  4. Huawei Sun2000 & ioBroker via JS script funktioniert
    5.7k
481 Beiträge 62 Kommentatoren 158.5k Aufrufe 63 Beobachtet
  • R rainereglinsky
    @rainereglinsky Hilfe!
    hatte bis gestern ein toll funktionierenden Raspi 4 mit dem JS script laufen - alles war gut. Habe dann den Raspi fertig gemacht für den headless Betrieb - immer noch alles bestens.
    Heute bekomme ich keine Daten mehr aus meiner Sun 2000 ausgelesen - nur Fehlermeldungen. Habe schon das Backup von gestern neu eingespielt - gleiche Ergebnis.
    Auf meinem PC läuft das gleiche Script - ohne Probleme - alle Werte werden angezeigt.
    Hat jemand eine Idee????
    Hier Teile des Protokolls
    avascript.0
    2023-09-01 15:50:03.304 warn script.js.Huawei_Sun: Error received reading address 38200 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:58.303 warn script.js.Huawei_Sun: Error received reading address 37700 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:53.302 warn script.js.Huawei_Sun: Error received reading address 37100 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:48.303 warn script.js.Huawei_Sun: Error received reading address 37000 from id: 1 with error: undefined
    admin.0
    2023-09-01 15:49:46.330 info <== Disconnect system.user.admin from ::ffff:192.168.178.99 javascript
    admin.0
    admin.0
    2023-09-01 15:49:45.445 info ==> Connected system.user.admin from ::ffff:192.168.178.99
    javascript.0
    2023-09-01 15:49:43.302 warn script.js.Huawei_Sun: Error received reading address 32000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:38.302 warn script.js.Huawei_Sun: Error received reading address 38200 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:33.302 warn script.js.Huawei_Sun: Error received reading address 37700 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:28.302 warn script.js.Huawei_Sun: Error received reading address 37100 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:23.301 warn script.js.Huawei_Sun: Error received reading address 37000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:18.301 warn script.js.Huawei_Sun: Error received reading address 32000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:13.301 warn script.js.Huawei_Sun: Error received reading address 47081 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:08.301 warn script.js.Huawei_Sun: Error received reading address 38400 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:49:03.301 warn script.js.Huawei_Sun: Error received reading address 38300 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:58.301 warn script.js.Huawei_Sun: Error received reading address 37800 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:53.301 warn script.js.Huawei_Sun: Error received reading address 30000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:48.300 warn script.js.Huawei_Sun: Error received reading address 38200 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:43.300 warn script.js.Huawei_Sun: Error received reading address 37700 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:38.300 warn script.js.Huawei_Sun: Error received reading address 37100 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:33.299 warn script.js.Huawei_Sun: Error received reading address 37000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:28.299 warn script.js.Huawei_Sun: Error received reading address 32000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:23.299 warn script.js.Huawei_Sun: Error received reading address 38200 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:18.299 warn script.js.Huawei_Sun: Error received reading address 37700 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:13.299 warn script.js.Huawei_Sun: Error received reading address 37100 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:08.299 warn script.js.Huawei_Sun: Error received reading address 37000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:48:03.299 warn script.js.Huawei_Sun: Error received reading address 32000 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:47:58.298 warn script.js.Huawei_Sun: Error received reading address 38200 from id: 1 with error: undefined
    javascript.0
    2023-09-01 15:47:53.298 warn script.js.Huawei_Sun: Error received reading address 37700 from id: 1 with error: undefined
    juggi1962
    schrieb am zuletzt editiert von juggi1962
    #381
    @rainereglinsky du könntest das was R4 weiter oben geschrieben hat probieren.
    Du könntest versuchen in der Funktion readRegisterSpace() den auskommentierten Bereich zu aktivieren, also:
    function readRegisterSpace(id, address, length)
        client.setID(ModBusIDs[id-1]);
        client.readHoldingRegisters(address, length, function(err, data)
            if (err)
                if (err.modbusCode == null)
                {   console.warn("Lost connection to client. Trying to reconnect...");
                    ConnectModbus();
                } else
                console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
            else
            {   //console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                for (var i = 0; i < length; i++) Buffer[id-1][address + i - BufOffset] = data.data[i];
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #382
      Guten Tag,
      ich bräuchte mal Hilfe bei den Einstellungen.
      Hardware:
      • WR SUN2000-8KTL-M1
        2 Strings
        Battery 15 kWh mit 3 Modulen
        Energy Meter
      • WR SUN2000-6KTL-M1
        1 String
      anbei Bild von Fusionsolar:
      Die Verbindung zeigt connected.
      Könnt ihr mir mal sagen was einstellen ist (außer der IP).
      Also hier:
      var currentinverter = 2;
      oder hier:
      // Enter the Modbus-IDs of your Sun2000 inverters here (example for two inverters): const ModBusIDs = [16, 1];
      const ModBusIDs = [1];
      Ich weißt die ID nicht ?!
      oder hier:
      const BatteryUnits = [[3, 0]];
      Hab schon mit allem möglichen rum probiert.
      Irgendwie fehlen viele Werte und manche sind nicht plausibel.
      Danke.
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #383
        @Chris-b
        Könntest du mir da helfen ?
        Danke.
        C 1 Antwort Letzte Antwort
        • bahnuhrB bahnuhr
          @Chris-b
          Chris_B
          #384
          @bahnuhr Hallo - ich glaube der einzige wirkliche Fehler ist, dass Du zwar zwei Strings, aber 'nur' einen Inverter hast. In diesem Sinne müsste folgendes gesetzt sein:
          var currentinverter = 1;
          // On which Modbus-ID can we reach the power meter? (via Sun2000!)
          const PowerMeterID = 0;
          // Enter your battery stack setup. 2 dimensional array, e.g. [[3, 2], [3, 0]] means:
          // First inverter has two battery stacks with 3 + 2 battery modules
          // while second inverter has only one battery stack with 3 battery modules
          Das Setup entspricht eigentlich fast meinem Setup, einzig, dass ich nur einen String habe.
          Jetzt müsste man schauen was an Fehlermeldungen kommen. Und beachte: Gewisse Werte sind erst nach einmal Durchlaufen von Mitternacht wirklich sinnvoll.
          Gruss
          • C Chris_B
            Gruss
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #385
            @chris_b
            Ne ich habe 2 WR und insgesamt 3 Strings.
            WR 1: 2 Strings
            WR 2: 1 String
            Danke.
            B C 2 Antworten Letzte Antwort
            • bahnuhrB bahnuhr
              @chris_b
              WR 1: 2 Strings
              WR 2: 1 String
              baerengraben
              #386
              @bahnuhr Ich habe 2 WR, insgesamt 4 Strings und keine Batterie.
              Meine funktionierende Konfig:
              // Enter your inverter modbus IP and port here
              const ModBusPort = 502;
              const ModBusHost = "192.168.x.x"; //Dongle-IP auf WR1 (Master)
              const ModBusIDs = [1,2]; //Gem. Einstellung auf den WRs
              const BatteryUnits = [[0]];
              // These register spaces need to be read
              const RegToRead =
              [ [32000, 116],   // inverter status -                            read fast
                [37000, 68],    // battery information -                        read fast
                [37100, 114],   // meter info -                                 read fast
                [37700, 100],   // battery information -                        read fast
                [38200, 100],   // additional battery information -             read fast
                [30000, 81],    // model info, SN, max Power (static info) -    read slow
              //  [37800, 100],   // additional battery information -             read slow
              //  [38300, 100],   // additional battery information -             read slow
              //  [38400, 100],   // additional battery information -             read slow
              //  [47081, 2]      // additional battery information -             read slow
              //[35300, 40]     // inverter power adjustments -                 do not read
              const RegFast = 5;      // number of register spaces to read fast (must be < RegToRead.length)
              const RegFastMod = 3;  // read slow registers every n'th time (mod operator)
              var RegReadCnt = 0;     // Loop counter
              var RegToReadPtr = 0;   // pointer to register spaces
              Ich habe dann auch im Code noch einiges bezüglich Batterie auskommentiert. Das Script funktioniert damit seit rund 2 Wochen ohne Probleme.
              Mir ist aufgefallen, dass du currentinverter auf 2 gesetzt hast. Das ist aus meiner Sicht nicht korrekt. Das ist ja nur der "Pointer" auf den zu verarbeitenden Inverter, der hochgezählt wird.
                baerengraben
                #387
                @Chris_B Ich habe noch eine kleine Ergänzung für das Script. Die "Live-Daten" werden tiptop ausgelesen. Aber was mich eigentlich mindestens gleichviel interessiert, ist der aktuelle Status des Systems. Beispielsweise ist der Code für den WR-DeviceStatus vorhanden, nicht aber die konkrete Bedeutung des Codes. Ich habe hier dein Script bei mir folgendermassen ergänzt. Evtl. kannst du das für dich auch gebrauchen:
                // Zusätzliche States
                createState(JavaInst + "Solarpower.Huawei.Inverter.1.DeviceStatusName",   "",  {read: true, write: true, name: "Inverter 1 - Device Status Name"});
                    // Setze Device-Status Namen
                    // Inverter 1
                    var deviceStatusName = "";
                    switch (getState(JavaInst + SHI + "1.DeviceStatus").val)
                        case 0: deviceStatusName = "Initializing";break;
                        case 1: deviceStatusName = "Detecting ISO";break;
                        case 2: deviceStatusName = "Detecting irradiation";break;
                        case 3: deviceStatusName = "Grid detecting";break;
                        case 256: deviceStatusName = "Starting";break;
                        case 512: deviceStatusName = "On grid";break;
                        case 513: deviceStatusName = "On grid Power limit";break;
                        case 514: deviceStatusName = "On grid self derating";break;
                        case 768: deviceStatusName = "Shutdown fault";break;
                        case 769: deviceStatusName = "Shutdown command";break;
                        case 770: deviceStatusName = "Shutdown OVGR";break;
                        case 771: deviceStatusName = "Shutdown communication disconnected";break;
                        case 772: deviceStatusName = "Shutdown power limit";break;
                        case 773: deviceStatusName = "Shutdown start manually";break;
                        case 774: deviceStatusName = "Shutdown DC switch OFF";break;
                        case 1025: deviceStatusName = "Grid dispatch cos(Phi)-P curve";break;
                        case 1026: deviceStatusName = "Grid dispatch Q-U curve";break;
                        case 1280: deviceStatusName = "Spot-check";break;
                        case 1281: deviceStatusName = "Spot-checking";break;
                        case 1536: deviceStatusName = "Inspecting";break;
                        case 1792: deviceStatusName = "AFCI self-check";break;
                        case 2048: deviceStatusName = "I V scanning";break;
                        case 2304: deviceStatusName =" DC input detection";break;
                        case 40960: deviceStatusName = "No irradiation";break;
                        default: deviceStatusName = "undefined";break;
                    setState(JavaInst + SHI + "1.DeviceStatusName",  deviceStatusName);
                Zusätzlich wäre es auch super interessant die Bedeutungen von
                • SHI + id + ".State1
                • SHI + id + ".State2
                • SHI + id + ".State3
                • SHI + id + ".Alarm1
                • SHI + id + ".Alarm2
                • SHI + id + ".Alarm3
                • SHI + id + ".FaultCode"
                konkret zu kennen. Da bin ich aber noch nicht wirklich aus der Doku schlau geworden.
                • bahnuhrB bahnuhr
                  @chris_b
                  WR 1: 2 Strings
                  WR 2: 1 String
                  Chris_B
                  #388
                  @bahnuhr OK, sorry, habe nicht gesehen, dass du 2 Inverter hast. Also, ausmeiner Sicht, müsste das dann so aussehen:
                  const ModBusIDs = [1, 2];
                  const BatteryUnits = [[3, 0], [0, 0]];
                  Der von @baerengraben angegebene Array für die BatteryUnits ist nicht korrekt. Es kann laufen, aber das Programm greift potentiell auf nicht definierte Daten zu. Es muss für jeden WR angegeben werden, wie der potentiell vorhandene Batterystack aufgebaut ist. In diesem Fall: Am ersten WR hängt ein einfacher Battery Stack mit 3 Modulen, am zweiten hängt nichts (und auch das sollte spezifiziert werden).
                  Wichtig: PowerMeterID sagt, an welchem WR das PowerMeter hängt. In diesem Fall am erste WR.
                  Was mir nicht ganz klar ist sind die ModBusIDs. Bei nur einem WR ist das [1], bei zwei würde ich es einmal wie von @baerengraben vorgeschlagen ausprobieren, oder sonst mit der zweiten Zahl spielen...
                  Gruss
                  Gruss
                  • B baerengraben
                        // Inverter 1
                    Chris_B
                    #389
                    @baerengraben Ja, das ist auch noch ein Ausbau den ich machen wollte. Ich schau mir das an. Danke und Gruss
                      palantin
                      schrieb am zuletzt editiert von palantin
                      #390
                      vorweg herzlichen Dank für die Erstellung des Scripts.
                      Ich bekomme sauber Daten aus den Wechselrichtern.
                      meine Konfiguration: zwei Sun2000 8+6 KTL über Kaskade an einem Dongle und ein Smartmeter ebenfalls am Haupt-Wechselrichter. Ich bekomme Daten ins Fusion solar, aber bekomme keine Modbus Daten vom SmartMeter.
                      Wenn ich die PowerMeter id auf 0 setze, werden leere Datenpunkte erzeugt,
                      Setzte ich die id auf 11, was das offenbar die ID des SmartMeters sein dürfte laut Handyapp im Installateursaccount, wird der ganze Ordner nicht geschrieben und ich erhalte den Fehler: d575302c-224a-45d1-adf2-ba9c991cea01-image.png
                      Habe jeweils vor- einem neuen Test den ganzen Objektbaum in ioBroker gelöscht.
                      Hatte schon jemand so ein Verhalten?
                      Ich verwende die letztversion des Scripts
                      const ModBusHost = "192.168.1.137";
                      ConnectModbus();
                      const ModBusIDs = [1, 16];
                      Batterie verwende ich keine, daher habe ich ProcessBattery(i); auskommentiert in der Funktion ProcessData
                      • C Chris_B
                        Gruss
                        Gruss
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #391
                        @chris_b
                        @baerengraben
                        So, habe nun folgendes eingestellt:
                        Bekomme nun sehr viele DP gefüllt.
                        Const ModBusIDs = [16,1];
                        Bei diesen DP:
                        const RegToRead =
                          [47081, 8]      // additional battery information -             read slow
                        kommen Fehler im log:
                        javascript.0
                        2023-09-08 16:20:57.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 37700 from id: 1 with error: undefined
                        javascript.0
                        2023-09-08 16:20:52.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 37100 from id: 1 with error: undefined
                        javascript.0
                        2023-09-08 16:20:47.914	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 37000 from id: 1 with error: undefined
                        javascript.0
                        2023-09-08 16:20:42.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 32000 from id: 1 with error: undefined
                        javascript.0
                        2023-09-08 16:20:37.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 47081 from id: 16 with error: undefined
                        javascript.0
                        2023-09-08 16:20:32.914	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 38400 from id: 16 with error: undefined
                        javascript.0
                        2023-09-08 16:20:27.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 38300 from id: 16 with error: undefined
                        javascript.0
                        2023-09-08 16:20:27.883	warn	script.js.Scripte.Geraete.Huawei_Original_V4: Error received reading address 37700 from id: 16 with error: Slave device busy (retry request again later)
                        Soll/kann ich die einfach auskommentieren.
                        mfg
                        Danke.
                        P 1 Antwort Letzte Antwort
                        • J Offline
                          jokerjo1000
                          #392
                          ich hoffe ich darf das hier einmal schreiben?
                          Ich habe laienhafte Kenntnisse von der ganzen Materie, jedoch nicht ausreichend um hier mitzukommen.
                          Habe auch eine Huawei PV Anlage mit Wechselrichter Speicher und Power Meter. Auch ein Raspi mit Iobroker ist am laufen. Daten hole ich mir u.a. von Influx und evcc. Gerne würde ich die Modbus Daten in den Iobroker bekommen. Hier hört aber mein Wissenstand auf. Ihr schreibt hier viel was für Kenner etwas ist aber leider nicht für "Anfänger". Es wäre echt klasse wenn jemand vielleicht einmal Lust hat uns Laien etwas mitzunehmen. Habe versucht das Skript von Chris im Iobroker zu installieren, jedoch ohne Erfolg. Es haut lediglich nur Fehlermeldungen raus. Das liegt sicherlich an mir und ich würde mich freuen das auch einmal hin zu bekommen. Es wäre also schön wenn jemand uns Newbies etwas itnehmen könnte.
                          DANKE !!!
                          H 1 Antwort Letzte Antwort
                          • bahnuhrB bahnuhr
                            @chris_b
                            @baerengraben
                            Bei diesen DP:
                            const RegToRead =
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            mfg
                            palantin
                            #393
                            @bahnuhr hast du Daten unter "Meter"
                            • P palantin
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #394
                              @palantin sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                              ja, hat aber gedauert.
                              Danke.
                              • bahnuhrB bahnuhr
                                palantin
                                #395
                                @bahnuhr
                                welche Kommunikationsid steht bei dir in der SolarApp von Huawei vom SmartMeter?
                                • P palantin
                                  @bahnuhr
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #396
                                  @bahnuhr
                                  keine Ahnung was du meinst bzw. wo ich sowas finde
                                  Danke.
                                  • J jokerjo1000
                                    DANKE !!!
                                    hussi
                                    #397
                                    @jokerjo1000 Ich habe auch von Null angefangen. Evtl. kann ich dir Helfen.
                                    Der erste Schritt ist, dass du unter Instanzen in den Einstellungen von Javascript das NPM Modul "modbus-serial" hinzufügst. Dazu vorher:
                                    https://www.npmjs.com/package/modbus-serial
                                    Anschließend gehst du zu den Scripten und legst dir ein neues Javascript mit dem Inhalt von Chris´ github:
                                    https://github.com/ChrisBCH/SunLuna2000_iobroker
                                    Dann müssen in dem Script die Daten deiner PV Anlage eingegeben werden. IP, etc.
                                    Nun solltest du die Daten in den Objekten unter javascript > 0 > Solarpower sehen.
                                    • B badsnoopy667
                                      @pettyboo
                                      Ich hab es jetzt hinbekommen Register zu schreiben! Ich kann jetzt die maximale Entladeleistung der Batterie auf 0 setzen wenn das eAuto lädt.
                                      Ich hab es mit node-red gemacht. Hier der Flow für das eine Register:
                                      flows.json
                                      Den Wert den man einstellen will, z.B. 400 Watt schreibt man in den SET Datenpunkt (vorher anlegen!). Das Hauptproblem ist, dass der Wert in zwei Register geschrieben werden muss. Also muss er aufgeteilt werden. Das macht der Funktions-Node im Flow. Einfach mal ausprobieren, ich glaub man kann nicht viel kaputt machen, falsche Werte nimmt der WR nicht an. (Ohne Garantie!)
                                      Hier nochmal die Modbus Interface Definitions V3, ohne die geht's nicht:
                                      https://forum.iobroker.net/assets/uploads/files/1624831109365-solar-inverter-modbus-interface-definitions-v3.0.pdf
                                      Viel Erfolg!
                                      0 Offline
                                      0 Offline
                                      0815_Peter
                                      #398
                                      @badsnoopy667
                                      Hallo in die Runde,
                                      vielleicht hab ich was überlesen bei den 395 Antworten, wenn ja bitte entschuldigt.
                                      Das schreiben der U32 Zahl (Maximum Charge and Discharge Power) funktioniert mit den Flow vom badsnoopy667 hab vielen dank.
                                      Wenn ich die % Werte der SOC Charge Cutoff und Discharge Cutoff einstellen will muss ich eine U16 Zahl schicken zum WR.
                                      Ich werde aus der Beschreibung für die Funktion im Flow nicht so richtig schlau.
                                      https://stevesnoderedguide.com/modbus-writing-data
                                      Das mit den GAIN habe ich schon beachtet --> eine 100 sind 10% --> trotzdem will der WR meine Werte nicht :-( also sollte es auch der Funktion liegen die den String aufarbeitet.
                                      Kann mir bitte jemand helfen wie die Funktion im Flow aussehen muss, damit der WR die % Werte annimmt die geschickt werden.
                                      B 1 Antwort Letzte Antwort
                                      • 0 0815_Peter
                                        @badsnoopy667
                                        Hallo in die Runde,
                                        badsnoopy667
                                        #399
                                        @0815_peter
                                        Ich glaube Du hast in den falschen Thread gepostet.
                                        Aber versuch's mal hiermit:
                                        var fc = 16;
                                        var sa = 50;
                                        var addresses = 2;
                                        var buf = Buffer.alloc(2); // create a buffer with 2 bytes for UINT16
                                        buf.writeUInt16BE(msg.payload); // write UINT16 value to the buffer
                                        var value = buf.readUInt16BE(); // read the UINT16 value from the buffer
                                        msg.slave_ip = "192.168.1.76";
                                        msg.payload = value;
                                        return msg;
                                        • 0 Offline
                                          0 Offline
                                          0815_Peter
                                          #400
                                          @badsnoopy667
                                          Danke für deine Antwort
                                          okay ich hab hier geantwortet, da du am Anfang von diesen Thread gezeigt hast wie du auf die Register schreibst.
                                          Leider klappt deine Funktion nicht...der WR nimmt die Werte nicht :-(
                                          ich hab meinen Flow mal hier angehangen vielleicht sieht du ja gleich den Fehler.
                                          flows.json
