  4. Alpha Test js-controller 4.0
196 Beiträge 20 Kommentatoren 39.6k Aufrufe 22 Beobachtet
  • apollon77A apollon77
    @thomas-braun GitHub Issue im Controller bitte
    @apollon77
    Einzeln lief es jetzt durch:
    iobroker upgrade web
    war okay, danach war angeblich socketio auch aktualisiert.
      arteckA Offline
      arteckA Offline
      arteck
      @apollon77 das ist der
      iobroker upgrade all
      J:\source\ioBroker\SmartHome2>iobroker upgrade all
      Exception in PromiseRejectCallback:
      J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:139
      RangeError: Maximum call stack size exceeded
      J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:128
                  await this.upgradeAdapterHelper(repo, sortedAdapters, forceDowngrade, autoConfirm);
      Cannot upgrade: Maximum call stack size exceeded
      • M mrjeschke
        @apollon77
        Nach dem update auf den js-controller 4 bekomme ich wieder invalid
        Type errors.
        2022-01-31 23:45:51.995 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:51.996 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:51.998 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:51.999 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.000 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.000 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.002 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.002 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.003 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.003 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.004 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.005 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        edit: war etwas zu schnell.
        Fehler war vorher auch schon da, war aber vorher Info, jetzt Warnung
        @maik-0 Neue info Adapter Version auf GitHub (und auf dem Weg ins Repo) 1.9.18 sollte das fixen
          @apollon77
          @thomas-braun sagte in Alpha Test js-controller 4.0:
          Ja das liegt an internen dependencies. "unrelated"
            @apollon77
            Edgy (node17/npm8) Testing meldet beim Upgrade von Adaptern:
            echad@chet:~ $ iobroker update -u && iobroker upgrade all
            Used repository: live-beta
            Adapter    "socketio"     : 4.1.0    , installed 4.0.3  [Updatable]
            Adapter    "web"          : 4.1.0    , installed 4.0.1  [Updatable]
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:139
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:128
            echad@chet:~ $
            @thomas-braun @arteck Grund gefunden
            opossumO 1 Antwort Letzte Antwort
              opossumO Offline
              opossumO Offline
              opossum
              schrieb am zuletzt editiert von opossum
              Hallo, @apollon77,
              habe meine Testinstallation mit dem Update versehen. Lief alles sauber durch. Nach dem Update abgefragt:
              debian@iobrokertest:/opt/iobroker$ iobroker status
              Objects type: jsonl
              States  type: jsonl
              Auch die Meldung im Admin habe ich bestätigt. Danke für die super Arbeit.
              Habe nach dem Update versucht, den Adapter Backitup von 2.2.1 auf 2.2.3 anzuheben, das ging leider nicht korrekt durch.
              Folgende Meldungen im Log:
              backitup.0 2022-02-01 16:25:22.031	error	backitup.0 already running
              backitup.0 2022-02-01 16:24:50.013	error	backitup.0 already running
              backitup.0 2022-02-01 16:24:18.025	error	backitup.0 already running
              backitup.0 2022-02-01 16:23:46.142	error	backitup.0 already running
              backitup.0 2022-02-01 16:23:31.285	error	backitup.0 already running
              backitup.0 2022-02-01 16:22:59.313	error	backitup.0 already running
              backitup.0 2022-02-01 16:22:27.386	error	backitup.0 already running
              backitup.0 2022-02-01 16:22:24.131	error	Cannot read property 'getErrorText' of undefined
              backitup.0 2022-02-01 16:22:24.129	error	TypeError: Cannot read property 'getErrorText' of undefined at Adapter.terminate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:241:64) at finishUnload (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8349:26) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.backitup/main.js:155:13) at Adapter.emit (events.js:400:28) at process.stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8376:22) at Object.onceWrapper (events.js:520:26) at process.emit (events.js:412:35)
              Adapter wechselt zwischen rot und grün. Bringt aber laufend diesen Fehler. Auch nach Deinstallation und Neuinstallation gab es folgende Warnungen/Errors:
              backitup.0 2022-02-01 16:39:17.887	warn	Got terminate signal. Checking desired PID: 2821 vs own PID 2348
              backitup.0 2022-02-01 16:39:17.861	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
              backitup.0 2022-02-01 16:38:47.266	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              backitup.0 2022-02-01 16:38:47.262	error	backitup.0 already running
              backitup.0 2022-02-01 16:38:45.884	warn	Got terminate signal. Checking desired PID: 2808 vs own PID 2348
              backitup.0 2022-02-01 16:38:45.862	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
              backitup.0 2022-02-01 16:38:15.268	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              backitup.0 2022-02-01 16:38:15.265	error	backitup.0 already running
              backitup.0 2022-02-01 16:38:13.960	warn	Got terminate signal. Checking desired PID: 2797 vs own PID 2348
              backitup.0 2022-02-01 16:38:13.934	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
              backitup.0 2022-02-01 16:37:43.339	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              backitup.0 2022-02-01 16:37:43.336	error	backitup.0 already running
              Hätte ich das Adapterupdate vorher machen sollen? Habe noch das Update des Web-Servers auf 3.4.16 durchgeführt, da gab es keine Auffälligkeiten.
              Downgrade des Backitup auf 2.2.1 durchgeführt, der Fehler bleibt.
              Habe dann den Fixer ausgeführt:
              debian@iobrokertest:/opt/iobroker$ iobroker stop
              debian@iobrokertest:/opt/iobroker$ iobroker fix
              library: loaded
              Library version=2021-12-27
                  Welcome to the ioBroker installation fixer!
                  Script version: 2021-12-27
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/3)
              Holen:1 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
              Holen:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
              Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
              Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
              Holen:5 http://security.debian.org/debian-security bullseye-security/main Sources [95,3 kB]
              Holen:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [115 kB]
              Holen:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [74,4 kB]
              Holen:8 http://deb.debian.org/debian bullseye/main Sources [8.626 kB]
              Holen:9 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
              Holen:10 http://deb.debian.org/debian bullseye-updates/main Sources.diff/Index [4.995 B]
              Holen:11 http://deb.debian.org/debian bullseye-updates/main amd64 Packages.diff/Index [4.995 B]
              Holen:12 http://deb.debian.org/debian bullseye-updates/main Sources T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [238 B]
              Holen:13 http://deb.debian.org/debian bullseye-updates/main amd64 Packages T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [1.102 B]
              Holen:14 http://deb.debian.org/debian bullseye/main amd64 Packages [8.183 kB]
              Holen:15 http://deb.debian.org/debian bullseye/main Translation-en [6.243 kB]
              Es wurden 23,6 MB in 12 s geholt (1.939 kB/s).
              N: Für das Depot »http://deb.debian.org/debian bullseye InRelease« wurde der »Version«-Wert von »11.1« in »11.2« geändert.
              Installed gcc-c++
              Installed python-dev
              Installed cmake
                  Checking ioBroker user and directory permissions (2/3)
                  Checking autostart (3/3)
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              debian@iobrokertest:/opt/iobroker$ iobroker start
              Jetzt läuft es wieder sauber mit BackitUp 2.2.1.
              https://www.schlepper-petersdorf.de
              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
              • opossumO opossum
                Hallo, @apollon77,
                Objects type: jsonl
                States  type: jsonl
                library: loaded
                Installed gcc-c++
                Installed cmake
                Autostart enabled!
                @opossum sagte in Alpha Test js-controller 4.0:
                Knips doch mal den Prozess aus.
                opossumO 2 Antworten Letzte Antwort
                  opossumO Offline
                  opossumO Offline
                  opossum
                  Hallo, @thomas-braun,
                  danke für die Hilfe. War wohl die Notwendigkeit, den Fixer drüber laufen zu lassen (siehe einen Post höher, habe den noch einmal editiert). Nun läuft es wieder sauber. Hätte wohl vorher die Linuxversion anheben müssen?
                    opossumO Offline
                    opossumO Offline
                    opossum
                    habe noch einmal auf 2.2.3 hochgezogen, wieder die Fehlermeldung. Dann Deinen Rat befolgt und den
                    Got terminate signal. Checking desired PID: 0 vs own PID 4383
                    ausgeknipst. Ergebnis:
                    backitup.0 2022-02-01 17:02:38.118	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                    backitup.0 2022-02-01 17:02:38.035	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 4.0.0-alpha.67-20220131-6621d47f
                    Ruhe und läuft, vielen Dank.
                    • opossumO opossum
                      Wenn ich mir apt update relevanten Part anschaue: Ja. Regelmäßiger updaten.
                      • opossumO opossum
                        Hallo, @apollon77,
                        Objects type: jsonl
                        States  type: jsonl
                        library: loaded
                        Installed gcc-c++
                        Installed cmake
                        Autostart enabled!
                        @opossum Hast du mal das echte Log von deinem"ersten "Log"? Also das auch /opt/iobroker/log/... ?
                        Mich würde interessieren welche Prozess IDs (die stehen an sich in der Logzeile) da was geloggt hat. Und auch das volle Log und nicht "gefiltert" :-) Sowas hilft immer nicht wirklich um den Fehler eingrenzen zu können.
                        Aber ja bei dir hat sich ein Prozess nicht beendet und das hat zu den Fehlern geführt.
                        • apollon77A Offline
                          Hallo alle miteinander,
                          ich habe gerade den @next aktualisiert mit der alpha.69. Enthalten sind:
                          • (Apollon77) Optimize Stop Handling to prevent errors - reported by @Feuersturm
                          • (Apollon77) Fix upgrade all command - reported by @thomas-braun und @arteck
                          • (foxriver76) fix error if controller exits before dbs are connected - reported by @opossum
                          Eine neue Version des Info Adapters ist auch im Latest.
                          Wars das schon ... mehr habt Ihr nicht zu bieten duck ;-)))
                          Please check and retest
                          Ingo
                          Thomas BraunT FeuersturmF arteckA 4 Antworten Letzte Antwort
                            Ingo
                            @apollon77 sagte in Alpha Test js-controller 4.0:
                            PROVOZIER MICH NICHT!!!1111111 ;-)
                            Ich setzt das edgy-System jetzt auf node@18 und npm@9 !!!
                            Der neue Adapter ws zickt noch irgendwie:
                            error: ws.0 (19853) port 8084 already in use
                            Da habe ich aber noch nicht verstanden, wie der nun mit socketio zusammenspielt oder überhaupt zusammenspielen soll oder den socketio ersetzt.
                              gg
                              Hab mir gedacht "I jinx it" lieber jetzt als später ;-))
                              Mach doch mach doch ;-)
                              Auch wenn off topic: Naja Port ändern auch einen der nicht schon von socketio genutzt wird :-)
                              Am Ende ist es so: Der ws Adapter setzt auf Pure Websockets, was am Ende etwas schneller sein sollte als socketio und heutzutage an sich immer besser unterstützt wird von allem. Einiger Overhead von socketio entfällt halt. Es entfällt aber auch zB der "long polling Fallback" von socketip der immer in Umgebungen zu tragen kommt wo Websockets nicht tun (Proxies und sowas) oder wo Websockets geblickt sind (was aber genau das ist was früher oft vorkam - inzwischen eher nicht mehr. Es soll "die nächste schlankere Kommunikationsform" werden die socketio ablöst ... Wenn aber UIs einen socketio selbst mitbringen und die Library nicht vom Server laden (was oft passiert) knallts halt wenn da kein echtes socketio ist.
                                gg
                                @apollon77
                                Hm. Okay, aber jetzt versteh ich immer noch nicht, ob sich die beiden Adapter ggf. 'im Weg' stehen (auch bei individuellen Ports) oder ob einer der beiden entbehrlich ist.
                                  @apollon77
                                  @thomas-braun Es ist die Frage ob Du sie überhaupt als Einzeladapter brauchst :-) Alle Voisus arbeiten normalerweise über den Web adapter und dort hast Du eins der beiden integriert und kannst mit web 4.1 wählen welches aktiv ist. Einzeln - und vor allem mit einem eigenen Port angeboten - braucht man socketio an sich nur wenn du spezielle Anwendungen hast die das als "Weg mit ioBroker zu reden" benutze, weil es am ENde ja ne Datenschnittstelle ist
                                    Das ist eine gute Frage... Ich weiß es bei meinem eigenen System nichtmal... Irgendwann war irgendwie der socketio mal da und ist seither immer mitgeschleppt worden. Könnte ich ja auch eigentlich mal rauskicken...
                                      Ingo
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      @apollon77 Beim update auf die neue Version auf die alpha 69 hab ich folgendes in der Konsole.
                                      Muss ich als Anwender hier aktiv werden?
                                      > iobroker.js-controller@4.0.0-alpha.69-20220201-a819d264 install /opt/iobroker/        node_modules/iobroker.js-controller
                                      > node iobroker.js setup first
                                      object _design/system updated
                                      The following notifications happened during sync:
                                      - Ignoring Directory "benchmark.files" because officially not created as meta ob        ject. Please remove directory!
                                      - Ignoring Directory "daswetter" because officially not created as meta object.        Please remove directory!
                                      - Ignoring Directory "daswetter.admin" because officially not created as meta ob        ject. Please remove directory!
                                      - Ignoring Directory "dwd.admin" because officially not created as meta object.        Please remove directory!
                                      - Ignoring Directory "fritzbox.admin" because officially not created as meta obj        ect. Please remove directory!
                                      - Ignoring Directory "fully-tablet-control.admin" because officially not created        as meta object. Please remove directory!
                                      - Ignoring Directory "hm-rega" because officially not created as meta object. Pl        ease remove directory!
                                      - Ignoring Directory "iogo.admin" because officially not created as meta object.        Please remove directory!
                                      - Ignoring Directory "rainbird.admin" because officially not created as meta obj        ect. Please remove directory!
                                      - Ignoring Directory "seq.admin" because officially not created as meta object.        Please remove directory!
                                      - Ignoring Directory "tr-064-community.admin" because officially not created as        meta object. Please remove directory!
                                      - Ignoring Directory "web-speedy.admin" because officially not created as meta o        bject. Please remove directory!
                                      - Ignoring Directory "worx.admin" because officially not created as meta object.        Please remove directory!
                                      • FeuersturmF Feuersturm
                                        @feuersturm Sind die Adapter installiert? Siehst du mit den "ids" Meta objekte im Admin?
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          @apollon77 Ja die Adapter sind installiert. Wo genau soll ich Meta Objekte sehen?
