  4. [gelöst] Probleme bei Update von admin
    1.5k
    1.5k
admin-adapterehostunreachfehlermeldungupdateupdate adapter
85 Beiträge 6 Kommentatoren 13.9k Aufrufe 3 Beobachtet
  • M Markus Faltermeier
    ich kann den nicht löschen. da bekomme ich die gleichen Fehlermeldungen wie beim updaten:
    $ iobroker del terminal
    Delete adapter "terminal"
    host.raspberrypi object terminal deleted
    host.raspberrypi object terminal.admin deleted
    npm uninstall iobroker.terminal --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ENOENTnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-streamnpm ERR! errno -2
    npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/readable-stream'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-11T13_22_31_721Z-debug.log
    Error deleting adapter terminal from disk: Error: host.raspberrypi: Cannot uninstall iobroker.terminal: 254
    You might have to delete it yourself!
    Process exited with code 0
    #68
    @markus-faltermeier sagte in Probleme bei Update von admin:
    dann mach das
      @markus-faltermeier
      Editiere /opt/iobroker/node_modules/canvas/package.json:
      Suche nach der "scripts" sektion und dort "install"
      Das install kommando ist
      node-pre-gyp install --fallback-to-build
      hänge mal noch
      --update-binary
      dran.
      Also
      node-pre-gyp install --fallback-to-build --update-binary
      M
      M
      Markus Faltermeier
      #69
      Hi ich habe jetzt alles durchsucht. Aber ich habe kein Verzeichnis "Canvas"
      pi@raspberrypi:/opt/iobroker/node_modules $ ls
      abab                        har-schema                             object-hash
      abort-controller            har-validator                          object-inspect
      accepts                     has                                    object-keys
      acme-http-01-standalone     has-bigints                            once
      acorn                       has-binary                             one-time
      acorn-globals               has-binary2                            on-finished
      acorn-walk                  has-cors                               on-headers
      after                       has-symbols                            optionator
      agent-base                  has-tostringtag                        options
      ajv                         has-unicode                            ordered-read-streams
      @alcalzone                  hawk                                   os-locale
      alcalzone-shared            he                                     ospath
      alexa-cookie2               help-me                                otplib
      alexa-remote2               hoek                                   owlintuition
      ansi-regex                  homematic-xmlrpc                       pako
      ansi-styles                 hosted-git-info                        parse5
      anymatch                    hot-patcher                            parse-json
      @apollon                    html-encoding-sniffer                  parsejson
      aproba                      http-errors                            parseqs
      are-we-there-yet            http-proxy                             parseuri
      argparse                    http-proxy-agent                       parseurl
      arraybuffer.slice           http-proxy-middleware                  parsexmlresponse
      array-ext                   http-proxy-response-rewrite            passport
      array-flatten               https                                  passport-local
      array.prototype.findindex   http-signature                         passport.socketio
      arrify                      https-proxy-agent                      passport-strategy
      asap                        iconv-lite                             path-dirname
      asn1                        ieee754                                path-exists
      asn1-ber                    immediate                              path-is-absolute
      assert-plus                 indexof                                path-parse
      async                       inflight                               path-posix
      asynckit                    inherits                               path-to-regexp
      async-limiter               ini                                    path-type
      async-retry                 internal-slot                          pause
      at-least-node               invert-kv                              pause-stream
      autobind-decorator          @iobroker                              performance-now
      aws4                        iobroker                               picocolors
      aws-iot-device-sdk          iobroker.admin                         picomatch
      aws-sign2                   iobroker.alexa2                        pidusage
      axios                       iobroker.backitup                      pify
      backo2                      iobroker.cloud                         ping
      balanced-match              iobroker.daswetter                     pinkie
      base-64                     iobroker.deconz                        pinkie-promise
      base64-arraybuffer          iobroker.denon                         pluralize
      base64id                    iobroker.discovery                     p-map
      base64-js                   iobroker.dwd                           portfinder
      bcrypt-pbkdf                iobroker.email                         prelude-ls
      bent                        iobroker.fhem                          process-nextick-args
      better-assert               iobroker.flot                          promise
      bignumber.js                iobroker.fritzbox                      promisify-child-process
      binary                      iobroker.geofency                      prompt
      binary-extensions           iobroker.harmony                       proper-lockfile
      bindings                    iobroker.heatingcontrol                proxy-addr
      binrpc                      iobroker.history                       psl
      bl                          iobroker.hm-rega                       pump
      blob                        iobroker.hm-rpc                        pumpify
      bluebird                    iobroker.hue                           punycode
      body-parser                 iobroker.ical                          pushover-notifications
      boom                        iobroker.icons-icons8                  put
      bottleneck                  iobroker.icons-mfd-svg                 q
      brace-expansion             iobroker.icons-ultimate-png            qs
      braces                      iobroker.info                          querystring
      browser-process-hrtime      iobroker.iot                           querystringify
      buffer                      iobroker.javascript                    random-bytes
      buffer-equal-constant-time  iobroker.js-controller                 range-parser
      buffer-from                 iobroker.lightify                      rasha
      bufferhelper                iobroker.mihome                        raw-body
      buffers                     iobroker.mihome-vacuum                 rc
      busboy                      iobroker.mobile                        read
      button-events               iobroker.mqtt                          readable-stream
      bytes                       iobroker.mqtt-client                   readdirp
      bytesish                    iobroker.nut                           readline-sync
      callback-stream             iobroker.octoprint                     read-pkg
      call-bind                   iobroker.ping                          read-pkg-up
      callsite                    iobroker.pushover                      redirect-https
      camelcase                   iobroker.rpi2                          redis-commands
      capitalize                  iobroker.scenes                        redis-errors
      caseless                    iobroker.shelly                        redis-parser
      cert-info                   iobroker.simple-api                    reinterval
      chainsaw                    iobroker.snmp                          remove-trailing-separator
      charenc                     iobroker.socketio                      request
      chokidar                    iobroker.sonoff                        request-promise
      chownr                      iobroker.spotify-premium               request-promise-core
      ci-info                     iobroker.statistics                    request-promise-native
      cli                         iobroker.synology                      require-directory
      cliff                       iobroker.tankerkoenig                  require-main-filename
      cliui                       iobroker.telegram                      requires-port
      cloneextend                 iobroker.terminal                      resolve
      cluster-key-slot            iobroker.text2command                  respjs
      co                          iobroker.tr-064                        retry
      coap                        iobroker.type-detector                 revalidator
      coap-packet                 iobroker.upnp                          rfdc
      code-point-at               iobroker.vis                           @root
      coffee-compiler             iobroker.vis-bars                      rpi-gpio
      coffee-script               iobroker.vis-colorpicker               rpi-gpio-buttons
      coiot-coap                  iobroker.vis-fancyswitch               rrule
      color                       iobroker.vis-google-fonts              safe-buffer
      color-convert               iobroker.vis-hqwidgets                 safer-buffer
      color-name                  iobroker.vis-jqui-mfd                  safe-replace
      @colors                     iobroker.vis-metro                     safe-stable-stringify
      colors                      iobroker.vis-players                   sax
      colorspace                  iobroker.vis-plumb                     saxes
      color-string                iobroker.vis-timeandweather            secure-keys
      combined-stream             iobroker.vis-weather                   semaphore
      commander                   iobroker.web                           semver
      commist                     ioredis                                send
      component-bind              ip                                     @sentry
      component-emitter           ipaddr.js                              seq-logging
      component-inherit           is                                     @serialport
      concat-map                  is-absolute                            serialport
      concat-stream               isarray                                serve-static
      connect                     is-arrayish                            set-blocking
      connect-flash               is-bigint                              set-immediate-shim
      console-control-strings     is-binary-path                         setprototypeof
      content-disposition         is-boolean-object                      shelly-iot
      content-type                is-callable                            side-channel
      cookie                      is-date-object                         signal-exit
      cookie-parser               isemail                                simple-concat
      cookie-signature            is-extglob                             simple-get
      core-util-is                is-fullwidth-code-point                simple-swizzle
      cron                        is-glob                                sntp
      cron-parser                 is-nan                                 socket.io
      crypt                       is-negated-glob                        socket.io-adapter
      cryptiles                   is-negative-zero                       socket.io-client
      crypto-js                   is-number                              socket.io-parser
      cssom                       is-number-object                       socksv5
      cssstyle                    is-plain-obj                           soef
      cycle                       is-potential-custom-element-name       sorted-array-functions
      d                           is-regex                               source-map
      @dabh                       is-relative                            source-map-support
      daemonize2                  is-shared-array-buffer                 spdx-correct
      dashdash                    is-stream                              spdx-exceptions
      data-urls                   isstream                               spdx-expression-parse
      debug                       is-string                              spdx-license-ids
      decache                     is-symbol                              split
      decamelize                  is-typedarray                          split2
      decimal.js                  is-unc-path                            sprintf-js
      decompress-response         is-utf8                                sshpk
      deep-clone                  is-weakref                             stack-trace
      deep-extend                 is-windows                             standard-as-callback
      deep-is                     joi                                    statuses
      define-properties           jsbn                                   stealthy-require
      delayed-stream              jsdom                                  stream-combiner
      delegates                   jshashes                               streamsearch
      denque                      json3                                  stream-shift
      depd                        jsonata                                string_decoder
      destroy                     json-bigint                            string.prototype.trimend
      detect-libc                 jsonc-parser                           string.prototype.trimstart
      dgram                       jsonfile                               stringstream
      dicer                       json-schema                            string-width
      diskusage                   json-schema-traverse                   strip-ansi
      dns-packet                  json-stable-stringify-without-jsonify  strip-bom
      domexception                json-stringify-safe                    strip-json-comments
      dropbox-v2-api              jsonwebtoken                           strnum
      duplexer                    jsprim                                 suncalc2
      duplexify                   js-sdsl                                symbol-tree
      ecc-jsbn                    js-yaml                                sync-exec
      ecdsa-sig-formatter         jszip                                  syno
      echarts                     jwa                                    systeminformation
      eckles                      jws                                    tar
      ee-first                    keypairs                               tar-fs
      emoji-regex                 kuler                                  tar-stream
      enabled                     layerr                                 tcp-ping
      encodeurl                   lcid                                   text-hex
      end-of-stream               le-acme-core                           thirty-two
      engine.io                   le-challenge-fs                        through
      engine.io-client            le-sni-auto                            through2
      engine.io-parser            leven                                  through2-filter
      epoll                       levn                                   to-absolute-glob
      error-ex                    lie                                    to-array
      es5-ext                     loadavg-windows                        toidentifier
      es6-iterator                load-json-file                         @tootallnate
      es6-map                     localforage                            topo
      es6-promise                 lodash                                 to-regex-range
      es6-set                     lodash.defaults                        tough-cookie
      es6-symbol                  lodash.flatten                         tr46
      es-abstract                 lodash.includes                        traverse
      esbuild                     lodash.isarguments                     triple-beam
      escalade                    lodash.isboolean                       tslib
      escape-html                 lodash.isinteger                       tunnel-agent
      escodegen                   lodash.isnumber                        tweetnacl
      esprima                     lodash.isplainobject                   type
      es-to-primitive             lodash.isstring                        type-check
      estraverse                  lodash.once                            typedarray
      esutils                     logform                                type-is
      etag                        long-timeout                           @types
      event-emitter               lru-cache                              typescript
      eventemitter3               lru_map                                uid-number
      event-stream                luxon                                  uid-safe
      event-target-shim           map-stream                             ultron
      expand-template             md5                                    unbox-primitive
      express                     mdns-discovery                         unc-path-regex
      express-fileupload          media-typer                            underscore
      express-session             merge-descriptors                      unique-stream
      ext                         methods                                universalify
      extend                      micromatch                             unpipe
      extsprintf                  mime                                   uri-js
      eyes                        mime-db                                url-join
      fast-deep-equal             mime-types                             url-parse
      fast-json-stable-stringify  mimic-response                         url-template
      fast-levenshtein            minimatch                              ursa-optional
      fastseries                  minimist                               util-deprecate
      fast-text-encoding          minipass                               utils-merge
      fast-xml-parser             minizlib                               uuid
      fecha                       mkdirp                                 validate-npm-package-license
      file-stream-rotator         mkdirp-classic                         vary
      file-type                   moment                                 verror
      file-uri-to-path            moment-timezone                        virtual-tsc
      fill-range                  mqtt                                   vm2
      finalhandler                mqtt-connection                        w3c-hr-time
      find-up                     mqtt-packet                            w3c-xmlserializer
      fn.name                     ms                                     wake_on_lan
      follow-redirects            mute-stream                            weak-daemon
      forever-agent               nan                                    webdav
      form-data                   napi-build-utils                       webidl-conversions
      forwarded                   nconf                                  websocket-stream
      fresh                       ncp                                    whatwg-encoding
      from                        nearest-color                          whatwg-mimetype
      fs-constants                negotiator                             whatwg-url
      fs-extra                    nested-property                        which-boxed-primitive
      fs-minipass                 netmask                                which-module
      fs.realpath                 net-snmp                               wide-align
      ftp                         next-tick                              window-size
      function-bind               node-dht-sensor                        winston
      gauge                       node-expat                             winston-daily-rotate-file
      gaxios                      node.extend                            winston-seq-updated
      gcp-metadata                node-fetch                             winston-syslog
      get-caller-file             node-forge                             winston-transport
      get-intrinsic               node-hue-api                           word-wrap
      getpass                     node-ical                              wrap-ansi
      get-ssl-certificate         node-inspect                           wrappy
      get-symbol-description      nodemailer                             ws
      github-from-package         node-mndp                              wtf-8
      glob                        node-nut                               xml2js
      glob-parent                 node-rest-client                       xml2json
      glob-stream                 node-schedule                          xml2json-light
      glossy                      node-ssdp                              xmlbuilder
      @googleapis                 node-telegram-bot-api                  xmlchars
      googleapis-common           node-wol                               xmldom
      google-auth-library         normalize-package-data                 xmlhttprequest-ssl
      google-p12-pem              normalize-path                         xml-name-validator
      graceful-fs                 npmlog                                 xregexp
      @greenlock                  number-allocator                       xtend
      greenlock                   number-is-nan                          y18n
      greenlock-express           nwsapi                                 yallist
      greenlock-manager-fs        oauth                                  yargs
      greenlock-store-fs          oauth-sign                             yargs-parser
      gtoken                      object-assign                          yeast
      @harmonyhub                 object.assign                          zigbee-herdsman
      harmonyhubws                object-component                       zrender
      pi@raspberrypi:/opt/iobroker/node_modules $ cd /canvas
      -bash: cd: /canvas: Datei oder Verzeichnis nicht gefunden
      pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker/node_modules/canvas
      -bash: cd: /opt/iobroker/node_modules/canvas: Datei oder Verzeichnis nicht gefunden
        cron                        is-glob                                sntp
        eckles                      jws                                    tar
        fill-range                  mqtt                                   vm2
        Thomas BraunT
        Thomas BraunT
        #70
        @markus-faltermeier
        Komisch. Da sehe ich eigentlich entsprechende Meldungen in deinem Log die auf canvas hindeuten würden.
        cd /opt/iobroker
        npm ls canvas
        M 2 Antworten Letzte Antwort
          @markus-faltermeier
          cd /opt/iobroker
          npm ls canvas
          M
          M
          Markus Faltermeier
          #71
          @thomas-braun Hi,
          da bekomme ich diese Ausgabe
          pi@raspberrypi:/opt/iobroker $ npm ls canvas
          npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
          iobroker.inst@2.0.3 /opt/iobroker
          └─┬ iobroker.iot@1.8.24
            └── UNMET OPTIONAL DEPENDENCY canvas@2.9.0
            @thomas-braun Hi,
            Thomas BraunT
            Thomas BraunT
            #72
            @markus-faltermeier
            Da hängt schon mal eines deiner Probleme.
            npm ls
            bringt?
            HomoranH M 2 Antworten Letzte Antwort
              @markus-faltermeier
              cd /opt/iobroker
              npm ls canvas
              M
              M
              Markus Faltermeier
              #73
              Ich hab jetzt nochmal versucht nach dem anderen thread vorzugehen.
              mit "npm list" taucht der tr064 immer noch auf. Und ich krieg den nicht gelöscht
               semver@5.7.1
              ├── UNMET DEPENDENCY tr-O64@0.2.4
              └─┬ yargs@7.1.0
                ├── camelcase@3.0.0
                ├─┬ cliui@3.2.0
                │ ├── string-width@1.0.2 deduped
                │ ├─┬ strip-ansi@3.0.1
                │ │ └── ansi-regex@2.1.1
                │ └─┬ wrap-ansi@2.1.0
                │   └── strip-ansi@3.0.1 deduped
                ├── decamelize@1.2.0
                ├── get-caller-file@1.0.3
                ├─┬ os-locale@1.4.0
                │ └─┬ lcid@1.0.0
                │   └── invert-kv@1.0.0
              sieht zwar so aus, als ob er dann mit dem angegebenen Befehl:
              cd /opt/iobroker/node_modules/iobroker.tr-064
              npm uninstall tr-O64
              deinstalliert. Aber anschließend ist er immer noch da.
              ich bekomm da folgende Ausgabe:
              pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.tr-064
              pi@raspberrypi:/opt/iobroker/node_modules/iobroker.tr-064 $ npm uninstall tr-O64
              > es5-ext@0.10.57 postinstall /opt/iobroker/node_modules/iobroker.tr-064/node_modules/es5-ext
              > node -e "try{require('./_postinstall')}catch(e){}"
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              added 564 packages from 408 contributors and audited 570 packages in 29.66s
              43 packages are looking for funding
                run `npm fund` for details
              found 3 vulnerabilities (1 low, 2 high)
                run `npm audit fix` to fix them, or `npm audit` for details
                @markus-faltermeier
                npm ls
                bringt?
                #74
                @thomas-braun sagte in Probleme bei Update von admin:
                und das zweite ist die falsche Version von der package-lock.json wegen npm v8.
                  @markus-faltermeier
                  npm ls
                  bringt?
                  M
                  M
                  Markus Faltermeier
                  #75
                  │ │ │ ├── component-emitter@1.2.1
                  │ │ │ ├── component-inherit@0.0.3
                  │ │ │ ├─┬ debug@2.3.3
                  │ │ │ │ └── ms@0.7.2
                  │ │ │ ├── engine.io-parser@1.3.2 deduped
                  │ │ │ ├── has-cors@1.1.0
                  │ │ │ ├── indexof@0.0.1 deduped
                  │ │ │ ├─┬ parsejson@0.0.3
                  │ │ │ │ └── better-assert@1.0.2 deduped
                  │ │ │ ├─┬ parseqs@0.0.5
                  │ │ │ ├── parseuri@0.0.5 deduped
                  │ │ │ ├── ws@1.1.1 deduped
                  │ │ │ ├── xmlhttprequest-ssl@1.5.3
                  │ │ │ └── yeast@0.1.2
                  │ │ ├── has-binary@0.1.7 deduped
                  │ │ ├── object-component@0.0.3
                  │ │ ├─┬ parseuri@0.0.5
                  │ │ │ └─┬ better-assert@1.0.2
                  │ │ │   └── callsite@1.0.0 deduped
                  │ │ ├── socket.io-parser@2.3.1 deduped
                  │ │ └── to-array@0.1.4
                  │ └── ws@7.5.7
                  ├─┬ iobroker.daswetter@3.0.9
                  │ ├─┬ @iobroker/adapter-core@2.5.1
                  │ │ └─┬ @types/iobroker@3.3.4
                  │ │   └── @types/node@13.13.5 deduped
                  │ ├─┬ @sentry/node@6.14.1
                  │ │ ├─┬ @sentry/core@6.14.1
                  │ │ │ ├── @sentry/hub@6.14.1 deduped
                  │ │ │ ├─┬ @sentry/minimal@6.14.1
                  │ │ │ │ ├── @sentry/hub@6.14.1 deduped
                  │ │ │ │ ├── @sentry/types@6.14.1 deduped
                  │ │ │ │ └── tslib@1.11.2 deduped
                  │ │ │ ├── @sentry/utils@6.14.1 deduped
                  │ │ ├─┬ @sentry/hub@6.14.1
                  │ │ ├─┬ @sentry/tracing@6.14.1
                  │ │ │ ├─┬ @sentry/hub@6.14.1
                  │ │ │ │ ├── @sentry/utils@6.14.1 deduped
                  │ │ │ ├─┬ @sentry/utils@6.14.1
                  │ │ ├── cookie@0.4.1 deduped
                  │ │ ├── https-proxy-agent@5.0.0 deduped
                  │ │ ├── lru_map@0.3.3 deduped
                  │ ├─┬ bent@7.3.12
                  │ │ ├── bytesish@0.4.4
                  │ │ ├── caseless@0.12.0 deduped
                  │ │ └── is-stream@2.0.1
                  │ └── xml2json-light@1.0.6
                  ├─┬ iobroker.deconz@1.3.19
                  │ ├── @sentry/integrations@6.16.1 deduped
                  │ ├── @sentry/node@6.16.1 deduped
                  │ ├── request@2.88.2 deduped
                  │ ├── source-map-support@0.5.21 deduped
                  │ └── ws@7.5.6
                  ├─┬ iobroker.denon@1.12.1
                  │ └─┬ @iobroker/adapter-core@2.5.1
                  ├─┬ iobroker.discovery@2.7.3
                  │ ├─┬ mdns-discovery@0.2.6
                  │ │ ├─┬ debug@2.2.0
                  │ │ │ └── ms@0.7.1
                  │ │ ├── dgram@1.0.1
                  │ │ └─┬ dns-packet@1.3.1
                  │ │   ├── ip@1.1.5 deduped
                  │ │   └── safe-buffer@5.1.2 deduped
                  │ ├── netmask@2.0.2
                  │ ├── node-mndp@0.0.3
                  │ ├─┬ node-ssdp@4.0.1
                  │ │ ├─┬ async@2.6.3
                  │ │ │ └── lodash@4.17.21 deduped
                  │ │ ├── bluebird@3.7.2
                  │ │ ├─┬ debug@3.2.7
                  │ │ │ └── ms@2.1.3
                  │ │ ├── extend@3.0.2 deduped
                  │ │ └── ip@1.1.5 deduped
                  │ └─┬ serialport@9.2.8
                  │   ├─┬ @serialport/binding-mock@9.2.4
                  │   │ ├─┬ @serialport/binding-abstract@9.2.3
                  │   │ │ └─┬ debug@4.3.3
                  │   │ │   └── ms@2.1.2
                  │   │ └─┬ debug@4.3.3
                  │   │   └── ms@2.1.2
                  │   ├─┬ UNMET OPTIONAL DEPENDENCY @serialport/bindings@9.2.8
                  │   │ ├── @serialport/binding-abstract@9.2.3 deduped
                  │   │ ├── @serialport/parser-readline@9.2.4 deduped
                  │   │ ├─┬ bindings@1.5.0
                  │   │ │ └── file-uri-to-path@1.0.0
                  │   │ ├─┬ UNMET OPTIONAL DEPENDENCY debug@4.3.3
                  │   │ │ └── UNMET OPTIONAL DEPENDENCY ms@2.1.2
                  │   │ ├── nan@2.15.0 deduped
                  │   │ └─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@7.0.1
                  │   │   ├── UNMET OPTIONAL DEPENDENCY detect-libc@2.0.1
                  │   │   ├── expand-template@2.0.3 deduped
                  │   │   ├── github-from-package@0.0.0 deduped
                  │   │   ├── minimist@1.2.5 deduped
                  │   │   ├── mkdirp-classic@0.5.3 deduped
                  │   │   ├── napi-build-utils@1.0.2 deduped
                  │   │   ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@3.8.0
                  │   │   │ └─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                  │   │   │   └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                  │   │   │     └── yallist@4.0.0 deduped
                  │   │   ├── npmlog@4.1.2 deduped
                  │   │   ├── pump@3.0.0 deduped
                  │   │   ├── rc@1.2.8 deduped
                  │   │   ├─┬ UNMET OPTIONAL DEPENDENCY simple-get@4.0.1
                  │   │   │ ├─┬ UNMET OPTIONAL DEPENDENCY decompress-response@6.0.0
                  │   │   │ │ └── UNMET OPTIONAL DEPENDENCY mimic-response@3.1.0
                  │   │   │ ├── once@1.4.0 deduped
                  │   │   │ └── simple-concat@1.0.0 deduped
                  │   │   ├── tar-fs@2.1.1 deduped
                  │   │   └── tunnel-agent@0.6.0 deduped
                  │   ├── @serialport/parser-byte-length@9.2.4
                  │   ├── @serialport/parser-cctalk@9.2.4
                  │   ├── @serialport/parser-delimiter@9.2.4
                  │   ├── @serialport/parser-inter-byte-timeout@9.2.4
                  │   ├─┬ @serialport/parser-readline@9.2.4
                  │   │ └── @serialport/parser-delimiter@9.2.4 deduped
                  │   ├── @serialport/parser-ready@9.2.4
                  │   ├── @serialport/parser-regex@9.2.4
                  │   ├─┬ @serialport/stream@9.2.4
                  │   │ └─┬ debug@4.3.3
                  │   │   └── ms@2.1.2
                  │   └─┬ debug@4.3.3
                  │     └── ms@2.1.2
                  ├─┬ iobroker.dwd@2.7.7
                  │ ├─┬ @iobroker/adapter-core@2.5.0
                  │ │ └─┬ @types/iobroker@3.3.0
                  │ └─┬ axios@0.21.4
                  │   └── follow-redirects@1.14.8 deduped
                  ├─┬ iobroker.email@1.0.10
                  │ └── nodemailer@6.7.2
                  ├─┬ iobroker.fhem@1.6.3
                  ├─┬ iobroker.flot@1.10.7
                  ├─┬ iobroker.fritzbox@0.2.1
                  │ └─┬ xml2js@0.4.23
                  │   ├── sax@1.2.4
                  │   └── xmlbuilder@11.0.1
                  ├─┬ iobroker.geofency@1.0.3
                  │ └── request@2.88.2 deduped
                  ├─┬ iobroker.harmony@1.2.2
                  │ ├─┬ @harmonyhub/discover@1.0.8
                  │ │ ├── autobind-decorator@2.4.0
                  │ │ └─┬ debug@4.1.1
                  │ │   └── ms@2.1.2
                  │ ├─┬ @iobroker/adapter-core@1.0.3
                  │ │ └─┬ @types/iobroker@1.4.13
                  │ ├─┬ harmonyhubws@1.0.6
                  │ │ ├── request@2.88.2 deduped
                  │ │ ├─┬ request-promise-native@1.0.8
                  │ │ │ ├─┬ request-promise-core@1.1.3
                  │ │ │ │ └── lodash@4.17.21 deduped
                  │ │ │ ├── stealthy-require@1.1.1
                  │ │ │ └── tough-cookie@2.5.0 deduped
                  │ │ ├── semver@5.7.1 deduped
                  │ │ └─┬ ws@6.2.1
                  │ │   └── async-limiter@1.0.1
                  │ └── semaphore@1.0.5
                  ├─┬ iobroker.heatingcontrol@2.7.2
                  │ │ ├── @sentry/tracing@6.14.1 deduped
                  │ └─┬ cron@1.8.2
                  │   └─┬ moment-timezone@0.5.34
                  │     └── moment@2.29.1 deduped
                  ├─┬ iobroker.history@1.10.5
                  ├─┬ iobroker.hm-rega@3.0.35
                  │ ├─┬ iconv-lite@0.6.3
                  │ │ └── safer-buffer@2.1.2
                  │ └── xml2js@0.4.23 deduped
                  ├─┬ iobroker.hm-rpc@1.15.0
                  │ ├─┬ binrpc@3.3.1
                  │ │ ├─┬ binary@0.3.0
                  │ │ │ ├── buffers@0.1.1
                  │ │ │ └─┬ chainsaw@0.1.0
                  │ │ │   └── traverse@0.3.9
                  │ │ └── put@0.0.6
                  │ └─┬ homematic-xmlrpc@1.0.2
                  │   ├── sax@0.4.3
                  │   └── xmlbuilder@0.4.2
                  ├─┬ UNMET DEPENDENCY iobroker.hue@3.5.31
                  │ ├─┬ UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
                  │ │ └─┬ UNMET DEPENDENCY @types/iobroker@3.3.4
                  │ └─┬ node-hue-api@4.0.11
                  │   ├── axios@0.21.4 deduped
                  │   ├── bottleneck@2.19.5
                  │   └── get-ssl-certificate@2.3.3
                  ├─┬ iobroker.ical@1.11.4
                  │ ├── cloneextend@0.0.3
                  │ ├─┬ node-ical@0.13.0
                  │ │ ├── moment-timezone@0.5.34 deduped
                  │ │ ├─┬ node-fetch@2.6.7
                  │ │ │ └─┬ whatwg-url@5.0.0
                  │ │ │   ├── tr46@0.0.3
                  │ │ │   └── webidl-conversions@3.0.1
                  │ │ ├── rrule@2.6.8 deduped
                  │ │ └── uuid@8.3.2
                  │ └─┬ rrule@2.6.8
                  │   ├── luxon@1.27.0
                  ├── iobroker.icons-icons8@0.0.1
                  ├── iobroker.icons-mfd-svg@1.0.2
                  ├── iobroker.icons-ultimate-png@1.0.1
                  ├─┬ iobroker.info@1.9.8
                  │ ├── jshashes@1.0.8
                  │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@1.0.7
                  │ ├─┬ semver@7.3.5
                  │ │ └─┬ lru-cache@6.0.0
                  │ └── systeminformation@5.11.3
                  ├─┬ iobroker.iot@1.8.24
                  │ ├─┬ aws-iot-device-sdk@2.2.11
                  │ │ ├── crypto-js@4.0.0
                  │ │ ├─┬ mqtt@4.2.8
                  │ │ │ ├── commist@1.1.0 deduped
                  │ │ │ ├─┬ concat-stream@2.0.0
                  │ │ │ │ ├── buffer-from@1.1.1 deduped
                  │ │ │ │ ├── inherits@2.0.4 deduped
                  │ │ │ │ ├── readable-stream@3.6.0 deduped
                  │ │ │ │ └── typedarray@0.0.6 deduped
                  │ │ │ ├─┬ debug@4.3.3
                  │ │ │ │ └── ms@2.1.2
                  │ │ │ ├─┬ duplexify@4.1.2
                  │ │ │ │ ├── end-of-stream@1.4.4 deduped
                  │ │ │ │ └── stream-shift@1.0.1 deduped
                  │ │ │ ├─┬ help-me@3.0.0
                  │ │ │ │ ├── glob@7.1.6 deduped
                  │ │ │ │ └── readable-stream@3.6.0 deduped
                  │ │ │ ├── minimist@1.2.5 deduped
                  │ │ │ ├─┬ mqtt-packet@6.10.0
                  │ │ │ │ ├── bl@4.1.0 deduped
                  │ │ │ │ ├── debug@4.3.3 deduped
                  │ │ │ │ └── process-nextick-args@2.0.1 deduped
                  │ │ │ ├── pump@3.0.0 deduped
                  │ │ │ ├─┬ readable-stream@3.6.0
                  │ │ │ │ ├── string_decoder@1.1.1 deduped
                  │ │ │ │ └── util-deprecate@1.0.2 deduped
                  │ │ │ ├── reinterval@1.1.0 deduped
                  │ │ │ ├─┬ split2@3.2.2
                  │ │ │ ├── ws@7.5.7
                  │ │ │ └── xtend@4.0.2 deduped
                  │ │ └── websocket-stream@5.5.2 deduped
                  │ ├─┬ UNMET OPTIONAL DEPENDENCY canvas@2.9.0
                  │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @mapbox/node-pre-gyp@1.0.8
                  │ │ │ ├── detect-libc@1.0.3 deduped
                  │ │ │ ├── https-proxy-agent@5.0.0 deduped
                  │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY make-dir@3.1.0
                  │ │ │ │ └── UNMET OPTIONAL DEPENDENCY semver@6.3.0
                  │ │ │ ├── node-fetch@2.6.7 deduped
                  │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY nopt@5.0.0
                  │ │ │ │ └── UNMET OPTIONAL DEPENDENCY abbrev@1.1.1
                  │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY npmlog@5.0.1
                  │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY are-we-there-yet@2.0.0
                  │ │ │ │ │ ├── delegates@1.0.0
                  │ │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY readable-stream@3.6.0
                  │ │ │ │ │   ├── inherits@2.0.4 deduped
                  │ │ │ │ │   ├── string_decoder@1.1.1 deduped
                  │ │ │ │ │   └── util-deprecate@1.0.2 deduped
                  │ │ │ │ ├── console-control-strings@1.1.0
                  │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY gauge@3.0.2
                  │ │ │ │ │ ├── aproba@1.2.0
                  │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY color-support@1.1.3
                  │ │ │ │ │ ├── console-control-strings@1.1.0 deduped
                  │ │ │ │ │ ├── has-unicode@2.0.1
                  │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY object-assign@4.1.1
                  │ │ │ │ │ ├── signal-exit@3.0.3 deduped
                  │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY string-width@4.2.3
                  │ │ │ │ │ │ ├── emoji-regex@8.0.0 deduped
                  │ │ │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY is-fullwidth-code-point@3.0.0
                  │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                  │ │ │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY strip-ansi@6.0.1
                  │ │ │ │ │ │ └── UNMET OPTIONAL DEPENDENCY ansi-regex@5.0.1
                  │ │ │ │ │ └─┬ wide-align@1.1.3
                  │ │ │ │ │   └── string-width@1.0.2 deduped
                  │ │ │ │ └── set-blocking@2.0.0 deduped
                  │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY rimraf@3.0.2
                  │ │ │ │ └── glob@7.1.6 deduped
                  │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY semver@7.3.5
                  │ │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY lru-cache@6.0.0
                  │ │ │ │   └── yallist@4.0.0 deduped
                  │ │ │ └── tar@6.1.11 deduped
                  │ │ └─┬ simple-get@3.1.0
                  │ │   ├─┬ decompress-response@4.2.1
                  │ │   │ └── mimic-response@2.1.0
                  │ ├─┬ echarts@4.9.0
                  │ │ └── zrender@4.3.2
                  │ ├── iobroker.type-detector@1.0.17
                  │ ├─┬ jsdom@17.0.0
                  │ │ ├── abab@2.0.5
                  │ │ ├── acorn@8.7.0
                  │ │ ├─┬ acorn-globals@6.0.0
                  │ │ │ ├── acorn@7.4.1
                  │ │ │ └── acorn-walk@7.2.0
                  │ │ ├── cssom@0.5.0
                  │ │ ├─┬ cssstyle@2.3.0
                  │ │ │ └── cssom@0.3.8
                  │ │ ├─┬ data-urls@3.0.1
                  │ │ │ ├── abab@2.0.5 deduped
                  │ │ │ ├── whatwg-mimetype@3.0.0
                  │ │ │ └─┬ whatwg-url@10.0.0
                  │ │ │   ├─┬ tr46@3.0.0
                  │ │ │   │ └── punycode@2.1.1 deduped
                  │ │ │   └── webidl-conversions@7.0.0
                  │ │ ├── decimal.js@10.3.1
                  │ │ ├─┬ domexception@2.0.1
                  │ │ │ └── webidl-conversions@5.0.0
                  │ │ ├─┬ escodegen@2.0.0
                  │ │ │ ├── esprima@4.0.1
                  │ │ │ ├── estraverse@5.3.0
                  │ │ │ ├── esutils@2.0.3
                  │ │ │ ├─┬ optionator@0.8.3
                  │ │ │ │ ├── deep-is@0.1.4
                  │ │ │ │ ├── fast-levenshtein@2.0.6
                  │ │ │ │ ├─┬ levn@0.3.0
                  │ │ │ │ │ ├── prelude-ls@1.1.2 deduped
                  │ │ │ │ │ └── type-check@0.3.2 deduped
                  │ │ │ │ ├─┬ type-check@0.3.2
                  │ │ │ │ │ └── prelude-ls@1.1.2 deduped
                  │ │ │ │ └── word-wrap@1.2.3
                  │ │ │ └── source-map@0.6.1 deduped
                  │ │ ├─┬ form-data@4.0.0
                  │ │ │ ├── asynckit@0.4.0 deduped
                  │ │ │ ├── combined-stream@1.0.8 deduped
                  │ │ │ └── mime-types@2.1.34 deduped
                  │ │ ├─┬ html-encoding-sniffer@2.0.1
                  │ │ │ └── whatwg-encoding@1.0.5 deduped
                  │ │ ├─┬ http-proxy-agent@4.0.1
                  │ │ │ ├── @tootallnate/once@1.1.2
                  │ │ │ ├── agent-base@6.0.2 deduped
                  │ │ │   └── ms@2.1.2
                  │ │ ├── is-potential-custom-element-name@1.0.1
                  │ │ ├── nwsapi@2.2.0
                  │ │ ├── parse5@6.0.1
                  │ │ ├─┬ saxes@5.0.1
                  │ │ │ └── xmlchars@2.2.0
                  │ │ ├── symbol-tree@3.2.4
                  │ │ ├─┬ tough-cookie@4.0.0
                  │ │ │ ├── psl@1.8.0 deduped
                  │ │ │ ├── punycode@2.1.1 deduped
                  │ │ │ └── universalify@0.1.2 deduped
                  │ │ ├─┬ w3c-hr-time@1.0.2
                  │ │ │ └── browser-process-hrtime@1.0.0
                  │ │ ├─┬ w3c-xmlserializer@2.0.0
                  │ │ │ └── xml-name-validator@3.0.0 deduped
                  │ │ ├── webidl-conversions@6.1.0
                  │ │ ├─┬ whatwg-encoding@1.0.5
                  │ │ │ └── iconv-lite@0.4.24 deduped
                  │ │ ├── whatwg-mimetype@2.3.0
                  │ │ ├─┬ whatwg-url@9.1.0
                  │ │ │ ├─┬ tr46@2.1.0
                  │ │ │ └── webidl-conversions@6.1.0 deduped
                  │ │ ├── ws@8.5.0
                  │ ├── moment@2.29.1
                  │ ├─┬ UNMET OPTIONAL DEPENDENCY sharp@0.28.1
                  │ │ ├─┬ color@3.2.1
                  │ │ │ ├─┬ color-convert@1.9.3
                  │ │ │ │ └── color-name@1.1.3
                  │ │ │ └─┬ color-string@1.9.0
                  │ │ │   ├── color-name@1.1.3 deduped
                  │ │ │   └─┬ simple-swizzle@0.2.2
                  │ │ │     └── is-arrayish@0.3.2
                  │ │ ├── UNMET OPTIONAL DEPENDENCY node-addon-api@3.2.1
                  │ │ ├─┬ UNMET OPTIONAL DEPENDENCY prebuild-install@6.1.4
                  │ │ │ ├── expand-template@2.0.3
                  │ │ │ ├── github-from-package@0.0.0
                  │ │ │ ├── mkdirp-classic@0.5.3 deduped
                  │ │ │ ├── napi-build-utils@1.0.2
                  │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY node-abi@2.30.1
                  │ │ │ │ └── semver@5.7.1 deduped
                  │ │ │ ├─┬ npmlog@4.1.2
                  │ │ │ │ ├─┬ are-we-there-yet@1.1.5
                  │ │ │ │ │ ├── delegates@1.0.0 deduped
                  │ │ │ │ │ └── readable-stream@2.3.7 deduped
                  │ │ │ │ ├─┬ gauge@2.7.4
                  │ │ │ │ │ ├── aproba@1.2.0 deduped
                  │ │ │ │ │ ├── has-unicode@2.0.1 deduped
                  │ │ │ │ │ ├── object-assign@4.1.0 deduped
                  │ │ │ │ │ ├── string-width@1.0.2 deduped
                  │ │ │ │ │ ├── strip-ansi@3.0.1 deduped
                  │ │ │ │ │ └── wide-align@1.1.3 deduped
                  │ │ │ ├─┬ rc@1.2.8
                  │ │ │ │ ├── deep-extend@0.6.0
                  │ │ │ │ ├── ini@1.3.5 deduped
                  │ │ │ │ ├── minimist@1.2.5 deduped
                  │ │ │ │ └── strip-json-comments@2.0.1
                  │ │ │ ├── simple-get@3.1.0 deduped
                  │ │ │ ├── tar-fs@2.1.1 deduped
                  │ │ │ └── tunnel-agent@0.6.0 deduped
                  │ └── uuid@8.3.2
                  ├─┬ iobroker.javascript@5.2.21
                  │ │   └── @types/node@10.17.60 deduped
                  │ ├── @types/node@10.17.60
                  │ ├─┬ @types/request@2.48.8
                  │ │ ├── @types/caseless@0.12.2
                  │ │ ├── @types/node@13.13.5
                  │ │ ├── @types/tough-cookie@4.0.1
                  │ │ └─┬ form-data@2.5.1
                  │ ├── coffee-compiler@0.3.2
                  │ ├── coffee-script@1.12.7
                  │ ├── jsonata@1.8.6
                  │ ├── node-inspect@2.0.0
                  │ ├─┬ node-schedule@2.0.0
                  │ │ ├── cron-parser@3.5.0 deduped
                  │ │ ├── long-timeout@0.1.1 deduped
                  │ │ └── sorted-array-functions@1.3.0 deduped
                  │ ├── oauth@0.9.15
                  │ ├─┬ owlintuition@0.4.0
                  │ │ └─┬ xml2json@0.12.0
                  │ │   ├── hoek@4.2.1
                  │ │   ├─┬ joi@13.7.0
                  │ │   │ ├── hoek@5.0.4
                  │ │   │ ├─┬ isemail@3.2.0
                  │ │   │ └─┬ topo@3.0.3
                  │ │   │   └── hoek@6.1.3
                  │ │   └─┬ node-expat@2.4.0
                  │ │     ├── bindings@1.5.0 deduped
                  │ │     └── nan@2.15.0 deduped
                  │ ├─┬ semver@7.3.5
                  │ ├── suncalc2@1.8.1
                  │ ├── typescript@4.5.5
                  │ ├─┬ virtual-tsc@0.6.2
                  │ │ ├─┬ debug@4.3.3
                  │ │ │ └── ms@2.1.2
                  │ │ └── picocolors@1.0.0
                  │ ├─┬ vm2@3.9.7
                  │ │ ├── acorn@8.7.0 deduped
                  │ │ └── acorn-walk@8.2.0
                  │ ├─┬ wake_on_lan@1.0.0
                  │ │ └── minimist@1.2.5 deduped
                  ├─┬ iobroker.js-controller@3.3.22
                  │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                  │ │ ├── esbuild@0.11.23
                  │ │ └── jsonc-parser@3.0.0
                  │ ├─┬ @iobroker/db-objects-file@1.2.7
                  │ │ ├─┬ @iobroker/db-base@1.2.4
                  │ │ │ ├── deep-clone@3.0.3 deduped
                  │ │ │ ├─┬ fs-extra@9.1.0
                  │ │ │ │ ├── at-least-node@1.0.0 deduped
                  │ │ │ │ ├── graceful-fs@4.2.4 deduped
                  │ │ │ │ ├─┬ jsonfile@6.1.0
                  │ │ │ │ │ ├── graceful-fs@4.2.4 deduped
                  │ │ │ │ │ └── universalify@2.0.0 deduped
                  │ │ │ ├── node.extend@2.0.2 deduped
                  │ │ │ └── respjs@4.2.0
                  │ │ ├── @iobroker/db-objects-redis@1.2.7 deduped
                  │ │ └── node.extend@2.0.2 deduped
                  │ ├─┬ @iobroker/db-objects-jsonl@1.2.7
                  │ │ ├─┬ @alcalzone/jsonl-db@1.3.0
                  │ │ │ ├─┬ alcalzone-shared@3.0.4
                  │ │ │ │ └─┬ debug@4.3.3
                  │ │ │ └─┬ proper-lockfile@4.1.2
                  │ │ │   ├── retry@0.12.0
                  │ │ │   └── signal-exit@3.0.3
                  │ │ ├── @iobroker/db-base@1.2.4 deduped
                  │ │ ├── @iobroker/db-objects-file@1.2.7 deduped
                  │ ├─┬ @iobroker/db-objects-redis@1.2.7
                  │ │ ├─┬ ioredis@4.28.5
                  │ │ │ ├── cluster-key-slot@1.1.0
                  │ │ │ ├── denque@1.5.1
                  │ │ │ ├── lodash.defaults@4.2.0
                  │ │ │ ├── lodash.flatten@4.4.0
                  │ │ │ ├── lodash.isarguments@3.1.0
                  │ │ │ ├── p-map@2.1.0
                  │ │ │ ├── redis-commands@1.7.0
                  │ │ │ ├── redis-errors@1.2.0
                  │ │ │ ├─┬ redis-parser@3.0.0
                  │ │ │ │ └── redis-errors@1.2.0 deduped
                  │ │ │ └── standard-as-callback@2.1.0
                  │ ├─┬ @iobroker/db-states-file@1.2.7
                  │ │ └── @iobroker/db-states-redis@1.2.7 deduped
                  │ ├─┬ @iobroker/db-states-jsonl@1.2.7
                  │ │ ├── @alcalzone/jsonl-db@1.3.0 deduped
                  │ │ ├── @iobroker/db-states-file@1.2.7 deduped
                  │ ├─┬ @iobroker/db-states-redis@1.2.7
                  │ │ └── ioredis@4.28.5 deduped
                  │ ├── @iobroker/plugin-base@1.2.1
                  │ ├─┬ @iobroker/plugin-sentry@1.1.10
                  │ │ ├── @iobroker/plugin-base@1.2.1 deduped
                  │ │ ├── @sentry/integrations@6.16.1 deduped
                  │ │ ├── @sentry/node@6.16.1 deduped
                  │ │ └── source-map-support@0.5.21 deduped
                  │ ├─┬ chokidar@3.5.3
                  │ │ ├─┬ anymatch@3.1.2
                  │ │ │ ├── normalize-path@3.0.0 deduped
                  │ │ │ └── picomatch@2.3.1
                  │ │ ├─┬ braces@3.0.2
                  │ │ │ └─┬ fill-range@7.0.1
                  │ │ │   └─┬ to-regex-range@5.0.1
                  │ │ │     └── is-number@7.0.0
                  │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@2.3.2
                  │ │ ├─┬ glob-parent@5.1.2
                  │ │ │ └── is-glob@4.0.1 deduped
                  │ │ ├─┬ is-binary-path@2.1.0
                  │ │ │ └── binary-extensions@2.2.0
                  │ │ ├─┬ is-glob@4.0.1
                  │ │ │ └── is-extglob@2.1.1
                  │ │ └─┬ readdirp@3.6.0
                  │ │   └── picomatch@2.3.1 deduped
                  │ ├── ci-info@3.3.0
                  │ ├── daemonize2@0.4.2
                  │ ├─┬ debug@4.3.3
                  │ │ └── ms@2.1.2
                  │ ├─┬ decache@4.6.1
                  │ ├─┬ diskusage@1.1.3
                  │ │ ├── es6-promise@4.2.8
                  │ ├─┬ event-stream@4.0.1
                  │ │ ├── duplexer@0.1.1
                  │ │ ├── from@0.1.7
                  │ │ ├── map-stream@0.0.7
                  │ │ ├─┬ pause-stream@0.0.11
                  │ │ │ └── through@2.3.8 deduped
                  │ │ ├─┬ split@1.0.1
                  │ │ ├─┬ stream-combiner@0.2.2
                  │ │ │ ├── duplexer@0.1.1 deduped
                  │ ├─┬ greenlock@4.0.4
                  │ │ ├─┬ @greenlock/manager@3.1.0
                  │ │ │ └─┬ greenlock-manager-fs@3.1.1
                  │ │ │   ├── @root/mkdirp@1.0.0 deduped
                  │ │ │   └── safe-replace@1.1.0 deduped
                  │ │ ├─┬ @root/acme@3.1.0
                  │ │ │ ├── @root/csr@0.8.1 deduped
                  │ │ │ ├── @root/encoding@1.0.1
                  │ │ │ ├─┬ @root/keypairs@0.10.3
                  │ │ │ │ ├── @root/encoding@1.0.1 deduped
                  │ │ │ │ ├── @root/pem@1.0.4 deduped
                  │ │ │ │ └── @root/x509@0.7.2 deduped
                  │ │ │ ├── @root/request@1.8.1 deduped
                  │ │ │ └─┬ @root/x509@0.7.2
                  │ │ │   ├── @root/asn1@1.0.0 deduped
                  │ │ │   └── @root/encoding@1.0.1 deduped
                  │ │ ├─┬ @root/csr@0.8.1
                  │ │ │ ├─┬ @root/asn1@1.0.0
                  │ │ │ │ └── @root/encoding@1.0.1 deduped
                  │ │ ├─┬ @root/greenlock@4.0.5
                  │ │ │ ├── @greenlock/manager@3.1.0 deduped
                  │ │ │ ├── @root/acme@3.1.0 deduped
                  │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
                  │ │ │ ├── cert-info@1.5.1 deduped
                  │ │ │ ├── greenlock-store-fs@3.2.2 deduped
                  │ │ ├─┬ @root/keypairs@0.9.0
                  │ │ ├─┬ greenlock-store-fs@3.2.2
                  │ ├─┬ greenlock-express@4.0.3
                  │ │ ├── @root/greenlock@4.0.5 deduped
                  │ │ ├─┬ @root/greenlock-express@4.0.4
                  │ │ │ ├── @root/greenlock@4.0.5 deduped
                  │ │ │ └── redirect-https@1.3.1 deduped
                  │ │ └─┬ redirect-https@1.3.1
                  │ │   └── escape-html@1.0.3 deduped
                  │ ├─┬ jsonwebtoken@8.5.1
                  │ │ ├─┬ jws@3.2.2
                  │ │ │ ├─┬ jwa@1.4.1
                  │ │ │ │ ├── buffer-equal-constant-time@1.0.1 deduped
                  │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
                  │ │ │ │ └── safe-buffer@5.1.2 deduped
                  │ │ ├── lodash.includes@4.3.0
                  │ │ ├── lodash.isboolean@3.0.3
                  │ │ ├── lodash.isinteger@4.0.4
                  │ │ ├── lodash.isnumber@3.0.3
                  │ │ ├── lodash.isplainobject@4.0.6
                  │ │ ├── lodash.isstring@4.0.1
                  │ │ ├── lodash.once@4.1.1
                  │ │ ├── ms@2.1.2
                  │ ├─┬ jszip@3.7.1
                  │ │ ├─┬ lie@3.3.0
                  │ │ │ └── immediate@3.0.6
                  │ │ ├── pako@1.0.11
                  │ │ ├─┬ readable-stream@2.3.7
                  │ │ │ ├── core-util-is@1.0.2 deduped
                  │ │ │ ├── isarray@1.0.0
                  │ │ │ ├── process-nextick-args@2.0.1
                  │ │ │ ├── safe-buffer@5.1.2 deduped
                  │ │ │ ├─┬ string_decoder@1.1.1
                  │ │ └── set-immediate-shim@1.0.1
                  │ ├─┬ le-acme-core@2.1.4
                  │ │ └─┬ rsa-compat@1.9.4
                  │ │   ├─┬ keypairs@1.2.14
                  │ │   │ ├── eckles@1.4.1
                  │ │   │ └── rasha@1.2.5
                  │ │   ├── node-forge@0.7.6
                  │ │   └─┬ ursa-optional@0.9.10
                  │ ├─┬ le-challenge-fs@2.0.9
                  │ │ └── @root/mkdirp@1.0.0 deduped
                  │ ├── le-sni-auto@2.1.9
                  │ ├─┬ loadavg-windows@1.1.1
                  │ │ └── weak-daemon@1.0.3
                  │ ├── mime@2.6.0
                  │ ├── ncp@2.0.0
                  │ ├── node-forge@0.10.0
                  │ ├── node-schedule@2.1.0 deduped
                  │ ├─┬ node.extend@2.0.2
                  │ │ ├─┬ has@1.0.3
                  │ │ │ └── function-bind@1.1.1
                  │ │ └── is@3.3.0
                  │ ├─┬ pidusage@2.0.21
                  │ │ └── safe-buffer@5.2.1
                  │ ├── promisify-child-process@4.1.1
                  │ ├─┬ prompt@1.2.1
                  │ │ ├── async@0.9.2
                  │ │ ├── colors@1.4.0 deduped
                  │ │ ├─┬ read@1.0.7
                  │ │ │ └── mute-stream@0.0.8
                  │ │ ├── revalidator@0.1.8
                  │ │ └─┬ winston@2.4.5
                  │ │   ├── async@1.0.0
                  │ │   ├── colors@1.0.3
                  │ │   ├── cycle@1.0.3
                  │ │   ├── eyes@0.1.8
                  │ │   ├── isstream@0.1.2 deduped
                  │ │   └── stack-trace@0.0.10 deduped
                  │ ├── readline-sync@1.4.10
                  │ ├─┬ semver@7.3.5
                  │ ├─┬ tar@6.1.11
                  │ │ ├── chownr@2.0.0
                  │ │ ├─┬ fs-minipass@2.1.0
                  │ │ │ └── minipass@3.1.1 deduped
                  │ │ ├─┬ minipass@3.1.1
                  │ │ ├─┬ minizlib@2.1.2
                  │ │ │ ├── minipass@3.1.1 deduped
                  │ │ ├── mkdirp@1.0.4
                  │ ├─┬ winston@3.6.0
                  │ │ ├─┬ @dabh/diagnostics@2.0.3
                  │ │ │ ├─┬ colorspace@1.1.4
                  │ │ │ │ ├── color@3.2.1 deduped
                  │ │ │ │ └── text-hex@1.0.0
                  │ │ │ ├── enabled@2.0.0
                  │ │ │ └── kuler@2.0.0
                  │ │ ├── async@3.2.3
                  │ │ ├── is-stream@2.0.1 deduped
                  │ │ ├─┬ logform@2.4.0
                  │ │ │ ├── @colors/colors@1.5.0
                  │ │ │ ├── fecha@4.2.1
                  │ │ │ ├── ms@2.1.3
                  │ │ │ ├── safe-stable-stringify@2.3.1 deduped
                  │ │ │ └── triple-beam@1.3.0 deduped
                  │ │ ├─┬ one-time@1.0.0
                  │ │ │ └── fn.name@1.1.0
                  │ │ ├── stack-trace@0.0.10
                  │ │ ├── triple-beam@1.3.0
                  │ │ └─┬ winston-transport@4.5.0
                  │ │   ├── logform@2.4.0 deduped
                  │ ├─┬ winston-daily-rotate-file@4.6.1
                  │ │ ├─┬ file-stream-rotator@0.6.1
                  │ │ │ └── moment@2.29.1 deduped
                  │ │ ├── object-hash@2.2.0
                  │ │ ├── triple-beam@1.3.0 deduped
                  │ │ └── winston-transport@4.5.0 deduped
                  │ ├─┬ winston-seq-updated@1.0.4
                  │ │ ├── seq-logging@0.4.6
                  │ ├─┬ winston-syslog@2.4.4
                  │ │ ├── glossy@0.1.7
                  │ │ └─┬ UNMET OPTIONAL DEPENDENCY unix-dgram@2.0.3
                  │ └─┬ yargs@16.2.0
                  │   ├─┬ cliui@7.0.4
                  │   │ ├── string-width@4.2.3 deduped
                  │   │ ├─┬ strip-ansi@6.0.1
                  │   │ │ └── ansi-regex@5.0.1
                  │   │ └─┬ wrap-ansi@7.0.0
                  │   │   ├─┬ ansi-styles@4.3.0
                  │   │   │ └─┬ color-convert@2.0.1
                  │   │   │   └── color-name@1.1.4
                  │   │   └── strip-ansi@6.0.1 deduped
                  │   ├── escalade@3.1.1
                  │   ├── get-caller-file@2.0.5
                  │   ├── require-directory@2.1.1 deduped
                  │   ├─┬ string-width@4.2.3
                  │   │ ├── is-fullwidth-code-point@3.0.0
                  │   ├── y18n@5.0.8
                  │   └── yargs-parser@20.2.9
                  ├─┬ iobroker.lightify@0.2.16
                  │ ├── mdns-discovery@0.2.6 deduped
                  │ ├── moment@2.29.1 deduped
                  │ ├─┬ promise@8.0.1
                  │ │ └── asap@2.0.6
                  │ └─┬ soef@0.4.15
                  │   ├── array-ext@0.1.5
                  │   └── sprintf-js@1.1.2
                  ├─┬ iobroker.mihome@1.3.7
                  ├── iobroker.mihome-vacuum@1.1.5
                  ├─┬ iobroker.mobile@1.0.1
                  ├─┬ iobroker.mqtt@2.4.1
                  │ ├─┬ mqtt@2.18.9
                  │ │ ├─┬ commist@1.1.0
                  │ │ │ ├── leven@2.1.0
                  │ │ │ └── minimist@1.2.5 deduped
                  │ │ ├─┬ concat-stream@1.6.2
                  │ │ │ ├── readable-stream@2.3.7 deduped
                  │ │ ├─┬ end-of-stream@1.4.4
                  │ │ │ └── once@1.4.0 deduped
                  │ │ ├─┬ es6-map@0.1.5
                  │ │ │ ├─┬ d@1.0.1
                  │ │ │ │ ├── es5-ext@0.10.53 deduped
                  │ │ │ │ └── type@1.2.0
                  │ │ │ ├─┬ es5-ext@0.10.53
                  │ │ │ │ ├── es6-iterator@2.0.3 deduped
                  │ │ │ │ ├── es6-symbol@3.1.3 deduped
                  │ │ │ │ └── next-tick@1.0.0
                  │ │ │ ├─┬ es6-iterator@2.0.3
                  │ │ │ │ ├── d@1.0.1 deduped
                  │ │ │ │ └── es6-symbol@3.1.3 deduped
                  │ │ │ ├─┬ es6-set@0.1.5
                  │ │ │ │ ├─┬ es6-symbol@3.1.1
                  │ │ │ │ │ ├── d@1.0.1 deduped
                  │ │ │ │ │ └── es5-ext@0.10.53 deduped
                  │ │ │ │ └── event-emitter@0.3.5 deduped
                  │ │ │ ├─┬ es6-symbol@3.1.3
                  │ │ │ │ └─┬ ext@1.4.0
                  │ │ │ │   └── type@2.0.0
                  │ │ │ └─┬ event-emitter@0.3.5
                  │ │ ├─┬ help-me@1.1.0
                  │ │ │ ├─┬ callback-stream@1.1.0
                  │ │ │ ├─┬ glob-stream@6.1.0
                  │ │ │ │ ├── extend@3.0.2 deduped
                  │ │ │ │ ├─┬ glob-parent@3.1.0
                  │ │ │ │ │ ├─┬ is-glob@3.1.0
                  │ │ │ │ │ │ └── is-extglob@2.1.1 deduped
                  │ │ │ │ │ └── path-dirname@1.0.2
                  │ │ │ │ ├── is-negated-glob@1.0.0
                  │ │ │ │ ├─┬ ordered-read-streams@1.0.1
                  │ │ │ │ ├─┬ pumpify@1.5.1
                  │ │ │ │ │ ├── duplexify@3.7.1 deduped
                  │ │ │ │ │ └─┬ pump@2.0.1
                  │ │ │ │ │   ├── end-of-stream@1.4.4 deduped
                  │ │ │ │ │   └── once@1.4.0 deduped
                  │ │ │ │ ├── readable-stream@2.3.7 deduped
                  │ │ │ │ ├── remove-trailing-separator@1.1.0
                  │ │ │ │ ├─┬ to-absolute-glob@2.0.2
                  │ │ │ │ │ ├─┬ is-absolute@1.0.0
                  │ │ │ │ │ │ ├─┬ is-relative@1.0.0
                  │ │ │ │ │ │ │ └─┬ is-unc-path@1.0.0
                  │ │ │ │ │ │ │   └── unc-path-regex@0.1.2
                  │ │ │ │ │ │ └── is-windows@1.0.2
                  │ │ │ │ │ └── is-negated-glob@1.0.0 deduped
                  │ │ │ │ └─┬ unique-stream@2.3.1
                  │ │ │ │   ├── json-stable-stringify-without-jsonify@1.0.1
                  │ │ │ │   └─┬ through2-filter@3.0.0
                  │ │ │ │     ├── through2@2.0.5 deduped
                  │ │ │ │     └── xtend@4.0.2 deduped
                    │ └── ws@7.5.7
                    │ ├─┬ bent@7.3.12
                    │ └── ws@7.5.6
                    │ │ ├─┬ debug@2.2.0
                    │ │ │ └── ms@0.7.1
                    │ │ ├── dgram@1.0.1
                    │ ├── netmask@2.0.2
                    │ │ ├─┬ async@2.6.3
                    │ │ ├─┬ debug@3.2.7
                    │ │ │ └── ms@2.1.3
                    │   │ │   └── ms@2.1.2
                    │   │ └─┬ debug@4.3.3
                    │   │   └── ms@2.1.2
                    │   │ └─┬ debug@4.3.3
                    │   │   └── ms@2.1.2
                    │   └─┬ debug@4.3.3
                    │     └── ms@2.1.2
                    │ └─┬ axios@0.21.4
                    │ └─┬ xml2js@0.4.23
                    │   ├── sax@1.2.4
                    │ │ └─┬ debug@4.1.1
                    │ │   └── ms@2.1.2
                    │ │ └─┬ ws@6.2.1
                    │ └─┬ cron@1.8.2
                    │ ├─┬ binrpc@3.3.1
                    │ │ └── put@0.0.6
                    │   ├── sax@0.4.3
                    │ │ └── uuid@8.3.2
                    │ └─┬ rrule@2.6.8
                    │   ├── luxon@1.27.0
                    │ ├─┬ semver@7.3.5
                    │ │ ├─┬ mqtt@4.2.8
                    │ │ │ ├── ws@7.5.7
                    │ ├─┬ echarts@4.9.0
                    │ ├─┬ jsdom@17.0.0
                    │ │ ├── abab@2.0.5
                    │ │ ├── acorn@8.7.0
                    │ │ ├── cssom@0.5.0
                    │ │ │   └── ms@2.1.2
                    │ │ ├─┬ saxes@5.0.1
                    │ │ ├── ws@8.5.0
                    │ ├── moment@2.29.1
                    │ │ ├─┬ color@3.2.1
                    │ │ │ ├─┬ rc@1.2.8
                    │ └── uuid@8.3.2
                    │ ├── jsonata@1.8.6
                    │ ├── oauth@0.9.15
                    │ │   ├── hoek@4.2.1
                    │ │   ├─┬ joi@13.7.0
                    │ ├─┬ semver@7.3.5
                    │ │ ├─┬ debug@4.3.3
                    │ │ │ └── ms@2.1.2
                    │ ├─┬ vm2@3.9.7
                    │ ├── ci-info@3.3.0
                    │ ├─┬ debug@4.3.3
                    │ │ └── ms@2.1.2
                    │ ├─┬ decache@4.6.1
                    │ │ ├── from@0.1.7
                    │ │ ├─┬ split@1.0.1
                    │ │ ├─┬ jws@3.2.2
                    │ │ │ ├─┬ jwa@1.4.1
                    │ │ ├── ms@2.1.2
                    │ ├─┬ jszip@3.7.1
                    │ │ ├─┬ lie@3.3.0
                    │ │ ├── pako@1.0.11
                    │ ├── mime@2.6.0
                    │ ├── ncp@2.0.0
                    │ │ ├─┬ has@1.0.3
                    │ │ └── is@3.3.0
                    │ ├─┬ prompt@1.2.1
                    │ │ ├── async@0.9.2
                    │ │ ├─┬ read@1.0.7
                    │ │   ├── async@1.0.0
                    │ │   ├── cycle@1.0.3
                    │ │   ├── eyes@0.1.8
                    │ ├─┬ semver@7.3.5
                    │ ├─┬ tar@6.1.11
                    │ ├─┬ winston@3.6.0
                    │ │ ├── async@3.2.3
                    │ │ │ ├── ms@2.1.3
                    │ └─┬ yargs@16.2.0
                    │   ├─┬ cliui@7.0.4
                    │   ├── y18n@5.0.8
                    │ ├─┬ promise@8.0.1
                    │ │ └── asap@2.0.6
                    │ └─┬ soef@0.4.15
                    │ ├─┬ mqtt@2.18.9
                    │ │ │ ├─┬ d@1.0.1
                    M
                    M
                    Markus Faltermeier
                    #76
                    @markus-faltermeier
                    und der zweite Teil
                    │ │ ├─┬ mqtt-packet@5.6.1
                    │ │ │ ├─┬ bl@1.2.2
                    │ │ │ ├── process-nextick-args@2.0.1 deduped
                    │ │ ├─┬ split2@2.2.0
                    │ │ │ └── through2@2.0.5 deduped
                    │ │ ├─┬ websocket-stream@5.2.0
                    │ │ │ ├─┬ ws@6.2.2
                    │ │ │ │ └── async-limiter@1.0.1 deduped
                    │ ├─┬ mqtt-connection@4.1.0
                    │ │ ├─┬ duplexify@3.7.1
                    │ │ └─┬ through2@2.0.5
                    │ ├─┬ websocket-stream@5.5.2
                    │ │ ├─┬ ws@3.3.3
                    │ │ │ ├── async-limiter@1.0.1 deduped
                    │ │ │ └── ultron@1.1.1
                    │ └── ws@8.5.0
                    ├─┬ iobroker.mqtt-client@1.5.0
                    │ ├─┬ @iobroker/adapter-core@2.6.0
                    │ │ └─┬ @types/iobroker@4.0.1
                    │ └── mqtt@2.18.9 deduped
                    ├─┬ iobroker.nut@1.5.0
                    │ └── node-nut@1.0.3
                    ├─┬ iobroker.octoprint@2.1.0
                    │ └─┬ axios@0.24.0
                    ├─┬ iobroker.ping@1.5.0
                    ├─┬ iobroker.pushover@2.0.5
                    │ └── pushover-notifications@1.2.2
                    ├─┬ iobroker.rpi2@1.3.1
                    │ ├─┬ node-dht-sensor@0.4.3
                    │ │ └── node-addon-api@1.7.2
                    │ ├─┬ rpi-gpio@2.1.7
                    │ │ ├─┬ async-retry@1.3.3
                    │ │ │ └── retry@0.13.1
                    │ │ ├─┬ debug@3.2.7
                    │ │ │ └── ms@2.1.3
                    │ │ └─┬ epoll@2.0.10
                    │ ├─┬ rpi-gpio-buttons@2.0.1
                    │ │ ├── button-events@1.0.2
                    │ │ └── rpi-gpio@2.1.7 deduped
                    │ └── sync-exec@0.6.2
                    ├─┬ iobroker.scenes@2.3.8
                    │ └── node-schedule@2.1.0 deduped
                    ├─┬ iobroker.shelly@4.0.7
                    │ ├── @apollon/iobroker-tools@0.2.0
                    │ ├─┬ coiot-coap@1.0.0
                    │ │ ├─┬ coap@0.24.0
                    │ │ │ ├── capitalize@2.0.4
                    │ │ │ ├── coap-packet@0.1.14
                    │ │ │ ├── fastseries@2.0.0
                    │ │ │ ├─┬ lru-cache@5.1.1
                    │ │ │ │ └── yallist@3.1.1
                    │ │ │ └─┬ readable-stream@3.6.0
                    │ │ └── commander@6.2.1
                    │ ├─┬ mqtt@4.3.5
                    │ │ ├─┬ debug@4.3.3
                    │ │ │ └── ms@2.1.2
                    │ │ │ ├─┬ glob@7.1.6
                    │ │ │ │ ├── fs.realpath@1.0.0
                    │ │ │ │ ├─┬ inflight@1.0.6
                    │ │ │ │ │ ├── once@1.4.0 deduped
                    │ │ │ │ │ └── wrappy@1.0.2 deduped
                    │ │ │ │ ├── minimatch@3.0.4 deduped
                    │ │ │ │ └── path-is-absolute@1.0.1
                    │ │ ├─┬ lru-cache@6.0.0
                    │ │ ├─┬ number-allocator@1.0.9
                    │ │ │ └── js-sdsl@2.1.4
                    │ │ ├── rfdc@1.3.0
                    │ │ ├── ws@7.5.7
                    │ ├── mqtt-connection@4.1.0 deduped
                    │ ├─┬ ping@0.4.1
                    │ │ ├── q@1.5.1
                    │ │ └── underscore@1.13.2
                    │ ├─┬ shelly-iot@1.1.2
                    │ │ ├─┬ coap@0.26.0
                    │ │ │ ├─┬ @types/bl@5.0.2
                    │ │ │ │ ├── @types/node@13.13.5 deduped
                    │ │ │ │ └─┬ @types/readable-stream@2.3.13
                    │ │ │ ├── @types/node@16.11.25
                    │ │ │ ├─┬ bl@5.0.0
                    │ │ │ │ ├─┬ buffer@6.0.3
                    │ │ │ │ │ ├── base64-js@1.3.1 deduped
                    │ │ │ │ │ └── ieee754@1.2.1
                    │ │ │ ├── capitalize@2.0.4 deduped
                    │ │ │ ├── coap-packet@1.1.1
                    │ │ │ ├── fastseries@2.0.0 deduped
                    │ │ │ ├─┬ lru-cache@6.0.0
                    │ │ └─┬ node-rest-client@3.1.1
                    │ │   ├─┬ debug@4.3.3
                    │ │   │ └── ms@2.1.2
                    │ │   ├── follow-redirects@1.14.8 deduped
                    │ │   └── xml2js@0.4.23 deduped
                    │ ├── tcp-ping@0.1.1
                    │ ├── xml2js@0.4.23 deduped
                    │ └── xmlbuilder@15.1.1
                    ├─┬ iobroker.simple-api@2.6.2
                    ├─┬ iobroker.snmp@0.5.0
                    │ └─┬ net-snmp@1.2.5
                    │   └── asn1-ber@1.0.9
                    ├─┬ iobroker.socketio@3.1.5
                    │ ├─┬ axios@0.23.0
                    │ │ └── follow-redirects@1.14.8 deduped
                    │ ├── cookie-parser@1.4.6 deduped
                    │ ├── express-session@1.17.2 deduped
                    │ └─┬ socket.io@2.4.1
                    │   ├─┬ debug@4.1.1
                    │   │ └── ms@2.1.3
                    │   ├─┬ engine.io@3.5.0
                    │   │ ├── accepts@1.3.8 deduped
                    │   │ ├── base64id@2.0.0
                    │   │ ├─┬ debug@4.1.1
                    │   │ │ └── ms@2.1.3 deduped
                    │   │ ├─┬ engine.io-parser@2.2.1
                    │   │ │ ├── after@0.8.2 deduped
                    │   │ │ ├── arraybuffer.slice@0.0.7
                    │   │ │ ├── base64-arraybuffer@0.1.4
                    │   │ │ ├── blob@0.0.5
                    │   │ │ └── has-binary2@1.0.3 deduped
                    │   │ └── ws@7.4.6
                    │   ├─┬ has-binary2@1.0.3
                    │   │ └── isarray@2.0.1
                    │   ├── socket.io-adapter@1.1.2
                    │   ├─┬ socket.io-client@2.4.0
                    │   │ ├── backo2@1.0.2 deduped
                    │   │ ├── component-bind@1.0.0 deduped
                    │   │ ├── component-emitter@1.3.0
                    │   │ ├─┬ debug@3.1.0
                    │   │ │ └── ms@2.0.0
                    │   │ ├─┬ engine.io-client@3.5.2
                    │   │ │ ├── component-emitter@1.3.0 deduped
                    │   │ │ ├── component-inherit@0.0.3 deduped
                    │   │ │ ├─┬ debug@3.1.0
                    │   │ │ │ └── ms@2.0.0
                    │   │ │ ├── engine.io-parser@2.2.1 deduped
                    │   │ │ ├── has-cors@1.1.0 deduped
                    │   │ │ ├── parseqs@0.0.6 deduped
                    │   │ │ ├── parseuri@0.0.6 deduped
                    │   │ │ ├── ws@7.4.6 deduped
                    │   │ │ ├── xmlhttprequest-ssl@1.6.3
                    │   │ │ └── yeast@0.1.2 deduped
                    │   │ ├── has-binary2@1.0.3 deduped
                    │   │ ├─┬ socket.io-parser@3.3.2
                    │   │ │ ├── debug@3.1.0 deduped
                    │   │ │ └── isarray@2.0.1 deduped
                    │   │ └── to-array@0.1.4 deduped
                    │   └─┬ socket.io-parser@3.4.1
                    │     ├─┬ debug@4.1.1
                    │     └── isarray@2.0.1
                    ├─┬ iobroker.sonoff@2.4.7
                    │ └── mqtt-connection@4.1.0 deduped
                    ├─┬ iobroker.spotify-premium@1.0.0
                    │ ├─┬ @iobroker/adapter-core@1.0.1
                    │ │ └── @types/iobroker@1.4.13 deduped
                    │ ├── promise@8.0.1 deduped
                    │ ├── querystring@0.2.0
                    │ └─┬ request@2.83.0
                    │   ├── aws-sign2@0.7.0 deduped
                    │   ├── aws4@1.9.1 deduped
                    │   ├── forever-agent@0.6.1 deduped
                    │   ├── form-data@2.3.3 deduped
                    │   ├─┬ har-validator@5.0.3
                    │   │ ├─┬ ajv@5.5.2
                    │   │ │ ├── co@4.6.0
                    │   │ │ ├── fast-deep-equal@1.1.0
                    │   │ │ ├── fast-json-stable-stringify@2.1.0 deduped
                    │   │ │ └── json-schema-traverse@0.3.1
                    │   │ └── har-schema@2.0.0 deduped
                    │   ├─┬ hawk@6.0.2
                    │   │ ├─┬ boom@4.3.1
                    │   │ │ └── hoek@4.2.1 deduped
                    │   │ ├─┬ cryptiles@3.1.4
                    │   │ │ └─┬ boom@5.2.0
                    │   │ ├── hoek@4.2.1 deduped
                    │   │ └─┬ sntp@2.1.0
                    │   ├── http-signature@1.2.0 deduped
                    │   ├── is-typedarray@1.0.0 deduped
                    │   ├── json-stringify-safe@5.0.1 deduped
                    │   ├── mime-types@2.1.34 deduped
                    │   ├── oauth-sign@0.8.2
                    │   ├── performance-now@2.1.0 deduped
                    │   ├── qs@6.5.2
                    │   ├── stringstream@0.0.6
                    │   ├─┬ tough-cookie@2.3.4
                    │   │ └── punycode@1.4.1
                    │   ├── tunnel-agent@0.6.0 deduped
                    │   └── uuid@3.4.0 deduped
                    ├─┬ iobroker.statistics@1.0.9
                    │ └── cron@1.8.2 deduped
                    ├─┬ iobroker.synology@1.1.3
                    │ ├─┬ @iobroker/adapter-core@2.4.0
                    │ │ └─┬ @types/iobroker@3.2.4
                    │ └─┬ syno@3.0.0
                    │   ├── commander@4.1.1
                    │   ├─┬ js-yaml@3.14.1
                    │   │ ├─┬ argparse@1.0.10
                    │   │ │ └── sprintf-js@1.0.3
                    │   │ └── esprima@4.0.1 deduped
                    │   ├── lodash@4.17.21 deduped
                    │   ├── minimist@0.2.1
                    │   ├─┬ nconf@0.10.0
                    │   │ ├── async@1.5.2
                    │   │ ├── ini@1.3.5
                    │   │ ├── secure-keys@1.0.0
                    │   │ └─┬ yargs@3.32.0
                    │   │   ├── camelcase@2.1.1
                    │   │   ├── cliui@3.2.0 deduped
                    │   │   ├── decamelize@1.2.0 deduped
                    │   │   ├── os-locale@1.4.0 deduped
                    │   │   ├── window-size@0.1.4
                    │   │   └── y18n@3.2.1 deduped
                    │   ├── ospath@1.2.2
                    │   ├─┬ otplib@11.0.1
                    │   │ └── thirty-two@1.0.2
                    │   ├── pluralize@8.0.0
                    ├─┬ iobroker.tankerkoenig@2.1.1
                    ├─┬ iobroker.telegram@1.11.1
                    │ ├─┬ axios@0.25.0
                    │ ├─┬ node-telegram-bot-api@0.56.0
                    │ │ ├─┬ array.prototype.findindex@2.1.0
                    │ │ │ ├─┬ define-properties@1.1.3
                    │ │ │ │ └── object-keys@1.1.1
                    │ │ │ └─┬ es-abstract@1.19.1
                    │ │ │   ├── call-bind@1.0.2 deduped
                    │ │ │   ├─┬ es-to-primitive@1.2.1
                    │ │ │   │ ├── is-callable@1.2.4 deduped
                    │ │ │   │ ├─┬ is-date-object@1.0.5
                    │ │ │   │ │ └── has-tostringtag@1.0.0 deduped
                    │ │ │   │ └─┬ is-symbol@1.0.4
                    │ │ │   │   └── has-symbols@1.0.2 deduped
                    │ │ │   ├── function-bind@1.1.1 deduped
                    │ │ │   ├─┬ get-intrinsic@1.1.1
                    │ │ │   │ ├── function-bind@1.1.1 deduped
                    │ │ │   │ ├── has@1.0.3 deduped
                    │ │ │   ├─┬ get-symbol-description@1.0.0
                    │ │ │   │ ├── call-bind@1.0.2 deduped
                    │ │ │   │ └── get-intrinsic@1.1.1 deduped
                    │ │ │   ├── has-symbols@1.0.2
                    │ │ │   ├─┬ internal-slot@1.0.3
                    │ │ │   │ ├── get-intrinsic@1.1.1 deduped
                    │ │ │   │ └─┬ side-channel@1.0.4
                    │ │ │   │   └── object-inspect@1.12.0 deduped
                    │ │ │   ├── is-negative-zero@2.0.2
                    │ │ │   ├─┬ is-regex@1.1.4
                    │ │ │   │ └─┬ has-tostringtag@1.0.0
                    │ │ │   ├── is-shared-array-buffer@1.0.1
                    │ │ │   ├─┬ is-string@1.0.7
                    │ │ │   ├─┬ is-weakref@1.0.2
                    │ │ │   │ └── call-bind@1.0.2 deduped
                    │ │ │   ├── object-inspect@1.12.0
                    │ │ │   ├── object-keys@1.1.1 deduped
                    │ │ │   ├─┬ object.assign@4.1.2
                    │ │ │   │ ├── define-properties@1.1.3 deduped
                    │ │ │   │ ├── has-symbols@1.0.2 deduped
                    │ │ │   │ └── object-keys@1.1.1 deduped
                    │ │ │   ├─┬ string.prototype.trimend@1.0.4
                    │ │ │   │ └── define-properties@1.1.3 deduped
                    │ │ │   ├─┬ string.prototype.trimstart@1.0.4
                    │ │ │   └─┬ unbox-primitive@1.0.1
                    │ │ │     ├── has-bigints@1.0.1
                    │ │ │     └─┬ which-boxed-primitive@1.0.2
                    │ │ │       ├─┬ is-bigint@1.0.4
                    │ │ │       │ └── has-bigints@1.0.1 deduped
                    │ │ │       ├─┬ is-boolean-object@1.1.2
                    │ │ │       ├─┬ is-number-object@1.0.6
                    │ │ │       ├── is-string@1.0.7 deduped
                    │ │ │       └── is-symbol@1.0.4 deduped
                    │ │ ├─┬ bl@1.2.3
                    │ │ ├── bluebird@3.7.2 deduped
                    │ │ ├─┬ debug@3.2.7
                    │ │ │ └── ms@2.1.3
                    │ │ ├── depd@1.1.2 deduped
                    │ │ ├── eventemitter3@3.1.2
                    │ │ ├── file-type@3.9.0
                    │ │ ├── mime@1.6.0
                    │ │ ├─┬ pump@2.0.1
                    │ │ └─┬ request-promise@4.2.6
                    │ │   ├─┬ request-promise-core@1.1.4
                    │ │   ├── stealthy-require@1.1.1 deduped
                    │ └─┬ socksv5@0.0.6
                    │   └─┬ ipv6@3.1.1
                    │     ├─┬ cli@0.4.5
                    │     ├─┬ cliff@0.1.10
                    │     │ ├── eyes@0.1.8 deduped
                    │     │ └─┬ winston@0.8.3
                    │     │   ├── async@0.2.10
                    │     │   ├── colors@0.6.2
                    │     │   ├── cycle@1.0.3 deduped
                    │     │   ├── pkginfo@0.3.1
                    │     └── sprintf@0.1.3
                    ├─┬ iobroker.terminal@0.1.2
                    │ ├─┬ UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
                    │ ├── body-parser@1.19.2 deduped
                    │ ├── commander@5.1.0
                    │ ├─┬ connect@3.7.0
                    │ │ ├── debug@2.6.9 deduped
                    │ │ ├── finalhandler@1.1.2 deduped
                    │ │ ├── parseurl@1.3.3 deduped
                    │ │ └── utils-merge@1.0.1 deduped
                    │ ├── connect-flash@0.1.1 deduped
                    │ ├── express@4.17.3 deduped
                    │ ├── nan@2.15.0
                    │ ├─┬ passport@0.2.2
                    │ │ ├── passport-strategy@1.0.0 deduped
                    │ │ └── pause@0.0.1 deduped
                    │ ├── passport-local@1.0.0 deduped
                    │ ├─┬ send@0.17.2
                    │ │ ├── destroy@1.0.4
                    │ │ ├── encodeurl@1.0.2 deduped
                    │ │ ├── escape-html@1.0.3 deduped
                    │ │ ├── etag@1.8.1 deduped
                    │ │ ├── fresh@0.5.2 deduped
                    │ │ ├── http-errors@1.8.1 deduped
                    │ │ ├── mime@1.6.0 deduped
                    │ │ ├── ms@2.1.3
                    │ │ ├── on-finished@2.3.0 deduped
                    │ │ ├── range-parser@1.2.1 deduped
                    │ │ └── statuses@1.5.0 deduped
                    │ ├── socket.io@1.7.2 deduped
                    │ ├── uid-number@0.0.6
                    │ └── xtend@4.0.2
                    ├─┬ iobroker.text2command@2.1.1
                    ├─┬ iobroker.tr-064@4.2.15
                    ├─┬ iobroker.upnp@1.0.19
                    │ ├── ip@1.1.5
                    │ ├── node-ssdp@4.0.1 deduped
                    │ ├─┬ parsexmlresponse@0.0.5
                    │ ├─┬ portfinder@1.0.28
                    │ │ ├── async@2.6.3 deduped
                    │ │ ├─┬ debug@3.2.7
                    │ │ │ └── ms@2.1.3
                    │ │ └─┬ mkdirp@0.5.5
                    │ └── xmldom@0.6.0
                    ├─┬ iobroker.vis@1.4.5
                    │ └── jsonwebtoken@8.5.1 deduped
                    ├── iobroker.vis-bars@0.1.4
                    ├─┬ iobroker.vis-colorpicker@1.2.0
                    ├── iobroker.vis-fancyswitch@1.1.0
                    ├─┬ iobroker.vis-google-fonts@1.0.3
                    ├── iobroker.vis-hqwidgets@1.1.9
                    ├── iobroker.vis-jqui-mfd@1.0.12
                    ├── iobroker.vis-metro@1.1.2
                    ├─┬ iobroker.vis-players@0.1.6
                    │ └── @iobroker/adapter-core@1.0.3 deduped
                    ├─┬ iobroker.vis-plumb@1.0.2
                    ├── iobroker.vis-timeandweather@1.1.7
                    ├── iobroker.vis-weather@2.5.5
                    ├─┬ iobroker.web@3.4.16
                    │ ├── iobroker.simple-api@2.6.2 deduped
                    │ ├── iobroker.socketio@3.1.5 deduped
                    │ ├─┬ mime-types@2.1.34
                    │ │ └── mime-db@1.51.0
                    │ ├── passport@0.5.2 deduped
                    │ ├── passport.socketio@3.7.0 deduped
                    │ │ ├─┬ debug@3.1.0
                    │ │ │ └── ms@2.0.0 deduped
                    │ │ │ ├─┬ engine.io-parser@2.2.1
                    │ │ │ │ ├── after@0.8.2 deduped
                    │ │ │ │ ├── arraybuffer.slice@0.0.7
                    │ │ │ │ ├── base64-arraybuffer@0.1.4
                    │ │ │ │ ├── blob@0.0.5
                    │ │ │ │ └── has-binary2@1.0.3 deduped
                    │ │ │ ├── ws@7.4.6
                    ├─┬ UNMET DEPENDENCY iobroker.zigbee@1.6.16
                    │ ├── tar@6.1.11 deduped
                    │ ├── UNMET DEPENDENCY typescript@4.5.4
                    │ ├─┬ zigbee-herdsman@0.14.16
                    │ │ ├── debounce@1.2.1
                    │ │ ├─┬ debug@4.3.3
                    │ │ │ └── ms@2.1.2
                    │ │ ├── fast-deep-equal@3.1.3
                    │ │ ├── mixin-deep@2.0.1
                    │ │ ├─┬ mz@2.7.0
                    │ │ │ ├── any-promise@1.3.0
                    │ │ │ ├── object-assign@4.1.1
                    │ │ │ └─┬ thenify-all@1.6.0
                    │ │ │   └─┬ thenify@3.3.1
                    │ │ │     └── any-promise@1.3.0 deduped
                    │ │ ├─┬ serialport@9.2.8
                    │ │ │ ├─┬ @serialport/binding-mock@9.2.4
                    │ │ │ │ ├─┬ @serialport/binding-abstract@9.2.3
                    │ │ │ │ │ └── debug@4.3.3 deduped
                    │ │ │ ├─┬ @serialport/bindings@9.2.8
                    │ │ │ │ ├── @serialport/binding-abstract@9.2.3 deduped
                    │ │ │ │ ├── @serialport/parser-readline@9.2.4 deduped
                    │ │ │ │ ├─┬ bindings@1.5.0
                    │ │ │ │ │ └── file-uri-to-path@1.0.0
                    │ │ │ │ ├── nan@2.15.0
                    │ │ │ │ └─┬ prebuild-install@7.0.1
                    │ │ │ │   ├── detect-libc@2.0.0
                    │ │ │ │   ├── expand-template@2.0.3
                    │ │ │ │   ├── github-from-package@0.0.0
                    │ │ │ │   ├── mkdirp-classic@0.5.3
                    │ │ │ │   ├── napi-build-utils@1.0.2
                    │ │ │ │   ├─┬ node-abi@3.8.0
                    │ │ │ │   │ └─┬ semver@7.3.5
                    │ │ │ │   │   └─┬ lru-cache@6.0.0
                    │ │ │ │   │     └── yallist@4.0.0
                    │ │ │ │   ├─┬ npmlog@4.1.2
                    │ │ │ │   │ ├─┬ are-we-there-yet@1.1.7
                    │ │ │ │   │ │ ├── delegates@1.0.0
                    │ │ │ │   │ │ └─┬ readable-stream@2.3.7
                    │ │ │ │   │ │   ├── core-util-is@1.0.3
                    │ │ │ │   │ │   ├── inherits@2.0.4 deduped
                    │ │ │ │   │ │   ├── isarray@1.0.0
                    │ │ │ │   │ │   ├── process-nextick-args@2.0.1
                    │ │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
                    │ │ │ │   │ │   ├─┬ string_decoder@1.1.1
                    │ │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                    │ │ │ │   │ │   └── util-deprecate@1.0.2
                    │ │ │ │   │ ├─┬ gauge@2.7.4
                    │ │ │ │   │ │ ├── aproba@1.2.0
                    │ │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
                    │ │ │ │   │ │ ├── has-unicode@2.0.1
                    │ │ │ │   │ │ ├── object-assign@4.1.1 deduped
                    │ │ │ │   │ │ ├── signal-exit@3.0.7
                    │ │ │ │   │ │ ├─┬ string-width@1.0.2
                    │ │ │ │   │ │ │ ├── code-point-at@1.1.0
                    │ │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                    │ │ │ │   │ │ │ │ └── number-is-nan@1.0.1
                    │ │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                    │ │ │ │   │ │ ├─┬ strip-ansi@3.0.1
                    │ │ │ │   │ │ │ └── ansi-regex@2.1.1
                    │ │ │ │   │ │ └─┬ wide-align@1.1.5
                    │ │ │ │   │ │   └── string-width@1.0.2 deduped
                    │ │ │ │   │ └── set-blocking@2.0.0
                    │ │ │ │   ├─┬ pump@3.0.0
                    │ │ │ │   │ ├─┬ end-of-stream@1.4.4
                    │ │ │ │   │ │ └── once@1.4.0 deduped
                    │ │ │ │   │ └─┬ once@1.4.0
                    │ │ │ │   ├─┬ rc@1.2.8
                    │ │ │ │   │ ├── deep-extend@0.6.0
                    │ │ │ │   │ ├── ini@1.3.8
                    │ │ │ │   │ ├── minimist@1.2.5 deduped
                    │ │ │ │   │ └── strip-json-comments@2.0.1
                    │ │ │ │   ├─┬ simple-get@4.0.1
                    │ │ │ │   │ ├─┬ decompress-response@6.0.0
                    │ │ │ │   │ │ └── mimic-response@3.1.0
                    │ │ │ │   │ └── simple-concat@1.0.1
                    │ │ │ │   ├─┬ tar-fs@2.1.1
                    │ │ │ │   │ ├── chownr@1.1.4
                    │ │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
                    │ │ │ │   │ ├── pump@3.0.0 deduped
                    │ │ │ │   │ └─┬ tar-stream@2.2.0
                    │ │ │ │   │   ├─┬ bl@4.1.0
                    │ │ │ │   │   │ ├─┬ buffer@5.7.1
                    │ │ │ │   │   │ │ ├── base64-js@1.5.1
                    │ │ │ │   │   │ │ └── ieee754@1.2.1
                    │ │ │ │   │   │ └─┬ readable-stream@3.6.0
                    │ │ │ │   │   │   ├── string_decoder@1.1.1 deduped
                    │ │ │ │   │   │   └── util-deprecate@1.0.2 deduped
                    │ │ │ │   │   ├── fs-constants@1.0.0
                    │ │ │ │   └─┬ tunnel-agent@0.6.0
                    │ │ │ ├── @serialport/parser-byte-length@9.2.4
                    │ │ │ ├── @serialport/parser-cctalk@9.2.4
                    │ │ │ ├── @serialport/parser-delimiter@9.2.4
                    │ │ │ ├── @serialport/parser-inter-byte-timeout@9.2.4
                    │ │ │ ├─┬ @serialport/parser-readline@9.2.4
                    │ │ │ │ └── @serialport/parser-delimiter@9.2.4 deduped
                    │ │ │ ├── @serialport/parser-ready@9.2.4
                    │ │ │ ├── @serialport/parser-regex@9.2.4
                    │ │ │ ├─┬ @serialport/stream@9.2.4
                    │ │ └── slip@1.0.2
                    │ └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.422
                    │   ├─┬ UNMET DEPENDENCY axios@0.25.0
                    │   │ └── UNMET DEPENDENCY follow-redirects@1.14.8
                    │   ├── UNMET DEPENDENCY buffer-crc32@0.2.13
                    │   ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
                    │   │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
                    │   │ │ └── UNMET DEPENDENCY debug@4.3.3
                    │   │ └─┬ UNMET DEPENDENCY debug@4.3.3
                    │   │   └── UNMET DEPENDENCY ms@2.1.2
                    │   ├─┬ UNMET DEPENDENCY tar-stream@2.2.0
                    │   │ ├─┬ UNMET DEPENDENCY bl@4.1.0
                    │   │ │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                    │   │ │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                    │   │ │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                    │   │ │ ├── UNMET DEPENDENCY inherits@2.0.4
                    │   │ │ └── UNMET DEPENDENCY readable-stream@3.6.0
                    │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                    │   │ │ └─┬ UNMET DEPENDENCY once@1.4.0
                    │   │ │   └── UNMET DEPENDENCY wrappy@1.0.2
                    │   │ ├── UNMET DEPENDENCY fs-constants@1.0.0
                    │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                    │   │   ├─┬ UNMET DEPENDENCY string_decoder@1.3.0
                    │   │   │ └── UNMET DEPENDENCY safe-buffer@5.2.1
                    │   │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                    │   └─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.14
                    │     ├── UNMET DEPENDENCY debounce@1.2.1
                    │     ├─┬ UNMET DEPENDENCY debug@4.3.3
                    │     ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
                    │     ├── UNMET DEPENDENCY mixin-deep@2.0.1
                    │     ├─┬ UNMET DEPENDENCY mz@2.7.0
                    │     │ ├── UNMET DEPENDENCY any-promise@1.3.0
                    │     │ ├── UNMET DEPENDENCY object-assign@4.1.1
                    │     │ └─┬ UNMET DEPENDENCY thenify-all@1.6.0
                    │     │   └─┬ UNMET DEPENDENCY thenify@3.3.1
                    │     │     └── UNMET DEPENDENCY any-promise@1.3.0
                    │     ├─┬ UNMET DEPENDENCY serialport@9.2.8
                    │     │ ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
                    │     │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                    │     │ │ │ └── UNMET DEPENDENCY debug@4.3.3
                    │     │ ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.8
                    │     │ │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                    │     │ │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                    │     │ │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
                    │     │ │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
                    │     │ │ ├── UNMET DEPENDENCY debug@4.3.3
                    │     │ │ ├── UNMET DEPENDENCY nan@2.15.0
                    │     │ │ └─┬ UNMET DEPENDENCY prebuild-install@7.0.1
                    │     │ │   ├── UNMET DEPENDENCY detect-libc@2.0.0
                    │     │ │   ├── UNMET DEPENDENCY expand-template@2.0.3
                    │     │ │   ├── UNMET DEPENDENCY github-from-package@0.0.0
                    │     │ │   ├── UNMET DEPENDENCY minimist@1.2.5
                    │     │ │   ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                    │     │ │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
                    │     │ │   ├─┬ UNMET DEPENDENCY node-abi@3.8.0
                    │     │ │   │ └─┬ UNMET DEPENDENCY semver@7.3.5
                    │     │ │   │   └─┬ UNMET DEPENDENCY lru-cache@6.0.0
                    │     │ │   │     └── UNMET DEPENDENCY yallist@4.0.0
                    │     │ │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
                    │     │ │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
                    │     │ │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
                    │     │ │   │ │ └─┬ UNMET DEPENDENCY readable-stream@2.3.7
                    │     │ │   │ │   ├── UNMET DEPENDENCY core-util-is@1.0.3
                    │     │ │   │ │   ├── UNMET DEPENDENCY inherits@2.0.4
                    │     │ │   │ │   ├── UNMET DEPENDENCY isarray@1.0.0
                    │     │ │   │ │   ├── UNMET DEPENDENCY process-nextick-args@2.0.1
                    │     │ │   │ │   ├── UNMET DEPENDENCY safe-buffer@5.1.2
                    │     │ │   │ │   ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
                    │     │ │   │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
                    │     │ │   │ │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                    │     │ │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                    │     │ │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
                    │     │ │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
                    │     │ │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                    │     │ │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
                    │     │ │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
                    │     │ │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.7
                    │     │ │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
                    │     │ │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
                    │     │ │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
                    │     │ │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
                    │     │ │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
                    │     │ │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
                    │     │ │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
                    │     │ │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
                    │     │ │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
                    │     │ │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
                    │     │ │   ├─┬ UNMET DEPENDENCY pump@3.0.0
                    │     │ │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                    │     │ │   │ │ └── UNMET DEPENDENCY once@1.4.0
                    │     │ │   │ └─┬ UNMET DEPENDENCY once@1.4.0
                    │     │ │   │   └── UNMET DEPENDENCY wrappy@1.0.2
                    │     │ │   ├─┬ UNMET DEPENDENCY rc@1.2.8
                    │     │ │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
                    │     │ │   │ ├── UNMET DEPENDENCY ini@1.3.8
                    │     │ │   │ ├── UNMET DEPENDENCY minimist@1.2.5
                    │     │ │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
                    │     │ │   ├─┬ UNMET DEPENDENCY simple-get@4.0.1
                    │     │ │   │ ├─┬ UNMET DEPENDENCY decompress-response@6.0.0
                    │     │ │   │ │ └── UNMET DEPENDENCY mimic-response@3.1.0
                    │     │ │   │ ├── UNMET DEPENDENCY once@1.4.0
                    │     │ │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
                    │     │ │   ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
                    │     │ │   │ ├── UNMET DEPENDENCY chownr@1.1.4
                    │     │ │   │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                    │     │ │   │ ├── UNMET DEPENDENCY pump@3.0.0
                    │     │ │   │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
                    │     │ │   │   ├─┬ UNMET DEPENDENCY bl@4.1.0
                    │     │ │   │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                    │     │ │   │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                    │     │ │   │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                    │     │ │   │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                    │     │ │   │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
                    │     │ │   │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
                    │     │ │   │   ├── UNMET DEPENDENCY fs-constants@1.0.0
                    │     │ │   └─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
                    │     │ ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
                    │     │ ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
                    │     │ ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                    │     │ ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
                    │     │ ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                    │     │ │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                    │     │ ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
                    │     │ ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
                    │     │ ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
                    │     └── UNMET DEPENDENCY slip@1.0.2
                    ├── semver@5.7.1
                    └─┬ yargs@7.1.0
                      ├── camelcase@3.0.0
                      ├─┬ cliui@3.2.0
                      ├─┬ os-locale@1.4.0
                      │ └─┬ lcid@1.0.0
                      ├─┬ read-pkg-up@1.0.1
                      │ ├─┬ find-up@1.1.2
                      │ │ ├─┬ path-exists@2.1.0
                      │ │ │ └── pinkie-promise@2.0.1 deduped
                      │ │ └─┬ pinkie-promise@2.0.1
                      │ │   └── pinkie@2.0.4
                      │ └─┬ read-pkg@1.1.0
                      │   ├─┬ load-json-file@1.1.0
                      │   │ ├─┬ parse-json@2.2.0
                      │   │ │ └─┬ error-ex@1.3.2
                      │   │ │   └── is-arrayish@0.2.1
                      │   │ ├── pify@2.3.0
                      │   │ ├── pinkie-promise@2.0.1 deduped
                      │   │ └─┬ strip-bom@2.0.0
                      │   │   └── is-utf8@0.2.1
                      │   ├─┬ normalize-package-data@2.5.0
                      │   │ ├── hosted-git-info@2.8.8
                      │   │ ├─┬ resolve@1.17.0
                      │   │ │ └── path-parse@1.0.6
                      │   │ └─┬ validate-npm-package-license@3.0.4
                      │   │   ├─┬ spdx-correct@3.1.0
                      │   │   │ ├── spdx-expression-parse@3.0.0 deduped
                      │   │   │ └── spdx-license-ids@3.0.5
                      │   │   └─┬ spdx-expression-parse@3.0.0
                      │   │     ├── spdx-exceptions@2.3.0
                      │   │     └── spdx-license-ids@3.0.5 deduped
                      │   └─┬ path-type@1.1.0
                      │     ├── pify@2.3.0 deduped
                      ├── require-main-filename@1.0.1
                      ├── set-blocking@2.0.0
                      ├── which-module@1.0.0
                      ├── y18n@3.2.1
                      └─┬ yargs-parser@5.0.0
                        └── camelcase@3.0.0 deduped
                    npm ERR! missing: tr-O64@0.2.4, required by iobroker.inst@2.0.3
                    npm ERR! missing: iobroker.hue@3.5.31, required by iobroker.inst@2.0.3
                    npm ERR! missing: iobroker.zigbee@1.6.16, required by iobroker.inst@2.0.3
                    npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
                    npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.hue@3.5.31
                    npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.1
                    npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.zigbee@1.6.16
                    npm ERR! missing: typescript@4.5.4, required by iobroker.zigbee@1.6.16
                    npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigbee@1.6.16
                    npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
                    npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14.0.422
                    npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converters@14.0.422
                    npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.422
                    npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converters@14.0.422
                    npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
                    npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
                    npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
                    npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
                    npm ERR! missing: ms@2.1.2, required by debug@4.3.3
                    npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
                    npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
                    npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
                    npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
                    npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
                    npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
                    npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
                    npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
                    npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
                    npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
                    npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
                    npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
                    npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
                    npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
                    npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
                    npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
                    npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
                    npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
                    npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
                    npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
                    npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
                    npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
                    npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
                    npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
                    npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/binding-mock@9.2.4
                    npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
                    npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
                    npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bindings@9.2.8
                    npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bindings@9.2.8
                    npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
                    npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
                    npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
                    npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
                    npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
                    npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
                    npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
                    npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
                    npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
                    npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
                    npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
                    npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
                    npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
                    npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
                    npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
                    npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
                    npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
                    npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
                    npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
                    npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
                    npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
                    npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
                    npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
                    npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
                    npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
                    npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
                    npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
                    npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
                    npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
                    npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
                    npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
                    npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
                    npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
                    npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
                    npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
                    npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
                    npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
                    npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
                    npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
                    npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
                    npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
                    npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
                    npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
                    npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
                    npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
                    npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
                    npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
                    npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
                    npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
                    npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
                    npm ERR! missing: once@1.4.0, required by pump@3.0.0
                    npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
                    npm ERR! missing: ini@1.3.8, required by rc@1.2.8
                    npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
                    npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
                    npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
                    npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
                    npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
                    npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
                    npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
                    npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
                    npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
                    npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
                    npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
                    npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
                    npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/parser-readline@9.2.4
                    npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
                      M
                      M
                      Markus Faltermeier
                      #77
                      wieso npm v8?
                      Ich dachte ich habe v6 drauf. Das zeigt mir zumindest "npm -v" an
                      • M Markus Faltermeier
                        wieso npm v8?
                        #78
                        @markus-faltermeier sagte in Probleme bei Update von admin:
                        wieso npm v8?
                        und vorher war kein npm >6 drauf?
                          wieso npm v8?
                          M
                          M
                          Markus Faltermeier
                          #79
                          vorher hatte ich v7 drauf. Das haben wir aber ganz am anfang geändert. Da hatte ich den node js auf V14 upgedated und der npm war danach auf V6.14.16
                            #80
                            und npm v7 war ja nicht untätig. Damit wurde die package-lock.json in version2 geschrieben.
                            npm v6 braucht diese aber in v1
                            hab dir extra nochmal die Meldung aus dem Log zitiert
                            Lösch die package-lock.json. Die wird dann beim nächsten Aufruf von npm in der richtigen Version neu angelegt.
                              M
                              M
                              Markus Faltermeier
                              #81
                              bevor ich das jetzt falsch mache.
                              das geht doch so oder:
                              ins Verzeichnis /opt/iobroker wechseln und dann einfach
                              "rm package-lock.json"
                              Stimmt das?
                                Stimmt das?
                                #82
                                Stimmt das?
                                Weiß ich nicht!
                                kann dir jetzt nicht sagen wo die Datei liegt
                                  Stimmt das?
                                  Weiß ich nicht!
                                  M
                                  M
                                  Markus Faltermeier
                                  #83
                                  hab sie gelöscht.
                                  Jetzt ist die Warnung von oben weg.
                                  Die Ausgabe sieht jetzt folgendermaßen aus:
                                    Stimmt das?
                                    Weiß ich nicht!
                                    M
                                    M
                                    Markus Faltermeier
                                    #84
                                    jetzt komm ich in den IOBROKER gar nicht mehr rein :-(
                                    Keine Ahnung was hier los ist...
                                      M
                                      M
                                      Markus Faltermeier
                                      #85
                                      @markus-faltermeier
                                      bin wieder da :-)
                                      Jetzt blieb mir nichts anderes übrig als den IOBroker neu zu installieren.
                                      Geht ja mittlerweile viel einfacher als damals als ich den IOBROKER das letzte mal installiert habe.
                                      Ich vermute ich hab irgendetwas falsch gemacht, als ich den IOBROKER auf Bullseye upgedated habe...
                                      Kann ich leider nicht mehr nachvollziehen.
                                      Zum Glück hab ich tägliches Backup gemacht. Und es ist schön zu sehen, dass das zurückspielen auch klappt :-)
                                      Es waren alle Adapter wieder da. Leider auch die alten, die ich vorher gelöscht habe.
                                      Also den TR064 und Terminal hab ich dann gleich gelöscht.
                                      Jetzt scheint alles zu funktionieren
                                      Danke nochmal für Eure Hilfe und Geduld...
                                      LG Markus
