  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.3k
812 Beiträge 97 Kommentatoren 452.2k Aufrufe 83 Beobachtet
  • A Andre105
    Hat geklappt 👍
    #741
    @andre105
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    sagt?
    A 1 Antwort Letzte Antwort
      @andre105
      sagt?
      Andre105
      #742
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sat Sep 17 19:12:00 2022 from 192.168.178.28
      andre105@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
      [sudo] Passwort für andre105:
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden:                                                      Die Datei existiert bereits
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      andre105
      andre105 dialout cdrom floppy sudo audio dip video plugdev netdev iobroker
      /home/andre105
      OK:1 http://phoscon.de/apt/deconz bullseye InRelease
      OK:2 http://security.debian.org/debian-security bullseye-security InRelease
      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      OK:4 http://ftp.de.debian.org/debian bullseye InRelease
      OK:5 http://ftp.de.debian.org/debian bullseye-updates InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           16.17.0-deb-1nodesource1
        Installationskandidat: 16.17.0-deb-1nodesource1
        Versionstabelle:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main am                                                     d64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
      • A Andre105
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        4.0.23
        andre105
        /home/andre105
        nodejs:
          Versionstabelle:
        #743
        @andre105
        Passt. Der npm tree ist auch sauber?
          @andre105
          Andre105
          #744
          andre105@iobroker:~$ cd /opt/iobroker
          npm ls | grep -E 'github|ERR'
          andre105@iobroker:/opt/iobroker$
          • A Andre105
            #745
            @andre105
            Prima.Viel Spaß mit nodejs 16.
              @andre105
              Andre105
              #746
              Super, wie immer Danke für die Hilfe.
              Ich muss auch immer am Ball bleiben.
              Jetzt kommt die dunkle Jahreszeit,da kann man sie wieder mehr mit beschäftigen.
              • Claus1985 0C Offline
                Claus1985 0
                #747
                Hi Zusammen,
                bekomme das Update auf 16 nicht hin:
                 curl -sL https://deb.nodesource.com/setup_16.x | sudo -E        bash -
                ## Installing the NodeSource Node.js 16.x repo...
                ## Populating apt-get cache...
                + apt-get update
                Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                Holen:2 http://www.deb-multimedia.org buster InRelease [17,8 kB]
                Holen:3 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                Holen:4 https://deb.nodesource.com/node_14.x buster InRelease [4.584 B]
                Ign:5 https://repos.influxdata.com/raspbian buster InRelease
                Fehl:6 https://repos.influxdata.com/raspbian buster Release
                  404  Not Found [IP: 2600:9000:223e:9000:11:fe8d:7d40:93a1 443]
                Holen:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,        0 MB]
                Holen:8 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB        ]
                Holen:9 https://deb.nodesource.com/node_14.x buster/main armhf Packages [782 B]
                E: Das Depot »https://repos.influxdata.com/raspbian buster Release« enthält kein        e Release-Datei.
                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur        chgeführt werden, daher ist es standardmäßig deaktiviert.
                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur        ation finden Sie in der Handbuchseite apt-secure(8).
                N: Für das Depot »http://www.deb-multimedia.org buster InRelease« wurde der »Ver        sion«-Wert von »10.12« in »10.13« geändert.
                Error executing command, exiting
                Wie kann ich das Update durchführen / den Fehler beheben?
                Danke und Gruß,
                Claus
                J 1 Antwort Letzte Antwort
                • Claus1985 0C Claus1985 0
                  Hi Zusammen,
                  + apt-get update
                  Danke und Gruß,
                  Claus
                  Jan1
                  #748
                  @claus1985-0 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                  Editiere die nodesource.list unter /etc/apt/ und schreib da 16 rein, dann macht er automatisch das Update auf 16 ;)
                  Claus1985 0C Thomas BraunT 2 Antworten Letzte Antwort
                  • J Jan1
                    Claus1985 0
                    #749
                    @jan1 Danke für die schnelle Antwort, allerdings habe ich im Verzeichnis keine nodesource.list:
                    /etc/apt $ dir
                    apt.conf.d   listchanges.conf  sources.list    trusted.gpg   trusted.gpg.d
                    auth.conf.d  preferences.d     sources.list.d  trusted.gpg~
                      /etc/apt $ dir
                      Jan1
                      #750
                      @claus1985-0
                      Jou, Fehler von mir. Liegt in sources.list.d
                      Claus1985 0C 1 Antwort Letzte Antwort
                      • J Jan1
                        @claus1985-0
                        Claus1985 0
                        #751
                        @jan1 wenn ich die Datei mit nano öffne ist kein Inhalt drin und nano sagt "„sources.list.d“ ist ein Verzeichnis "
                          Jan1
                          #752
                          @claus1985-0
                          Du musst die Datei ja auch angeben:
                          sudo nano /etc/apt/sources.list.d/nodesource.list
                          • J Jan1
                            #753
                            @jan1 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                            Aber nur wenn die anderen Kinken aus den Quellen repariert werden.
                            Influx-Repo ist offenbar falsch, und das Multimedia -Dingsie muss umgestellt werden. (Wozu braucht man das überhaupt?)
                            sudo apt update
                            sudo apt full-upgrade
                            muss final jedenfalls durchlaufen.
                            • J Jan1
                              @claus1985-0
                              Claus1985 0
                              #754
                              @jan1 ja sorry habs verpeilt...
                                Jan1
                                #755
                                @claus1985-0
                                und den Rest der falsch ist erst mal raus, da sonst eh nix läuft wie Thomas schon geschrieben hat
                                  sudo apt update
                                  Claus1985 0
                                  schrieb am zuletzt editiert von Claus1985 0
                                  #756
                                  @thomas-braun wie kann ich denn den Influxdb Eintrag aus der Quellen Liste für apt entfernen?
                                  Reicht das wenn ich die Datei influxdb.list aus dem Verzeichnis sources.list.d lösche?
                                    #757
                                    @claus1985-0
                                    Ich würde ja einen gültigen Eintrag reinsetzen.
                                    Oder die krumme Zeile erstmal nur mit
                                    # auskommentieren.
                                    Ein gültige Zeile sollte so aussehen:
                                    deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian buster stable
                                      @claus1985-0
                                      # auskommentieren.
                                      Claus1985 0
                                      #758
                                      @thomas-braun habs auskommentiert, lief einwandfrei durch.
                                      Update auf 16 hat geklappt. ioBroker läuft wieder wie gehabt.
                                      Einzig der Zigbee Adapter startet nicht mehr und das ohne jegliche Fehlermeldung.
                                        #759
                                        Der dürfte gerade neugebaut werden. Geduld.
                                          Claus1985 0
                                          #760
                                          @thomas-braun hast recht, läuft wieder einwandfrei 👍 Vielen Dank für Eure Hilfe!!
