  4. Adapter "smartmeter"
3.6k Beiträge 281 Kommentatoren 2.9m Aufrufe 162 Beobachtet
  • a200A Offline
    a200A Offline
    a200
    #241
    Fehler bei der Adpaterinstallation. Ich kenne mich mit npm nicht aus. Woran könnte es liegen?
    WTF? Error: not found: git
    $ ./iobroker add smartmeter
    npm install iobroker.smartmeter --production --prefix "/opt/iobroker" (System call)
    npm WARN addRemoteGit Error: not found: git
    npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    npm
    WARN addRemoteGit apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-ed0728e5 because of error: { [Error: not found: git] code: 'ENOGIT' }
    npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-ed0728e5: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-ed0728e5: undefined
    ! npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    npm
    WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN
    npm
    WARN
    addRemoteGit apollon77/OpenSML resetting remote /root/.npm/_git-remotes/https-github-com-apollon77-OpenSML-git-a6e1d91f because of error: { [Error: not found: git] code: 'ENOGIT' }
    npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/https-github-com-apollon77-OpenSML-git-a6e1d91f: undefinednpm
    undefined
    npm
    WARN addRemoteGit
    addRemoteGit
    npm WARN
    addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)npm WARN addRemoteGit apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-19f1fc63 because of error: { [Error: not found: git] code: 'ENOGIT' }
    ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-19f1fc63: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-19f1fc63: undefined
    ! npm ERR! Linux 4.9.0-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.smartmeter" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v4.7.2
    npm ERR! npm v2.15.11
    npm ERR! code ENOGIT
    ! npm ERR! not found: git
    npm ERR!
    npm ERR! Failed using git.
    npm ERR! This is most likely not a problem with npm itself.
    npm ERR! Please check if you have git installed and in your PATH.
    ! npm ERR! Please include the following file with any support request:
    npm ERR! /opt/npm-debug.log
    ! ERROR: host.miniyou Cannot install iobroker.smartmeter: 1
      #242
      Es fehlt zumindest ein Paket:
      sudo apt-get install git
      Rainer
      • a200A Offline
        a200A Offline
        a200
        #243
        @Homoran:
        Rainer `
        dachte ich auch. aber git ist da! Andere Pakete lassen sich installieren. ;( ich sach mal weiter.
          #244
          @a200:
          dachte ich auch. aber git ist da `
          und sonst stand da noch was von gitnpm….
          Aber so etwas hatten wir schonmal, da war dann die Ursache woanders.
          Kann es sein, dass du diesen Adapter als root installieren musst?
          Rainer
          • a200A Offline
            a200A Offline
            a200
            #245
            @Homoran:
            @a200:
            Rainer `
            schau ich mal. danke für den hinweis
            • C Offline
              chemieka
              #246
              @a200
              Hier das Bild. Der erste Sensor läuft jetzt schon drei Tage da müsste mal ein richtiger Tageswert kommen aber warten wir mal noch. <size size="150">Oder halt as ist ja W/h und nicht KW/h das stimmt ja ;) Alles Bestens.</size>
              • a200A Offline
                a200A Offline
                a200
                #247
                @Homoran:
                @a200:
                Rainer `
                manuelle installation des Adapters + ioBroker restart hat geholfen. DANKE!
                • apollon77A Offline
                  #248
                  Hey All,
                  Neue Version 0.3.0 vom Adapter auf Github.
                  Ja, aktuell wird "git" benötigt (apt-get install git), da ich eine Library direkt von Github installieren muss weil da ein Fix drin ist den der Library Owner noch nicht akzeptiert hat :-(
                  @wendy2702: Retry please. Einstellungen gleich lassen. Das der F.F-Fehler kommt ist komisch. Sicherstellen das der Adapter ggf nach der Installation neu gestartet wurde …
                  • wendy2702W Offline
                    wendy2702W Offline
                    wendy2702
                    #249
                    @apollon77:
                    Hey All,
                    @wendy2702: Retry please. Einstellungen gleich lassen. Das der F.F-Fehler kommt ist komisch. Sicherstellen das der Adapter ggf nach der Installation neu gestartet wurde … `
                    Erstmal die gute Nachricht: Ich habe Objecte und Werte :D
                    Jetzt habe ich aber das Problem das der Adapter sich nicht mehr stoppen lässt über die Instanz Seite.
                    filename="Smartmeter_0.3.0_läuft_immer.jpg" index="1">~~
                    Und hier mal ein relativ umfangreiches logfile. Abfrage Intervall 30s. Weiß jetzt nicht ob die "Error" gekommen sind weil ich versucht habe den Adapter zu stoppen, Interval geändert, Adapter wieder gestartet. Vermute aber schon.
                    999_smartmeter_0.3.0.zip
                    EDIT: das mit dem Stoppen des Adapters scheint nicht immer ein Problem zu sein. Muss das mal beobachten
                      #250
                      @wendy2702:
                      Erstmal die gute Nachricht: Ich habe Objecte und Werte :D `
                      Super! Ich liebe Geräte die Protokolle implementieren aber sich dann nicht daran halten ;-)
                      Hatte sowas aber fast schon befürchtet und Lösung gefunden. Passt
                      @wendy2702:
                      EDIT: das mit dem Stoppen des Adapters scheint nicht immer ein Problem zu sein. Muss das mal beobachten `
                      Also hier dazu eine Info: Die aktuelle Stop-Logik ist so, dass Sie sofort greifen sollte wenn er gerade in der "Wartezeit" zwischen zwei Requests ist (also in den 30 Sekunden nach Ende einer Nachricht bis er das nächste mal anfängt) ODER er beendet sich nach dem verarbeiten der aktuellen Nachricht und startet keine neue Wartezeit.
                      Bei 300baud und der Länge Deiner Nachricht braucht er alleine 20-25 Sekunden um die Nachricht zu emfangen :-) … also beim Stoppen etwas geduld haben. ioBroker sollte verhindern das du mehrere instanzen gleichzeitig laufen hast.
                        wendy2702W Offline
                        wendy2702
                        #251
                        @apollon77:
                        @wendy2702:
                        @wendy2702:
                        Bei 300baud und der Länge Deiner Nachricht braucht er alleine 20-25 Sekunden um die Nachricht zu emfangen :-) … also beim Stoppen etwas geduld haben. ioBroker sollte verhindern das du mehrere instanzen gleichzeitig laufen hast. `
                        Funktioniert erstmal perfekt jetzt.
                        Gleich mal einen PI bestellen der dann fest in den Zählerschrank kann.
                        Vielen Dank für deine Arbeit und Geduld.
                          #252
                          @wendy2702:
                          Gleich mal einen PI bestellen der dann fest in den Zählerschrank kann. `
                          Auf die Schnelle:
                          http://www.pollin.de/shop/dt/ODc1NzkyOT … n_Set.html
                          da gibt es aber noch andere!
                          Rainer
                            wendy2702W Offline
                            wendy2702
                            #253
                            Danke.
                            Bin noch mit mir am hadern ob er wirklich "rein" soll oder vielleicht doch nur drauf.
                              #254
                              @wendy2702:
                              Danke.
                              Bin noch mit mir am hadern ob er wirklich "rein" soll oder vielleicht doch nur drauf. `
                              dito, mein Kopf ist noch unterwegs, dann erst testen, dann probieren, dann entscheiden - oder auch nicht ;-)
                              Rainer
                              • I Offline
                                I Offline
                                ichderarnd
                                #255
                                Da es noch Probleme mit der Installation gibt habe ich den Test mit dem EFR Zähler erstmal verschoben.
                                Bei meinem PI3 war es so, dass sich die Installation der Version 0.2.4 mit 100% CPU aufgehängt hat. SSH, um den npm Prozess zu killen ging leider nicht mehr. Es blieb nur hartes Ausschalten des PI.
                                arndl
                                  wendy2702W Offline
                                  wendy2702
                                  #256
                                  Hm,
                                  Mittlerweile sind wir bei Version 0.3.0
                                  Hat das hier keiner auf einem PI3 laufen?
                                  Naja. Ich werde berichten wenn der PI und ich nächste Woche zusammen zu hause sind.
                                  • I Offline
                                    I Offline
                                    ichderarnd
                                    #257
                                    Interessant. Nach einem Reload im ioBroker Adapter-TAB steht da nun in der Spalte "Version" 0.2.6 und unter "Installiert" 0.3.0
                                    In den Instanzen wird der Adapter jedoch nicht aufgeführt.
                                    arndl
                                    • C Offline
                                      chemieka
                                      #258
                                      @wendy2702:
                                      Hm,
                                      Gesendet von iPhone mit Tapatalk Pro `
                                      Doch doch mein System ist auf einer PI3. Daran zwei Leseköpfe mit SML Protokoll.
                                      Version 0.2.4 ohne Probleme installiert.
                                      • C Offline
                                        chemieka
                                        #259
                                        <size size="150">So ich bin jetzt fast fertig und wollte hier mal das Ergebnis zeigen.
                                        Alles mit eurer Hilfe. Danke, vielen Dank.</size>
                                          wendy2702W Offline
                                          wendy2702
                                          #260
                                          @arndl:
                                          arndl `
                                          Du musst den vom Adapter noch installieren damit er als Instanz erscheint.
