  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.3k
812 Beiträge 97 Kommentatoren 452.2k Aufrufe 83 Beobachtet
  • GlasfaserG Glasfaser
    @chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
    sehe jetzt unter Instanzen den Adapter nicht mehr!!
    iobroker add klf200
    Chrisdor
    #721
    @glasfaser hat leider auch nicht geklappt
    2022-08-20 21:53:06.714 - info: host.e-server instance system.adapter.klf200.0 started with pid 2473
    2022-08-20 21:53:08.269 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
    2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: throw err;
    2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: ^
    2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
    2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: Require stack:
    2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
    2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
    2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
    2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
    2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
    2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
    2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
    2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: }
    2022-08-20 21:53:08.275 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-08-20 21:53:08.276 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
    2022-08-20 21:53:08.276 - info: host.e-server system.adapter.klf200.0 will be rebuilt
    2022-08-20 21:53:08.278 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2022-08-20 21:53:08.278 - info: host.e-server iobroker rebuild
    2022-08-20 21:53:09.677 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
    • GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #722
      @chrisdor
      Sorry keine Idee mehr .. warum dieser Adapter zickt .
      C 1 Antwort Letzte Antwort
        @chrisdor
        Chrisdor
        #723
        @glasfaser ok, aber danke für deine Bemühungen!
        • C Chrisdor
          SBorgS Offline
          SBorgS Offline
          SBorg
          #724
          Was liefert denn ein npm list|grep node ?
          Taucht da node-schedule auf? Sonst versuche mal ein npm install node-schedule
          LG SBorg ( SBorg auf GitHub)
          • SBorgS SBorg
            Chrisdor
            #725
            @sborg das wars jetzt funktioniert es! Danke, Danke!!!
            e-server@e-server:/opt/iobroker$ npm list|grep node
            [sudo] password for e-server:
            ├── node-inspect@2.0.0 extraneous
            e-server@e-server:/opt/iobroker$ npm install node-schedule
            added 1 package, removed 645 packages, and changed 1 package in 17s
            90 packages are looking for funding
              run `npm fund` for details
            └── node-schedule@2.1.0
            Hab jetzt noch einen Master und einen zweiten Slave, da kommt node-schedule auch nicht vor. Aber alle installierten Adapter laufen problemlos bzw. Iobroker selbst auch! Sollt ich das auch nach installieren?
            Last login: Sat Aug 20 18:48:31 2022 from 192.168.178.57
            c-server@c-server:~$ cd /opt/iobroker
            c-server@c-server:/opt/iobroker$ npm list|grep node
            [sudo] password for c-server:
            Last login: Sun Aug 21 13:44:13 2022 from 192.168.178.57
            d-server@d-server:~$ cd /opt/iobroker
            d-server@d-server:/opt/iobroker$ npm list|grep node
            [sudo] password for d-server:
            • C Chrisdor
              SBorgS Offline
              SBorgS Offline
              SBorg
              #726
              Nein, das wäre nur Ressourcenverschwendung. Falls mal ein Adapter auf einem System den braucht, meldet er sich schon (siehe "error" in deinen Logs von oben). Normalerweise werden die Dependencies aber auch vom Adapter aufgelöst und nachinstalliert.
              Fährst ja auch nicht das ganze Jahr mit angehängtem Wohnwagen rum, nur weil du ihn vielleicht mal 2 Wochen im Jahr brauchst ;)
              • SBorgS SBorg
                Chrisdor
                #727
                @sborg sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                Ok, verstehe!! Danke nochmal.
                Da hast du natürlich recht!! :😁
                • F Offline
                  Frank06347
                  #728
                  ich habe auf die empfohlene Version Node.js 16.x ein Update gemacht.
                  Jetzt wird folgendes in der Übersicht angezeigt:
                  Ist das so richtig?
                  Welche NPM Version wird empfohlen?
                  Muss ich mich um die NPM-Version kümmern? ... oder kommt die automatisch durch Node.js?
                  Wo finde ich die verfügbaren Updates (siehe Screeshot)?
                  Viele Grüße
                  Frank
                  DiginixD HomoranH 2 Antworten Letzte Antwort
                  • F Frank06347
                    Ist das so richtig?
                    Viele Grüße
                    Frank
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #729
                    @frank06347 Das passt so. NPM nicht manuell updaten, kommt passend mit und zur nodejs Ver.
                    ..:: So long! Tom ::..
                    • F Frank06347
                      Ist das so richtig?
                      Viele Grüße
                      Frank
                      #730
                      @frank06347 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                      Ist das so richtig?
                      ja!
                      https://forum.iobroker.net/post/848055
                      F 1 Antwort Letzte Antwort
                        Ist das so richtig?
                        ja!
                        Frank06347
                        #731
                        @homoran sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                        Ist das so richtig?
                        ja!
                        Alles klar ... Fehler im Admin .... vielen Dank für schnelle Antwort!
                        Viele Grüße
                        Frank
                        • F Frank06347
                          Ist das so richtig?
                          ja!
                          Viele Grüße
                          Frank
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #732
                          Nur zur Klärung , das ist kein Fehler vom ADMIN !
                          Deshalb habe ich hier :
                          ... es soll nur verhindert werden : "verleitet nur zu unnötigen Installations/Upgrade-Versuchen."
                          https://github.com/ioBroker/ioBroker.admin/issues/1663
                            torstenhe
                            schrieb am zuletzt editiert von torstenhe
                            #733
                            Schönen guten Morgen,
                            wollte euch mein Erfolgserlebnis in Bezug auf Node.js mitteilen.
                            kurz zur Vorgeschichte. Mein iobroker lief jetzt mehr als ein Jahr unter Windows auf einem Surface 1. Bisher habe ich immer alles hinbekommen und er lief 24 / 7 ohne Probleme, egal welches Update, es lief einfach super.
                            Jetzt bin ich auf proxmox gewechselt und einem Surface Pro 7 mit mit Displayschaden umgezogen. Als OS habe ich ubuntu server gewählt, 4 Cores und 4 GB RAM.
                            Im ioBroker unter Windows Backup gezogen und im Ubuntu Server eingespielt. Hat erst mal länger gedauert, hatte da am Anfang etwas Probleme mit, läuft aber jetzt und das sehr performant.
                            Dann Conbee ii usb durchgereicht, alles installiert und Backup eingespielt. Lief auf anhieb.
                            Bis hierher alles gut gelaufen und es läuft auch alles.
                            Dann habe ich gesehen das meine Node.js Version noch auf v12.22.9 ist.
                            Ich hab glaub ich alles durch was man so machen kann. Snapshots sei dank, so kam ich immer wieder zurück. :-) Aber nichts hatte geholfen. Stichwort "Broken-Pipe".
                            Nur das folgende konnte mir helfen:
                            iobroker stop
                            cd /opt/iobroker
                            sudo npm cache verify
                            sudo chown -R iobroker /opt/iobroker
                            sudo apt update -y && sudo apt upgrade -y
                            sudo apt-get purge nodejs -y && sudo apt-get autoremove -y && sudo apt-get autoclean -y
                            sudo curl -sL https://deb.nodesource.com/setup_16.x | sudo bash -
                            sudo apt-get install -y nodejs
                            iobroker stop
                            npm install -y iobroker.js-controller --unsafe-perm --production --save --prefix
                            npm rebuild
                            iobroker update
                            iobroker upgrade self
                            iobroker upgrade -y
                            iobroker start
                            Vielleicht hilft das dem ein oder anderen noch. :)
                            LG
                            Torsten
                            • T torstenhe
                              iobroker stop
                              cd /opt/iobroker
                              iobroker stop
                              npm rebuild
                              iobroker update
                              iobroker upgrade -y
                              iobroker start
                              LG
                              Torsten
                              #734
                              @torstenhe
                              Ehrlich gesagt: Recht wirr.
                                @torstenhe
                                torstenhe
                                #735
                                Mag sein, läuft aber jetzt. 🙄
                                  Andre105
                                  schrieb am zuletzt editiert von Andre105
                                  #736
                                  Moin,
                                  Ist es jetzt ratsam auf Node.js 16 zu wechseln?
                                  Wenn ja, wie war das noch mit den Befehlen?
                                  • A Andre105
                                    Moin,
                                    #737
                                    @andre105
                                    Ja.
                                    HowTo in meiner Signatur.
                                    A 1 Antwort Letzte Antwort
                                      @andre105
                                      Ja.
                                      Andre105
                                      #738
                                      Muss ich das auch beachten?
                                      HINWEIS: ACHTUNG BEIM UPGRADE AUF NODE.js 16!!!
                                      Ein Upgrade auf die Version 16 / npm 8 erfordert im Vorfeld einen sauberen 'npm tree'!!!.
                                      Bei mir steht das:
                                      andre105@iobroker:~$ cd /opt/iobroker
                                      npm ls | grep -E 'github|ERR'
                                      [sudo] Passwort für andre105:
                                      │ │ │ ├── github-from-package@0.0.0
                                      npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                                      npm ERR! extraneous: libmime@5.0.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/libmime
                                        │ │ │   ├── github-from-package@0.0.0 deduped
                                      andre105@iobroker:/opt/iobroker$
                                      • A Andre105
                                        Bei mir steht das:
                                        #739
                                        @andre105
                                        Nein, sollte kein Problem sein.
                                          @andre105
                                          Andre105
                                          #740
                                          Hat geklappt 👍
