  4. Alpha Test js-controller 4.0
196 Beiträge 20 Kommentatoren 39.6k Aufrufe 22 Beobachtet
    @apollon77
    Edgy (node17/npm8) Testing meldet beim Upgrade von Adaptern:
    RangeError: Maximum call stack size exceeded
    Cannot upgrade: Maximum call stack size exceeded
    echad@chet:~ $ iobroker update -u && iobroker upgrade all
    Used repository: live-beta
    Adapter    "socketio"     : 4.1.0    , installed 4.0.3  [Updatable]
    Adapter    "web"          : 4.1.0    , installed 4.0.1  [Updatable]
    Exception in PromiseRejectCallback:
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:139
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:128
                await this.upgradeAdapterHelper(repo, sortedAdapters, forceDowngrade, autoConfirm);
    echad@chet:~ $
    @thomas-braun GitHub Issue im Controller bitte
    Thomas BraunT arteckA 2 Antworten Letzte Antwort
    • apollon77A apollon77
      @apollon77
      Einzeln lief es jetzt durch:
      iobroker upgrade web
      war okay, danach war angeblich socketio auch aktualisiert.
        arteckA Offline
        arteckA Offline
        arteck
        @apollon77 das ist der
        J:\source\ioBroker\SmartHome2>iobroker upgrade all
        J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:139
        J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:128
        • M mrjeschke
          @apollon77
          Nach dem update auf den js-controller 4 bekomme ich wieder invalid
          Type errors.
          2022-01-31 23:45:51.995 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
          2022-01-31 23:45:51.996 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
          2022-01-31 23:45:51.998 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
          2022-01-31 23:45:51.999 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
          2022-01-31 23:45:52.000 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
          2022-01-31 23:45:52.000 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
          2022-01-31 23:45:52.002 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
          2022-01-31 23:45:52.002 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
          2022-01-31 23:45:52.003 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
          2022-01-31 23:45:52.003 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
          2022-01-31 23:45:52.004 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
          2022-01-31 23:45:52.005 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
          edit: war etwas zu schnell.
          Fehler war vorher auch schon da, war aber vorher Info, jetzt Warnung
          @maik-0 Neue info Adapter Version auf GitHub (und auf dem Weg ins Repo) 1.9.18 sollte das fixen
            @apollon77
            @thomas-braun sagte in Alpha Test js-controller 4.0:
            Ja das liegt an internen dependencies. "unrelated"
              @apollon77
              echad@chet:~ $
              @thomas-braun @arteck Grund gefunden
              opossumO 1 Antwort Letzte Antwort
                opossumO Offline
                opossumO Offline
                opossum
                schrieb am zuletzt editiert von opossum
                Hallo, @apollon77,
                habe meine Testinstallation mit dem Update versehen. Lief alles sauber durch. Nach dem Update abgefragt:
                debian@iobrokertest:/opt/iobroker$ iobroker status
                Objects type: jsonl
                States  type: jsonl
                Auch die Meldung im Admin habe ich bestätigt. Danke für die super Arbeit.
                Habe nach dem Update versucht, den Adapter Backitup von 2.2.1 auf 2.2.3 anzuheben, das ging leider nicht korrekt durch.
                Folgende Meldungen im Log:
                backitup.0 2022-02-01 16:25:22.031	error	backitup.0 already running
                backitup.0 2022-02-01 16:24:50.013	error	backitup.0 already running
                backitup.0 2022-02-01 16:24:18.025	error	backitup.0 already running
                backitup.0 2022-02-01 16:23:46.142	error	backitup.0 already running
                backitup.0 2022-02-01 16:23:31.285	error	backitup.0 already running
                backitup.0 2022-02-01 16:22:59.313	error	backitup.0 already running
                backitup.0 2022-02-01 16:22:27.386	error	backitup.0 already running
                backitup.0 2022-02-01 16:22:24.131	error	Cannot read property 'getErrorText' of undefined
                backitup.0 2022-02-01 16:22:24.129	error	TypeError: Cannot read property 'getErrorText' of undefined at Adapter.terminate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:241:64) at finishUnload (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8349:26) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.backitup/main.js:155:13) at Adapter.emit (events.js:400:28) at process.stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8376:22) at Object.onceWrapper (events.js:520:26) at process.emit (events.js:412:35)
                Adapter wechselt zwischen rot und grün. Bringt aber laufend diesen Fehler. Auch nach Deinstallation und Neuinstallation gab es folgende Warnungen/Errors:
                backitup.0 2022-02-01 16:39:17.887	warn	Got terminate signal. Checking desired PID: 2821 vs own PID 2348
                backitup.0 2022-02-01 16:39:17.861	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                backitup.0 2022-02-01 16:38:47.266	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                backitup.0 2022-02-01 16:38:47.262	error	backitup.0 already running
                backitup.0 2022-02-01 16:38:45.884	warn	Got terminate signal. Checking desired PID: 2808 vs own PID 2348
                backitup.0 2022-02-01 16:38:45.862	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                backitup.0 2022-02-01 16:38:15.268	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                backitup.0 2022-02-01 16:38:15.265	error	backitup.0 already running
                backitup.0 2022-02-01 16:38:13.960	warn	Got terminate signal. Checking desired PID: 2797 vs own PID 2348
                backitup.0 2022-02-01 16:38:13.934	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                backitup.0 2022-02-01 16:37:43.339	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                backitup.0 2022-02-01 16:37:43.336	error	backitup.0 already running
                Hätte ich das Adapterupdate vorher machen sollen? Habe noch das Update des Web-Servers auf 3.4.16 durchgeführt, da gab es keine Auffälligkeiten.
                Downgrade des Backitup auf 2.2.1 durchgeführt, der Fehler bleibt.
                Habe dann den Fixer ausgeführt:
                debian@iobrokertest:/opt/iobroker$ iobroker stop
                debian@iobrokertest:/opt/iobroker$ iobroker fix
                library: loaded
                Library version=2021-12-27
                    Welcome to the ioBroker installation fixer!
                    Script version: 2021-12-27
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                Holen:1 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                Holen:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
                Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                Holen:5 http://security.debian.org/debian-security bullseye-security/main Sources [95,3 kB]
                Holen:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [115 kB]
                Holen:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [74,4 kB]
                Holen:8 http://deb.debian.org/debian bullseye/main Sources [8.626 kB]
                Holen:9 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
                Holen:10 http://deb.debian.org/debian bullseye-updates/main Sources.diff/Index [4.995 B]
                Holen:11 http://deb.debian.org/debian bullseye-updates/main amd64 Packages.diff/Index [4.995 B]
                Holen:12 http://deb.debian.org/debian bullseye-updates/main Sources T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [238 B]
                Holen:13 http://deb.debian.org/debian bullseye-updates/main amd64 Packages T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [1.102 B]
                Holen:14 http://deb.debian.org/debian bullseye/main amd64 Packages [8.183 kB]
                Holen:15 http://deb.debian.org/debian bullseye/main Translation-en [6.243 kB]
                Es wurden 23,6 MB in 12 s geholt (1.939 kB/s).
                N: Für das Depot »http://deb.debian.org/debian bullseye InRelease« wurde der »Version«-Wert von »11.1« in »11.2« geändert.
                Installed gcc-c++
                Installed python-dev
                Installed cmake
                    Checking ioBroker user and directory permissions (2/3)
                Created /etc/sudoers.d/iobroker
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                debian@iobrokertest:/opt/iobroker$ iobroker start
                Jetzt läuft es wieder sauber mit BackitUp 2.2.1.
                https://www.schlepper-petersdorf.de
                Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                • opossumO opossum
                  Hallo, @apollon77,
                  Objects type: jsonl
                  States  type: jsonl
                  library: loaded
                  Installed gcc-c++
                  Installed cmake
                  Autostart enabled!
                  @opossum sagte in Alpha Test js-controller 4.0:
                  Knips doch mal den Prozess aus.
                  opossumO 2 Antworten Letzte Antwort
                    opossumO Offline
                    opossumO Offline
                    opossum
                    Hallo, @thomas-braun,
                    danke für die Hilfe. War wohl die Notwendigkeit, den Fixer drüber laufen zu lassen (siehe einen Post höher, habe den noch einmal editiert). Nun läuft es wieder sauber. Hätte wohl vorher die Linuxversion anheben müssen?
                      opossumO Offline
                      opossumO Offline
                      opossum
                      habe noch einmal auf 2.2.3 hochgezogen, wieder die Fehlermeldung. Dann Deinen Rat befolgt und den
                      Got terminate signal. Checking desired PID: 0 vs own PID 4383
                      ausgeknipst. Ergebnis:
                      backitup.0 2022-02-01 17:02:38.118	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                      backitup.0 2022-02-01 17:02:38.035	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 4.0.0-alpha.67-20220131-6621d47f
                      Ruhe und läuft, vielen Dank.
                      • opossumO opossum
                        Wenn ich mir apt update relevanten Part anschaue: Ja. Regelmäßiger updaten.
                        • opossumO opossum
                          Hallo, @apollon77,
                          Objects type: jsonl
                          States  type: jsonl
                          library: loaded
                          Installed gcc-c++
                          Installed cmake
                          Autostart enabled!
                          @opossum Hast du mal das echte Log von deinem"ersten "Log"? Also das auch /opt/iobroker/log/... ?
                          Mich würde interessieren welche Prozess IDs (die stehen an sich in der Logzeile) da was geloggt hat. Und auch das volle Log und nicht "gefiltert" :-) Sowas hilft immer nicht wirklich um den Fehler eingrenzen zu können.
                          Aber ja bei dir hat sich ein Prozess nicht beendet und das hat zu den Fehlern geführt.
                          • apollon77A Offline
                            Hallo alle miteinander,
                            ich habe gerade den @next aktualisiert mit der alpha.69. Enthalten sind:
                            • (Apollon77) Optimize Stop Handling to prevent errors - reported by @Feuersturm
                            • (Apollon77) Fix upgrade all command - reported by @thomas-braun und @arteck
                            • (foxriver76) fix error if controller exits before dbs are connected - reported by @opossum
                            Eine neue Version des Info Adapters ist auch im Latest.
                            Wars das schon ... mehr habt Ihr nicht zu bieten duck ;-)))
                            Please check and retest
                            Ingo
                            Thomas BraunT FeuersturmF arteckA 4 Antworten Letzte Antwort
                              Ingo
                              @apollon77 sagte in Alpha Test js-controller 4.0:
                              PROVOZIER MICH NICHT!!!1111111 ;-)
                              Ich setzt das edgy-System jetzt auf node@18 und npm@9 !!!
                              Der neue Adapter ws zickt noch irgendwie:
                              error: ws.0 (19853) port 8084 already in use
                              Da habe ich aber noch nicht verstanden, wie der nun mit socketio zusammenspielt oder überhaupt zusammenspielen soll oder den socketio ersetzt.
                                gg
                                Hab mir gedacht "I jinx it" lieber jetzt als später ;-))
                                Mach doch mach doch ;-)
                                Auch wenn off topic: Naja Port ändern auch einen der nicht schon von socketio genutzt wird :-)
                                Am Ende ist es so: Der ws Adapter setzt auf Pure Websockets, was am Ende etwas schneller sein sollte als socketio und heutzutage an sich immer besser unterstützt wird von allem. Einiger Overhead von socketio entfällt halt. Es entfällt aber auch zB der "long polling Fallback" von socketip der immer in Umgebungen zu tragen kommt wo Websockets nicht tun (Proxies und sowas) oder wo Websockets geblickt sind (was aber genau das ist was früher oft vorkam - inzwischen eher nicht mehr. Es soll "die nächste schlankere Kommunikationsform" werden die socketio ablöst ... Wenn aber UIs einen socketio selbst mitbringen und die Library nicht vom Server laden (was oft passiert) knallts halt wenn da kein echtes socketio ist.
                                  gg
                                  @apollon77
                                  Hm. Okay, aber jetzt versteh ich immer noch nicht, ob sich die beiden Adapter ggf. 'im Weg' stehen (auch bei individuellen Ports) oder ob einer der beiden entbehrlich ist.
                                    @apollon77
                                    @thomas-braun Es ist die Frage ob Du sie überhaupt als Einzeladapter brauchst :-) Alle Voisus arbeiten normalerweise über den Web adapter und dort hast Du eins der beiden integriert und kannst mit web 4.1 wählen welches aktiv ist. Einzeln - und vor allem mit einem eigenen Port angeboten - braucht man socketio an sich nur wenn du spezielle Anwendungen hast die das als "Weg mit ioBroker zu reden" benutze, weil es am ENde ja ne Datenschnittstelle ist
                                      Das ist eine gute Frage... Ich weiß es bei meinem eigenen System nichtmal... Irgendwann war irgendwie der socketio mal da und ist seither immer mitgeschleppt worden. Könnte ich ja auch eigentlich mal rauskicken...
                                        Ingo
                                        FeuersturmF Offline
                                        FeuersturmF Offline
                                        Feuersturm
                                        @apollon77 Beim update auf die neue Version auf die alpha 69 hab ich folgendes in der Konsole.
                                        Muss ich als Anwender hier aktiv werden?
                                        > iobroker.js-controller@4.0.0-alpha.69-20220201-a819d264 install /opt/iobroker/        node_modules/iobroker.js-controller
                                        > node iobroker.js setup first
                                        object _design/system updated
                                        The following notifications happened during sync:
                                        - Ignoring Directory "benchmark.files" because officially not created as meta ob        ject. Please remove directory!
                                        - Ignoring Directory "daswetter" because officially not created as meta object.        Please remove directory!
                                        - Ignoring Directory "daswetter.admin" because officially not created as meta ob        ject. Please remove directory!
                                        - Ignoring Directory "dwd.admin" because officially not created as meta object.        Please remove directory!
                                        - Ignoring Directory "fritzbox.admin" because officially not created as meta obj        ect. Please remove directory!
                                        - Ignoring Directory "fully-tablet-control.admin" because officially not created        as meta object. Please remove directory!
                                        - Ignoring Directory "hm-rega" because officially not created as meta object. Pl        ease remove directory!
                                        - Ignoring Directory "iogo.admin" because officially not created as meta object.        Please remove directory!
                                        - Ignoring Directory "rainbird.admin" because officially not created as meta obj        ect. Please remove directory!
                                        - Ignoring Directory "seq.admin" because officially not created as meta object.        Please remove directory!
                                        - Ignoring Directory "tr-064-community.admin" because officially not created as        meta object. Please remove directory!
                                        - Ignoring Directory "web-speedy.admin" because officially not created as meta o        bject. Please remove directory!
                                        - Ignoring Directory "worx.admin" because officially not created as meta object.        Please remove directory!
                                        • FeuersturmF Feuersturm
                                          @feuersturm Sind die Adapter installiert? Siehst du mit den "ids" Meta objekte im Admin?
