  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • M Michaelnorge
    Hab ich gemacht, jetzt die Version 2.3.5.
    Das Problem besteht weiterhin. Bluelink versucht 3x zu starten und wird dann vom Host gestoppt.
    2023-07-20 13:37:37.076 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.total is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.080 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.092 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.093 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.097 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
    at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49)
    at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21)
    at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21)
    at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21)
    at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17)
    at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29)
    2023-07-20 13:37:37.098 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.106 - warn: bluelink.0 (12152) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-07-20 13:37:37.108 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.engine is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.109 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.118 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.119 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.120 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    2023-07-20 13:37:37.121 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.125 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.climate is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.126 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.141 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.141 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.142 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    2023-07-20 13:37:37.142 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.147 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.devices is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.149 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.162 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.162 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.163 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    2023-07-20 13:37:37.163 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.battery is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.185 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.186 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.187 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    2023-07-20 13:37:37.187 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.191 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.regen is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.192 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.215 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.216 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.217 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    2023-07-20 13:37:37.217 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.distance is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
    2023-07-20 13:37:37.238 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 13:37:37.239 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 13:37:37.239 - error: bluelink.0 (12152) Error: undefined is not a valid state value
    2023-07-20 13:37:37.240 - error: bluelink.0 (12152) undefined is not a valid state value
    2023-07-20 13:37:37.623 - error: bluelink.0 (12152) Error: Connection is closed.
    2023-07-20 13:37:37.625 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed.
    2023-07-20 13:37:37.627 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed.
    2023-07-20 13:37:37.629 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed.
    2023-07-20 13:37:37.632 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed.
    2023-07-20 13:37:37.634 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed.
    2023-07-20 13:37:37.636 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed.
    2023-07-20 13:37:37.638 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.period": Connection is closed.
    2023-07-20 13:37:37.759 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-07-20 13:37:37.759 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
    Mich stört das nicht wirklich, zur Not ziehe ich ein Backup von Gestern rein - wäre aber cool zu erfahren wieso das passiert ist 😁
    Ich meine ich hätte den JS-Controller upgedated (jetzt v18.17.0)
    arteckA Offline
    arteckA Offline
    arteck
    #1301
    @michaelnorge mach erstmal in den Einstellungen den EV teil aus( links unten) . da passt was nicht.. dann sollte zumindest der adapter wieder starten
    ansonten kannst nochmal von GIT isntallieren..
    • arteckA arteck
      Michaelnorge
      #1302
      @arteck Mir war das zu heikel und ich habe direkt nach meinem letzten Post ne 10 Tage alte Version drüber gezogen, noch bevor ich angefangen bin, mit den Betas rumzuspielen.
      Vielleicht habe ich einfach was falsch gemacht, vielleicht melden sich auch noch andere hier mit dem gleichen Problem. Sry das ich Dir nicht helfen kann ;-)
      • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
      • arteckA Offline
        arteckA Offline
        arteck
        #1303
        ich hab da mal was gebastelt damit die Datenpunkte stimmen, bei MHEV/PHEV oder Benziner/Diesel
        die können die Klima nicht einschalten
        die Motorvariante dementsprechend einstellen ..sonst startet der Adapter nicht.. meldung im LOG beachten
        ansonsten kann man jetzt auch fore_login durchführen.. ohne den adapter neu starten zu müssen
        ALLE Steuerrungsdatenpunkte sind umgezogen in Control.. bitte adapter Datenpunkte löschen .. damit diese an der richtigen stelle neu erstellt werden
        force_update wurde korrigiert.. war als button deklariert..
        nik82N 1 Antwort Letzte Antwort
        • arteckA arteck
          nik82N Offline
          nik82N Offline
          nik82
          #1304
          @arteck
          Vielen Dank für das Update, funktioniert alles perfekt 👍
          (EV: Kia EV6)
          • M Michael Loddoch
            @dalugi Hast du inzwischen einen Lösung gefunden?
            DaLugi
            #1305
            @michael-loddoch
            Mit Version 2.3.5 funktioniert es jetzt. Dankeschön!
              bigal
              #1306
              Seit heute morgen 0 Uhr, hat noch jemand die Probleme?
              Bluelink App geht aber ohne Probleme
              bluelink.0
              	2023-07-29 09:18:27.129	error	Server is not available or login credentials are wrong
              bluelink.0
              	2023-07-29 09:18:27.128	error	ManagedBluelinkyError: @EuropeController.getVehicles: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/vehicles - {"retCode":"F","resCode":"4017","resMsg":"Invalid request value - Invalid Application Id. - 32437.111000061035","msgId":"973b7063-9c26-433e-9532-f4c5316b5bdb"}
              bluelink.0
              	2023-07-29 09:18:21.185	info	Login to api
              bluelink.0
              	2023-07-29 09:18:21.140	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.15.0, js-controller: 4.0.24
              Meister MopperM M R 3 Antworten Letzte Antwort
              • B bigal
                bluelink.0
                bluelink.0
                bluelink.0
                bluelink.0
                Meister MopperM Offline
                Meister Mopper
                #1307
                @bigal sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                Jap, kommt immer mal wieder vor, die Server spacken mal wieder rum.
                Proxmox und HA ...
                • B bigal
                  bluelink.0
                  bluelink.0
                  bluelink.0
                  bluelink.0
                  Michaelnorge
                  schrieb am zuletzt editiert von Michaelnorge
                  #1308
                  @bigal Jepp, hier das Gleiche (Norwegen)
                  Edit: Ist aber gut das hier im Forum jemand bescheid sagt. Das schließt dann automatisch einen anderen Fehler aus :-)
                  • B bigal
                    bluelink.0
                    bluelink.0
                    bluelink.0
                    bluelink.0
                    Ron 1
                    #1309
                    @bigal @arteck
                    Ich glaube das liegt an einem Problem der hyundai_kia_Connect_api. Es waren wohl auch andere Programm betroffen.: =>
                    https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/releases/tag/v3.4.0
                    Habe leider zu wenig Ahnung um das Problem genau nachzuvollziehen. Bei mir besteht es auf alle Fälle weiterhin.
                    • R Ron 1
                      @bigal @arteck
                      Michaelnorge
                      #1310
                      @ron-1 Ja bei mir auch unverändert....
                      • Meister MopperM Offline
                        Meister Mopper
                        #1311
                        @michaelnorge
                        Bei mir funktioniert es seit 11:14 Uhr wieder. Mal sehen wie lang
                        Proxmox und HA ...
                        ? M R 3 Antworten Letzte Antwort
                          @michaelnorge
                          #1312
                          @meister-mopper
                          Hier läufts auch wieder…
                            @michaelnorge
                            Michaelnorge
                            #1313
                            @meister-mopper Ja hier auch :-)
                              @michaelnorge
                              Ron 1
                              #1314
                              @meister-mopper Hier geht es auch wieder .
                                sansibar
                                #1315
                                vielleicht kann mir ja jemand mal erklären, was ich falsch mache: Ich habe auch Version 2.3.5 über GIT installiert. Ich habe einen KIA EV6 und entsprechend Motor "EV" ausgewählt.
                                Die Verbindung funktioniert wunderbar und es werden regelmäßig Updates vom Auto geholt und in die Objekte geschrieben.
                                Wenn ich einen(!) Befehl ans Auto sende, dann funktioniert auch das wunderbar, also Klima an, aufschließen, whatever...
                                Sende ich einen weiteren Befehl, dann kommt dieser nicht am Auto an und im Protokoll erscheint folgende Fehlermeldung:
                                Hier habe ich bspw. zwei mal hintereinander die Klima gestoppt: Das erste Mal klappt, das zweite (und jedes weitere) Mal nicht mehr.
                                Starte ich die Instanz neu, dann kann ich wieder erfolgreich einen(!) Befehl abschicken, sende ich einen zweiten oder dritten Befehl, dann laufen die in diesen Fehler - bis ich die Instanz wieder neu starte.
                                Sieht das bei noch jemandem so aus? Jemand eine Idee?
                                Vielen Dank 😳
                                arteckA nik82N 2 Antworten Letzte Antwort
                                • S sansibar
                                  Vielen Dank 😳
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #1316
                                  @sansibar ja das ist noch ein Bug..Serverseitig..warum auch immer .. es scheint als ob jede 2-te Aufruf die App ID verliert
                                  deshalb hab ich ein force_login button eingebaut.. also befehl absetzen dann dirket hinterher force_login...dann klappt mit dem nächsten Befehl ohne Fehler
                                  • S sansibar
                                    Vielen Dank 😳
                                    nik82N Offline
                                    nik82N Offline
                                    nik82
                                    #1317
                                    @sansibar
                                    Hey da haben wir ja endlich noch einen Kia EV6 Fahrer :-)
                                    Arteck hat dafür extra den force_login Button rein.
                                    Einfach dieses Blockly machen, dann funktioniert alles perfekt:
                                    W S 2 Antworten Letzte Antwort
                                    • nik82N nik82
                                      @sansibar
                                      W Offline
                                      W Offline
                                      wm20320
                                      #1318
                                      hab seit einer Weile folgendes Problem: Adapter startet normal und liest die neuen Werte ein. Aber dann meldet er unhandled promis rejection und schließlich UNCOUGHT_EXCEPTION, der js-controller stoppt den Adapter wegen häufiger Abstürze.
                                      Ich kann leider nicht mehr genau nachvollziehen, ab wann der Fehler genau aufgetaucht ist. Entweder ist es seit dem Controller-Update auf Ver. 5 oder seit einem Node-Update auf 18.x
                                      Bereits versucht: Adapter gelöscht, 1) von npm neuinstalliert, 2) von Github neuinstalliert
                                      Screenshot vom Log:
                                      Vielleicht habt ihr einen Tipp/eine Lösung für mich. Danke!
                                      VG Marcus
                                      H nik82N arteckA 3 Antworten Letzte Antwort
                                      • W wm20320
                                        Screenshot vom Log:
                                        VG Marcus
                                        Heinz2100
                                        schrieb am zuletzt editiert von Heinz2100
                                        #1319
                                        @wm20320 Ich habe genau dieselbe Fehlermeldung beim Homekit Controller. Danach Bootloop und stop des Adapters durch das System.Fehler.jpg
                                        • Lukas MaiL Offline
                                          Lukas MaiL Offline
                                          Lukas Mai
                                          #1320
                                          Ist der Plugin auch mit einem Genesis (Tochterfirma von Hyundai) nutzbar?
