  4. Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK
    6.5k
1.0k Beiträge 16 Kommentatoren 321.6k Aufrufe 15 Beobachtet
    @goetschhofer
    mach mal so
    sudo influxd backup -portable -database iobroker -host 127.0.0.1:8088 /tmp/influx_backup
    GOETSCHHOFER
    schrieb am zuletzt editiert von GOETSCHHOFER
    #386
    @crunchip said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
    Ehrlich, wenn ich dich hier nicht hätte, hätte ich schon längst das Handtuch geworfen. Danke 👍
    pi@raspberrypi:~ $ sudo influxd backup -portable -database iobroker -host 127.0.0.1:8088 /tmp/influx_backup
    2021/05/10 10:42:39 backing up metastore to /tmp/influx_backup/meta.00
    2021/05/10 10:42:39 backing up db=iobroker
    2021/05/10 10:42:39 backing up db=iobroker rp=autogen shard=2 to /tmp/influx_backup/iobroker.autogen.00002.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:42:45 backing up db=iobroker rp=autogen shard=9 to /tmp/influx_backup/iobroker.autogen.00009.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:42:54 backing up db=iobroker rp=autogen shard=17 to /tmp/influx_backup/iobroker.autogen.00017.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:02 backing up db=iobroker rp=autogen shard=22 to /tmp/influx_backup/iobroker.autogen.00022.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:07 backing up db=iobroker rp=autogen shard=26 to /tmp/influx_backup/iobroker.autogen.00026.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:16 backing up db=iobroker rp=autogen shard=34 to /tmp/influx_backup/iobroker.autogen.00034.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:23 backing up db=iobroker rp=autogen shard=42 to /tmp/influx_backup/iobroker.autogen.00042.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:30 backing up db=iobroker rp=autogen shard=50 to /tmp/influx_backup/iobroker.autogen.00050.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:44 backing up db=iobroker rp=autogen shard=58 to /tmp/influx_backup/iobroker.autogen.00058.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:43:54 backing up db=iobroker rp=autogen shard=66 to /tmp/influx_backup/iobroker.autogen.00066.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:04 backing up db=iobroker rp=autogen shard=74 to /tmp/influx_backup/iobroker.autogen.00074.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:09 backing up db=iobroker rp=autogen shard=82 to /tmp/influx_backup/iobroker.autogen.00082.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:19 backing up db=iobroker rp=autogen shard=90 to /tmp/influx_backup/iobroker.autogen.00090.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:28 backing up db=iobroker rp=autogen shard=98 to /tmp/influx_backup/iobroker.autogen.00098.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:36 backing up db=iobroker rp=autogen shard=106 to /tmp/influx_backup/iobroker.autogen.00106.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:43 backing up db=iobroker rp=autogen shard=114 to /tmp/influx_backup/iobroker.autogen.00114.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:48 backing up db=iobroker rp=autogen shard=122 to /tmp/influx_backup/iobroker.autogen.00122.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:48 backing up db=iobroker rp=autogen shard=130 to /tmp/influx_backup/iobroker.autogen.00130.00 since 0001-01-01T00:00:00Z
    2021/05/10 10:44:48 backup complete:
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.meta
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s2.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s9.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s17.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s22.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s26.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s34.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s42.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s50.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s58.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s66.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s74.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s82.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s90.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s98.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s106.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s114.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s122.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.s130.tar.gz
    2021/05/10 10:44:48     /tmp/influx_backup/20210510T084239Z.manifest
    pi@raspberrypi:~ $ ^C
    • G GOETSCHHOFER
      crunchipC Offline
      crunchipC Offline
      #387
      @goetschhofer ok, backup hast du nun auf dem PI
      dann musst du nun auf deinem LCX ein Verzeichnis anlegen
      mkdir /tmp/influx_backup
      die Daten die jetzt auf deinem Pi erstellt wurden, musst du auf deinem LXC in das Verzeichnis kopieren
      soweit ich gelesen habe, darf die selbe Datenbank nicht vorhanden sein, da du die Influx Insatnz aber schon gestartet hast wurde ja eine Datenbank iobroker schon angelegt.
      Ich würde die Influx Instanz auf deinem neuen Iobroker stoppen
      dann auf deinem Influxdb LXC folgendes
      influx
      drop database iobroker
      exit
      anschliessend dieses ausführen (bin mir aber nicht sicher, ob der influx Dienst vorher gestoppt sein muss), daher vllt vorher noch stoppen
      sudo service influxdb stop
      influxd restore -metadir /var/lib/influxdb/meta /tmp/influx_backup
      influxd restore -database iobroker -datadir /var/lib/influxdb/data /tmp/influx_backup
      sudo chown -R influxdb:influxdb /var/lib/influxdb
      systemctl start influxdb
      G 1 Antwort Letzte Antwort
        @goetschhofer ah, ok
        ich blick ehrlich gesagt da im Moment auch nicht durch
        setz mal ein sudo vor den Befehl
        was steht eigentlich in deiner /etc/influxdb/influxdb.conf beim PI
        geht um diesen Eintrag
        bind-address = "127.0.0.1:8088
        GOETSCHHOFER
        #388
        bind-address = "127.0.0.1:8088 kann ich nicht finden ?
        • G GOETSCHHOFER
          crunchipC Offline
          crunchipC Offline
          #389
          @goetschhofer das steht ganz oben, das passt schon, sonst hätte das backup nicht funktioniert, bzw würde das backup via backitup gar nicht funktionieren
            influx
            exit
            GOETSCHHOFER
            #390
            @crunchip
            InfluxDB war seit gestern gestoppt.
            Unten habe ich noch eine Fehlermeldung.
            LXC-INFLUXDB-192 login: karl
            Password:
            Last login: Mon May 10 10:07:07 CEST 2021 on tty1
            Linux LXC-INFLUXDB-192 5.4.106-1-pve #1 SMP PVE 5.4.106-1 (Fri, 19 Mar 2021 11:08:47 +0100) x86_64
            permitted by applicable law.
            karl@LXC-INFLUXDB-192:~$ mkdir /tmp/influx_backup
            karl@LXC-INFLUXDB-192:~$ influx
            Connected to http://localhost:8086 version 1.8.5
            InfluxDB shell version: 1.8.5
            > exit
            karl@LXC-INFLUXDB-192:~$ influxd restore -metadir /var/lib/influxdb/meta influx_backup
            restore: backup path should be a valid directory: influx_backup
            karl@LXC-INFLUXDB-192:~$ influxd restore -database iobroker -datadir /var/lib/influxdb/data influx_backup
            karl@LXC-INFLUXDB-192:~$ sudo chown -R influxdb:influxdb /var/lib/influxdb
            [sudo] password for karl:
            karl@LXC-INFLUXDB-192:~$ systemctl start influxdb
            Failed to start influxdb.service: Access denied
            See system logs and 'systemctl status influxdb.service' for details.
            • G GOETSCHHOFER
              @crunchip
              Password:
              > exit
              crunchipC Offline
              crunchipC Offline
              #391
              @goetschhofer sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
              sorry war mein Fehler, Verzeichnis nicht richtig angegeben, hab es oben korrigiert
              also dieses nochmal
              sudo influxd restore -metadir /var/lib/influxdb/meta /tmp/influx_backup
              sudo influxd restore -database iobroker -datadir /var/lib/influxdb/data /tmp/influx_backup
              sudo systemctl start influxdb
                also dieses nochmal
                GOETSCHHOFER
                #392
                @crunchip
                Warum hat er in /tmp/influx_backup keinen Inhalt ?
                karl@LXC-INFLUXDB-192:~$ sudo service influxdb stop
                karl@LXC-INFLUXDB-192:~$ influxd restore -metadir /var/lib/influxdb/meta /tmp/influx_backup
                restore: no metastore backups in /tmp/influx_backup
                karl@LXC-INFLUXDB-192:~$ cd /tmp/influx_backup
                karl@LXC-INFLUXDB-192:/tmp/influx_backup$ ls -l
                total 0
                • G GOETSCHHOFER
                  @crunchip
                  total 0
                  crunchipC Offline
                  crunchipC Offline
                  #393
                  @goetschhofer hast du die Dateien vom Pi auf den LXC kopiert?
                    GOETSCHHOFER
                    #394
                    @crunchip
                    Ich war eben bis dahin der Meinung, dass durch die Angabe der IP-192.168.1.177-LXC-Influxdb in ein Verzeichnis beim LXC geschrieben werden ? Wie haben dies ja dann auf 127.0.0. geändert.
                    D.h. die Daten liegen noch immer am RSP ?
                    Nur wie kopiere ich diese vom Pi in das LXC Verzeichnis, von einer IP in die andere IP ?
                    • G GOETSCHHOFER
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      #395
                      @goetschhofer weiss nicht was du nutzt, kannst du z.b. mit winscp, filezilla...
                        GOETSCHHOFER
                        #396
                        @crunchip
                        ja, winscp habe ich.
                        In putty öffnen ....... ?
                        • G GOETSCHHOFER
                          @crunchip
                          crunchipC Offline
                          crunchipC Offline
                          #397
                          @goetschhofer dann logge dich auf deinem Pi ein, lade die Daten runter, logg die auf deinen LXC ein und füge sie dort wieder ein.
                          Ich muss dann leider los, die Arbeit ruft
                          G 2 Antworten Letzte Antwort
                            GOETSCHHOFER
                            #398
                            @crunchip
                            Vielen Dank für heute.
                              GOETSCHHOFER
                              #399
                              @crunchip
                              Hätte jetzt mit Filezilla die backup Datei vom RSP auf meinen Windowsrechner geschoben, damit ich das backup-Influxdb anschließend in mein LXC-Influxdb hochladen kann, er lässt aber nur den Ordner tmp ohne den Ordner Influx_backup zu.
                              Den einzelnen Ordner kann ich auch nicht nach links kopieren.
                              Müsste hier vielleicht in den Einstellungen vom RSP noch etwas freigeschaltet werden ?
                              Meister MopperM crunchipC 2 Antworten Letzte Antwort
                              • G GOETSCHHOFER
                                @crunchip
                                Meister MopperM Online
                                Meister Mopper
                                #400
                                @goetschhofer
                                Der Benutzer 'pi', mit dem Du Dich via filezilla auf dem Raspi einloggst, hat nicht die erforderlichen Rechte für diesen Ordner.
                                Was kommt nach getfacl /tmp/influx_backup in der Konsole des Raspi?
                                Proxmox und HA ...
                                • G GOETSCHHOFER
                                  @crunchip
                                  crunchipC Offline
                                  crunchipC Offline
                                  #401
                                  @goetschhofer wenn ich richtig gelesen habe, erfordert der Ordner influx_backup root Rechte, mit dem normalen User kann mal also nicht darauf zugreifen.
                                  Ich bin unterwegs, vllt kann dir @Thomas-Braun kurz unter die Arme greifen.
                                    #402
                                    @crunchip @GOETSCHHOFER
                                    Ich bin auch nur via Mobiltelefon aktiv. Und habe auch influx nicht im Einsatz.
                                    Gemeinhin wird sowas aber über Gruppen geregelt, die User müssen wohl noch in eine Gruppe 'influx' oder so ähnlich rein, vermute ich zumindest. Vielleicht weiß @simatec das aber genauer wie das ganze gemountet wird bzw. werden sollte.
                                      @goetschhofer
                                      GOETSCHHOFER
                                      #403
                                      @meister-mopper said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                                      pi@raspberrypi:~ $ getfacl /tmp/influx_backup
                                      getfacl: Entferne führende '/' von absoluten Pfadnamen
                                      # file: tmp/influx_backup
                                      # owner: root
                                      # group: root
                                      user::rwx
                                      group::---
                                      other::---
                                      pi@raspberrypi:~ $
                                        GOETSCHHOFER
                                        #404
                                        @thomas-braun said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                                        @simatec
                                        Hallo simatec,
                                        könntest du mir bitte bei folgendem Problem weiterhelfen.
                                        • G GOETSCHHOFER
                                          @simatec
                                          Hallo simatec,
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #405
                                          @goetschhofer
                                          Warum machst du es dir so kompliziert?
                                          Gehe nach der Anleitung von backitup vor. Hier steht beschrieben, wie du dein Influx einrichten musst, damit Backitup die db sichern kann.
                                          https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#InfluxDB-Backup
                                          Wichtig ist bei dir, dass du bind-address = "0.0.0.0:8088" in deiner influxdb.conf einträgst.
                                          Nach jeder änderung der influxdb.conf ist ein restart von influx von nöten.
                                          Wenn du das ganze manuell machen willst, kopiere dir den Ordner "backup-Influxdb" direkt in dein Home-Verzeichnis und führe den Restore von dort aus.
                                          Wichtig beim Restore darf die db, welche du herstellen willst, nicht existieren.
                                          • Besuche meine Github Seite
                                          • HowTo Restore ioBroker
