  4. Master und Slave klappt nicht.
43 Beiträge 5 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • A Achim55
    @achim55
    Wenn ich die Installation von ioBroker installer auf dem Raspberry starte kommen Meldungen mit warning.
    Der Iobroker läuft aber trotz dessen. Ist das okay so ?
    pi@raspberrypiSlave:~ $ curl -sLf https://deb.nodesource.com/setup_12.x | sudo -E bash -
    ## Installing the NodeSource Node.js 12.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.5 kB]
    Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
    Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [246 kB]
    Fetched 13.5 MB in 8s (1,622 kB/s)
    Reading package lists... Done
    N: Repository 'http://archive.raspberrypi.org/debian bullseye InRelease' changed its 'Suite' value from 'unstable' to 'stable'
    ## Confirming "bullseye" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/bullseye/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:3 https://deb.nodesource.com/node_12.x bullseye InRelease [4,586 B]
    Get:4 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages [777 B]
    Fetched 5,363 B in 1s (5,258 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    pi@raspberrypiSlave:~ $ sudo apt-get install -y nodejs
    Building dependency tree... Done
    The following NEW packages will be installed:
      nodejs
    0 upgraded, 1 newly installed, 0 to remove and 44 not upgraded.
    Need to get 15.9 MB of archives.
    After this operation, 86.0 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_12.x bullseye/main armhf nodejs armhf 12.22.9-deb-1nodesource1 [15.9 MB]
    Fetched 15.9 MB in 3s (4,939 kB/s)
    Selecting previously unselected package nodejs.
    (Reading database ... 40796 files and directories currently installed.)
    Preparing to unpack .../nodejs_12.22.9-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (12.22.9-deb-1nodesource1) ...
    Setting up nodejs (12.22.9-deb-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@raspberrypiSlave:~ $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2021-12-27
        Welcome to the ioBroker installer!
        Installer version: 2021-12-27
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_12.x bullseye InRelease
    Changing npm registry to https://registry.npmjs.org
    Installed acl
    Installed gcc-c++
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed git
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed python-dev
    Installed cmake
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:58,
                     from ../src/main.cpp:3:
    /home/pi/.cache/node-gyp/12.22.9/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      736 |       (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/12.22.9/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
      770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
      433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
      452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:58,
                     from ../src/./serialport.h:13,
                     from ../src/serialport.cpp:1:
    /home/pi/.cache/node-gyp/12.22.9/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
      486 | NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
      179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
       89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    @achim55 sagte in Master und Slave klappt nicht.:
    wenn der ioB trotzdem läuft ist alles ok. Da sind ein paar WARN aber kein ERROR
    Aber was genau machst du denn jetzt mit redis auf dem Master?
    Ich kenne diese Meldung nicht
    Do you want to migrate objects and states from "file/redis" to "file/redis" [y/N]:
    Vorgabe ist ja auch Nein
    Was ist denn hiermit?
    @homoran sagte in Master und Slave klappt nicht.:
    da mag dann die Konfiguration mit drin gewesen sein, aber die Datenbank muss separat installiert werden.
    So out of the box hätte das gar nicht laufen dürfen
    Hast du redis.db nachinstalliert?
    Wenn ja, was zwar auf einem NUC unnötig ist, aber nicht stört, dann kannst du es a) auf file stellen, oder b) für den Slave freigeben.
    BTW: Wie läuft ioB auf dem NUC - da hast du auch noch nichts zu geschrieben?
    hoffentlich nativ
    A 1 Antwort Letzte Antwort
      hoffentlich nativ
      Achim55
      mhhh.... ich habe das Backup vom Raspberry auf dem NUC eingelesen. Da meckerte er beim starten und ich installiere Redis.
      Wie kann ich den auf file migrieren ?
      Auf dem NUC läuft der ioB mit allen Instanzen schon etwas über ein Jahr ohne Probleme.
      A HomoranH 2 Antworten Letzte Antwort
      • A Achim55
        Achim55
        @achim55
        ich habe jetzt die Installation auf dem Slave am laufen.
        Kann jedoch nichts mit der Frage anfangen.
        Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]:
        pi@raspberrypiSlave:~ $ iobroker setup custom
        Current configuration:
        - Objects database:
          - Type: file
          - Host/Unix Socket: 127.0.0.1
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(f)ile, (r)edis, ...], default [file]: f
        Host / Unix Socket of objects DB(file), default[127.0.0.1]: 192.168.178.47
        Port of objects DB(file), default[9001]:
        Type of states DB [(f)file, (r)edis, ...], default [file]: r
        When States are stored in a Redis database please make sure to configure Redis
        persistence to make sure a Redis problem will not cause data loss!
        Host / Unix Socket of states DB (redis), default[192.168.178.47]:
        Port of states DB (redis), default[6379]:
        Host name of this machine [raspberrypiSlave]:
        • A Achim55
          @achim55
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          Achim55
          @achim55
          Der Master ist fertig
          Enter secret phrase for connection:
          Repeat secret phrase for connection:
          Changing objects server to accept connections on all IP addresses.
          Please check the binding of redis service. By default it is only local: http://download.redis.io/redis-stable/redis.conft this host)!
          Change "bind 127.0.0.1" to "bind 0.0.0.0" or to others.
          Please restart ioBroker for the changes to take effect: "iobroker restart"y not running please start befeore trying to discover this host.
          Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
          Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
          Multihost discovery server: enabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    file on 0.0.0.0
          States:                     redis on 0.0.0.0
          root@debian:~#
          • A Achim55
            @achim55
            root@debian:~#
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @achim55
            root ?
            redis ?
            bist du nach der Anleitung vorgegangen ?
            wo sind die Screenshots der einzelnen Teile ?
            Danke.
            • bahnuhrB bahnuhr
              @achim55
              root ?
              redis ?
              Achim55
              @bahnuhr
              Ja bin ich. die Frage taucht nicht auf in der Anleitung.
              Welche welche Teile meinst Du ?
              • A Achim55
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @achim55
                Iobroker multihost einrichten_2.pdf
                Und davon die einzelnen Screenshots !
                Danke.
                • bahnuhrB bahnuhr
                  @achim55
                  Achim55
                  @bahnuhr
                  Ich bin jetzt etwas verwirrt :-) Die Screenshots sind doch weiter oben.
                  Ich bin nach der Anleitung vorgegangen. Jedoch kommt in der Anleitung nicht die Frage beim installieren auf dem Slave:
                  Was soll ich da jetzt eingeben ?
                  • A Achim55
                    Aha, dann passt das jetzt.
                    über iobroker setup custom auf file stellen
                    dann lass es, aber du musst in der redis.conf dann auch Redis für den Slave freigeben
                    When States are stored in a Redis database please make sure to configure Redis persistence to make sure a Redis problem will not cause data loss!
                    Wo bist du denn da drauf?
                    Das ist doch der slave, oder?
                    A bahnuhrB 2 Antworten Letzte Antwort
                      Achim55
                      ja die Frage taucht bei dem Slave auf.
                      • A Achim55
                        und wie bantwortest du die Frage auf dem Slave, ob er ein Master oder ein Slave sei?
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @Achim55
                          Ich frag jetzt nochmal (aber dann zum letzten mal).
                          Warum redis ???
                          Danke.
                          • bahnuhrB bahnuhr
                            @Achim55
                            Warum redis ???
                            @bahnuhr sagte in Master und Slave klappt nicht.:
                            Warum redis ???
                            Altlasten
                              Warum redis ???
                              Altlasten
                              Achim55
                              @homoran genau Altlasten.
                              ich fange jetzt noch mal beim NUC an und schmeiße redis raus mit apt-get remove redis damit das mal sauber über die Bühne geht :-)
                              Dann starte ich auf dem NUC iobroker setup custom und beantworte die Frage mit file.
                              Bin mal gespannt ob der ioB auf dem NUC dann noch läuft.
                              HomoranH A 2 Antworten Letzte Antwort
                              • A Achim55
                                und genau dann geht es nicht sauber über die Bühne
                                iobroker will dann immer noch drauf zugreifen
                                also erst
                                oder nur.
                                Ob redis da noch werkelt ist negebnsächlich
                                • A Achim55
                                  Achim55
                                  @achim55 said in Master und Slave klappt nicht.:
                                  redis ist raus :-) und der ioB läuft auf dem NUC.
                                  Was mache ich jetzt mit der Frage auf dem Slave ?
                                  bahnuhrB HomoranH 2 Antworten Letzte Antwort
                                  • A Achim55
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @achim55
                                    Master:
                                    Slave
                                    Nochmal: zeige deine Screenshots!
                                    Diese Frage kommt nicht !
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      @achim55
                                      Master:
                                      Slave
                                      Achim55
                                      @bahnuhr
                                      okay.
                                      Master:
                                      Slave:
                                      • A Achim55
                                        @bahnuhr
                                        okay.
                                        Master:
                                        Slave:
                                        Achim55
                                        @achim55
                                        ich glaube hier liegt der Fehler. Habe da mit r geantwortet.
                                        • A Achim55
                                          @achim55
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          @achim55
                                          Und hier hab ich auch noch etwas anderes:
                                          beim master
                                          Danke.
