  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
    @chrisxy sagte in js-controller 4.0 jetzt im BETA/LATEST!:
    Außer
    root@iobroker
    sind da keine Fehler zu sehen.
    ChrisXY
    #124
    @thomas-braun wie den besser?
    Nochmal Installieren auch iob fix bringr das:
    root@iobroker:/# sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/debug
    npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/node-forge
    npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/semver
    npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/mime
    npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/tar
    npm WARN checkPermissions Missing write access to /node_modules/@iobroker
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/@iobroker/js-controller-cli/node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN enoent ENOENT: no such file or directory, open '/package.json'
    npm WARN !invalid#1 No description
    npm WARN !invalid#1 No repository field.
    npm WARN !invalid#1 No README data
    npm WARN !invalid#1 No license field.
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /node_modules/iobroker.js-controller/node_modules/debug
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'
    npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/node_modules/iobroker.js-controller/node_modules/debug'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-08T09_17_51_107Z-debug.log
    • C ChrisXY
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      #125
      seufz
      Kommt vermutlich vom rumgehampel als root.
      iobroker stop
      iobroker fix
      versuchen.
      C 1 Antwort Letzte Antwort
        seufz
        iobroker stop
        iobroker fix
        versuchen.
        ChrisXY
        schrieb am zuletzt editiert von ChrisXY
        #126
        Kann sein aber das mach ich so schon seit Jahren. Früher war das doch oft so?
        fix habe ich natürlich schon Probiert.
        Werde ich wohl ein Backup zurückspielen müssen komisch .. bisher gab es nie Probleme alles sauber durch.
        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
        • C ChrisXY
          #127
          Dann machst du es seit Jahren falsch. Als root meldet man sich seit 'ewig' nicht mehr an.
            ChrisXY
            #128
            @thomas-braun okay ja das ist die Proxmox Konsole
            E 1 Antwort Letzte Antwort
            • C ChrisXY
              e-s
              #129
              @chrisxy auch mal wieder falscher Ordner, versuche es mal in /opt/iobroker
              • E e-s
                ChrisXY
                #130
                @e-s Danke da habe ich keine Fehler bekommen. Jedoch bei iobroker Start kommt auch die Migrations meldung. Aber mein iobroker Menü links ist auch leer. Zigbee usw. alles fehlt. Einige Adapter werden auch nicht mehr grün
                Fhem, Zigbee ... ich lass iobroker mal etwas Zeit
                iobroker status sagt auch nicht mehr redis
                Objects type: file
                States type: file
                Scheinbar beim Update mein Redis verloren gegangen. Bekomm es auch nicht hin iob fix usw.. immer Zugriffs Probleme
                Connecting to previous DB "file"...
                Creating backup ...
                This can take some time ... please be patient!
                host.iobroker 19727 states saved
                host.iobroker 22369 objects saved
                Backup created: /opt/iobroker/backups/2022_02_08-12_52_25_backupiobroker-migration.tar.gz
                updating conf/iobroker.json
                Uncaught Rejection: Error: EACCES: permission denied, open '/iobroker-data/iobroker.json.bak'
                    at Object.openSync (fs.js:476:3)
                    at Object.writeFileSync (fs.js:1467:35)
                    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:521:24
                This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                root@iobroker:/dev# iob status
                iobroker is not running on this host.
                Objects type: file
                States  type: file
                • OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #131
                  Hallo hier meine Erkenntnisse des Tests. Ob die alle durch den js-controller verursacht sind weiß ich nicht. sind aber auch keine Kriitischen Fehler:
                  Ausganslage:
                  Getestet wird in einem docker-container auf Basis buanet/iobroker:latest in einem macvlan. volumes wurden nicht in einen Ordner herausgeführt
                  docker-compose-file
                  version: '2.1'
                  services:
                    iobrokertest4_0_0:
                      restart: always
                      image: buanet/iobroker:latest
                      container_name: iobrokertest4_0_0
                      hostname: iobrokertest4_0_0
                      ports:
                        - "8081:8081"
                      volumes:
                        - iobrokertest4_0_0:/opt/iobroker
                      networks:
                        dockerMACVLAN:
                          ipv4_address: 192.168.1.87
                  networks:
                    dockerMACVLAN:
                      external: true
                  volumes:
                    iobrokertest4_0_0:
                  Testablauf
                  Nach Erzeugen des Containers wurden das repo auf latest gesetzt. Hier ist mir aufgefallen, das beim Speichern des Konfigurationsdialog eine Fehlermeldung auftrat "DB cannot be read " oder so ähnlich. Der Dialog konnte nicht geschlossen werden, sondern man musste erneut die http-adresse des iobrokers eingeben.
                  Fehler/Problem1: Beim Speichern des Konfigurationsdialog konnte der Dialog nicht geschlossen werden.
                  im Anschluss habe ich alle Adapter aktualisiert
                  Danach Update von js-controller
                  Fehler/Problem2: Bei den Hinweisen gibt es einen Fehler im adapterfixer. Es fehlt ein leerzeichen zwischen bash und -
                  curl -sL https://iobroker.net/fix.sh | bash-
                  upgrade lief soweit gut, bis auf die oben bereits benannten Probleme (angezeigte Fehlermeldungen, Fixer muss durchgeführt werden, sonst Fehlermeldung "operation not permittet"
                  Im Anschluss dann noch Update des Admin-Adapters
                  Beim installieren von Adaptern traten 2 Probleme auf.
                  Der Adapter hat eine Abhängigkeit zu vis, vis eine Abhängigkeit zu web. Beide wurden auch installiert, nur am Ende brach die Installation des eigentlichen Adapters mit Fehlermeldung ab (meldung landete nicht im log)
                  Fehler/Problem3:
                  Bei Installation von Adaptern mit Abhängigkeiten zu vis/web wird der eigentliche Adapter nicht installiert.
                  Ein erneuter Aufruf der Installation endete dann mit der folgenden Fehlermeldung
                  iobroker adapter "rssfeed" cannot be installed: Cannot read property 'startsWith' of undefined
                  iobroker adapter "tvprogram" cannot be installed: Cannot read property 'startsWith' of undefined
                  Fehler/Problem4:
                  Innerhalb einer gewissen zeit nach Umstellung und Start von iobroker können keine Adapter installiert werden. Das sollte über eine Meldung dem Nutzer signalisiert werden.
                  Nach einer gewissen Zeit, klappte dann die erneute Installation der Adapter
                  Meine Adapter und Widgets
                  Links im Profil
                  AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                  • OliverIOO OliverIO
                    Ausganslage:
                    docker-compose-file
                    version: '2.1'
                    services:
                      iobrokertest4_0_0:
                        restart: always
                        ports:
                          - "8081:8081"
                        volumes:
                        networks:
                          dockerMACVLAN:
                    networks:
                      dockerMACVLAN:
                        external: true
                    volumes:
                      iobrokertest4_0_0:
                    Testablauf
                    Fehler/Problem3:
                    Fehler/Problem4:
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #132
                    @oliverio sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                    Wenn ich das oben im Post markieren und kopiere, ist da ein Leerzeichen.
                    @apollon77 vielleicht als Block-Code formatieren?
                    • AlCalzoneA AlCalzone
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #133
                      @alcalzone
                      Links im Profil
                        @alcalzone
                        #134
                        @oliverio Mist, dann ist der Fallback text im Admin falsch ... Bitte Admin Issue anlegen - bzw es gibt eins von Feuersturm das der Fallback Text anstelle ein anderer angezeigt wird ... da am besten dazu bitte
                        • apollon77A apollon77
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #135
                          @apollon77
                          https://github.com/ioBroker/ioBroker.admin/issues/1311#issuecomment-1032599083
                          Links im Profil
                          • apollon77A Offline
                            #136
                            @ice987 @fastfoot einer Von euch mal Zeit für nen docker test einer neuen Version die hoffentlich das "iob fix nach erstem Start" weg machen sollte ... ? Bitte mich mal direkt anschreiben
                            EDIT: habs mit @fastfoot probiert. Fix tut. :-) Kommt bald offiziell
                            • C ChrisXY
                              Bei mir sind folgende fehler gekommen. Danach liefen fast keine Adapter alle Lese/Schreib Probleme wohl...
                              iob fix hilft nicht
                              root@iobroker:/# iob upgrade self
                              Update js-controller from @3.3.22 to @4.0.4
                              NPM version: 6.14.10
                              npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              In file included from ../src/unix_dgram.cc:5:
                              ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
                              ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
                                   , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                              In file included from ../../nan/nan.h:54,
                              ../src/unix_dgram.cc: At global scope:
                              /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                     (node::addon_register_func) (regfunc),                          \
                              /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
                                 NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                              ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                               NODE_MODULE(unix_dgram, Initialize)
                              Im log auch bisschen was:
                              host.iobroker
                              2022-02-08 10:01:30.519	error	instance system.adapter.hm-rpc.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.iobroker
                              2022-02-08 10:01:30.519	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:81:21)
                              host.iobroker
                              2022-02-08 10:01:30.519	error	Caught by controller[0]: at doListen (net.js:1503:7)
                              host.iobroker
                              2022-02-08 10:01:30.519	error	Caught by controller[0]: at listenInCluster (net.js:1366:12)
                              host.iobroker
                              2022-02-08 10:01:30.519	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1301:21)
                              host.iobroker
                              2022-02-08 10:01:30.519	error	Caught by controller[0]: Error: listen EADDRNOTAVAIL: address not available 192.168.2.200:2001
                              #137
                              Da scheint irgendetwas anderes auf Port 2001 zu Hören, und daher kann der Adapter nicht starten ... Stelle sicher das da nicht noch Zombie Prozesse laufen
                                @homecineplexx hatte ich auch
                                @apollon77 bin soeben auf v4, habe allerdings danach ein paar Adapter Update's angestoßen, die Meldung kommt bei jedem Adapter update
                                2022-02-08 09:44:29.782 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
                                2022-02-08 09:44:29.818 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                                2022-02-08 09:45:52.304 - info: shelly.0 (653) Got terminate signal TERMINATE_YOURSELF
                                2022-02-08 09:45:52.305 - info: shelly.0 (653) Closing Adapter
                                2022-02-08 09:46:12.167 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
                                2022-02-08 09:46:12.171 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                                2022-02-08 09:46:12.774 - info: shuttercontrol.0 (1872) Adapter is disabled => stop
                                2022-02-08 09:46:12.783 - info: shuttercontrol.0 (1872) cleaned everything up...
                                2022-02-08 09:58:07.286 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)(node:14307) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:14307) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
                                2022-02-08 09:58:07.293 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                                2022-02-08 09:59:24.076 - info: trashschedule.0 (2332) Got terminate signal TERMINATE_YOURSELF
                                2022-02-08 09:59:24.078 - info: trashschedule.0 (2332) cleaned everything up...
                                2022-02-08 10:01:14.838 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
                                2022-02-08 10:01:14.853 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                                2022-02-08 10:02:40.396 - info: jarvis.0 (1316) Got terminate signal TERMINATE_YOURSELF
                                2022-02-08 10:02:40.423 - info: jarvis.0 (1316) Adapter stopped und unloaded.
                                Nachtrag:
                                habe das nun eine Weile beobachtet, an der Performance hat sich nicht groß was verändert, da ich sowieso schon jsonl verwende, jedoch sehe ich nun einen erhöhten Ram Verbrauch, ob das vom Controller Update kommt oder den 4 Adapter Updates geschuldet ist, keine Ahnung.
                                #138
                                @crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                Kannst Das ggf nochmal versuchen nachzustellen und dazu das kommando anstelle über "iob upgrade name" mal mittels ´node --trace-warnings /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade name` machen ... dann sollten mehr infos kommen ...
                                • C ChrisXY
                                  #139
                                  Naja, npm macht hier inzwischen auch einige Dinge sehr anders ... also "vor einigen Jahren" war auch da einiges anders. Inzwischen verhält sich mit aktuelleren npm Versionen hier einiges anders bzw manchmal wie ne Diva
                                  • C ChrisXY
                                    Objects type: file
                                    States type: file
                                    Creating backup ...
                                    Objects type: file
                                    States  type: file
                                    #140
                                    @chrisxy Ääähmm ... was Hast Du genau hier getan? Das ist ist ein Migration-Prozess ... so mir scheint es als ob du aktiv über "iob setup custom" eine Migration zu "file" gemacht hast und dabei gab es einen Permission Fehler.
                                    Um es jetzt zu fixen:
                                    1.) iob fix um die Rechtefehler zu fixen
                                    2.) Wenn DU zurück zum letzten Redis Stand willst editiere die /opt/iobroker/iobroker-data/iobroker.json und ändere bei objects und states jeweils den Typ in "redis" da wo jetzt scheinbar "file" steht.
                                    Danach sollte erstmal alles wieder laufen
                                      Ausganslage:
                                      docker-compose-file
                                      version: '2.1'
                                      services:
                                        iobrokertest4_0_0:
                                          restart: always
                                          ports:
                                            - "8081:8081"
                                          volumes:
                                          networks:
                                            dockerMACVLAN:
                                      networks:
                                        dockerMACVLAN:
                                          external: true
                                      volumes:
                                        iobrokertest4_0_0:
                                      Testablauf
                                      Fehler/Problem3:
                                      Fehler/Problem4:
                                      #141
                                      @oliverio Zu Fehler 1: Ich verstehe nicht was Du meinst. Hast Du da mehr Infos? Screenshot? Whatever?
                                      zu Fehler 3: Unbekannt, bitte GitHub issue anlegen. Und am besten mehr logs bitte und so. Ich kann DAS nicht niachstellen, aber sehe ein anderes issue wenn ich tvprogram installiere und weder web noch vis habe
                                      Zu Fehler 4: Keine Ahnung was du meinst? Was sagt das system am anfang? Die Installation sollte an sich davon unabhängig sein ...Mehr details und Logs bitte
                                        m0rph
                                        schrieb am zuletzt editiert von m0rph
                                        #142
                                        Also ich kann nach dem Update keine adapter mehr updaten, das Update selbst ist ohne Probleme durchgelaufen bis auf die erwarteten Fehler.
                                        • M m0rph
                                          #143
                                          @m0rph Was bedeutet "kannst nicht mehr updaten"? Fehlermeldung?
