  4. Adapter "smartmeter"
    5.7k
3.6k Beiträge 281 Kommentatoren 2.9m Aufrufe 162 Beobachtet
  • B Bandit2001
    Genau kann ich das leider nicht mehr sagen, ich habe in Admin einfach auf "Alle Adapter aktualisieren" geklickt.
    Gibt es so etwas wie ein Update-Log?
    #2161
    @bandit2001 sagte in Adapter "smartmeter":
    aber welche du jetzt hast:
    iobroker update -i
    B 1 Antwort Letzte Antwort
      iobroker update -i
      Bandit2001
      #2162
      Ja, das kann ich:
      pi@ioBroker-Pi:~ $ iobroker update -i
      Used repository: stable
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
      Adapter    "backitup"      : 2.1.17   , installed 2.1.17
      Adapter    "discovery"     : 2.7.0    , installed 2.7.0
      Adapter    "ecovacs-deebot": 1.2.4    , installed 1.2.2 [Updateable]
      Adapter    "email"         : 1.0.10   , installed 1.0.10
      Adapter    "flot"          : 1.10.6   , installed 1.10.6
      Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "hm-rega"       : 3.0.31   , installed 3.0.31
      Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
      Adapter    "ical"          : 1.11.4   , installed 1.11.4
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
      Adapter    "influxdb"      : 1.9.5    , installed 2.1.1
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.22   , installed 1.8.22
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.18   , installed 3.3.18
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "pushover"      : 2.0.5    , installed 2.0.5
      Adapter    "robonect"      : 0.1.3    , installed 0.1.4
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "smartmeter"    : 3.2.1    , installed 3.2.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "tvspielfilm"   : 1.0.4    , installed 2.0.4
      Adapter    "vis"           : 1.4.4    , installed 1.4.3 [Updateable]
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Das sind alle.
        MartyBr
        #2163
        @noox
        Ich habe heute einen Landis Gyr 650 bekommen. Auf der seriellen Schnittstelle sehe ich alle Daten reinkommen. Leider bekommt der Smartmeter-Controller keine Daten.
        Kannst du mir vielleicht deine Einstellungen im Smartmeter-Controller nennen (Baud, Schnittstelleneinrichtung, Protokoll (D0???)
        Ich verzweifle hier
        Martin
        Intel NUCs mit Proxmox / Iobroker als VM unter Debian
        Raspeberry mit USB Leseköpfen für Smartmeter
        Homematic und Homematic IP
        N 1 Antwort Letzte Antwort
        • M MartyBr
          @noox
          Ich verzweifle hier
          N Offline
          N Offline
          noox
          #2164
          @martybr
          ich hab halt die Wärmezähler 2WR5
          Die Standard-Werte bekommt man mit '?' - bei meinen kommt man deutlich mehr Werte mit '#'
          • N noox
            @martybr
            MartyBr
            #2165
            @noox
            Sehr seltsam, ich habe den Adapter wie bei dir eingestellt und bekomme den Adapter einfach nicht grün.
            Das Terminal liefert aber die Werte:
            Hast du noch eine Idee?
            Martin
            N HomoranH 2 Antworten Letzte Antwort
            • M MartyBr
              @noox
              N Offline
              N Offline
              noox
              #2166
              @martybr
              Was steht in den Logs?
              Grad wenn man viel herumprobiert, kann auch sein, dass der USB-Port nicht mehr freigegeben wird.
              Ich hab dann z.B. sowas bekommen:
              smartmeter.1 2021-01-19 09:40:30.508 warn (30797) Error on Baudrate changeover: Error: Port is not open
              Ich hab mir dazu notiert, den Raspberry Pi neu zu starten.
              • M MartyBr
                @noox
                #2167
                @martybr sagte in Adapter "smartmeter":
                das darf aber nicht parallel zum Adapter laufen
                  MartyBr
                  schrieb am zuletzt editiert von MartyBr
                  #2168
                  Ich habe doch nur cat /dev/lesekopf1 auf dem Raspi gestartet. Das sollte doch kein Problem machen, oder doch?
                  Edit:
                  Auch ohne Terminal wird der Adapter nicht grün.
                  Martin
                  • M MartyBr
                    Edit:
                    #2169
                    was ist denn lesekopf1?
                    der muss doch irgendwomit verbunden sein
                      MartyBr
                      #2170
                      Hier mal das Log:
                      smartmeter.0
                      2021-10-25 17:41:06.223	info	Error: Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0
                      2021-10-25 17:41:05.213	warn	No match for Message "\u0000"
                      smartmeter.0
                      2021-10-25 17:41:05.211	info	Error: No match for Message "\u0000"
                      smartmeter.0
                      2021-10-25 17:41:04.169	warn	Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0
                      2021-10-25 17:41:04.168	info	Error: Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0
                      2021-10-25 17:41:03.159	warn	No match for Message "\u0000"
                      smartmeter.0
                      2021-10-25 17:41:03.157	info	Error: No match for Message "\u0000"
                      smartmeter.0
                      smartmeter.0
                      smartmeter.0
                      2021-10-25 17:41:02.115	warn	Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0
                      2021-10-25 17:41:02.114	info	Error: Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0
                      2021-10-25 17:41:01.103	warn	No match for Message "\u0000"
                      smartmeter.0
                      2021-10-25 17:41:01.101	info	Error: No match for Message "\u0000"
                      smartmeter.0
                      2021-10-25 17:41:00.059	warn	Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0
                      2021-10-25 17:41:00.057	info	Error: Error on Baudrate changeover: Error: Port is not open
                      Martin
                      • M MartyBr
                        Hier mal das Log:
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        smartmeter.0
                        #2171
                        passt!
                        entweder falscher Port in der Konfig, oder der Port wird durch ein anderes Programm benutzt
                          MartyBr
                          #2172
                          Das ist eine Verknüpfung zu den USB Leseköpfen:
                          usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D2C-if00-port0
                          usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D30-if00-port0
                          pi@ioBroker-RasPi:/dev/serial/by-id $
                          Martin
                            passt!
                            MartyBr
                            #2173
                            Das "lustige" an der Situation ist, dass der Adapter bis heute funktioniert hat. Ich habe heute den neuen Zähler bekommen und den IR Lesekopf umgesteckt.
                            Martin
                            • M MartyBr
                              #2174
                              und warum sind deine Einstellungen so geheim?
                              M 2 Antworten Letzte Antwort
                                MartyBr
                                #2175
                                Ich hatte die von noox 1 zu 1 übernommen.
                                Also:
                                Martin
                                • M MartyBr
                                  Also:
                                  MartyBr
                                  #2176
                                  @Homoran
                                  Ich habe die Einstellung der Schnittstelle:
                                  pi@ioBroker-RasPi:/dev $ sudo stty -F /dev/lesekopf1
                                  speed 300 baud; line = 0;
                                  min = 1; time = 0;
                                  -brkint -icrnl -imaxbel
                                  -opost -onlcr
                                  -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
                                  Martin
                                    MartyBr
                                    #2177
                                    Ich habe auch den langen Device-Namen eingetragen:
                                    Auch das funktioniert nicht.
                                    Edit:
                                    Kann es sein, das ioBroker nicht (mehr) auf die Schnittstelle zugreifen kann? Die Ausgabe per cat/.... läuft ja.
                                    Martin
                                    • M MartyBr
                                      Edit:
                                      #2178
                                      wie ich schrob:
                                      @homoran sagte in Adapter "smartmeter":
                                      passt!
                                      was machst du da???
                                      nix auf der Konsole mit dem Lesekopf machen
                                      und bitte deine Konfig zeigen!
                                      keine Nacherzählung
                                        wie ich schrob:
                                        passt!
                                        was machst du da???
                                        keine Nacherzählung
                                        MartyBr
                                        #2179
                                        Ich hatte sie oben gepostet, hier noch mal:
                                        Trotzdem verstehe ich die Meldung nicht
                                        passt!
                                        Es kommen Daten an, sonst könnte ich sie nicht per cat anzeigen. cat blockiert doch keine Ports.
                                        Martin
                                        • M MartyBr
                                          passt!
                                          #2180
                                          @martybr doch serielle Ports sind dann geblockt. Daher nochmal: wenn adapter dann kein paralleles cat bitte.
