  4. Verfügbarkeit von Sensoren über Node Red überwachen
    2.3k
    4.2k
426 Beiträge 5 Kommentatoren 73.1k Aufrufe 4 Beobachtet
  • mickymM mickym
    @schmetterfliege Kannst mir mal Dein zigbee Objekt auch hier reinkopieren - dann kann ich es noch besser nachvollziehen. ;)
    Schmetterfliege
    #301
    @mickym
    {"00158d000163f2bc":{"name":"Raum","id":"00158d000163f2bc","room":"Küche","humidity":54.04,"temperature":21.78},"00158d000283e64e":{"name":"Raum","id":"00158d000283e64e","room":"Großes Bad","humidity":54.14,"temperature":22.42},"00158d000283e67b":{"name":"Raum","id":"00158d000283e67b","room":"Kleines Bad","humidity":53.54,"temperature":22.42},"00158d000309a45a":{"name":"Raum","id":"00158d000309a45a","room":"Schlafzimmer","humidity":59.91,"temperature":20.82},"00158d000410e87b":{"name":"Raum","id":"00158d000410e87b","room":"Büro","humidity":56.98,"temperature":22.24},"00158d000410e8ca":{"name":"Raum","id":"00158d000410e8ca","room":"Wohnzimmer","humidity":59.85,"temperature":21.64},"00158d000411103a":{"name":"Raum","id":"00158d000411103a","room":"Esszimmer","humidity":54.05,"temperature":22.43},"00158d00076565a1":{"name":"Heizung","id":"00158d00076565a1","room":"Wohnzimmer","humidity":82.7,"temperature":28.31},"00158d000774f35a":{"name":"Heizung","id":"00158d000774f35a","room":"Büro","humidity":62.55,"temperature":26.56},"00158d000774f34a":{"name":"Heizung","id":"00158d000774f34a","room":"Schlafzimmer","humidity":70.45,"temperature":26.04},"00158d00077dce53":{"name":"Heizung","id":"00158d00077dce53","room":"Esszimmer","humidity":54.81,"temperature":26.16},"00158d00075f6607":{"name":"Raum","id":"00158d00075f6607","room":"Abstellkammer","humidity":52.92,"temperature":22.65},"00158d000774f31c":{"name":"Jewel Orchid","id":"00158d000774f31c","room":"Büro","humidity":41.01,"temperature":23.79},"00158d000774f2c9":{"name":"Heizung","id":"00158d000774f2c9","room":"Abstellkammer","humidity":53.06,"temperature":25.78},"00158d00073c0c65":{"name":"Raum","id":"00158d00073c0c65","room":"Eingang","humidity":40.08,"temperature":24.82},"00158d000774f2cb":{"name":"Raum","id":"00158d000774f2cb","room":"Flur 2","humidity":56.69,"temperature":23.51},"00158d00041d8697":{"name":"Raum","id":"00158d00041d8697","room":"Flur 1","humidity":54.98,"temperature":22.05}}
    • mickymM Offline
      mickymM Offline
      mickym
      #302
      Danke ;) - dauert bissi - weil ich gleich noch was optimieren möchte. ;)
      • mickymM mickym
        Schmetterfliege
        #303
        @mickym
        Kein Stress - bin noch ein Weilchen wach 😁
        Solangsam fange ich an zu glauben du bist ein Bot oder sowas.
        So viel Hilfsbereitschaft und das auch noch zu jeder Tages und Nacht Zeit ist irgendwie kaum zu fassen hehe
        • S Schmetterfliege
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          #304
          @schmetterfliege Also ist noch die Version die ich geschickt habe - bei mir funktioniert das ohne Probleme -
          So hier die optimierte Version:
                 "id": "7b5bb841bf8e240c",
                 "type": "change",
                 "z": "0b2773fbdc77eea3",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload.timestamp",
                         "pt": "msg",
                         "to": "$lookup($flowContext(\"timestamps\"), payload.id).timestamp",
                         "tot": "jsonata"
                         "t": "set",
                         "p": "payload.lastupdate",
                         "pt": "msg",
                         "to": "$moment(payload.timestamp).fromNow()",
                         "tot": "jsonata"
                         "t": "set",
                         "pt": "msg",
                         "to": "$moment(payload.timestamp).format(\"DD.MM.YYYY HH:mm:ss\")\t",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 710,
                 "y": 620,
                 "wires": [
                         "584c0e94d5c2de86"
          Anstelle mehrfach den Kontext einzulesen - wird der timestamp nur einmal eingelesen und dann entweder formatiert oder die Differenz berechnet:
          Das locale("de") habe ich in der Change Node vergessen - musst halt noch nachtragen.
          Finde es nachwievor zwar überflüssig ts und die Zeitdifferenz zu berechnen.
            Schmetterfliege
            #305
            hmm.
            An welcher Stelle wird denn bei dir das LastUpdate dann in das Zigbee Objekt geladen? In der Change Node sehe ich das jedenfalls nicht
            mickymM 2 Antworten Letzte Antwort
            • S Schmetterfliege
              hmm.
              mickymM Offline
              mickymM Offline
              mickym
              #306
              @schmetterfliege doch in der 2. Regel.
              • S Schmetterfliege
                hmm.
                mickymM Offline
                mickymM Offline
                mickym
                #307
                @schmetterfliege Das steht auch nicht in der zigbee Kontext variable - schau doch ins Debug fenster - was da rauskommt. Mach mal hinter die JOIN Node eine Debug Node und poste die.Die zigbee Flow- Kontext wird nicht modifiziert.
                • mickymM mickym
                  Schmetterfliege
                  #308
                  @mickym said in Verfügbarkeit von Sensoren über Node Red überwachen:
                  Okay, ich bin davon ausgegangen dass das da drin landet weil du das vorher selbst geschrieben hast 😀
                  In der Tabelle sehe ich in der Tat die Zeitdifferenzen. Funktioniert also! :)
                  • S Schmetterfliege
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #309
                    @schmetterfliege Ok mit den Zigbee Objekten habe ich die gemeint, die in die Table Node kommen. ;)
                      Schmetterfliege
                      #310
                      Also ja, du übergibst das in das Objekt das im Flow übergeben wird.
                      Ich dachte aber mit Objekt meinst du das Zigbee Objekt in den Kontextvariablen 😁
                      Sorry!
                      • S Schmetterfliege
                        Sorry!
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #311
                        @schmetterfliege Na egal - somit sollte Dein Problem jedenfalls gelöst sein.
                          Schmetterfliege
                          #312
                          Vielen Dank für die Lösung meines Problems! :)
                          Was meinst du btw. damit dass du es für überflüssig hältst ts und die Zeitdifferenz zu berechnen?
                          Die TS habe ich ja nur damit ich die Differenzen berechnen kann.
                          Und die Differenzen möchte ich um innerhalb der Tabelle direkt sehen zu können ob alle Sensoren regelmäßig Daten liefern, oder ob da einer nicht mehr funktioniert - ohne im IoB im Zigbee Adapter nachschauen zu müssen
                          • S Schmetterfliege
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #313
                            @schmetterfliege Ja in der Tabelle die Differenzen - aber dann brauchst den Timestamp nicht mehr.
                            Ein Zeitstempel in der Tabelle 42e48739-1d99-4007-839e-1fd2489a0940-image.png
                            und dann ist 27 Minuten her - finde ich halt redundant.
                            Im Prinzip im Objekt ist es egal - aber ich würde es halt in der Tabelle nicht mehr anzeigen.
                            • mickymM mickym
                              Schmetterfliege
                              #314
                              achsooooo!
                              Die Timestamps zeige ich da ja nicht mehr an :D
                              • S Schmetterfliege
                                achsooooo!
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #315
                                @schmetterfliege sagte in Verfügbarkeit von Sensoren über Node Red überwachen:
                                Ah OK - :) - Dann macht das Sinn. 👍
                                • S Schmetterfliege
                                  achsooooo!
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #316
                                  Dann kannst auch die letzte Regel rausschmeissen, die den Unix Timestamp formatiert:
                                    Schmetterfliege
                                    #317
                                    stimmt :)
                                    • mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #318
                                      @schmetterfliege bzw. die Change NOde ganz vereinfachen und den timestamp aus dem Objekt entfernen. ;)
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "pt": "msg",
                                                     "to": "$moment($lookup($flowContext(\"timestamps\"), payload.id).timestamp).locale(\"de\").fromNow()",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 750,
                                             "y": 620,
                                             "wires": [
                                                     "584c0e94d5c2de86"
                                      • mickymM mickym
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 750,
                                               "y": 620,
                                               "wires": [
                                                       "584c0e94d5c2de86"
                                        Schmetterfliege
                                        #319
                                        @mickym
                                        Funktioniert :)
                                        Sorry dass ich dir durch meine Undeutlichkeit die ganze Arbeit mit dem Optimieren gemacht habe, und jetzt alles wieder rausfällt :S
                                        • S Schmetterfliege
                                          @mickym
                                          Funktioniert :)
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #320
                                          @schmetterfliege Na ja - im Prinzip hätte ich halt in der Timestamps variable - den ts nicht in ein Objekt sondern direkt gespeichert - das hat es dann halt noch bissi komplexer gemacht als nötig. Aber nun funktioniert es ja auch so. ;)
                                          In diesem Fall siehst ist es aber alles halb so kompliziert und es wird über eine Regel in einer Change Node das erreicht, was Du vorher mit dem ganzen Flow machen wolltest.
                                          Ich würde mir allerdings schon Sorgen machen, wenn sich die Geräte 4 Monate nicht mehr gemeldet haben.
