  4. Verfügbarkeit von Sensoren über Node Red überwachen
    5.7k
426 Beiträge 5 Kommentatoren 75.0k Aufrufe 4 Beobachtet
  • mickymM mickym
    @schmetterfliege Nee die ID brauchst da nicht aufnehmen .- ich habs dir gerade geschickt.
    mickymM Offline
    mickymM Offline
    mickym
    #298
    Wenns nicht klappt - dann kopiere mir mal die timestamps Variable mit ihren Werten hier in den Thread.
      Schmetterfliege
      #299
      Klappt mit der geänderten Change Node noch nicht:
      {"00158d000163f2bc":{"timestamp":1663981535112},"00158d000283e64e":{"timestamp":1663982212986},"00158d000283e67b":{"timestamp":1663982683881},"00158d000309a45a":{"timestamp":1663982254922},"00158d000410e87b":{"timestamp":1663982585805},"00158d000410e8ca":{"timestamp":1663981345934},"00158d000411103a":{"timestamp":1663982267461},"00158d00076565a1":{"timestamp":1653136793375},"00158d000774f35a":{"timestamp":1653136904758},"00158d000774f34a":{"timestamp":1653136693961},"00158d00077dce53":{"timestamp":1653137001054},"00158d00075f6607":{"timestamp":1663982582413},"00158d000774f31c":{"timestamp":1653475998546},"00158d000774f2c9":{"timestamp":1653136500038},"00158d00073c0c65":{"timestamp":1653475703207},"00158d000774f2cb":{"timestamp":1662847386918},"00158d00041d8697":{"timestamp":1663982154689}}
      • S Schmetterfliege
        mickymM Offline
        mickymM Offline
        mickym
        #300
        @schmetterfliege Kannst mir mal Dein zigbee Objekt auch hier reinkopieren - dann kann ich es noch besser nachvollziehen. ;)
        • mickymM mickym
          Schmetterfliege
          #301
          @mickym
          {"00158d000163f2bc":{"name":"Raum","id":"00158d000163f2bc","room":"Küche","humidity":54.04,"temperature":21.78},"00158d000283e64e":{"name":"Raum","id":"00158d000283e64e","room":"Großes Bad","humidity":54.14,"temperature":22.42},"00158d000283e67b":{"name":"Raum","id":"00158d000283e67b","room":"Kleines Bad","humidity":53.54,"temperature":22.42},"00158d000309a45a":{"name":"Raum","id":"00158d000309a45a","room":"Schlafzimmer","humidity":59.91,"temperature":20.82},"00158d000410e87b":{"name":"Raum","id":"00158d000410e87b","room":"Büro","humidity":56.98,"temperature":22.24},"00158d000410e8ca":{"name":"Raum","id":"00158d000410e8ca","room":"Wohnzimmer","humidity":59.85,"temperature":21.64},"00158d000411103a":{"name":"Raum","id":"00158d000411103a","room":"Esszimmer","humidity":54.05,"temperature":22.43},"00158d00076565a1":{"name":"Heizung","id":"00158d00076565a1","room":"Wohnzimmer","humidity":82.7,"temperature":28.31},"00158d000774f35a":{"name":"Heizung","id":"00158d000774f35a","room":"Büro","humidity":62.55,"temperature":26.56},"00158d000774f34a":{"name":"Heizung","id":"00158d000774f34a","room":"Schlafzimmer","humidity":70.45,"temperature":26.04},"00158d00077dce53":{"name":"Heizung","id":"00158d00077dce53","room":"Esszimmer","humidity":54.81,"temperature":26.16},"00158d00075f6607":{"name":"Raum","id":"00158d00075f6607","room":"Abstellkammer","humidity":52.92,"temperature":22.65},"00158d000774f31c":{"name":"Jewel Orchid","id":"00158d000774f31c","room":"Büro","humidity":41.01,"temperature":23.79},"00158d000774f2c9":{"name":"Heizung","id":"00158d000774f2c9","room":"Abstellkammer","humidity":53.06,"temperature":25.78},"00158d00073c0c65":{"name":"Raum","id":"00158d00073c0c65","room":"Eingang","humidity":40.08,"temperature":24.82},"00158d000774f2cb":{"name":"Raum","id":"00158d000774f2cb","room":"Flur 2","humidity":56.69,"temperature":23.51},"00158d00041d8697":{"name":"Raum","id":"00158d00041d8697","room":"Flur 1","humidity":54.98,"temperature":22.05}}
          • mickymM Offline
            mickymM Offline
            mickym
            #302
            Danke ;) - dauert bissi - weil ich gleich noch was optimieren möchte. ;)
            • mickymM mickym
              Schmetterfliege
              #303
              @mickym
              Kein Stress - bin noch ein Weilchen wach 😁
              Solangsam fange ich an zu glauben du bist ein Bot oder sowas.
              So viel Hilfsbereitschaft und das auch noch zu jeder Tages und Nacht Zeit ist irgendwie kaum zu fassen hehe
              • S Schmetterfliege
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                #304
                @schmetterfliege Also ist noch die Version die ich geschickt habe - bei mir funktioniert das ohne Probleme -
                So hier die optimierte Version:
                       "id": "7b5bb841bf8e240c",
                       "type": "change",
                       "z": "0b2773fbdc77eea3",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload.timestamp",
                               "pt": "msg",
                               "to": "$lookup($flowContext(\"timestamps\"), payload.id).timestamp",
                               "tot": "jsonata"
                               "t": "set",
                               "p": "payload.lastupdate",
                               "pt": "msg",
                               "to": "$moment(payload.timestamp).fromNow()",
                               "tot": "jsonata"
                               "t": "set",
                               "pt": "msg",
                               "to": "$moment(payload.timestamp).format(\"DD.MM.YYYY HH:mm:ss\")\t",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 710,
                       "y": 620,
                       "wires": [
                               "584c0e94d5c2de86"
                Anstelle mehrfach den Kontext einzulesen - wird der timestamp nur einmal eingelesen und dann entweder formatiert oder die Differenz berechnet:
                Das locale("de") habe ich in der Change Node vergessen - musst halt noch nachtragen.
                Finde es nachwievor zwar überflüssig ts und die Zeitdifferenz zu berechnen.
                  Schmetterfliege
                  #305
                  hmm.
                  An welcher Stelle wird denn bei dir das LastUpdate dann in das Zigbee Objekt geladen? In der Change Node sehe ich das jedenfalls nicht
                  • S Schmetterfliege
                    hmm.
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #306
                    @schmetterfliege doch in der 2. Regel.
                    • S Schmetterfliege
                      hmm.
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #307
                      @schmetterfliege Das steht auch nicht in der zigbee Kontext variable - schau doch ins Debug fenster - was da rauskommt. Mach mal hinter die JOIN Node eine Debug Node und poste die.Die zigbee Flow- Kontext wird nicht modifiziert.
                      • mickymM mickym
                        Schmetterfliege
                        #308
                        @mickym said in Verfügbarkeit von Sensoren über Node Red überwachen:
                        Okay, ich bin davon ausgegangen dass das da drin landet weil du das vorher selbst geschrieben hast 😀
                        In der Tabelle sehe ich in der Tat die Zeitdifferenzen. Funktioniert also! :)
                        • S Schmetterfliege
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #309
                          @schmetterfliege Ok mit den Zigbee Objekten habe ich die gemeint, die in die Table Node kommen. ;)
                            Schmetterfliege
                            #310
                            Also ja, du übergibst das in das Objekt das im Flow übergeben wird.
                            Ich dachte aber mit Objekt meinst du das Zigbee Objekt in den Kontextvariablen 😁
                            Sorry!
                            • S Schmetterfliege
                              Sorry!
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #311
                              @schmetterfliege Na egal - somit sollte Dein Problem jedenfalls gelöst sein.
                                Schmetterfliege
                                #312
                                Vielen Dank für die Lösung meines Problems! :)
                                Was meinst du btw. damit dass du es für überflüssig hältst ts und die Zeitdifferenz zu berechnen?
                                Die TS habe ich ja nur damit ich die Differenzen berechnen kann.
                                Und die Differenzen möchte ich um innerhalb der Tabelle direkt sehen zu können ob alle Sensoren regelmäßig Daten liefern, oder ob da einer nicht mehr funktioniert - ohne im IoB im Zigbee Adapter nachschauen zu müssen
                                • S Schmetterfliege
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #313
                                  @schmetterfliege Ja in der Tabelle die Differenzen - aber dann brauchst den Timestamp nicht mehr.
                                  Ein Zeitstempel in der Tabelle 42e48739-1d99-4007-839e-1fd2489a0940-image.png
                                  und dann ist 27 Minuten her - finde ich halt redundant.
                                  Im Prinzip im Objekt ist es egal - aber ich würde es halt in der Tabelle nicht mehr anzeigen.
                                  • mickymM mickym
                                    Schmetterfliege
                                    #314
                                    achsooooo!
                                    Die Timestamps zeige ich da ja nicht mehr an :D
                                    • S Schmetterfliege
                                      achsooooo!
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #315
                                      @schmetterfliege sagte in Verfügbarkeit von Sensoren über Node Red überwachen:
                                      Ah OK - :) - Dann macht das Sinn. 👍
                                      • S Schmetterfliege
                                        achsooooo!
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #316
                                        Dann kannst auch die letzte Regel rausschmeissen, die den Unix Timestamp formatiert:
                                          Schmetterfliege
                                          #317
                                          stimmt :)
