  4. js-controller 4.0 jetzt im BETA/LATEST!
    6.3k
747 Beiträge 70 Kommentatoren 277.4k Aufrufe 60 Beobachtet
  • C Offline
    ChrisXY
    #121
    Bei mir sind folgende fehler gekommen. Danach liefen fast keine Adapter alle Lese/Schreib Probleme wohl...
    iob fix hilft nicht
    root@iobroker:/# iob upgrade self
    Update js-controller from @3.3.22 to @4.0.4
    NPM version: 6.14.10
    npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(unix_dgram, Initialize)
    Im log auch bisschen was:
    host.iobroker
    2022-02-08 10:01:30.519	error	instance system.adapter.hm-rpc.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2022-02-08 10:01:30.519	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:81:21)
    host.iobroker
    2022-02-08 10:01:30.519	error	Caught by controller[0]: at doListen (net.js:1503:7)
    host.iobroker
    2022-02-08 10:01:30.519	error	Caught by controller[0]: at listenInCluster (net.js:1366:12)
    host.iobroker
    2022-02-08 10:01:30.519	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1301:21)
    host.iobroker
    2022-02-08 10:01:30.519	error	Caught by controller[0]: Error: listen EADDRNOTAVAIL: address not available 192.168.2.200:2001
    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
    • C ChrisXY
      iob fix hilft nicht
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      #122
      @chrisxy sagte in js-controller 4.0 jetzt im BETA/LATEST!:
      Außer
      root@iobroker
      sind da keine Fehler zu sehen.
      C 1 Antwort Letzte Antwort
      • H homecineplexx
        @apollon77 hallo, sieht das nicht etwas komisch aus?
        iobroker status
        (node:10529) Warning: Accessing non-existent property 'count' of module exports inside circular dependency
        (Use `node --trace-warnings ...` to show where the warning was created)
        (node:10529) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency
        (node:10529) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
        (node:10529) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
        Objects type: jsonl
        States  type: jsonl
        crunchipC Abwesend
        crunchipC Abwesend
        #123
        @homecineplexx hatte ich auch
        @apollon77 bin soeben auf v4, habe allerdings danach ein paar Adapter Update's angestoßen, die Meldung kommt bei jedem Adapter update
        2022-02-08 09:44:29.782 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
        2022-02-08 09:44:29.818 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
        2022-02-08 09:45:52.304 - info: shelly.0 (653) Got terminate signal TERMINATE_YOURSELF
        2022-02-08 09:45:52.305 - info: shelly.0 (653) Closing Adapter
        2022-02-08 09:46:12.167 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
        2022-02-08 09:46:12.171 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
        2022-02-08 09:46:12.774 - info: shuttercontrol.0 (1872) Adapter is disabled => stop
        2022-02-08 09:46:12.783 - info: shuttercontrol.0 (1872) cleaned everything up...
        2022-02-08 09:58:07.286 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)(node:14307) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:14307) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
        2022-02-08 09:58:07.293 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
        2022-02-08 09:59:24.076 - info: trashschedule.0 (2332) Got terminate signal TERMINATE_YOURSELF
        2022-02-08 09:59:24.078 - info: trashschedule.0 (2332) cleaned everything up...
        2022-02-08 10:01:14.838 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
        2022-02-08 10:01:14.853 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
        2022-02-08 10:02:40.396 - info: jarvis.0 (1316) Got terminate signal TERMINATE_YOURSELF
        2022-02-08 10:02:40.423 - info: jarvis.0 (1316) Adapter stopped und unloaded.
        Nachtrag:
        habe das nun eine Weile beobachtet, an der Performance hat sich nicht groß was verändert, da ich sowieso schon jsonl verwende, jedoch sehe ich nun einen erhöhten Ram Verbrauch, ob das vom Controller Update kommt oder den 4 Adapter Updates geschuldet ist, keine Ahnung.
          Außer
          root@iobroker
          ChrisXY
          #124
          @thomas-braun wie den besser?
          Nochmal Installieren auch iob fix bringr das:
          root@iobroker:/# sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/debug
          npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/node-forge
          npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/semver
          npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/mime
          npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/tar
          npm WARN checkPermissions Missing write access to /node_modules/@iobroker
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/@iobroker/js-controller-cli/node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN enoent ENOENT: no such file or directory, open '/package.json'
          npm WARN !invalid#1 No description
          npm WARN !invalid#1 No repository field.
          npm WARN !invalid#1 No README data
          npm WARN !invalid#1 No license field.
          npm ERR! code EACCES
          npm ERR! syscall access
          npm ERR! path /node_modules/iobroker.js-controller/node_modules/debug
          npm ERR! errno -13
          npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'
          npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'] {
          npm ERR!   errno: -13,
          npm ERR!   code: 'EACCES',
          npm ERR!   syscall: 'access',
          npm ERR!   path: '/node_modules/iobroker.js-controller/node_modules/debug'
          npm ERR! }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator.
          npm ERR!     /home/iobroker/.npm/_logs/2022-02-08T09_17_51_107Z-debug.log
          • C ChrisXY
            npm ERR! errno -13
            npm ERR! }
            npm ERR!
            npm ERR!
            #125
            seufz
            Kommt vermutlich vom rumgehampel als root.
            iobroker stop
            iobroker fix
            versuchen.
              seufz
              iobroker stop
              iobroker fix
              versuchen.
              ChrisXY
              schrieb am zuletzt editiert von ChrisXY
              #126
              Kann sein aber das mach ich so schon seit Jahren. Früher war das doch oft so?
              fix habe ich natürlich schon Probiert.
              Werde ich wohl ein Backup zurückspielen müssen komisch .. bisher gab es nie Probleme alles sauber durch.
              • C ChrisXY
                #127
                Dann machst du es seit Jahren falsch. Als root meldet man sich seit 'ewig' nicht mehr an.
                  ChrisXY
                  #128
                  @thomas-braun okay ja das ist die Proxmox Konsole
                  E 1 Antwort Letzte Antwort
                  • C ChrisXY
                    e-s
                    #129
                    @chrisxy auch mal wieder falscher Ordner, versuche es mal in /opt/iobroker
                    • E e-s
                      ChrisXY
                      #130
                      @e-s Danke da habe ich keine Fehler bekommen. Jedoch bei iobroker Start kommt auch die Migrations meldung. Aber mein iobroker Menü links ist auch leer. Zigbee usw. alles fehlt. Einige Adapter werden auch nicht mehr grün
                      Fhem, Zigbee ... ich lass iobroker mal etwas Zeit
                      iobroker status sagt auch nicht mehr redis
                      Objects type: file
                      States type: file
                      Scheinbar beim Update mein Redis verloren gegangen. Bekomm es auch nicht hin iob fix usw.. immer Zugriffs Probleme
                      Connecting to previous DB "file"...
                      Creating backup ...
                      This can take some time ... please be patient!
                      host.iobroker 19727 states saved
                      host.iobroker 22369 objects saved
                      Backup created: /opt/iobroker/backups/2022_02_08-12_52_25_backupiobroker-migration.tar.gz
                      updating conf/iobroker.json
                      Uncaught Rejection: Error: EACCES: permission denied, open '/iobroker-data/iobroker.json.bak'
                          at Object.openSync (fs.js:476:3)
                          at Object.writeFileSync (fs.js:1467:35)
                          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:521:24
                      This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      root@iobroker:/dev# iob status
                      iobroker is not running on this host.
                      Objects type: file
                      States  type: file
                      • OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #131
                        Hallo hier meine Erkenntnisse des Tests. Ob die alle durch den js-controller verursacht sind weiß ich nicht. sind aber auch keine Kriitischen Fehler:
                        Ausganslage:
                        Getestet wird in einem docker-container auf Basis buanet/iobroker:latest in einem macvlan. volumes wurden nicht in einen Ordner herausgeführt
                        docker-compose-file
                        version: '2.1'
                        services:
                          iobrokertest4_0_0:
                            restart: always
                            image: buanet/iobroker:latest
                            container_name: iobrokertest4_0_0
                            hostname: iobrokertest4_0_0
                            ports:
                              - "8081:8081"
                            volumes:
                              - iobrokertest4_0_0:/opt/iobroker
                            networks:
                              dockerMACVLAN:
                                ipv4_address: 192.168.1.87
                        networks:
                          dockerMACVLAN:
                            external: true
                        volumes:
                          iobrokertest4_0_0:
                        Testablauf
                        Nach Erzeugen des Containers wurden das repo auf latest gesetzt. Hier ist mir aufgefallen, das beim Speichern des Konfigurationsdialog eine Fehlermeldung auftrat "DB cannot be read " oder so ähnlich. Der Dialog konnte nicht geschlossen werden, sondern man musste erneut die http-adresse des iobrokers eingeben.
                        Fehler/Problem1: Beim Speichern des Konfigurationsdialog konnte der Dialog nicht geschlossen werden.
                        im Anschluss habe ich alle Adapter aktualisiert
                        Danach Update von js-controller
                        Fehler/Problem2: Bei den Hinweisen gibt es einen Fehler im adapterfixer. Es fehlt ein leerzeichen zwischen bash und -
                        curl -sL https://iobroker.net/fix.sh | bash-
                        upgrade lief soweit gut, bis auf die oben bereits benannten Probleme (angezeigte Fehlermeldungen, Fixer muss durchgeführt werden, sonst Fehlermeldung "operation not permittet"
                        Im Anschluss dann noch Update des Admin-Adapters
                        Beim installieren von Adaptern traten 2 Probleme auf.
                        Der Adapter hat eine Abhängigkeit zu vis, vis eine Abhängigkeit zu web. Beide wurden auch installiert, nur am Ende brach die Installation des eigentlichen Adapters mit Fehlermeldung ab (meldung landete nicht im log)
                        Fehler/Problem3:
                        Bei Installation von Adaptern mit Abhängigkeiten zu vis/web wird der eigentliche Adapter nicht installiert.
                        Ein erneuter Aufruf der Installation endete dann mit der folgenden Fehlermeldung
                        iobroker adapter "rssfeed" cannot be installed: Cannot read property 'startsWith' of undefined
                        iobroker adapter "tvprogram" cannot be installed: Cannot read property 'startsWith' of undefined
                        Fehler/Problem4:
                        Innerhalb einer gewissen zeit nach Umstellung und Start von iobroker können keine Adapter installiert werden. Das sollte über eine Meldung dem Nutzer signalisiert werden.
                        Nach einer gewissen Zeit, klappte dann die erneute Installation der Adapter
                        Meine Adapter und Widgets
                        Links im Profil
                        AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                        • OliverIOO OliverIO
                          Ausganslage:
                          docker-compose-file
                          version: '2.1'
                          services:
                            iobrokertest4_0_0:
                              restart: always
                              ports:
                                - "8081:8081"
                              volumes:
                              networks:
                                dockerMACVLAN:
                          networks:
                            dockerMACVLAN:
                              external: true
                          volumes:
                            iobrokertest4_0_0:
                          Testablauf
                          Fehler/Problem3:
                          Fehler/Problem4:
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #132
                          @oliverio sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                          Wenn ich das oben im Post markieren und kopiere, ist da ein Leerzeichen.
                          @apollon77 vielleicht als Block-Code formatieren?
                          • AlCalzoneA AlCalzone
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #133
                            @alcalzone
                            Links im Profil
                              @alcalzone
                              #134
                              @oliverio Mist, dann ist der Fallback text im Admin falsch ... Bitte Admin Issue anlegen - bzw es gibt eins von Feuersturm das der Fallback Text anstelle ein anderer angezeigt wird ... da am besten dazu bitte
                              • apollon77A apollon77
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #135
                                @apollon77
                                https://github.com/ioBroker/ioBroker.admin/issues/1311#issuecomment-1032599083
                                Links im Profil
                                • apollon77A Offline
                                  #136
                                  @ice987 @fastfoot einer Von euch mal Zeit für nen docker test einer neuen Version die hoffentlich das "iob fix nach erstem Start" weg machen sollte ... ? Bitte mich mal direkt anschreiben
                                  EDIT: habs mit @fastfoot probiert. Fix tut. :-) Kommt bald offiziell
                                  • C ChrisXY
                                    iob fix hilft nicht
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    #137
                                    Da scheint irgendetwas anderes auf Port 2001 zu Hören, und daher kann der Adapter nicht starten ... Stelle sicher das da nicht noch Zombie Prozesse laufen
                                      Nachtrag:
                                      #138
                                      @crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                      Kannst Das ggf nochmal versuchen nachzustellen und dazu das kommando anstelle über "iob upgrade name" mal mittels ´node --trace-warnings /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade name` machen ... dann sollten mehr infos kommen ...
                                      crunchipC 2 Antworten Letzte Antwort
                                      • C ChrisXY
                                        #139
                                        Naja, npm macht hier inzwischen auch einige Dinge sehr anders ... also "vor einigen Jahren" war auch da einiges anders. Inzwischen verhält sich mit aktuelleren npm Versionen hier einiges anders bzw manchmal wie ne Diva
                                        • C ChrisXY
                                          Objects type: file
                                          States type: file
                                          Creating backup ...
                                          Objects type: file
                                          States  type: file
                                          #140
                                          @chrisxy Ääähmm ... was Hast Du genau hier getan? Das ist ist ein Migration-Prozess ... so mir scheint es als ob du aktiv über "iob setup custom" eine Migration zu "file" gemacht hast und dabei gab es einen Permission Fehler.
                                          Um es jetzt zu fixen:
                                          1.) iob fix um die Rechtefehler zu fixen
                                          2.) Wenn DU zurück zum letzten Redis Stand willst editiere die /opt/iobroker/iobroker-data/iobroker.json und ändere bei objects und states jeweils den Typ in "redis" da wo jetzt scheinbar "file" steht.
                                          Danach sollte erstmal alles wieder laufen
