  4. [gelöst] Probleme bei Update von admin
admin-adapterehostunreachfehlermeldungupdateupdate adapter
85 Beiträge 6 Kommentatoren 15.0k Aufrufe 3 Beobachtet
  • M Markus Faltermeier
    bekam folgende Ausgabe:
    pi@raspberrypi:/opt/iobroker $ iobroker update -u
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
    Adapter    "backitup"      : 2.3.3    , installed 2.2.3 [Updateable]
    Adapter    "discovery"     : 2.7.5    , installed 2.7.3 [Updateable]
    Adapter    "hue"           : 3.6.5    , installed 3.5.31 [Updateable]
    Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
    Adapter    "mihome-vacuum" : 3.3.1    , installed 1.1.5 [Updateable]
    Adapter    "shelly"        : 5.3.2    , installed 4.0.7 [Updateable]
    pi@raspberrypi:/opt/iobroker $ ^C
    pi@raspberrypi:/opt/iobroker $ iobroker upgrade
    This upgrade of "hue" will introduce the following changes:
    -> 3.6.5:
    correctly identify third party switches (closes #273)
    -> 3.6.3:
    added `info.connection` state (closes #268)
    -> 3.6.2:
    -> 3.6.1:
    ct values of groups can be even lower due to third party lights
    -> 3.6.0:
    allow to trigger scenes via `command` state, this allows to start a scene with `transitiontime`
    Would you like to upgrade hue from @3.5.31 to @3.6.5 now? [(y)es, (n)o]: y
    Update hue from @3.5.31 to @3.6.5
    NPM version: 6.14.16
    npm install iobroker.hue@3.6.5 --loglevel error --prefix "/opt/iobroker" (System call)
    Traceback (most recent call last):
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 47, in <module>
        import gyp
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 10, in <module>
        import gyp.input
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 7, in <module>
        import ast
    ImportError: No module named ast
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
    gyp ERR! System Linux 5.10.103-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v14.19.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! not ok
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
        import gyp
        import gyp.input
        import ast
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    node-pre-gyp ERR! System Linux 5.10.103-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v14.19.0
    node-pre-gyp ERR! node-pre-gyp -v v1.0.8
    node-pre-gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! cwd /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@9.2.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@9.2.8 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_53_08_366Z-debug.log
    upload [14] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
    Update "system.adapter.hue.0"
    upload [13] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
    upload [12] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
    upload [11] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
    upload [10] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
    Adapter "hue" updated
    This upgrade of "discovery" will introduce the following changes:
    -> 2.7.5:
    Fix kecontact detection (Sentry IOBROKER-DISCOVERY-3P)
    -> 2.7.4:
    Replaced flot with eCharts
    info Adapter removed
    Would you like to upgrade discovery from @2.7.3 to @2.7.5 now? [(y)es, (n)o]: y
    Update discovery from @2.7.3 to @2.7.5
    npm install iobroker.discovery@2.7.5 --loglevel error --prefix "/opt/iobroker" (System call)
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_54_11_360Z-debug.log
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    Adapter "discovery" updated
    This upgrade of "admin" will introduce the following changes:
    -> 5.3.1:
    Support of IPv6 address by links (vis, material, end so on)
    Corrected errors in the base settings
    Corrected error with the pre-selected language in wizard
    -> 5.3.0:
    Enable http compression in webserver
    Removed deprecated package "request"
    Added JSONL option for base settings
    Added small improvements
    Added the file viewer for binary states
    Would you like to upgrade admin from @5.2.3 to @5.3.1 now? [(y)es, (n)o]: y
    Update admin from @5.2.3 to @5.3.1
    host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
    npm install iobroker.admin@5.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_55_22_755Z-debug.log
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Adapter "admin" updated
    host.raspberrypi Adapter "system.adapter.admin.0" is started
    This upgrade of "shelly" will at least introduce the following changes:
    -> 5.3.2:
    Added cover position status for generation 2 devices
    Added cover power, voltage, current and energy for generation 2 devices
    Updated switch roles for material ui (switch.power to switch)
    -> 5.3.1:
    Don't ack new values directly after change
    -> 5.3.0:
    Added Shelly Plus I4
    Added more objects for power metering channels (current, voltage, limits, ...)
    Moved device temperature of generation 2 devices to relays (this is the official way)
    Added Sys channel (eco mode, timezone, ...) for generation 1 devices
    Fixed datatype error of Shelly 1/PM ext switch
    Added option to enable/disable WiFi access point (generation 2 devices)
    Added power limits and position control for covers (generation 2 devices)
    Removed colors for online state indication on device objects
    -> 5.2.0:
    Added Shelly Pro 1
    Added Shelly Pro 1 PM
    Added Shelly Pro 2
    Added Shelly Pro 2 PM
    Added Shelly Plus 2 PM
    Allow to change device and channel names of generation 2 devices
    Added auto on/off timers for generation 2 devices
    Added input mode, events and initial state for generation 2 devices
    Added support of covers / shutters for generation 2 devices
    Replaced node-fetch with axios (also for digest auth)
    -> 5.1.3:
    Changed common.states strings to objects
    Just perform firmware update if an available update was detected
    Extended logging for CoAP
    -> 5.1.2:
    Fixed Shelly UNI ADC voltage
    Fixed dimmer brightness values handling
    Logging improvements for offline devices
    -> 5.1.1:
    Fixed firmware auto update
    Updated timeouts
    Added command source for shelly 2.5
    Added color for device objects as online indicator
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade shelly from @4.0.7 to @5.3.2 now? [(y)es, (n)o]: y
    Update shelly from @4.0.7 to @5.3.2
    npm install iobroker.shelly@5.3.2 --loglevel error --prefix "/opt/iobroker" (System call)
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_56_39_294Z-debug.log
    upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
    upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
    upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
    upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
    upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
    Adapter "shelly" updated
    This upgrade of "mihome-vacuum" will at least introduce the following changes:
    -> 3.3.1:
    fix IOBROKER-MIHOME-VACUUM-Z
    fix some errors
    -> 3.3.0:
    fix no rooms for S5
    fix IOBROKER-MIHOME-VACUUM-4 DB closed
    fix connection error
    -> 3.2.2:
    the communication is corrected
    Added roles to be detected by type-detector
    -> 3.2.1:
    Adjust several crash cases (IOBROKER-MIHOME-VACUUM-K, IOBROKER-MIHOME-VACUUM-J, IOBROKER-MIHOME-VACUUM-F, IOBROKER-MIHOME-VACUUM-7, IOBROKER-MIHOME-VACUUM-A, IOBROKER-MIHOME-VACUUM-4, IOBROKER-MIHOME-VACUUM-G, IOBROKER-MIHOME-VACUUM-C, IOBROKER-MIHOME-VACUUM-B, IOBROKER-MIHOME-VACUUM-Q, IOBROKER-MIHOME-VACUUM-M)
    -> 3.2.0:
    fixed error
    -> 3.1.7:
    added Sentry, minimize messages, fix disk I/O
    -> 3.1.5:
    Breaking changes, Map format changed, added wifi state, added multimap support, added mopstate, fixed objects, show zones and points when selectiong in app, minmize disk I/O, minimize Messages clear and extend log,
    Would you like to upgrade mihome-vacuum from @1.1.5 to @3.3.1 now? [(y)es, (n)o]: y
    Update mihome-vacuum from @1.1.5 to @3.3.1
    npm install iobroker.mihome-vacuum@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_57_43_910Z-debug.log
    upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
    Update "system.adapter.mihome-vacuum.0"
    upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
    upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
    upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
    upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
    upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
    upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
    upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
    upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
    upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
    upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
    Adapter "mihome-vacuum" updated
    This upgrade of "backitup" will introduce the following changes:
    -> 2.3.3:
    small GUI fixes
    Docker restore tunning
    -> 2.3.2:
    Bugfix Restore Interface for http
    Fix json history
    -> 2.3.1:
    Bugfix Grafana
    Bugfix Restore for Docker System
    Restore Interface with https Support
    use iobroker SSL Certificates for https
    -> 2.3.0:
    Influxdb2 Backup added
    Influxdb2 Restore added
    Bugfix Grafana Backup
    Bugfix GUI
    Bugfix Redis Restore
    New Restore WebIf added
    dependencies updated
    Bugfix start after Restore
    redis remote Backup added
    Error messages configurable
    Translations added
    Adjustments to js-controller 4
    -> 2.2.4:
    Restore backup of different controller version added
    Fix YAHKA Backup for more Instances
    Would you like to upgrade backitup from @2.2.3 to @2.3.3 now? [(y)es, (n)o]: y
    Update backitup from @2.2.3 to @2.3.3
    npm install iobroker.backitup@2.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
        import gyp
        import gyp.input
        import ast
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T12_59_12_369Z-debug.log
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    Adapter "backitup" updated
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @markus-faltermeier
    iobroker stop
    iobroker fix
    iobroker start
      @markus-faltermeier
      iobroker stop
      iobroker fix
      iobroker start
      M
      M
      Markus Faltermeier
      das lief jetzt zumindest mal ohne Fehler durch
      pi@raspberrypi:/opt/iobroker $ iobroker fix
      library: loaded
      Library version=2022-02-10
          Welcome to the ioBroker installation fixer!
          Script version: 2022-02-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
      Installed gcc-c++
      Installed python-dev
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        Thomas BraunT
        Thomas BraunT
        @markus-faltermeier
        Editiere /opt/iobroker/node_modules/canvas/package.json:
        Suche nach der "scripts" sektion und dort "install"
        Das install kommando ist
        node-pre-gyp install --fallback-to-build
        hänge mal noch
        --update-binary
        dran.
        Also
        node-pre-gyp install --fallback-to-build --update-binary
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          Thomas BraunT
          Thomas BraunT
          #66
          @markus-faltermeier
          Ist der terminal-Adapter jetzt auch deinstalliert?
            @markus-faltermeier
            M
            M
            Markus Faltermeier
            #67
            ich kann den nicht löschen. da bekomme ich die gleichen Fehlermeldungen wie beim updaten:
            $ iobroker del terminal
            Delete adapter "terminal"
            host.raspberrypi object terminal deleted
            host.raspberrypi object terminal.admin deleted
            npm uninstall iobroker.terminal --loglevel error --prefix "/opt/iobroker" (System call)
            npm ERR! code ENOENTnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-streamnpm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-stream'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T13_22_31_721Z-debug.log
            Error deleting adapter terminal from disk: Error: host.raspberrypi: Cannot uninstall iobroker.terminal: 254
            You might have to delete it yourself!
            Process exited with code 0
              #68
              @markus-faltermeier sagte in Probleme bei Update von admin:
              dann mach das
                @markus-faltermeier
                hänge mal noch
                --update-binary
                dran.
                Also
                M
                M
                Markus Faltermeier
                #69
                Hi ich habe jetzt alles durchsucht. Aber ich habe kein Verzeichnis "Canvas"
                pi@raspberrypi:/opt/iobroker/node_modules $ ls
                abab                        har-schema                             object-hash
                abort-controller            har-validator                          object-inspect
                accepts                     has                                    object-keys
                acme-http-01-standalone     has-bigints                            once
                acorn                       has-binary                             one-time
                acorn-globals               has-binary2                            on-finished
                acorn-walk                  has-cors                               on-headers
                after                       has-symbols                            optionator
                agent-base                  has-tostringtag                        options
                ajv                         has-unicode                            ordered-read-streams
                @alcalzone                  hawk                                   os-locale
                alcalzone-shared            he                                     ospath
                alexa-cookie2               help-me                                otplib
                alexa-remote2               hoek                                   owlintuition
                ansi-regex                  homematic-xmlrpc                       pako
                ansi-styles                 hosted-git-info                        parse5
                anymatch                    hot-patcher                            parse-json
                @apollon                    html-encoding-sniffer                  parsejson
                aproba                      http-errors                            parseqs
                are-we-there-yet            http-proxy                             parseuri
                argparse                    http-proxy-agent                       parseurl
                arraybuffer.slice           http-proxy-middleware                  parsexmlresponse
                array-ext                   http-proxy-response-rewrite            passport
                array-flatten               https                                  passport-local
                array.prototype.findindex   http-signature                         passport.socketio
                arrify                      https-proxy-agent                      passport-strategy
                asap                        iconv-lite                             path-dirname
                asn1                        ieee754                                path-exists
                asn1-ber                    immediate                              path-is-absolute
                assert-plus                 indexof                                path-parse
                async                       inflight                               path-posix
                asynckit                    inherits                               path-to-regexp
                async-limiter               ini                                    path-type
                async-retry                 internal-slot                          pause
                at-least-node               invert-kv                              pause-stream
                autobind-decorator          @iobroker                              performance-now
                aws4                        iobroker                               picocolors
                aws-iot-device-sdk          iobroker.admin                         picomatch
                aws-sign2                   iobroker.alexa2                        pidusage
                axios                       iobroker.backitup                      pify
                backo2                      iobroker.cloud                         ping
                balanced-match              iobroker.daswetter                     pinkie
                base-64                     iobroker.deconz                        pinkie-promise
                base64-arraybuffer          iobroker.denon                         pluralize
                base64id                    iobroker.discovery                     p-map
                base64-js                   iobroker.dwd                           portfinder
                bcrypt-pbkdf                iobroker.email                         prelude-ls
                bent                        iobroker.fhem                          process-nextick-args
                better-assert               iobroker.flot                          promise
                bignumber.js                iobroker.fritzbox                      promisify-child-process
                binary                      iobroker.geofency                      prompt
                binary-extensions           iobroker.harmony                       proper-lockfile
                bindings                    iobroker.heatingcontrol                proxy-addr
                binrpc                      iobroker.history                       psl
                bl                          iobroker.hm-rega                       pump
                blob                        iobroker.hm-rpc                        pumpify
                bluebird                    iobroker.hue                           punycode
                body-parser                 iobroker.ical                          pushover-notifications
                boom                        iobroker.icons-icons8                  put
                bottleneck                  iobroker.icons-mfd-svg                 q
                brace-expansion             iobroker.icons-ultimate-png            qs
                braces                      iobroker.info                          querystring
                browser-process-hrtime      iobroker.iot                           querystringify
                buffer                      iobroker.javascript                    random-bytes
                buffer-equal-constant-time  iobroker.js-controller                 range-parser
                buffer-from                 iobroker.lightify                      rasha
                bufferhelper                iobroker.mihome                        raw-body
                buffers                     iobroker.mihome-vacuum                 rc
                busboy                      iobroker.mobile                        read
                button-events               iobroker.mqtt                          readable-stream
                bytes                       iobroker.mqtt-client                   readdirp
                bytesish                    iobroker.nut                           readline-sync
                callback-stream             iobroker.octoprint                     read-pkg
                call-bind                   iobroker.ping                          read-pkg-up
                callsite                    iobroker.pushover                      redirect-https
                camelcase                   iobroker.rpi2                          redis-commands
                capitalize                  iobroker.scenes                        redis-errors
                caseless                    iobroker.shelly                        redis-parser
                cert-info                   iobroker.simple-api                    reinterval
                chainsaw                    iobroker.snmp                          remove-trailing-separator
                charenc                     iobroker.socketio                      request
                chokidar                    iobroker.sonoff                        request-promise
                chownr                      iobroker.spotify-premium               request-promise-core
                ci-info                     iobroker.statistics                    request-promise-native
                cli                         iobroker.synology                      require-directory
                cliff                       iobroker.tankerkoenig                  require-main-filename
                cliui                       iobroker.telegram                      requires-port
                cloneextend                 iobroker.terminal                      resolve
                cluster-key-slot            iobroker.text2command                  respjs
                co                          iobroker.tr-064                        retry
                coap                        iobroker.type-detector                 revalidator
                coap-packet                 iobroker.upnp                          rfdc
                code-point-at               iobroker.vis                           @root
                coffee-compiler             iobroker.vis-bars                      rpi-gpio
                coffee-script               iobroker.vis-colorpicker               rpi-gpio-buttons
                coiot-coap                  iobroker.vis-fancyswitch               rrule
                color                       iobroker.vis-google-fonts              safe-buffer
                color-convert               iobroker.vis-hqwidgets                 safer-buffer
                color-name                  iobroker.vis-jqui-mfd                  safe-replace
                @colors                     iobroker.vis-metro                     safe-stable-stringify
                colors                      iobroker.vis-players                   sax
                colorspace                  iobroker.vis-plumb                     saxes
                color-string                iobroker.vis-timeandweather            secure-keys
                combined-stream             iobroker.vis-weather                   semaphore
                commander                   iobroker.web                           semver
                commist                     ioredis                                send
                component-bind              ip                                     @sentry
                component-emitter           ipaddr.js                              seq-logging
                component-inherit           is                                     @serialport
                concat-map                  is-absolute                            serialport
                concat-stream               isarray                                serve-static
                connect                     is-arrayish                            set-blocking
                connect-flash               is-bigint                              set-immediate-shim
                console-control-strings     is-binary-path                         setprototypeof
                content-disposition         is-boolean-object                      shelly-iot
                content-type                is-callable                            side-channel
                cookie                      is-date-object                         signal-exit
                cookie-parser               isemail                                simple-concat
                cookie-signature            is-extglob                             simple-get
                core-util-is                is-fullwidth-code-point                simple-swizzle
                cron                        is-glob                                sntp
                cron-parser                 is-nan                                 socket.io
                crypt                       is-negated-glob                        socket.io-adapter
                cryptiles                   is-negative-zero                       socket.io-client
                crypto-js                   is-number                              socket.io-parser
                cssom                       is-number-object                       socksv5
                cssstyle                    is-plain-obj                           soef
                cycle                       is-potential-custom-element-name       sorted-array-functions
                d                           is-regex                               source-map
                @dabh                       is-relative                            source-map-support
                daemonize2                  is-shared-array-buffer                 spdx-correct
                dashdash                    is-stream                              spdx-exceptions
                data-urls                   isstream                               spdx-expression-parse
                debug                       is-string                              spdx-license-ids
                decache                     is-symbol                              split
                decamelize                  is-typedarray                          split2
                decimal.js                  is-unc-path                            sprintf-js
                decompress-response         is-utf8                                sshpk
                deep-clone                  is-weakref                             stack-trace
                deep-extend                 is-windows                             standard-as-callback
                deep-is                     joi                                    statuses
                define-properties           jsbn                                   stealthy-require
                delayed-stream              jsdom                                  stream-combiner
                delegates                   jshashes                               streamsearch
                denque                      json3                                  stream-shift
                depd                        jsonata                                string_decoder
                destroy                     json-bigint                            string.prototype.trimend
                detect-libc                 jsonc-parser                           string.prototype.trimstart
                dgram                       jsonfile                               stringstream
                dicer                       json-schema                            string-width
                diskusage                   json-schema-traverse                   strip-ansi
                dns-packet                  json-stable-stringify-without-jsonify  strip-bom
                domexception                json-stringify-safe                    strip-json-comments
                dropbox-v2-api              jsonwebtoken                           strnum
                duplexer                    jsprim                                 suncalc2
                duplexify                   js-sdsl                                symbol-tree
                ecc-jsbn                    js-yaml                                sync-exec
                ecdsa-sig-formatter         jszip                                  syno
                echarts                     jwa                                    systeminformation
                eckles                      jws                                    tar
                ee-first                    keypairs                               tar-fs
                emoji-regex                 kuler                                  tar-stream
                enabled                     layerr                                 tcp-ping
                encodeurl                   lcid                                   text-hex
                end-of-stream               le-acme-core                           thirty-two
                engine.io                   le-challenge-fs                        through
                engine.io-client            le-sni-auto                            through2
                engine.io-parser            leven                                  through2-filter
                epoll                       levn                                   to-absolute-glob
                error-ex                    lie                                    to-array
                es5-ext                     loadavg-windows                        toidentifier
                es6-iterator                load-json-file                         @tootallnate
                es6-map                     localforage                            topo
                es6-promise                 lodash                                 to-regex-range
                es6-set                     lodash.defaults                        tough-cookie
                es6-symbol                  lodash.flatten                         tr46
                es-abstract                 lodash.includes                        traverse
                esbuild                     lodash.isarguments                     triple-beam
                escalade                    lodash.isboolean                       tslib
                escape-html                 lodash.isinteger                       tunnel-agent
                escodegen                   lodash.isnumber                        tweetnacl
                esprima                     lodash.isplainobject                   type
                es-to-primitive             lodash.isstring                        type-check
                estraverse                  lodash.once                            typedarray
                esutils                     logform                                type-is
                etag                        long-timeout                           @types
                event-emitter               lru-cache                              typescript
                eventemitter3               lru_map                                uid-number
                event-stream                luxon                                  uid-safe
                event-target-shim           map-stream                             ultron
                expand-template             md5                                    unbox-primitive
                express                     mdns-discovery                         unc-path-regex
                express-fileupload          media-typer                            underscore
                express-session             merge-descriptors                      unique-stream
                ext                         methods                                universalify
                extend                      micromatch                             unpipe
                extsprintf                  mime                                   uri-js
                eyes                        mime-db                                url-join
                fast-deep-equal             mime-types                             url-parse
                fast-json-stable-stringify  mimic-response                         url-template
                fast-levenshtein            minimatch                              ursa-optional
                fastseries                  minimist                               util-deprecate
                fast-text-encoding          minipass                               utils-merge
                fast-xml-parser             minizlib                               uuid
                fecha                       mkdirp                                 validate-npm-package-license
                file-stream-rotator         mkdirp-classic                         vary
                file-type                   moment                                 verror
                file-uri-to-path            moment-timezone                        virtual-tsc
                fill-range                  mqtt                                   vm2
                finalhandler                mqtt-connection                        w3c-hr-time
                find-up                     mqtt-packet                            w3c-xmlserializer
                fn.name                     ms                                     wake_on_lan
                follow-redirects            mute-stream                            weak-daemon
                forever-agent               nan                                    webdav
                form-data                   napi-build-utils                       webidl-conversions
                forwarded                   nconf                                  websocket-stream
                fresh                       ncp                                    whatwg-encoding
                from                        nearest-color                          whatwg-mimetype
                fs-constants                negotiator                             whatwg-url
                fs-extra                    nested-property                        which-boxed-primitive
                fs-minipass                 netmask                                which-module
                fs.realpath                 net-snmp                               wide-align
                ftp                         next-tick                              window-size
                function-bind               node-dht-sensor                        winston
                gauge                       node-expat                             winston-daily-rotate-file
                gaxios                      node.extend                            winston-seq-updated
                gcp-metadata                node-fetch                             winston-syslog
                get-caller-file             node-forge                             winston-transport
                get-intrinsic               node-hue-api                           word-wrap
                getpass                     node-ical                              wrap-ansi
                get-ssl-certificate         node-inspect                           wrappy
                get-symbol-description      nodemailer                             ws
                github-from-package         node-mndp                              wtf-8
                glob                        node-nut                               xml2js
                glob-parent                 node-rest-client                       xml2json
                glob-stream                 node-schedule                          xml2json-light
                glossy                      node-ssdp                              xmlbuilder
                @googleapis                 node-telegram-bot-api                  xmlchars
                googleapis-common           node-wol                               xmldom
                google-auth-library         normalize-package-data                 xmlhttprequest-ssl
                google-p12-pem              normalize-path                         xml-name-validator
                graceful-fs                 npmlog                                 xregexp
                @greenlock                  number-allocator                       xtend
                greenlock                   number-is-nan                          y18n
                greenlock-express           nwsapi                                 yallist
                greenlock-manager-fs        oauth                                  yargs
                greenlock-store-fs          oauth-sign                             yargs-parser
                gtoken                      object-assign                          yeast
                @harmonyhub                 object.assign                          zigbee-herdsman
                harmonyhubws                object-component                       zrender
                pi@raspberrypi:/opt/iobroker/node_modules $ cd /canvas
                -bash: cd: /canvas: Datei oder Verzeichnis nicht gefunden
                pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker/node_modules/canvas
                -bash: cd: /opt/iobroker/node_modules/canvas: Datei oder Verzeichnis nicht gefunden
                  cron                        is-glob                                sntp
                  eckles                      jws                                    tar
                  fill-range                  mqtt                                   vm2
                  Thomas BraunT
                  Thomas BraunT
                  #70
                  @markus-faltermeier
                  Komisch. Da sehe ich eigentlich entsprechende Meldungen in deinem Log die auf canvas hindeuten würden.
                  cd /opt/iobroker
                  npm ls canvas
                  M 2 Antworten Letzte Antwort
                    @markus-faltermeier
                    cd /opt/iobroker
                    npm ls canvas
                    M
                    M
                    Markus Faltermeier
                    #71
                    @thomas-braun Hi,
                    da bekomme ich diese Ausgabe
                    pi@raspberrypi:/opt/iobroker $ npm ls canvas
                    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                    iobroker.inst@2.0.3 /opt/iobroker
                    └─┬ iobroker.iot@1.8.24
                      └── UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                      @thomas-braun Hi,
                      Thomas BraunT
                      Thomas BraunT
                      #72
                      @markus-faltermeier
                      Da hängt schon mal eines deiner Probleme.
                      npm ls
                      bringt?
                      HomoranH M 2 Antworten Letzte Antwort
                        @markus-faltermeier
                        cd /opt/iobroker
                        npm ls canvas
                        M
                        M
                        Markus Faltermeier
                        #73
                        Ich hab jetzt nochmal versucht nach dem anderen thread vorzugehen.
                        mit "npm list" taucht der tr064 immer noch auf. Und ich krieg den nicht gelöscht
                         semver@5.7.1
                        ├── UNMET DEPENDENCY tr-O64@0.2.4
                        └─┬ yargs@7.1.0
                          ├── camelcase@3.0.0
                          ├─┬ cliui@3.2.0
                          │ ├── string-width@1.0.2 deduped
                          │ ├─┬ strip-ansi@3.0.1
                          │ │ └── ansi-regex@2.1.1
                          │ └─┬ wrap-ansi@2.1.0
                          │   └── strip-ansi@3.0.1 deduped
                          ├── decamelize@1.2.0
                          ├── get-caller-file@1.0.3
                          ├─┬ os-locale@1.4.0
                          │ └─┬ lcid@1.0.0
                          │   └── invert-kv@1.0.0
                        sieht zwar so aus, als ob er dann mit dem angegebenen Befehl:
                        cd /opt/iobroker/node_modules/iobroker.tr-064
                        npm uninstall tr-O64
                        deinstalliert. Aber anschließend ist er immer noch da.
                        ich bekomm da folgende Ausgabe:
                        pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.tr-064
                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.tr-064 $ npm uninstall tr-O64
                        > es5-ext@0.10.57 postinstall /opt/iobroker/node_modules/iobroker.tr-064/node_modules/es5-ext
                        > node -e "try{require('./_postinstall')}catch(e){}"
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        added 564 packages from 408 contributors and audited 570 packages in 29.66s
                        43 packages are looking for funding
                          run `npm fund` for details
                        found 3 vulnerabilities (1 low, 2 high)
                          run `npm audit fix` to fix them, or `npm audit` for details
                          @markus-faltermeier
                          npm ls
                          bringt?
                          #74
                          @thomas-braun sagte in Probleme bei Update von admin:
                          und das zweite ist die falsche Version von der package-lock.json wegen npm v8.
                            @markus-faltermeier
                            npm ls
                            bringt?
                            M
                            M
                            Markus Faltermeier
                            #75
                            │ │ │ ├── component-emitter@1.2.1
                            │ │ │ ├── component-inherit@0.0.3
                            │ │ │ ├─┬ debug@2.3.3
                            │ │ │ │ └── ms@0.7.2
                            │ │ │ ├── engine.io-parser@1.3.2 deduped
                            │ │ │ ├── has-cors@1.1.0
                            │ │ │ ├── indexof@0.0.1 deduped
                            │ │ │ ├─┬ parsejson@0.0.3
                            │ │ │ │ └── better-assert@1.0.2 deduped
                            │ │ │ ├─┬ parseqs@0.0.5
                            │ │ │ ├── parseuri@0.0.5 deduped
                            │ │ │ ├── ws@1.1.1 deduped
                            │ │ │ ├── xmlhttprequest-ssl@1.5.3
                            │ │ │ └── yeast@0.1.2
                            │ │ ├── has-binary@0.1.7 deduped
                            │ │ ├── object-component@0.0.3
                            │ │ ├─┬ parseuri@0.0.5
                            │ │ │ └─┬ better-assert@1.0.2
                            │ │ │   └── callsite@1.0.0 deduped
                            │ │ ├── socket.io-parser@2.3.1 deduped
                            │ │ └── to-array@0.1.4
                            │ └── ws@7.5.7
                            ├─┬ iobroker.daswetter@3.0.9
                            │ ├─┬ @iobroker/adapter-core@2.5.1
                            │ │ └─┬ @types/iobroker@3.3.4
                            │ │   └── @types/node@13.13.5 deduped
                            │ ├─┬ @sentry/node@6.14.1
                            │ │ ├─┬ @sentry/core@6.14.1
                            │ │ │ ├── @sentry/hub@6.14.1 deduped
                            │ │ │ ├─┬ @sentry/minimal@6.14.1
                            │ │ │ │ ├── @sentry/hub@6.14.1 deduped
                            │ │ │ │ ├── @sentry/types@6.14.1 deduped
                            │ │ │ │ └── tslib@1.11.2 deduped
                            │ │ │ ├── @sentry/utils@6.14.1 deduped
                            │ │ ├─┬ @sentry/hub@6.14.1
                            │ │ ├─┬ @sentry/tracing@6.14.1
                            │ │ │ ├─┬ @sentry/hub@6.14.1
                            │ │ │ │ ├── @sentry/utils@6.14.1 deduped
                            │ │ │ ├─┬ @sentry/utils@6.14.1
                            │ │ ├── cookie@0.4.1 deduped
                            │ │ ├── https-proxy-agent@5.0.0 deduped
                            │ │ ├── lru_map@0.3.3 deduped
                            │ ├─┬ bent@7.3.12
                            │ │ ├── bytesish@0.4.4
                            │ │ ├── caseless@0.12.0 deduped
                            │ │ └── is-stream@2.0.1
                            │ └── xml2json-light@1.0.6
                            ├─┬ iobroker.deconz@1.3.19
                            │ ├── @sentry/integrations@6.16.1 deduped
                            │ ├── @sentry/node@6.16.1 deduped
                            │ ├── request@2.88.2 deduped
                            │ ├── source-map-support@0.5.21 deduped
                            │ └── ws@7.5.6
                            ├─┬ iobroker.denon@1.12.1
                            │ └─┬ @iobroker/adapter-core@2.5.1
                            ├─┬ iobroker.discovery@2.7.3
                            │ ├─┬ mdns-discovery@0.2.6
                            │ │ ├─┬ debug@2.2.0
                            │ │ │ └── ms@0.7.1
                            │ │ ├── dgram@1.0.1
                            │ │ └─┬ dns-packet@1.3.1
                            │ │   ├── ip@1.1.5 deduped
                            │ │   └── safe-buffer@5.1.2 deduped
                            │ ├── netmask@2.0.2
                            │ ├── node-mndp@0.0.3
                            │ ├─┬ node-ssdp@4.0.1
                            │ │ ├─┬ async@2.6.3
                            │ │ │ └── lodash@4.17.21 deduped
                            │ │ ├── bluebird@3.7.2
                            │ │ ├─┬ debug@3.2.7
                            │ │ │ └── ms@2.1.3
                            │ │ ├── extend@3.0.2 deduped
                            │ │ └── ip@1.1.5 deduped
                            │ └─┬ serialport@9.2.8
                            │   ├─┬ @serialport/binding-mock@9.2.4
                            │   │ ├─┬ @serialport/binding-abstract@9.2.3
                            │   │ │ └─┬ debug@4.3.3
                            │   │ │   └── ms@2.1.2
                            │   │ └─┬ debug@4.3.3
                            │   │   └── ms@2.1.2
                            │   ├─┬ UNMET OPTIONAL DEPENDENCY @serialport/bindings@9.2.8
                            │   │ ├── @serialport/binding-abstract@9.2.3 deduped
                            │   │ ├── @serialport/parser-readline@9.2.4 deduped
                            │   │ ├─┬ bindings@1.5.0
                            │   │ │ └── file-uri-to-path@1.0.0
                            │   │ ├─┬ UNMET OPTIONAL DEPENDENCY debug@4.3.3
                            │   │ │ └── UNMET OPTIONAL DEPENDENCY ms@2.1.2
                            │   │ ├── nan@2.15.0 deduped
                            │   │ └─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@7.0.1
                            │   │   ├── UNMET OPTIONAL DEPENDENCY detect-libc@2.0.1
                            │   │   ├── expand-template@2.0.3 deduped
                            │   │   ├── github-from-package@0.0.0 deduped
                            │   │   ├── minimist@1.2.5 deduped
                            │   │   ├── mkdirp-classic@0.5.3 deduped
                            │   │   ├── napi-build-utils@1.0.2 deduped
                            │   │   ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@3.8.0
                            │   │   │ └─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                            │   │   │   └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                            │   │   │     └── yallist@4.0.0 deduped
                            │   │   ├── npmlog@4.1.2 deduped
                            │   │   ├── pump@3.0.0 deduped
                            │   │   ├── rc@1.2.8 deduped
                            │   │   ├─┬ UNMET OPTIONAL DEPENDENCY simple-get@4.0.1
                            │   │   │ ├─┬ UNMET OPTIONAL DEPENDENCY decompress-response@6.0.0
                            │   │   │ │ └── UNMET OPTIONAL DEPENDENCY mimic-response@3.1.0
                            │   │   │ ├── once@1.4.0 deduped
                            │   │   │ └── simple-concat@1.0.0 deduped
                            │   │   ├── tar-fs@2.1.1 deduped
                            │   │   └── tunnel-agent@0.6.0 deduped
                            │   ├── @serialport/parser-byte-length@9.2.4
                            │   ├── @serialport/parser-cctalk@9.2.4
                            │   ├── @serialport/parser-delimiter@9.2.4
                            │   ├── @serialport/parser-inter-byte-timeout@9.2.4
                            │   ├─┬ @serialport/parser-readline@9.2.4
                            │   │ └── @serialport/parser-delimiter@9.2.4 deduped
                            │   ├── @serialport/parser-ready@9.2.4
                            │   ├── @serialport/parser-regex@9.2.4
                            │   ├─┬ @serialport/stream@9.2.4
                            │   │ └─┬ debug@4.3.3
                            │   │   └── ms@2.1.2
                            │   └─┬ debug@4.3.3
                            │     └── ms@2.1.2
                            ├─┬ iobroker.dwd@2.7.7
                            │ ├─┬ @iobroker/adapter-core@2.5.0
                            │ │ └─┬ @types/iobroker@3.3.0
                            │ └─┬ axios@0.21.4
                            │   └── follow-redirects@1.14.8 deduped
                            ├─┬ iobroker.email@1.0.10
                            │ └── nodemailer@6.7.2
                            ├─┬ iobroker.fhem@1.6.3
                            ├─┬ iobroker.flot@1.10.7
                            ├─┬ iobroker.fritzbox@0.2.1
                            │ └─┬ xml2js@0.4.23
                            │   ├── sax@1.2.4
                            │   └── xmlbuilder@11.0.1
                            ├─┬ iobroker.geofency@1.0.3
                            │ └── request@2.88.2 deduped
                            ├─┬ iobroker.harmony@1.2.2
                            │ ├─┬ @harmonyhub/discover@1.0.8
                            │ │ ├── autobind-decorator@2.4.0
                            │ │ └─┬ debug@4.1.1
                            │ │   └── ms@2.1.2
                            │ ├─┬ @iobroker/adapter-core@1.0.3
                            │ │ └─┬ @types/iobroker@1.4.13
                            │ ├─┬ harmonyhubws@1.0.6
                            │ │ ├── request@2.88.2 deduped
                            │ │ ├─┬ request-promise-native@1.0.8
                            │ │ │ ├─┬ request-promise-core@1.1.3
                            │ │ │ │ └── lodash@4.17.21 deduped
                            │ │ │ ├── stealthy-require@1.1.1
                            │ │ │ └── tough-cookie@2.5.0 deduped
                            │ │ ├── semver@5.7.1 deduped
                            │ │ └─┬ ws@6.2.1
                            │ │   └── async-limiter@1.0.1
                            │ └── semaphore@1.0.5
                            ├─┬ iobroker.heatingcontrol@2.7.2
                            │ │ ├── @sentry/tracing@6.14.1 deduped
                            │ └─┬ cron@1.8.2
                            │   └─┬ moment-timezone@0.5.34
                            │     └── moment@2.29.1 deduped
                            ├─┬ iobroker.history@1.10.5
                            ├─┬ iobroker.hm-rega@3.0.35
                            │ ├─┬ iconv-lite@0.6.3
                            │ │ └── safer-buffer@2.1.2
                            │ └── xml2js@0.4.23 deduped
                            ├─┬ iobroker.hm-rpc@1.15.0
                            │ ├─┬ binrpc@3.3.1
                            │ │ ├─┬ binary@0.3.0
                            │ │ │ ├── buffers@0.1.1
                            │ │ │ └─┬ chainsaw@0.1.0
                            │ │ │   └── traverse@0.3.9
                            │ │ └── put@0.0.6
                            │ └─┬ homematic-xmlrpc@1.0.2
                            │   ├── sax@0.4.3
                            │   └── xmlbuilder@0.4.2
                            ├─┬ UNMET DEPENDENCY iobroker.hue@3.5.31
                            │ ├─┬ UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
                            │ │ └─┬ UNMET DEPENDENCY @types/iobroker@3.3.4
                            │ └─┬ node-hue-api@4.0.11
                            │   ├── axios@0.21.4 deduped
                            │   ├── bottleneck@2.19.5
                            │   └── get-ssl-certificate@2.3.3
                            ├─┬ iobroker.ical@1.11.4
                            │ ├── cloneextend@0.0.3
                            │ ├─┬ node-ical@0.13.0
                            │ │ ├── moment-timezone@0.5.34 deduped
                            │ │ ├─┬ node-fetch@2.6.7
                            │ │ │ └─┬ whatwg-url@5.0.0
                            │ │ │   ├── tr46@0.0.3
                            │ │ │   └── webidl-conversions@3.0.1
                            │ │ ├── rrule@2.6.8 deduped
                            │ │ └── uuid@8.3.2
                            │ └─┬ rrule@2.6.8
                            │   ├── luxon@1.27.0
                            ├── iobroker.icons-icons8@0.0.1
                            ├── iobroker.icons-mfd-svg@1.0.2
                            ├── iobroker.icons-ultimate-png@1.0.1
                            ├─┬ iobroker.info@1.9.8
                            │ ├── jshashes@1.0.8
                            │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@1.0.7
                            │ ├─┬ semver@7.3.5
                            │ │ └─┬ lru-cache@6.0.0
                            │ └── systeminformation@5.11.3
                            ├─┬ iobroker.iot@1.8.24
                            │ ├─┬ aws-iot-device-sdk@2.2.11
                            │ │ ├── crypto-js@4.0.0
                            │ │ ├─┬ mqtt@4.2.8
                            │ │ │ ├── commist@1.1.0 deduped
                            │ │ │ ├─┬ concat-stream@2.0.0
                            │ │ │ │ ├── buffer-from@1.1.1 deduped
                            │ │ │ │ ├── inherits@2.0.4 deduped
                            │ │ │ │ ├── readable-stream@3.6.0 deduped
                            │ │ │ │ └── typedarray@0.0.6 deduped
                            │ │ │ ├─┬ debug@4.3.3
                            │ │ │ │ └── ms@2.1.2
                            │ │ │ ├─┬ duplexify@4.1.2
                            │ │ │ │ ├── end-of-stream@1.4.4 deduped
                            │ │ │ │ └── stream-shift@1.0.1 deduped
                            │ │ │ ├─┬ help-me@3.0.0
                            │ │ │ │ ├── glob@7.1.6 deduped
                            │ │ │ │ └── readable-stream@3.6.0 deduped
                            │ │ │ ├── minimist@1.2.5 deduped
                            │ │ │ ├─┬ mqtt-packet@6.10.0
                            │ │ │ │ ├── bl@4.1.0 deduped
                            │ │ │ │ ├── debug@4.3.3 deduped
                            │ │ │ │ └── process-nextick-args@2.0.1 deduped
                            │ │ │ ├── pump@3.0.0 deduped
                            │ │ │ ├─┬ readable-stream@3.6.0
                            │ │ │ │ ├── string_decoder@1.1.1 deduped
                            │ │ │ │ └── util-deprecate@1.0.2 deduped
                            │ │ │ ├── reinterval@1.1.0 deduped
                            │ │ │ ├─┬ split2@3.2.2
                            │ │ │ ├── ws@7.5.7
                            │ │ │ └── xtend@4.0.2 deduped
                            │ │ └── websocket-stream@5.5.2 deduped
                            │ ├─┬ UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                            │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @mapbox/node-pre-gyp@1.0.8
                            │ │ │ ├── detect-libc@1.0.3 deduped
                            │ │ │ ├── https-proxy-agent@5.0.0 deduped
                            │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY make-dir@3.1.0
                            │ │ │ │ └── UNMET OPTIONAL DEPENDENCY semver@6.3.0
                            │ │ │ ├── node-fetch@2.6.7 deduped
                            │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY nopt@5.0.0
                            │ │ │ │ └── UNMET OPTIONAL DEPENDENCY abbrev@1.1.1
                            │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY npmlog@5.0.1
                            │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY are-we-there-yet@2.0.0
                            │ │ │ │ │ ├── delegates@1.0.0
                            │ │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY readable-stream@3.6.0
                            │ │ │ │ │   ├── inherits@2.0.4 deduped
                            │ │ │ │ │   ├── string_decoder@1.1.1 deduped
                            │ │ │ │ │   └── util-deprecate@1.0.2 deduped
                            │ │ │ │ ├── console-control-strings@1.1.0
                            │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY gauge@3.0.2
                            │ │ │ │ │ ├── aproba@1.2.0
                            │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY color-support@1.1.3
                            │ │ │ │ │ ├── console-control-strings@1.1.0 deduped
                            │ │ │ │ │ ├── has-unicode@2.0.1
                            │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY object-assign@4.1.1
                            │ │ │ │ │ ├── signal-exit@3.0.3 deduped
                            │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY string-width@4.2.3
                            │ │ │ │ │ │ ├── emoji-regex@8.0.0 deduped
                            │ │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY is-fullwidth-code-point@3.0.0
                            │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                            │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                            │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY ansi-regex@5.0.1
                            │ │ │ │ │ └─┬ wide-align@1.1.3
                            │ │ │ │ │   └── string-width@1.0.2 deduped
                            │ │ │ │ └── set-blocking@2.0.0 deduped
                            │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY rimraf@3.0.2
                            │ │ │ │ └── glob@7.1.6 deduped
                            │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                            │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                            │ │ │ │   └── yallist@4.0.0 deduped
                            │ │ │ └── tar@6.1.11 deduped
                            │ │ └─┬ simple-get@3.1.0
                            │ │   ├─┬ decompress-response@4.2.1
                            │ │   │ └── mimic-response@2.1.0
                            │ ├─┬ echarts@4.9.0
                            │ │ └── zrender@4.3.2
                            │ ├── iobroker.type-detector@1.0.17
                            │ ├─┬ jsdom@17.0.0
                            │ │ ├── abab@2.0.5
                            │ │ ├── acorn@8.7.0
                            │ │ ├─┬ acorn-globals@6.0.0
                            │ │ │ ├── acorn@7.4.1
                            │ │ │ └── acorn-walk@7.2.0
                            │ │ ├── cssom@0.5.0
                            │ │ ├─┬ cssstyle@2.3.0
                            │ │ │ └── cssom@0.3.8
                            │ │ ├─┬ data-urls@3.0.1
                            │ │ │ ├── abab@2.0.5 deduped
                            │ │ │ ├── whatwg-mimetype@3.0.0
                            │ │ │ └─┬ whatwg-url@10.0.0
                            │ │ │   ├─┬ tr46@3.0.0
                            │ │ │   │ └── punycode@2.1.1 deduped
                            │ │ │   └── webidl-conversions@7.0.0
                            │ │ ├── decimal.js@10.3.1
                            │ │ ├─┬ domexception@2.0.1
                            │ │ │ └── webidl-conversions@5.0.0
                            │ │ ├─┬ escodegen@2.0.0
                            │ │ │ ├── esprima@4.0.1
                            │ │ │ ├── estraverse@5.3.0
                            │ │ │ ├── esutils@2.0.3
                            │ │ │ ├─┬ optionator@0.8.3
                            │ │ │ │ ├── deep-is@0.1.4
                            │ │ │ │ ├── fast-levenshtein@2.0.6
                            │ │ │ │ ├─┬ levn@0.3.0
                            │ │ │ │ │ ├── prelude-ls@1.1.2 deduped
                            │ │ │ │ │ └── type-check@0.3.2 deduped
                            │ │ │ │ ├─┬ type-check@0.3.2
                            │ │ │ │ │ └── prelude-ls@1.1.2 deduped
                            │ │ │ │ └── word-wrap@1.2.3
                            │ │ │ └── source-map@0.6.1 deduped
                            │ │ ├─┬ form-data@4.0.0
                            │ │ │ ├── asynckit@0.4.0 deduped
                            │ │ │ ├── combined-stream@1.0.8 deduped
                            │ │ │ └── mime-types@2.1.34 deduped
                            │ │ ├─┬ html-encoding-sniffer@2.0.1
                            │ │ │ └── whatwg-encoding@1.0.5 deduped
                            │ │ ├─┬ http-proxy-agent@4.0.1
                            │ │ │ ├── @tootallnate/once@1.1.2
                            │ │ │ ├── agent-base@6.0.2 deduped
                            │ │ │   └── ms@2.1.2
                            │ │ ├── is-potential-custom-element-name@1.0.1
                            │ │ ├── nwsapi@2.2.0
                            │ │ ├── parse5@6.0.1
                            │ │ ├─┬ saxes@5.0.1
                            │ │ │ └── xmlchars@2.2.0
                            │ │ ├── symbol-tree@3.2.4
                            │ │ ├─┬ tough-cookie@4.0.0
                            │ │ │ ├── psl@1.8.0 deduped
                            │ │ │ ├── punycode@2.1.1 deduped
                            │ │ │ └── universalify@0.1.2 deduped
                            │ │ ├─┬ w3c-hr-time@1.0.2
                            │ │ │ └── browser-process-hrtime@1.0.0
                            │ │ ├─┬ w3c-xmlserializer@2.0.0
                            │ │ │ └── xml-name-validator@3.0.0 deduped
                            │ │ ├── webidl-conversions@6.1.0
                            │ │ ├─┬ whatwg-encoding@1.0.5
                            │ │ │ └── iconv-lite@0.4.24 deduped
                            │ │ ├── whatwg-mimetype@2.3.0
                            │ │ ├─┬ whatwg-url@9.1.0
                            │ │ │ ├─┬ tr46@2.1.0
                            │ │ │ └── webidl-conversions@6.1.0 deduped
                            │ │ ├── ws@8.5.0
                            │ ├── moment@2.29.1
                            │ ├─┬ UNMET OPTIONAL DEPENDENCY sharp@0.28.1
                            │ │ ├─┬ color@3.2.1
                            │ │ │ ├─┬ color-convert@1.9.3
                            │ │ │ │ └── color-name@1.1.3
                            │ │ │ └─┬ color-string@1.9.0
                            │ │ │   ├── color-name@1.1.3 deduped
                            │ │ │   └─┬ simple-swizzle@0.2.2
                            │ │ │     └── is-arrayish@0.3.2
                            │ │ ├── UNMET OPTIONAL DEPENDENCY node-addon-api@3.2.1
                            │ │ ├─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@6.1.4
                            │ │ │ ├── expand-template@2.0.3
                            │ │ │ ├── github-from-package@0.0.0
                            │ │ │ ├── mkdirp-classic@0.5.3 deduped
                            │ │ │ ├── napi-build-utils@1.0.2
                            │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@2.30.1
                            │ │ │ │ └── semver@5.7.1 deduped
                            │ │ │ ├─┬ npmlog@4.1.2
                            │ │ │ │ ├─┬ are-we-there-yet@1.1.5
                            │ │ │ │ │ ├── delegates@1.0.0 deduped
                            │ │ │ │ │ └── readable-stream@2.3.7 deduped
                            │ │ │ │ ├─┬ gauge@2.7.4
                            │ │ │ │ │ ├── aproba@1.2.0 deduped
                            │ │ │ │ │ ├── has-unicode@2.0.1 deduped
                            │ │ │ │ │ ├── object-assign@4.1.0 deduped
                            │ │ │ │ │ ├── string-width@1.0.2 deduped
                            │ │ │ │ │ ├── strip-ansi@3.0.1 deduped
                            │ │ │ │ │ └── wide-align@1.1.3 deduped
                            │ │ │ ├─┬ rc@1.2.8
                            │ │ │ │ ├── deep-extend@0.6.0
                            │ │ │ │ ├── ini@1.3.5 deduped
                            │ │ │ │ ├── minimist@1.2.5 deduped
                            │ │ │ │ └── strip-json-comments@2.0.1
                            │ │ │ ├── simple-get@3.1.0 deduped
                            │ │ │ ├── tar-fs@2.1.1 deduped
                            │ │ │ └── tunnel-agent@0.6.0 deduped
                            │ └── uuid@8.3.2
                            ├─┬ iobroker.javascript@5.2.21
                            │ │   └── @types/node@10.17.60 deduped
                            │ ├── @types/node@10.17.60
                            │ ├─┬ @types/request@2.48.8
                            │ │ ├── @types/caseless@0.12.2
                            │ │ ├── @types/node@13.13.5
                            │ │ ├── @types/tough-cookie@4.0.1
                            │ │ └─┬ form-data@2.5.1
                            │ ├── coffee-compiler@0.3.2
                            │ ├── coffee-script@1.12.7
                            │ ├── jsonata@1.8.6
                            │ ├── node-inspect@2.0.0
                            │ ├─┬ node-schedule@2.0.0
                            │ │ ├── cron-parser@3.5.0 deduped
                            │ │ ├── long-timeout@0.1.1 deduped
                            │ │ └── sorted-array-functions@1.3.0 deduped
                            │ ├── oauth@0.9.15
                            │ ├─┬ owlintuition@0.4.0
                            │ │ └─┬ xml2json@0.12.0
                            │ │   ├── hoek@4.2.1
                            │ │   ├─┬ joi@13.7.0
                            │ │   │ ├── hoek@5.0.4
                            │ │   │ ├─┬ isemail@3.2.0
                            │ │   │ └─┬ topo@3.0.3
                            │ │   │   └── hoek@6.1.3
                            │ │   └─┬ node-expat@2.4.0
                            │ │     ├── bindings@1.5.0 deduped
                            │ │     └── nan@2.15.0 deduped
                            │ ├─┬ semver@7.3.5
                            │ ├── suncalc2@1.8.1
                            │ ├── typescript@4.5.5
                            │ ├─┬ virtual-tsc@0.6.2
                            │ │ ├─┬ debug@4.3.3
                            │ │ │ └── ms@2.1.2
                            │ │ └── picocolors@1.0.0
                            │ ├─┬ vm2@3.9.7
                            │ │ ├── acorn@8.7.0 deduped
                            │ │ └── acorn-walk@8.2.0
                            │ ├─┬ wake_on_lan@1.0.0
                            │ │ └── minimist@1.2.5 deduped
                            ├─┬ iobroker.js-controller@3.3.22
                            │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                            │ │ ├── esbuild@0.11.23
                            │ │ └── jsonc-parser@3.0.0
                            │ ├─┬ @iobroker/db-objects-file@1.2.7
                            │ │ ├─┬ @iobroker/db-base@1.2.4
                            │ │ │ ├── deep-clone@3.0.3 deduped
                            │ │ │ ├─┬ fs-extra@9.1.0
                            │ │ │ │ ├── at-least-node@1.0.0 deduped
                            │ │ │ │ ├── graceful-fs@4.2.4 deduped
                            │ │ │ │ ├─┬ jsonfile@6.1.0
                            │ │ │ │ │ ├── graceful-fs@4.2.4 deduped
                            │ │ │ │ │ └── universalify@2.0.0 deduped
                            │ │ │ ├── node.extend@2.0.2 deduped
                            │ │ │ └── respjs@4.2.0
                            │ │ ├── @iobroker/db-objects-redis@1.2.7 deduped
                            │ │ └── node.extend@2.0.2 deduped
                            │ ├─┬ @iobroker/db-objects-jsonl@1.2.7
                            │ │ ├─┬ @alcalzone/jsonl-db@1.3.0
                            │ │ │ ├─┬ alcalzone-shared@3.0.4
                            │ │ │ │ └─┬ debug@4.3.3
                            │ │ │ └─┬ proper-lockfile@4.1.2
                            │ │ │   ├── retry@0.12.0
                            │ │ │   └── signal-exit@3.0.3
                            │ │ ├── @iobroker/db-base@1.2.4 deduped
                            │ │ ├── @iobroker/db-objects-file@1.2.7 deduped
                            │ ├─┬ @iobroker/db-objects-redis@1.2.7
                            │ │ ├─┬ ioredis@4.28.5
                            │ │ │ ├── cluster-key-slot@1.1.0
                            │ │ │ ├── denque@1.5.1
                            │ │ │ ├── lodash.defaults@4.2.0
                            │ │ │ ├── lodash.flatten@4.4.0
                            │ │ │ ├── lodash.isarguments@3.1.0
                            │ │ │ ├── p-map@2.1.0
                            │ │ │ ├── redis-commands@1.7.0
                            │ │ │ ├── redis-errors@1.2.0
                            │ │ │ ├─┬ redis-parser@3.0.0
                            │ │ │ │ └── redis-errors@1.2.0 deduped
                            │ │ │ └── standard-as-callback@2.1.0
                            │ ├─┬ @iobroker/db-states-file@1.2.7
                            │ │ └── @iobroker/db-states-redis@1.2.7 deduped
                            │ ├─┬ @iobroker/db-states-jsonl@1.2.7
                            │ │ ├── @alcalzone/jsonl-db@1.3.0 deduped
                            │ │ ├── @iobroker/db-states-file@1.2.7 deduped
                            │ ├─┬ @iobroker/db-states-redis@1.2.7
                            │ │ └── ioredis@4.28.5 deduped
                            │ ├── @iobroker/plugin-base@1.2.1
                            │ ├─┬ @iobroker/plugin-sentry@1.1.10
                            │ │ ├── @iobroker/plugin-base@1.2.1 deduped
                            │ │ ├── @sentry/integrations@6.16.1 deduped
                            │ │ ├── @sentry/node@6.16.1 deduped
                            │ │ └── source-map-support@0.5.21 deduped
                            │ ├─┬ chokidar@3.5.3
                            │ │ ├─┬ anymatch@3.1.2
                            │ │ │ ├── normalize-path@3.0.0 deduped
                            │ │ │ └── picomatch@2.3.1
                            │ │ ├─┬ braces@3.0.2
                            │ │ │ └─┬ fill-range@7.0.1
                            │ │ │   └─┬ to-regex-range@5.0.1
                            │ │ │     └── is-number@7.0.0
                            │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@2.3.2
                            │ │ ├─┬ glob-parent@5.1.2
                            │ │ │ └── is-glob@4.0.1 deduped
                            │ │ ├─┬ is-binary-path@2.1.0
                            │ │ │ └── binary-extensions@2.2.0
                            │ │ ├─┬ is-glob@4.0.1
                            │ │ │ └── is-extglob@2.1.1
                            │ │ └─┬ readdirp@3.6.0
                            │ │   └── picomatch@2.3.1 deduped
                            │ ├── ci-info@3.3.0
                            │ ├── daemonize2@0.4.2
                            │ ├─┬ debug@4.3.3
                            │ │ └── ms@2.1.2
                            │ ├─┬ decache@4.6.1
                            │ ├─┬ diskusage@1.1.3
                            │ │ ├── es6-promise@4.2.8
                            │ ├─┬ event-stream@4.0.1
                            │ │ ├── duplexer@0.1.1
                            │ │ ├── from@0.1.7
                            │ │ ├── map-stream@0.0.7
                            │ │ ├─┬ pause-stream@0.0.11
                            │ │ │ └── through@2.3.8 deduped
                            │ │ ├─┬ split@1.0.1
                            │ │ ├─┬ stream-combiner@0.2.2
                            │ │ │ ├── duplexer@0.1.1 deduped
                            │ ├─┬ greenlock@4.0.4
                            │ │ ├─┬ @greenlock/manager@3.1.0
                            │ │ │ └─┬ greenlock-manager-fs@3.1.1
                            │ │ │   ├── @root/mkdirp@1.0.0 deduped
                            │ │ │   └── safe-replace@1.1.0 deduped
                            │ │ ├─┬ @root/acme@3.1.0
                            │ │ │ ├── @root/csr@0.8.1 deduped
                            │ │ │ ├── @root/encoding@1.0.1
                            │ │ │ ├─┬ @root/keypairs@0.10.3
                            │ │ │ │ ├── @root/encoding@1.0.1 deduped
                            │ │ │ │ ├── @root/pem@1.0.4 deduped
                            │ │ │ │ └── @root/x509@0.7.2 deduped
                            │ │ │ ├── @root/request@1.8.1 deduped
                            │ │ │ └─┬ @root/x509@0.7.2
                            │ │ │   ├── @root/asn1@1.0.0 deduped
                            │ │ │   └── @root/encoding@1.0.1 deduped
                            │ │ ├─┬ @root/csr@0.8.1
                            │ │ │ ├─┬ @root/asn1@1.0.0
                            │ │ │ │ └── @root/encoding@1.0.1 deduped
                            │ │ ├─┬ @root/greenlock@4.0.5
                            │ │ │ ├── @greenlock/manager@3.1.0 deduped
                            │ │ │ ├── @root/acme@3.1.0 deduped
                            │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
                            │ │ │ ├── cert-info@1.5.1 deduped
                            │ │ │ ├── greenlock-store-fs@3.2.2 deduped
                            │ │ ├─┬ @root/keypairs@0.9.0
                            │ │ ├─┬ greenlock-store-fs@3.2.2
                            │ ├─┬ greenlock-express@4.0.3
                            │ │ ├── @root/greenlock@4.0.5 deduped
                            │ │ ├─┬ @root/greenlock-express@4.0.4
                            │ │ │ ├── @root/greenlock@4.0.5 deduped
                            │ │ │ └── redirect-https@1.3.1 deduped
                            │ │ └─┬ redirect-https@1.3.1
                            │ │   └── escape-html@1.0.3 deduped
                            │ ├─┬ jsonwebtoken@8.5.1
                            │ │ ├─┬ jws@3.2.2
                            │ │ │ ├─┬ jwa@1.4.1
                            │ │ │ │ ├── buffer-equal-constant-time@1.0.1 deduped
                            │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
                            │ │ │ │ └── safe-buffer@5.1.2 deduped
                            │ │ ├── lodash.includes@4.3.0
                            │ │ ├── lodash.isboolean@3.0.3
                            │ │ ├── lodash.isinteger@4.0.4
                            │ │ ├── lodash.isnumber@3.0.3
                            │ │ ├── lodash.isplainobject@4.0.6
                            │ │ ├── lodash.isstring@4.0.1
                            │ │ ├── lodash.once@4.1.1
                            │ │ ├── ms@2.1.2
                            │ ├─┬ jszip@3.7.1
                            │ │ ├─┬ lie@3.3.0
                            │ │ │ └── immediate@3.0.6
                            │ │ ├── pako@1.0.11
                            │ │ ├─┬ readable-stream@2.3.7
                            │ │ │ ├── core-util-is@1.0.2 deduped
                            │ │ │ ├── isarray@1.0.0
                            │ │ │ ├── process-nextick-args@2.0.1
                            │ │ │ ├── safe-buffer@5.1.2 deduped
                            │ │ │ ├─┬ string_decoder@1.1.1
                            │ │ └── set-immediate-shim@1.0.1
                            │ ├─┬ le-acme-core@2.1.4
                            │ │ └─┬ rsa-compat@1.9.4
                            │ │   ├─┬ keypairs@1.2.14
                            │ │   │ ├── eckles@1.4.1
                            │ │   │ └── rasha@1.2.5
                            │ │   ├── node-forge@0.7.6
                            │ │   └─┬ ursa-optional@0.9.10
                            │ ├─┬ le-challenge-fs@2.0.9
                            │ │ └── @root/mkdirp@1.0.0 deduped
                            │ ├── le-sni-auto@2.1.9
                            │ ├─┬ loadavg-windows@1.1.1
                            │ │ └── weak-daemon@1.0.3
                            │ ├── mime@2.6.0
                            │ ├── ncp@2.0.0
                            │ ├── node-forge@0.10.0
                            │ ├── node-schedule@2.1.0 deduped
                            │ ├─┬ node.extend@2.0.2
                            │ │ ├─┬ has@1.0.3
                            │ │ │ └── function-bind@1.1.1
                            │ │ └── is@3.3.0
                            │ ├─┬ pidusage@2.0.21
                            │ │ └── safe-buffer@5.2.1
                            │ ├── promisify-child-process@4.1.1
                            │ ├─┬ prompt@1.2.1
                            │ │ ├── async@0.9.2
                            │ │ ├── colors@1.4.0 deduped
                            │ │ ├─┬ read@1.0.7
                            │ │ │ └── mute-stream@0.0.8
                            │ │ ├── revalidator@0.1.8
                            │ │ └─┬ winston@2.4.5
                            │ │   ├── async@1.0.0
                            │ │   ├── colors@1.0.3
                            │ │   ├── cycle@1.0.3
                            │ │   ├── eyes@0.1.8
                            │ │   ├── isstream@0.1.2 deduped
                            │ │   └── stack-trace@0.0.10 deduped
                            │ ├── readline-sync@1.4.10
                            │ ├─┬ semver@7.3.5
                            │ ├─┬ tar@6.1.11
                            │ │ ├── chownr@2.0.0
                            │ │ ├─┬ fs-minipass@2.1.0
                            │ │ │ └── minipass@3.1.1 deduped
                            │ │ ├─┬ minipass@3.1.1
                            │ │ ├─┬ minizlib@2.1.2
                            │ │ │ ├── minipass@3.1.1 deduped
                            │ │ ├── mkdirp@1.0.4
                            │ ├─┬ winston@3.6.0
                            │ │ ├─┬ @dabh/diagnostics@2.0.3
                            │ │ │ ├─┬ colorspace@1.1.4
                            │ │ │ │ ├── color@3.2.1 deduped
                            │ │ │ │ └── text-hex@1.0.0
                            │ │ │ ├── enabled@2.0.0
                            │ │ │ └── kuler@2.0.0
                            │ │ ├── async@3.2.3
                            │ │ ├── is-stream@2.0.1 deduped
                            │ │ ├─┬ logform@2.4.0
                            │ │ │ ├── @colors/colors@1.5.0
                            │ │ │ ├── fecha@4.2.1
                            │ │ │ ├── ms@2.1.3
                            │ │ │ ├── safe-stable-stringify@2.3.1 deduped
                            │ │ │ └── triple-beam@1.3.0 deduped
                            │ │ ├─┬ one-time@1.0.0
                            │ │ │ └── fn.name@1.1.0
                            │ │ ├── stack-trace@0.0.10
                            │ │ ├── triple-beam@1.3.0
                            │ │ └─┬ winston-transport@4.5.0
                            │ │   ├── logform@2.4.0 deduped
                            │ ├─┬ winston-daily-rotate-file@4.6.1
                            │ │ ├─┬ file-stream-rotator@0.6.1
                            │ │ │ └── moment@2.29.1 deduped
                            │ │ ├── object-hash@2.2.0
                            │ │ ├── triple-beam@1.3.0 deduped
                            │ │ └── winston-transport@4.5.0 deduped
                            │ ├─┬ winston-seq-updated@1.0.4
                            │ │ ├── seq-logging@0.4.6
                            │ ├─┬ winston-syslog@2.4.4
                            │ │ ├── glossy@0.1.7
                            │ │ └─┬ UNMET OPTIONAL DEPENDENCY unix-dgram@2.0.3
                            │ └─┬ yargs@16.2.0
                            │   ├─┬ cliui@7.0.4
                            │   │ ├── string-width@4.2.3 deduped
                            │   │ ├─┬ strip-ansi@6.0.1
                            │   │ │ └── ansi-regex@5.0.1
                            │   │ └─┬ wrap-ansi@7.0.0
                            │   │   ├─┬ ansi-styles@4.3.0
                            │   │   │ └─┬ color-convert@2.0.1
                            │   │   │   └── color-name@1.1.4
                            │   │   └── strip-ansi@6.0.1 deduped
                            │   ├── escalade@3.1.1
                            │   ├── get-caller-file@2.0.5
                            │   ├── require-directory@2.1.1 deduped
                            │   ├─┬ string-width@4.2.3
                            │   │ ├── is-fullwidth-code-point@3.0.0
                            │   ├── y18n@5.0.8
                            │   └── yargs-parser@20.2.9
                            ├─┬ iobroker.lightify@0.2.16
                            │ ├── mdns-discovery@0.2.6 deduped
                            │ ├── moment@2.29.1 deduped
                            │ ├─┬ promise@8.0.1
                            │ │ └── asap@2.0.6
                            │ └─┬ soef@0.4.15
                            │   ├── array-ext@0.1.5
                            │   └── sprintf-js@1.1.2
                            ├─┬ iobroker.mihome@1.3.7
                            ├── iobroker.mihome-vacuum@1.1.5
                            ├─┬ iobroker.mobile@1.0.1
                            ├─┬ iobroker.mqtt@2.4.1
                            │ ├─┬ mqtt@2.18.9
                            │ │ ├─┬ commist@1.1.0
                            │ │ │ ├── leven@2.1.0
                            │ │ │ └── minimist@1.2.5 deduped
                            │ │ ├─┬ concat-stream@1.6.2
                            │ │ │ ├── readable-stream@2.3.7 deduped
                            │ │ ├─┬ end-of-stream@1.4.4
                            │ │ │ └── once@1.4.0 deduped
                            │ │ ├─┬ es6-map@0.1.5
                            │ │ │ ├─┬ d@1.0.1
                            │ │ │ │ ├── es5-ext@0.10.53 deduped
                            │ │ │ │ └── type@1.2.0
                            │ │ │ ├─┬ es5-ext@0.10.53
                            │ │ │ │ ├── es6-iterator@2.0.3 deduped
                            │ │ │ │ ├── es6-symbol@3.1.3 deduped
                            │ │ │ │ └── next-tick@1.0.0
                            │ │ │ ├─┬ es6-iterator@2.0.3
                            │ │ │ │ ├── d@1.0.1 deduped
                            │ │ │ │ └── es6-symbol@3.1.3 deduped
                            │ │ │ ├─┬ es6-set@0.1.5
                            │ │ │ │ ├─┬ es6-symbol@3.1.1
                            │ │ │ │ │ ├── d@1.0.1 deduped
                            │ │ │ │ │ └── es5-ext@0.10.53 deduped
                            │ │ │ │ └── event-emitter@0.3.5 deduped
                            │ │ │ ├─┬ es6-symbol@3.1.3
                            │ │ │ │ └─┬ ext@1.4.0
                            │ │ │ │   └── type@2.0.0
                            │ │ │ └─┬ event-emitter@0.3.5
                            │ │ ├─┬ help-me@1.1.0
                            │ │ │ ├─┬ callback-stream@1.1.0
                            │ │ │ ├─┬ glob-stream@6.1.0
                            │ │ │ │ ├── extend@3.0.2 deduped
                            │ │ │ │ ├─┬ glob-parent@3.1.0
                            │ │ │ │ │ ├─┬ is-glob@3.1.0
                            │ │ │ │ │ │ └── is-extglob@2.1.1 deduped
                            │ │ │ │ │ └── path-dirname@1.0.2
                            │ │ │ │ ├── is-negated-glob@1.0.0
                            │ │ │ │ ├─┬ ordered-read-streams@1.0.1
                            │ │ │ │ ├─┬ pumpify@1.5.1
                            │ │ │ │ │ ├── duplexify@3.7.1 deduped
                            │ │ │ │ │ └─┬ pump@2.0.1
                            │ │ │ │ │   ├── end-of-stream@1.4.4 deduped
                            │ │ │ │ │   └── once@1.4.0 deduped
                            │ │ │ │ ├── readable-stream@2.3.7 deduped
                            │ │ │ │ ├── remove-trailing-separator@1.1.0
                            │ │ │ │ ├─┬ to-absolute-glob@2.0.2
                            │ │ │ │ │ ├─┬ is-absolute@1.0.0
                            │ │ │ │ │ │ ├─┬ is-relative@1.0.0
                            │ │ │ │ │ │ │ └─┬ is-unc-path@1.0.0
                            │ │ │ │ │ │ │   └── unc-path-regex@0.1.2
                            │ │ │ │ │ │ └── is-windows@1.0.2
                            │ │ │ │ │ └── is-negated-glob@1.0.0 deduped
                            │ │ │ │ └─┬ unique-stream@2.3.1
                            │ │ │ │   ├── json-stable-stringify-without-jsonify@1.0.1
                            │ │ │ │   └─┬ through2-filter@3.0.0
                            │ │ │ │     ├── through2@2.0.5 deduped
                            │ │ │ │     └── xtend@4.0.2 deduped
                            • M Markus Faltermeier
                              │ └── ws@7.5.7
                              │ ├─┬ bent@7.3.12
                              │ └── ws@7.5.6
                              │ │ ├─┬ debug@2.2.0
                              │ │ │ └── ms@0.7.1
                              │ │ ├── dgram@1.0.1
                              │ ├── netmask@2.0.2
                              │ │ ├─┬ async@2.6.3
                              │ │ ├─┬ debug@3.2.7
                              │ │ │ └── ms@2.1.3
                              │   │ │   └── ms@2.1.2
                              │   │ └─┬ debug@4.3.3
                              │   │   └── ms@2.1.2
                              │   │ └─┬ debug@4.3.3
                              │   │   └── ms@2.1.2
                              │   └─┬ debug@4.3.3
                              │     └── ms@2.1.2
                              │ └─┬ axios@0.21.4
                              │ └─┬ xml2js@0.4.23
                              │   ├── sax@1.2.4
                              │ │ └─┬ debug@4.1.1
                              │ │   └── ms@2.1.2
                              │ │ └─┬ ws@6.2.1
                              │ └─┬ cron@1.8.2
                              │ ├─┬ binrpc@3.3.1
                              │ │ └── put@0.0.6
                              │   ├── sax@0.4.3
                              │ │ └── uuid@8.3.2
                              │ └─┬ rrule@2.6.8
                              │   ├── luxon@1.27.0
                              │ ├─┬ semver@7.3.5
                              │ │ ├─┬ mqtt@4.2.8
                              │ │ │ ├── ws@7.5.7
                              │ ├─┬ echarts@4.9.0
                              │ ├─┬ jsdom@17.0.0
                              │ │ ├── abab@2.0.5
                              │ │ ├── acorn@8.7.0
                              │ │ ├── cssom@0.5.0
                              │ │ │   └── ms@2.1.2
                              │ │ ├─┬ saxes@5.0.1
                              │ │ ├── ws@8.5.0
                              │ ├── moment@2.29.1
                              │ │ ├─┬ color@3.2.1
                              │ │ │ ├─┬ rc@1.2.8
                              │ └── uuid@8.3.2
                              │ ├── jsonata@1.8.6
                              │ ├── oauth@0.9.15
                              │ │   ├── hoek@4.2.1
                              │ │   ├─┬ joi@13.7.0
                              │ ├─┬ semver@7.3.5
                              │ │ ├─┬ debug@4.3.3
                              │ │ │ └── ms@2.1.2
                              │ ├─┬ vm2@3.9.7
                              │ ├── ci-info@3.3.0
                              │ ├─┬ debug@4.3.3
                              │ │ └── ms@2.1.2
                              │ ├─┬ decache@4.6.1
                              │ │ ├── from@0.1.7
                              │ │ ├─┬ split@1.0.1
                              │ │ ├─┬ jws@3.2.2
                              │ │ │ ├─┬ jwa@1.4.1
                              │ │ ├── ms@2.1.2
                              │ ├─┬ jszip@3.7.1
                              │ │ ├─┬ lie@3.3.0
                              │ │ ├── pako@1.0.11
                              │ ├── mime@2.6.0
                              │ ├── ncp@2.0.0
                              │ │ ├─┬ has@1.0.3
                              │ │ └── is@3.3.0
                              │ ├─┬ prompt@1.2.1
                              │ │ ├── async@0.9.2
                              │ │ ├─┬ read@1.0.7
                              │ │   ├── async@1.0.0
                              │ │   ├── cycle@1.0.3
                              │ │   ├── eyes@0.1.8
                              │ ├─┬ semver@7.3.5
                              │ ├─┬ tar@6.1.11
                              │ ├─┬ winston@3.6.0
                              │ │ ├── async@3.2.3
                              │ │ │ ├── ms@2.1.3
                              │ └─┬ yargs@16.2.0
                              │   ├─┬ cliui@7.0.4
                              │   ├── y18n@5.0.8
                              │ ├─┬ promise@8.0.1
                              │ │ └── asap@2.0.6
                              │ └─┬ soef@0.4.15
                              │ ├─┬ mqtt@2.18.9
                              │ │ │ ├─┬ d@1.0.1
                              M
                              M
                              Markus Faltermeier
                              #76
                              @markus-faltermeier
                              und der zweite Teil
                              │ │ ├─┬ mqtt-packet@5.6.1
                              │ │ │ ├─┬ bl@1.2.2
                              │ │ │ ├── process-nextick-args@2.0.1 deduped
                              │ │ ├─┬ split2@2.2.0
                              │ │ │ └── through2@2.0.5 deduped
                              │ │ ├─┬ websocket-stream@5.2.0
                              │ │ │ ├─┬ ws@6.2.2
                              │ │ │ │ └── async-limiter@1.0.1 deduped
                              │ ├─┬ mqtt-connection@4.1.0
                              │ │ ├─┬ duplexify@3.7.1
                              │ │ └─┬ through2@2.0.5
                              │ ├─┬ websocket-stream@5.5.2
                              │ │ ├─┬ ws@3.3.3
                              │ │ │ ├── async-limiter@1.0.1 deduped
                              │ │ │ └── ultron@1.1.1
                              │ └── ws@8.5.0
                              ├─┬ iobroker.mqtt-client@1.5.0
                              │ ├─┬ @iobroker/adapter-core@2.6.0
                              │ │ └─┬ @types/iobroker@4.0.1
                              │ └── mqtt@2.18.9 deduped
                              ├─┬ iobroker.nut@1.5.0
                              │ └── node-nut@1.0.3
                              ├─┬ iobroker.octoprint@2.1.0
                              │ └─┬ axios@0.24.0
                              ├─┬ iobroker.ping@1.5.0
                              ├─┬ iobroker.pushover@2.0.5
                              │ └── pushover-notifications@1.2.2
                              ├─┬ iobroker.rpi2@1.3.1
                              │ ├─┬ node-dht-sensor@0.4.3
                              │ │ └── node-addon-api@1.7.2
                              │ ├─┬ rpi-gpio@2.1.7
                              │ │ ├─┬ async-retry@1.3.3
                              │ │ │ └── retry@0.13.1
                              │ │ ├─┬ debug@3.2.7
                              │ │ │ └── ms@2.1.3
                              │ │ └─┬ epoll@2.0.10
                              │ ├─┬ rpi-gpio-buttons@2.0.1
                              │ │ ├── button-events@1.0.2
                              │ │ └── rpi-gpio@2.1.7 deduped
                              │ └── sync-exec@0.6.2
                              ├─┬ iobroker.scenes@2.3.8
                              │ └── node-schedule@2.1.0 deduped
                              ├─┬ iobroker.shelly@4.0.7
                              │ ├── @apollon/iobroker-tools@0.2.0
                              │ ├─┬ coiot-coap@1.0.0
                              │ │ ├─┬ coap@0.24.0
                              │ │ │ ├── capitalize@2.0.4
                              │ │ │ ├── coap-packet@0.1.14
                              │ │ │ ├── fastseries@2.0.0
                              │ │ │ ├─┬ lru-cache@5.1.1
                              │ │ │ │ └── yallist@3.1.1
                              │ │ │ └─┬ readable-stream@3.6.0
                              │ │ └── commander@6.2.1
                              │ ├─┬ mqtt@4.3.5
                              │ │ ├─┬ debug@4.3.3
                              │ │ │ └── ms@2.1.2
                              │ │ │ ├─┬ glob@7.1.6
                              │ │ │ │ ├── fs.realpath@1.0.0
                              │ │ │ │ ├─┬ inflight@1.0.6
                              │ │ │ │ │ ├── once@1.4.0 deduped
                              │ │ │ │ │ └── wrappy@1.0.2 deduped
                              │ │ │ │ ├── minimatch@3.0.4 deduped
                              │ │ │ │ └── path-is-absolute@1.0.1
                              │ │ ├─┬ lru-cache@6.0.0
                              │ │ ├─┬ number-allocator@1.0.9
                              │ │ │ └── js-sdsl@2.1.4
                              │ │ ├── rfdc@1.3.0
                              │ │ ├── ws@7.5.7
                              │ ├── mqtt-connection@4.1.0 deduped
                              │ ├─┬ ping@0.4.1
                              │ │ ├── q@1.5.1
                              │ │ └── underscore@1.13.2
                              │ ├─┬ shelly-iot@1.1.2
                              │ │ ├─┬ coap@0.26.0
                              │ │ │ ├─┬ @types/bl@5.0.2
                              │ │ │ │ ├── @types/node@13.13.5 deduped
                              │ │ │ │ └─┬ @types/readable-stream@2.3.13
                              │ │ │ ├── @types/node@16.11.25
                              │ │ │ ├─┬ bl@5.0.0
                              │ │ │ │ ├─┬ buffer@6.0.3
                              │ │ │ │ │ ├── base64-js@1.3.1 deduped
                              │ │ │ │ │ └── ieee754@1.2.1
                              │ │ │ ├── capitalize@2.0.4 deduped
                              │ │ │ ├── coap-packet@1.1.1
                              │ │ │ ├── fastseries@2.0.0 deduped
                              │ │ │ ├─┬ lru-cache@6.0.0
                              │ │ └─┬ node-rest-client@3.1.1
                              │ │   ├─┬ debug@4.3.3
                              │ │   │ └── ms@2.1.2
                              │ │   ├── follow-redirects@1.14.8 deduped
                              │ │   └── xml2js@0.4.23 deduped
                              │ ├── tcp-ping@0.1.1
                              │ ├── xml2js@0.4.23 deduped
                              │ └── xmlbuilder@15.1.1
                              ├─┬ iobroker.simple-api@2.6.2
                              ├─┬ iobroker.snmp@0.5.0
                              │ └─┬ net-snmp@1.2.5
                              │   └── asn1-ber@1.0.9
                              ├─┬ iobroker.socketio@3.1.5
                              │ ├─┬ axios@0.23.0
                              │ │ └── follow-redirects@1.14.8 deduped
                              │ ├── cookie-parser@1.4.6 deduped
                              │ ├── express-session@1.17.2 deduped
                              │ └─┬ socket.io@2.4.1
                              │   ├─┬ debug@4.1.1
                              │   │ └── ms@2.1.3
                              │   ├─┬ engine.io@3.5.0
                              │   │ ├── accepts@1.3.8 deduped
                              │   │ ├── base64id@2.0.0
                              │   │ ├─┬ debug@4.1.1
                              │   │ │ └── ms@2.1.3 deduped
                              │   │ ├─┬ engine.io-parser@2.2.1
                              │   │ │ ├── after@0.8.2 deduped
                              │   │ │ ├── arraybuffer.slice@0.0.7
                              │   │ │ ├── base64-arraybuffer@0.1.4
                              │   │ │ ├── blob@0.0.5
                              │   │ │ └── has-binary2@1.0.3 deduped
                              │   │ └── ws@7.4.6
                              │   ├─┬ has-binary2@1.0.3
                              │   │ └── isarray@2.0.1
                              │   ├── socket.io-adapter@1.1.2
                              │   ├─┬ socket.io-client@2.4.0
                              │   │ ├── backo2@1.0.2 deduped
                              │   │ ├── component-bind@1.0.0 deduped
                              │   │ ├── component-emitter@1.3.0
                              │   │ ├─┬ debug@3.1.0
                              │   │ │ └── ms@2.0.0
                              │   │ ├─┬ engine.io-client@3.5.2
                              │   │ │ ├── component-emitter@1.3.0 deduped
                              │   │ │ ├── component-inherit@0.0.3 deduped
                              │   │ │ ├─┬ debug@3.1.0
                              │   │ │ │ └── ms@2.0.0
                              │   │ │ ├── engine.io-parser@2.2.1 deduped
                              │   │ │ ├── has-cors@1.1.0 deduped
                              │   │ │ ├── parseqs@0.0.6 deduped
                              │   │ │ ├── parseuri@0.0.6 deduped
                              │   │ │ ├── ws@7.4.6 deduped
                              │   │ │ ├── xmlhttprequest-ssl@1.6.3
                              │   │ │ └── yeast@0.1.2 deduped
                              │   │ ├── has-binary2@1.0.3 deduped
                              │   │ ├─┬ socket.io-parser@3.3.2
                              │   │ │ ├── debug@3.1.0 deduped
                              │   │ │ └── isarray@2.0.1 deduped
                              │   │ └── to-array@0.1.4 deduped
                              │   └─┬ socket.io-parser@3.4.1
                              │     ├─┬ debug@4.1.1
                              │     └── isarray@2.0.1
                              ├─┬ iobroker.sonoff@2.4.7
                              │ └── mqtt-connection@4.1.0 deduped
                              ├─┬ iobroker.spotify-premium@1.0.0
                              │ ├─┬ @iobroker/adapter-core@1.0.1
                              │ │ └── @types/iobroker@1.4.13 deduped
                              │ ├── promise@8.0.1 deduped
                              │ ├── querystring@0.2.0
                              │ └─┬ request@2.83.0
                              │   ├── aws-sign2@0.7.0 deduped
                              │   ├── aws4@1.9.1 deduped
                              │   ├── forever-agent@0.6.1 deduped
                              │   ├── form-data@2.3.3 deduped
                              │   ├─┬ har-validator@5.0.3
                              │   │ ├─┬ ajv@5.5.2
                              │   │ │ ├── co@4.6.0
                              │   │ │ ├── fast-deep-equal@1.1.0
                              │   │ │ ├── fast-json-stable-stringify@2.1.0 deduped
                              │   │ │ └── json-schema-traverse@0.3.1
                              │   │ └── har-schema@2.0.0 deduped
                              │   ├─┬ hawk@6.0.2
                              │   │ ├─┬ boom@4.3.1
                              │   │ │ └── hoek@4.2.1 deduped
                              │   │ ├─┬ cryptiles@3.1.4
                              │   │ │ └─┬ boom@5.2.0
                              │   │ ├── hoek@4.2.1 deduped
                              │   │ └─┬ sntp@2.1.0
                              │   ├── http-signature@1.2.0 deduped
                              │   ├── is-typedarray@1.0.0 deduped
                              │   ├── json-stringify-safe@5.0.1 deduped
                              │   ├── mime-types@2.1.34 deduped
                              │   ├── oauth-sign@0.8.2
                              │   ├── performance-now@2.1.0 deduped
                              │   ├── qs@6.5.2
                              │   ├── stringstream@0.0.6
                              │   ├─┬ tough-cookie@2.3.4
                              │   │ └── punycode@1.4.1
                              │   ├── tunnel-agent@0.6.0 deduped
                              │   └── uuid@3.4.0 deduped
                              ├─┬ iobroker.statistics@1.0.9
                              │ └── cron@1.8.2 deduped
                              ├─┬ iobroker.synology@1.1.3
                              │ ├─┬ @iobroker/adapter-core@2.4.0
                              │ │ └─┬ @types/iobroker@3.2.4
                              │ └─┬ syno@3.0.0
                              │   ├── commander@4.1.1
                              │   ├─┬ js-yaml@3.14.1
                              │   │ ├─┬ argparse@1.0.10
                              │   │ │ └── sprintf-js@1.0.3
                              │   │ └── esprima@4.0.1 deduped
                              │   ├── lodash@4.17.21 deduped
                              │   ├── minimist@0.2.1
                              │   ├─┬ nconf@0.10.0
                              │   │ ├── async@1.5.2
                              │   │ ├── ini@1.3.5
                              │   │ ├── secure-keys@1.0.0
                              │   │ └─┬ yargs@3.32.0
                              │   │   ├── camelcase@2.1.1
                              │   │   ├── cliui@3.2.0 deduped
                              │   │   ├── decamelize@1.2.0 deduped
                              │   │   ├── os-locale@1.4.0 deduped
                              │   │   ├── window-size@0.1.4
                              │   │   └── y18n@3.2.1 deduped
                              │   ├── ospath@1.2.2
                              │   ├─┬ otplib@11.0.1
                              │   │ └── thirty-two@1.0.2
                              │   ├── pluralize@8.0.0
                              ├─┬ iobroker.tankerkoenig@2.1.1
                              ├─┬ iobroker.telegram@1.11.1
                              │ ├─┬ axios@0.25.0
                              │ ├─┬ node-telegram-bot-api@0.56.0
                              │ │ ├─┬ array.prototype.findindex@2.1.0
                              │ │ │ ├─┬ define-properties@1.1.3
                              │ │ │ │ └── object-keys@1.1.1
                              │ │ │ └─┬ es-abstract@1.19.1
                              │ │ │   ├── call-bind@1.0.2 deduped
                              │ │ │   ├─┬ es-to-primitive@1.2.1
                              │ │ │   │ ├── is-callable@1.2.4 deduped
                              │ │ │   │ ├─┬ is-date-object@1.0.5
                              │ │ │   │ │ └── has-tostringtag@1.0.0 deduped
                              │ │ │   │ └─┬ is-symbol@1.0.4
                              │ │ │   │   └── has-symbols@1.0.2 deduped
                              │ │ │   ├── function-bind@1.1.1 deduped
                              │ │ │   ├─┬ get-intrinsic@1.1.1
                              │ │ │   │ ├── function-bind@1.1.1 deduped
                              │ │ │   │ ├── has@1.0.3 deduped
                              │ │ │   ├─┬ get-symbol-description@1.0.0
                              │ │ │   │ ├── call-bind@1.0.2 deduped
                              │ │ │   │ └── get-intrinsic@1.1.1 deduped
                              │ │ │   ├── has-symbols@1.0.2
                              │ │ │   ├─┬ internal-slot@1.0.3
                              │ │ │   │ ├── get-intrinsic@1.1.1 deduped
                              │ │ │   │ └─┬ side-channel@1.0.4
                              │ │ │   │   └── object-inspect@1.12.0 deduped
                              │ │ │   ├── is-negative-zero@2.0.2
                              │ │ │   ├─┬ is-regex@1.1.4
                              │ │ │   │ └─┬ has-tostringtag@1.0.0
                              │ │ │   ├── is-shared-array-buffer@1.0.1
                              │ │ │   ├─┬ is-string@1.0.7
                              │ │ │   ├─┬ is-weakref@1.0.2
                              │ │ │   │ └── call-bind@1.0.2 deduped
                              │ │ │   ├── object-inspect@1.12.0
                              │ │ │   ├── object-keys@1.1.1 deduped
                              │ │ │   ├─┬ object.assign@4.1.2
                              │ │ │   │ ├── define-properties@1.1.3 deduped
                              │ │ │   │ ├── has-symbols@1.0.2 deduped
                              │ │ │   │ └── object-keys@1.1.1 deduped
                              │ │ │   ├─┬ string.prototype.trimend@1.0.4
                              │ │ │   │ └── define-properties@1.1.3 deduped
                              │ │ │   ├─┬ string.prototype.trimstart@1.0.4
                              │ │ │   └─┬ unbox-primitive@1.0.1
                              │ │ │     ├── has-bigints@1.0.1
                              │ │ │     └─┬ which-boxed-primitive@1.0.2
                              │ │ │       ├─┬ is-bigint@1.0.4
                              │ │ │       │ └── has-bigints@1.0.1 deduped
                              │ │ │       ├─┬ is-boolean-object@1.1.2
                              │ │ │       ├─┬ is-number-object@1.0.6
                              │ │ │       ├── is-string@1.0.7 deduped
                              │ │ │       └── is-symbol@1.0.4 deduped
                              │ │ ├─┬ bl@1.2.3
                              │ │ ├── bluebird@3.7.2 deduped
                              │ │ ├─┬ debug@3.2.7
                              │ │ │ └── ms@2.1.3
                              │ │ ├── depd@1.1.2 deduped
                              │ │ ├── eventemitter3@3.1.2
                              │ │ ├── file-type@3.9.0
                              │ │ ├── mime@1.6.0
                              │ │ ├─┬ pump@2.0.1
                              │ │ └─┬ request-promise@4.2.6
                              │ │   ├─┬ request-promise-core@1.1.4
                              │ │   ├── stealthy-require@1.1.1 deduped
                              │ └─┬ socksv5@0.0.6
                              │   └─┬ ipv6@3.1.1
                              │     ├─┬ cli@0.4.5
                              │     ├─┬ cliff@0.1.10
                              │     │ ├── eyes@0.1.8 deduped
                              │     │ └─┬ winston@0.8.3
                              │     │   ├── async@0.2.10
                              │     │   ├── colors@0.6.2
                              │     │   ├── cycle@1.0.3 deduped
                              │     │   ├── pkginfo@0.3.1
                              │     └── sprintf@0.1.3
                              ├─┬ iobroker.terminal@0.1.2
                              │ ├─┬ UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
                              │ ├── body-parser@1.19.2 deduped
                              │ ├── commander@5.1.0
                              │ ├─┬ connect@3.7.0
                              │ │ ├── debug@2.6.9 deduped
                              │ │ ├── finalhandler@1.1.2 deduped
                              │ │ ├── parseurl@1.3.3 deduped
                              │ │ └── utils-merge@1.0.1 deduped
                              │ ├── connect-flash@0.1.1 deduped
                              │ ├── express@4.17.3 deduped
                              │ ├── nan@2.15.0
                              │ ├─┬ passport@0.2.2
                              │ │ ├── passport-strategy@1.0.0 deduped
                              │ │ └── pause@0.0.1 deduped
                              │ ├── passport-local@1.0.0 deduped
                              │ ├─┬ send@0.17.2
                              │ │ ├── destroy@1.0.4
                              │ │ ├── encodeurl@1.0.2 deduped
                              │ │ ├── escape-html@1.0.3 deduped
                              │ │ ├── etag@1.8.1 deduped
                              │ │ ├── fresh@0.5.2 deduped
                              │ │ ├── http-errors@1.8.1 deduped
                              │ │ ├── mime@1.6.0 deduped
                              │ │ ├── ms@2.1.3
                              │ │ ├── on-finished@2.3.0 deduped
                              │ │ ├── range-parser@1.2.1 deduped
                              │ │ └── statuses@1.5.0 deduped
                              │ ├── socket.io@1.7.2 deduped
                              │ ├── uid-number@0.0.6
                              │ └── xtend@4.0.2
                              ├─┬ iobroker.text2command@2.1.1
                              ├─┬ iobroker.tr-064@4.2.15
                              ├─┬ iobroker.upnp@1.0.19
                              │ ├── ip@1.1.5
                              │ ├── node-ssdp@4.0.1 deduped
                              │ ├─┬ parsexmlresponse@0.0.5
                              │ ├─┬ portfinder@1.0.28
                              │ │ ├── async@2.6.3 deduped
                              │ │ ├─┬ debug@3.2.7
                              │ │ │ └── ms@2.1.3
                              │ │ └─┬ mkdirp@0.5.5
                              │ └── xmldom@0.6.0
                              ├─┬ iobroker.vis@1.4.5
                              │ └── jsonwebtoken@8.5.1 deduped
                              ├── iobroker.vis-bars@0.1.4
                              ├─┬ iobroker.vis-colorpicker@1.2.0
                              ├── iobroker.vis-fancyswitch@1.1.0
                              ├─┬ iobroker.vis-google-fonts@1.0.3
                              ├── iobroker.vis-hqwidgets@1.1.9
                              ├── iobroker.vis-jqui-mfd@1.0.12
                              ├── iobroker.vis-metro@1.1.2
                              ├─┬ iobroker.vis-players@0.1.6
                              │ └── @iobroker/adapter-core@1.0.3 deduped
                              ├─┬ iobroker.vis-plumb@1.0.2
                              ├── iobroker.vis-timeandweather@1.1.7
                              ├── iobroker.vis-weather@2.5.5
                              ├─┬ iobroker.web@3.4.16
                              │ ├── iobroker.simple-api@2.6.2 deduped
                              │ ├── iobroker.socketio@3.1.5 deduped
                              │ ├─┬ mime-types@2.1.34
                              │ │ └── mime-db@1.51.0
                              │ ├── passport@0.5.2 deduped
                              │ ├── passport.socketio@3.7.0 deduped
                              │ │ ├─┬ debug@3.1.0
                              │ │ │ └── ms@2.0.0 deduped
                              │ │ │ ├─┬ engine.io-parser@2.2.1
                              │ │ │ │ ├── after@0.8.2 deduped
                              │ │ │ │ ├── arraybuffer.slice@0.0.7
                              │ │ │ │ ├── base64-arraybuffer@0.1.4
                              │ │ │ │ ├── blob@0.0.5
                              │ │ │ │ └── has-binary2@1.0.3 deduped
                              │ │ │ ├── ws@7.4.6
                              ├─┬ UNMET DEPENDENCY iobroker.zigbee@1.6.16
                              │ ├── tar@6.1.11 deduped
                              │ ├── UNMET DEPENDENCY typescript@4.5.4
                              │ ├─┬ zigbee-herdsman@0.14.16
                              │ │ ├── debounce@1.2.1
                              │ │ ├─┬ debug@4.3.3
                              │ │ │ └── ms@2.1.2
                              │ │ ├── fast-deep-equal@3.1.3
                              │ │ ├── mixin-deep@2.0.1
                              │ │ ├─┬ mz@2.7.0
                              │ │ │ ├── any-promise@1.3.0
                              │ │ │ ├── object-assign@4.1.1
                              │ │ │ └─┬ thenify-all@1.6.0
                              │ │ │   └─┬ thenify@3.3.1
                              │ │ │     └── any-promise@1.3.0 deduped
                              │ │ ├─┬ serialport@9.2.8
                              │ │ │ ├─┬ @serialport/binding-mock@9.2.4
                              │ │ │ │ ├─┬ @serialport/binding-abstract@9.2.3
                              │ │ │ │ │ └── debug@4.3.3 deduped
                              │ │ │ ├─┬ @serialport/bindings@9.2.8
                              │ │ │ │ ├── @serialport/binding-abstract@9.2.3 deduped
                              │ │ │ │ ├── @serialport/parser-readline@9.2.4 deduped
                              │ │ │ │ ├─┬ bindings@1.5.0
                              │ │ │ │ │ └── file-uri-to-path@1.0.0
                              │ │ │ │ ├── nan@2.15.0
                              │ │ │ │ └─┬ prebuild-install@7.0.1
                              │ │ │ │   ├── detect-libc@2.0.0
                              │ │ │ │   ├── expand-template@2.0.3
                              │ │ │ │   ├── github-from-package@0.0.0
                              │ │ │ │   ├── mkdirp-classic@0.5.3
                              │ │ │ │   ├── napi-build-utils@1.0.2
                              │ │ │ │   ├─┬ node-abi@3.8.0
                              │ │ │ │   │ └─┬ semver@7.3.5
                              │ │ │ │   │   └─┬ lru-cache@6.0.0
                              │ │ │ │   │     └── yallist@4.0.0
                              │ │ │ │   ├─┬ npmlog@4.1.2
                              │ │ │ │   │ ├─┬ are-we-there-yet@1.1.7
                              │ │ │ │   │ │ ├── delegates@1.0.0
                              │ │ │ │   │ │ └─┬ readable-stream@2.3.7
                              │ │ │ │   │ │   ├── core-util-is@1.0.3
                              │ │ │ │   │ │   ├── inherits@2.0.4 deduped
                              │ │ │ │   │ │   ├── isarray@1.0.0
                              │ │ │ │   │ │   ├── process-nextick-args@2.0.1
                              │ │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
                              │ │ │ │   │ │   ├─┬ string_decoder@1.1.1
                              │ │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                              │ │ │ │   │ │   └── util-deprecate@1.0.2
                              │ │ │ │   │ ├─┬ gauge@2.7.4
                              │ │ │ │   │ │ ├── aproba@1.2.0
                              │ │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
                              │ │ │ │   │ │ ├── has-unicode@2.0.1
                              │ │ │ │   │ │ ├── object-assign@4.1.1 deduped
                              │ │ │ │   │ │ ├── signal-exit@3.0.7
                              │ │ │ │   │ │ ├─┬ string-width@1.0.2
                              │ │ │ │   │ │ │ ├── code-point-at@1.1.0
                              │ │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                              │ │ │ │   │ │ │ │ └── number-is-nan@1.0.1
                              │ │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                              │ │ │ │   │ │ ├─┬ strip-ansi@3.0.1
                              │ │ │ │   │ │ │ └── ansi-regex@2.1.1
                              │ │ │ │   │ │ └─┬ wide-align@1.1.5
                              │ │ │ │   │ │   └── string-width@1.0.2 deduped
                              │ │ │ │   │ └── set-blocking@2.0.0
                              │ │ │ │   ├─┬ pump@3.0.0
                              │ │ │ │   │ ├─┬ end-of-stream@1.4.4
                              │ │ │ │   │ │ └── once@1.4.0 deduped
                              │ │ │ │   │ └─┬ once@1.4.0
                              │ │ │ │   ├─┬ rc@1.2.8
                              │ │ │ │   │ ├── deep-extend@0.6.0
                              │ │ │ │   │ ├── ini@1.3.8
                              │ │ │ │   │ ├── minimist@1.2.5 deduped
                              │ │ │ │   │ └── strip-json-comments@2.0.1
                              │ │ │ │   ├─┬ simple-get@4.0.1
                              │ │ │ │   │ ├─┬ decompress-response@6.0.0
                              │ │ │ │   │ │ └── mimic-response@3.1.0
                              │ │ │ │   │ └── simple-concat@1.0.1
                              │ │ │ │   ├─┬ tar-fs@2.1.1
                              │ │ │ │   │ ├── chownr@1.1.4
                              │ │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
                              │ │ │ │   │ ├── pump@3.0.0 deduped
                              │ │ │ │   │ └─┬ tar-stream@2.2.0
                              │ │ │ │   │   ├─┬ bl@4.1.0
                              │ │ │ │   │   │ ├─┬ buffer@5.7.1
                              │ │ │ │   │   │ │ ├── base64-js@1.5.1
                              │ │ │ │   │   │ │ └── ieee754@1.2.1
                              │ │ │ │   │   │ └─┬ readable-stream@3.6.0
                              │ │ │ │   │   │   ├── string_decoder@1.1.1 deduped
                              │ │ │ │   │   │   └── util-deprecate@1.0.2 deduped
                              │ │ │ │   │   ├── fs-constants@1.0.0
                              │ │ │ │   └─┬ tunnel-agent@0.6.0
                              │ │ │ ├── @serialport/parser-byte-length@9.2.4
                              │ │ │ ├── @serialport/parser-cctalk@9.2.4
                              │ │ │ ├── @serialport/parser-delimiter@9.2.4
                              │ │ │ ├── @serialport/parser-inter-byte-timeout@9.2.4
                              │ │ │ ├─┬ @serialport/parser-readline@9.2.4
                              │ │ │ │ └── @serialport/parser-delimiter@9.2.4 deduped
                              │ │ │ ├── @serialport/parser-ready@9.2.4
                              │ │ │ ├── @serialport/parser-regex@9.2.4
                              │ │ │ ├─┬ @serialport/stream@9.2.4
                              │ │ └── slip@1.0.2
                              │ └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.422
                              │   ├─┬ UNMET DEPENDENCY axios@0.25.0
                              │   │ └── UNMET DEPENDENCY follow-redirects@1.14.8
                              │   ├── UNMET DEPENDENCY buffer-crc32@0.2.13
                              │   ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
                              │   │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
                              │   │ │ └── UNMET DEPENDENCY debug@4.3.3
                              │   │ └─┬ UNMET DEPENDENCY debug@4.3.3
                              │   │   └── UNMET DEPENDENCY ms@2.1.2
                              │   ├─┬ UNMET DEPENDENCY tar-stream@2.2.0
                              │   │ ├─┬ UNMET DEPENDENCY bl@4.1.0
                              │   │ │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                              │   │ │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                              │   │ │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                              │   │ │ ├── UNMET DEPENDENCY inherits@2.0.4
                              │   │ │ └── UNMET DEPENDENCY readable-stream@3.6.0
                              │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                              │   │ │ └─┬ UNMET DEPENDENCY once@1.4.0
                              │   │ │   └── UNMET DEPENDENCY wrappy@1.0.2
                              │   │ ├── UNMET DEPENDENCY fs-constants@1.0.0
                              │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                              │   │   ├─┬ UNMET DEPENDENCY string_decoder@1.3.0
                              │   │   │ └── UNMET DEPENDENCY safe-buffer@5.2.1
                              │   │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                              │   └─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.14
                              │     ├── UNMET DEPENDENCY debounce@1.2.1
                              │     ├─┬ UNMET DEPENDENCY debug@4.3.3
                              │     ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
                              │     ├── UNMET DEPENDENCY mixin-deep@2.0.1
                              │     ├─┬ UNMET DEPENDENCY mz@2.7.0
                              │     │ ├── UNMET DEPENDENCY any-promise@1.3.0
                              │     │ ├── UNMET DEPENDENCY object-assign@4.1.1
                              │     │ └─┬ UNMET DEPENDENCY thenify-all@1.6.0
                              │     │   └─┬ UNMET DEPENDENCY thenify@3.3.1
                              │     │     └── UNMET DEPENDENCY any-promise@1.3.0
                              │     ├─┬ UNMET DEPENDENCY serialport@9.2.8
                              │     │ ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
                              │     │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                              │     │ │ │ └── UNMET DEPENDENCY debug@4.3.3
                              │     │ ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.8
                              │     │ │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                              │     │ │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                              │     │ │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
                              │     │ │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
                              │     │ │ ├── UNMET DEPENDENCY debug@4.3.3
                              │     │ │ ├── UNMET DEPENDENCY nan@2.15.0
                              │     │ │ └─┬ UNMET DEPENDENCY prebuild-install@7.0.1
                              │     │ │   ├── UNMET DEPENDENCY detect-libc@2.0.0
                              │     │ │   ├── UNMET DEPENDENCY expand-template@2.0.3
                              │     │ │   ├── UNMET DEPENDENCY github-from-package@0.0.0
                              │     │ │   ├── UNMET DEPENDENCY minimist@1.2.5
                              │     │ │   ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                              │     │ │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
                              │     │ │   ├─┬ UNMET DEPENDENCY node-abi@3.8.0
                              │     │ │   │ └─┬ UNMET DEPENDENCY semver@7.3.5
                              │     │ │   │   └─┬ UNMET DEPENDENCY lru-cache@6.0.0
                              │     │ │   │     └── UNMET DEPENDENCY yallist@4.0.0
                              │     │ │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
                              │     │ │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
                              │     │ │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
                              │     │ │   │ │ └─┬ UNMET DEPENDENCY readable-stream@2.3.7
                              │     │ │   │ │   ├── UNMET DEPENDENCY core-util-is@1.0.3
                              │     │ │   │ │   ├── UNMET DEPENDENCY inherits@2.0.4
                              │     │ │   │ │   ├── UNMET DEPENDENCY isarray@1.0.0
                              │     │ │   │ │   ├── UNMET DEPENDENCY process-nextick-args@2.0.1
                              │     │ │   │ │   ├── UNMET DEPENDENCY safe-buffer@5.1.2
                              │     │ │   │ │   ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
                              │     │ │   │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
                              │     │ │   │ │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                              │     │ │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                              │     │ │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
                              │     │ │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
                              │     │ │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                              │     │ │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
                              │     │ │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
                              │     │ │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.7
                              │     │ │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
                              │     │ │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
                              │     │ │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
                              │     │ │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
                              │     │ │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
                              │     │ │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
                              │     │ │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
                              │     │ │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
                              │     │ │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
                              │     │ │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
                              │     │ │   ├─┬ UNMET DEPENDENCY pump@3.0.0
                              │     │ │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                              │     │ │   │ │ └── UNMET DEPENDENCY once@1.4.0
                              │     │ │   │ └─┬ UNMET DEPENDENCY once@1.4.0
                              │     │ │   │   └── UNMET DEPENDENCY wrappy@1.0.2
                              │     │ │   ├─┬ UNMET DEPENDENCY rc@1.2.8
                              │     │ │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
                              │     │ │   │ ├── UNMET DEPENDENCY ini@1.3.8
                              │     │ │   │ ├── UNMET DEPENDENCY minimist@1.2.5
                              │     │ │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
                              │     │ │   ├─┬ UNMET DEPENDENCY simple-get@4.0.1
                              │     │ │   │ ├─┬ UNMET DEPENDENCY decompress-response@6.0.0
                              │     │ │   │ │ └── UNMET DEPENDENCY mimic-response@3.1.0
                              │     │ │   │ ├── UNMET DEPENDENCY once@1.4.0
                              │     │ │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
                              │     │ │   ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
                              │     │ │   │ ├── UNMET DEPENDENCY chownr@1.1.4
                              │     │ │   │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                              │     │ │   │ ├── UNMET DEPENDENCY pump@3.0.0
                              │     │ │   │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
                              │     │ │   │   ├─┬ UNMET DEPENDENCY bl@4.1.0
                              │     │ │   │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                              │     │ │   │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                              │     │ │   │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                              │     │ │   │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                              │     │ │   │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
                              │     │ │   │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
                              │     │ │   │   ├── UNMET DEPENDENCY fs-constants@1.0.0
                              │     │ │   └─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
                              │     │ ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
                              │     │ ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
                              │     │ ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                              │     │ ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
                              │     │ ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                              │     │ │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                              │     │ ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
                              │     │ ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
                              │     │ ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
                              │     └── UNMET DEPENDENCY slip@1.0.2
                              ├── semver@5.7.1
                              └─┬ yargs@7.1.0
                                ├── camelcase@3.0.0
                                ├─┬ cliui@3.2.0
                                ├─┬ os-locale@1.4.0
                                │ └─┬ lcid@1.0.0
                                ├─┬ read-pkg-up@1.0.1
                                │ ├─┬ find-up@1.1.2
                                │ │ ├─┬ path-exists@2.1.0
                                │ │ │ └── pinkie-promise@2.0.1 deduped
                                │ │ └─┬ pinkie-promise@2.0.1
                                │ │   └── pinkie@2.0.4
                                │ └─┬ read-pkg@1.1.0
                                │   ├─┬ load-json-file@1.1.0
                                │   │ ├─┬ parse-json@2.2.0
                                │   │ │ └─┬ error-ex@1.3.2
                                │   │ │   └── is-arrayish@0.2.1
                                │   │ ├── pify@2.3.0
                                │   │ ├── pinkie-promise@2.0.1 deduped
                                │   │ └─┬ strip-bom@2.0.0
                                │   │   └── is-utf8@0.2.1
                                │   ├─┬ normalize-package-data@2.5.0
                                │   │ ├── hosted-git-info@2.8.8
                                │   │ ├─┬ resolve@1.17.0
                                │   │ │ └── path-parse@1.0.6
                                │   │ └─┬ validate-npm-package-license@3.0.4
                                │   │   ├─┬ spdx-correct@3.1.0
                                │   │   │ ├── spdx-expression-parse@3.0.0 deduped
                                │   │   │ └── spdx-license-ids@3.0.5
                                │   │   └─┬ spdx-expression-parse@3.0.0
                                │   │     ├── spdx-exceptions@2.3.0
                                │   │     └── spdx-license-ids@3.0.5 deduped
                                │   └─┬ path-type@1.1.0
                                │     ├── pify@2.3.0 deduped
                                ├── require-main-filename@1.0.1
                                ├── set-blocking@2.0.0
                                ├── which-module@1.0.0
                                ├── y18n@3.2.1
                                └─┬ yargs-parser@5.0.0
                                  └── camelcase@3.0.0 deduped
                              npm ERR! missing: tr-O64@0.2.4, required by iobroker.inst@2.0.3
                              npm ERR! missing: iobroker.hue@3.5.31, required by iobroker.inst@2.0.3
                              npm ERR! missing: iobroker.zigbee@1.6.16, required by iobroker.inst@2.0.3
                              npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
                              npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.hue@3.5.31
                              npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.1
                              npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.zigbee@1.6.16
                              npm ERR! missing: typescript@4.5.4, required by iobroker.zigbee@1.6.16
                              npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigbee@1.6.16
                              npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
                              npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14.0.422
                              npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converters@14.0.422
                              npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.422
                              npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converters@14.0.422
                              npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
                              npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
                              npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
                              npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
                              npm ERR! missing: ms@2.1.2, required by debug@4.3.3
                              npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
                              npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
                              npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
                              npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
                              npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
                              npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
                              npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
                              npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
                              npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
                              npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
                              npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
                              npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
                              npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
                              npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
                              npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
                              npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
                              npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
                              npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
                              npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
                              npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
                              npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
                              npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
                              npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
                              npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
                              npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/binding-mock@9.2.4
                              npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
                              npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
                              npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bindings@9.2.8
                              npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bindings@9.2.8
                              npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
                              npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
                              npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
                              npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
                              npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
                              npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
                              npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
                              npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
                              npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
                              npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
                              npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
                              npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
                              npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
                              npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
                              npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
                              npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
                              npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
                              npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
                              npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
                              npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
                              npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
                              npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
                              npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
                              npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
                              npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
                              npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
                              npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
                              npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
                              npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
                              npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
                              npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
                              npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
                              npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
                              npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
                              npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
                              npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
                              npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
                              npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
                              npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
                              npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
                              npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
                              npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
                              npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
                              npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
                              npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
                              npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
                              npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
                              npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
                              npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
                              npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
                              npm ERR! missing: once@1.4.0, required by pump@3.0.0
                              npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
                              npm ERR! missing: ini@1.3.8, required by rc@1.2.8
                              npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
                              npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
                              npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
                              npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
                              npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
                              npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
                              npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
                              npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
                              npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
                              npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
                              npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
                              npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
                              npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/parser-readline@9.2.4
                              npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
                                M
                                M
                                Markus Faltermeier
                                #77
                                wieso npm v8?
                                Ich dachte ich habe v6 drauf. Das zeigt mir zumindest "npm -v" an
                                  wieso npm v8?
                                  #78
                                  @markus-faltermeier sagte in Probleme bei Update von admin:
                                  wieso npm v8?
                                  und vorher war kein npm >6 drauf?
                                    wieso npm v8?
                                    M
                                    M
                                    Markus Faltermeier
                                    #79
                                    vorher hatte ich v7 drauf. Das haben wir aber ganz am anfang geändert. Da hatte ich den node js auf V14 upgedated und der npm war danach auf V6.14.16
                                      #80
                                      und npm v7 war ja nicht untätig. Damit wurde die package-lock.json in version2 geschrieben.
                                      npm v6 braucht diese aber in v1
                                      hab dir extra nochmal die Meldung aus dem Log zitiert
                                      Lösch die package-lock.json. Die wird dann beim nächsten Aufruf von npm in der richtigen Version neu angelegt.
                                        M
                                        M
                                        Markus Faltermeier
                                        #81
                                        bevor ich das jetzt falsch mache.
                                        das geht doch so oder:
                                        ins Verzeichnis /opt/iobroker wechseln und dann einfach
                                        "rm package-lock.json"
                                        Stimmt das?
                                          Stimmt das?
                                          #82
                                          Stimmt das?
                                          Weiß ich nicht!
                                          kann dir jetzt nicht sagen wo die Datei liegt
                                          84.1k
