  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
    Michaelnorge
    #1298
    @arteck Frische Installation oder drüber installieren?
    • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
    • M Michaelnorge
      arteckA Offline
      arteckA Offline
      arteck
      #1299
      @michaelnorge ja
        Michaelnorge
        schrieb am zuletzt editiert von Michaelnorge
        #1300
        Hab ich gemacht, jetzt die Version 2.3.5.
        Das Problem besteht weiterhin. Bluelink versucht 3x zu starten und wird dann vom Host gestoppt.
        2023-07-20 13:37:37.076 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.total is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.080 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.092 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.093 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.097 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
        at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49)
        at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21)
        at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34)
        at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21)
        at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17)
        at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21)
        at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17)
        at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29)
        2023-07-20 13:37:37.098 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.106 - warn: bluelink.0 (12152) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-07-20 13:37:37.108 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.engine is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.109 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.118 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.119 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.120 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        2023-07-20 13:37:37.121 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.125 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.climate is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.126 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.141 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.141 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.142 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        2023-07-20 13:37:37.142 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.147 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.devices is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.149 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.162 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.162 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.163 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        2023-07-20 13:37:37.163 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.battery is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.185 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.186 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.187 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        2023-07-20 13:37:37.187 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.191 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.regen is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.192 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.215 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.216 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.217 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        2023-07-20 13:37:37.217 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.distance is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
        2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer.
        2023-07-20 13:37:37.238 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-07-20 13:37:37.239 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value
        2023-07-20 13:37:37.239 - error: bluelink.0 (12152) Error: undefined is not a valid state value
        2023-07-20 13:37:37.240 - error: bluelink.0 (12152) undefined is not a valid state value
        2023-07-20 13:37:37.623 - error: bluelink.0 (12152) Error: Connection is closed.
        2023-07-20 13:37:37.625 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed.
        2023-07-20 13:37:37.627 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed.
        2023-07-20 13:37:37.629 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed.
        2023-07-20 13:37:37.632 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed.
        2023-07-20 13:37:37.634 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed.
        2023-07-20 13:37:37.636 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed.
        2023-07-20 13:37:37.638 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.period": Connection is closed.
        2023-07-20 13:37:37.759 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-07-20 13:37:37.759 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
        Mich stört das nicht wirklich, zur Not ziehe ich ein Backup von Gestern rein - wäre aber cool zu erfahren wieso das passiert ist 😁
        Ich meine ich hätte den JS-Controller upgedated (jetzt v18.17.0)
        • M Michaelnorge
          arteckA Offline
          arteckA Offline
          arteck
          #1301
          @michaelnorge mach erstmal in den Einstellungen den EV teil aus( links unten) . da passt was nicht.. dann sollte zumindest der adapter wieder starten
          ansonten kannst nochmal von GIT isntallieren..
          • arteckA arteck
            Michaelnorge
            #1302
            @arteck Mir war das zu heikel und ich habe direkt nach meinem letzten Post ne 10 Tage alte Version drüber gezogen, noch bevor ich angefangen bin, mit den Betas rumzuspielen.
            Vielleicht habe ich einfach was falsch gemacht, vielleicht melden sich auch noch andere hier mit dem gleichen Problem. Sry das ich Dir nicht helfen kann ;-)
            • arteckA Offline
              arteckA Offline
              arteck
              #1303
              ich hab da mal was gebastelt damit die Datenpunkte stimmen, bei MHEV/PHEV oder Benziner/Diesel
              die können die Klima nicht einschalten
              die Motorvariante dementsprechend einstellen ..sonst startet der Adapter nicht.. meldung im LOG beachten
              ansonsten kann man jetzt auch fore_login durchführen.. ohne den adapter neu starten zu müssen
              ALLE Steuerrungsdatenpunkte sind umgezogen in Control.. bitte adapter Datenpunkte löschen .. damit diese an der richtigen stelle neu erstellt werden
              force_update wurde korrigiert.. war als button deklariert..
              nik82N 1 Antwort Letzte Antwort
              • arteckA arteck
                nik82N Offline
                nik82N Offline
                nik82
                #1304
                @arteck
                Vielen Dank für das Update, funktioniert alles perfekt 👍
                (EV: Kia EV6)
                • M Michael Loddoch
                  @dalugi Hast du inzwischen einen Lösung gefunden?
                  DaLugi
                  #1305
                  @michael-loddoch
                  Mit Version 2.3.5 funktioniert es jetzt. Dankeschön!
                    bigal
                    #1306
                    Seit heute morgen 0 Uhr, hat noch jemand die Probleme?
                    Bluelink App geht aber ohne Probleme
                    bluelink.0
                    	2023-07-29 09:18:27.129	error	Server is not available or login credentials are wrong
                    bluelink.0
                    	2023-07-29 09:18:27.128	error	ManagedBluelinkyError: @EuropeController.getVehicles: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/vehicles - {"retCode":"F","resCode":"4017","resMsg":"Invalid request value - Invalid Application Id. - 32437.111000061035","msgId":"973b7063-9c26-433e-9532-f4c5316b5bdb"}
                    bluelink.0
                    	2023-07-29 09:18:21.185	info	Login to api
                    bluelink.0
                    	2023-07-29 09:18:21.140	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.15.0, js-controller: 4.0.24
                    Meister MopperM M R 3 Antworten Letzte Antwort
                    • B bigal
                      bluelink.0
                      bluelink.0
                      bluelink.0
                      bluelink.0
                      Meister MopperM Offline
                      Meister Mopper
                      #1307
                      @bigal sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                      Jap, kommt immer mal wieder vor, die Server spacken mal wieder rum.
                      Proxmox und HA ...
                      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                      • B bigal
                        bluelink.0
                        bluelink.0
                        bluelink.0
                        bluelink.0
                        Michaelnorge
                        #1308
                        @bigal Jepp, hier das Gleiche (Norwegen)
                        Edit: Ist aber gut das hier im Forum jemand bescheid sagt. Das schließt dann automatisch einen anderen Fehler aus :-)
                        • B bigal
                          bluelink.0
                          bluelink.0
                          bluelink.0
                          bluelink.0
                          Ron 1
                          #1309
                          @bigal @arteck
                          Ich glaube das liegt an einem Problem der hyundai_kia_Connect_api. Es waren wohl auch andere Programm betroffen.: =>
                          https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/releases/tag/v3.4.0
                          Habe leider zu wenig Ahnung um das Problem genau nachzuvollziehen. Bei mir besteht es auf alle Fälle weiterhin.
                          • R Ron 1
                            @bigal @arteck
                            Michaelnorge
                            #1310
                            @ron-1 Ja bei mir auch unverändert....
                            • Meister MopperM Offline
                              Meister Mopper
                              #1311
                              @michaelnorge
                              Bei mir funktioniert es seit 11:14 Uhr wieder. Mal sehen wie lang
                              Proxmox und HA ...
                              ? M R 3 Antworten Letzte Antwort
                                @michaelnorge
                                #1312
                                @meister-mopper
                                Hier läufts auch wieder…
                                  @michaelnorge
                                  Michaelnorge
                                  #1313
                                  @meister-mopper Ja hier auch :-)
                                    @michaelnorge
                                    Ron 1
                                    #1314
                                    @meister-mopper Hier geht es auch wieder .
                                      sansibar
                                      #1315
                                      vielleicht kann mir ja jemand mal erklären, was ich falsch mache: Ich habe auch Version 2.3.5 über GIT installiert. Ich habe einen KIA EV6 und entsprechend Motor "EV" ausgewählt.
                                      Die Verbindung funktioniert wunderbar und es werden regelmäßig Updates vom Auto geholt und in die Objekte geschrieben.
                                      Wenn ich einen(!) Befehl ans Auto sende, dann funktioniert auch das wunderbar, also Klima an, aufschließen, whatever...
                                      Sende ich einen weiteren Befehl, dann kommt dieser nicht am Auto an und im Protokoll erscheint folgende Fehlermeldung:
                                      Hier habe ich bspw. zwei mal hintereinander die Klima gestoppt: Das erste Mal klappt, das zweite (und jedes weitere) Mal nicht mehr.
                                      Starte ich die Instanz neu, dann kann ich wieder erfolgreich einen(!) Befehl abschicken, sende ich einen zweiten oder dritten Befehl, dann laufen die in diesen Fehler - bis ich die Instanz wieder neu starte.
                                      Sieht das bei noch jemandem so aus? Jemand eine Idee?
                                      Vielen Dank 😳
                                      arteckA nik82N 2 Antworten Letzte Antwort
                                      • S sansibar
                                        Vielen Dank 😳
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #1316
                                        @sansibar ja das ist noch ein Bug..Serverseitig..warum auch immer .. es scheint als ob jede 2-te Aufruf die App ID verliert
                                        deshalb hab ich ein force_login button eingebaut.. also befehl absetzen dann dirket hinterher force_login...dann klappt mit dem nächsten Befehl ohne Fehler
                                        • S sansibar
                                          Vielen Dank 😳
                                          nik82N Offline
                                          nik82N Offline
                                          nik82
                                          #1317
                                          @sansibar
                                          Hey da haben wir ja endlich noch einen Kia EV6 Fahrer :-)
                                          Arteck hat dafür extra den force_login Button rein.
                                          Einfach dieses Blockly machen, dann funktioniert alles perfekt:
                                          W S 2 Antworten Letzte Antwort
