  4. Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK
    5.7k
1.0k Beiträge 16 Kommentatoren 304.6k Aufrufe 15 Beobachtet
    @goetschhofer in der ersten zeile steht aber nur 192.168.1.7 sollte doch .77 sein
    GOETSCHHOFER
    #381
    @crunchip
    Sorry, hier war ich schlampig.
    pi@raspberrypi:~ $ influxd backup -portable -database iobroker -host 192.168.1.77:8088 /tmp/mysnapshot
    2021/05/10 10:16:20 backing up metastore to /tmp/mysnapshot/meta.00
    2021/05/10 10:16:23 Download shard 0 failed dial tcp 192.168.1.77:8088: connect: no route to host.  Waiting 2s and retrying (0)...
    2021/05/10 10:16:26 Download shard 0 failed dial tcp 192.168.1.77:8088: connect: no route to host.  Waiting 2s and retrying (1)...
    2021/05/10 10:16:29 Download shard 0 failed dial tcp 192.168.1.77:8088: connect: no route to host.  Waiting 2s and retrying (2)...
    2021/05/10 10:16:32 Download shard 0 failed dial tcp 192.168.1.77:8088: connect: no route to host.  Waiting 2s and retrying (3)...
    2021/05/10 10:16:35 Download shard 0 failed dial tcp 192.168.1.77:8088: connect: no route to host.  Waiting 2s and retrying (4)...
    2021/05/10 10:16:38 Download shard 0 failed dial tcp 192.168.1.77:8088: connect: no route to host.  Waiting 2s and retrying (5)...
      GOETSCHHOFER
      #382
      @crunchip
      Hier habe ich noch einen Fehler gemacht. .177 anstatt .77
      pi@raspberrypi:~ $ influxd backup -portable -database iobroker -host 192.168.1.177:8088 /tmp/mysnapshot
      2021/05/10 10:18:41 backing up metastore to /tmp/mysnapshot/meta.00
      2021/05/10 10:18:41 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (0)...
      2021/05/10 10:18:43 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (1)...
      2021/05/10 10:18:45 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (2)...
      2021/05/10 10:18:47 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (3)...
      2021/05/10 10:18:49 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (4)...
      2021/05/10 10:18:51 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (5)...
      2021/05/10 10:18:53 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
      • G GOETSCHHOFER
        @crunchip
        crunchipC Offline
        crunchipC Offline
        #383
        @goetschhofer ah, ok
        ich blick ehrlich gesagt da im Moment auch nicht durch
        setz mal ein sudo vor den Befehl
        was steht eigentlich in deiner /etc/influxdb/influxdb.conf beim PI
        geht um diesen Eintrag
        bind-address = "127.0.0.1:8088
        G 2 Antworten Letzte Antwort
          GOETSCHHOFER
          schrieb am zuletzt editiert von GOETSCHHOFER
          #384
          @crunchip
          backup portable influxdb mit sudo vom RSP aus.
          login as: pi
          pi@192.168.1.160's password:
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Mon May 10 10:08:05 2021 from pc-home-desktop-q6er4kb.fritz.box
          pi@raspberrypi:~ $ sudo influxd backup -portable -database iobroker -host 192.168.1.177:8088 /tmp/mysnapshot
          2021/05/10 10:35:40 backing up metastore to /tmp/mysnapshot/meta.00
          2021/05/10 10:35:40 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (0)...
          2021/05/10 10:35:42 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (1)...
          2021/05/10 10:35:44 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (2)...
          2021/05/10 10:35:46 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (3)...
          2021/05/10 10:35:48 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (4)...
          2021/05/10 10:35:50 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2s and retrying (5)...
          2021/05/10 10:35:52 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
          2021/05/10 10:35:55 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
          2021/05/10 10:36:06 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
          2021/05/10 10:36:50 Download shard 0 failed dial tcp 192.168.1.177:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
          ^Cpi@raspberrypi:~ $ ^C
          • G GOETSCHHOFER
            @crunchip
            login as: pi
            crunchipC Offline
            crunchipC Offline
            #385
            @goetschhofer
            mach mal so
            sudo influxd backup -portable -database iobroker -host 127.0.0.1:8088 /tmp/influx_backup
            G 1 Antwort Letzte Antwort
              @goetschhofer
              mach mal so
              GOETSCHHOFER
              #386
              @crunchip said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
              Ehrlich, wenn ich dich hier nicht hätte, hätte ich schon längst das Handtuch geworfen. Danke 👍
              pi@raspberrypi:~ $ sudo influxd backup -portable -database iobroker -host 127.0.0.1:8088 /tmp/influx_backup
              2021/05/10 10:42:39 backing up metastore to /tmp/influx_backup/meta.00
              2021/05/10 10:42:39 backing up db=iobroker
              2021/05/10 10:42:39 backing up db=iobroker rp=autogen shard=2 to /tmp/influx_backup/iobroker.autogen.00002.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:42:45 backing up db=iobroker rp=autogen shard=9 to /tmp/influx_backup/iobroker.autogen.00009.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:42:54 backing up db=iobroker rp=autogen shard=17 to /tmp/influx_backup/iobroker.autogen.00017.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:02 backing up db=iobroker rp=autogen shard=22 to /tmp/influx_backup/iobroker.autogen.00022.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:07 backing up db=iobroker rp=autogen shard=26 to /tmp/influx_backup/iobroker.autogen.00026.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:16 backing up db=iobroker rp=autogen shard=34 to /tmp/influx_backup/iobroker.autogen.00034.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:23 backing up db=iobroker rp=autogen shard=42 to /tmp/influx_backup/iobroker.autogen.00042.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:30 backing up db=iobroker rp=autogen shard=50 to /tmp/influx_backup/iobroker.autogen.00050.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:44 backing up db=iobroker rp=autogen shard=58 to /tmp/influx_backup/iobroker.autogen.00058.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:43:54 backing up db=iobroker rp=autogen shard=66 to /tmp/influx_backup/iobroker.autogen.00066.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:04 backing up db=iobroker rp=autogen shard=74 to /tmp/influx_backup/iobroker.autogen.00074.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:09 backing up db=iobroker rp=autogen shard=82 to /tmp/influx_backup/iobroker.autogen.00082.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:19 backing up db=iobroker rp=autogen shard=90 to /tmp/influx_backup/iobroker.autogen.00090.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:28 backing up db=iobroker rp=autogen shard=98 to /tmp/influx_backup/iobroker.autogen.00098.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:36 backing up db=iobroker rp=autogen shard=106 to /tmp/influx_backup/iobroker.autogen.00106.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:43 backing up db=iobroker rp=autogen shard=114 to /tmp/influx_backup/iobroker.autogen.00114.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:48 backing up db=iobroker rp=autogen shard=122 to /tmp/influx_backup/iobroker.autogen.00122.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:48 backing up db=iobroker rp=autogen shard=130 to /tmp/influx_backup/iobroker.autogen.00130.00 since 0001-01-01T00:00:00Z
              2021/05/10 10:44:48 backup complete:
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.meta
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s2.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s9.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s17.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s22.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s26.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s34.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s42.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s50.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s58.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s66.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s74.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s82.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s90.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s98.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s106.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s114.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s122.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s130.tar.gz
              2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.manifest
              crunchipC 2 Antworten Letzte Antwort
              • G GOETSCHHOFER
                crunchipC Offline
                crunchipC Offline
                #387
                @goetschhofer ok, backup hast du nun auf dem PI
                dann musst du nun auf deinem LCX ein Verzeichnis anlegen
                mkdir /tmp/influx_backup
                die Daten die jetzt auf deinem Pi erstellt wurden, musst du auf deinem LXC in das Verzeichnis kopieren
                soweit ich gelesen habe, darf die selbe Datenbank nicht vorhanden sein, da du die Influx Insatnz aber schon gestartet hast wurde ja eine Datenbank iobroker schon angelegt.
                Ich würde die Influx Instanz auf deinem neuen Iobroker stoppen
                dann auf deinem Influxdb LXC folgendes
                influx
                drop database iobroker
                exit
                anschliessend dieses ausführen (bin mir aber nicht sicher, ob der influx Dienst vorher gestoppt sein muss), daher vllt vorher noch stoppen
                sudo service influxdb stop
                influxd restore -metadir /var/lib/influxdb/meta /tmp/influx_backup
                influxd restore -database iobroker -datadir /var/lib/influxdb/data /tmp/influx_backup
                sudo chown -R influxdb:influxdb /var/lib/influxdb
                systemctl start influxdb
                  GOETSCHHOFER
                  #388
                  bind-address = "127.0.0.1:8088 kann ich nicht finden ?
                  • G GOETSCHHOFER
                    crunchipC Offline
                    crunchipC Offline
                    #389
                    @goetschhofer das steht ganz oben, das passt schon, sonst hätte das backup nicht funktioniert, bzw würde das backup via backitup gar nicht funktionieren
                      influx
                      exit
                      GOETSCHHOFER
                      #390
                      @crunchip
                      InfluxDB war seit gestern gestoppt.
                      Unten habe ich noch eine Fehlermeldung.
                      LXC-INFLUXDB-192 login: karl
                      Password:
                      Last login: Mon May 10 10:07:07 CEST 2021 on tty1
                      Linux LXC-INFLUXDB-192 5.4.106-1-pve #1 SMP PVE 5.4.106-1 (Fri, 19 Mar 2021 11:08:47 +0100) x86_64
                      karl@LXC-INFLUXDB-192:~$ mkdir /tmp/influx_backup
                      karl@LXC-INFLUXDB-192:~$ influx
                      Connected to http://localhost:8086 version 1.8.5
                      InfluxDB shell version: 1.8.5
                      > exit
                      karl@LXC-INFLUXDB-192:~$ influxd restore -metadir /var/lib/influxdb/meta influx_backup
                      restore: backup path should be a valid directory: influx_backup
                      karl@LXC-INFLUXDB-192:~$ influxd restore -database iobroker -datadir /var/lib/influxdb/data influx_backup
                      karl@LXC-INFLUXDB-192:~$ sudo chown -R influxdb:influxdb /var/lib/influxdb
                      [sudo] password for karl:
                      karl@LXC-INFLUXDB-192:~$ systemctl start influxdb
                      Failed to start influxdb.service: Access denied
                      See system logs and 'systemctl status influxdb.service' for details.
                      • G GOETSCHHOFER
                        @crunchip
                        Password:
                        > exit
                        crunchipC Offline
                        crunchipC Offline
                        #391
                        @goetschhofer sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                        sorry war mein Fehler, Verzeichnis nicht richtig angegeben, hab es oben korrigiert
                        also dieses nochmal
                        sudo influxd restore -metadir /var/lib/influxdb/meta /tmp/influx_backup
                        sudo influxd restore -database iobroker -datadir /var/lib/influxdb/data /tmp/influx_backup
                        sudo systemctl start influxdb
                          also dieses nochmal
                          GOETSCHHOFER
                          #392
                          @crunchip
                          Warum hat er in /tmp/influx_backup keinen Inhalt ?
                          karl@LXC-INFLUXDB-192:~$ sudo service influxdb stop
                          karl@LXC-INFLUXDB-192:~$ influxd restore -metadir /var/lib/influxdb/meta /tmp/influx_backup
                          restore: no metastore backups in /tmp/influx_backup
                          karl@LXC-INFLUXDB-192:~$ cd /tmp/influx_backup
                          karl@LXC-INFLUXDB-192:/tmp/influx_backup$ ls -l
                          total 0
                          • G GOETSCHHOFER
                            @crunchip
                            total 0
                            crunchipC Offline
                            crunchipC Offline
                            #393
                            @goetschhofer hast du die Dateien vom Pi auf den LXC kopiert?
                              GOETSCHHOFER
                              #394
                              @crunchip
                              Ich war eben bis dahin der Meinung, dass durch die Angabe der IP-192.168.1.177-LXC-Influxdb in ein Verzeichnis beim LXC geschrieben werden ? Wie haben dies ja dann auf 127.0.0. geändert.
                              D.h. die Daten liegen noch immer am RSP ?
                              Nur wie kopiere ich diese vom Pi in das LXC Verzeichnis, von einer IP in die andere IP ?
                              • G GOETSCHHOFER
                                @crunchip
                                crunchipC Offline
                                crunchipC Offline
                                #395
                                @goetschhofer weiss nicht was du nutzt, kannst du z.b. mit winscp, filezilla...
                                  GOETSCHHOFER
                                  #396
                                  @crunchip
                                  ja, winscp habe ich.
                                  In putty öffnen ....... ?
                                  • G GOETSCHHOFER
                                    @crunchip
                                    crunchipC Offline
                                    crunchipC Offline
                                    #397
                                    @goetschhofer dann logge dich auf deinem Pi ein, lade die Daten runter, logg die auf deinen LXC ein und füge sie dort wieder ein.
                                    Ich muss dann leider los, die Arbeit ruft
                                      GOETSCHHOFER
                                      #398
                                      @crunchip
                                      Vielen Dank für heute.
                                        GOETSCHHOFER
                                        #399
                                        @crunchip
                                        Hätte jetzt mit Filezilla die backup Datei vom RSP auf meinen Windowsrechner geschoben, damit ich das backup-Influxdb anschließend in mein LXC-Influxdb hochladen kann, er lässt aber nur den Ordner tmp ohne den Ordner Influx_backup zu.
                                        Den einzelnen Ordner kann ich auch nicht nach links kopieren.
                                        Müsste hier vielleicht in den Einstellungen vom RSP noch etwas freigeschaltet werden ?
                                        Meister MopperM crunchipC 2 Antworten Letzte Antwort
                                        • G GOETSCHHOFER
                                          @crunchip
                                          Meister MopperM Online
                                          Meister Mopper
                                          #400
                                          @goetschhofer
                                          Der Benutzer 'pi', mit dem Du Dich via filezilla auf dem Raspi einloggst, hat nicht die erforderlichen Rechte für diesen Ordner.
                                          Was kommt nach getfacl /tmp/influx_backup in der Konsole des Raspi?
                                          Proxmox und HA ...
