  4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
    6.3k
citroencorsacorsa-eopelpeugeotpsae208
334 Beiträge 44 Kommentatoren 86.2k Aufrufe 43 Beobachtet
  • M mane444
    @tombox Hi, Systemabsturz ist weg. Nun werden die Daten gelesen, aber nach einer Stunde kommen Errors und es werden keine Datenpunkte mehr aktualisiert.
    Hier das Log, ab 9:12 wurden keine Daten mehr aktualisiert. Nach einem Neustart des Adapters läuft das ganze wieder für eine Stunde
    psa.0
    2021-06-28 09:22:57.899	error	Get device status failed
    psa.0
    2021-06-28 09:22:57.897	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
    psa.0
    2021-06-28 09:22:57.896	error	Get VR7BCZKXCME028557.status failed
    psa.0
    2021-06-28 09:22:57.894	error	Error: Request failed with status code 401
    psa.0
    2021-06-28 09:17:58.017	error	Get device status failed
    psa.0
    2021-06-28 09:17:58.015	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
    psa.0
    2021-06-28 09:17:58.013	error	Get VR7BCZKXCME028557.status failed
    psa.0
    2021-06-28 09:17:58.010	error	Error: Request failed with status code 401
    psa.0
    2021-06-28 09:17:57.999	error	Get device status failed
    psa.0
    2021-06-28 09:17:57.997	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
    psa.0
    2021-06-28 09:17:57.995	error	Get VR7BCZKXCME028557.status failed
    psa.0
    2021-06-28 09:17:57.993	error	Error: Request failed with status code 401
    psa.0
    2021-06-28 09:17:56.329	error	Refresh token failed
    psa.0
    2021-06-28 09:17:56.327	error	{"error":"invalid_client","error_description":"Client authentication failed"}
    psa.0
    2021-06-28 09:17:56.326	error	Refreshtoken failed
    psa.0
    2021-06-28 09:17:56.311	error	Error: Request failed with status code 401
    psa.0
    2021-06-28 08:17:56.930	info	Login successful
    psa.0
    2021-06-28 08:17:56.228	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
    host.TestBroker
    2021-06-28 08:17:51.210	info	instance system.adapter.psa.0 started with pid 8893
    host.TestBroker
    2021-06-28 08:17:48.763	info	instance system.adapter.psa.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    tombox
    #41
    @mane444 Eigentlich sollte das erst nach 3h kommen. Ich habe mal auf 1h reduziert und den Fehler abgefangen.
    Einfach nochmal probieren.
    HumidorH M 2 Antworten Letzte Antwort
      aueland
      #42
      @tombox die Fehlermeldung von @mane444 habe ich nicht bekommen, aber aktuell gibt es gerade diesen Fehler:
      psa.0	2021-06-28 16:33:49.432	warn	(20643) {"code":"404","message":"404 Not found"}
      psa.0	2021-06-28 16:33:49.431	warn	(20643) receive old api failed
      psa.0	2021-06-28 16:33:49.431	warn	(20643) Error: Request failed with status code 404
      Die neue API-Abfrage läuft ohne Probleme durch seit heute Morgen.
      • T tombox
        HumidorH Offline
        HumidorH Offline
        Humidor
        schrieb am zuletzt editiert von Humidor
        #43
        @tombox morgen, wie fkt. das mit der "neuen" API ? ist 0.0.6 aktuell?
        psa.0	2021-06-30 08:04:31.872	error	(394990) Get vehicles failed
        psa.0	2021-06-30 08:04:31.872	error	(394990) No compatible vehicles found. Maybe your vehicle is too old.
        psa.0	2021-06-30 08:04:31.871	error	(394990) {"uuid":"1207d474-f6f4-4077-b40b-6f4cd7872349","code":40410,"message":"No vehicule found"}
        psa.0	2021-06-30 08:04:31.871	error	(394990) Get Vehicles failed
        psa.0	2021-06-30 08:04:31.871	error	(394990) Error: Request failed with status code 404
        psa.0	2021-06-30 08:04:31.266	warn	(394990) No Token received for old api
        psa.0	2021-06-30 08:04:31.265	warn	(394990) {"session":"1cec33b9eeb5a7b64baf4a37acfedca3","returnCode":"NEED_AUTHORIZATION","token":"ffae1e4d78b9ea8b64df43801ef63f3c062923edd725369600f930d4df2fa08e"}
        psa.0	2021-06-30 08:04:31.265	debug	(394990) {"session":"1cec33b9eeb5a7b64baf4a37acfedca3","returnCode":"NEED_AUTHORIZATION","token":"ffae1e4d78b9ea8b64df43801ef63f3c062923edd725369600f930d4df2fa08e"}
        psa.0	2021-06-30 08:04:31.023	info	(394990) Login successful
        BG
        • HumidorH Humidor
          tombox
          #44
          @humidor welches Baujahr hast du und in welcher App wird dir dein Fahrzeug angezeigt
          • T tombox
            mane444
            #45
            @tombox Hi ich hab das heute nochmal mit der neusten Version getestet. Bei läuft das immer genau 1 Stunde dann kommt der Fehler.
            psa.0
            2021-06-30 11:39:37.068	error	{"error":"invalid_client","error_description":"Client authentication failed"}
            psa.0
            2021-06-30 11:39:37.068	error	Refreshtoken failed
            psa.0
            2021-06-30 11:39:37.067	error	Error: Request failed with status code 401
            psa.0
            2021-06-30 11:39:36.827	info	Token expired. Try to refresh token
            psa.0
            2021-06-30 11:39:36.816	info	Token expired. Try to refresh token
            psa.0
            2021-06-30 11:39:36.373	error	Refresh token failed
            psa.0
            2021-06-30 11:39:36.373	error	{"error":"invalid_client","error_description":"Client authentication failed"}
            psa.0
            2021-06-30 11:39:36.372	error	Refreshtoken failed
            psa.0
            2021-06-30 11:39:36.366	error	Error: Request failed with status code 401
            psa.0
            2021-06-30 10:39:35.907	info	Login successful
            psa.0
            2021-06-30 10:39:35.423	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
            Auto Citroen eC4; HandyApp MYCitroen v.1.29.3
            Vielleicht hilfts ja bei der Lösung.
            • T tombox
              HumidorH Offline
              HumidorH Offline
              Humidor
              #46
              @tombox BJ 2021, App ? MyPeugeot
              BG
              • M mane444
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                tombox
                #47
                @mane444 Danke für den hinweis citroen sollte jetzt gefixt sein
                • HumidorH Humidor
                  tombox
                  #48
                  @humidor Ist es auch ein E Auto? Was passiert wenn du dich in der App ausloggst und nochmal einloggst
                  • T tombox
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    #49
                    @tombox nein, ein std. 2008 kein e-2008, dh. nur e gehen? ein Sim hat er mW. es wird ja die Position im App angezeigt.
                    BG
                    • HumidorH Humidor
                      tombox
                      #50
                      @humidor die normalen gehen such aber nur Kilometer stand. Aber dein Login geht nicht deswegen mal mit der aktuellen App probieren ob man sich einloggen kann
                      • T tombox
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        #51
                        @tombox Login ist korrekt, mich interessiert nur die Position, dh das fkt nicht?
                        BG
                        • HumidorH Humidor
                          tombox
                          schrieb am zuletzt editiert von tombox
                          #52
                          @humidor Mit einem Nicht E Fahrzeug wird das nicht unterstützt. Die Position wird glaube nur via Bluetooth an die App übertragen
                          • T tombox
                            mane444
                            #53
                            @tombox Hi, läuft seit 6 Std ohne Probleme.
                            Super !👍
                            M M 2 Antworten Letzte Antwort
                            • M mane444
                              Super !👍
                              MasterAndi0815
                              #54
                              Hallo tombox,
                              musste leider feststellen, dass die Daten nicht mehr aktualisiert wurden.
                              Habe den Adapter deinstalliert und die aktuelle Version wieder installiert.
                              Aber es kommt ein Login Fehler, obwohl die Anmeldedaten stimmen.
                              Vorher kommt aber ein Zertifikatsfehler, der mich vermuten lässt, dass die Peugeot Webseite aufgerufen wird und nicht die Citroen Seite, obwohl ich in der Instanz Citroen ausgewählt habe.
                              psa.0	2021-07-05 13:55:31.161	error	(15382) Login failed
                              psa.0	2021-07-05 13:55:31.161	error	(15382) {"error":"invalid_grant","error_description":"The provided access grant is invalid, expired, or revoked."}
                              psa.0	2021-07-05 13:55:31.160	error	(15382) Login failed
                              psa.0	2021-07-05 13:55:31.160	error	(15382) Error: Request failed with status code 400
                              psa.0	2021-07-05 13:55:31.065	warn	(15382) OldAPI Login failed
                              psa.0	2021-07-05 13:55:31.064	warn	(15382) Login old api failed
                              psa.0	2021-07-05 13:55:31.064	warn	(15382) Error [ERR_TLS_CERT_ALTNAME_INVALID]: Hostname/IP does not match certificate's altnames: Host: id-dcr.peugeot.com. is not in the cert's altnames: DNS:*.citroen.com
                              psa.0	2021-07-05 13:55:30.908	info	(15382) starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.2, js-controller: 3.2.16
                              M T 2 Antworten Letzte Antwort
                              • M mane444
                                Super !👍
                                mane444
                                #55
                                @mane444 Hi bei mir hatte der Adapter heute Nacht auch wieder einen Hänger. Hab dann heute Mittag den Adapter neu gestartet nun kommen die Werte wieder.
                                psa.0
                                2021-07-05 04:00:02.855	warn	OldAPI Login failed
                                psa.0
                                2021-07-05 04:00:02.854	warn	Login old api failed
                                psa.0
                                2021-07-05 04:00:02.853	warn	Error: getaddrinfo ENOTFOUND id-dcr.citroen.com
                                psa.0
                                2021-07-05 04:00:02.840	error	Login failed
                                psa.0
                                2021-07-05 04:00:02.839	error	Login failed
                                psa.0
                                2021-07-05 04:00:02.838	error	Error: getaddrinfo ENOTFOUND idpcvs.citroen.com
                                psa.0
                                2021-07-05 03:59:52.715	info	starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
                                host.buanet-iobroker1
                                2021-07-05 03:59:50.380	info	instance system.adapter.psa.0 started with pid 31308
                                2021-07-05 03:59:20.276	info	Restart adapter system.adapter.psa.0 because enabled
                                2021-07-05 03:59:20.197	error	instance system.adapter.psa.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                psa.0
                                2021-07-05 03:59:19.423	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                psa.0
                                2021-07-05 03:59:19.420	info	terminating
                                psa.0
                                2021-07-05 03:59:19.420	warn	Clear yet terminated interval 527
                                psa.0
                                2021-07-05 03:59:19.419	warn	Clear yet terminated interval undefined
                                psa.0
                                2021-07-05 03:59:19.419	warn	Clear yet terminated interval 597
                                psa.0
                                2021-07-05 03:59:19.412	error	Cannot read property 'status' of undefined
                                psa.0
                                2021-07-05 03:59:19.411	error	TypeError: Cannot read property 'status' of undefined at /opt/iobroker/node_modules/iobroker.psa/main.js:392:40 at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                psa.0
                                2021-07-05 03:59:19.410	error	unhandled promise rejection: Cannot read property 'status' of undefined
                                psa.0
                                2021-07-05 03:59:19.410	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                psa.0
                                2021-07-05 03:59:18.796	error	Refresh token failed
                                psa.0
                                2021-07-05 03:59:18.796	error	Refreshtoken failed
                                psa.0
                                2021-07-05 03:59:18.795	error	Error: getaddrinfo ENOTFOUND idpcvs.citroen.com
                                • M MasterAndi0815
                                  Hallo tombox,
                                  MasterAndi0815
                                  schrieb am zuletzt editiert von MasterAndi0815
                                  #56
                                  @masterandi0815
                                  Jetzt wollte ich zum Test mich in der App auf dem iPhone einmal neu anmelden, leider klappt das auch nicht. Beim Passwort vergessen wird nicht mal meine E-Mail Adresse akzeptiert.
                                  Wie es aussieht hat PSA/Stellantis gerade eine anderes Problem.
                                  Werde es gleich noch mal unter Android probieren. -> Unter Android dasselbe Problem.
                                  Zum Glück ist der Account auf dem iPhone meiner Frau noch angemeldet.
                                  • M MasterAndi0815
                                    Hallo tombox,
                                    tombox
                                    #57
                                    @masterandi0815 installier nochmal neu und probiere nochmal
                                    • M MasterAndi0815
                                      @masterandi0815
                                      H Online
                                      H Online
                                      holgerwolf
                                      #58
                                      @masterandi0815 Das Problem hatte ich letzte Woche auch. Ging garnix mehr. Useraccount kannte die App nicht, deshalb konnte man die auch nicht zurücksetzen.
                                      Ich musste den Zugang komplett neu einrichten. Und hänge jetzt wohl auch auf nem anderen Server. Jedenfalls bekommt Tronity keine GPS Daten mehr. Das ging bei mir im Gegensatz zu vielen anderen die letzten Wochen noch.
                                      Ich tippe mal, PSA baut um und schaltet nach und nach die alte API ab,
                                      • H holgerwolf
                                        MasterAndi0815
                                        #59
                                        @holgerwolf
                                        Habe jetzt auch den Account unter derselben E-Mail Adresse neu angelegt und unseren e-C4 neu verbunden.
                                        Witzigerweise kam dann noch eine E-Mail, dass die Remote Dienste gekündigt wurden, da das Auto mit einem neuen Account verbunden wurde.
                                        Auf jeden Fall funktioniert jetzt auch der Adapter wieder einwandfrei und die Daten werden wieder einwandfrei abgerufen.
                                          mane444
                                          #60
                                          Hi, ich hab immer mal wieder Abbrüche der Verbindung. Sobald ich den Adapter neu starte läuft es wieder.
                                          Gibt's da eine Erklärung?
                                          Kann man irgendwie die "old API" abschalten, da scheinbar hier das Problem herkommt.
                                          Auto ist Citroen C4 elektro.
                                          info.0
                                          2021-07-24 08:48:56.815	error	Error: connect ETIMEDOUT 185.199.111.133:443
                                          psa.0
                                          2021-07-24 08:46:21.863	error	Login failed
                                          psa.0
                                          2021-07-24 08:46:21.862	error	Login failed
                                          psa.0
                                          2021-07-24 08:46:21.861	error	Error: getaddrinfo ENOTFOUND idpcvs.citroen.com
                                          psa.0
                                          2021-07-24 08:46:21.857	warn	OldAPI Login failed
                                          psa.0
                                          2021-07-24 08:46:21.856	warn	Login old api failed
                                          psa.0
                                          2021-07-24 08:46:21.855	warn	Error: getaddrinfo ENOTFOUND id-dcr.citroen.com
