  4. [gelöst] Probleme bei Update von admin
admin-adapterehostunreachfehlermeldungupdateupdate adapter
85 Beiträge 6 Kommentatoren 15.0k Aufrufe 3 Beobachtet
  • M Markus Faltermeier
    habs probiert. aber auch beim Löschen kommen ähnliche Fehler...
    geht also auch nicht
    $ iobroker del tr-064
    Delete adapter "tr-064"
    host.raspberrypi Counted 2 meta of tr-064
    host.raspberrypi Counted 1 adapter for tr-064
    host.raspberrypi Counted 1 states of system.adapter.tr-064
    host.raspberrypi Counted 1 states (system.adapter.tr-064.*) from states
    host.raspberrypi file tr-064.admin deleted
    host.raspberrypi object tr-064 deleted
    host.raspberrypi object tr-064.admin deleted
    host.raspberrypi Deleting 4 object(s).
    host.raspberrypi Deleting 1 state(s).
    npm uninstall iobroker.tr-064 --loglevel error --prefix "/opt/iobroker" (System call)
    Traceback (most recent call last): File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module> import gyp File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module> import gyp.input File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module> import astImportError: No module named astgyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
    gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
    gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:400:28)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1058:16)
    node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)node-pre-gyp ERR! System Linux 5.10.103-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v14.19.0node-pre-gyp ERR! node-pre-gyp -v v1.0.8node-pre-gyp ERR! not ok
    gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.103-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindingsgyp ERR! node -v v14.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.2.8 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T12_00_44_147Z-debug.log
    Error deleting adapter tr-064 from disk: Error: host.raspberrypi: Cannot uninstall iobroker.tr-064: 1You might have to delete it yourself!
    Process exited with code 0
    @markus-faltermeier sagte in Probleme bei Update von admin:
    hast du den verlinkten Thread gelesen?
    und auch den darin enthaltenen Link?
    https://forum.iobroker.net/topic/46210/npm-problem/7?_=1646992450721
      M
      M
      Markus Faltermeier
      ich versuch das grade alles zu verstehen.
      ich habe jetzt auch noch mal den oberen Befehl benutzt.
      Wie es aussieht ist er jetzt wirklich deinstalliert. Er taucht zumindest nicht mehr in der Liste auf
      pi@raspberrypi:/ $ iobroker list adapters
      system.adapter.admin                   : admin          - v5.3.1
      system.adapter.alexa2                  : alexa2         - v3.11.2
      system.adapter.backitup                : backitup       - v2.3.3
      system.adapter.cloud                   : cloud          - v4.1.0
      system.adapter.daswetter               : daswetter      - v3.0.9
      system.adapter.deconz                  : deconz         - v1.3.19
      system.adapter.denon                   : denon          - v1.12.1
      system.adapter.discovery               : discovery      - v2.7.5
      system.adapter.dwd                     : dwd            - v2.7.7
      system.adapter.email                   : email          - v1.0.10
      system.adapter.fhem                    : fhem           - v1.6.3
      system.adapter.flot                    : flot           - v1.10.7
      system.adapter.fritzbox                : fritzbox       - v0.2.1
      system.adapter.geofency                : geofency       - v1.0.3
      system.adapter.harmony                 : harmony        - v1.2.2
      system.adapter.heatingcontrol          : heatingcontrol - v2.7.2
      system.adapter.history                 : history        - v1.10.5
      system.adapter.hm-rega                 : hm-rega        - v3.0.35
      system.adapter.hm-rpc                  : hm-rpc         - v1.15.0
      system.adapter.hmm                     : hmm            - v1.0.1
      system.adapter.hue                     : hue            - v3.6.5
      system.adapter.ical                    : ical           - v1.11.4
      system.adapter.icons-icons8            : icons-icons8   - v0.0.1
      system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
      system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
      system.adapter.info                    : info           - v1.9.8
      system.adapter.iot                     : iot            - v1.8.24
      system.adapter.javascript              : javascript     - v5.2.21
      system.adapter.lightify                : lightify       - v0.2.16
      system.adapter.mihome                  : mihome         - v1.3.7
      system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
      system.adapter.mobile                  : mobile         - v1.0.1
      system.adapter.mqtt                    : mqtt           - v2.4.1
      system.adapter.mqtt-client             : mqtt-client    - v1.5.0
      system.adapter.node-red                : node-red       - v1.9.0
      system.adapter.nut                     : nut            - v1.5.0
      system.adapter.octoprint               : octoprint      - v2.1.0
      system.adapter.ping                    : ping           - v1.5.0
      system.adapter.pushover                : pushover       - v2.0.5
      system.adapter.radar                   : radar          - v1.1.3
      system.adapter.rpi2                    : rpi2           - v1.3.1
      system.adapter.scenes                  : scenes         - v2.3.8
      system.adapter.shelly                  : shelly         - v5.3.2
      system.adapter.simple-api              : simple-api     - v2.6.2
      system.adapter.snmp                    : snmp           - v0.5.0
      system.adapter.socketio                : socketio       - v3.1.5
      system.adapter.sonoff                  : sonoff         - v2.4.7
      system.adapter.spotify-premium         : spotify-premium - v1.0.0
      system.adapter.statistics              : statistics     - v1.0.9
      system.adapter.synology                : synology       - v1.1.3
      system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
      system.adapter.telegram                : telegram       - v1.11.1
      system.adapter.text2command            : text2command   - v2.1.1
      system.adapter.upnp                    : upnp           - v1.0.19
      system.adapter.vis                     : vis            - v1.4.5
      system.adapter.vis-bars                : vis-bars       - v0.1.4
      system.adapter.vis-beta                : vis-beta       - v0.12.11
      system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
      system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
      system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
      system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
      system.adapter.vis-metro               : vis-metro      - v1.1.2
      system.adapter.vis-players             : vis-players    - v0.1.6
      system.adapter.vis-plumb               : vis-plumb      - v1.0.2
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
      system.adapter.vis-weather             : vis-weather    - v2.5.5
      system.adapter.web                     : web            - v3.4.16
      system.adapter.zigbee                  : zigbee         - v1.6.16
        hast du denn keine Probleme mehr.
        im zweiten verlinkten Thread brachte
        cd /opt/iobroker/
        npm list
        noch die Überreste hervor
          cd /opt/iobroker/
          npm list
          M
          M
          Markus Faltermeier
          hab ich probiert. Ich bekomme bei diesem Befehl auch jede Menge Fehler:
            │   │ ├─┬ parse-json@2.2.0
            │   │ │ └─┬ error-ex@1.3.2
            │   │ │   └── is-arrayish@0.2.1
            │   │ ├── pify@2.3.0
            │   │ ├── pinkie-promise@2.0.1 deduped
            │   │ └─┬ strip-bom@2.0.0
            │   │   └── is-utf8@0.2.1
            │   ├─┬ normalize-package-data@2.5.0
            │   │ ├── hosted-git-info@2.8.8
            │   │ ├─┬ resolve@1.17.0
            │   │ │ └── path-parse@1.0.6
            │   │ ├── semver@5.7.1 deduped
            │   │ └─┬ validate-npm-package-license@3.0.4
            │   │   ├─┬ spdx-correct@3.1.0
            │   │   │ ├── spdx-expression-parse@3.0.0 deduped
            │   │   │ └── spdx-license-ids@3.0.5
            │   │   └─┬ spdx-expression-parse@3.0.0
            │   │     ├── spdx-exceptions@2.3.0
            │   │     └── spdx-license-ids@3.0.5 deduped
            │   └─┬ path-type@1.1.0
            │     ├── graceful-fs@4.2.4 deduped
            │     ├── pify@2.3.0 deduped
            │     └── pinkie-promise@2.0.1 deduped
            ├── require-directory@2.1.1
            ├── require-main-filename@1.0.1
            ├── set-blocking@2.0.0
            ├─┬ string-width@1.0.2
            │ ├── code-point-at@1.1.0
            │ ├─┬ is-fullwidth-code-point@1.0.0
            │ │ └── number-is-nan@1.0.1
            │ └── strip-ansi@3.0.1 deduped
            ├── which-module@1.0.0
            ├── y18n@3.2.1
            └─┬ yargs-parser@5.0.0
              └── camelcase@3.0.0 deduped
          npm ERR! missing: iobroker.terminal@0.1.2, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.zigbee@1.6.16, required by iobroker.inst@2.0.3
          npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
          npm ERR! missing: commander@5.1.0, required by iobroker.terminal@0.1.2
          npm ERR! missing: connect@3.7.0, required by iobroker.terminal@0.1.2
          npm ERR! missing: passport@0.2.2, required by iobroker.terminal@0.1.2
          npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.zigbee@1.6.        16
          npm ERR! missing: typescript@4.5.4, required by iobroker.zigbee@1.6.16
          npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigb        ee@1.6.16
          npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.        1
          npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
          npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14        .0.422
          npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converter        s@14.0.422
          npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.        422
          npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converter        s@14.0.422
          npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
          npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
          npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
          npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
          npm ERR! missing: ms@2.1.2, required by debug@4.3.3
          npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
          npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
          npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
          npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
          npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
          npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
          npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
          npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
          npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
          npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
          npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
          npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
          npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
          npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
          npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
          npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
          npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
          npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
          npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
          npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
          npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
          npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
          npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
          npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
          npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
          npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
          npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
          npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
          npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
          npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
          npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9        .2.8
          npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
          npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2        .8
          npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by seria        lport@9.2.8
          npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.        8
          npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
          npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
          npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
          npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
          npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bi        nding-mock@9.2.4
          npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
          npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
          npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bi        ndings@9.2.8
          npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bin        dings@9.2.8
          npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
          npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
          npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
          npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
          npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
          npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
          npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
          npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
          npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
          npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
          npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
          npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
          npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
          npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
          npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
          npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
          npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
          npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
          npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
          npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
          npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
          npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
          npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
          npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
          npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
          npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
          npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
          npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
          npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
          npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
          npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
          npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
          npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
          npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
          npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
          npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
          npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
          npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
          npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
          npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
          npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
          npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
          npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
          npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
          npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
          npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
          npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
          npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
          npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
          npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
          npm ERR! missing: once@1.4.0, required by pump@3.0.0
          npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
          npm ERR! missing: ini@1.3.8, required by rc@1.2.8
          npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
          npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
          npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
          npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
          npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
          npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
          npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
          npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
          npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
          npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
          npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
          npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
          npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/pa        rser-readline@9.2.4
          npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
              │   │ ├── pify@2.3.0
              ├── y18n@3.2.1
            dann ist bei dir wahrscheinlich auch deine node und npm Installation verbogen.
            Da fehlt doch was
            Bitte vollständige Ein- und Ausgabe posten!
            Da kenne ich mich aber nicht aus. Vielleicht kann dir da @Thomas-Braun helfen
            M 2 Antworten Letzte Antwort
              Da fehlt doch was
              M
              M
              Markus Faltermeier
              wie kann ich das machen. Das Terminal schneidet oben was weg...
              Die Ausgabe ist scheinbar zu lang
                Da fehlt doch was
                M
                M
                Markus Faltermeier
                ich hab jetzt mal alles kopiert soweit wie das terminal es mir noch anzeigt.
                │ │ ├── https-proxy-agent@5.0.0 deduped
                │ │ ├── lru_map@0.3.3 deduped
                │ │ └── tslib@1.11.2 deduped
                │ ├─┬ bent@7.3.12
                │ │ ├── bytesish@0.4.4
                │ │ ├── caseless@0.12.0 deduped
                │ │ └── is-stream@2.0.1
                │ └── xml2json-light@1.0.6
                ├─┬ iobroker.deconz@1.3.19
                │ ├─┬ @iobroker/adapter-core@2.5.1
                │ │ └─┬ @types/iobroker@3.3.4
                │ │   └── @types/node@13.13.5 deduped
                │ ├── @sentry/integrations@6.16.1 deduped
                │ ├── @sentry/node@6.16.1 deduped
                │ ├── request@2.88.2 deduped
                │ ├── source-map-support@0.5.21 deduped
                │ └── ws@7.5.6
                ├─┬ iobroker.denon@1.12.1
                │ └─┬ @iobroker/adapter-core@2.5.1
                ├─┬ iobroker.discovery@2.7.3
                │ ├─┬ mdns-discovery@0.2.6
                │ │ ├─┬ debug@2.2.0
                │ │ │ └── ms@0.7.1
                │ │ ├── dgram@1.0.1
                │ │ └─┬ dns-packet@1.3.1
                │ │   ├── ip@1.1.5 deduped
                │ │   └── safe-buffer@5.1.2 deduped
                │ ├── netmask@2.0.2
                │ ├── node-mndp@0.0.3
                │ ├─┬ node-ssdp@4.0.1
                │ │ ├─┬ async@2.6.3
                │ │ │ └── lodash@4.17.21 deduped
                │ │ ├── bluebird@3.7.2
                │ │ ├─┬ debug@3.2.7
                │ │ │ └── ms@2.1.3
                │ │ ├── extend@3.0.2 deduped
                │ │ └── ip@1.1.5 deduped
                │ └─┬ serialport@9.2.8
                │   ├─┬ @serialport/binding-mock@9.2.4
                │   │ ├─┬ @serialport/binding-abstract@9.2.3
                │   │ │ └─┬ debug@4.3.3
                │   │ │   └── ms@2.1.2
                │   │ └─┬ debug@4.3.3
                │   │   └── ms@2.1.2
                │   ├─┬ UNMET OPTIONAL DEPENDENCY @serialport/bindings@9.2.8
                │   │ ├── @serialport/binding-abstract@9.2.3 deduped
                │   │ ├── @serialport/parser-readline@9.2.4 deduped
                │   │ ├─┬ bindings@1.5.0
                │   │ │ └── file-uri-to-path@1.0.0
                │   │ ├─┬ UNMET OPTIONAL DEPENDENCY debug@4.3.3
                │   │ │ └── UNMET OPTIONAL DEPENDENCY ms@2.1.2
                │   │ ├── nan@2.15.0 deduped
                │   │ └─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@7.0.1
                │   │   ├── UNMET OPTIONAL DEPENDENCY detect-libc@2.0.1
                │   │   ├── expand-template@2.0.3 deduped
                │   │   ├── github-from-package@0.0.0 deduped
                │   │   ├── minimist@1.2.5 deduped
                │   │   ├── mkdirp-classic@0.5.3 deduped
                │   │   ├── napi-build-utils@1.0.2 deduped
                │   │   ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@3.8.0
                │   │   │ └─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                │   │   │   └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                │   │   │     └── yallist@4.0.0 deduped
                │   │   ├── npmlog@4.1.2 deduped
                │   │   ├── pump@3.0.0 deduped
                │   │   ├── rc@1.2.8 deduped
                │   │   ├─┬ UNMET OPTIONAL DEPENDENCY simple-get@4.0.1
                │   │   │ ├─┬ UNMET OPTIONAL DEPENDENCY decompress-response@6.0.0
                │   │   │ │ └── UNMET OPTIONAL DEPENDENCY mimic-response@3.1.0
                │   │   │ ├── once@1.4.0 deduped
                │   │   │ └── simple-concat@1.0.0 deduped
                │   │   ├── tar-fs@2.1.1 deduped
                │   │   └── tunnel-agent@0.6.0 deduped
                │   ├── @serialport/parser-byte-length@9.2.4
                │   ├── @serialport/parser-cctalk@9.2.4
                │   ├── @serialport/parser-delimiter@9.2.4
                │   ├── @serialport/parser-inter-byte-timeout@9.2.4
                │   ├─┬ @serialport/parser-readline@9.2.4
                │   │ └── @serialport/parser-delimiter@9.2.4 deduped
                │   ├── @serialport/parser-ready@9.2.4
                │   ├── @serialport/parser-regex@9.2.4
                │   ├─┬ @serialport/stream@9.2.4
                │   │ └─┬ debug@4.3.3
                │   │   └── ms@2.1.2
                │   └─┬ debug@4.3.3
                │     └── ms@2.1.2
                ├─┬ iobroker.dwd@2.7.7
                │ ├─┬ @iobroker/adapter-core@2.5.0
                │ │ └─┬ @types/iobroker@3.3.0
                │ └─┬ axios@0.21.4
                │   └── follow-redirects@1.14.8 deduped
                ├─┬ iobroker.email@1.0.10
                │ └── nodemailer@6.7.2
                ├─┬ iobroker.fhem@1.6.3
                ├─┬ iobroker.flot@1.10.7
                ├─┬ iobroker.fritzbox@0.2.1
                │ └─┬ xml2js@0.4.23
                │   ├── sax@1.2.4
                │   └── xmlbuilder@11.0.1
                ├─┬ iobroker.geofency@1.0.3
                │ └── request@2.88.2 deduped
                ├─┬ iobroker.harmony@1.2.2
                │ ├─┬ @harmonyhub/discover@1.0.8
                │ │ ├── autobind-decorator@2.4.0
                │ │ └─┬ debug@4.1.1
                │ │   └── ms@2.1.2
                │ ├─┬ @iobroker/adapter-core@1.0.3
                │ │ └─┬ @types/iobroker@1.4.13
                │ ├─┬ harmonyhubws@1.0.6
                │ │ ├── request@2.88.2 deduped
                │ │ ├─┬ request-promise-native@1.0.8
                │ │ │ ├─┬ request-promise-core@1.1.3
                │ │ │ │ └── lodash@4.17.21 deduped
                │ │ │ ├── stealthy-require@1.1.1
                │ │ │ └── tough-cookie@2.5.0 deduped
                │ │ └─┬ ws@6.2.1
                │ │   └── async-limiter@1.0.1
                │ └── semaphore@1.0.5
                ├─┬ iobroker.heatingcontrol@2.7.2
                │ ├─┬ @sentry/node@6.14.1
                │ │ ├─┬ @sentry/core@6.14.1
                │ │ │ ├── @sentry/hub@6.14.1 deduped
                │ │ │ ├─┬ @sentry/minimal@6.14.1
                │ │ │ │ ├── @sentry/hub@6.14.1 deduped
                │ │ │ │ ├── @sentry/types@6.14.1 deduped
                │ │ │ │ └── tslib@1.11.2 deduped
                │ │ │ ├── @sentry/utils@6.14.1 deduped
                │ │ ├─┬ @sentry/hub@6.14.1
                │ │ ├── @sentry/tracing@6.14.1 deduped
                │ │ ├─┬ @sentry/utils@6.14.1
                │ │ ├── cookie@0.4.1 deduped
                │ └─┬ cron@1.8.2
                │   └─┬ moment-timezone@0.5.34
                │     └── moment@2.29.1 deduped
                ├─┬ iobroker.history@1.10.5
                ├─┬ iobroker.hm-rega@3.0.35
                │ ├─┬ iconv-lite@0.6.3
                │ │ └── safer-buffer@2.1.2
                │ └── xml2js@0.4.23 deduped
                ├─┬ iobroker.hm-rpc@1.15.0
                │ ├─┬ binrpc@3.3.1
                │ │ ├─┬ binary@0.3.0
                │ │ │ ├── buffers@0.1.1
                │ │ │ └─┬ chainsaw@0.1.0
                │ │ │   └── traverse@0.3.9
                │ │ └── put@0.0.6
                │ └─┬ homematic-xmlrpc@1.0.2
                │   ├── sax@0.4.3
                │   └── xmlbuilder@0.4.2
                ├─┬ iobroker.hue@3.5.31
                │ └─┬ node-hue-api@4.0.11
                │   ├── axios@0.21.4 deduped
                │   ├── bottleneck@2.19.5
                │   └── get-ssl-certificate@2.3.3
                ├─┬ iobroker.ical@1.11.4
                │ ├── cloneextend@0.0.3
                │ ├─┬ node-ical@0.13.0
                │ │ ├── moment-timezone@0.5.34 deduped
                │ │ ├─┬ node-fetch@2.6.7
                │ │ │ └─┬ whatwg-url@5.0.0
                │ │ │   ├── tr46@0.0.3
                │ │ │   └── webidl-conversions@3.0.1
                │ │ ├── rrule@2.6.8 deduped
                │ │ └── uuid@8.3.2
                │ └─┬ rrule@2.6.8
                │   ├── luxon@1.27.0
                ├── iobroker.icons-icons8@0.0.1
                ├── iobroker.icons-mfd-svg@1.0.2
                ├── iobroker.icons-ultimate-png@1.0.1
                ├─┬ iobroker.info@1.9.8
                │ ├── jshashes@1.0.8
                │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@1.0.7
                │ ├─┬ semver@7.3.5
                │ │ └─┬ lru-cache@6.0.0
                │ └── systeminformation@5.11.3
                ├─┬ iobroker.iot@1.8.24
                │ ├─┬ aws-iot-device-sdk@2.2.11
                │ │ ├── crypto-js@4.0.0
                │ │ ├─┬ mqtt@4.2.8
                │ │ │ ├── commist@1.1.0 deduped
                │ │ │ ├─┬ concat-stream@2.0.0
                │ │ │ │ ├── buffer-from@1.1.1 deduped
                │ │ │ │ ├── inherits@2.0.4 deduped
                │ │ │ │ ├── readable-stream@3.6.0 deduped
                │ │ │ │ └── typedarray@0.0.6 deduped
                │ │ │ ├─┬ debug@4.3.3
                │ │ │ │ └── ms@2.1.2
                │ │ │ ├─┬ duplexify@4.1.2
                │ │ │ │ ├── end-of-stream@1.4.4 deduped
                │ │ │ │ └── stream-shift@1.0.1 deduped
                │ │ │ ├─┬ help-me@3.0.0
                │ │ │ │ ├── glob@7.1.6 deduped
                │ │ │ │ └── readable-stream@3.6.0 deduped
                │ │ │ ├── minimist@1.2.5 deduped
                │ │ │ ├─┬ mqtt-packet@6.10.0
                │ │ │ │ ├── bl@4.1.0 deduped
                │ │ │ │ ├── debug@4.3.3 deduped
                │ │ │ │ └── process-nextick-args@2.0.1 deduped
                │ │ │ ├── pump@3.0.0 deduped
                │ │ │ ├─┬ readable-stream@3.6.0
                │ │ │ │ ├── string_decoder@1.1.1 deduped
                │ │ │ │ └── util-deprecate@1.0.2 deduped
                │ │ │ ├── reinterval@1.1.0 deduped
                │ │ │ ├─┬ split2@3.2.2
                │ │ │ ├── ws@7.5.7
                │ │ │ └── xtend@4.0.2 deduped
                │ │ └── websocket-stream@5.5.2 deduped
                │ ├─┬ UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @mapbox/node-pre-gyp@1.0.8
                │ │ │ ├── detect-libc@1.0.3 deduped
                │ │ │ ├── https-proxy-agent@5.0.0 deduped
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY make-dir@3.1.0
                │ │ │ │ └── UNMET OPTIONAL DEPENDENCY semver@6.3.0
                │ │ │ ├── node-fetch@2.6.7 deduped
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY nopt@5.0.0
                │ │ │ │ └── UNMET OPTIONAL DEPENDENCY abbrev@1.1.1
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY npmlog@5.0.1
                │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY are-we-there-yet@2.0.0
                │ │ │ │ │ ├── delegates@1.0.0
                │ │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY readable-stream@3.6.0
                │ │ │ │ │   ├── inherits@2.0.4 deduped
                │ │ │ │ │   ├── string_decoder@1.1.1 deduped
                │ │ │ │ │   └── util-deprecate@1.0.2 deduped
                │ │ │ │ ├── console-control-strings@1.1.0
                │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY gauge@3.0.2
                │ │ │ │ │ ├── aproba@1.2.0
                │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY color-support@1.1.3
                │ │ │ │ │ ├── console-control-strings@1.1.0 deduped
                │ │ │ │ │ ├── has-unicode@2.0.1
                │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY object-assign@4.1.1
                │ │ │ │ │ ├── signal-exit@3.0.3 deduped
                │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY string-width@4.2.3
                │ │ │ │ │ │ ├── emoji-regex@8.0.0 deduped
                │ │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY is-fullwidth-code-point@3.0.0
                │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY ansi-regex@5.0.1
                │ │ │ │ │ └─┬ wide-align@1.1.3
                │ │ │ │ │   └── string-width@1.0.2 deduped
                │ │ │ │ └── set-blocking@2.0.0 deduped
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY rimraf@3.0.2
                │ │ │ │ └── glob@7.1.6 deduped
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                │ │ │ │   └── yallist@4.0.0 deduped
                │ │ │ └── tar@6.1.11 deduped
                │ │ └─┬ simple-get@3.1.0
                │ │   ├─┬ decompress-response@4.2.1
                │ │   │ └── mimic-response@2.1.0
                │ ├─┬ echarts@4.9.0
                │ │ └── zrender@4.3.2
                │ ├── iobroker.type-detector@1.0.17
                │ ├─┬ jsdom@17.0.0
                │ │ ├── abab@2.0.5
                │ │ ├── acorn@8.7.0
                │ │ ├─┬ acorn-globals@6.0.0
                │ │ │ ├── acorn@7.4.1
                │ │ │ └── acorn-walk@7.2.0
                │ │ ├── cssom@0.5.0
                │ │ ├─┬ cssstyle@2.3.0
                │ │ │ └── cssom@0.3.8
                │ │ ├─┬ data-urls@3.0.1
                │ │ │ ├── abab@2.0.5 deduped
                │ │ │ ├── whatwg-mimetype@3.0.0
                │ │ │ └─┬ whatwg-url@10.0.0
                │ │ │   ├─┬ tr46@3.0.0
                │ │ │   │ └── punycode@2.1.1 deduped
                │ │ │   └── webidl-conversions@7.0.0
                │ │ ├── decimal.js@10.3.1
                │ │ ├─┬ domexception@2.0.1
                │ │ │ └── webidl-conversions@5.0.0
                │ │ ├─┬ escodegen@2.0.0
                │ │ │ ├── esprima@4.0.1
                │ │ │ ├── estraverse@5.3.0
                │ │ │ ├── esutils@2.0.3
                │ │ │ ├─┬ optionator@0.8.3
                │ │ │ │ ├── deep-is@0.1.4
                │ │ │ │ ├── fast-levenshtein@2.0.6
                │ │ │ │ ├─┬ levn@0.3.0
                │ │ │ │ │ ├── prelude-ls@1.1.2 deduped
                │ │ │ │ │ └── type-check@0.3.2 deduped
                │ │ │ │ ├─┬ type-check@0.3.2
                │ │ │ │ │ └── prelude-ls@1.1.2 deduped
                │ │ │ │ └── word-wrap@1.2.3
                │ │ │ └── source-map@0.6.1 deduped
                │ │ ├─┬ form-data@4.0.0
                │ │ │ ├── asynckit@0.4.0 deduped
                │ │ │ ├── combined-stream@1.0.8 deduped
                │ │ │ └── mime-types@2.1.34 deduped
                │ │ ├─┬ html-encoding-sniffer@2.0.1
                │ │ │ └── whatwg-encoding@1.0.5 deduped
                │ │ ├─┬ http-proxy-agent@4.0.1
                │ │ │ ├── @tootallnate/once@1.1.2
                │ │ │ ├── agent-base@6.0.2 deduped
                │ │ │   └── ms@2.1.2
                │ │ ├── is-potential-custom-element-name@1.0.1
                │ │ ├── nwsapi@2.2.0
                │ │ ├── parse5@6.0.1
                │ │ ├─┬ saxes@5.0.1
                │ │ │ └── xmlchars@2.2.0
                │ │ ├── symbol-tree@3.2.4
                │ │ ├─┬ tough-cookie@4.0.0
                │ │ │ ├── psl@1.8.0 deduped
                │ │ │ ├── punycode@2.1.1 deduped
                │ │ │ └── universalify@0.1.2 deduped
                │ │ ├─┬ w3c-hr-time@1.0.2
                │ │ │ └── browser-process-hrtime@1.0.0
                │ │ ├─┬ w3c-xmlserializer@2.0.0
                │ │ │ └── xml-name-validator@3.0.0 deduped
                │ │ ├── webidl-conversions@6.1.0
                │ │ ├─┬ whatwg-encoding@1.0.5
                │ │ │ └── iconv-lite@0.4.24 deduped
                │ │ ├── whatwg-mimetype@2.3.0
                │ │ ├─┬ whatwg-url@9.1.0
                │ │ │ ├─┬ tr46@2.1.0
                │ │ │ └── webidl-conversions@6.1.0 deduped
                │ │ ├── ws@8.5.0
                │ ├── moment@2.29.1
                │ ├─┬ UNMET OPTIONAL DEPENDENCY sharp@0.28.1
                │ │ ├─┬ color@3.2.1
                │ │ │ ├─┬ color-convert@1.9.3
                │ │ │ │ └── color-name@1.1.3
                │ │ │ └─┬ color-string@1.9.0
                │ │ │   ├── color-name@1.1.3 deduped
                │ │ │   └─┬ simple-swizzle@0.2.2
                │ │ │     └── is-arrayish@0.3.2
                │ │ ├── UNMET OPTIONAL DEPENDENCY node-addon-api@3.2.1
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@6.1.4
                │ │ │ ├── expand-template@2.0.3
                │ │ │ ├── github-from-package@0.0.0
                │ │ │ ├── mkdirp-classic@0.5.3 deduped
                │ │ │ ├── napi-build-utils@1.0.2
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@2.30.1
                │ │ │ │ └── semver@5.7.1 deduped
                │ │ │ ├─┬ npmlog@4.1.2
                │ │ │ │ ├─┬ are-we-there-yet@1.1.5
                │ │ │ │ │ ├── delegates@1.0.0 deduped
                │ │ │ │ │ └── readable-stream@2.3.7 deduped
                │ │ │ │ ├─┬ gauge@2.7.4
                │ │ │ │ │ ├── aproba@1.2.0 deduped
                │ │ │ │ │ ├── has-unicode@2.0.1 deduped
                │ │ │ │ │ ├── object-assign@4.1.0 deduped
                │ │ │ │ │ ├── string-width@1.0.2 deduped
                │ │ │ │ │ ├── strip-ansi@3.0.1 deduped
                │ │ │ │ │ └── wide-align@1.1.3 deduped
                │ │ │ ├─┬ rc@1.2.8
                │ │ │ │ ├── deep-extend@0.6.0
                │ │ │ │ ├── ini@1.3.5 deduped
                │ │ │ │ ├── minimist@1.2.5 deduped
                │ │ │ │ └── strip-json-comments@2.0.1
                │ │ │ ├── simple-get@3.1.0 deduped
                │ │ │ ├── tar-fs@2.1.1 deduped
                │ │ │ └── tunnel-agent@0.6.0 deduped
                │ └── uuid@8.3.2
                ├─┬ iobroker.javascript@5.2.21
                │ │   └── @types/node@10.17.60 deduped
                │ ├── @types/node@10.17.60
                │ ├─┬ @types/request@2.48.8
                │ │ ├── @types/caseless@0.12.2
                │ │ ├── @types/node@13.13.5
                │ │ ├── @types/tough-cookie@4.0.1
                │ │ └─┬ form-data@2.5.1
                │ ├── coffee-compiler@0.3.2
                │ ├── coffee-script@1.12.7
                │ ├── jsonata@1.8.6
                │ ├── node-inspect@2.0.0
                │ ├─┬ node-schedule@2.0.0
                │ │ ├── cron-parser@3.5.0 deduped
                │ │ ├── long-timeout@0.1.1 deduped
                │ │ └── sorted-array-functions@1.3.0 deduped
                │ ├── oauth@0.9.15
                │ ├─┬ owlintuition@0.4.0
                │ │ └─┬ xml2json@0.12.0
                │ │   ├── hoek@4.2.1
                │ │   ├─┬ joi@13.7.0
                │ │   │ ├── hoek@5.0.4
                │ │   │ ├─┬ isemail@3.2.0
                │ │   │ └─┬ topo@3.0.3
                │ │   │   └── hoek@6.1.3
                │ │   └─┬ node-expat@2.4.0
                │ │     ├── bindings@1.5.0 deduped
                │ │     └── nan@2.15.0 deduped
                │ ├─┬ semver@7.3.5
                │ ├── suncalc2@1.8.1
                │ ├── typescript@4.5.5
                │ ├─┬ virtual-tsc@0.6.2
                │ │ ├─┬ debug@4.3.3
                │ │ │ └── ms@2.1.2
                │ │ └── picocolors@1.0.0
                │ ├─┬ vm2@3.9.7
                │ │ ├── acorn@8.7.0 deduped
                │ │ └── acorn-walk@8.2.0
                │ ├─┬ wake_on_lan@1.0.0
                │ │ └── minimist@1.2.5 deduped
                ├─┬ iobroker.js-controller@3.3.22
                │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                │ │ ├── esbuild@0.11.23
                │ │ └── jsonc-parser@3.0.0
                │ ├─┬ @iobroker/db-objects-file@1.2.7
                │ │ ├─┬ @iobroker/db-base@1.2.4
                │ │ │ ├── deep-clone@3.0.3 deduped
                │ │ │ ├─┬ fs-extra@9.1.0
                │ │ │ │ ├── at-least-node@1.0.0 deduped
                │ │ │ │ ├── graceful-fs@4.2.4 deduped
                │ │ │ │ ├─┬ jsonfile@6.1.0
                │ │ │ │ │ ├── graceful-fs@4.2.4 deduped
                │ │ │ │ │ └── universalify@2.0.0 deduped
                │ │ │ ├── node.extend@2.0.2 deduped
                │ │ │ └── respjs@4.2.0
                │ │ ├── @iobroker/db-objects-redis@1.2.7 deduped
                │ │ └── node.extend@2.0.2 deduped
                │ ├─┬ @iobroker/db-objects-jsonl@1.2.7
                │ │ ├─┬ @alcalzone/jsonl-db@1.3.0
                │ │ │ ├─┬ alcalzone-shared@3.0.4
                │ │ │ │ └─┬ debug@4.3.3
                │ │ │ └─┬ proper-lockfile@4.1.2
                │ │ │   ├── retry@0.12.0
                │ │ │   └── signal-exit@3.0.3
                │ │ ├── @iobroker/db-base@1.2.4 deduped
                │ │ ├── @iobroker/db-objects-file@1.2.7 deduped
                │ ├─┬ @iobroker/db-objects-redis@1.2.7
                │ │ ├─┬ ioredis@4.28.5
                │ │ │ ├── cluster-key-slot@1.1.0
                │ │ │ ├── denque@1.5.1
                │ │ │ ├── lodash.defaults@4.2.0
                │ │ │ ├── lodash.flatten@4.4.0
                │ │ │ ├── lodash.isarguments@3.1.0
                │ │ │ ├── p-map@2.1.0
                │ │ │ ├── redis-commands@1.7.0
                │ │ │ ├── redis-errors@1.2.0
                │ │ │ ├─┬ redis-parser@3.0.0
                │ │ │ │ └── redis-errors@1.2.0 deduped
                │ │ │ └── standard-as-callback@2.1.0
                │ ├─┬ @iobroker/db-states-file@1.2.7
                │ │ └── @iobroker/db-states-redis@1.2.7 deduped
                │ ├─┬ @iobroker/db-states-jsonl@1.2.7
                │ │ ├── @alcalzone/jsonl-db@1.3.0 deduped
                │ │ ├── @iobroker/db-states-file@1.2.7 deduped
                │ ├─┬ @iobroker/db-states-redis@1.2.7
                │ │ └── ioredis@4.28.5 deduped
                │ ├── @iobroker/plugin-base@1.2.1
                │ ├─┬ @iobroker/plugin-sentry@1.1.10
                │ │ ├── @iobroker/plugin-base@1.2.1 deduped
                │ │ ├── @sentry/integrations@6.16.1 deduped
                │ │ ├── @sentry/node@6.16.1 deduped
                │ │ └── source-map-support@0.5.21 deduped
                │ ├─┬ chokidar@3.5.3
                │ │ ├─┬ anymatch@3.1.2
                │ │ │ ├── normalize-path@3.0.0 deduped
                │ │ │ └── picomatch@2.3.1
                │ │ ├─┬ braces@3.0.2
                │ │ │ └─┬ fill-range@7.0.1
                │ │ │   └─┬ to-regex-range@5.0.1
                │ │ │     └── is-number@7.0.0
                │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@2.3.2
                │ │ ├─┬ glob-parent@5.1.2
                │ │ │ └── is-glob@4.0.1 deduped
                │ │ ├─┬ is-binary-path@2.1.0
                │ │ │ └── binary-extensions@2.2.0
                │ │ ├─┬ is-glob@4.0.1
                │ │ │ └── is-extglob@2.1.1
                │ │ └─┬ readdirp@3.6.0
                │ │   └── picomatch@2.3.1 deduped
                │ ├── ci-info@3.3.0
                │ ├── daemonize2@0.4.2
                │ ├─┬ debug@4.3.3
                │ │ └── ms@2.1.2
                │ ├─┬ decache@4.6.1
                │ │ └── callsite@1.0.0
                │ ├─┬ diskusage@1.1.3
                │ │ ├── es6-promise@4.2.8
                │ ├─┬ event-stream@4.0.1
                │ │ ├── duplexer@0.1.1
                │ │ ├── from@0.1.7
                │ │ ├── map-stream@0.0.7
                │ │ ├─┬ pause-stream@0.0.11
                │ │ │ └── through@2.3.8 deduped
                │ │ ├─┬ split@1.0.1
                │ │ ├─┬ stream-combiner@0.2.2
                │ │ │ ├── duplexer@0.1.1 deduped
                │ ├─┬ greenlock@4.0.4
                │ │ ├─┬ @greenlock/manager@3.1.0
                │ │ │ └─┬ greenlock-manager-fs@3.1.1
                │ │ │   ├── @root/mkdirp@1.0.0 deduped
                │ │ │   └── safe-replace@1.1.0 deduped
                │ │ ├─┬ @root/acme@3.1.0
                │ │ │ ├── @root/csr@0.8.1 deduped
                │ │ │ ├── @root/encoding@1.0.1
                │ │ │ ├─┬ @root/keypairs@0.10.3
                │ │ │ │ ├── @root/encoding@1.0.1 deduped
                │ │ │ │ ├── @root/pem@1.0.4 deduped
                │ │ │ │ └── @root/x509@0.7.2 deduped
                │ │ │ ├── @root/request@1.8.1 deduped
                │ │ │ └─┬ @root/x509@0.7.2
                │ │ │   ├── @root/asn1@1.0.0 deduped
                │ │ │   └── @root/encoding@1.0.1 deduped
                │ │ ├─┬ @root/csr@0.8.1
                │ │ │ ├─┬ @root/asn1@1.0.0
                │ │ │ │ └── @root/encoding@1.0.1 deduped
                │ │ ├─┬ @root/greenlock@4.0.5
                │ │ │ ├── @greenlock/manager@3.1.0 deduped
                │ │ │ ├── @root/acme@3.1.0 deduped
                │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
                │ │ │ ├── cert-info@1.5.1 deduped
                │ │ │ ├── greenlock-store-fs@3.2.2 deduped
                │ │ ├─┬ @root/keypairs@0.9.0
                │ │ ├─┬ greenlock-store-fs@3.2.2
                │ ├─┬ greenlock-express@4.0.3
                │ │ ├── @root/greenlock@4.0.5 deduped
                │ │ ├─┬ @root/greenlock-express@4.0.4
                │ │ │ ├── @root/greenlock@4.0.5 deduped
                │ │ │ └── redirect-https@1.3.1 deduped
                │ │ └─┬ redirect-https@1.3.1
                │ │   └── escape-html@1.0.3 deduped
                │ ├─┬ jsonwebtoken@8.5.1
                │ │ ├─┬ jws@3.2.2
                │ │ │ ├─┬ jwa@1.4.1
                │ │ │ │ ├── buffer-equal-constant-time@1.0.1 deduped
                │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
                │ │ │ │ └── safe-buffer@5.1.2 deduped
                │ │ ├── lodash.includes@4.3.0
                │ │ ├── lodash.isboolean@3.0.3
                │ │ ├── lodash.isinteger@4.0.4
                │ │ ├── lodash.isnumber@3.0.3
                │ │ ├── lodash.isplainobject@4.0.6
                │ │ ├── lodash.isstring@4.0.1
                │ │ ├── lodash.once@4.1.1
                │ │ ├── ms@2.1.2
                │ ├─┬ jszip@3.7.1
                │ │ ├─┬ lie@3.3.0
                │ │ │ └── immediate@3.0.6
                │ │ ├── pako@1.0.11
                │ │ ├─┬ readable-stream@2.3.7
                │ │ │ ├── core-util-is@1.0.2 deduped
                │ │ │ ├── isarray@1.0.0
                │ │ │ ├── process-nextick-args@2.0.1
                │ │ │ ├── safe-buffer@5.1.2 deduped
                │ │ │ ├─┬ string_decoder@1.1.1
                │ │ └── set-immediate-shim@1.0.1
                │ ├─┬ le-acme-core@2.1.4
                │ │ └─┬ rsa-compat@1.9.4
                │ │   ├─┬ keypairs@1.2.14
                │ │   │ ├── eckles@1.4.1
                │ │   │ └── rasha@1.2.5
                │ │   ├── node-forge@0.7.6
                │ │   └─┬ ursa-optional@0.9.10
                │ ├─┬ le-challenge-fs@2.0.9
                │ │ └── @root/mkdirp@1.0.0 deduped
                │ ├── le-sni-auto@2.1.9
                │ ├─┬ loadavg-windows@1.1.1
                │ │ └── weak-daemon@1.0.3
                │ ├── mime@2.6.0
                │ ├── ncp@2.0.0
                │ ├── node-forge@0.10.0
                │ ├── node-schedule@2.1.0 deduped
                │ ├─┬ node.extend@2.0.2
                │ │ ├─┬ has@1.0.3
                │ │ │ └── function-bind@1.1.1
                │ │ └── is@3.3.0
                │ ├─┬ pidusage@2.0.21
                │ │ └── safe-buffer@5.2.1
                │ ├── promisify-child-process@4.1.1
                │ ├─┬ prompt@1.2.1
                │ │ ├── async@0.9.2
                │ │ ├── colors@1.4.0 deduped
                │ │ ├─┬ read@1.0.7
                │ │ │ └── mute-stream@0.0.8
                │ │ ├── revalidator@0.1.8
                │ │ └─┬ winston@2.4.5
                │ │   ├── async@1.0.0
                │ │   ├── colors@1.0.3
                │ │   ├── cycle@1.0.3
                │ │   ├── eyes@0.1.8
                │ │   ├── isstream@0.1.2 deduped
                │ │   └── stack-trace@0.0.10 deduped
                │ ├── readline-sync@1.4.10
                │ ├─┬ semver@7.3.5
                │ ├─┬ tar@6.1.11
                │ │ ├── chownr@2.0.0
                │ │ ├─┬ fs-minipass@2.1.0
                │ │ │ └── minipass@3.1.1 deduped
                │ │ ├─┬ minipass@3.1.1
                │ │ ├─┬ minizlib@2.1.2
                │ │ │ ├── minipass@3.1.1 deduped
                │ │ ├── mkdirp@1.0.4
                │ ├─┬ winston@3.6.0
                │ │ ├─┬ @dabh/diagnostics@2.0.3
                │ │ │ ├─┬ colorspace@1.1.4
                │ │ │ │ ├── color@3.2.1 deduped
                │ │ │ │ └── text-hex@1.0.0
                │ │ │ ├── enabled@2.0.0
                │ │ │ └── kuler@2.0.0
                │ │ ├── async@3.2.3
                │ │ ├── is-stream@2.0.1 deduped
                │ │ ├─┬ logform@2.4.0
                │ │ │ ├── @colors/colors@1.5.0
                │ │ │ ├── fecha@4.2.1
                │ │ │ ├── ms@2.1.3
                │ │ │ ├── safe-stable-stringify@2.3.1 deduped
                │ │ │ └── triple-beam@1.3.0 deduped
                │ │ ├─┬ one-time@1.0.0
                │ │ │ └── fn.name@1.1.0
                │ │ ├── stack-trace@0.0.10
                │ │ ├── triple-beam@1.3.0
                │ │ └─┬ winston-transport@4.5.0
                │ │   ├── logform@2.4.0 deduped
                │ ├─┬ winston-daily-rotate-file@4.6.1
                │ │ ├─┬ file-stream-rotator@0.6.1
                │ │ │ └── moment@2.29.1 deduped
                │ │ ├── object-hash@2.2.0
                │ │ ├── triple-beam@1.3.0 deduped
                │ │ └── winston-transport@4.5.0 deduped
                │ ├─┬ winston-seq-updated@1.0.4
                │ │ ├── seq-logging@0.4.6
                │ ├─┬ winston-syslog@2.4.4
                │ │ ├── glossy@0.1.7
                │ │ └─┬ unix-dgram@2.0.3
                │ └─┬ yargs@16.2.0
                │   ├─┬ cliui@7.0.4
                │   │ ├── string-width@4.2.3 deduped
                │   │ ├─┬ strip-ansi@6.0.1
                │   │ │ └── ansi-regex@5.0.1
                │   │ └─┬ wrap-ansi@7.0.0
                │   │   ├─┬ ansi-styles@4.3.0
                │   │   │ └─┬ color-convert@2.0.1
                │   │   │   └── color-name@1.1.4
                │   │   └── strip-ansi@6.0.1 deduped
                │   ├── escalade@3.1.1
                │   ├── get-caller-file@2.0.5
                │   ├── require-directory@2.1.1 deduped
                │   ├─┬ string-width@4.2.3
                │   │ ├── is-fullwidth-code-point@3.0.0
                │   ├── y18n@5.0.8
                │   └── yargs-parser@20.2.9
                ├─┬ iobroker.lightify@0.2.16
                │ ├── mdns-discovery@0.2.6 deduped
                │ ├── moment@2.29.1 deduped
                │ ├─┬ promise@8.0.1
                │ │ └── asap@2.0.6
                │ └─┬ soef@0.4.15
                │   ├── array-ext@0.1.5
                │   └── sprintf-js@1.1.2
                ├─┬ iobroker.mihome@1.3.7
                ├── iobroker.mihome-vacuum@1.1.5
                ├─┬ iobroker.mobile@1.0.1
                ├─┬ iobroker.mqtt@2.4.1
                │ ├─┬ mqtt@2.18.9
                │ │ ├─┬ commist@1.1.0
                │ │ │ ├── leven@2.1.0
                │ │ │ └── minimist@1.2.5 deduped
                │ │ ├─┬ concat-stream@1.6.2
                │ │ │ ├── readable-stream@2.3.7 deduped
                │ │ ├─┬ end-of-stream@1.4.4
                │ │ │ └── once@1.4.0 deduped
                │ │ ├─┬ es6-map@0.1.5
                │ │ │ ├─┬ d@1.0.1
                │ │ │ │ ├── es5-ext@0.10.53 deduped
                │ │ │ │ └── type@1.2.0
                │ │ │ ├─┬ es5-ext@0.10.53
                │ │ │ │ ├── es6-iterator@2.0.3 deduped
                │ │ │ │ ├── es6-symbol@3.1.3 deduped
                │ │ │ │ └── next-tick@1.0.0
                │ │ │ ├─┬ es6-iterator@2.0.3
                │ │ │ │ ├── d@1.0.1 deduped
                │ │ │ │ └── es6-symbol@3.1.3 deduped
                │ │ │ ├─┬ es6-set@0.1.5
                │ │ │ │ ├─┬ es6-symbol@3.1.1
                │ │ │ │ │ ├── d@1.0.1 deduped
                │ │ │ │ │ └── es5-ext@0.10.53 deduped
                │ │ │ │ └── event-emitter@0.3.5 deduped
                │ │ │ ├─┬ es6-symbol@3.1.3
                │ │ │ │ └─┬ ext@1.4.0
                │ │ │ │   └── type@2.0.0
                │ │ │ └─┬ event-emitter@0.3.5
                │ │ ├─┬ help-me@1.1.0
                │ │ │ ├─┬ callback-stream@1.1.0
                │ │ │ ├─┬ glob-stream@6.1.0
                │ │ │ │ ├── extend@3.0.2 deduped
                │ │ │ │ ├─┬ glob-parent@3.1.0
                │ │ │ │ │ ├─┬ is-glob@3.1.0
                │ │ │ │ │ │ └── is-extglob@2.1.1 deduped
                │ │ │ │ │ └── path-dirname@1.0.2
                │ │ │ │ ├── is-negated-glob@1.0.0
                │ │ │ │ ├─┬ ordered-read-streams@1.0.1
                │ │ │ │ ├─┬ pumpify@1.5.1
                │ │ │ │ │ ├── duplexify@3.7.1 deduped
                │ │ │ │ │ └─┬ pump@2.0.1
                │ │ │ │ │   ├── end-of-stream@1.4.4 deduped
                │ │ │ │ │   └── once@1.4.0 deduped
                │ │ │ │ ├── readable-stream@2.3.7 deduped
                │ │ │ │ ├── remove-trailing-separator@1.1.0
                │ │ │ │ ├─┬ to-absolute-glob@2.0.2
                │ │ │ │ │ ├─┬ is-absolute@1.0.0
                │ │ │ │ │ │ ├─┬ is-relative@1.0.0
                │ │ │ │ │ │ │ └─┬ is-unc-path@1.0.0
                │ │ │ │ │ │ │   └── unc-path-regex@0.1.2
                │ │ │ │ │ │ └── is-windows@1.0.2
                │ │ │ │ │ └── is-negated-glob@1.0.0 deduped
                │ │ │ │ └─┬ unique-stream@2.3.1
                │ │ │ │   ├── json-stable-stringify-without-jsonify@1.0.1
                │ │ │ │   └─┬ through2-filter@3.0.0
                │ │ │ │     ├── through2@2.0.5 deduped
                │ │ │ │     └── xtend@4.0.2 deduped
                │ │ ├─┬ mqtt-packet@5.6.1
                │ │ │ ├─┬ bl@1.2.2
                │ │ │ ├── process-nextick-args@2.0.1 deduped
                │ │ ├─┬ split2@2.2.0
                │ │ │ └── through2@2.0.5 deduped
                │ │ ├─┬ websocket-stream@5.2.0
                  │ ├─┬ bent@7.3.12
                  │ └── ws@7.5.6
                  │ │ ├─┬ debug@2.2.0
                  │ │ │ └── ms@0.7.1
                  │ │ ├── dgram@1.0.1
                  │ ├── netmask@2.0.2
                  │ │ ├─┬ async@2.6.3
                  │ │ ├─┬ debug@3.2.7
                  │ │ │ └── ms@2.1.3
                  │   │ │   └── ms@2.1.2
                  │   │ └─┬ debug@4.3.3
                  │   │   └── ms@2.1.2
                  │   │ └─┬ debug@4.3.3
                  │   │   └── ms@2.1.2
                  │   └─┬ debug@4.3.3
                  │     └── ms@2.1.2
                  │ └─┬ axios@0.21.4
                  │ └─┬ xml2js@0.4.23
                  │   ├── sax@1.2.4
                  │ │ └─┬ debug@4.1.1
                  │ │   └── ms@2.1.2
                  │ │ └─┬ ws@6.2.1
                  │ └─┬ cron@1.8.2
                  │ ├─┬ binrpc@3.3.1
                  │ │ └── put@0.0.6
                  │   ├── sax@0.4.3
                  │ │ └── uuid@8.3.2
                  │ └─┬ rrule@2.6.8
                  │   ├── luxon@1.27.0
                  │ ├─┬ semver@7.3.5
                  │ │ ├─┬ mqtt@4.2.8
                  │ │ │ ├── ws@7.5.7
                  │ ├─┬ echarts@4.9.0
                  │ ├─┬ jsdom@17.0.0
                  │ │ ├── abab@2.0.5
                  │ │ ├── acorn@8.7.0
                  │ │ ├── cssom@0.5.0
                  │ │ │   └── ms@2.1.2
                  │ │ ├─┬ saxes@5.0.1
                  │ │ ├── ws@8.5.0
                  │ ├── moment@2.29.1
                  │ │ ├─┬ color@3.2.1
                  │ │ │ ├─┬ rc@1.2.8
                  │ └── uuid@8.3.2
                  │ ├── jsonata@1.8.6
                  │ ├── oauth@0.9.15
                  │ │   ├── hoek@4.2.1
                  │ │   ├─┬ joi@13.7.0
                  │ ├─┬ semver@7.3.5
                  │ │ ├─┬ debug@4.3.3
                  │ │ │ └── ms@2.1.2
                  │ ├─┬ vm2@3.9.7
                  │ ├── ci-info@3.3.0
                  │ ├─┬ debug@4.3.3
                  │ │ └── ms@2.1.2
                  │ ├─┬ decache@4.6.1
                  │ │ ├── from@0.1.7
                  │ │ ├─┬ split@1.0.1
                  │ │ ├─┬ jws@3.2.2
                  │ │ │ ├─┬ jwa@1.4.1
                  │ │ ├── ms@2.1.2
                  │ ├─┬ jszip@3.7.1
                  │ │ ├─┬ lie@3.3.0
                  │ │ ├── pako@1.0.11
                  │ ├── mime@2.6.0
                  │ ├── ncp@2.0.0
                  │ │ ├─┬ has@1.0.3
                  │ │ └── is@3.3.0
                  │ ├─┬ prompt@1.2.1
                  │ │ ├── async@0.9.2
                  │ │ ├─┬ read@1.0.7
                  │ │   ├── async@1.0.0
                  │ │   ├── cycle@1.0.3
                  │ │   ├── eyes@0.1.8
                  │ ├─┬ semver@7.3.5
                  │ ├─┬ tar@6.1.11
                  │ ├─┬ winston@3.6.0
                  │ │ ├── async@3.2.3
                  │ │ │ ├── ms@2.1.3
                  │ └─┬ yargs@16.2.0
                  │   ├─┬ cliui@7.0.4
                  │   ├── y18n@5.0.8
                  │ ├─┬ promise@8.0.1
                  │ │ └── asap@2.0.6
                  │ └─┬ soef@0.4.15
                  │ ├─┬ mqtt@2.18.9
                  │ │ │ ├─┬ d@1.0.1
                  │ │ │ ├─┬ bl@1.2.2
                  M
                  M
                  Markus Faltermeier
                  @markus-faltermeier
                  und der 2. Teil
                  │ │ │ ├─┬ ws@6.2.2
                  │ │ │ │ └── async-limiter@1.0.1 deduped
                  │ ├─┬ mqtt-connection@4.1.0
                  │ │ ├─┬ duplexify@3.7.1
                  │ │ └─┬ through2@2.0.5
                  │ ├─┬ websocket-stream@5.5.2
                  │ │ ├─┬ ws@3.3.3
                  │ │ │ ├── async-limiter@1.0.1 deduped
                  │ │ │ └── ultron@1.1.1
                  │ └── ws@8.5.0
                  ├─┬ iobroker.mqtt-client@1.5.0
                  │ ├─┬ @iobroker/adapter-core@2.6.0
                  │ │ └─┬ @types/iobroker@4.0.1
                  │ └── mqtt@2.18.9 deduped
                  ├─┬ iobroker.nut@1.5.0
                  │ └── node-nut@1.0.3
                  ├─┬ iobroker.octoprint@2.1.0
                  │ └─┬ axios@0.24.0
                  ├─┬ iobroker.ping@1.5.0
                  ├─┬ iobroker.pushover@2.0.5
                  │ └── pushover-notifications@1.2.2
                  ├─┬ iobroker.rpi2@1.3.1
                  │ ├─┬ node-dht-sensor@0.4.3
                  │ │ └── node-addon-api@1.7.2
                  │ ├─┬ rpi-gpio@2.1.7
                  │ │ ├─┬ async-retry@1.3.3
                  │ │ │ └── retry@0.13.1
                  │ │ ├─┬ debug@3.2.7
                  │ │ │ └── ms@2.1.3
                  │ │ └─┬ epoll@2.0.10
                  │ ├─┬ rpi-gpio-buttons@2.0.1
                  │ │ ├── button-events@1.0.2
                  │ │ └── rpi-gpio@2.1.7 deduped
                  │ └── sync-exec@0.6.2
                  ├─┬ iobroker.scenes@2.3.8
                  │ └── node-schedule@2.1.0 deduped
                  ├─┬ iobroker.shelly@4.0.7
                  │ ├── @apollon/iobroker-tools@0.2.0
                  │ ├─┬ coiot-coap@1.0.0
                  │ │ ├─┬ coap@0.24.0
                  │ │ │ ├── capitalize@2.0.4
                  │ │ │ ├── coap-packet@0.1.14
                  │ │ │ ├── fastseries@2.0.0
                  │ │ │ ├─┬ lru-cache@5.1.1
                  │ │ │ │ └── yallist@3.1.1
                  │ │ │ └─┬ readable-stream@3.6.0
                  │ │ └── commander@6.2.1
                  │ ├─┬ mqtt@4.3.5
                  │ │ ├─┬ debug@4.3.3
                  │ │ │ └── ms@2.1.2
                  │ │ │ ├─┬ glob@7.1.6
                  │ │ │ │ ├── fs.realpath@1.0.0
                  │ │ │ │ ├─┬ inflight@1.0.6
                  │ │ │ │ │ ├── once@1.4.0 deduped
                  │ │ │ │ │ └── wrappy@1.0.2 deduped
                  │ │ │ │ ├── minimatch@3.0.4 deduped
                  │ │ │ │ └── path-is-absolute@1.0.1
                  │ │ ├─┬ lru-cache@6.0.0
                  │ │ ├─┬ number-allocator@1.0.9
                  │ │ │ └── js-sdsl@2.1.4
                  │ │ ├── rfdc@1.3.0
                  │ │ ├── ws@7.5.7
                  │ ├── mqtt-connection@4.1.0 deduped
                  │ ├─┬ ping@0.4.1
                  │ │ ├── q@1.5.1
                  │ │ └── underscore@1.13.2
                  │ ├─┬ shelly-iot@1.1.2
                  │ │ ├─┬ coap@0.26.0
                  │ │ │ ├─┬ @types/bl@5.0.2
                  │ │ │ │ ├── @types/node@13.13.5 deduped
                  │ │ │ │ └─┬ @types/readable-stream@2.3.13
                  │ │ │ ├── @types/node@16.11.25
                  │ │ │ ├─┬ bl@5.0.0
                  │ │ │ │ ├─┬ buffer@6.0.3
                  │ │ │ │ │ ├── base64-js@1.3.1 deduped
                  │ │ │ │ │ └── ieee754@1.2.1
                  │ │ │ ├── capitalize@2.0.4 deduped
                  │ │ │ ├── coap-packet@1.1.1
                  │ │ │ ├── fastseries@2.0.0 deduped
                  │ │ │ ├─┬ lru-cache@6.0.0
                  │ │ └─┬ node-rest-client@3.1.1
                  │ │   ├─┬ debug@4.3.3
                  │ │   │ └── ms@2.1.2
                  │ │   ├── follow-redirects@1.14.8 deduped
                  │ │   └── xml2js@0.4.23 deduped
                  │ ├── tcp-ping@0.1.1
                  │ ├── xml2js@0.4.23 deduped
                  │ └── xmlbuilder@15.1.1
                  ├─┬ iobroker.simple-api@2.6.2
                  ├─┬ iobroker.snmp@0.5.0
                  │ └─┬ net-snmp@1.2.5
                  │   └── asn1-ber@1.0.9
                  ├─┬ iobroker.socketio@3.1.5
                  │ ├─┬ axios@0.23.0
                  │ │ └── follow-redirects@1.14.8 deduped
                  │ ├── cookie-parser@1.4.6 deduped
                  │ ├── express-session@1.17.2 deduped
                  │ └─┬ socket.io@2.4.1
                  │   ├─┬ debug@4.1.1
                  │   │ └── ms@2.1.3
                  │   ├─┬ engine.io@3.5.0
                  │   │ ├── accepts@1.3.8 deduped
                  │   │ ├── base64id@2.0.0
                  │   │ ├─┬ debug@4.1.1
                  │   │ │ └── ms@2.1.3 deduped
                  │   │ ├─┬ engine.io-parser@2.2.1
                  │   │ │ ├── after@0.8.2 deduped
                  │   │ │ ├── arraybuffer.slice@0.0.7
                  │   │ │ ├── base64-arraybuffer@0.1.4
                  │   │ │ ├── blob@0.0.5
                  │   │ │ └── has-binary2@1.0.3 deduped
                  │   │ └── ws@7.4.6
                  │   ├─┬ has-binary2@1.0.3
                  │   │ └── isarray@2.0.1
                  │   ├── socket.io-adapter@1.1.2
                  │   ├─┬ socket.io-client@2.4.0
                  │   │ ├── backo2@1.0.2 deduped
                  │   │ ├── component-bind@1.0.0 deduped
                  │   │ ├── component-emitter@1.3.0
                  │   │ ├─┬ debug@3.1.0
                  │   │ │ └── ms@2.0.0
                  │   │ ├─┬ engine.io-client@3.5.2
                  │   │ │ ├── component-emitter@1.3.0 deduped
                  │   │ │ ├── component-inherit@0.0.3 deduped
                  │   │ │ ├─┬ debug@3.1.0
                  │   │ │ │ └── ms@2.0.0
                  │   │ │ ├── engine.io-parser@2.2.1 deduped
                  │   │ │ ├── has-cors@1.1.0 deduped
                  │   │ │ ├── indexof@0.0.1 deduped
                  │   │ │ ├── parseqs@0.0.6 deduped
                  │   │ │ ├── parseuri@0.0.6 deduped
                  │   │ │ ├── ws@7.4.6 deduped
                  │   │ │ ├── xmlhttprequest-ssl@1.6.3
                  │   │ │ └── yeast@0.1.2 deduped
                  │   │ ├── has-binary2@1.0.3 deduped
                  │   │ ├─┬ socket.io-parser@3.3.2
                  │   │ │ ├── debug@3.1.0 deduped
                  │   │ │ └── isarray@2.0.1 deduped
                  │   │ └── to-array@0.1.4 deduped
                  │   └─┬ socket.io-parser@3.4.1
                  │     ├── component-emitter@1.2.1
                  │     ├─┬ debug@4.1.1
                  │     └── isarray@2.0.1
                  ├─┬ iobroker.sonoff@2.4.7
                  │ └── mqtt-connection@4.1.0 deduped
                  ├─┬ iobroker.spotify-premium@1.0.0
                  │ ├─┬ @iobroker/adapter-core@1.0.1
                  │ │ └── @types/iobroker@1.4.13 deduped
                  │ ├── promise@8.0.1 deduped
                  │ ├── querystring@0.2.0
                  │ └─┬ request@2.83.0
                  │   ├── aws-sign2@0.7.0 deduped
                  │   ├── aws4@1.9.1 deduped
                  │   ├── forever-agent@0.6.1 deduped
                  │   ├── form-data@2.3.3 deduped
                  │   ├─┬ har-validator@5.0.3
                  │   │ ├─┬ ajv@5.5.2
                  │   │ │ ├── co@4.6.0
                  │   │ │ ├── fast-deep-equal@1.1.0
                  │   │ │ ├── fast-json-stable-stringify@2.1.0 deduped
                  │   │ │ └── json-schema-traverse@0.3.1
                  │   │ └── har-schema@2.0.0 deduped
                  │   ├─┬ hawk@6.0.2
                  │   │ ├─┬ boom@4.3.1
                  │   │ │ └── hoek@4.2.1 deduped
                  │   │ ├─┬ cryptiles@3.1.4
                  │   │ │ └─┬ boom@5.2.0
                  │   │ ├── hoek@4.2.1 deduped
                  │   │ └─┬ sntp@2.1.0
                  │   ├── http-signature@1.2.0 deduped
                  │   ├── is-typedarray@1.0.0 deduped
                  │   ├── json-stringify-safe@5.0.1 deduped
                  │   ├── mime-types@2.1.34 deduped
                  │   ├── oauth-sign@0.8.2
                  │   ├── performance-now@2.1.0 deduped
                  │   ├── qs@6.5.2
                  │   ├── stringstream@0.0.6
                  │   ├─┬ tough-cookie@2.3.4
                  │   │ └── punycode@1.4.1
                  │   ├── tunnel-agent@0.6.0 deduped
                  │   └── uuid@3.4.0 deduped
                  ├─┬ iobroker.statistics@1.0.9
                  │ └── cron@1.8.2 deduped
                  ├─┬ iobroker.synology@1.1.3
                  │ ├─┬ @iobroker/adapter-core@2.4.0
                  │ │ └─┬ @types/iobroker@3.2.4
                  │ └─┬ syno@3.0.0
                  │   ├── commander@4.1.1
                  │   ├─┬ js-yaml@3.14.1
                  │   │ ├─┬ argparse@1.0.10
                  │   │ │ └── sprintf-js@1.0.3
                  │   │ └── esprima@4.0.1 deduped
                  │   ├── lodash@4.17.21 deduped
                  │   ├── minimist@0.2.1
                  │   ├─┬ nconf@0.10.0
                  │   │ ├── async@1.5.2
                  │   │ ├── ini@1.3.5
                  │   │ ├── secure-keys@1.0.0
                  │   │ └─┬ yargs@3.32.0
                  │   │   ├── camelcase@2.1.1
                  │   │   ├── cliui@3.2.0 deduped
                  │   │   ├── decamelize@1.2.0 deduped
                  │   │   ├── os-locale@1.4.0 deduped
                  │   │   ├── window-size@0.1.4
                  │   │   └── y18n@3.2.1 deduped
                  │   ├── ospath@1.2.2
                  │   ├─┬ otplib@11.0.1
                  │   │ └── thirty-two@1.0.2
                  │   ├── pluralize@8.0.0
                  ├─┬ iobroker.tankerkoenig@2.1.1
                  ├─┬ iobroker.telegram@1.11.1
                  │ ├─┬ axios@0.25.0
                  │ ├─┬ node-telegram-bot-api@0.56.0
                  │ │ ├─┬ array.prototype.findindex@2.1.0
                  │ │ │ ├─┬ define-properties@1.1.3
                  │ │ │ │ └── object-keys@1.1.1
                  │ │ │ └─┬ es-abstract@1.19.1
                  │ │ │   ├── call-bind@1.0.2 deduped
                  │ │ │   ├─┬ es-to-primitive@1.2.1
                  │ │ │   │ ├── is-callable@1.2.4 deduped
                  │ │ │   │ ├─┬ is-date-object@1.0.5
                  │ │ │   │ │ └── has-tostringtag@1.0.0 deduped
                  │ │ │   │ └─┬ is-symbol@1.0.4
                  │ │ │   │   └── has-symbols@1.0.2 deduped
                  │ │ │   ├── function-bind@1.1.1 deduped
                  │ │ │   ├─┬ get-intrinsic@1.1.1
                  │ │ │   │ ├── function-bind@1.1.1 deduped
                  │ │ │   │ ├── has@1.0.3 deduped
                  │ │ │   ├─┬ get-symbol-description@1.0.0
                  │ │ │   │ ├── call-bind@1.0.2 deduped
                  │ │ │   │ └── get-intrinsic@1.1.1 deduped
                  │ │ │   ├── has-symbols@1.0.2
                  │ │ │   ├─┬ internal-slot@1.0.3
                  │ │ │   │ ├── get-intrinsic@1.1.1 deduped
                  │ │ │   │ └─┬ side-channel@1.0.4
                  │ │ │   │   └── object-inspect@1.12.0 deduped
                  │ │ │   ├── is-negative-zero@2.0.2
                  │ │ │   ├─┬ is-regex@1.1.4
                  │ │ │   │ └─┬ has-tostringtag@1.0.0
                  │ │ │   ├── is-shared-array-buffer@1.0.1
                  │ │ │   ├─┬ is-string@1.0.7
                  │ │ │   ├─┬ is-weakref@1.0.2
                  │ │ │   │ └── call-bind@1.0.2 deduped
                  │ │ │   ├── object-inspect@1.12.0
                  │ │ │   ├── object-keys@1.1.1 deduped
                  │ │ │   ├─┬ object.assign@4.1.2
                  │ │ │   │ ├── define-properties@1.1.3 deduped
                  │ │ │   │ ├── has-symbols@1.0.2 deduped
                  │ │ │   │ └── object-keys@1.1.1 deduped
                  │ │ │   ├─┬ string.prototype.trimend@1.0.4
                  │ │ │   │ └── define-properties@1.1.3 deduped
                  │ │ │   ├─┬ string.prototype.trimstart@1.0.4
                  │ │ │   └─┬ unbox-primitive@1.0.1
                  │ │ │     ├── has-bigints@1.0.1
                  │ │ │     └─┬ which-boxed-primitive@1.0.2
                  │ │ │       ├─┬ is-bigint@1.0.4
                  │ │ │       │ └── has-bigints@1.0.1 deduped
                  │ │ │       ├─┬ is-boolean-object@1.1.2
                  │ │ │       ├─┬ is-number-object@1.0.6
                  │ │ │       ├── is-string@1.0.7 deduped
                  │ │ │       └── is-symbol@1.0.4 deduped
                  │ │ ├─┬ bl@1.2.3
                  │ │ ├── bluebird@3.7.2 deduped
                  │ │ ├─┬ debug@3.2.7
                  │ │ │ └── ms@2.1.3
                  │ │ ├── depd@1.1.2 deduped
                  │ │ ├── eventemitter3@3.1.2
                  │ │ ├── file-type@3.9.0
                  │ │ ├── mime@1.6.0
                  │ │ ├─┬ pump@2.0.1
                  │ │ └─┬ request-promise@4.2.6
                  │ │   ├─┬ request-promise-core@1.1.4
                  │ │   ├── stealthy-require@1.1.1 deduped
                  │ └─┬ socksv5@0.0.6
                  │   └─┬ ipv6@3.1.1
                  │     ├─┬ cli@0.4.5
                  │     ├─┬ cliff@0.1.10
                  │     │ ├── eyes@0.1.8 deduped
                  │     │ └─┬ winston@0.8.3
                  │     │   ├── async@0.2.10
                  │     │   ├── colors@0.6.2
                  │     │   ├── cycle@1.0.3 deduped
                  │     │   ├── pkginfo@0.3.1
                  │     └── sprintf@0.1.3
                  ├─┬ iobroker.terminal@0.1.2
                  │ ├─┬ UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
                  │ ├── body-parser@1.19.2 deduped
                  │ ├── commander@5.1.0
                  │ ├─┬ connect@3.7.0
                  │ │ ├── debug@2.6.9 deduped
                  │ │ ├── finalhandler@1.1.2 deduped
                  │ │ ├── parseurl@1.3.3 deduped
                  │ │ └── utils-merge@1.0.1 deduped
                  │ ├── connect-flash@0.1.1 deduped
                  │ ├── express@4.17.3 deduped
                  │ ├── nan@2.15.0
                  │ ├─┬ passport@0.2.2
                  │ │ ├── passport-strategy@1.0.0 deduped
                  │ │ └── pause@0.0.1 deduped
                  │ ├── passport-local@1.0.0 deduped
                  │ ├─┬ send@0.17.2
                  │ │ ├── destroy@1.0.4
                  │ │ ├── encodeurl@1.0.2 deduped
                  │ │ ├── escape-html@1.0.3 deduped
                  │ │ ├── etag@1.8.1 deduped
                  │ │ ├── fresh@0.5.2 deduped
                  │ │ ├── http-errors@1.8.1 deduped
                  │ │ ├── mime@1.6.0 deduped
                  │ │ ├── ms@2.1.3
                  │ │ ├── on-finished@2.3.0 deduped
                  │ │ ├── range-parser@1.2.1 deduped
                  │ │ └── statuses@1.5.0 deduped
                  │ ├── socket.io@1.7.2 deduped
                  │ ├── uid-number@0.0.6
                  │ └── xtend@4.0.2
                  ├─┬ iobroker.text2command@2.1.1
                  ├─┬ iobroker.tr-064@4.2.15
                  ├─┬ iobroker.upnp@1.0.19
                  │ ├── ip@1.1.5
                  │ ├── node-ssdp@4.0.1 deduped
                  │ ├─┬ parsexmlresponse@0.0.5
                  │ ├─┬ portfinder@1.0.28
                  │ │ ├── async@2.6.3 deduped
                  │ │ ├─┬ debug@3.2.7
                  │ │ │ └── ms@2.1.3
                  │ │ └─┬ mkdirp@0.5.5
                  │ └── xmldom@0.6.0
                  ├─┬ iobroker.vis@1.4.5
                  │ └── jsonwebtoken@8.5.1 deduped
                  ├── iobroker.vis-bars@0.1.4
                  ├─┬ iobroker.vis-colorpicker@1.2.0
                  ├── iobroker.vis-fancyswitch@1.1.0
                  ├─┬ iobroker.vis-google-fonts@1.0.3
                  ├── iobroker.vis-hqwidgets@1.1.9
                  ├── iobroker.vis-jqui-mfd@1.0.12
                  ├── iobroker.vis-metro@1.1.2
                  ├─┬ iobroker.vis-players@0.1.6
                  │ └── @iobroker/adapter-core@1.0.3 deduped
                  ├─┬ iobroker.vis-plumb@1.0.2
                  ├── iobroker.vis-timeandweather@1.1.7
                  ├── iobroker.vis-weather@2.5.5
                  ├─┬ iobroker.web@3.4.16
                  │ ├── iobroker.simple-api@2.6.2 deduped
                  │ ├── iobroker.socketio@3.1.5 deduped
                  │ ├─┬ mime-types@2.1.34
                  │ │ └── mime-db@1.51.0
                  │ ├── passport@0.5.2 deduped
                  │ ├── passport.socketio@3.7.0 deduped
                  │ │ ├─┬ debug@3.1.0
                  │ │ │ └── ms@2.0.0 deduped
                  │ │ │ ├─┬ engine.io-parser@2.2.1
                  │ │ │ │ ├── after@0.8.2 deduped
                  │ │ │ │ ├── arraybuffer.slice@0.0.7
                  │ │ │ │ ├── base64-arraybuffer@0.1.4
                  │ │ │ │ ├── blob@0.0.5
                  │ │ │ │ └── has-binary2@1.0.3 deduped
                  │ │ │ ├── ws@7.4.6
                  ├─┬ UNMET DEPENDENCY iobroker.zigbee@1.6.16
                  │ ├─┬ UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
                  │ │ └─┬ UNMET DEPENDENCY @types/iobroker@3.3.4
                  │ ├── tar@6.1.11 deduped
                  │ ├── UNMET DEPENDENCY typescript@4.5.4
                  │ ├─┬ zigbee-herdsman@0.14.16
                  │ │ ├── debounce@1.2.1
                  │ │ ├─┬ debug@4.3.3
                  │ │ │ └── ms@2.1.2
                  │ │ ├── fast-deep-equal@3.1.3
                  │ │ ├── mixin-deep@2.0.1
                  │ │ ├─┬ mz@2.7.0
                  │ │ │ ├── any-promise@1.3.0
                  │ │ │ ├── object-assign@4.1.1
                  │ │ │ └─┬ thenify-all@1.6.0
                  │ │ │   └─┬ thenify@3.3.1
                  │ │ │     └── any-promise@1.3.0 deduped
                  │ │ ├─┬ serialport@9.2.8
                  │ │ │ ├─┬ @serialport/binding-mock@9.2.4
                  │ │ │ │ ├─┬ @serialport/binding-abstract@9.2.3
                  │ │ │ │ │ └── debug@4.3.3 deduped
                  │ │ │ ├─┬ @serialport/bindings@9.2.8
                  │ │ │ │ ├── @serialport/binding-abstract@9.2.3 deduped
                  │ │ │ │ ├── @serialport/parser-readline@9.2.4 deduped
                  │ │ │ │ ├─┬ bindings@1.5.0
                  │ │ │ │ │ └── file-uri-to-path@1.0.0
                  │ │ │ │ ├── nan@2.15.0
                  │ │ │ │ └─┬ prebuild-install@7.0.1
                  │ │ │ │   ├── detect-libc@2.0.0
                  │ │ │ │   ├── expand-template@2.0.3
                  │ │ │ │   ├── github-from-package@0.0.0
                  │ │ │ │   ├── mkdirp-classic@0.5.3
                  │ │ │ │   ├── napi-build-utils@1.0.2
                  │ │ │ │   ├─┬ node-abi@3.8.0
                  │ │ │ │   │ └─┬ semver@7.3.5
                  │ │ │ │   │   └─┬ lru-cache@6.0.0
                  │ │ │ │   │     └── yallist@4.0.0
                  │ │ │ │   ├─┬ npmlog@4.1.2
                  │ │ │ │   │ ├─┬ are-we-there-yet@1.1.7
                  │ │ │ │   │ │ ├── delegates@1.0.0
                  │ │ │ │   │ │ └─┬ readable-stream@2.3.7
                  │ │ │ │   │ │   ├── core-util-is@1.0.3
                  │ │ │ │   │ │   ├── inherits@2.0.4 deduped
                  │ │ │ │   │ │   ├── isarray@1.0.0
                  │ │ │ │   │ │   ├── process-nextick-args@2.0.1
                  │ │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
                  │ │ │ │   │ │   ├─┬ string_decoder@1.1.1
                  │ │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                  │ │ │ │   │ │   └── util-deprecate@1.0.2
                  │ │ │ │   │ ├─┬ gauge@2.7.4
                  │ │ │ │   │ │ ├── aproba@1.2.0
                  │ │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
                  │ │ │ │   │ │ ├── has-unicode@2.0.1
                  │ │ │ │   │ │ ├── object-assign@4.1.1 deduped
                  │ │ │ │   │ │ ├── signal-exit@3.0.7
                  │ │ │ │   │ │ ├─┬ string-width@1.0.2
                  │ │ │ │   │ │ │ ├── code-point-at@1.1.0
                  │ │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                  │ │ │ │   │ │ │ │ └── number-is-nan@1.0.1
                  │ │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                  │ │ │ │   │ │ ├─┬ strip-ansi@3.0.1
                  │ │ │ │   │ │ │ └── ansi-regex@2.1.1
                  │ │ │ │   │ │ └─┬ wide-align@1.1.5
                  │ │ │ │   │ │   └── string-width@1.0.2 deduped
                  │ │ │ │   │ └── set-blocking@2.0.0
                  │ │ │ │   ├─┬ pump@3.0.0
                  │ │ │ │   │ ├─┬ end-of-stream@1.4.4
                  │ │ │ │   │ │ └── once@1.4.0 deduped
                  │ │ │ │   │ └─┬ once@1.4.0
                  │ │ │ │   ├─┬ rc@1.2.8
                  │ │ │ │   │ ├── deep-extend@0.6.0
                  │ │ │ │   │ ├── ini@1.3.8
                  │ │ │ │   │ ├── minimist@1.2.5 deduped
                  │ │ │ │   │ └── strip-json-comments@2.0.1
                  │ │ │ │   ├─┬ simple-get@4.0.1
                  │ │ │ │   │ ├─┬ decompress-response@6.0.0
                  │ │ │ │   │ │ └── mimic-response@3.1.0
                  │ │ │ │   │ └── simple-concat@1.0.1
                  │ │ │ │   ├─┬ tar-fs@2.1.1
                  │ │ │ │   │ ├── chownr@1.1.4
                  │ │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
                  │ │ │ │   │ ├── pump@3.0.0 deduped
                  │ │ │ │   │ └─┬ tar-stream@2.2.0
                  │ │ │ │   │   ├─┬ bl@4.1.0
                  │ │ │ │   │   │ ├─┬ buffer@5.7.1
                  │ │ │ │   │   │ │ ├── base64-js@1.5.1
                  │ │ │ │   │   │ │ └── ieee754@1.2.1
                  │ │ │ │   │   │ └─┬ readable-stream@3.6.0
                  │ │ │ │   │   │   ├── string_decoder@1.1.1 deduped
                  │ │ │ │   │   │   └── util-deprecate@1.0.2 deduped
                  │ │ │ │   │   ├── fs-constants@1.0.0
                  │ │ │ │   └─┬ tunnel-agent@0.6.0
                  │ │ │ ├── @serialport/parser-byte-length@9.2.4
                  │ │ │ ├── @serialport/parser-cctalk@9.2.4
                  │ │ │ ├── @serialport/parser-delimiter@9.2.4
                  │ │ │ ├── @serialport/parser-inter-byte-timeout@9.2.4
                  │ │ │ ├─┬ @serialport/parser-readline@9.2.4
                  │ │ │ │ └── @serialport/parser-delimiter@9.2.4 deduped
                  │ │ │ ├── @serialport/parser-ready@9.2.4
                  │ │ │ ├── @serialport/parser-regex@9.2.4
                  │ │ │ ├─┬ @serialport/stream@9.2.4
                  │ │ └── slip@1.0.2
                  │ └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.422
                  │   ├─┬ UNMET DEPENDENCY axios@0.25.0
                  │   │ └── UNMET DEPENDENCY follow-redirects@1.14.8
                  │   ├── UNMET DEPENDENCY buffer-crc32@0.2.13
                  │   ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
                  │   │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
                  │   │ │ └── UNMET DEPENDENCY debug@4.3.3
                  │   │ └─┬ UNMET DEPENDENCY debug@4.3.3
                  │   │   └── UNMET DEPENDENCY ms@2.1.2
                  │   ├─┬ UNMET DEPENDENCY tar-stream@2.2.0
                  │   │ ├─┬ UNMET DEPENDENCY bl@4.1.0
                  │   │ │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                  │   │ │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                  │   │ │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                  │   │ │ ├── UNMET DEPENDENCY inherits@2.0.4
                  │   │ │ └── UNMET DEPENDENCY readable-stream@3.6.0
                  │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                  │   │ │ └─┬ UNMET DEPENDENCY once@1.4.0
                  │   │ │   └── UNMET DEPENDENCY wrappy@1.0.2
                  │   │ ├── UNMET DEPENDENCY fs-constants@1.0.0
                  │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                  │   │   ├─┬ UNMET DEPENDENCY string_decoder@1.3.0
                  │   │   │ └── UNMET DEPENDENCY safe-buffer@5.2.1
                  │   │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                  │   └─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.14
                  │     ├── UNMET DEPENDENCY debounce@1.2.1
                  │     ├─┬ UNMET DEPENDENCY debug@4.3.3
                  │     ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
                  │     ├── UNMET DEPENDENCY mixin-deep@2.0.1
                  │     ├─┬ UNMET DEPENDENCY mz@2.7.0
                  │     │ ├── UNMET DEPENDENCY any-promise@1.3.0
                  │     │ ├── UNMET DEPENDENCY object-assign@4.1.1
                  │     │ └─┬ UNMET DEPENDENCY thenify-all@1.6.0
                  │     │   └─┬ UNMET DEPENDENCY thenify@3.3.1
                  │     │     └── UNMET DEPENDENCY any-promise@1.3.0
                  │     ├─┬ UNMET DEPENDENCY serialport@9.2.8
                  │     │ ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
                  │     │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                  │     │ │ │ └── UNMET DEPENDENCY debug@4.3.3
                  │     │ ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.8
                  │     │ │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                  │     │ │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                  │     │ │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
                  │     │ │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
                  │     │ │ ├── UNMET DEPENDENCY debug@4.3.3
                  │     │ │ ├── UNMET DEPENDENCY nan@2.15.0
                  │     │ │ └─┬ UNMET DEPENDENCY prebuild-install@7.0.1
                  │     │ │   ├── UNMET DEPENDENCY detect-libc@2.0.0
                  │     │ │   ├── UNMET DEPENDENCY expand-template@2.0.3
                  │     │ │   ├── UNMET DEPENDENCY github-from-package@0.0.0
                  │     │ │   ├── UNMET DEPENDENCY minimist@1.2.5
                  │     │ │   ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                  │     │ │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
                  │     │ │   ├─┬ UNMET DEPENDENCY node-abi@3.8.0
                  │     │ │   │ └─┬ UNMET DEPENDENCY semver@7.3.5
                  │     │ │   │   └─┬ UNMET DEPENDENCY lru-cache@6.0.0
                  │     │ │   │     └── UNMET DEPENDENCY yallist@4.0.0
                  │     │ │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
                  │     │ │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
                  │     │ │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
                  │     │ │   │ │ └─┬ UNMET DEPENDENCY readable-stream@2.3.7
                  │     │ │   │ │   ├── UNMET DEPENDENCY core-util-is@1.0.3
                  │     │ │   │ │   ├── UNMET DEPENDENCY inherits@2.0.4
                  │     │ │   │ │   ├── UNMET DEPENDENCY isarray@1.0.0
                  │     │ │   │ │   ├── UNMET DEPENDENCY process-nextick-args@2.0.1
                  │     │ │   │ │   ├── UNMET DEPENDENCY safe-buffer@5.1.2
                  │     │ │   │ │   ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
                  │     │ │   │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
                  │     │ │   │ │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                  │     │ │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                  │     │ │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
                  │     │ │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
                  │     │ │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                  │     │ │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
                  │     │ │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
                  │     │ │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.7
                  │     │ │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
                  │     │ │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
                  │     │ │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
                  │     │ │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
                  │     │ │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
                  │     │ │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
                  │     │ │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
                  │     │ │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
                  │     │ │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
                  │     │ │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
                  │     │ │   ├─┬ UNMET DEPENDENCY pump@3.0.0
                  │     │ │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                  │     │ │   │ │ └── UNMET DEPENDENCY once@1.4.0
                  │     │ │   │ └─┬ UNMET DEPENDENCY once@1.4.0
                  │     │ │   │   └── UNMET DEPENDENCY wrappy@1.0.2
                  │     │ │   ├─┬ UNMET DEPENDENCY rc@1.2.8
                  │     │ │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
                  │     │ │   │ ├── UNMET DEPENDENCY ini@1.3.8
                  │     │ │   │ ├── UNMET DEPENDENCY minimist@1.2.5
                  │     │ │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
                  │     │ │   ├─┬ UNMET DEPENDENCY simple-get@4.0.1
                  │     │ │   │ ├─┬ UNMET DEPENDENCY decompress-response@6.0.0
                  │     │ │   │ │ └── UNMET DEPENDENCY mimic-response@3.1.0
                  │     │ │   │ ├── UNMET DEPENDENCY once@1.4.0
                  │     │ │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
                  │     │ │   ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
                  │     │ │   │ ├── UNMET DEPENDENCY chownr@1.1.4
                  │     │ │   │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                  │     │ │   │ ├── UNMET DEPENDENCY pump@3.0.0
                  │     │ │   │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
                  │     │ │   │   ├─┬ UNMET DEPENDENCY bl@4.1.0
                  │     │ │   │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                  │     │ │   │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                  │     │ │   │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                  │     │ │   │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                  │     │ │   │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
                  │     │ │   │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
                  │     │ │   │   ├── UNMET DEPENDENCY fs-constants@1.0.0
                  │     │ │   └─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
                  │     │ ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
                  │     │ ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
                  │     │ ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                  │     │ ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
                  │     │ ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                  │     │ │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                  │     │ ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
                  │     │ ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
                  │     │ ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
                  │     └── UNMET DEPENDENCY slip@1.0.2
                  ├── semver@5.7.1
                  ├── UNMET DEPENDENCY tr-O64@0.2.4
                  └─┬ yargs@7.1.0
                    ├── camelcase@3.0.0
                    ├─┬ cliui@3.2.0
                    │ └─┬ wrap-ansi@2.1.0
                    ├── get-caller-file@1.0.3
                    ├─┬ os-locale@1.4.0
                    │ └─┬ lcid@1.0.0
                    │   └── invert-kv@1.0.0
                    ├─┬ read-pkg-up@1.0.1
                    │ ├─┬ find-up@1.1.2
                    │ │ ├─┬ path-exists@2.1.0
                    │ │ │ └── pinkie-promise@2.0.1 deduped
                    │ │ └─┬ pinkie-promise@2.0.1
                    │ │   └── pinkie@2.0.4
                    │ └─┬ read-pkg@1.1.0
                    │   ├─┬ load-json-file@1.1.0
                    │   │ ├── pify@2.3.0
                    ├── y18n@3.2.1
                  npm ERR! missing: tr-O64@0.2.4, required by iobroker.inst@2.0.3
                  • M Markus Faltermeier
                    Thomas BraunT
                    Thomas BraunT
                    Most Active Developer
                    Man kann nach oben scrollen. Ist aber nicht nötig, die Zusammenfassung am Ende ist ja schon gehaltvoll genug.
                    Der tr-O64 ist z. B. auch noch drin:
                    iobroker update -u
                    liefert?
                      iobroker update -u
                      liefert?
                      M
                      M
                      Markus Faltermeier
                      das ist die Ausgabe:
                      pi@raspberrypi:/opt/iobroker $ iobroker update -u
                      Used repository: stable
                      hash unchanged, use cached sources
                      update done
                      Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
                      Adapter    "backitup"      : 2.3.3    , installed 2.2.3 [Updateable]
                      Adapter    "discovery"     : 2.7.5    , installed 2.7.3 [Updateable]
                      Adapter    "hue"           : 3.6.5    , installed 3.5.31 [Updateable]
                      Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
                      Adapter    "mihome-vacuum" : 3.3.1    , installed 1.1.5 [Updateable]
                      Adapter    "shelly"        : 5.3.2    , installed 4.0.7 [Updateable]
                        update done
                        Thomas BraunT
                        Thomas BraunT
                        @markus-faltermeier
                        Okay, und
                        iobroker upgrade
                        macht nun?
                          @markus-faltermeier
                          Okay, und
                          iobroker upgrade
                          macht nun?
                          M
                          M
                          Markus Faltermeier
                          bekam folgende Ausgabe:
                          update done
                          pi@raspberrypi:/opt/iobroker $ ^C
                          pi@raspberrypi:/opt/iobroker $ iobroker upgrade
                          This upgrade of "hue" will introduce the following changes:
                          -> 3.6.5:
                          correctly identify third party switches (closes #273)
                          -> 3.6.3:
                          added `info.connection` state (closes #268)
                          -> 3.6.2:
                          -> 3.6.1:
                          ct values of groups can be even lower due to third party lights
                          -> 3.6.0:
                          allow to trigger scenes via `command` state, this allows to start a scene with `transitiontime`
                          Would you like to upgrade hue from @3.5.31 to @3.6.5 now? [(y)es, (n)o]: y
                          Update hue from @3.5.31 to @3.6.5
                          NPM version: 6.14.16
                          npm install iobroker.hue@3.6.5 --loglevel error --prefix "/opt/iobroker" (System call)
                          Traceback (most recent call last):
                            File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
                              import gyp
                            File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
                              import gyp.input
                            File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
                              import ast
                          ImportError: No module named ast
                          gyp ERR! configure error
                          gyp ERR! stack Error: `gyp` failed with exit code: 1
                          gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                          gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                          gyp ERR! System Linux 5.10.103-v7l+
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                          gyp ERR! node -v v14.19.0
                          gyp ERR! node-gyp -v v5.1.0
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                          gyp ERR! not ok
                          node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                          gyp ERR! cwd /opt/iobroker/node_modules/canvas
                          gyp ERR! not ok
                          node-pre-gyp ERR! build error
                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                          node-pre-gyp ERR! System Linux 5.10.103-v7l+
                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                          node-pre-gyp ERR! node -v v14.19.0
                          node-pre-gyp ERR! node-pre-gyp -v v1.0.8
                          node-pre-gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! cwd /opt/iobroker/node_modules/sharp
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                          gyp ERR! not ok
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the @serialport/bindings@9.2.8 install script.
                          npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_53_08_366Z-debug.log
                          upload [14] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                          Update "system.adapter.hue.0"
                          upload [13] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                          upload [12] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                          upload [11] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                          upload [10] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [9] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [8] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [7] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                          Adapter "hue" updated
                          This upgrade of "discovery" will introduce the following changes:
                          -> 2.7.5:
                          Fix kecontact detection (Sentry IOBROKER-DISCOVERY-3P)
                          -> 2.7.4:
                          Replaced flot with eCharts
                          info Adapter removed
                          Would you like to upgrade discovery from @2.7.3 to @2.7.5 now? [(y)es, (n)o]: y
                          Update discovery from @2.7.3 to @2.7.5
                          npm install iobroker.discovery@2.7.5 --loglevel error --prefix "/opt/iobroker" (System call)
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_54_11_360Z-debug.log
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          Adapter "discovery" updated
                          This upgrade of "admin" will introduce the following changes:
                          -> 5.3.1:
                          Support of IPv6 address by links (vis, material, end so on)
                          Corrected errors in the base settings
                          Corrected error with the pre-selected language in wizard
                          -> 5.3.0:
                          Enable http compression in webserver
                          Removed deprecated package "request"
                          Added JSONL option for base settings
                          Added small improvements
                          Added the file viewer for binary states
                          Would you like to upgrade admin from @5.2.3 to @5.3.1 now? [(y)es, (n)o]: y
                          Update admin from @5.2.3 to @5.3.1
                          host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                          npm install iobroker.admin@5.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_55_22_755Z-debug.log
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          Adapter "admin" updated
                          host.raspberrypi Adapter "system.adapter.admin.0" is started
                          This upgrade of "shelly" will at least introduce the following changes:
                          -> 5.3.2:
                          Added cover position status for generation 2 devices
                          Added cover power, voltage, current and energy for generation 2 devices
                          Updated switch roles for material ui (switch.power to switch)
                          -> 5.3.1:
                          Don't ack new values directly after change
                          -> 5.3.0:
                          Added Shelly Plus I4
                          Added more objects for power metering channels (current, voltage, limits, ...)
                          Moved device temperature of generation 2 devices to relays (this is the official way)
                          Added Sys channel (eco mode, timezone, ...) for generation 1 devices
                          Fixed datatype error of Shelly 1/PM ext switch
                          Added option to enable/disable WiFi access point (generation 2 devices)
                          Added power limits and position control for covers (generation 2 devices)
                          Removed colors for online state indication on device objects
                          -> 5.2.0:
                          Added Shelly Pro 1
                          Added Shelly Pro 1 PM
                          Added Shelly Pro 2
                          Added Shelly Pro 2 PM
                          Added Shelly Plus 2 PM
                          Allow to change device and channel names of generation 2 devices
                          Added auto on/off timers for generation 2 devices
                          Added input mode, events and initial state for generation 2 devices
                          Added support of covers / shutters for generation 2 devices
                          Replaced node-fetch with axios (also for digest auth)
                          -> 5.1.3:
                          Changed common.states strings to objects
                          Just perform firmware update if an available update was detected
                          Extended logging for CoAP
                          -> 5.1.2:
                          Fixed Shelly UNI ADC voltage
                          Fixed dimmer brightness values handling
                          Logging improvements for offline devices
                          -> 5.1.1:
                          Fixed firmware auto update
                          Updated timeouts
                          Added command source for shelly 2.5
                          Added color for device objects as online indicator
                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                          Would you like to upgrade shelly from @4.0.7 to @5.3.2 now? [(y)es, (n)o]: y
                          Update shelly from @4.0.7 to @5.3.2
                          npm install iobroker.shelly@5.3.2 --loglevel error --prefix "/opt/iobroker" (System call)
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_56_39_294Z-debug.log
                          upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                          upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                          upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                          upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                          upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          Adapter "shelly" updated
                          This upgrade of "mihome-vacuum" will at least introduce the following changes:
                          -> 3.3.1:
                          fix IOBROKER-MIHOME-VACUUM-Z
                          fix some errors
                          -> 3.3.0:
                          fix no rooms for S5
                          fix IOBROKER-MIHOME-VACUUM-4 DB closed
                          fix connection error
                          -> 3.2.2:
                          the communication is corrected
                          Added roles to be detected by type-detector
                          -> 3.2.1:
                          Adjust several crash cases (IOBROKER-MIHOME-VACUUM-K, IOBROKER-MIHOME-VACUUM-J, IOBROKER-MIHOME-VACUUM-F, IOBROKER-MIHOME-VACUUM-7, IOBROKER-MIHOME-VACUUM-A, IOBROKER-MIHOME-VACUUM-4, IOBROKER-MIHOME-VACUUM-G, IOBROKER-MIHOME-VACUUM-C, IOBROKER-MIHOME-VACUUM-B, IOBROKER-MIHOME-VACUUM-Q, IOBROKER-MIHOME-VACUUM-M)
                          -> 3.2.0:
                          fixed error
                          -> 3.1.7:
                          added Sentry, minimize messages, fix disk I/O
                          -> 3.1.5:
                          Breaking changes, Map format changed, added wifi state, added multimap support, added mopstate, fixed objects, show zones and points when selectiong in app, minmize disk I/O, minimize Messages clear and extend log,
                          Would you like to upgrade mihome-vacuum from @1.1.5 to @3.3.1 now? [(y)es, (n)o]: y
                          Update mihome-vacuum from @1.1.5 to @3.3.1
                          npm install iobroker.mihome-vacuum@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_57_43_910Z-debug.log
                          upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                          Update "system.adapter.mihome-vacuum.0"
                          upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                          upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                          upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                          upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                          upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                          upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                          upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                          upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                          upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                          upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                          Adapter "mihome-vacuum" updated
                          This upgrade of "backitup" will introduce the following changes:
                          -> 2.3.3:
                          small GUI fixes
                          Docker restore tunning
                          -> 2.3.2:
                          Bugfix Restore Interface for http
                          Fix json history
                          -> 2.3.1:
                          Bugfix Grafana
                          Bugfix Restore for Docker System
                          Restore Interface with https Support
                          use iobroker SSL Certificates for https
                          -> 2.3.0:
                          Influxdb2 Backup added
                          Influxdb2 Restore added
                          Bugfix Grafana Backup
                          Bugfix GUI
                          Bugfix Redis Restore
                          New Restore WebIf added
                          dependencies updated
                          Bugfix start after Restore
                          redis remote Backup added
                          Error messages configurable
                          Translations added
                          Adjustments to js-controller 4
                          -> 2.2.4:
                          Restore backup of different controller version added
                          Fix YAHKA Backup for more Instances
                          Would you like to upgrade backitup from @2.2.3 to @2.3.3 now? [(y)es, (n)o]: y
                          Update backitup from @2.2.3 to @2.3.3
                          npm install iobroker.backitup@2.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                              import gyp
                              import gyp.input
                              import ast
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_59_12_369Z-debug.log
                          upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                          Adapter "backitup" updated
                            update done
                            -> 3.6.5:
                            -> 3.6.3:
                            -> 3.6.2:
                            -> 3.6.1:
                            -> 3.6.0:
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            -> 2.7.5:
                            -> 2.7.4:
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            -> 5.3.1:
                            -> 5.3.0:
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            -> 5.3.2:
                            -> 5.3.1:
                            -> 5.3.0:
                            -> 5.2.0:
                            Added Shelly Pro 1
                            Added Shelly Pro 2
                            -> 5.1.3:
                            -> 5.1.2:
                            -> 5.1.1:
                            Updated timeouts
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            -> 3.3.1:
                            fix some errors
                            -> 3.3.0:
                            fix no rooms for S5
                            -> 3.2.2:
                            -> 3.2.1:
                            -> 3.2.0:
                            fixed error
                            -> 3.1.7:
                            -> 3.1.5:
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            -> 2.3.3:
                            small GUI fixes
                            -> 2.3.2:
                            Fix json history
                            -> 2.3.1:
                            Bugfix Grafana
                            -> 2.3.0:
                            Bugfix GUI
                            Translations added
                            -> 2.2.4:
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                                import gyp
                                import gyp.input
                                import ast
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            Thomas BraunT
                            Thomas BraunT
                            @markus-faltermeier
                            iobroker stop
                            iobroker fix
                            iobroker start
                              @markus-faltermeier
                              iobroker stop
                              iobroker fix
                              iobroker start
                              M
                              M
                              Markus Faltermeier
                              das lief jetzt zumindest mal ohne Fehler durch
                              pi@raspberrypi:/opt/iobroker $ iobroker fix
                              library: loaded
                              Library version=2022-02-10
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2022-02-13
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/3)
                              OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                              OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                              Installed gcc-c++
                              Installed python-dev
                                  Checking ioBroker user and directory permissions (2/3)
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                                library: loaded
                                Installed gcc-c++
                                Autostart enabled!
                                Thomas BraunT
                                Thomas BraunT
                                @markus-faltermeier
                                Editiere /opt/iobroker/node_modules/canvas/package.json:
                                Suche nach der "scripts" sektion und dort "install"
                                Das install kommando ist
                                node-pre-gyp install --fallback-to-build
                                hänge mal noch
                                --update-binary
                                dran.
                                Also
                                node-pre-gyp install --fallback-to-build --update-binary
                                  library: loaded
                                  Installed gcc-c++
                                  Autostart enabled!
                                  Thomas BraunT
                                  Thomas BraunT
                                  #66
                                  @markus-faltermeier
                                  Ist der terminal-Adapter jetzt auch deinstalliert?
                                    @markus-faltermeier
                                    M
                                    M
                                    Markus Faltermeier
                                    #67
                                    ich kann den nicht löschen. da bekomme ich die gleichen Fehlermeldungen wie beim updaten:
                                    $ iobroker del terminal
                                    Delete adapter "terminal"
                                    host.raspberrypi object terminal deleted
                                    host.raspberrypi object terminal.admin deleted
                                    npm uninstall iobroker.terminal --loglevel error --prefix "/opt/iobroker" (System call)
                                    npm ERR! code ENOENTnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-streamnpm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-stream'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                                    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T13_22_31_721Z-debug.log
                                    Error deleting adapter terminal from disk: Error: host.raspberrypi: Cannot uninstall iobroker.terminal: 254
                                    You might have to delete it yourself!
                                    Process exited with code 0
                                      #68
                                      @markus-faltermeier sagte in Probleme bei Update von admin:
                                      dann mach das
                                        @markus-faltermeier
                                        hänge mal noch
                                        --update-binary
                                        dran.
                                        Also
                                        M
                                        M
                                        Markus Faltermeier
                                        #69
                                        Hi ich habe jetzt alles durchsucht. Aber ich habe kein Verzeichnis "Canvas"
                                        pi@raspberrypi:/opt/iobroker/node_modules $ ls
                                        abab                        har-schema                             object-hash
                                        abort-controller            har-validator                          object-inspect
                                        accepts                     has                                    object-keys
                                        acme-http-01-standalone     has-bigints                            once
                                        acorn                       has-binary                             one-time
                                        acorn-globals               has-binary2                            on-finished
                                        acorn-walk                  has-cors                               on-headers
                                        after                       has-symbols                            optionator
                                        agent-base                  has-tostringtag                        options
                                        ajv                         has-unicode                            ordered-read-streams
                                        @alcalzone                  hawk                                   os-locale
                                        alcalzone-shared            he                                     ospath
                                        alexa-cookie2               help-me                                otplib
                                        alexa-remote2               hoek                                   owlintuition
                                        ansi-regex                  homematic-xmlrpc                       pako
                                        ansi-styles                 hosted-git-info                        parse5
                                        anymatch                    hot-patcher                            parse-json
                                        @apollon                    html-encoding-sniffer                  parsejson
                                        aproba                      http-errors                            parseqs
                                        are-we-there-yet            http-proxy                             parseuri
                                        argparse                    http-proxy-agent                       parseurl
                                        arraybuffer.slice           http-proxy-middleware                  parsexmlresponse
                                        array-ext                   http-proxy-response-rewrite            passport
                                        array-flatten               https                                  passport-local
                                        array.prototype.findindex   http-signature                         passport.socketio
                                        arrify                      https-proxy-agent                      passport-strategy
                                        asap                        iconv-lite                             path-dirname
                                        asn1                        ieee754                                path-exists
                                        asn1-ber                    immediate                              path-is-absolute
                                        assert-plus                 indexof                                path-parse
                                        async                       inflight                               path-posix
                                        asynckit                    inherits                               path-to-regexp
                                        async-limiter               ini                                    path-type
                                        async-retry                 internal-slot                          pause
                                        at-least-node               invert-kv                              pause-stream
                                        autobind-decorator          @iobroker                              performance-now
                                        aws4                        iobroker                               picocolors
                                        aws-iot-device-sdk          iobroker.admin                         picomatch
                                        aws-sign2                   iobroker.alexa2                        pidusage
                                        axios                       iobroker.backitup                      pify
                                        backo2                      iobroker.cloud                         ping
                                        balanced-match              iobroker.daswetter                     pinkie
                                        base-64                     iobroker.deconz                        pinkie-promise
                                        base64-arraybuffer          iobroker.denon                         pluralize
                                        base64id                    iobroker.discovery                     p-map
                                        base64-js                   iobroker.dwd                           portfinder
                                        bcrypt-pbkdf                iobroker.email                         prelude-ls
                                        bent                        iobroker.fhem                          process-nextick-args
                                        better-assert               iobroker.flot                          promise
                                        bignumber.js                iobroker.fritzbox                      promisify-child-process
                                        binary                      iobroker.geofency                      prompt
                                        binary-extensions           iobroker.harmony                       proper-lockfile
                                        bindings                    iobroker.heatingcontrol                proxy-addr
                                        binrpc                      iobroker.history                       psl
                                        bl                          iobroker.hm-rega                       pump
                                        blob                        iobroker.hm-rpc                        pumpify
                                        bluebird                    iobroker.hue                           punycode
                                        body-parser                 iobroker.ical                          pushover-notifications
                                        boom                        iobroker.icons-icons8                  put
                                        bottleneck                  iobroker.icons-mfd-svg                 q
                                        brace-expansion             iobroker.icons-ultimate-png            qs
                                        braces                      iobroker.info                          querystring
                                        browser-process-hrtime      iobroker.iot                           querystringify
                                        buffer                      iobroker.javascript                    random-bytes
                                        buffer-equal-constant-time  iobroker.js-controller                 range-parser
                                        buffer-from                 iobroker.lightify                      rasha
                                        bufferhelper                iobroker.mihome                        raw-body
                                        buffers                     iobroker.mihome-vacuum                 rc
                                        busboy                      iobroker.mobile                        read
                                        button-events               iobroker.mqtt                          readable-stream
                                        bytes                       iobroker.mqtt-client                   readdirp
                                        bytesish                    iobroker.nut                           readline-sync
                                        callback-stream             iobroker.octoprint                     read-pkg
                                        call-bind                   iobroker.ping                          read-pkg-up
                                        callsite                    iobroker.pushover                      redirect-https
                                        camelcase                   iobroker.rpi2                          redis-commands
                                        capitalize                  iobroker.scenes                        redis-errors
                                        caseless                    iobroker.shelly                        redis-parser
                                        cert-info                   iobroker.simple-api                    reinterval
                                        chainsaw                    iobroker.snmp                          remove-trailing-separator
                                        charenc                     iobroker.socketio                      request
                                        chokidar                    iobroker.sonoff                        request-promise
                                        chownr                      iobroker.spotify-premium               request-promise-core
                                        ci-info                     iobroker.statistics                    request-promise-native
                                        cli                         iobroker.synology                      require-directory
                                        cliff                       iobroker.tankerkoenig                  require-main-filename
                                        cliui                       iobroker.telegram                      requires-port
                                        cloneextend                 iobroker.terminal                      resolve
                                        cluster-key-slot            iobroker.text2command                  respjs
                                        co                          iobroker.tr-064                        retry
                                        coap                        iobroker.type-detector                 revalidator
                                        coap-packet                 iobroker.upnp                          rfdc
                                        code-point-at               iobroker.vis                           @root
                                        coffee-compiler             iobroker.vis-bars                      rpi-gpio
                                        coffee-script               iobroker.vis-colorpicker               rpi-gpio-buttons
                                        coiot-coap                  iobroker.vis-fancyswitch               rrule
                                        color                       iobroker.vis-google-fonts              safe-buffer
                                        color-convert               iobroker.vis-hqwidgets                 safer-buffer
                                        color-name                  iobroker.vis-jqui-mfd                  safe-replace
                                        @colors                     iobroker.vis-metro                     safe-stable-stringify
                                        colors                      iobroker.vis-players                   sax
                                        colorspace                  iobroker.vis-plumb                     saxes
                                        color-string                iobroker.vis-timeandweather            secure-keys
                                        combined-stream             iobroker.vis-weather                   semaphore
                                        commander                   iobroker.web                           semver
                                        commist                     ioredis                                send
                                        component-bind              ip                                     @sentry
                                        component-emitter           ipaddr.js                              seq-logging
                                        component-inherit           is                                     @serialport
                                        concat-map                  is-absolute                            serialport
                                        concat-stream               isarray                                serve-static
                                        connect                     is-arrayish                            set-blocking
                                        connect-flash               is-bigint                              set-immediate-shim
                                        console-control-strings     is-binary-path                         setprototypeof
                                        content-disposition         is-boolean-object                      shelly-iot
                                        content-type                is-callable                            side-channel
                                        cookie                      is-date-object                         signal-exit
                                        cookie-parser               isemail                                simple-concat
                                        cookie-signature            is-extglob                             simple-get
                                        core-util-is                is-fullwidth-code-point                simple-swizzle
                                        cron                        is-glob                                sntp
                                        cron-parser                 is-nan                                 socket.io
                                        crypt                       is-negated-glob                        socket.io-adapter
                                        cryptiles                   is-negative-zero                       socket.io-client
                                        crypto-js                   is-number                              socket.io-parser
                                        cssom                       is-number-object                       socksv5
                                        cssstyle                    is-plain-obj                           soef
                                        cycle                       is-potential-custom-element-name       sorted-array-functions
                                        d                           is-regex                               source-map
                                        @dabh                       is-relative                            source-map-support
                                        daemonize2                  is-shared-array-buffer                 spdx-correct
                                        dashdash                    is-stream                              spdx-exceptions
                                        data-urls                   isstream                               spdx-expression-parse
                                        debug                       is-string                              spdx-license-ids
                                        decache                     is-symbol                              split
                                        decamelize                  is-typedarray                          split2
                                        decimal.js                  is-unc-path                            sprintf-js
                                        decompress-response         is-utf8                                sshpk
                                        deep-clone                  is-weakref                             stack-trace
                                        deep-extend                 is-windows                             standard-as-callback
                                        deep-is                     joi                                    statuses
                                        define-properties           jsbn                                   stealthy-require
                                        delayed-stream              jsdom                                  stream-combiner
                                        delegates                   jshashes                               streamsearch
                                        denque                      json3                                  stream-shift
                                        depd                        jsonata                                string_decoder
                                        destroy                     json-bigint                            string.prototype.trimend
                                        detect-libc                 jsonc-parser                           string.prototype.trimstart
                                        dgram                       jsonfile                               stringstream
                                        dicer                       json-schema                            string-width
                                        diskusage                   json-schema-traverse                   strip-ansi
                                        dns-packet                  json-stable-stringify-without-jsonify  strip-bom
                                        domexception                json-stringify-safe                    strip-json-comments
                                        dropbox-v2-api              jsonwebtoken                           strnum
                                        duplexer                    jsprim                                 suncalc2
                                        duplexify                   js-sdsl                                symbol-tree
                                        ecc-jsbn                    js-yaml                                sync-exec
                                        ecdsa-sig-formatter         jszip                                  syno
                                        echarts                     jwa                                    systeminformation
                                        eckles                      jws                                    tar
                                        ee-first                    keypairs                               tar-fs
                                        emoji-regex                 kuler                                  tar-stream
                                        enabled                     layerr                                 tcp-ping
                                        encodeurl                   lcid                                   text-hex
                                        end-of-stream               le-acme-core                           thirty-two
                                        engine.io                   le-challenge-fs                        through
                                        engine.io-client            le-sni-auto                            through2
                                        engine.io-parser            leven                                  through2-filter
                                        epoll                       levn                                   to-absolute-glob
                                        error-ex                    lie                                    to-array
                                        es5-ext                     loadavg-windows                        toidentifier
                                        es6-iterator                load-json-file                         @tootallnate
                                        es6-map                     localforage                            topo
                                        es6-promise                 lodash                                 to-regex-range
                                        es6-set                     lodash.defaults                        tough-cookie
                                        es6-symbol                  lodash.flatten                         tr46
                                        es-abstract                 lodash.includes                        traverse
                                        esbuild                     lodash.isarguments                     triple-beam
                                        escalade                    lodash.isboolean                       tslib
                                        escape-html                 lodash.isinteger                       tunnel-agent
                                        escodegen                   lodash.isnumber                        tweetnacl
                                        esprima                     lodash.isplainobject                   type
                                        es-to-primitive             lodash.isstring                        type-check
                                        estraverse                  lodash.once                            typedarray
                                        esutils                     logform                                type-is
                                        etag                        long-timeout                           @types
                                        event-emitter               lru-cache                              typescript
                                        eventemitter3               lru_map                                uid-number
                                        event-stream                luxon                                  uid-safe
                                        event-target-shim           map-stream                             ultron
                                        expand-template             md5                                    unbox-primitive
                                        express                     mdns-discovery                         unc-path-regex
                                        express-fileupload          media-typer                            underscore
                                        express-session             merge-descriptors                      unique-stream
                                        ext                         methods                                universalify
                                        extend                      micromatch                             unpipe
                                        extsprintf                  mime                                   uri-js
                                        eyes                        mime-db                                url-join
                                        fast-deep-equal             mime-types                             url-parse
                                        fast-json-stable-stringify  mimic-response                         url-template
                                        fast-levenshtein            minimatch                              ursa-optional
                                        fastseries                  minimist                               util-deprecate
                                        fast-text-encoding          minipass                               utils-merge
                                        fast-xml-parser             minizlib                               uuid
                                        fecha                       mkdirp                                 validate-npm-package-license
                                        file-stream-rotator         mkdirp-classic                         vary
                                        file-type                   moment                                 verror
                                        file-uri-to-path            moment-timezone                        virtual-tsc
                                        fill-range                  mqtt                                   vm2
                                        finalhandler                mqtt-connection                        w3c-hr-time
                                        find-up                     mqtt-packet                            w3c-xmlserializer
                                        fn.name                     ms                                     wake_on_lan
                                        follow-redirects            mute-stream                            weak-daemon
                                        forever-agent               nan                                    webdav
                                        form-data                   napi-build-utils                       webidl-conversions
                                        forwarded                   nconf                                  websocket-stream
                                        fresh                       ncp                                    whatwg-encoding
                                        from                        nearest-color                          whatwg-mimetype
                                        fs-constants                negotiator                             whatwg-url
                                        fs-extra                    nested-property                        which-boxed-primitive
                                        fs-minipass                 netmask                                which-module
                                        fs.realpath                 net-snmp                               wide-align
                                        ftp                         next-tick                              window-size
                                        function-bind               node-dht-sensor                        winston
                                        gauge                       node-expat                             winston-daily-rotate-file
                                        gaxios                      node.extend                            winston-seq-updated
                                        gcp-metadata                node-fetch                             winston-syslog
                                        get-caller-file             node-forge                             winston-transport
                                        get-intrinsic               node-hue-api                           word-wrap
                                        getpass                     node-ical                              wrap-ansi
                                        get-ssl-certificate         node-inspect                           wrappy
                                        get-symbol-description      nodemailer                             ws
                                        github-from-package         node-mndp                              wtf-8
                                        glob                        node-nut                               xml2js
                                        glob-parent                 node-rest-client                       xml2json
                                        glob-stream                 node-schedule                          xml2json-light
                                        glossy                      node-ssdp                              xmlbuilder
                                        @googleapis                 node-telegram-bot-api                  xmlchars
                                        googleapis-common           node-wol                               xmldom
                                        google-auth-library         normalize-package-data                 xmlhttprequest-ssl
                                        google-p12-pem              normalize-path                         xml-name-validator
                                        graceful-fs                 npmlog                                 xregexp
                                        @greenlock                  number-allocator                       xtend
                                        greenlock                   number-is-nan                          y18n
                                        greenlock-express           nwsapi                                 yallist
                                        greenlock-manager-fs        oauth                                  yargs
                                        greenlock-store-fs          oauth-sign                             yargs-parser
                                        gtoken                      object-assign                          yeast
                                        @harmonyhub                 object.assign                          zigbee-herdsman
                                        harmonyhubws                object-component                       zrender
                                        pi@raspberrypi:/opt/iobroker/node_modules $ cd /canvas
                                        -bash: cd: /canvas: Datei oder Verzeichnis nicht gefunden
                                        pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker/node_modules/canvas
                                        -bash: cd: /opt/iobroker/node_modules/canvas: Datei oder Verzeichnis nicht gefunden
                                          cron                        is-glob                                sntp
                                          eckles                      jws                                    tar
                                          fill-range                  mqtt                                   vm2
                                          Thomas BraunT
                                          Thomas BraunT
                                          #70
                                          @markus-faltermeier
                                          Komisch. Da sehe ich eigentlich entsprechende Meldungen in deinem Log die auf canvas hindeuten würden.
                                          cd /opt/iobroker
                                          npm ls canvas
                                          M 2 Antworten Letzte Antwort
                                          84.1k
