  4. Master und Slave klappt nicht.
    6.1k
43 Beiträge 5 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • A Achim55
    @achim55
    ich habe jetzt die Installation auf dem Slave am laufen.
    Kann jedoch nichts mit der Frage anfangen.
    Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]:
    pi@raspberrypiSlave:~ $ iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: file
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis, ...], default [file]: f
    Host / Unix Socket of objects DB(file), default[127.0.0.1]: 192.168.178.47
    Port of objects DB(file), default[9001]:
    Type of states DB [(f)file, (r)edis, ...], default [file]: r
    When States are stored in a Redis database please make sure to configure Redis
    persistence to make sure a Redis problem will not cause data loss!
    Host / Unix Socket of states DB (redis), default[192.168.178.47]:
    Port of states DB (redis), default[6379]:
    Host name of this machine [raspberrypiSlave]:
    Achim55
    @achim55
    Der Master ist fertig
    Enter secret phrase for connection:
    Repeat secret phrase for connection:
    Changing objects server to accept connections on all IP addresses.
    Please check the binding of redis service. By default it is only local: http://download.redis.io/redis-stable/redis.conft this host)!
    Change "bind 127.0.0.1" to "bind 0.0.0.0" or to others.
    Please restart ioBroker for the changes to take effect: "iobroker restart"y not running please start befeore trying to discover this host.
    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    file on 0.0.0.0
    States:                     redis on 0.0.0.0
    root@debian:~#
    • A Achim55
      @achim55
      root@debian:~#
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @achim55
      root ?
      redis ?
      bist du nach der Anleitung vorgegangen ?
      wo sind die Screenshots der einzelnen Teile ?
      Danke.
      • bahnuhrB bahnuhr
        @achim55
        root ?
        redis ?
        Achim55
        @bahnuhr
        Ja bin ich. die Frage taucht nicht auf in der Anleitung.
        Welche welche Teile meinst Du ?
        • A Achim55
          @bahnuhr
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @achim55
          Iobroker multihost einrichten_2.pdf
          Und davon die einzelnen Screenshots !
          Danke.
          • bahnuhrB bahnuhr
            @achim55
            Achim55
            @bahnuhr
            Ich bin jetzt etwas verwirrt :-) Die Screenshots sind doch weiter oben.
            Ich bin nach der Anleitung vorgegangen. Jedoch kommt in der Anleitung nicht die Frage beim installieren auf dem Slave:
            Was soll ich da jetzt eingeben ?
            • A Achim55
              mhhh.... ich habe das Backup vom Raspberry auf dem NUC eingelesen. Da meckerte er beim starten und ich installiere Redis.
              Wie kann ich den auf file migrieren ?
              Auf dem NUC läuft der ioB mit allen Instanzen schon etwas über ein Jahr ohne Probleme.
              @achim55 sagte in Master und Slave klappt nicht.:
              Aha, dann passt das jetzt.
              über iobroker setup custom auf file stellen
              dann lass es, aber du musst in der redis.conf dann auch Redis für den Slave freigeben
              When States are stored in a Redis database please make sure to configure Redis persistence to make sure a Redis problem will not cause data loss!
              Wo bist du denn da drauf?
              Das ist doch der slave, oder?
              A bahnuhrB 2 Antworten Letzte Antwort
                Achim55
                ja die Frage taucht bei dem Slave auf.
                • A Achim55
                  und wie bantwortest du die Frage auf dem Slave, ob er ein Master oder ein Slave sei?
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @Achim55
                    Ich frag jetzt nochmal (aber dann zum letzten mal).
                    Warum redis ???
                    Danke.
                    • bahnuhrB bahnuhr
                      @Achim55
                      Warum redis ???
                      @bahnuhr sagte in Master und Slave klappt nicht.:
                      Warum redis ???
                      Altlasten
                        Warum redis ???
                        Altlasten
                        Achim55
                        @homoran genau Altlasten.
                        ich fange jetzt noch mal beim NUC an und schmeiße redis raus mit apt-get remove redis damit das mal sauber über die Bühne geht :-)
                        Dann starte ich auf dem NUC iobroker setup custom und beantworte die Frage mit file.
                        Bin mal gespannt ob der ioB auf dem NUC dann noch läuft.
                        HomoranH A 2 Antworten Letzte Antwort
                        • A Achim55
                          und genau dann geht es nicht sauber über die Bühne
                          iobroker will dann immer noch drauf zugreifen
                          also erst
                          oder nur.
                          Ob redis da noch werkelt ist negebnsächlich
                          • A Achim55
                            Achim55
                            @achim55 said in Master und Slave klappt nicht.:
                            redis ist raus :-) und der ioB läuft auf dem NUC.
                            Was mache ich jetzt mit der Frage auf dem Slave ?
                            bahnuhrB HomoranH 2 Antworten Letzte Antwort
                            • A Achim55
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @achim55
                              Master:
                              Slave
                              Nochmal: zeige deine Screenshots!
                              Diese Frage kommt nicht !
                              Danke.
                              • bahnuhrB bahnuhr
                                @achim55
                                Master:
                                Slave
                                Achim55
                                @bahnuhr
                                okay.
                                Master:
                                Slave:
                                • A Achim55
                                  @bahnuhr
                                  okay.
                                  Master:
                                  Slave:
                                  Achim55
                                  @achim55
                                  ich glaube hier liegt der Fehler. Habe da mit r geantwortet.
                                  • A Achim55
                                    @achim55
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @achim55
                                    Und hier hab ich auch noch etwas anderes:
                                    beim master
                                    Danke.
                                    • A Achim55
                                      Es ist immer noch ein Slave (S)!!!
                                      Aber jetzt hast du doch schon vorher redis auf dem Slave aktiviert
                                      geh da raus und mache alles mit iobroker setup custom manuell.
                                      Dann siehst du auch wo du dran bist
                                        Achim55
                                        jetzt hat es geklappt :-)
                                        redis verwirrte mich total .
                                        Danke noch mal an alle !!!!
                                        • A Achim55
                                          mit setup custom statt mit der automatischen Methode?
                                          Ich weiß gar nicht warum die so unbeliebt ist - damit geht das in Sekunden
