  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • M Michaelnorge
    Guten Morgen!
    Kann mir einer sagen was dies bedeutet?
    2023-07-20 11:45:05.839 - error: bluelink.0 (8379) undefined is not a valid state value
    2023-07-20 11:45:05.848 - error: bluelink.0 (8379) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-20 11:45:05.849 - error: bluelink.0 (8379) unhandled promise rejection: undefined is not a valid state value
    2023-07-20 11:45:05.850 - error: bluelink.0 (8379) Error: undefined is not a valid state value
    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
    at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49)
    at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21)
    at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34)
    at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21)
    at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:383:17)
    at async ae. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:222:25)
    2023-07-20 11:45:05.851 - error: bluelink.0 (8379) undefined is not a valid state value
    2023-07-20 11:45:06.306 - error: bluelink.0 (8379) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.devices": DB closed
    2023-07-20 11:45:06.307 - warn: bluelink.0 (8379) Could not perform strict object check of state bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.engine: DB closed
    2023-07-20 11:45:06.309 - warn: bluelink.0 (8379) get state error: Connection is closed.
    2023-07-20 11:45:06.310 - error: bluelink.0 (8379) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.devices: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.devices": DB closed
    2023-07-20 11:45:06.314 - error: bluelink.0 (8379) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.battery": Connection is closed.
    2023-07-20 11:45:06.316 - error: bluelink.0 (8379) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.battery: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.battery": Connection is closed.
    2023-07-20 11:45:06.445 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    Nach dem Start des Adapters haut mir diese Fehlermeldung 3x ins log, danach schließt ioBroker automatisch den Adapter.
    Adapterversionen: 2.3.5/2.3.2
    Plattform:
    linux
    Betriebssystem:
    linux
    Architektur:
    arm
    CPUs:
    Geschwindigkeit:
    1500 MHz
    Modell:
    unknown
    RAM:
    3.7 GB
    System-Betriebszeit:
    9 T. 05:14:06
    Node.js:
    v18.17.0
    time:
    1689846274481
    Adapter-Anzahl:
    563
    NPM:
    9.6.7
    Datenträgergröße:
    14.3 GB
    Freier Festplattenspeicher:
    6.4 GB
    Betriebszeit:
    05:02:18
    Aktive Instanzen:
    35
    Pfad:
    /opt/iobroker/
    aktiv:
    _nodeCurrent:
    18.17.0
    _nodeNewest:
    18.17.0
    _nodeNewestNext:
    18.17.0
    _npmCurrent:
    9.6.7
    _npmNewest:
    9.6.7
    _npmNewestNext:
    9.6.7
    NewanN Offline
    NewanN Offline
    Newan
    #1295
    @michaelnorge Bitte mal auf debug stellen.
    • NewanN Newan
      Michaelnorge
      #1296
      @newan Habe ich hier vorliegen - kann ich Dir das per Mail oder so senden? Sind ne haufen Infos drinne die ich nicht alle rausgefiltert bekomme.
      Bräuchte dann eine Emailaddy von Dir :-)
      • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
      • M Michaelnorge
        Guten Morgen!
        Plattform:
        linux
        Betriebssystem:
        linux
        Architektur:
        arm
        CPUs:
        Geschwindigkeit:
        1500 MHz
        Modell:
        unknown
        RAM:
        3.7 GB
        9 T. 05:14:06
        Node.js:
        v18.17.0
        time:
        1689846274481
        Adapter-Anzahl:
        563
        NPM:
        9.6.7
        Datenträgergröße:
        14.3 GB
        6.4 GB
        Betriebszeit:
        05:02:18
        Aktive Instanzen:
        35
        Pfad:
        /opt/iobroker/
        aktiv:
        _nodeCurrent:
        18.17.0
        _nodeNewest:
        18.17.0
        _nodeNewestNext:
        18.17.0
        _npmCurrent:
        9.6.7
        _npmNewest:
        9.6.7
        _npmNewestNext:
        9.6.7
        arteckA Offline
        arteckA Offline
        arteck
        #1297
        @michaelnorge ALSO
        ersmal adapter von Git installieren dann dann alle Objekte löschen
        dann adapter starten
        falls jetzt zum Abbruch kommt ..l den abbruch Posten..
        die Stelle passt nicht zum sourcode was du da hast..
          Michaelnorge
          #1298
          @arteck Frische Installation oder drüber installieren?
          • M Michaelnorge
            arteckA Offline
            arteckA Offline
            arteck
            #1299
            @michaelnorge ja
              Michaelnorge
              schrieb am zuletzt editiert von Michaelnorge
              #1300
              Hab ich gemacht, jetzt die Version 2.3.5.
              Das Problem besteht weiterhin. Bluelink versucht 3x zu starten und wird dann vom Host gestoppt.
              2023-07-20 13:37:37.076 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.total is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.080 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.092 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.093 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.097 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21)
              at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17)
              at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29)
              2023-07-20 13:37:37.098 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.106 - warn: bluelink.0 (12152) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-07-20 13:37:37.108 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.engine is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.109 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.118 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.119 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.120 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              2023-07-20 13:37:37.121 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.125 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.climate is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.126 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.141 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.141 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.142 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              2023-07-20 13:37:37.142 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.147 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.devices is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.149 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.162 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.162 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.163 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              2023-07-20 13:37:37.163 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.battery is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.185 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.186 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.187 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              2023-07-20 13:37:37.187 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.191 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.regen is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.192 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.215 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.216 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.217 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              2023-07-20 13:37:37.217 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.distance is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
              2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
              2023-07-20 13:37:37.238 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-07-20 13:37:37.239 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
              2023-07-20 13:37:37.239 - error: bluelink.0 (12152) Error: undefined is not a valid state value
              2023-07-20 13:37:37.240 - error: bluelink.0 (12152) undefined is not a valid state value
              2023-07-20 13:37:37.623 - error: bluelink.0 (12152) Error: Connection is closed.
              2023-07-20 13:37:37.625 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed.
              2023-07-20 13:37:37.627 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed.
              2023-07-20 13:37:37.629 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed.
              2023-07-20 13:37:37.632 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed.
              2023-07-20 13:37:37.634 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed.
              2023-07-20 13:37:37.636 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed.
              2023-07-20 13:37:37.638 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.period": Connection is closed.
              2023-07-20 13:37:37.759 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              2023-07-20 13:37:37.759 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
              Mich stört das nicht wirklich, zur Not ziehe ich ein Backup von Gestern rein - wäre aber cool zu erfahren wieso das passiert ist 😁
              Ich meine ich hätte den JS-Controller upgedated (jetzt v18.17.0)
              • M Michaelnorge
                arteckA Offline
                arteckA Offline
                arteck
                #1301
                @michaelnorge mach erstmal in den Einstellungen den EV teil aus( links unten) . da passt was nicht.. dann sollte zumindest der adapter wieder starten
                ansonten kannst nochmal von GIT isntallieren..
                • arteckA arteck
                  Michaelnorge
                  #1302
                  @arteck Mir war das zu heikel und ich habe direkt nach meinem letzten Post ne 10 Tage alte Version drüber gezogen, noch bevor ich angefangen bin, mit den Betas rumzuspielen.
                  Vielleicht habe ich einfach was falsch gemacht, vielleicht melden sich auch noch andere hier mit dem gleichen Problem. Sry das ich Dir nicht helfen kann ;-)
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    #1303
                    ich hab da mal was gebastelt damit die Datenpunkte stimmen, bei MHEV/PHEV oder Benziner/Diesel
                    die können die Klima nicht einschalten
                    die Motorvariante dementsprechend einstellen ..sonst startet der Adapter nicht.. meldung im LOG beachten
                    ansonsten kann man jetzt auch fore_login durchführen.. ohne den adapter neu starten zu müssen
                    ALLE Steuerrungsdatenpunkte sind umgezogen in Control.. bitte adapter Datenpunkte löschen .. damit diese an der richtigen stelle neu erstellt werden
                    force_update wurde korrigiert.. war als button deklariert..
                    nik82N 1 Antwort Letzte Antwort
                    • arteckA arteck
                      nik82N Offline
                      nik82N Offline
                      nik82
                      #1304
                      @arteck
                      Vielen Dank für das Update, funktioniert alles perfekt 👍
                      (EV: Kia EV6)
                      • M Michael Loddoch
                        @dalugi Hast du inzwischen einen Lösung gefunden?
                        DaLugi
                        #1305
                        @michael-loddoch
                        Mit Version 2.3.5 funktioniert es jetzt. Dankeschön!
                          bigal
                          #1306
                          Seit heute morgen 0 Uhr, hat noch jemand die Probleme?
                          Bluelink App geht aber ohne Probleme
                          bluelink.0
                          	2023-07-29 09:18:27.129	error	Server is not available or login credentials are wrong
                          bluelink.0
                          	2023-07-29 09:18:27.128	error	ManagedBluelinkyError: @EuropeController.getVehicles: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/vehicles - {"retCode":"F","resCode":"4017","resMsg":"Invalid request value - Invalid Application Id. - 32437.111000061035","msgId":"973b7063-9c26-433e-9532-f4c5316b5bdb"}
                          bluelink.0
                          	2023-07-29 09:18:21.185	info	Login to api
                          bluelink.0
                          	2023-07-29 09:18:21.140	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.15.0, js-controller: 4.0.24
                          Meister MopperM M R 3 Antworten Letzte Antwort
                          • B bigal
                            bluelink.0
                            bluelink.0
                            bluelink.0
                            bluelink.0
                            Meister MopperM Online
                            Meister Mopper
                            #1307
                            @bigal sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                            Jap, kommt immer mal wieder vor, die Server spacken mal wieder rum.
                            Proxmox und HA ...
                            Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                            • B bigal
                              bluelink.0
                              bluelink.0
                              bluelink.0
                              bluelink.0
                              Michaelnorge
                              #1308
                              @bigal Jepp, hier das Gleiche (Norwegen)
                              Edit: Ist aber gut das hier im Forum jemand bescheid sagt. Das schließt dann automatisch einen anderen Fehler aus :-)
                              • B bigal
                                bluelink.0
                                bluelink.0
                                bluelink.0
                                bluelink.0
                                Ron 1
                                #1309
                                @bigal @arteck
                                Ich glaube das liegt an einem Problem der hyundai_kia_Connect_api. Es waren wohl auch andere Programm betroffen.: =>
                                https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/releases/tag/v3.4.0
                                Habe leider zu wenig Ahnung um das Problem genau nachzuvollziehen. Bei mir besteht es auf alle Fälle weiterhin.
                                • R Ron 1
                                  @bigal @arteck
                                  Michaelnorge
                                  #1310
                                  @ron-1 Ja bei mir auch unverändert....
                                  • Meister MopperM Online
                                    Meister Mopper
                                    #1311
                                    @michaelnorge
                                    Bei mir funktioniert es seit 11:14 Uhr wieder. Mal sehen wie lang
                                    Proxmox und HA ...
                                    ? M R 3 Antworten Letzte Antwort
                                      @michaelnorge
                                      #1312
                                      @meister-mopper
                                      Hier läufts auch wieder…
                                        @michaelnorge
                                        Michaelnorge
                                        #1313
                                        @meister-mopper Ja hier auch :-)
                                          @michaelnorge
                                          Ron 1
                                          #1314
                                          @meister-mopper Hier geht es auch wieder .
