UNMET OPTIONAL DEPENDENCY ms@2.1.2
        │   │ ├── nan@2.15.0 deduped
        │   │ └─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@7.0.1
        │   │   ├── UNMET OPTIONAL DEPENDENCY detect-libc@2.0.1
        │   │   ├── expand-template@2.0.3 deduped
        │   │   ├── github-from-package@0.0.0 deduped
        │   │   ├── minimist@1.2.5 deduped
        │   │   ├── mkdirp-classic@0.5.3 deduped
        │   │   ├── napi-build-utils@1.0.2 deduped
        │   │   ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@3.8.0
        │   │   │ └─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
        │   │   │   └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
        │   │   │     └── yallist@4.0.0 deduped
        │   │   ├── npmlog@4.1.2 deduped
        │   │   ├── pump@3.0.0 deduped
        │   │   ├── rc@1.2.8 deduped
        │   │   ├─┬ UNMET OPTIONAL DEPENDENCY simple-get@4.0.1
        │   │   │ ├─┬ UNMET OPTIONAL DEPENDENCY decompress-response@6.0.0
        │   │   │ │ └── UNMET OPTIONAL DEPENDENCY mimic-response@3.1.0
        │   │   │ ├── once@1.4.0 deduped
        │   │   │ └── simple-concat@1.0.0 deduped
        │   │   ├── tar-fs@2.1.1 deduped
        │   │   └── tunnel-agent@0.6.0 deduped
        │   ├── @serialport/parser-byte-length@9.2.4
        │   ├── @serialport/parser-cctalk@9.2.4
        │   ├── @serialport/parser-delimiter@9.2.4
        │   ├── @serialport/parser-inter-byte-timeout@9.2.4
        │   ├─┬ @serialport/parser-readline@9.2.4
        │   │ └── @serialport/parser-delimiter@9.2.4 deduped
        │   ├── @serialport/parser-ready@9.2.4
        │   ├── @serialport/parser-regex@9.2.4
        │   ├─┬ @serialport/stream@9.2.4
        │   │ └─┬ debug@4.3.3
        │   │   └── ms@2.1.2
        │   └─┬ debug@4.3.3
        │     └── ms@2.1.2
        ├─┬ iobroker.dwd@2.7.7
        │ ├─┬ @iobroker/adapter-core@2.5.0
        │ │ └─┬ @types/iobroker@3.3.0
        │ └─┬ axios@0.21.4
        │   └── follow-redirects@1.14.8 deduped
        ├─┬ iobroker.email@1.0.10
        │ └── nodemailer@6.7.2
        ├─┬ iobroker.fhem@1.6.3
        ├─┬ iobroker.flot@1.10.7
        ├─┬ iobroker.fritzbox@0.2.1
        │ └─┬ xml2js@0.4.23
        │   ├── sax@1.2.4
        │   └── xmlbuilder@11.0.1
        ├─┬ iobroker.geofency@1.0.3
        │ └── request@2.88.2 deduped
        ├─┬ iobroker.harmony@1.2.2
        │ ├─┬ @harmonyhub/discover@1.0.8
        │ │ ├── autobind-decorator@2.4.0
        │ │ └─┬ debug@4.1.1
        │ │   └── ms@2.1.2
        │ ├─┬ @iobroker/adapter-core@1.0.3
        │ │ └─┬ @types/iobroker@1.4.13
        │ ├─┬ harmonyhubws@1.0.6
        │ │ ├── request@2.88.2 deduped
        │ │ ├─┬ request-promise-native@1.0.8
        │ │ │ ├─┬ request-promise-core@1.1.3
        │ │ │ │ └── lodash@4.17.21 deduped
        │ │ │ ├── stealthy-require@1.1.1
        │ │ │ └── tough-cookie@2.5.0 deduped
        │ │ └─┬ ws@6.2.1
        │ │   └── async-limiter@1.0.1
        │ └── semaphore@1.0.5
        ├─┬ iobroker.heatingcontrol@2.7.2
        │ ├─┬ @sentry/node@6.14.1
        │ │ ├─┬ @sentry/core@6.14.1
        │ │ │ ├── @sentry/hub@6.14.1 deduped
        │ │ │ ├─┬ @sentry/minimal@6.14.1
        │ │ │ │ ├── @sentry/hub@6.14.1 deduped
        │ │ │ │ ├── @sentry/types@6.14.1 deduped
        │ │ │ │ └── tslib@1.11.2 deduped
        │ │ │ ├── @sentry/utils@6.14.1 deduped
        │ │ ├─┬ @sentry/hub@6.14.1
        │ │ ├── @sentry/tracing@6.14.1 deduped
        │ │ ├─┬ @sentry/utils@6.14.1
        │ │ ├── cookie@0.4.1 deduped
        │ └─┬ cron@1.8.2
        │   └─┬ moment-timezone@0.5.34
        │     └── moment@2.29.1 deduped
        ├─┬ iobroker.history@1.10.5
        ├─┬ iobroker.hm-rega@3.0.35
        │ ├─┬ iconv-lite@0.6.3
        │ │ └── safer-buffer@2.1.2
        │ └── xml2js@0.4.23 deduped
        ├─┬ iobroker.hm-rpc@1.15.0
        │ ├─┬ binrpc@3.3.1
        │ │ ├─┬ binary@0.3.0
        │ │ │ ├── buffers@0.1.1
        │ │ │ └─┬ chainsaw@0.1.0
        │ │ │   └── traverse@0.3.9
        │ │ └── put@0.0.6
        │ └─┬ homematic-xmlrpc@1.0.2
        │   ├── sax@0.4.3
        │   └── xmlbuilder@0.4.2
        ├─┬ iobroker.hue@3.5.31
        │ └─┬ node-hue-api@4.0.11
        │   ├── axios@0.21.4 deduped
        │   ├── bottleneck@2.19.5
        │   └── get-ssl-certificate@2.3.3
        ├─┬ iobroker.ical@1.11.4
        │ ├── cloneextend@0.0.3
        │ ├─┬ node-ical@0.13.0
        │ │ ├── moment-timezone@0.5.34 deduped
        │ │ ├─┬ node-fetch@2.6.7
        │ │ │ └─┬ whatwg-url@5.0.0
        │ │ │   ├── tr46@0.0.3
        │ │ │   └── webidl-conversions@3.0.1
        │ │ ├── rrule@2.6.8 deduped
        │ │ └── uuid@8.3.2
        │ └─┬ rrule@2.6.8
        │   ├── luxon@1.27.0
        ├── iobroker.icons-icons8@0.0.1
        ├── iobroker.icons-mfd-svg@1.0.2
        ├── iobroker.icons-ultimate-png@1.0.1
        ├─┬ iobroker.info@1.9.8
        │ ├── jshashes@1.0.8
        │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@1.0.7
        │ ├─┬ semver@7.3.5
        │ │ └─┬ lru-cache@6.0.0
        │ └── systeminformation@5.11.3
        ├─┬ iobroker.iot@1.8.24
        │ ├─┬ aws-iot-device-sdk@2.2.11
        │ │ ├── crypto-js@4.0.0
        │ │ ├─┬ mqtt@4.2.8
        │ │ │ ├── commist@1.1.0 deduped
        │ │ │ ├─┬ concat-stream@2.0.0
        │ │ │ │ ├── buffer-from@1.1.1 deduped
        │ │ │ │ ├── inherits@2.0.4 deduped
        │ │ │ │ ├── readable-stream@3.6.0 deduped
        │ │ │ │ └── typedarray@0.0.6 deduped
        │ │ │ ├─┬ debug@4.3.3
        │ │ │ │ └── ms@2.1.2
        │ │ │ ├─┬ duplexify@4.1.2
        │ │ │ │ ├── end-of-stream@1.4.4 deduped
        │ │ │ │ └── stream-shift@1.0.1 deduped
        │ │ │ ├─┬ help-me@3.0.0
        │ │ │ │ ├── glob@7.1.6 deduped
        │ │ │ │ └── readable-stream@3.6.0 deduped
        │ │ │ ├── minimist@1.2.5 deduped
        │ │ │ ├─┬ mqtt-packet@6.10.0
        │ │ │ │ ├── bl@4.1.0 deduped
        │ │ │ │ ├── debug@4.3.3 deduped
        │ │ │ │ └── process-nextick-args@2.0.1 deduped
        │ │ │ ├── pump@3.0.0 deduped
        │ │ │ ├─┬ readable-stream@3.6.0
        │ │ │ │ ├── string_decoder@1.1.1 deduped
        │ │ │ │ └── util-deprecate@1.0.2 deduped
        │ │ │ ├── reinterval@1.1.0 deduped
        │ │ │ ├─┬ split2@3.2.2
        │ │ │ ├── ws@7.5.7
        │ │ │ └── xtend@4.0.2 deduped
        │ │ └── websocket-stream@5.5.2 deduped
        │ ├─┬ UNMET OPTIONAL DEPENDENCY canvas@2.9.0
        │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @mapbox/node-pre-gyp@1.0.8
        │ │ │ ├── detect-libc@1.0.3 deduped
        │ │ │ ├── https-proxy-agent@5.0.0 deduped
        │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY make-dir@3.1.0
        │ │ │ │ └── UNMET OPTIONAL DEPENDENCY semver@6.3.0
        │ │ │ ├── node-fetch@2.6.7 deduped
        │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY nopt@5.0.0
        │ │ │ │ └── UNMET OPTIONAL DEPENDENCY abbrev@1.1.1
        │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY npmlog@5.0.1
        │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY are-we-there-yet@2.0.0
        │ │ │ │ │ ├── delegates@1.0.0
        │ │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY readable-stream@3.6.0
        │ │ │ │ │   ├── inherits@2.0.4 deduped
        │ │ │ │ │   ├── string_decoder@1.1.1 deduped
        │ │ │ │ │   └── util-deprecate@1.0.2 deduped
        │ │ │ │ ├── console-control-strings@1.1.0
        │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY gauge@3.0.2
        │ │ │ │ │ ├── aproba@1.2.0
        │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY color-support@1.1.3
        │ │ │ │ │ ├── console-control-strings@1.1.0 deduped
        │ │ │ │ │ ├── has-unicode@2.0.1
        │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY object-assign@4.1.1
        │ │ │ │ │ ├── signal-exit@3.0.3 deduped
        │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY string-width@4.2.3
        │ │ │ │ │ │ ├── emoji-regex@8.0.0 deduped
        │ │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY is-fullwidth-code-point@3.0.0
        │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
        │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
        │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY ansi-regex@5.0.1
        │ │ │ │ │ └─┬ wide-align@1.1.3
        │ │ │ │ │   └── string-width@1.0.2 deduped
        │ │ │ │ └── set-blocking@2.0.0 deduped
        │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY rimraf@3.0.2
        │ │ │ │ └── glob@7.1.6 deduped
        │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
        │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
        │ │ │ │   └── yallist@4.0.0 deduped
        │ │ │ └── tar@6.1.11 deduped
        │ │ └─┬ simple-get@3.1.0
        │ │   ├─┬ decompress-response@4.2.1
        │ │   │ └── mimic-response@2.1.0
        │ ├─┬ echarts@4.9.0
        │ │ └── zrender@4.3.2
        │ ├── iobroker.type-detector@1.0.17
        │ ├─┬ jsdom@17.0.0
        │ │ ├── abab@2.0.5
        │ │ ├── acorn@8.7.0
        │ │ ├─┬ acorn-globals@6.0.0
        │ │ │ ├── acorn@7.4.1
        │ │ │ └── acorn-walk@7.2.0
        │ │ ├── cssom@0.5.0
        │ │ ├─┬ cssstyle@2.3.0
        │ │ │ └── cssom@0.3.8
        │ │ ├─┬ data-urls@3.0.1
        │ │ │ ├── abab@2.0.5 deduped
        │ │ │ ├── whatwg-mimetype@3.0.0
        │ │ │ └─┬ whatwg-url@10.0.0
        │ │ │   ├─┬ tr46@3.0.0
        │ │ │   │ └── punycode@2.1.1 deduped
        │ │ │   └── webidl-conversions@7.0.0
        │ │ ├── decimal.js@10.3.1
        │ │ ├─┬ domexception@2.0.1
        │ │ │ └── webidl-conversions@5.0.0
        │ │ ├─┬ escodegen@2.0.0
        │ │ │ ├── esprima@4.0.1
        │ │ │ ├── estraverse@5.3.0
        │ │ │ ├── esutils@2.0.3
        │ │ │ ├─┬ optionator@0.8.3
        │ │ │ │ ├── deep-is@0.1.4
        │ │ │ │ ├── fast-levenshtein@2.0.6
        │ │ │ │ ├─┬ levn@0.3.0
        │ │ │ │ │ ├── prelude-ls@1.1.2 deduped
        │ │ │ │ │ └── type-check@0.3.2 deduped
        │ │ │ │ ├─┬ type-check@0.3.2
        │ │ │ │ │ └── prelude-ls@1.1.2 deduped
        │ │ │ │ └── word-wrap@1.2.3
        │ │ │ └── source-map@0.6.1 deduped
        │ │ ├─┬ form-data@4.0.0
        │ │ │ ├── asynckit@0.4.0 deduped
        │ │ │ ├── combined-stream@1.0.8 deduped
        │ │ │ └── mime-types@2.1.34 deduped
        │ │ ├─┬ html-encoding-sniffer@2.0.1
        │ │ │ └── whatwg-encoding@1.0.5 deduped
        │ │ ├─┬ http-proxy-agent@4.0.1
        │ │ │ ├── @tootallnate/once@1.1.2
        │ │ │ ├── agent-base@6.0.2 deduped
        │ │ │   └── ms@2.1.2
        │ │ ├── is-potential-custom-element-name@1.0.1
        │ │ ├── nwsapi@2.2.0
        │ │ ├── parse5@6.0.1
        │ │ ├─┬ saxes@5.0.1
        │ │ │ └── xmlchars@2.2.0
        │ │ ├── symbol-tree@3.2.4
        │ │ ├─┬ tough-cookie@4.0.0
        │ │ │ ├── psl@1.8.0 deduped
        │ │ │ ├── punycode@2.1.1 deduped
        │ │ │ └── universalify@0.1.2 deduped
        │ │ ├─┬ w3c-hr-time@1.0.2
        │ │ │ └── browser-process-hrtime@1.0.0
        │ │ ├─┬ w3c-xmlserializer@2.0.0
        │ │ │ └── xml-name-validator@3.0.0 deduped
        │ │ ├── webidl-conversions@6.1.0
        │ │ ├─┬ whatwg-encoding@1.0.5
        │ │ │ └── iconv-lite@0.4.24 deduped
        │ │ ├── whatwg-mimetype@2.3.0
        │ │ ├─┬ whatwg-url@9.1.0
        │ │ │ ├─┬ tr46@2.1.0
        │ │ │ └── webidl-conversions@6.1.0 deduped
        │ │ ├── ws@8.5.0
        │ ├── moment@2.29.1
        │ ├─┬ UNMET OPTIONAL DEPENDENCY sharp@0.28.1
        │ │ ├─┬ color@3.2.1
        │ │ │ ├─┬ color-convert@1.9.3
        │ │ │ │ └── color-name@1.1.3
        │ │ │ └─┬ color-string@1.9.0
        │ │ │   ├── color-name@1.1.3 deduped
        │ │ │   └─┬ simple-swizzle@0.2.2
        │ │ │     └── is-arrayish@0.3.2
        │ │ ├── UNMET OPTIONAL DEPENDENCY node-addon-api@3.2.1
        │ │ ├─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@6.1.4
        │ │ │ ├── expand-template@2.0.3
        │ │ │ ├── github-from-package@0.0.0
        │ │ │ ├── mkdirp-classic@0.5.3 deduped
        │ │ │ ├── napi-build-utils@1.0.2
        │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@2.30.1
        │ │ │ │ └── semver@5.7.1 deduped
        │ │ │ ├─┬ npmlog@4.1.2
        │ │ │ │ ├─┬ are-we-there-yet@1.1.5
        │ │ │ │ │ ├── delegates@1.0.0 deduped
        │ │ │ │ │ └── readable-stream@2.3.7 deduped
        │ │ │ │ ├─┬ gauge@2.7.4
        │ │ │ │ │ ├── aproba@1.2.0 deduped
        │ │ │ │ │ ├── has-unicode@2.0.1 deduped
        │ │ │ │ │ ├── object-assign@4.1.0 deduped
        │ │ │ │ │ ├── string-width@1.0.2 deduped
        │ │ │ │ │ ├── strip-ansi@3.0.1 deduped
        │ │ │ │ │ └── wide-align@1.1.3 deduped
        │ │ │ ├─┬ rc@1.2.8
        │ │ │ │ ├── deep-extend@0.6.0
        │ │ │ │ ├── ini@1.3.5 deduped
        │ │ │ │ ├── minimist@1.2.5 deduped
        │ │ │ │ └── strip-json-comments@2.0.1
        │ │ │ ├── simple-get@3.1.0 deduped
        │ │ │ ├── tar-fs@2.1.1 deduped
        │ │ │ └── tunnel-agent@0.6.0 deduped
        │ └── uuid@8.3.2
        ├─┬ iobroker.javascript@5.2.21
        │ │   └── @types/node@10.17.60 deduped
        │ ├── @types/node@10.17.60
        │ ├─┬ @types/request@2.48.8
        │ │ ├── @types/caseless@0.12.2
        │ │ ├── @types/node@13.13.5
        │ │ ├── @types/tough-cookie@4.0.1
        │ │ └─┬ form-data@2.5.1
        │ ├── coffee-compiler@0.3.2
        │ ├── coffee-script@1.12.7
        │ ├── jsonata@1.8.6
        │ ├── node-inspect@2.0.0
        │ ├─┬ node-schedule@2.0.0
        │ │ ├── cron-parser@3.5.0 deduped
        │ │ ├── long-timeout@0.1.1 deduped
        │ │ └── sorted-array-functions@1.3.0 deduped
        │ ├── oauth@0.9.15
        │ ├─┬ owlintuition@0.4.0
        │ │ └─┬ xml2json@0.12.0
        │ │   ├── hoek@4.2.1
        │ │   ├─┬ joi@13.7.0
        │ │   │ ├── hoek@5.0.4
        │ │   │ ├─┬ isemail@3.2.0
        │ │   │ └─┬ topo@3.0.3
        │ │   │   └── hoek@6.1.3
        │ │   └─┬ node-expat@2.4.0
        │ │     ├── bindings@1.5.0 deduped
        │ │     └── nan@2.15.0 deduped
        │ ├─┬ semver@7.3.5
        │ ├── suncalc2@1.8.1
        │ ├── typescript@4.5.5
        │ ├─┬ virtual-tsc@0.6.2
        │ │ ├─┬ debug@4.3.3
        │ │ │ └── ms@2.1.2
        │ │ └── picocolors@1.0.0
        │ ├─┬ vm2@3.9.7
        │ │ ├── acorn@8.7.0 deduped
        │ │ └── acorn-walk@8.2.0
        │ ├─┬ wake_on_lan@1.0.0
        │ │ └── minimist@1.2.5 deduped
        ├─┬ iobroker.js-controller@3.3.22
        │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
        │ │ ├── esbuild@0.11.23
        │ │ └── jsonc-parser@3.0.0
        │ ├─┬ @iobroker/db-objects-file@1.2.7
        │ │ ├─┬ @iobroker/db-base@1.2.4
        │ │ │ ├── deep-clone@3.0.3 deduped
        │ │ │ ├─┬ fs-extra@9.1.0
        │ │ │ │ ├── at-least-node@1.0.0 deduped
        │ │ │ │ ├── graceful-fs@4.2.4 deduped
        │ │ │ │ ├─┬ jsonfile@6.1.0
        │ │ │ │ │ ├── graceful-fs@4.2.4 deduped
        │ │ │ │ │ └── universalify@2.0.0 deduped
        │ │ │ ├── node.extend@2.0.2 deduped
        │ │ │ └── respjs@4.2.0
        │ │ ├── @iobroker/db-objects-redis@1.2.7 deduped
        │ │ └── node.extend@2.0.2 deduped
        │ ├─┬ @iobroker/db-objects-jsonl@1.2.7
        │ │ ├─┬ @alcalzone/jsonl-db@1.3.0
        │ │ │ ├─┬ alcalzone-shared@3.0.4
        │ │ │ │ └─┬ debug@4.3.3
        │ │ │ └─┬ proper-lockfile@4.1.2
        │ │ │   ├── retry@0.12.0
        │ │ │   └── signal-exit@3.0.3
        │ │ ├── @iobroker/db-base@1.2.4 deduped
        │ │ ├── @iobroker/db-objects-file@1.2.7 deduped
        │ ├─┬ @iobroker/db-objects-redis@1.2.7
        │ │ ├─┬ ioredis@4.28.5
        │ │ │ ├── cluster-key-slot@1.1.0
        │ │ │ ├── denque@1.5.1
        │ │ │ ├── lodash.defaults@4.2.0
        │ │ │ ├── lodash.flatten@4.4.0
        │ │ │ ├── lodash.isarguments@3.1.0
        │ │ │ ├── p-map@2.1.0
        │ │ │ ├── redis-commands@1.7.0
        │ │ │ ├── redis-errors@1.2.0
        │ │ │ ├─┬ redis-parser@3.0.0
        │ │ │ │ └── redis-errors@1.2.0 deduped
        │ │ │ └── standard-as-callback@2.1.0
        │ ├─┬ @iobroker/db-states-file@1.2.7
        │ │ └── @iobroker/db-states-redis@1.2.7 deduped
        │ ├─┬ @iobroker/db-states-jsonl@1.2.7
        │ │ ├── @alcalzone/jsonl-db@1.3.0 deduped
        │ │ ├── @iobroker/db-states-file@1.2.7 deduped
        │ ├─┬ @iobroker/db-states-redis@1.2.7
        │ │ └── ioredis@4.28.5 deduped
        │ ├── @iobroker/plugin-base@1.2.1
        │ ├─┬ @iobroker/plugin-sentry@1.1.10
        │ │ ├── @iobroker/plugin-base@1.2.1 deduped
        │ │ ├── @sentry/integrations@6.16.1 deduped
        │ │ ├── @sentry/node@6.16.1 deduped
        │ │ └── source-map-support@0.5.21 deduped
        │ ├─┬ chokidar@3.5.3
        │ │ ├─┬ anymatch@3.1.2
        │ │ │ ├── normalize-path@3.0.0 deduped
        │ │ │ └── picomatch@2.3.1
        │ │ ├─┬ braces@3.0.2
        │ │ │ └─┬ fill-range@7.0.1
        │ │ │   └─┬ to-regex-range@5.0.1
        │ │ │     └── is-number@7.0.0
        │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@2.3.2
        │ │ ├─┬ glob-parent@5.1.2
        │ │ │ └── is-glob@4.0.1 deduped
        │ │ ├─┬ is-binary-path@2.1.0
        │ │ │ └── binary-extensions@2.2.0
        │ │ ├─┬ is-glob@4.0.1
        │ │ │ └── is-extglob@2.1.1
        │ │ └─┬ readdirp@3.6.0
        │ │   └── picomatch@2.3.1 deduped
        │ ├── ci-info@3.3.0
        │ ├── daemonize2@0.4.2
        │ ├─┬ debug@4.3.3
        │ │ └── ms@2.1.2
        │ ├─┬ decache@4.6.1
        │ │ └── callsite@1.0.0
        │ ├─┬ diskusage@1.1.3
        │ │ ├── es6-promise@4.2.8
        │ ├─┬ event-stream@4.0.1
        │ │ ├── duplexer@0.1.1
        │ │ ├── from@0.1.7
        │ │ ├── map-stream@0.0.7
        │ │ ├─┬ pause-stream@0.0.11
        │ │ │ └── through@2.3.8 deduped
        │ │ ├─┬ split@1.0.1
        │ │ ├─┬ stream-combiner@0.2.2
        │ │ │ ├── duplexer@0.1.1 deduped
        │ ├─┬ greenlock@4.0.4
        │ │ ├─┬ @greenlock/manager@3.1.0
        │ │ │ └─┬ greenlock-manager-fs@3.1.1
        │ │ │   ├── @root/mkdirp@1.0.0 deduped
        │ │ │   └── safe-replace@1.1.0 deduped
        │ │ ├─┬ @root/acme@3.1.0
        │ │ │ ├── @root/csr@0.8.1 deduped
        │ │ │ ├── @root/encoding@1.0.1
        │ │ │ ├─┬ @root/keypairs@0.10.3
        │ │ │ │ ├── @root/encoding@1.0.1 deduped
        │ │ │ │ ├── @root/pem@1.0.4 deduped
        │ │ │ │ └── @root/x509@0.7.2 deduped
        │ │ │ ├── @root/request@1.8.1 deduped
        │ │ │ └─┬ @root/x509@0.7.2
        │ │ │   ├── @root/asn1@1.0.0 deduped
        │ │ │   └── @root/encoding@1.0.1 deduped
        │ │ ├─┬ @root/csr@0.8.1
        │ │ │ ├─┬ @root/asn1@1.0.0
        │ │ │ │ └── @root/encoding@1.0.1 deduped
        │ │ ├─┬ @root/greenlock@4.0.5
        │ │ │ ├── @greenlock/manager@3.1.0 deduped
        │ │ │ ├── @root/acme@3.1.0 deduped
        │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
        │ │ │ ├── cert-info@1.5.1 deduped
        │ │ │ ├── greenlock-store-fs@3.2.2 deduped
        │ │ ├─┬ @root/keypairs@0.9.0
        │ │ ├─┬ greenlock-store-fs@3.2.2
        │ ├─┬ greenlock-express@4.0.3
        │ │ ├── @root/greenlock@4.0.5 deduped
        │ │ ├─┬ @root/greenlock-express@4.0.4
        │ │ │ ├── @root/greenlock@4.0.5 deduped
        │ │ │ └── redirect-https@1.3.1 deduped
        │ │ └─┬ redirect-https@1.3.1
        │ │   └── escape-html@1.0.3 deduped
        │ ├─┬ jsonwebtoken@8.5.1
        │ │ ├─┬ jws@3.2.2
        │ │ │ ├─┬ jwa@1.4.1
        │ │ │ │ ├── buffer-equal-constant-time@1.0.1 deduped
        │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
        │ │ │ │ └── safe-buffer@5.1.2 deduped
        │ │ ├── lodash.includes@4.3.0
        │ │ ├── lodash.isboolean@3.0.3
        │ │ ├── lodash.isinteger@4.0.4
        │ │ ├── lodash.isnumber@3.0.3
        │ │ ├── lodash.isplainobject@4.0.6
        │ │ ├── lodash.isstring@4.0.1
        │ │ ├── lodash.once@4.1.1
        │ │ ├── ms@2.1.2
        │ ├─┬ jszip@3.7.1
        │ │ ├─┬ lie@3.3.0
        │ │ │ └── immediate@3.0.6
        │ │ ├── pako@1.0.11
        │ │ ├─┬ readable-stream@2.3.7
        │ │ │ ├── core-util-is@1.0.2 deduped
        │ │ │ ├── isarray@1.0.0
        │ │ │ ├── process-nextick-args@2.0.1
        │ │ │ ├── safe-buffer@5.1.2 deduped
        │ │ │ ├─┬ string_decoder@1.1.1
        │ │ └── set-immediate-shim@1.0.1
        │ ├─┬ le-acme-core@2.1.4
        │ │ └─┬ rsa-compat@1.9.4
        │ │   ├─┬ keypairs@1.2.14
        │ │   │ ├── eckles@1.4.1
        │ │   │ └── rasha@1.2.5
        │ │   ├── node-forge@0.7.6
        │ │   └─┬ ursa-optional@0.9.10
        │ ├─┬ le-challenge-fs@2.0.9
        │ │ └── @root/mkdirp@1.0.0 deduped
        │ ├── le-sni-auto@2.1.9
        │ ├─┬ loadavg-windows@1.1.1
        │ │ └── weak-daemon@1.0.3
        │ ├── mime@2.6.0
        │ ├── ncp@2.0.0
        │ ├── node-forge@0.10.0
        │ ├── node-schedule@2.1.0 deduped
        │ ├─┬ node.extend@2.0.2
        │ │ ├─┬ has@1.0.3
        │ │ │ └── function-bind@1.1.1
        │ │ └── is@3.3.0
        │ ├─┬ pidusage@2.0.21
        │ │ └── safe-buffer@5.2.1
        │ ├── promisify-child-process@4.1.1
        │ ├─┬ prompt@1.2.1
        │ │ ├── async@0.9.2
        │ │ ├── colors@1.4.0 deduped
        │ │ ├─┬ read@1.0.7
        │ │ │ └── mute-stream@0.0.8
        │ │ ├── revalidator@0.1.8
        │ │ └─┬ winston@2.4.5
        │ │   ├── async@1.0.0
        │ │   ├── colors@1.0.3
        │ │   ├── cycle@1.0.3
        │ │   ├── eyes@0.1.8
        │ │   ├── isstream@0.1.2 deduped
        │ │   └── stack-trace@0.0.10 deduped
        │ ├── readline-sync@1.4.10
        │ ├─┬ semver@7.3.5
        │ ├─┬ tar@6.1.11
        │ │ ├── chownr@2.0.0
        │ │ ├─┬ fs-minipass@2.1.0
        │ │ │ └── minipass@3.1.1 deduped
        │ │ ├─┬ minipass@3.1.1
        │ │ ├─┬ minizlib@2.1.2
        │ │ │ ├── minipass@3.1.1 deduped
        │ │ ├── mkdirp@1.0.4
        │ ├─┬ winston@3.6.0
        │ │ ├─┬ @dabh/diagnostics@2.0.3
        │ │ │ ├─┬ colorspace@1.1.4
        │ │ │ │ ├── color@3.2.1 deduped
        │ │ │ │ └── text-hex@1.0.0
        │ │ │ ├── enabled@2.0.0
        │ │ │ └── kuler@2.0.0
        │ │ ├── async@3.2.3
        │ │ ├── is-stream@2.0.1 deduped
        │ │ ├─┬ logform@2.4.0
        │ │ │ ├── @colors/colors@1.5.0
        │ │ │ ├── fecha@4.2.1
        │ │ │ ├── ms@2.1.3
        │ │ │ ├── safe-stable-stringify@2.3.1 deduped
        │ │ │ └── triple-beam@1.3.0 deduped
        │ │ ├─┬ one-time@1.0.0
        │ │ │ └── fn.name@1.1.0
        │ │ ├── stack-trace@0.0.10
        │ │ ├── triple-beam@1.3.0
        │ │ └─┬ winston-transport@4.5.0
        │ │   ├── logform@2.4.0 deduped
        │ ├─┬ winston-daily-rotate-file@4.6.1
        │ │ ├─┬ file-stream-rotator@0.6.1
        │ │ │ └── moment@2.29.1 deduped
        │ │ ├── object-hash@2.2.0
        │ │ ├── triple-beam@1.3.0 deduped
        │ │ └── winston-transport@4.5.0 deduped
        │ ├─┬ winston-seq-updated@1.0.4
        │ │ ├── seq-logging@0.4.6
        │ ├─┬ winston-syslog@2.4.4
        │ │ ├── glossy@0.1.7
        │ │ └─┬ unix-dgram@2.0.3
        │ └─┬ yargs@16.2.0
        │   ├─┬ cliui@7.0.4
        │   │ ├── string-width@4.2.3 deduped
        │   │ ├─┬ strip-ansi@6.0.1
        │   │ │ └── ansi-regex@5.0.1
        │   │ └─┬ wrap-ansi@7.0.0
        │   │   ├─┬ ansi-styles@4.3.0
        │   │   │ └─┬ color-convert@2.0.1
        │   │   │   └── color-name@1.1.4
        │   │   └── strip-ansi@6.0.1 deduped
        │   ├── escalade@3.1.1
        │   ├── get-caller-file@2.0.5
        │   ├── require-directory@2.1.1 deduped
        │   ├─┬ string-width@4.2.3
        │   │ ├── is-fullwidth-code-point@3.0.0
        │   ├── y18n@5.0.8
        │   └── yargs-parser@20.2.9
        ├─┬ iobroker.lightify@0.2.16
        │ ├── mdns-discovery@0.2.6 deduped
        │ ├── moment@2.29.1 deduped
        │ ├─┬ promise@8.0.1
        │ │ └── asap@2.0.6
        │ └─┬ soef@0.4.15
        │   ├── array-ext@0.1.5
        │   └── sprintf-js@1.1.2
        ├─┬ iobroker.mihome@1.3.7
        ├── iobroker.mihome-vacuum@1.1.5
        ├─┬ iobroker.mobile@1.0.1
        ├─┬ iobroker.mqtt@2.4.1
        │ ├─┬ mqtt@2.18.9
        │ │ ├─┬ commist@1.1.0
        │ │ │ ├── leven@2.1.0
        │ │ │ └── minimist@1.2.5 deduped
        │ │ ├─┬ concat-stream@1.6.2
        │ │ │ ├── readable-stream@2.3.7 deduped
        │ │ ├─┬ end-of-stream@1.4.4
        │ │ │ └── once@1.4.0 deduped
        │ │ ├─┬ es6-map@0.1.5
        │ │ │ ├─┬ d@1.0.1
        │ │ │ │ ├── es5-ext@0.10.53 deduped
        │ │ │ │ └── type@1.2.0
        │ │ │ ├─┬ es5-ext@0.10.53
        │ │ │ │ ├── es6-iterator@2.0.3 deduped
        │ │ │ │ ├── es6-symbol@3.1.3 deduped
        │ │ │ │ └── next-tick@1.0.0
        │ │ │ ├─┬ es6-iterator@2.0.3
        │ │ │ │ ├── d@1.0.1 deduped
        │ │ │ │ └── es6-symbol@3.1.3 deduped
        │ │ │ ├─┬ es6-set@0.1.5
        │ │ │ │ ├─┬ es6-symbol@3.1.1
        │ │ │ │ │ ├── d@1.0.1 deduped
        │ │ │ │ │ └── es5-ext@0.10.53 deduped
        │ │ │ │ └── event-emitter@0.3.5 deduped
        │ │ │ ├─┬ es6-symbol@3.1.3
        │ │ │ │ └─┬ ext@1.4.0
        │ │ │ │   └── type@2.0.0
        │ │ │ └─┬ event-emitter@0.3.5
        │ │ ├─┬ help-me@1.1.0
        │ │ │ ├─┬ callback-stream@1.1.0
        │ │ │ ├─┬ glob-stream@6.1.0
        │ │ │ │ ├── extend@3.0.2 deduped
        │ │ │ │ ├─┬ glob-parent@3.1.0
        │ │ │ │ │ ├─┬ is-glob@3.1.0
        │ │ │ │ │ │ └── is-extglob@2.1.1 deduped
        │ │ │ │ │ └── path-dirname@1.0.2
        │ │ │ │ ├── is-negated-glob@1.0.0
        │ │ │ │ ├─┬ ordered-read-streams@1.0.1
        │ │ │ │ ├─┬ pumpify@1.5.1
        │ │ │ │ │ ├── duplexify@3.7.1 deduped
        │ │ │ │ │ └─┬ pump@2.0.1
        │ │ │ │ │   ├── end-of-stream@1.4.4 deduped
        │ │ │ │ │   └── once@1.4.0 deduped
        │ │ │ │ ├── readable-stream@2.3.7 deduped
        │ │ │ │ ├── remove-trailing-separator@1.1.0
        │ │ │ │ ├─┬ to-absolute-glob@2.0.2
        │ │ │ │ │ ├─┬ is-absolute@1.0.0
        │ │ │ │ │ │ ├─┬ is-relative@1.0.0
        │ │ │ │ │ │ │ └─┬ is-unc-path@1.0.0
        │ │ │ │ │ │ │   └── unc-path-regex@0.1.2
        │ │ │ │ │ │ └── is-windows@1.0.2
        │ │ │ │ │ └── is-negated-glob@1.0.0 deduped
        │ │ │ │ └─┬ unique-stream@2.3.1
        │ │ │ │   ├── json-stable-stringify-without-jsonify@1.0.1
        │ │ │ │   └─┬ through2-filter@3.0.0
        │ │ │ │     ├── through2@2.0.5 deduped
        │ │ │ │     └── xtend@4.0.2 deduped
        │ │ ├─┬ mqtt-packet@5.6.1
        │ │ │ ├─┬ bl@1.2.2
        │ │ │ ├── process-nextick-args@2.0.1 deduped
        │ │ ├─┬ split2@2.2.0
        │ │ │ └── through2@2.0.5 deduped
        │ │ ├─┬ websocket-stream@5.2.0
          │ ├─┬ bent@7.3.12
          │ └── ws@7.5.6
          │ │ ├─┬ debug@2.2.0
          │ │ │ └── ms@0.7.1
          │ │ ├── dgram@1.0.1
          │ ├── netmask@2.0.2
          │ │ ├─┬ async@2.6.3
          │ │ ├─┬ debug@3.2.7
          │ │ │ └── ms@2.1.3
          │   │ │   └── ms@2.1.2
          │   │ └─┬ debug@4.3.3
          │   │   └── ms@2.1.2
          │   │ └─┬ debug@4.3.3
          │   │   └── ms@2.1.2
          │   └─┬ debug@4.3.3
          │     └── ms@2.1.2
          │ └─┬ axios@0.21.4
          │ └─┬ xml2js@0.4.23
          │   ├── sax@1.2.4
          │ │ └─┬ debug@4.1.1
          │ │   └── ms@2.1.2
          │ │ └─┬ ws@6.2.1
          │ └─┬ cron@1.8.2
          │ ├─┬ binrpc@3.3.1
          │ │ └── put@0.0.6
          │   ├── sax@0.4.3
          │ │ └── uuid@8.3.2
          │ └─┬ rrule@2.6.8
          │   ├── luxon@1.27.0
          │ ├─┬ semver@7.3.5
          │ │ ├─┬ mqtt@4.2.8
          │ │ │ ├── ws@7.5.7
          │ ├─┬ echarts@4.9.0
          │ ├─┬ jsdom@17.0.0
          │ │ ├── abab@2.0.5
          │ │ ├── acorn@8.7.0
          │ │ ├── cssom@0.5.0
          │ │ │   └── ms@2.1.2
          │ │ ├─┬ saxes@5.0.1
          │ │ ├── ws@8.5.0
          │ ├── moment@2.29.1
          │ │ ├─┬ color@3.2.1
          │ │ │ ├─┬ rc@1.2.8
          │ └── uuid@8.3.2
          │ ├── jsonata@1.8.6
          │ ├── oauth@0.9.15
          │ │   ├── hoek@4.2.1
          │ │   ├─┬ joi@13.7.0
          │ ├─┬ semver@7.3.5
          │ │ ├─┬ debug@4.3.3
          │ │ │ └── ms@2.1.2
          │ ├─┬ vm2@3.9.7
          │ ├── ci-info@3.3.0
          │ ├─┬ debug@4.3.3
          │ │ └── ms@2.1.2
          │ ├─┬ decache@4.6.1
          │ │ ├── from@0.1.7
          │ │ ├─┬ split@1.0.1
          │ │ ├─┬ jws@3.2.2
          │ │ │ ├─┬ jwa@1.4.1
          │ │ ├── ms@2.1.2
          │ ├─┬ jszip@3.7.1
          │ │ ├─┬ lie@3.3.0
          │ │ ├── pako@1.0.11
          │ ├── mime@2.6.0
          │ ├── ncp@2.0.0
          │ │ ├─┬ has@1.0.3
          │ │ └── is@3.3.0
          │ ├─┬ prompt@1.2.1
          │ │ ├── async@0.9.2
          │ │ ├─┬ read@1.0.7
          │ │   ├── async@1.0.0
          │ │   ├── cycle@1.0.3
          │ │   ├── eyes@0.1.8
          │ ├─┬ semver@7.3.5
          │ ├─┬ tar@6.1.11
          │ ├─┬ winston@3.6.0
          │ │ ├── async@3.2.3
          │ │ │ ├── ms@2.1.3
          │ └─┬ yargs@16.2.0
          │   ├─┬ cliui@7.0.4
          │   ├── y18n@5.0.8
          │ ├─┬ promise@8.0.1
          │ │ └── asap@2.0.6
          │ └─┬ soef@0.4.15
          │ ├─┬ mqtt@2.18.9
          │ │ │ ├─┬ d@1.0.1
          │ │ │ ├─┬ bl@1.2.2
          M
          M
          Markus Faltermeier
          @markus-faltermeier
          und der 2. Teil
          │ │ │ ├─┬ ws@6.2.2
          │ │ │ │ └── async-limiter@1.0.1 deduped
          │ ├─┬ mqtt-connection@4.1.0
          │ │ ├─┬ duplexify@3.7.1
          │ │ └─┬ through2@2.0.5
          │ ├─┬ websocket-stream@5.5.2
          │ │ ├─┬ ws@3.3.3
          │ │ │ ├── async-limiter@1.0.1 deduped
          │ │ │ └── ultron@1.1.1
          │ └── ws@8.5.0
          ├─┬ iobroker.mqtt-client@1.5.0
          │ ├─┬ @iobroker/adapter-core@2.6.0
          │ │ └─┬ @types/iobroker@4.0.1
          │ └── mqtt@2.18.9 deduped
          ├─┬ iobroker.nut@1.5.0
          │ └── node-nut@1.0.3
          ├─┬ iobroker.octoprint@2.1.0
          │ └─┬ axios@0.24.0
          ├─┬ iobroker.ping@1.5.0
          ├─┬ iobroker.pushover@2.0.5
          │ └── pushover-notifications@1.2.2
          ├─┬ iobroker.rpi2@1.3.1
          │ ├─┬ node-dht-sensor@0.4.3
          │ │ └── node-addon-api@1.7.2
          │ ├─┬ rpi-gpio@2.1.7
          │ │ ├─┬ async-retry@1.3.3
          │ │ │ └── retry@0.13.1
          │ │ ├─┬ debug@3.2.7
          │ │ │ └── ms@2.1.3
          │ │ └─┬ epoll@2.0.10
          │ ├─┬ rpi-gpio-buttons@2.0.1
          │ │ ├── button-events@1.0.2
          │ │ └── rpi-gpio@2.1.7 deduped
          │ └── sync-exec@0.6.2
          ├─┬ iobroker.scenes@2.3.8
          │ └── node-schedule@2.1.0 deduped
          ├─┬ iobroker.shelly@4.0.7
          │ ├── @apollon/iobroker-tools@0.2.0
          │ ├─┬ coiot-coap@1.0.0
          │ │ ├─┬ coap@0.24.0
          │ │ │ ├── capitalize@2.0.4
          │ │ │ ├── coap-packet@0.1.14
          │ │ │ ├── fastseries@2.0.0
          │ │ │ ├─┬ lru-cache@5.1.1
          │ │ │ │ └── yallist@3.1.1
          │ │ │ └─┬ readable-stream@3.6.0
          │ │ └── commander@6.2.1
          │ ├─┬ mqtt@4.3.5
          │ │ ├─┬ debug@4.3.3
          │ │ │ └── ms@2.1.2
          │ │ │ ├─┬ glob@7.1.6
          │ │ │ │ ├── fs.realpath@1.0.0
          │ │ │ │ ├─┬ inflight@1.0.6
          │ │ │ │ │ ├── once@1.4.0 deduped
          │ │ │ │ │ └── wrappy@1.0.2 deduped
          │ │ │ │ ├── minimatch@3.0.4 deduped
          │ │ │ │ └── path-is-absolute@1.0.1
          │ │ ├─┬ lru-cache@6.0.0
          │ │ ├─┬ number-allocator@1.0.9
          │ │ │ └── js-sdsl@2.1.4
          │ │ ├── rfdc@1.3.0
          │ │ ├── ws@7.5.7
          │ ├── mqtt-connection@4.1.0 deduped
          │ ├─┬ ping@0.4.1
          │ │ ├── q@1.5.1
          │ │ └── underscore@1.13.2
          │ ├─┬ shelly-iot@1.1.2
          │ │ ├─┬ coap@0.26.0
          │ │ │ ├─┬ @types/bl@5.0.2
          │ │ │ │ ├── @types/node@13.13.5 deduped
          │ │ │ │ └─┬ @types/readable-stream@2.3.13
          │ │ │ ├── @types/node@16.11.25
          │ │ │ ├─┬ bl@5.0.0
          │ │ │ │ ├─┬ buffer@6.0.3
          │ │ │ │ │ ├── base64-js@1.3.1 deduped
          │ │ │ │ │ └── ieee754@1.2.1
          │ │ │ ├── capitalize@2.0.4 deduped
          │ │ │ ├── coap-packet@1.1.1
          │ │ │ ├── fastseries@2.0.0 deduped
          │ │ │ ├─┬ lru-cache@6.0.0
          │ │ └─┬ node-rest-client@3.1.1
          │ │   ├─┬ debug@4.3.3
          │ │   │ └── ms@2.1.2
          │ │   ├── follow-redirects@1.14.8 deduped
          │ │   └── xml2js@0.4.23 deduped
          │ ├── tcp-ping@0.1.1
          │ ├── xml2js@0.4.23 deduped
          │ └── xmlbuilder@15.1.1
          ├─┬ iobroker.simple-api@2.6.2
          ├─┬ iobroker.snmp@0.5.0
          │ └─┬ net-snmp@1.2.5
          │   └── asn1-ber@1.0.9
          ├─┬ iobroker.socketio@3.1.5
          │ ├─┬ axios@0.23.0
          │ │ └── follow-redirects@1.14.8 deduped
          │ ├── cookie-parser@1.4.6 deduped
          │ ├── express-session@1.17.2 deduped
          │ └─┬ socket.io@2.4.1
          │   ├─┬ debug@4.1.1
          │   │ └── ms@2.1.3
          │   ├─┬ engine.io@3.5.0
          │   │ ├── accepts@1.3.8 deduped
          │   │ ├── base64id@2.0.0
          │   │ ├─┬ debug@4.1.1
          │   │ │ └── ms@2.1.3 deduped
          │   │ ├─┬ engine.io-parser@2.2.1
          │   │ │ ├── after@0.8.2 deduped
          │   │ │ ├── arraybuffer.slice@0.0.7
          │   │ │ ├── base64-arraybuffer@0.1.4
          │   │ │ ├── blob@0.0.5
          │   │ │ └── has-binary2@1.0.3 deduped
          │   │ └── ws@7.4.6
          │   ├─┬ has-binary2@1.0.3
          │   │ └── isarray@2.0.1
          │   ├── socket.io-adapter@1.1.2
          │   ├─┬ socket.io-client@2.4.0
          │   │ ├── backo2@1.0.2 deduped
          │   │ ├── component-bind@1.0.0 deduped
          │   │ ├── component-emitter@1.3.0
          │   │ ├─┬ debug@3.1.0
          │   │ │ └── ms@2.0.0
          │   │ ├─┬ engine.io-client@3.5.2
          │   │ │ ├── component-emitter@1.3.0 deduped
          │   │ │ ├── component-inherit@0.0.3 deduped
          │   │ │ ├─┬ debug@3.1.0
          │   │ │ │ └── ms@2.0.0
          │   │ │ ├── engine.io-parser@2.2.1 deduped
          │   │ │ ├── has-cors@1.1.0 deduped
          │   │ │ ├── indexof@0.0.1 deduped
          │   │ │ ├── parseqs@0.0.6 deduped
          │   │ │ ├── parseuri@0.0.6 deduped
          │   │ │ ├── ws@7.4.6 deduped
          │   │ │ ├── xmlhttprequest-ssl@1.6.3
          │   │ │ └── yeast@0.1.2 deduped
          │   │ ├── has-binary2@1.0.3 deduped
          │   │ ├─┬ socket.io-parser@3.3.2
          │   │ │ ├── debug@3.1.0 deduped
          │   │ │ └── isarray@2.0.1 deduped
          │   │ └── to-array@0.1.4 deduped
          │   └─┬ socket.io-parser@3.4.1
          │     ├── component-emitter@1.2.1
          │     ├─┬ debug@4.1.1
          │     └── isarray@2.0.1
          ├─┬ iobroker.sonoff@2.4.7
          │ └── mqtt-connection@4.1.0 deduped
          ├─┬ iobroker.spotify-premium@1.0.0
          │ ├─┬ @iobroker/adapter-core@1.0.1
          │ │ └── @types/iobroker@1.4.13 deduped
          │ ├── promise@8.0.1 deduped
          │ ├── querystring@0.2.0
          │ └─┬ request@2.83.0
          │   ├── aws-sign2@0.7.0 deduped
          │   ├── aws4@1.9.1 deduped
          │   ├── forever-agent@0.6.1 deduped
          │   ├── form-data@2.3.3 deduped
          │   ├─┬ har-validator@5.0.3
          │   │ ├─┬ ajv@5.5.2
          │   │ │ ├── co@4.6.0
          │   │ │ ├── fast-deep-equal@1.1.0
          │   │ │ ├── fast-json-stable-stringify@2.1.0 deduped
          │   │ │ └── json-schema-traverse@0.3.1
          │   │ └── har-schema@2.0.0 deduped
          │   ├─┬ hawk@6.0.2
          │   │ ├─┬ boom@4.3.1
          │   │ │ └── hoek@4.2.1 deduped
          │   │ ├─┬ cryptiles@3.1.4
          │   │ │ └─┬ boom@5.2.0
          │   │ ├── hoek@4.2.1 deduped
          │   │ └─┬ sntp@2.1.0
          │   ├── http-signature@1.2.0 deduped
          │   ├── is-typedarray@1.0.0 deduped
          │   ├── json-stringify-safe@5.0.1 deduped
          │   ├── mime-types@2.1.34 deduped
          │   ├── oauth-sign@0.8.2
          │   ├── performance-now@2.1.0 deduped
          │   ├── qs@6.5.2
          │   ├── stringstream@0.0.6
          │   ├─┬ tough-cookie@2.3.4
          │   │ └── punycode@1.4.1
          │   ├── tunnel-agent@0.6.0 deduped
          │   └── uuid@3.4.0 deduped
          ├─┬ iobroker.statistics@1.0.9
          │ └── cron@1.8.2 deduped
          ├─┬ iobroker.synology@1.1.3
          │ ├─┬ @iobroker/adapter-core@2.4.0
          │ │ └─┬ @types/iobroker@3.2.4
          │ └─┬ syno@3.0.0
          │   ├── commander@4.1.1
          │   ├─┬ js-yaml@3.14.1
          │   │ ├─┬ argparse@1.0.10
          │   │ │ └── sprintf-js@1.0.3
          │   │ └── esprima@4.0.1 deduped
          │   ├── lodash@4.17.21 deduped
          │   ├── minimist@0.2.1
          │   ├─┬ nconf@0.10.0
          │   │ ├── async@1.5.2
          │   │ ├── ini@1.3.5
          │   │ ├── secure-keys@1.0.0
          │   │ └─┬ yargs@3.32.0
          │   │   ├── camelcase@2.1.1
          │   │   ├── cliui@3.2.0 deduped
          │   │   ├── decamelize@1.2.0 deduped
          │   │   ├── os-locale@1.4.0 deduped
          │   │   ├── window-size@0.1.4
          │   │   └── y18n@3.2.1 deduped
          │   ├── ospath@1.2.2
          │   ├─┬ otplib@11.0.1
          │   │ └── thirty-two@1.0.2
          │   ├── pluralize@8.0.0
          ├─┬ iobroker.tankerkoenig@2.1.1
          ├─┬ iobroker.telegram@1.11.1
          │ ├─┬ axios@0.25.0
          │ ├─┬ node-telegram-bot-api@0.56.0
          │ │ ├─┬ array.prototype.findindex@2.1.0
          │ │ │ ├─┬ define-properties@1.1.3
          │ │ │ │ └── object-keys@1.1.1
          │ │ │ └─┬ es-abstract@1.19.1
          │ │ │   ├── call-bind@1.0.2 deduped
          │ │ │   ├─┬ es-to-primitive@1.2.1
          │ │ │   │ ├── is-callable@1.2.4 deduped
          │ │ │   │ ├─┬ is-date-object@1.0.5
          │ │ │   │ │ └── has-tostringtag@1.0.0 deduped
          │ │ │   │ └─┬ is-symbol@1.0.4
          │ │ │   │   └── has-symbols@1.0.2 deduped
          │ │ │   ├── function-bind@1.1.1 deduped
          │ │ │   ├─┬ get-intrinsic@1.1.1
          │ │ │   │ ├── function-bind@1.1.1 deduped
          │ │ │   │ ├── has@1.0.3 deduped
          │ │ │   ├─┬ get-symbol-description@1.0.0
          │ │ │   │ ├── call-bind@1.0.2 deduped
          │ │ │   │ └── get-intrinsic@1.1.1 deduped
          │ │ │   ├── has-symbols@1.0.2
          │ │ │   ├─┬ internal-slot@1.0.3
          │ │ │   │ ├── get-intrinsic@1.1.1 deduped
          │ │ │   │ └─┬ side-channel@1.0.4
          │ │ │   │   └── object-inspect@1.12.0 deduped
          │ │ │   ├── is-negative-zero@2.0.2
          │ │ │   ├─┬ is-regex@1.1.4
          │ │ │   │ └─┬ has-tostringtag@1.0.0
          │ │ │   ├── is-shared-array-buffer@1.0.1
          │ │ │   ├─┬ is-string@1.0.7
          │ │ │   ├─┬ is-weakref@1.0.2
          │ │ │   │ └── call-bind@1.0.2 deduped
          │ │ │   ├── object-inspect@1.12.0
          │ │ │   ├── object-keys@1.1.1 deduped
          │ │ │   ├─┬ object.assign@4.1.2
          │ │ │   │ ├── define-properties@1.1.3 deduped
          │ │ │   │ ├── has-symbols@1.0.2 deduped
          │ │ │   │ └── object-keys@1.1.1 deduped
          │ │ │   ├─┬ string.prototype.trimend@1.0.4
          │ │ │   │ └── define-properties@1.1.3 deduped
          │ │ │   ├─┬ string.prototype.trimstart@1.0.4
          │ │ │   └─┬ unbox-primitive@1.0.1
          │ │ │     ├── has-bigints@1.0.1
          │ │ │     └─┬ which-boxed-primitive@1.0.2
          │ │ │       ├─┬ is-bigint@1.0.4
          │ │ │       │ └── has-bigints@1.0.1 deduped
          │ │ │       ├─┬ is-boolean-object@1.1.2
          │ │ │       ├─┬ is-number-object@1.0.6
          │ │ │       ├── is-string@1.0.7 deduped
          │ │ │       └── is-symbol@1.0.4 deduped
          │ │ ├─┬ bl@1.2.3
          │ │ ├── bluebird@3.7.2 deduped
          │ │ ├─┬ debug@3.2.7
          │ │ │ └── ms@2.1.3
          │ │ ├── depd@1.1.2 deduped
          │ │ ├── eventemitter3@3.1.2
          │ │ ├── file-type@3.9.0
          │ │ ├── mime@1.6.0
          │ │ ├─┬ pump@2.0.1
          │ │ └─┬ request-promise@4.2.6
          │ │   ├─┬ request-promise-core@1.1.4
          │ │   ├── stealthy-require@1.1.1 deduped
          │ └─┬ socksv5@0.0.6
          │   └─┬ ipv6@3.1.1
          │     ├─┬ cli@0.4.5
          │     ├─┬ cliff@0.1.10
          │     │ ├── eyes@0.1.8 deduped
          │     │ └─┬ winston@0.8.3
          │     │   ├── async@0.2.10
          │     │   ├── colors@0.6.2
          │     │   ├── cycle@1.0.3 deduped
          │     │   ├── pkginfo@0.3.1
          │     └── sprintf@0.1.3
          ├─┬ iobroker.terminal@0.1.2
          │ ├─┬ UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
          │ ├── body-parser@1.19.2 deduped
          │ ├── commander@5.1.0
          │ ├─┬ connect@3.7.0
          │ │ ├── debug@2.6.9 deduped
          │ │ ├── finalhandler@1.1.2 deduped
          │ │ ├── parseurl@1.3.3 deduped
          │ │ └── utils-merge@1.0.1 deduped
          │ ├── connect-flash@0.1.1 deduped
          │ ├── express@4.17.3 deduped
          │ ├── nan@2.15.0
          │ ├─┬ passport@0.2.2
          │ │ ├── passport-strategy@1.0.0 deduped
          │ │ └── pause@0.0.1 deduped
          │ ├── passport-local@1.0.0 deduped
          │ ├─┬ send@0.17.2
          │ │ ├── destroy@1.0.4
          │ │ ├── encodeurl@1.0.2 deduped
          │ │ ├── escape-html@1.0.3 deduped
          │ │ ├── etag@1.8.1 deduped
          │ │ ├── fresh@0.5.2 deduped
          │ │ ├── http-errors@1.8.1 deduped
          │ │ ├── mime@1.6.0 deduped
          │ │ ├── ms@2.1.3
          │ │ ├── on-finished@2.3.0 deduped
          │ │ ├── range-parser@1.2.1 deduped
          │ │ └── statuses@1.5.0 deduped
          │ ├── socket.io@1.7.2 deduped
          │ ├── uid-number@0.0.6
          │ └── xtend@4.0.2
          ├─┬ iobroker.text2command@2.1.1
          ├─┬ iobroker.tr-064@4.2.15
          ├─┬ iobroker.upnp@1.0.19
          │ ├── ip@1.1.5
          │ ├── node-ssdp@4.0.1 deduped
          │ ├─┬ parsexmlresponse@0.0.5
          │ ├─┬ portfinder@1.0.28
          │ │ ├── async@2.6.3 deduped
          │ │ ├─┬ debug@3.2.7
          │ │ │ └── ms@2.1.3
          │ │ └─┬ mkdirp@0.5.5
          │ └── xmldom@0.6.0
          ├─┬ iobroker.vis@1.4.5
          │ └── jsonwebtoken@8.5.1 deduped
          ├── iobroker.vis-bars@0.1.4
          ├─┬ iobroker.vis-colorpicker@1.2.0
          ├── iobroker.vis-fancyswitch@1.1.0
          ├─┬ iobroker.vis-google-fonts@1.0.3
          ├── iobroker.vis-hqwidgets@1.1.9
          ├── iobroker.vis-jqui-mfd@1.0.12
          ├── iobroker.vis-metro@1.1.2
          ├─┬ iobroker.vis-players@0.1.6
          │ └── @iobroker/adapter-core@1.0.3 deduped
          ├─┬ iobroker.vis-plumb@1.0.2
          ├── iobroker.vis-timeandweather@1.1.7
          ├── iobroker.vis-weather@2.5.5
          ├─┬ iobroker.web@3.4.16
          │ ├── iobroker.simple-api@2.6.2 deduped
          │ ├── iobroker.socketio@3.1.5 deduped
          │ ├─┬ mime-types@2.1.34
          │ │ └── mime-db@1.51.0
          │ ├── passport@0.5.2 deduped
          │ ├── passport.socketio@3.7.0 deduped
          │ │ ├─┬ debug@3.1.0
          │ │ │ └── ms@2.0.0 deduped
          │ │ │ ├─┬ engine.io-parser@2.2.1
          │ │ │ │ ├── after@0.8.2 deduped
          │ │ │ │ ├── arraybuffer.slice@0.0.7
          │ │ │ │ ├── base64-arraybuffer@0.1.4
          │ │ │ │ ├── blob@0.0.5
          │ │ │ │ └── has-binary2@1.0.3 deduped
          │ │ │ ├── ws@7.4.6
          ├─┬ UNMET DEPENDENCY iobroker.zigbee@1.6.16
          │ ├─┬ UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
          │ │ └─┬ UNMET DEPENDENCY @types/iobroker@3.3.4
          │ ├── tar@6.1.11 deduped
          │ ├── UNMET DEPENDENCY typescript@4.5.4
          │ ├─┬ zigbee-herdsman@0.14.16
          │ │ ├── debounce@1.2.1
          │ │ ├─┬ debug@4.3.3
          │ │ │ └── ms@2.1.2
          │ │ ├── fast-deep-equal@3.1.3
          │ │ ├── mixin-deep@2.0.1
          │ │ ├─┬ mz@2.7.0
          │ │ │ ├── any-promise@1.3.0
          │ │ │ ├── object-assign@4.1.1
          │ │ │ └─┬ thenify-all@1.6.0
          │ │ │   └─┬ thenify@3.3.1
          │ │ │     └── any-promise@1.3.0 deduped
          │ │ ├─┬ serialport@9.2.8
          │ │ │ ├─┬ @serialport/binding-mock@9.2.4
          │ │ │ │ ├─┬ @serialport/binding-abstract@9.2.3
          │ │ │ │ │ └── debug@4.3.3 deduped
          │ │ │ ├─┬ @serialport/bindings@9.2.8
          │ │ │ │ ├── @serialport/binding-abstract@9.2.3 deduped
          │ │ │ │ ├── @serialport/parser-readline@9.2.4 deduped
          │ │ │ │ ├─┬ bindings@1.5.0
          │ │ │ │ │ └── file-uri-to-path@1.0.0
          │ │ │ │ ├── nan@2.15.0
          │ │ │ │ └─┬ prebuild-install@7.0.1
          │ │ │ │   ├── detect-libc@2.0.0
          │ │ │ │   ├── expand-template@2.0.3
          │ │ │ │   ├── github-from-package@0.0.0
          │ │ │ │   ├── mkdirp-classic@0.5.3
          │ │ │ │   ├── napi-build-utils@1.0.2
          │ │ │ │   ├─┬ node-abi@3.8.0
          │ │ │ │   │ └─┬ semver@7.3.5
          │ │ │ │   │   └─┬ lru-cache@6.0.0
          │ │ │ │   │     └── yallist@4.0.0
          │ │ │ │   ├─┬ npmlog@4.1.2
          │ │ │ │   │ ├─┬ are-we-there-yet@1.1.7
          │ │ │ │   │ │ ├── delegates@1.0.0
          │ │ │ │   │ │ └─┬ readable-stream@2.3.7
          │ │ │ │   │ │   ├── core-util-is@1.0.3
          │ │ │ │   │ │   ├── inherits@2.0.4 deduped
          │ │ │ │   │ │   ├── isarray@1.0.0
          │ │ │ │   │ │   ├── process-nextick-args@2.0.1
          │ │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
          │ │ │ │   │ │   ├─┬ string_decoder@1.1.1
          │ │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
          │ │ │ │   │ │   └── util-deprecate@1.0.2
          │ │ │ │   │ ├─┬ gauge@2.7.4
          │ │ │ │   │ │ ├── aproba@1.2.0
          │ │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
          │ │ │ │   │ │ ├── has-unicode@2.0.1
          │ │ │ │   │ │ ├── object-assign@4.1.1 deduped
          │ │ │ │   │ │ ├── signal-exit@3.0.7
          │ │ │ │   │ │ ├─┬ string-width@1.0.2
          │ │ │ │   │ │ │ ├── code-point-at@1.1.0
          │ │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
          │ │ │ │   │ │ │ │ └── number-is-nan@1.0.1
          │ │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
          │ │ │ │   │ │ ├─┬ strip-ansi@3.0.1
          │ │ │ │   │ │ │ └── ansi-regex@2.1.1
          │ │ │ │   │ │ └─┬ wide-align@1.1.5
          │ │ │ │   │ │   └── string-width@1.0.2 deduped
          │ │ │ │   │ └── set-blocking@2.0.0
          │ │ │ │   ├─┬ pump@3.0.0
          │ │ │ │   │ ├─┬ end-of-stream@1.4.4
          │ │ │ │   │ │ └── once@1.4.0 deduped
          │ │ │ │   │ └─┬ once@1.4.0
          │ │ │ │   ├─┬ rc@1.2.8
          │ │ │ │   │ ├── deep-extend@0.6.0
          │ │ │ │   │ ├── ini@1.3.8
          │ │ │ │   │ ├── minimist@1.2.5 deduped
          │ │ │ │   │ └── strip-json-comments@2.0.1
          │ │ │ │   ├─┬ simple-get@4.0.1
          │ │ │ │   │ ├─┬ decompress-response@6.0.0
          │ │ │ │   │ │ └── mimic-response@3.1.0
          │ │ │ │   │ └── simple-concat@1.0.1
          │ │ │ │   ├─┬ tar-fs@2.1.1
          │ │ │ │   │ ├── chownr@1.1.4
          │ │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
          │ │ │ │   │ ├── pump@3.0.0 deduped
          │ │ │ │   │ └─┬ tar-stream@2.2.0
          │ │ │ │   │   ├─┬ bl@4.1.0
          │ │ │ │   │   │ ├─┬ buffer@5.7.1
          │ │ │ │   │   │ │ ├── base64-js@1.5.1
          │ │ │ │   │   │ │ └── ieee754@1.2.1
          │ │ │ │   │   │ └─┬ readable-stream@3.6.0
          │ │ │ │   │   │   ├── string_decoder@1.1.1 deduped
          │ │ │ │   │   │   └── util-deprecate@1.0.2 deduped
          │ │ │ │   │   ├── fs-constants@1.0.0
          │ │ │ │   └─┬ tunnel-agent@0.6.0
          │ │ │ ├── @serialport/parser-byte-length@9.2.4
          │ │ │ ├── @serialport/parser-cctalk@9.2.4
          │ │ │ ├── @serialport/parser-delimiter@9.2.4
          │ │ │ ├── @serialport/parser-inter-byte-timeout@9.2.4
          │ │ │ ├─┬ @serialport/parser-readline@9.2.4
          │ │ │ │ └── @serialport/parser-delimiter@9.2.4 deduped
          │ │ │ ├── @serialport/parser-ready@9.2.4
          │ │ │ ├── @serialport/parser-regex@9.2.4
          │ │ │ ├─┬ @serialport/stream@9.2.4
          │ │ └── slip@1.0.2
          │ └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.422
          │   ├─┬ UNMET DEPENDENCY axios@0.25.0
          │   │ └── UNMET DEPENDENCY follow-redirects@1.14.8
          │   ├── UNMET DEPENDENCY buffer-crc32@0.2.13
          │   ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
          │   │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
          │   │ │ └── UNMET DEPENDENCY debug@4.3.3
          │   │ └─┬ UNMET DEPENDENCY debug@4.3.3
          │   │   └── UNMET DEPENDENCY ms@2.1.2
          │   ├─┬ UNMET DEPENDENCY tar-stream@2.2.0
          │   │ ├─┬ UNMET DEPENDENCY bl@4.1.0
          │   │ │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
          │   │ │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
          │   │ │ │ └── UNMET DEPENDENCY ieee754@1.2.1
          │   │ │ ├── UNMET DEPENDENCY inherits@2.0.4
          │   │ │ └── UNMET DEPENDENCY readable-stream@3.6.0
          │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
          │   │ │ └─┬ UNMET DEPENDENCY once@1.4.0
          │   │ │   └── UNMET DEPENDENCY wrappy@1.0.2
          │   │ ├── UNMET DEPENDENCY fs-constants@1.0.0
          │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
          │   │   ├─┬ UNMET DEPENDENCY string_decoder@1.3.0
          │   │   │ └── UNMET DEPENDENCY safe-buffer@5.2.1
          │   │   └── UNMET DEPENDENCY util-deprecate@1.0.2
          │   └─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.14
          │     ├── UNMET DEPENDENCY debounce@1.2.1
          │     ├─┬ UNMET DEPENDENCY debug@4.3.3
          │     ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
          │     ├── UNMET DEPENDENCY mixin-deep@2.0.1
          │     ├─┬ UNMET DEPENDENCY mz@2.7.0
          │     │ ├── UNMET DEPENDENCY any-promise@1.3.0
          │     │ ├── UNMET DEPENDENCY object-assign@4.1.1
          │     │ └─┬ UNMET DEPENDENCY thenify-all@1.6.0
          │     │   └─┬ UNMET DEPENDENCY thenify@3.3.1
          │     │     └── UNMET DEPENDENCY any-promise@1.3.0
          │     ├─┬ UNMET DEPENDENCY serialport@9.2.8
          │     │ ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
          │     │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
          │     │ │ │ └── UNMET DEPENDENCY debug@4.3.3
          │     │ ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.8
          │     │ │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
          │     │ │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
          │     │ │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
          │     │ │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
          │     │ │ ├── UNMET DEPENDENCY debug@4.3.3
          │     │ │ ├── UNMET DEPENDENCY nan@2.15.0
          │     │ │ └─┬ UNMET DEPENDENCY prebuild-install@7.0.1
          │     │ │   ├── UNMET DEPENDENCY detect-libc@2.0.0
          │     │ │   ├── UNMET DEPENDENCY expand-template@2.0.3
          │     │ │   ├── UNMET DEPENDENCY github-from-package@0.0.0
          │     │ │   ├── UNMET DEPENDENCY minimist@1.2.5
          │     │ │   ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
          │     │ │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
          │     │ │   ├─┬ UNMET DEPENDENCY node-abi@3.8.0
          │     │ │   │ └─┬ UNMET DEPENDENCY semver@7.3.5
          │     │ │   │   └─┬ UNMET DEPENDENCY lru-cache@6.0.0
          │     │ │   │     └── UNMET DEPENDENCY yallist@4.0.0
          │     │ │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
          │     │ │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
          │     │ │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
          │     │ │   │ │ └─┬ UNMET DEPENDENCY readable-stream@2.3.7
          │     │ │   │ │   ├── UNMET DEPENDENCY core-util-is@1.0.3
          │     │ │   │ │   ├── UNMET DEPENDENCY inherits@2.0.4
          │     │ │   │ │   ├── UNMET DEPENDENCY isarray@1.0.0
          │     │ │   │ │   ├── UNMET DEPENDENCY process-nextick-args@2.0.1
          │     │ │   │ │   ├── UNMET DEPENDENCY safe-buffer@5.1.2
          │     │ │   │ │   ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
          │     │ │   │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
          │     │ │   │ │   └── UNMET DEPENDENCY util-deprecate@1.0.2
          │     │ │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
          │     │ │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
          │     │ │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
          │     │ │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
          │     │ │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
          │     │ │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
          │     │ │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.7
          │     │ │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
          │     │ │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
          │     │ │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
          │     │ │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
          │     │ │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
          │     │ │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
          │     │ │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
          │     │ │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
          │     │ │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
          │     │ │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
          │     │ │   ├─┬ UNMET DEPENDENCY pump@3.0.0
          │     │ │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
          │     │ │   │ │ └── UNMET DEPENDENCY once@1.4.0
          │     │ │   │ └─┬ UNMET DEPENDENCY once@1.4.0
          │     │ │   │   └── UNMET DEPENDENCY wrappy@1.0.2
          │     │ │   ├─┬ UNMET DEPENDENCY rc@1.2.8
          │     │ │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
          │     │ │   │ ├── UNMET DEPENDENCY ini@1.3.8
          │     │ │   │ ├── UNMET DEPENDENCY minimist@1.2.5
          │     │ │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
          │     │ │   ├─┬ UNMET DEPENDENCY simple-get@4.0.1
          │     │ │   │ ├─┬ UNMET DEPENDENCY decompress-response@6.0.0
          │     │ │   │ │ └── UNMET DEPENDENCY mimic-response@3.1.0
          │     │ │   │ ├── UNMET DEPENDENCY once@1.4.0
          │     │ │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
          │     │ │   ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
          │     │ │   │ ├── UNMET DEPENDENCY chownr@1.1.4
          │     │ │   │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
          │     │ │   │ ├── UNMET DEPENDENCY pump@3.0.0
          │     │ │   │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
          │     │ │   │   ├─┬ UNMET DEPENDENCY bl@4.1.0
          │     │ │   │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
          │     │ │   │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
          │     │ │   │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
          │     │ │   │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
          │     │ │   │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
          │     │ │   │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
          │     │ │   │   ├── UNMET DEPENDENCY fs-constants@1.0.0
          │     │ │   └─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
          │     │ ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
          │     │ ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
          │     │ ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
          │     │ ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
          │     │ ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
          │     │ │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
          │     │ ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
          │     │ ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
          │     │ ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
          │     └── UNMET DEPENDENCY slip@1.0.2
          ├── semver@5.7.1
          ├── UNMET DEPENDENCY tr-O64@0.2.4
          └─┬ yargs@7.1.0
            ├── camelcase@3.0.0
            ├─┬ cliui@3.2.0
            │ └─┬ wrap-ansi@2.1.0
            ├── get-caller-file@1.0.3
            ├─┬ os-locale@1.4.0
            │ └─┬ lcid@1.0.0
            │   └── invert-kv@1.0.0
            ├─┬ read-pkg-up@1.0.1
            │ ├─┬ find-up@1.1.2
            │ │ ├─┬ path-exists@2.1.0
            │ │ │ └── pinkie-promise@2.0.1 deduped
            │ │ └─┬ pinkie-promise@2.0.1
            │ │   └── pinkie@2.0.4
            │ └─┬ read-pkg@1.1.0
            │   ├─┬ load-json-file@1.1.0
            │   │ ├── pify@2.3.0
            ├── y18n@3.2.1
          npm ERR! missing: tr-O64@0.2.4, required by iobroker.inst@2.0.3
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            Man kann nach oben scrollen. Ist aber nicht nötig, die Zusammenfassung am Ende ist ja schon gehaltvoll genug.
            Der tr-O64 ist z. B. auch noch drin:
            iobroker update -u
            liefert?
              iobroker update -u
              liefert?
              M
              M
              Markus Faltermeier
              das ist die Ausgabe:
              pi@raspberrypi:/opt/iobroker $ iobroker update -u
              Used repository: stable
              hash unchanged, use cached sources
              update done
              Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
              Adapter    "backitup"      : 2.3.3    , installed 2.2.3 [Updateable]
              Adapter    "discovery"     : 2.7.5    , installed 2.7.3 [Updateable]
              Adapter    "hue"           : 3.6.5    , installed 3.5.31 [Updateable]
              Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
              Adapter    "mihome-vacuum" : 3.3.1    , installed 1.1.5 [Updateable]
              Adapter    "shelly"        : 5.3.2    , installed 4.0.7 [Updateable]
                update done
                Thomas BraunT
                Thomas BraunT
                @markus-faltermeier
                Okay, und
                iobroker upgrade
                macht nun?
                  @markus-faltermeier
                  Okay, und
                  iobroker upgrade
                  macht nun?
                  M
                  M
                  Markus Faltermeier
                  bekam folgende Ausgabe:
                  update done
                  pi@raspberrypi:/opt/iobroker $ ^C
                  pi@raspberrypi:/opt/iobroker $ iobroker upgrade
                  This upgrade of "hue" will introduce the following changes:
                  -> 3.6.5:
                  correctly identify third party switches (closes #273)
                  -> 3.6.3:
                  added `info.connection` state (closes #268)
                  -> 3.6.2:
                  -> 3.6.1:
                  ct values of groups can be even lower due to third party lights
                  -> 3.6.0:
                  allow to trigger scenes via `command` state, this allows to start a scene with `transitiontime`
                  Would you like to upgrade hue from @3.5.31 to @3.6.5 now? [(y)es, (n)o]: y
                  Update hue from @3.5.31 to @3.6.5
                  NPM version: 6.14.16
                  npm install iobroker.hue@3.6.5 --loglevel error --prefix "/opt/iobroker" (System call)
                  Traceback (most recent call last):
                    File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
                      import gyp
                    File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
                      import gyp.input
                    File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
                      import ast
                  ImportError: No module named ast
                  gyp ERR! configure error
                  gyp ERR! stack Error: `gyp` failed with exit code: 1
                  gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                  gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                  gyp ERR! System Linux 5.10.103-v7l+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                  gyp ERR! node -v v14.19.0
                  gyp ERR! node-gyp -v v5.1.0
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                  gyp ERR! not ok
                  node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                  gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  gyp ERR! not ok
                  node-pre-gyp ERR! build error
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                  node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                  node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                  node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                  node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                  node-pre-gyp ERR! System Linux 5.10.103-v7l+
                  node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                  node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  node-pre-gyp ERR! node -v v14.19.0
                  node-pre-gyp ERR! node-pre-gyp -v v1.0.8
                  node-pre-gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! cwd /opt/iobroker/node_modules/sharp
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                  gyp ERR! not ok
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the @serialport/bindings@9.2.8 install script.
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_53_08_366Z-debug.log
                  upload [14] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                  Update "system.adapter.hue.0"
                  upload [13] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                  upload [12] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                  upload [11] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                  upload [10] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [9] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [8] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                  Adapter "hue" updated
                  This upgrade of "discovery" will introduce the following changes:
                  -> 2.7.5:
                  Fix kecontact detection (Sentry IOBROKER-DISCOVERY-3P)
                  -> 2.7.4:
                  Replaced flot with eCharts
                  info Adapter removed
                  Would you like to upgrade discovery from @2.7.3 to @2.7.5 now? [(y)es, (n)o]: y
                  Update discovery from @2.7.3 to @2.7.5
                  npm install iobroker.discovery@2.7.5 --loglevel error --prefix "/opt/iobroker" (System call)
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_54_11_360Z-debug.log
                  upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                  upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                  upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                  upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                  upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                  Adapter "discovery" updated
                  This upgrade of "admin" will introduce the following changes:
                  -> 5.3.1:
                  Support of IPv6 address by links (vis, material, end so on)
                  Corrected errors in the base settings
                  Corrected error with the pre-selected language in wizard
                  -> 5.3.0:
                  Enable http compression in webserver
                  Removed deprecated package "request"
                  Added JSONL option for base settings
                  Added small improvements
                  Added the file viewer for binary states
                  Would you like to upgrade admin from @5.2.3 to @5.3.1 now? [(y)es, (n)o]: y
                  Update admin from @5.2.3 to @5.3.1
                  host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                  npm install iobroker.admin@5.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_55_22_755Z-debug.log
                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  Adapter "admin" updated
                  host.raspberrypi Adapter "system.adapter.admin.0" is started
                  This upgrade of "shelly" will at least introduce the following changes:
                  -> 5.3.2:
                  Added cover position status for generation 2 devices
                  Added cover power, voltage, current and energy for generation 2 devices
                  Updated switch roles for material ui (switch.power to switch)
                  -> 5.3.1:
                  Don't ack new values directly after change
                  -> 5.3.0:
                  Added Shelly Plus I4
                  Added more objects for power metering channels (current, voltage, limits, ...)
                  Moved device temperature of generation 2 devices to relays (this is the official way)
                  Added Sys channel (eco mode, timezone, ...) for generation 1 devices
                  Fixed datatype error of Shelly 1/PM ext switch
                  Added option to enable/disable WiFi access point (generation 2 devices)
                  Added power limits and position control for covers (generation 2 devices)
                  Removed colors for online state indication on device objects
                  -> 5.2.0:
                  Added Shelly Pro 1
                  Added Shelly Pro 1 PM
                  Added Shelly Pro 2
                  Added Shelly Pro 2 PM
                  Added Shelly Plus 2 PM
                  Allow to change device and channel names of generation 2 devices
                  Added auto on/off timers for generation 2 devices
                  Added input mode, events and initial state for generation 2 devices
                  Added support of covers / shutters for generation 2 devices
                  Replaced node-fetch with axios (also for digest auth)
                  -> 5.1.3:
                  Changed common.states strings to objects
                  Just perform firmware update if an available update was detected
                  Extended logging for CoAP
                  -> 5.1.2:
                  Fixed Shelly UNI ADC voltage
                  Fixed dimmer brightness values handling
                  Logging improvements for offline devices
                  -> 5.1.1:
                  Fixed firmware auto update
                  Updated timeouts
                  Added command source for shelly 2.5
                  Added color for device objects as online indicator
                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                  Would you like to upgrade shelly from @4.0.7 to @5.3.2 now? [(y)es, (n)o]: y
                  Update shelly from @4.0.7 to @5.3.2
                  npm install iobroker.shelly@5.3.2 --loglevel error --prefix "/opt/iobroker" (System call)
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_56_39_294Z-debug.log
                  upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                  upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                  upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                  upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                  upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  Adapter "shelly" updated
                  This upgrade of "mihome-vacuum" will at least introduce the following changes:
                  -> 3.3.1:
                  fix IOBROKER-MIHOME-VACUUM-Z
                  fix some errors
                  -> 3.3.0:
                  fix no rooms for S5
                  fix IOBROKER-MIHOME-VACUUM-4 DB closed
                  fix connection error
                  -> 3.2.2:
                  the communication is corrected
                  Added roles to be detected by type-detector
                  -> 3.2.1:
                  Adjust several crash cases (IOBROKER-MIHOME-VACUUM-K, IOBROKER-MIHOME-VACUUM-J, IOBROKER-MIHOME-VACUUM-F, IOBROKER-MIHOME-VACUUM-7, IOBROKER-MIHOME-VACUUM-A, IOBROKER-MIHOME-VACUUM-4, IOBROKER-MIHOME-VACUUM-G, IOBROKER-MIHOME-VACUUM-C, IOBROKER-MIHOME-VACUUM-B, IOBROKER-MIHOME-VACUUM-Q, IOBROKER-MIHOME-VACUUM-M)
                  -> 3.2.0:
                  fixed error
                  -> 3.1.7:
                  added Sentry, minimize messages, fix disk I/O
                  -> 3.1.5:
                  Breaking changes, Map format changed, added wifi state, added multimap support, added mopstate, fixed objects, show zones and points when selectiong in app, minmize disk I/O, minimize Messages clear and extend log,
                  Would you like to upgrade mihome-vacuum from @1.1.5 to @3.3.1 now? [(y)es, (n)o]: y
                  Update mihome-vacuum from @1.1.5 to @3.3.1
                  npm install iobroker.mihome-vacuum@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_57_43_910Z-debug.log
                  upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                  Update "system.adapter.mihome-vacuum.0"
                  upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                  upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                  upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                  upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                  upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                  upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                  upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                  upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                  upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                  upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                  Adapter "mihome-vacuum" updated
                  This upgrade of "backitup" will introduce the following changes:
                  -> 2.3.3:
                  small GUI fixes
                  Docker restore tunning
                  -> 2.3.2:
                  Bugfix Restore Interface for http
                  Fix json history
                  -> 2.3.1:
                  Bugfix Grafana
                  Bugfix Restore for Docker System
                  Restore Interface with https Support
                  use iobroker SSL Certificates for https
                  -> 2.3.0:
                  Influxdb2 Backup added
                  Influxdb2 Restore added
                  Bugfix Grafana Backup
                  Bugfix GUI
                  Bugfix Redis Restore
                  New Restore WebIf added
                  dependencies updated
                  Bugfix start after Restore
                  redis remote Backup added
                  Error messages configurable
                  Translations added
                  Adjustments to js-controller 4
                  -> 2.2.4:
                  Restore backup of different controller version added
                  Fix YAHKA Backup for more Instances
                  Would you like to upgrade backitup from @2.2.3 to @2.3.3 now? [(y)es, (n)o]: y
                  Update backitup from @2.2.3 to @2.3.3
                  npm install iobroker.backitup@2.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                      import gyp
                      import gyp.input
                      import ast
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_59_12_369Z-debug.log
                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  Adapter "backitup" updated
                  • M Markus Faltermeier
                    update done
                    -> 3.6.5:
                    -> 3.6.3:
                    -> 3.6.2:
                    -> 3.6.1:
                    -> 3.6.0:
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    -> 2.7.5:
                    -> 2.7.4:
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    -> 5.3.1:
                    -> 5.3.0:
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    -> 5.3.2:
                    -> 5.3.1:
                    -> 5.3.0:
                    -> 5.2.0:
                    Added Shelly Pro 1
                    Added Shelly Pro 2
                    -> 5.1.3:
                    -> 5.1.2:
                    -> 5.1.1:
                    Updated timeouts
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    -> 3.3.1:
                    fix some errors
                    -> 3.3.0:
                    fix no rooms for S5
                    -> 3.2.2:
                    -> 3.2.1:
                    -> 3.2.0:
                    fixed error
                    -> 3.1.7:
                    -> 3.1.5:
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    -> 2.3.3:
                    small GUI fixes
                    -> 2.3.2:
                    Fix json history
                    -> 2.3.1:
                    Bugfix Grafana
                    -> 2.3.0:
                    Bugfix GUI
                    Translations added
                    -> 2.2.4:
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                        import gyp
                        import gyp.input
                        import ast
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    Thomas BraunT
                    Thomas BraunT
                    @markus-faltermeier
                    iobroker stop
                    iobroker fix
                    iobroker start
                      @markus-faltermeier
                      iobroker stop
                      iobroker fix
                      iobroker start
                      M
                      M
                      Markus Faltermeier
                      das lief jetzt zumindest mal ohne Fehler durch
                      pi@raspberrypi:/opt/iobroker $ iobroker fix
                      library: loaded
                      Library version=2022-02-10
                          Welcome to the ioBroker installation fixer!
                          Script version: 2022-02-13
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/3)
                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                      Installed gcc-c++
                      Installed python-dev
                          Checking ioBroker user and directory permissions (2/3)
                          Checking autostart (3/3)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                        library: loaded
                        Installed gcc-c++
                        Autostart enabled!
                        Thomas BraunT
                        Thomas BraunT
                        @markus-faltermeier
                        Editiere /opt/iobroker/node_modules/canvas/package.json:
                        Suche nach der "scripts" sektion und dort "install"
                        Das install kommando ist
                        node-pre-gyp install --fallback-to-build
                        hänge mal noch
                        --update-binary
                        dran.
                        Also
                        node-pre-gyp install --fallback-to-build --update-binary
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          Thomas BraunT
                          Thomas BraunT
                          #66
                          @markus-faltermeier
                          Ist der terminal-Adapter jetzt auch deinstalliert?
                            @markus-faltermeier
                            M
                            M
                            Markus Faltermeier
                            #67
                            ich kann den nicht löschen. da bekomme ich die gleichen Fehlermeldungen wie beim updaten:
                            $ iobroker del terminal
                            Delete adapter "terminal"
                            host.raspberrypi object terminal deleted
                            host.raspberrypi object terminal.admin deleted
                            npm uninstall iobroker.terminal --loglevel error --prefix "/opt/iobroker" (System call)
                            npm ERR! code ENOENTnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-streamnpm ERR! errno -2
                            npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-stream'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T13_22_31_721Z-debug.log
                            Error deleting adapter terminal from disk: Error: host.raspberrypi: Cannot uninstall iobroker.terminal: 254
                            You might have to delete it yourself!
                            Process exited with code 0
                              #68
                              @markus-faltermeier sagte in Probleme bei Update von admin:
                              dann mach das
                                @markus-faltermeier
                                hänge mal noch
                                --update-binary
                                dran.
                                Also
                                M
                                M
                                Markus Faltermeier
                                #69
                                Hi ich habe jetzt alles durchsucht. Aber ich habe kein Verzeichnis "Canvas"
                                pi@raspberrypi:/opt/iobroker/node_modules $ ls
                                abab                        har-schema                             object-hash
                                abort-controller            har-validator                          object-inspect
                                accepts                     has                                    object-keys
                                acme-http-01-standalone     has-bigints                            once
                                acorn                       has-binary                             one-time
                                acorn-globals               has-binary2                            on-finished
                                acorn-walk                  has-cors                               on-headers
                                after                       has-symbols                            optionator
                                agent-base                  has-tostringtag                        options
                                ajv                         has-unicode                            ordered-read-streams
                                @alcalzone                  hawk                                   os-locale
                                alcalzone-shared            he                                     ospath
                                alexa-cookie2               help-me                                otplib
                                alexa-remote2               hoek                                   owlintuition
                                ansi-regex                  homematic-xmlrpc                       pako
                                ansi-styles                 hosted-git-info                        parse5
                                anymatch                    hot-patcher                            parse-json
                                @apollon                    html-encoding-sniffer                  parsejson
                                aproba                      http-errors                            parseqs
                                are-we-there-yet            http-proxy                             parseuri
                                argparse                    http-proxy-agent                       parseurl
                                arraybuffer.slice           http-proxy-middleware                  parsexmlresponse
                                array-ext                   http-proxy-response-rewrite            passport
                                array-flatten               https                                  passport-local
                                array.prototype.findindex   http-signature                         passport.socketio
                                arrify                      https-proxy-agent                      passport-strategy
                                asap                        iconv-lite                             path-dirname
                                asn1                        ieee754                                path-exists
                                asn1-ber                    immediate                              path-is-absolute
                                assert-plus                 indexof                                path-parse
                                async                       inflight                               path-posix
                                asynckit                    inherits                               path-to-regexp
                                async-limiter               ini                                    path-type
                                async-retry                 internal-slot                          pause
                                at-least-node               invert-kv                              pause-stream
                                autobind-decorator          @iobroker                              performance-now
                                aws4                        iobroker                               picocolors
                                aws-iot-device-sdk          iobroker.admin                         picomatch
                                aws-sign2                   iobroker.alexa2                        pidusage
                                axios                       iobroker.backitup                      pify
                                backo2                      iobroker.cloud                         ping
                                balanced-match              iobroker.daswetter                     pinkie
                                base-64                     iobroker.deconz                        pinkie-promise
                                base64-arraybuffer          iobroker.denon                         pluralize
                                base64id                    iobroker.discovery                     p-map
                                base64-js                   iobroker.dwd                           portfinder
                                bcrypt-pbkdf                iobroker.email                         prelude-ls
                                bent                        iobroker.fhem                          process-nextick-args
                                better-assert               iobroker.flot                          promise
                                bignumber.js                iobroker.fritzbox                      promisify-child-process
                                binary                      iobroker.geofency                      prompt
                                binary-extensions           iobroker.harmony                       proper-lockfile
                                bindings                    iobroker.heatingcontrol                proxy-addr
                                binrpc                      iobroker.history                       psl
                                bl                          iobroker.hm-rega                       pump
                                blob                        iobroker.hm-rpc                        pumpify
                                bluebird                    iobroker.hue                           punycode
                                body-parser                 iobroker.ical                          pushover-notifications
                                boom                        iobroker.icons-icons8                  put
                                bottleneck                  iobroker.icons-mfd-svg                 q
                                brace-expansion             iobroker.icons-ultimate-png            qs
                                braces                      iobroker.info                          querystring
                                browser-process-hrtime      iobroker.iot                           querystringify
                                buffer                      iobroker.javascript                    random-bytes
                                buffer-equal-constant-time  iobroker.js-controller                 range-parser
                                buffer-from                 iobroker.lightify                      rasha
                                bufferhelper                iobroker.mihome                        raw-body
                                buffers                     iobroker.mihome-vacuum                 rc
                                busboy                      iobroker.mobile                        read
                                button-events               iobroker.mqtt                          readable-stream
                                bytes                       iobroker.mqtt-client                   readdirp
                                bytesish                    iobroker.nut                           readline-sync
                                callback-stream             iobroker.octoprint                     read-pkg
                                call-bind                   iobroker.ping                          read-pkg-up
                                callsite                    iobroker.pushover                      redirect-https
                                camelcase                   iobroker.rpi2                          redis-commands
                                capitalize                  iobroker.scenes                        redis-errors
                                caseless                    iobroker.shelly                        redis-parser
                                cert-info                   iobroker.simple-api                    reinterval
                                chainsaw                    iobroker.snmp                          remove-trailing-separator
                                charenc                     iobroker.socketio                      request
                                chokidar                    iobroker.sonoff                        request-promise
                                chownr                      iobroker.spotify-premium               request-promise-core
                                ci-info                     iobroker.statistics                    request-promise-native
                                cli                         iobroker.synology                      require-directory
                                cliff                       iobroker.tankerkoenig                  require-main-filename
                                cliui                       iobroker.telegram                      requires-port
                                cloneextend                 iobroker.terminal                      resolve
                                cluster-key-slot            iobroker.text2command                  respjs
                                co                          iobroker.tr-064                        retry
                                coap                        iobroker.type-detector                 revalidator
                                coap-packet                 iobroker.upnp                          rfdc
                                code-point-at               iobroker.vis                           @root
                                coffee-compiler             iobroker.vis-bars                      rpi-gpio
                                coffee-script               iobroker.vis-colorpicker               rpi-gpio-buttons
                                coiot-coap                  iobroker.vis-fancyswitch               rrule
                                color                       iobroker.vis-google-fonts              safe-buffer
                                color-convert               iobroker.vis-hqwidgets                 safer-buffer
                                color-name                  iobroker.vis-jqui-mfd                  safe-replace
                                @colors                     iobroker.vis-metro                     safe-stable-stringify
                                colors                      iobroker.vis-players                   sax
                                colorspace                  iobroker.vis-plumb                     saxes
                                color-string                iobroker.vis-timeandweather            secure-keys
                                combined-stream             iobroker.vis-weather                   semaphore
                                commander                   iobroker.web                           semver
                                commist                     ioredis                                send
                                component-bind              ip                                     @sentry
                                component-emitter           ipaddr.js                              seq-logging
                                component-inherit           is                                     @serialport
                                concat-map                  is-absolute                            serialport
                                concat-stream               isarray                                serve-static
                                connect                     is-arrayish                            set-blocking
                                connect-flash               is-bigint                              set-immediate-shim
                                console-control-strings     is-binary-path                         setprototypeof
                                content-disposition         is-boolean-object                      shelly-iot
                                content-type                is-callable                            side-channel
                                cookie                      is-date-object                         signal-exit
                                cookie-parser               isemail                                simple-concat
                                cookie-signature            is-extglob                             simple-get
                                core-util-is                is-fullwidth-code-point                simple-swizzle
                                cron                        is-glob                                sntp
                                cron-parser                 is-nan                                 socket.io
                                crypt                       is-negated-glob                        socket.io-adapter
                                cryptiles                   is-negative-zero                       socket.io-client
                                crypto-js                   is-number                              socket.io-parser
                                cssom                       is-number-object                       socksv5
                                cssstyle                    is-plain-obj                           soef
                                cycle                       is-potential-custom-element-name       sorted-array-functions
                                d                           is-regex                               source-map
                                @dabh                       is-relative                            source-map-support
                                daemonize2                  is-shared-array-buffer                 spdx-correct
                                dashdash                    is-stream                              spdx-exceptions
                                data-urls                   isstream                               spdx-expression-parse
                                debug                       is-string                              spdx-license-ids
                                decache                     is-symbol                              split
                                decamelize                  is-typedarray                          split2
                                decimal.js                  is-unc-path                            sprintf-js
                                decompress-response         is-utf8                                sshpk
                                deep-clone                  is-weakref                             stack-trace
                                deep-extend                 is-windows                             standard-as-callback
                                deep-is                     joi                                    statuses
                                define-properties           jsbn                                   stealthy-require
                                delayed-stream              jsdom                                  stream-combiner
                                delegates                   jshashes                               streamsearch
                                denque                      json3                                  stream-shift
                                depd                        jsonata                                string_decoder
                                destroy                     json-bigint                            string.prototype.trimend
                                detect-libc                 jsonc-parser                           string.prototype.trimstart
                                dgram                       jsonfile                               stringstream
                                dicer                       json-schema                            string-width
                                diskusage                   json-schema-traverse                   strip-ansi
                                dns-packet                  json-stable-stringify-without-jsonify  strip-bom
                                domexception                json-stringify-safe                    strip-json-comments
                                dropbox-v2-api              jsonwebtoken                           strnum
                                duplexer                    jsprim                                 suncalc2
                                duplexify                   js-sdsl                                symbol-tree
                                ecc-jsbn                    js-yaml                                sync-exec
                                ecdsa-sig-formatter         jszip                                  syno
                                echarts                     jwa                                    systeminformation
                                eckles                      jws                                    tar
                                ee-first                    keypairs                               tar-fs
                                emoji-regex                 kuler                                  tar-stream
                                enabled                     layerr                                 tcp-ping
                                encodeurl                   lcid                                   text-hex
                                end-of-stream               le-acme-core                           thirty-two
                                engine.io                   le-challenge-fs                        through
                                engine.io-client            le-sni-auto                            through2
                                engine.io-parser            leven                                  through2-filter
                                epoll                       levn                                   to-absolute-glob
                                error-ex                    lie                                    to-array
                                es5-ext                     loadavg-windows                        toidentifier
                                es6-iterator                load-json-file                         @tootallnate
                                es6-map                     localforage                            topo
                                es6-promise                 lodash                                 to-regex-range
                                es6-set                     lodash.defaults                        tough-cookie
                                es6-symbol                  lodash.flatten                         tr46
                                es-abstract                 lodash.includes                        traverse
                                esbuild                     lodash.isarguments                     triple-beam
                                escalade                    lodash.isboolean                       tslib
                                escape-html                 lodash.isinteger                       tunnel-agent
                                escodegen                   lodash.isnumber                        tweetnacl
                                esprima                     lodash.isplainobject                   type
                                es-to-primitive             lodash.isstring                        type-check
                                estraverse                  lodash.once                            typedarray
                                esutils                     logform                                type-is
                                etag                        long-timeout                           @types
                                event-emitter               lru-cache                              typescript
                                eventemitter3               lru_map                                uid-number
                                event-stream                luxon                                  uid-safe
                                event-target-shim           map-stream                             ultron
                                expand-template             md5                                    unbox-primitive
                                express                     mdns-discovery                         unc-path-regex
                                express-fileupload          media-typer                            underscore
                                express-session             merge-descriptors                      unique-stream
                                ext                         methods                                universalify
                                extend                      micromatch                             unpipe
                                extsprintf                  mime                                   uri-js
                                eyes                        mime-db                                url-join
                                fast-deep-equal             mime-types                             url-parse
                                fast-json-stable-stringify  mimic-response                         url-template
                                fast-levenshtein            minimatch                              ursa-optional
                                fastseries                  minimist                               util-deprecate
                                fast-text-encoding          minipass                               utils-merge
                                fast-xml-parser             minizlib                               uuid
                                fecha                       mkdirp                                 validate-npm-package-license
                                file-stream-rotator         mkdirp-classic                         vary
                                file-type                   moment                                 verror
                                file-uri-to-path            moment-timezone                        virtual-tsc
                                fill-range                  mqtt                                   vm2
                                finalhandler                mqtt-connection                        w3c-hr-time
                                find-up                     mqtt-packet                            w3c-xmlserializer
                                fn.name                     ms                                     wake_on_lan
                                follow-redirects            mute-stream                            weak-daemon
                                forever-agent               nan                                    webdav
                                form-data                   napi-build-utils                       webidl-conversions
                                forwarded                   nconf                                  websocket-stream
                                fresh                       ncp                                    whatwg-encoding
                                from                        nearest-color                          whatwg-mimetype
                                fs-constants                negotiator                             whatwg-url
                                fs-extra                    nested-property                        which-boxed-primitive
                                fs-minipass                 netmask                                which-module
                                fs.realpath                 net-snmp                               wide-align
                                ftp                         next-tick                              window-size
                                function-bind               node-dht-sensor                        winston
                                gauge                       node-expat                             winston-daily-rotate-file
                                gaxios                      node.extend                            winston-seq-updated
                                gcp-metadata                node-fetch                             winston-syslog
                                get-caller-file             node-forge                             winston-transport
                                get-intrinsic               node-hue-api                           word-wrap
                                getpass                     node-ical                              wrap-ansi
                                get-ssl-certificate         node-inspect                           wrappy
                                get-symbol-description      nodemailer                             ws
                                github-from-package         node-mndp                              wtf-8
                                glob                        node-nut                               xml2js
                                glob-parent                 node-rest-client                       xml2json
                                glob-stream                 node-schedule                          xml2json-light
                                glossy                      node-ssdp                              xmlbuilder
                                @googleapis                 node-telegram-bot-api                  xmlchars
                                googleapis-common           node-wol                               xmldom
                                google-auth-library         normalize-package-data                 xmlhttprequest-ssl
                                google-p12-pem              normalize-path                         xml-name-validator
                                graceful-fs                 npmlog                                 xregexp
                                @greenlock                  number-allocator                       xtend
                                greenlock                   number-is-nan                          y18n
                                greenlock-express           nwsapi                                 yallist
                                greenlock-manager-fs        oauth                                  yargs
                                greenlock-store-fs          oauth-sign                             yargs-parser
                                gtoken                      object-assign                          yeast
                                @harmonyhub                 object.assign                          zigbee-herdsman
                                harmonyhubws                object-component                       zrender
                                pi@raspberrypi:/opt/iobroker/node_modules $ cd /canvas
                                -bash: cd: /canvas: Datei oder Verzeichnis nicht gefunden
                                pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker/node_modules/canvas
                                -bash: cd: /opt/iobroker/node_modules/canvas: Datei oder Verzeichnis nicht gefunden
                                  cron                        is-glob                                sntp
                                  eckles                      jws                                    tar
                                  fill-range                  mqtt                                   vm2
                                  Thomas BraunT
                                  Thomas BraunT
                                  #70
                                  @markus-faltermeier
                                  Komisch. Da sehe ich eigentlich entsprechende Meldungen in deinem Log die auf canvas hindeuten würden.
                                  cd /opt/iobroker
                                  npm ls canvas
                                  M 2 Antworten Letzte Antwort
                                    @markus-faltermeier
                                    cd /opt/iobroker
                                    npm ls canvas
                                    M
                                    M
                                    Markus Faltermeier
                                    #71
                                    @thomas-braun Hi,
                                    da bekomme ich diese Ausgabe
                                    pi@raspberrypi:/opt/iobroker $ npm ls canvas
                                    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                                    iobroker.inst@2.0.3 /opt/iobroker
                                    └─┬ iobroker.iot@1.8.24
                                      └── UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                                      @thomas-braun Hi,
                                      Thomas BraunT
                                      Thomas BraunT
                                      #72
                                      @markus-faltermeier
                                      Da hängt schon mal eines deiner Probleme.
                                      npm ls
                                      bringt?
                                      HomoranH M 2 Antworten Letzte Antwort
                                        @markus-faltermeier
                                        cd /opt/iobroker
                                        npm ls canvas
                                        M
                                        M
                                        Markus Faltermeier
                                        #73
                                        Ich hab jetzt nochmal versucht nach dem anderen thread vorzugehen.
                                        mit "npm list" taucht der tr064 immer noch auf. Und ich krieg den nicht gelöscht
                                         semver@5.7.1
                                        └─┬ yargs@7.1.0
                                          ├── camelcase@3.0.0
                                          ├─┬ cliui@3.2.0
                                          │ ├── string-width@1.0.2 deduped
                                          ├─┬ os-locale@1.4.0
                                          │ └─┬ lcid@1.0.0
                                        sieht zwar so aus, als ob er dann mit dem angegebenen Befehl:
                                        cd /opt/iobroker/node_modules/iobroker.tr-064
                                        npm uninstall tr-O64
                                        deinstalliert. Aber anschließend ist er immer noch da.
                                        ich bekomm da folgende Ausgabe:
                                        pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.tr-064
                                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.tr-064 $ npm uninstall tr-O64
                                        > es5-ext@0.10.57 postinstall /opt/iobroker/node_modules/iobroker.tr-064/node_modules/es5-ext
                                        > node -e "try{require('./_postinstall')}catch(e){}"
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        added 564 packages from 408 contributors and audited 570 packages in 29.66s
                                        43 packages are looking for funding
                                          run `npm fund` for details
                                        found 3 vulnerabilities (1 low, 2 high)
                                          run `npm audit fix` to fix them, or `npm audit` for details
                                          @markus-faltermeier
                                          npm ls
                                          bringt?
                                          #74
                                          @thomas-braun sagte in Probleme bei Update von admin:
                                          und das zweite ist die falsche Version von der package-lock.json wegen npm v8.
                                          84.1k
