  4. wie bei tinkerboard / armbian note.js aktualisieren ?
32 Beiträge 5 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • HALH Offline
    HALH Offline
    HAL
    Der Update von note-red 2.0.3 auf 2.1.0 scheitert bei mir mit einer Fehlermeldung. Wenn ich die richtig verstehe, muss mein note.js auf 10.32.1 aktualisiert werden.
    Wie mache ich das richtig ?
    $ ./iobroker upgrade node-red
    Update node-red from @2.0.3 to @2.1.0
    host.tinkerboard Adapter "system.adapter.node-red.0" is stopped.
    NPM version: 6.14.6npm install iobroker.node-red@2.1.0 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for html-to-text@7.0.0: wanted: {"node":">=10.23.2"} (current: {"node":"10.22.0","npm":"6.14.6"})
    npm ERR! notsup Not compatible with your version of node/npm: html-to-text@7.0.0npm ERR! notsup Not compatible with your version of node/npm: html-to-text@7.0.0npm ERR! notsup Required: {"node":">=10.23.2"}
    npm ERR! notsup Actual:   {"npm":"6.14.6","node":"10.22.0"}
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-25T11_59_05_307Z-debug.log
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    Adapter "node-red" updated
    host.tinkerboard Adapter "system.adapter.node-red.0" is started
    process exited with code 0
    Systeminformationen:
    tinkerboard
    Platform linux
    Betriebssystem linux
    Architektur arm
    CPUs  4
    Geschwindigkeit 1800 MHz
    Modell ARMv7 Processor rev 1 (v7l)
    RAM 1.95 GB
    System Betriebszeit 72 T. 21:10:44
    Node.js  v10.22.0 (Es gibt eine neuere Version:
             v10.24.0 - Empfohlene Version v12.21.0)
    Festplatte Größe 28.01 GB
    Festplatte frei 24.33 GB
    Anzahl der Adapter 329
    NPM v6.14.6
    Betriebszeit 00:00:50
    Aktive Instanzen 7
    Hostname tinkerboard
    Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
    (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
    • HALH HAL
      tinkerboard
      Platform linux
      Architektur arm
      CPUs  4
      RAM 1.95 GB
      NPM v6.14.6
      Aktive Instanzen 7
      @hal Dürfte analog auch für Armbian gelten:
      HALH 1 Antwort Letzte Antwort
        HALH Offline
        HALH Offline
        HAL
        @thomas-braun sorry für die späte Antwort, war "beschäftigt". So ganz hat es nach der Anweisung nicht geklappt.
        Nach
        sudo apt update
        sudo apt upgrade
        sudo reboot
        konnte ich den neuen note-red Adapter installieren, es war aber noch die alte note.js 10.x installiert.
        Nach
         GNU nano 4.8      /etc/apt/sources.list.d/nodesource.list
        # deb https://deb.nodesource.com/node_10.x focal main
        # deb-src https://deb.nodesource.com/node_10.x focal main
        # node 12
        deb https://deb.nodesource.com/node_12.x buster main
        deb-src https://deb.nodesource.com/node_12.x buster main
        ein sudo apt update brachte Fehler
        root@tinkerboard:~# sudo apt update
        Hit:1 http://deb.debian.org/debian stable InRelease
        Hit:2 http://ports.ubuntu.com focal InRelease
        Hit:3 http://deb.debian.org/debian stable-updates InRelease
        Hit:4 http://deb.debian.org/debian-security stable/updates InRelease
        Hit:5 https://repos.influxdata.com/debian focal InRelease
        Hit:6 http://ports.ubuntu.com focal-security InRelease
        Hit:7 https://deb.nodesource.com/node_12.x buster InRelease
        Hit:8 http://ports.ubuntu.com focal-updates InRelease
        Hit:9 http://ports.ubuntu.com focal-backports InRelease
        Get:10 https://archive.raspbian.org/raspbian buster InRelease [15.0 kB]
        Err:10 https://archive.raspbian.org/raspbian buster InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
        Get:11 https://armbian.systemonachip.net/apt focal InRelease [18.2 kB]
        Reading package lists... Done
        W: GPG error: https://archive.raspbian.org/raspbian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
        E: The repository 'https://archive.raspbian.org/raspbian buster InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        root@tinkerboard:~# apt policy nodejs
        nodejs:
          Installed: 10.24.0-deb-1nodesource1
          Candidate: 12.21.0-1nodesource1
          Version table:
             12.21.0-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         *** 10.24.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 300
                300 http://deb.debian.org/debian-security stable/updates/main armhf ages
             10.21.0~dfsg-1~deb10u1 300
                300 http://deb.debian.org/debian stable/main armhf Packages
             10.19.0~dfsg-3ubuntu1 500
                500 http://ports.ubuntu.com focal/universe armhf Packages
        root@tinkerboard:~#
        auch ein sudo apt install nodejs=12.21.0-1nodesource1 lief auf Fehler
        root@tinkerboard:~# sudo apt install nodejs=12.21.0-1nodesource1
        Building dependency tree
        Some packages could not be installed. This may mean that you have
        requested an impossible situation or if you are using the unstable
        distribution that some required packages have not yet been created
        or been moved out of Incoming.
        The following information may help to resolve the situation:
        The following packages have unmet dependencies:
         nodejs : Depends: python-minimal but it is not going to be installed
        E: Unable to correct problems, you have held broken packages
        muss ich überhaupt die note.js akualisieren ? Momentan läuft alles.
        • HALH HAL
          Nach
          sudo apt update
          sudo apt upgrade
          sudo reboot
          Nach
          # node 12
          nodejs:
            Version table:
          root@tinkerboard:~#
          @hal
          Du schmeißt ja auch alles durcheinander. Was hast du denn da nun installiert?
          ubunt focal? RasperryOS 'Buster'? Armbian?
          lsb_release -a
          Als root meldet man sich nicht an, und wenn man es dann doch tut, dann macht man da auch nicht noch mit sudo herum...
            @hal
            lsb_release -a
            @thomas-braun sagte in wie bei tinkerboard / armbian note.js aktualisieren ?:
            Armbian gibt es jeweils Ubuntu oder Debian basiert.
            Warum @HAL beides drin hat ist mir schleierhaft.
            Auch dass nodejs python-minimal benötigt.
            python (ohne minimal) ist üblicherweise in jeder Distro drauf
              HALH Offline
              HALH Offline
              HAL
              Es ist Ubuntu focal
              pi@tinkerboard:~$ lsb_release -a
              No LSB modules are available.
              Distributor ID: Ubuntu
              Description:    Ubuntu 20.04.2 LTS
              Release:        20.04
              Codename:       focal
              • HALH HAL
                Nach
                sudo apt update
                sudo apt upgrade
                sudo reboot
                Nach
                # node 12
                nodejs:
                  Version table:
                root@tinkerboard:~#
                @hal sagte in wie bei tinkerboard / armbian note.js aktualisieren ?:
                Es ist Ubuntu focal
                und warum steht hier überall
                12.21.0-1nodesource1 500 > 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages > *** 10.24.0-deb-1nodesource1 100 > 100 /var/lib/dpkg/status > 10.24.0~dfsg-1~deb10u1 300 > 300 http://deb.debian.org/debian-security stable/updates/main armhf ages > 10.21.0~dfsg-1~deb10u1 300 > 300 http://deb.debian.org/debian stable/main armhf Packages
                Debian und Buster?
                das kann dann ja nicht passen
                  Es ist Ubuntu focal
                  Debian und Buster?
                  HALH Offline
                  HALH Offline
                  HAL
                  @homoran Ich habe mit dem Script installiert und nur das gemacht, was im Forumseintrag steht.
                  • HALH HAL
                    welches und welcher?
                      HALH Offline
                      HALH Offline
                      HAL
                      schrieb am zuletzt editiert von HAL
                      @homoran Tinkerboard Image installiert, dann mit dem https://github.com/Homoran/iobroker.install
                      ( ist aber schon etwas länger her ) iobroker installiert.
                      Als alles lief habe ich später noch InfluxDB und Grafana installiert
                      die notes.js habe ich nach dem mit empfohlenen Beitrag https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian versucht zu installieren, habe aber über sehen, das da debian steht.
                      • HALH HAL
                        @hal
                        Die Vorgehensweise bei deb-basierten Distributionen ist prinzipiell gleich.
                        Ubuntu basiert ja auf Debian. Die Unterscheide liegen im Detail, und deswegen sollte man nie Repositories für Debian mit denen für Ubuntu mischen. Ist wie beim Auto. Ein Passat fährt grundsätzlich ganz ähnlich wie ein Golf, dennoch kann man die wenigsten Teile von dem einen Modell auch an das andere schrauben.
                        Also den ganzen Kram zu Debian/Buster da raus, da müssen Ubuntu/Focal-Quellen rein.
                        • HALH HAL
                          das ist jetzt dein Problem
                            HALH Offline
                            HALH Offline
                            HAL
                            @homoran ok, meinst Du hier ?
                            # node 12
                            und wo finde ich die Quellen ?
                            • HALH HAL
                              # node 12
                              was stand denn da vorher, bevor du es auf "buster" geändert hast?
                              • HALH HAL
                                # node 12
                                deb https://deb.nodesource.com/node_12.x focal main
                                deb-src https://deb.nodesource.com/node_12.x focal main
                                gehört da rein, die Zeilen zu buster löschen.
                                Da müssen aber noch mehr .list-Dateien sein, die buster/debian-Quellen beinhalten.
                                  HALH Offline
                                  HALH Offline
                                  HAL
                                  @homoran nur die oberen jetzt auskommentierten beiden Zeilen:
                                  was ich irritiert, mal steht ubuntu in den Quellen und mal deb:
                                  pi@tinkerboard:~$ apt-cache policy
                                  Package files:
                                       release a=now
                                       release o=Node Source,n=buster,l=Node Source,c=main,b=armhf
                                       origin deb.nodesource.com
                                   500 https://deb.nodesource.com/node_10.x focal/main armhf Packages
                                       release o=Node Source,n=focal,l=Node Source,c=main,b=armhf
                                   500 https://repos.influxdata.com/debian focal/stable armhf Packages
                                       release o=InfluxDB,n=focal,l=InfluxDB,c=stable,b=armhf
                                       origin repos.influxdata.com
                                   300 http://deb.debian.org/debian-security stable/updates/main armhf Packages
                                       release v=10,o=Debian,a=stable,n=buster,l=Debian-Security,c=main,b=armhf
                                       origin deb.debian.org
                                   300 http://deb.debian.org/debian stable-updates/main armhf Packages
                                       release o=Debian,a=stable-updates,n=buster-updates,l=Debian,c=main,b=armhf
                                       release v=10.8,o=Debian,a=stable,n=buster,l=Debian,c=main,b=armhf
                                   500 http://apt.armbian.com focal/focal-desktop armhf Packages
                                       release o=Armbian,a=focal,n=focal,l=Armbian,c=focal-desktop,b=armhf
                                       origin apt.armbian.com
                                   500 http://apt.armbian.com focal/focal-utils armhf Packages
                                       release o=Armbian,a=focal,n=focal,l=Armbian,c=focal-utils,b=armhf
                                   500 http://apt.armbian.com focal/main armhf Packages
                                       release o=Armbian,a=focal,n=focal,l=Armbian,c=main,b=armhf
                                   100 http://ports.ubuntu.com focal-backports/universe armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-backports,n=focal,l=Ubuntu,c=universe,b=armhf
                                       origin ports.ubuntu.com
                                   500 http://ports.ubuntu.com focal-updates/multiverse armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=multiverse,b=armhf
                                   500 http://ports.ubuntu.com focal-updates/universe armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=universe,b=armhf
                                   500 http://ports.ubuntu.com focal-updates/restricted armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=restricted,b=armhf
                                   500 http://ports.ubuntu.com focal-updates/main armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=main,b=armhf
                                   500 http://ports.ubuntu.com focal-security/multiverse armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=multiverse,b=armhf
                                   500 http://ports.ubuntu.com focal-security/universe armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=universe,b=armhf
                                   500 http://ports.ubuntu.com focal-security/restricted armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=restricted,b=armhf
                                   500 http://ports.ubuntu.com focal-security/main armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=main,b=armhf
                                   500 http://ports.ubuntu.com focal/multiverse armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=multiverse,b=armhf
                                       release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=universe,b=armhf
                                   500 http://ports.ubuntu.com focal/restricted armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=restricted,b=armhf
                                   500 http://ports.ubuntu.com focal/main armhf Packages
                                       release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=main,b=armhf
                                  Pinned packages:
                                       chromium-bsu -> 0.9.16.1-2 with priority 700
                                       chromium-driver -> 88.0.4324.182-1~deb10u1 with priority 700
                                       chromium-driver -> 87.0.4280.141-0.1~deb10u1 with priority 700
                                       chromium-l10n -> 88.0.4324.182-1~deb10u1 with priority 700
                                       chromium-l10n -> 87.0.4280.141-0.1~deb10u1 with priority 700
                                       chromium-shell -> 88.0.4324.182-1~deb10u1 with priority 700
                                       chromium-shell -> 87.0.4280.141-0.1~deb10u1 with priority 700
                                       chromium -> 88.0.4324.182-1~deb10u1 with priority 700
                                       chromium -> 87.0.4280.141-0.1~deb10u1 with priority 700
                                       chromium-bsu-data -> 0.9.16.1-2 with priority 700
                                       chromium-sandbox -> 88.0.4324.182-1~deb10u1 with priority 700
                                       chromium-sandbox -> 87.0.4280.141-0.1~deb10u1 with priority 700
                                       chromium-common -> 88.0.4324.182-1~deb10u1 with priority 700
                                       chromium-common -> 87.0.4280.141-0.1~deb10u1 with priority 700
                                       chromium-tt-rss-notifier -> 0.5.2-2 with priority 700
                                       chromium-lwn4chrome -> 1.0-3 with priority 700
                                  pi@tinkerboard:~$
                                  • HALH HAL
                                    Package files:
                                         release a=now
                                    Pinned packages:
                                    pi@tinkerboard:~$
                                    @hal
                                    Zuvor
                                    sudo apt update
                                    Erst dann mit policy nachschauen. Und warum ist da chromium gepinnt?
                                    Und warum ist der überhaupt auf einem Server installiert? Hat da nix verloren.
                                      @hal
                                      Zuvor
                                      sudo apt update
                                      HALH Offline
                                      HALH Offline
                                      HAL
                                      @thomas-braun damit sind meine rudimentären Linux Kenntnisse überfordert. Aber bisher läuft alles einwandfrei.
                                      • HALH HAL
                                        Das sehe ich...
                                        ...nicht so.
                                          Das sehe ich...
                                          ...nicht so.
                                          HALH Offline
                                          HALH Offline
                                          HAL
                                          @thomas-braun woran sehe ich das ? Im iobroker log taucht kaum Fehler auf. Alle Adapter, Views, Scripte usw. tun es . Grafana und influxDB gehen auch. Die Load ist m.E. nicht zu hoch.
                                          Einzig Note.js lässt sich nicht aktualisieren.
                                          Müsste ich das System komplett neu aufsetzen um das zu fixen ?
                                          HALH Thomas BraunT 2 Antworten Letzte Antwort
