  4. Adapter: ioBroker.unifi
    apollon77A
unifi
1.0k Beiträge 172 Kommentatoren 613.5k Aufrufe 93 Beobachtet
  • F
    F
    Fuga
    #181
    ich habe den Adapter auch mal installiert bekomme aber fehler meldung im log:
    host.Home 2018-11-22 23:59:35.555 error instance system.adapter.unifi.0 terminated with code 0 (OK)
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at Array.every (native)
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
    Caught 2018-11-22 23:59:35.555 error by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    Caught 2018-11-22 23:59:35.554 error by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:57
    Caught 2018-11-22 23:59:35.554 error by controller[0]: TypeError: Cannot read property 'subsystem' of null
    unifi.0 2018-11-22 23:59:35.498 info cleaned everything up…
    unifi.0 2018-11-22 23:59:35.497 error at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
    unifi.0 2018-11-22 23:59:35.497 error at Array.every (native)
    unifi.0 2018-11-22 23:59:35.497 error at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
    unifi.0 2018-11-22 23:59:35.497 error at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    unifi.0 2018-11-22 23:59:35.497 error at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
    unifi.0 2018-11-22 23:59:35.497 error at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
    unifi.0 2018-11-22 23:59:35.497 error at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
    unifi.0 2018-11-22 23:59:35.497 error at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    unifi.0 2018-11-22 23:59:35.497 error at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:57
    unifi.0 2018-11-22 23:59:35.497 error TypeError: Cannot read property 'subsystem' of null
    unifi.0 2018-11-22 23:59:35.497 error uncaught exception: Cannot read property 'subsystem' of null
    unifi.0 2018-11-22 23:59:35.477 info getSitesStats: default
    unifi.0 2018-11-22 23:59:32.814 info controller = 192.168.1.121:8443
    unifi.0 2018-11-22 23:59:32.814 info update_interval = 60
    unifi.0 2018-11-22 23:59:32.813 info Starting UniFi-Controller query
    unifi.0 2018-11-22 23:59:32.800 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v6.14.4
    host.Home 2018-11-22 23:59:31.932 info instance system.adapter.unifi.0 started with pid 25137
    host.Home 2018-11-22 23:59:01.914 info Restart adapter system.adapter.unifi.0 because enabled
    Kann damit jemand was anfangen? Interessanterweise ergänzt er jedes mal einen Objekt im Objekt Ordner.
    PS: Im Unifi Controller sehe ich das er sich anmeldet also passen die Daten.
    • A
      A
      aleks-83
      #182
      Erstmal eine generelle Frage:
      Funktioniert der Adapter aktuell überhaupt noch?
      Meine UniFi Instanz startet und läuft laut Log sauber.
      Aber wenn ich die IP mit dem Port aufrufe (was bisher sofort funktionierte) wird das Laden der Seite irgendwann mit einer Zeitüberschreitung abgebrochen. der Firefox kommt noch bis zum "TLS-Handshake". Dieser scheint dann zu lange zu dauern.
      Wenn ich z.B. einen falschen Port angebe, merkt der Browser das sofort und meldet "Verbindung fehlgeschlagen".
      Eine Neuinstallation des Adapters hat nicht geholfen.
      Starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v8.12.0
      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
      = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
      Glasfaser 400
      • DutchmanD
        DutchmanD
        Dutchman
        #183
        bei mir laeuft alles noch
        • ThomasLPZT
          ThomasLPZT
          ThomasLPZ
          #184
          @aleks-83:
          Funktioniert der Adapter aktuell überhaupt noch? `
          Bei mir ist alles i.O.
          • P
            P
            ple
            #185
            Bei mir läuft er auch noch soweit, nur meine Anwesenheit kann ich damit nicht sauber prüfen. Bei 2 iPhones und einen android meldet er auch nach 4 Minuten mal, das ein Gerät abwesend ist. Dann ist es auf einmal wieder da.
            Hat wer von euch iPhones im Einsatz und prüft die Anwesenheit mit dem unifi Adapter?
            Oder sind noch weitere Einstellungen im Controller nötig.
            Habe zur Zeit 2 ap pro, Usg, und ein Switch.
            Intel Nuc + Proxmox
            • K
              K
              Kuddel
              #186
              Bei mir braucht der Unifi Adapter ca 10 Min um die Abwesenheit der Android Handy zu bemerken.
              DIe Einwahl ins WLAN bekommt der Adapter aber innerhalb von 30 Sekunden mit.
              Meine Anwesenheitssteuerung mit dem Unifi Adapter und einem Blockly Script läuft richtig gut
              • a200A
                a200A
                a200
                #187
                Hat sich erledigt. War die falsche Instanz. Sorry!
                Unter welchen Datenpunkt (Pfad) bekommst du die eingebuchten mac-Adressen aufgelistet. Mein Unifi Adapter läuft, aber den richtigen Datenpunkt habe ich noch nicht gefunden.
                Danke,
                a200.
                • P
                  P
                  ple
                  #188
                  @Kuddel:
                  Meine Anwesenheitssteuerung mit dem Unifi Adapter und einem Blockly Script läuft richtig gut `
                  Mach bitte mal ein Export von deinem Blockly. im Moment prüfe ich die anwesendheit wie folgt.
                  Last Timestamp + 3min - aktuelle zeit.
                  und da kommt es mal vor, dass Nachts ein Gerät abwesend geht, und das mal für 10 oder für 20 min. sobald es mal wieder aktiviert wird, gehts erst mal.
                  Bin mir nicht sicher, ob es noch Einstellungen im Unifi controller gibt, der das unterbindet.
                  Gruß und Danke
                  Intel Nuc + Proxmox
                  • K
                    K
                    Kuddel
                    #189
                    @ple:
                    @Kuddel:
                    Gruß und Danke `
                    Anwesenheit-Daniel
                    ! <xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="(8IEHS;3UV%Behk#V/ZA" x="-287" y="-336"><field name="SCHEDULE">*/5 * * * * *</field> <statement name="STATEMENT"><block type="controls_if" id="_D%O3y*a~O{5b]62/}pH"><mutation else="1"></mutation> <value name="IF0"><block type="logic_compare" id="{g2F#0g(xBSI!W+Ce3z@"><field name="OP">EQ</field> <value name="A"><block type="logic_compare" id="yOUpdRZuxE?@wAZLL;C{"><field name="OP">LT</field> <value name="A"><block type="math_arithmetic" id="@m_|`iM+n_p/Ychstc]S" inline="false"><field name="OP">MINUS</field> <value name="A"><shadow type="math_number" id="}iB%qwSrOwobDRjgfer8"><field name="NUM">1</field></shadow> <block type="get_value" id="+I72h`S}%r!`1;9|lD}g"><field name="ATTR">lc</field> <field name="OID">unifi.0.default.clients.8c:45:00:06:d8:02._uptime_by_uap</field></block></value> <value name="B"><shadow type="math_number" id="3X82G}`M9!H830yO/T#}"><field name="NUM">1</field></shadow> <block type="math_arithmetic" id="pa8lYgju|Cm%*q1-|Aak"><field name="OP">MINUS</field> <value name="A"><shadow type="math_number" id="(4Ry[Iycy@_Y%:P1[h6p"><field name="NUM">1</field></shadow> <block type="time_get" id="Q{Y4sPP4x93J%fj=}%~f"><mutation format="false" language="false"></mutation> <field name="OPTION">object</field></block></value> <value name="B"><shadow type="math_number" id="(_CVHD|_i]Wga;X![aT8"><field name="NUM">120000</field></shadow></value></block></value></block></value> <value name="B"><block type="math_number" id="SZwY0]w.17S(2SWwv7M3"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_boolean" id="Pj]*,,C5JkN8.N{efF-v"><field name="BOOL">TRUE</field></block></value></block></value> <statement name="DO0"><block type="control" id="=y1(AR^%tE~NZjw5R6B~"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Anwesenheit.Daniel</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="IxiYM)Zv:-j:wQ7j*F.e"><field name="BOOL">FALSE</field></block></value></block></statement> <statement name="ELSE"><block type="control" id="OkB}7pJaqOet~G9N.HSL"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Anwesenheit.Daniel</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="6iEHot_,AGbX)hTpgrzv"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement></block></xml> !
                    • E
                      E
                      ErazorVIP
                      #190
                      ich habe folgendes Problem. Der Unifi Adapter schein zulaufen. (hat auch schon einmal alles funktiniert)
                      jedoch bekomme ich jetzt flogende Meldung im Log:
                      host.ioBroker-Tinker	2018-12-17 09:45:12.068	info	Restart adapter system.adapter.unifi.0 because enabled
                      host.ioBroker-Tinker	2018-12-17 09:45:12.068	error	instance system.adapter.unifi.0 terminated with code 0 (OK)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.068	error	Caught by controller[0]: at emitOne (events.js:96:13)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.068	error	Caught by controller[0]: at Request. <anonymous>(/opt/iobroker/node_modules/request/request.js:1163:10)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.067	error	Caught by controller[0]: at Request.emit (events.js:191:7)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.067	error	Caught by controller[0]: at emitTwo (events.js:106:13)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.067	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.067	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/node-unifi/unifi.js:1399:27)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.066	error	Caught by controller[0]: at next (/opt/iobroker/node_modules/async/dist/async.js:5211:18)
                      host.ioBroker-Tinker	2018-12-17 09:45:12.066	error	Caught by controller[0]: at /opt/iobroker/node_modules/async/dist/async.js:958:16
                      host.ioBroker-Tinker	2018-12-17 09:45:12.066	error	Caught by controller[0]: at /opt/iobroker/node_modules/node-unifi/unifi.js:1411:13
                      host.ioBroker-Tinker	2018-12-17 09:45:12.065	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:471:28
                      host.ioBroker-Tinker	2018-12-17 09:45:12.064	error	Caught by controller[0]: TypeError: Cannot read property 'map' of undefined
                      unifi.0	2018-12-17 09:45:11.542	info	controller = 127.0.0.1:8443
                      unifi.0	2018-12-17 09:45:11.541	info	update_interval = 60
                      unifi.0	2018-12-17 09:45:11.539	info	Starting UniFi-Controller query</anonymous>
                      Kann das sein das der Port 8443 schon benutzt wird?
                      root@ioBroker-Tinker:~# netstat -tlpn
                      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      1013/redis-server 1
                      tcp        0      0 192.168.2.27:2001       0.0.0.0:*               LISTEN      2774/io.hm-rpc.2
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1011/sshd
                      tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      2682/ffserver
                      tcp        0      0 192.168.2.27:2010       0.0.0.0:*               LISTEN      1464/io.hm-rpc.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      2848/io.sonoff.0
                      tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      2685/io.hm-rpc.1
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1237/iobroker.js-co
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1237/iobroker.js-co
                      tcp6       0      0 :::8843                 :::*                    LISTEN      7593/java
                      tcp6       0      0 :::8880                 :::*                    LISTEN      7593/java
                      tcp6       0      0 :::8080                 :::*                    LISTEN      7593/java
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1322/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1622/io.web.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      1011/sshd
                      tcp6       0      0 :::8443                 :::*                    LISTEN      7593/java
                      tcp6       0      0 :::1884                 :::*                    LISTEN      2862/io.mqtt.0
                      Wenn ja was könnte ich tun?
                      • DutchmanD
                        DutchmanD
                        Dutchman
                        #191
                        8443 ist der port des unifi controllers, richtige IP usw eingegeben ?
                        Die fehlermeldung deutet darauf hin das informationen welche der adapter sucht nicht gefunen werden koennen.
                        • H
                          H
                          helftheo
                          #192
                          ich habe leider auch genau die gleiche Fehlermeldungen wie "Fuga" oben gepostet hat.
                          Bei mir lief alles problemlos, solange nur Switch und Accesspoint am Controller angemeldet waren.
                          Nach dem USG dazu gekommen ist, bekomme ich auch die Fehlermeldungen.
                          Weiß jemand wo der Fehler liegt?
                          Theo
                          • R
                            R
                            ReverZ
                            #193
                            Ist der 8443 nicht auch der Port, über den der iot-Adapter kommuniziert?
                            • S
                              S
                              simpixo
                              #194
                              Also ich habe ein
                              1x USG 4p
                              1x 24 port Switch
                              1x 16 Poe Switch
                              3 Accesspoints
                              alles von Ubiquiti, und alles läuft super mit dem Adapter!
                              Denn iot Adapter habe ich auch in Benutzung
                              Adrian
                              Aber ich hatte auch ein ähnliches Problem, das der Adapter keine Daten geholt hat, dies lag aber an einer Fehlkonfiguration des Unifi Controllers!!!
                              Hast du da irgendwelche Änderungen durchgeführt!?
                              • HiltexH
                                HiltexH
                                Hiltex
                                #195
                                gibt es eigentlich mit diesem Adapter die Möglichkeit, einzelne WLAN-Netzwerke zu aktivieren, bzw. zu deaktivieren?
                                Oder hat jemand einen anderen Weg gefunden, wie man das realisieren könnte?
                                Blog: indibit.de
                                • H
                                  H
                                  helftheo
                                  #196
                                  @simpixo
                                  Was heißt, Fehlkonfiguration? Ein Haken zu viel, oder zu wenig? Wo war genau der Fehler bei dir?
                                  Da Unifi für mich ganz neu ist, probiert man an verschiedensten Stellen was.
                                  Theo
                                  • N
                                    N
                                    nousefor82
                                    #197
                                    ich habe mein Gastnetzwerk mittels "Hotspot" abgesichert.
                                    Es wird also die Eingabe eines Voucher-Codes verlangt.
                                    Gibt es unter Objekten einen Datenpunkt, der diesen anzeigt?
                                    VG
                                    Jörg
                                    • HiltexH
                                      HiltexH
                                      Hiltex
                                      #198
                                      @nousefor82:
                                      VG
                                      Jörg `
                                      Konnte ich nicht finden. Aber über FHEM kommst du an die Voucher und kannst sogar welche erzeugen.
                                      Über den FHEM Adapter holst du dir die Infos dann nach ioBroker
                                      Blog: indibit.de
                                      • N
                                        N
                                        nousefor82
                                        #199
                                        Servus,
                                        das heißt ich muss FHEM aufsetzen, richtig?
                                        Danke und Gruß
                                        • HiltexH
                                          HiltexH
                                          Hiltex
                                          #200
                                          Möglicherweise gibt es noch andere Wege, aber der über FHEM funktioniert.
                                          Blog: indibit.de
                                          83.9k
                                          1.4m
