  4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
    6.3k
citroencorsacorsa-eopelpeugeotpsae208
334 Beiträge 44 Kommentatoren 86.2k Aufrufe 43 Beobachtet
  • T tombox
    @mane444 für old api failed problem einfach nochmal neu installieren und instanz neustarten
    mane444
    @tombox Das System stürzt wieder nach einer gewissen Zeit ab. Ich hab folgendes bemerkt. Da kommen Warnmeldungen und die verdoppeln sich nach jedem Zyklus.
    psa.0
    2021-06-27 21:35:37.174	warn	Clear yet terminated interval 118106
    psa.0
    2021-06-27 21:35:26.420	warn	Clear yet terminated interval 117788
    psa.0
    2021-06-27 21:35:26.345	warn	Clear yet terminated interval 115138
    psa.0
    2021-06-27 21:35:25.730	warn	Clear yet terminated interval 114820
    psa.0
    2021-06-27 21:35:25.647	warn	Clear yet terminated interval 112097
    psa.0
    2021-06-27 21:35:25.108	warn	Clear yet terminated interval 109109
    psa.0
    2021-06-27 21:35:24.622	warn	Clear yet terminated interval 108791
    psa.0
    2021-06-27 21:35:24.530	warn	Clear yet terminated interval 108473
    psa.0
    2021-06-27 21:35:24.483	warn	Clear yet terminated interval 107257
    psa.0
    2021-06-27 21:35:24.291	warn	Clear yet terminated interval 106346
    psa.0
    2021-06-27 21:35:24.162	warn	Clear yet terminated interval 90914
    psa.0
    2021-06-27 21:35:17.424	warn	Clear yet terminated interval 89087
    psa.0
    2021-06-27 21:35:17.141	warn	Clear yet terminated interval 88769
    psa.0
    2021-06-27 21:35:17.066	warn	Clear yet terminated interval 87853
    psa.0
    2021-06-27 21:35:16.896	warn	Clear yet terminated interval 83101
    psa.0
    2021-06-27 21:35:12.777	warn	Clear yet terminated interval 76868
    psa.0
    2021-06-27 21:30:26.502	warn	Clear yet terminated interval 66656
    psa.0
    2021-06-27 21:30:22.509	warn	Clear yet terminated interval 65998
    psa.0
    2021-06-27 21:30:22.356	warn	Clear yet terminated interval 63233
    psa.0
    2021-06-27 21:30:21.753	warn	Clear yet terminated interval 51482
    psa.0
    2021-06-27 21:30:17.661	warn	Clear yet terminated interval 50031
    psa.0
    2021-06-27 21:30:17.491	warn	Clear yet terminated interval 49404
    psa.0
    2021-06-27 21:30:17.325	warn	Clear yet terminated interval 44666
    psa.0
    2021-06-27 21:30:13.129	warn	Clear yet terminated interval 38440
    psa.0
    2021-06-27 21:25:21.732	warn	Clear yet terminated interval 31612
    psa.0
    2021-06-27 21:25:17.616	warn	Clear yet terminated interval 29438
    psa.0
    2021-06-27 21:25:17.059	warn	Clear yet terminated interval 24897
    psa.0
    2021-06-27 21:25:12.892	warn	Clear yet terminated interval 18781
    psa.0
    2021-06-27 21:20:17.319	warn	Clear yet terminated interval 14132
    psa.0
    2021-06-27 21:20:12.772	warn	Clear yet terminated interval 8241
    psa.0
    2021-06-27 21:15:13.068	warn	Clear yet terminated interval 2076
    psa.0
    2021-06-27 21:10:07.730	warn	Clear yet terminated interval undefined
    • M mane444
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      psa.0
      tombox
      @mane444 Ich habe nochmal was umgeschoben probiere es nochmal
        aueland
        Moin @tombox
        wollte auch ein Feedback geben. Toll, dass du den Adapter aufgesetzt hast!
        Nutze ihn gerade mit einem Peugeot e208 aus 2020.
        Läuft soweit, Login funktioniert, Daten kommen rein. Den Fehler
        hatte ich gestern nach der ersten Installation auch. Jetzt nochmal nach Deiner Änderung neu installiert und die Warnung scheint weg zu sein.
        Witzig ist, dass der Kilometerstand zwischen alter und neue API unterschiedlich zu sein scheint bzw. die neue API den aktuelleren Stand ausliest.
        Den Update-Intervall habe ich jetzt erstmal auf den 5 Minuten gelassen, aber gerade wenn es um das Laden geht, würde ich gerne Häufiger abfragen, gibt es dann Probleme mit der API oder kann man auch in Abständen problemlos abfragen?
        Habe ich das richtig verstanden, Du hast den vor den Adapter so aufzubohren, dass zukünftig auch ein Steuern über iobroker möglich wird? Also vor allem Vorklimatisierung, Ladesteuerung... Das wäre echt Spitze!
        T H 2 Antworten Letzte Antwort
        • A aueland
          Moin @tombox
          tombox
          @aueland Gut das der Fehler jetzt weg ist.
          Ich denke di eAPI kann einiges ab und minütlich sollte gehen oder weniger
          Ja wenn ich Zeit habe schon aber der Ablauf ist sehr kompliziert mit der SMS aktivierung
          • A aueland
            Moin @tombox
            H Online
            H Online
            holgerwolf
            @aueland sagte in Test Adapter PSA v0.0.x Peugot Opel Citroen:
            Das wird dir nix bringen, weil PSA leider den SoC beim Laden nicht aktualisiert :-(
              aueland
              @holgerwolf ok, das ist natürlich blöd, aber in der myPeugeot App - wenn sie denn mal funktioniert, wird es doch auch angezeigt...
              Sonst muss ich mal schauen, ob ich dann nicht was über die Daten der Wallbox basteln kann. Also Ausgangslage via psa und dann hinzurechnen, was die Wallbox als Ladung angibt.
              @tombox said in Test Adapter PSA v0.0.x Peugot Opel Citroen:
              Danke, bin gespannt und stehe für Tests gerne zur Verfügung.
              H 1 Antwort Letzte Antwort
              • A aueland
                H Online
                H Online
                holgerwolf
                Ja, aber du willst ja auch nicht ständig in der App nachschauen, damit dann die API nen neuen Wert hat ;-)
                Welche Wallbox hast du? Bei der OpenWB wird das jetzt schon gemacht. Beim Ladestart SoC abfragen und dann den SoC anhand der Lademenge, Batteriegröße und Effizienz berechen.
                • H holgerwolf
                  aueland
                  @holgerwolf habe die E3/DC easy Connect. Überschussladen klappt damit mehr oder weniger, aber z.B. nicht das Fzg. nur bis x% aufladen. Wobei ich da eventuell mit einem Script über die Wallboxsteuerung noch was machen könnte, aber das gibt es eben bisher m.W. nicht und ich konnte mich noch nicht damit beschäftigen. Greife im Moment nur lesend via modbus drauf zu. Über RSPC wäre auch eine schreibende Umsetzung möglich und damit das, was ich möchte. Wenn das aber auch von der anderen Seite - dem Peugeot her - ginge, wäre ich nicht böse drum ;-)
                  • T tombox
                    mane444
                    @tombox Hi, Systemabsturz ist weg. Nun werden die Daten gelesen, aber nach einer Stunde kommen Errors und es werden keine Datenpunkte mehr aktualisiert.
                    Hier das Log, ab 9:12 wurden keine Daten mehr aktualisiert. Nach einem Neustart des Adapters läuft das ganze wieder für eine Stunde
                    psa.0
                    2021-06-28 09:22:57.899	error	Get device status failed
                    psa.0
                    2021-06-28 09:22:57.897	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
                    psa.0
                    2021-06-28 09:22:57.896	error	Get VR7BCZKXCME028557.status failed
                    psa.0
                    2021-06-28 09:22:57.894	error	Error: Request failed with status code 401
                    psa.0
                    2021-06-28 09:17:58.017	error	Get device status failed
                    psa.0
                    2021-06-28 09:17:58.015	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
                    psa.0
                    2021-06-28 09:17:58.013	error	Get VR7BCZKXCME028557.status failed
                    psa.0
                    2021-06-28 09:17:58.010	error	Error: Request failed with status code 401
                    psa.0
                    2021-06-28 09:17:57.999	error	Get device status failed
                    psa.0
                    2021-06-28 09:17:57.997	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
                    psa.0
                    2021-06-28 09:17:57.995	error	Get VR7BCZKXCME028557.status failed
                    psa.0
                    2021-06-28 09:17:57.993	error	Error: Request failed with status code 401
                    psa.0
                    2021-06-28 09:17:56.329	error	Refresh token failed
                    psa.0
                    2021-06-28 09:17:56.327	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                    psa.0
                    2021-06-28 09:17:56.326	error	Refreshtoken failed
                    psa.0
                    2021-06-28 09:17:56.311	error	Error: Request failed with status code 401
                    psa.0
                    2021-06-28 08:17:56.930	info	Login successful
                    psa.0
                    2021-06-28 08:17:56.228	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
                    host.TestBroker
                    2021-06-28 08:17:51.210	info	instance system.adapter.psa.0 started with pid 8893
                    host.TestBroker
                    2021-06-28 08:17:48.763	info	instance system.adapter.psa.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    • M mane444
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      psa.0
                      host.TestBroker
                      host.TestBroker
                      tombox
                      @mane444 Eigentlich sollte das erst nach 3h kommen. Ich habe mal auf 1h reduziert und den Fehler abgefangen.
                      Einfach nochmal probieren.
                      HumidorH M 2 Antworten Letzte Antwort
                        aueland
                        @tombox die Fehlermeldung von @mane444 habe ich nicht bekommen, aber aktuell gibt es gerade diesen Fehler:
                        psa.0	2021-06-28 16:33:49.432	warn	(20643) {"code":"404","message":"404 Not found"}
                        psa.0	2021-06-28 16:33:49.431	warn	(20643) receive old api failed
                        psa.0	2021-06-28 16:33:49.431	warn	(20643) Error: Request failed with status code 404
                        Die neue API-Abfrage läuft ohne Probleme durch seit heute Morgen.
                        • T tombox
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          schrieb am zuletzt editiert von Humidor
                          @tombox morgen, wie fkt. das mit der "neuen" API ? ist 0.0.6 aktuell?
                          psa.0	2021-06-30 08:04:31.872	error	(394990) Get vehicles failed
                          psa.0	2021-06-30 08:04:31.872	error	(394990) No compatible vehicles found. Maybe your vehicle is too old.
                          psa.0	2021-06-30 08:04:31.871	error	(394990) {"uuid":"1207d474-f6f4-4077-b40b-6f4cd7872349","code":40410,"message":"No vehicule found"}
                          psa.0	2021-06-30 08:04:31.871	error	(394990) Get Vehicles failed
                          psa.0	2021-06-30 08:04:31.871	error	(394990) Error: Request failed with status code 404
                          psa.0	2021-06-30 08:04:31.266	warn	(394990) No Token received for old api
                          psa.0	2021-06-30 08:04:31.265	warn	(394990) {"session":"1cec33b9eeb5a7b64baf4a37acfedca3","returnCode":"NEED_AUTHORIZATION","token":"ffae1e4d78b9ea8b64df43801ef63f3c062923edd725369600f930d4df2fa08e"}
                          psa.0	2021-06-30 08:04:31.265	debug	(394990) {"session":"1cec33b9eeb5a7b64baf4a37acfedca3","returnCode":"NEED_AUTHORIZATION","token":"ffae1e4d78b9ea8b64df43801ef63f3c062923edd725369600f930d4df2fa08e"}
                          psa.0	2021-06-30 08:04:31.023	info	(394990) Login successful
                          BG
                          • HumidorH Humidor
                            tombox
                            @humidor welches Baujahr hast du und in welcher App wird dir dein Fahrzeug angezeigt
                            HumidorH 1 Antwort Letzte Antwort
                            • T tombox
                              mane444
                              @tombox Hi ich hab das heute nochmal mit der neusten Version getestet. Bei läuft das immer genau 1 Stunde dann kommt der Fehler.
                              psa.0
                              2021-06-30 11:39:37.068	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                              psa.0
                              2021-06-30 11:39:37.068	error	Refreshtoken failed
                              psa.0
                              2021-06-30 11:39:37.067	error	Error: Request failed with status code 401
                              psa.0
                              2021-06-30 11:39:36.827	info	Token expired. Try to refresh token
                              psa.0
                              2021-06-30 11:39:36.816	info	Token expired. Try to refresh token
                              psa.0
                              2021-06-30 11:39:36.373	error	Refresh token failed
                              psa.0
                              2021-06-30 11:39:36.373	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                              psa.0
                              2021-06-30 11:39:36.372	error	Refreshtoken failed
                              psa.0
                              2021-06-30 11:39:36.366	error	Error: Request failed with status code 401
                              psa.0
                              2021-06-30 10:39:35.907	info	Login successful
                              psa.0
                              2021-06-30 10:39:35.423	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
                              Auto Citroen eC4; HandyApp MYCitroen v.1.29.3
                              Vielleicht hilfts ja bei der Lösung.
                              • T tombox
                                HumidorH Offline
                                HumidorH Offline
                                Humidor
                                @tombox BJ 2021, App ? MyPeugeot
                                BG
                                • M mane444
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  psa.0
                                  tombox
                                  @mane444 Danke für den hinweis citroen sollte jetzt gefixt sein
                                  • HumidorH Humidor
                                    tombox
                                    @humidor Ist es auch ein E Auto? Was passiert wenn du dich in der App ausloggst und nochmal einloggst
                                    • T tombox
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      @tombox nein, ein std. 2008 kein e-2008, dh. nur e gehen? ein Sim hat er mW. es wird ja die Position im App angezeigt.
                                      BG
                                      • HumidorH Humidor
                                        tombox
                                        @humidor die normalen gehen such aber nur Kilometer stand. Aber dein Login geht nicht deswegen mal mit der aktuellen App probieren ob man sich einloggen kann
                                        • T tombox
                                          HumidorH Offline
                                          HumidorH Offline
                                          Humidor
                                          @tombox Login ist korrekt, mich interessiert nur die Position, dh das fkt nicht?
                                          BG
