  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.3k Aufrufe 147 Beobachtet
  • LongbowL Longbow
    guten Morgen, habe es alles gemacht wie es dort beschrieben ist, eine Abhilfe hat es leider nicht gebracht.
    Hab ein neues System nach den Anleitungen gemacht.
    Habe es mit auch alles angeschaut mit Nodejs, aber ich bekomme nur Fehlermeldungen. Der Adpater bleibt ohne Daten und Verbindung rot
    Debian GNU/Linux 11 iobroker-Test tty1
    iobroker-Test login: root
    Password:
    Linux iobroker-Test 5.15.30-2-pve #1 SMP PVE 5.15.30-3 (Fri, 22 Apr 2022 18:08:27 +0200) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Thu Feb  2 08:28:34 CET 2023 on tty1
    root@iobroker-Test:~# apt install sudo curl
    Reading package lists... Done
    Building dependency tree... Done
    The following additional packages will be installed:
      libcurl4
    The following NEW packages will be installed:
      curl libcurl4 sudo
    0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1673 kB of archives.
    After this operation, 5895 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Err:1 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u3
      Temporary failure resolving 'deb.debian.org'
    Err:2 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u3
    Err:3 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
    E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/libcurl4_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
    E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/curl_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
    E: Failed to fetch http://deb.debian.org/debian/pool/main/s/sudo/sudo_1.9.5p2-3_amd64.deb  Temporary failure resolving 'deb.debian.org'
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    root@iobroker-Test:~# curl libcurl4 sudo
    -bash: curl: command not found
    root@iobroker-Test:~# apt install curl
      libcurl4
      curl libcurl4
    0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 615 kB of archives.
    After this operation, 1196 kB of additional disk space will be used.
      sudo
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1059 kB of archives.
    After this operation, 4699 kB of additional disk space will be used.
    Err:1 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
    root@iobroker-Test:~# apt-get update
    Err:1 http://deb.debian.org/debian bullseye InRelease
    Err:2 http://security.debian.org bullseye-security InRelease
      Temporary failure resolving 'security.debian.org'
    Err:3 http://deb.debian.org/debian bullseye-updates InRelease
    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
    W: Failed to fetch http://security.debian.org/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    root@iobroker-Test:~# apt update && apt upgrade
    All packages are up to date.
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    LongbowL Offline
    LongbowL Offline
    Longbow
    #641
    @Thomas-Braun
    das war bei mir mit dem Befehl cd /opt/iobroker
    npm ls | grep -E 'github|ERR'
    cliffkirchhof@iobroker:/opt/iobroker$ npm ls | grep -E 'github|ERR'
    +-- eufy-security-client@2.4.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#7fc2a45a75ee1bf69ced36d351d1ec6d623896f6)
    +-- iobroker.klf200@1.0.1 (git+ssh://git@github.com/MiSchroe/ioBroker.klf200.git#c0799c01cca44762617b9fa5e709d60a83a80f24)
    +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspstream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)e_text
    • LongbowL Longbow
      Password:
        libcurl4
        curl libcurl4 sudo
        libcurl4
        curl libcurl4
        sudo
      #642
      @longbow sagte in [Neuer Adapter] EuSec:
      Dein Netzwerk ist kaputt.
      Und du möchstest nicht als root herumhampeln.
      LongbowL 1 Antwort Letzte Antwort
        LongbowL Offline
        LongbowL Offline
        Longbow
        #643
        sorry, ich verstehe es leider nicht ganz, was ist kaputt der iobroker läuft, bis auf den Adapter EuSec.
        Thomas BraunT L 2 Antworten Letzte Antwort
        • LongbowL Longbow
          #644
          @longbow
          Der Server deb.debian.org kann nicht erreicht werden. Warum auch immer. Vermutlich ein Knoten in deinem Netzwerk.
          • LongbowL Longbow
            locito09
            #645
            @longbow
            Eusec hat bekanntlich Probleme mit jpeg download und disconnected, schaue auf github und /oder weiter oben lesen.
            Es gibt noch keine Lösung die mir bekannt ist
            Für nächste mal Informiere dich was für Issues offen sind für den Adapter, und bitte ein paar post weiter oben lesen, das Problem ist bekannt
              @longbow
              LongbowL Offline
              LongbowL Offline
              Longbow
              #646
              @Thomas-Braun
              Danke für den Tipp, habe es neu gemacht, hatte ein IP Adressen Fehler.
              Aber jetzt geht der Adapter immer noch nicht.
              ======== Start marking the full check here =========
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Architecture:   x86_64
              Docker:         false
              Virtualization: lxc
              Distributor ID: Debian
              Description:    Debian GNU/Linux 11 (bullseye)
              Release:        11
              Codename:       bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
               19:36:02 up 11 min,  1 user,  load average: 0.33, 0.42, 0.48
              CPU threads: 4
              *** Time and Time Zones ***
              Thu Feb  2 18:36:02 UTC 2023
              Thu Feb  2 19:36:02 CET 2023
              CET +0100
              Europe/Berlin
              *** User and Groups ***
              cliffkirchhof
              /home/cliffkirchhof
              cliffkirchhof sudo iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            8.1G        492M        7.1G        0.0K        552M        7.6G
              Swap:           8.1G          0B        8.1G
              Total:           16G        492M         15G
                       8096 M total memory
                        492 M used memory
                        313 M active memory
                        665 M inactive memory
                       7050 M free memory
                          0 M buffer memory
                        552 M swap cache
                       8096 M total swap
                          0 M used swap
                       8096 M free swap
              *** FILESYSTEM ***
              Filesystem                       Type      Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--210--disk--0 ext4       20G  2.2G   17G  12% /
              none                             tmpfs     492K  4.0K  488K   1% /dev
              udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
              tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
              tmpfs                            tmpfs     3.2G   96K  3.2G   1% /run
              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
              Messages in dmesg:
              dmesg: read kernel buffer failed: Operation not permitted
              Show mounted filesystems (real ones only):
              TARGET SOURCE                           FSTYPE OPTIONS
              /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
              /var:
              382M    /var/
              222M    /var/cache
              218M    /var/cache/apt
              151M    /var/cache/apt/archives
              135M    /var/lib
              /opt/iobroker/backups:
              4.0K    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              93M     /opt/iobroker/iobroker-data/
              86M     /opt/iobroker/iobroker-data/files
              51M     /opt/iobroker/iobroker-data/files/javascript.admin
              32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              6.0M    /opt/iobroker/iobroker-data/objects.jsonl
              4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
              4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v16.19.0
              /usr/bin/node           v16.19.0
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Installed: 16.19.0-deb-1nodesource1
                Candidate: 16.19.0-deb-1nodesource1
                Version table:
               *** 16.19.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://security.debian.org bullseye-security/main amd64 Packages
                   12.22.5~dfsg-2~11u1 500
                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  4.0.24
              admin:          6.3.5
              javascript:     6.1.4
              Adapters from github:   1
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
              + system.adapter.chromecast.0             : chromecast            : iobroker-Final                           -  enabled
                system.adapter.cloud.0                  : cloud                 : iobroker-Final                           - disabled
              + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
              + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
                system.adapter.hue-extended.0           : hue-extended          : iobroker-Final                           - disabled
                system.adapter.hue.0                    : hue                   : iobroker-Final                           - disabled, port: 443
              + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
                system.adapter.synology.0               : synology              : iobroker-Final                           - disabled, port: 5000
                system.adapter.synology.1               : synology              : iobroker-Final                           - disabled, port: 5000
                system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
              + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.3.5    , installed 6.3.5
              Adapter    "backitup"     : 2.5.10   , installed 2.5.10
              Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
              Adapter    "cloud"        : 4.3.0    , installed 4.3.0
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hue"          : 3.7.1    , installed 3.7.1
              Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
              Controller "js-controller": 4.0.24   , installed 4.0.24
              Adapter    "socketio"     : 4.2.0    , installed 4.2.0
              Adapter    "sonos"        : 2.2.3    , installed 2.2.3
              Adapter    "synology"     : 2.1.13   , installed 2.1.13
              Adapter    "web"          : 4.3.0    , installed 4.3.0
              Adapter    "ws"           : 1.3.0    , installed 1.3.0
              Objects and States
              Objects:        545
              States:         464
              Hit:1 http://security.debian.org bullseye-security InRelease
              Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          235092916  1/init
              tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        235093971  116/systemd-resolve
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          235095151  306/master
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       235094725  127/iobroker.js-con
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        235093977  116/systemd-resolve
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       235094718  127/iobroker.js-con
              tcp6       0      0 :::22                   :::*                    LISTEN      0          235095055  1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          235092918  1/init
              tcp6       0      0 :::5355                 :::*                    LISTEN      104        235093974  116/systemd-resolve
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       235126555  2911/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       235112750  1107/io.admin.0
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          235095152  306/master
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       235096031  453/io.chromecast.0
              udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        235093970  116/systemd-resolve
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        235093976  116/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          235092917  1/init
              udp6       0      0 :::5355                 :::*                                104        235093973  116/systemd-resolve
              udp6       0      0 :::111                  :::*                                0          235092919  1/init
              2023-02-02 19:31:22.989  - info: web.0 (2911) socket.io server listening on port 8082
              2023-02-02 19:31:22.998  - info: web.0 (2911) Connect extension "eusec/build/lib/web.js"
              2023-02-02 19:31:23.000  - info: web.0 (2911) http server listening on port 8082
              2023-02-02 19:34:25.199  - info: host.iobroker-Final iobroker del eusec.0 --debug
              2023-02-02 19:34:25.796  - info: host.iobroker-Final iobroker Delete instance "eusec.0"
              2023-02-02 19:34:25.805  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 instances of eusec.0
              2023-02-02 19:34:25.812  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 14 states of system.adapter.eusec.0
              2023-02-02 19:34:25.817  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 3 states (system.adapter.eusec.0.*) from states
              2023-02-02 19:34:25.943  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 15 object(s).
              2023-02-02 19:34:25.981  - info: host.iobroker-Final object deleted system.adapter.eusec.0
              2023-02-02 19:34:25.982  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 state(s).
              2023-02-02 19:34:26.997  - info: host.iobroker-Final iobroker exit 0
              2023-02-02 19:35:24.489  - info: host.iobroker-Final iobroker del eusec --debug
              2023-02-02 19:35:25.022  - info: host.iobroker-Final iobroker Delete adapter "eusec"
              2023-02-02 19:35:25.040  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 2 meta of eusec
              2023-02-02 19:35:25.042  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 adapter for eusec
              2023-02-02 19:35:25.054  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 states (system.adapter.eusec.*) from states
              2023-02-02 19:35:25.213  - info: host.iobroker-Final iobroker host.iobroker-Final file eusec.admin deleted
              2023-02-02 19:35:25.217  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec deleted
              2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec.admin deleted
              2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 object(s).
              2023-02-02 19:35:25.227  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 1 state(s).
              2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker removed 884 packages, and changed 1 package in 3s
              2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker 66 packages are looking for funding  run `npm fund` for details
              2023-02-02 19:35:29.892  - info: host.iobroker-Final iobroker exit 0```
              code_text
              • LongbowL Offline
                LongbowL Offline
                Longbow
                #647
                Gibt es was neues, der Adapter bleibt rot, wie schon berichtet. der neu aufgesetzte ioborker läuft super.
                • LongbowL Longbow
                  #648
                  @longbow
                  Hier nix neues. Bei dir?
                  • B bropat
                    Hallo an alle,
                    ich möchte euch meinen ersten ioBroker Adapter "euSec", an dem ich gerade Arbeite, vorstellen:
                    https://github.com/bropat/ioBroker.euSec
                    Dieser Adapter ermöglicht die Steuerung von Eufy-Sicherheitsgeräten (https://www.eufylife.com/de/products/643/sicherheit) durch die Verbindung mit der Eufy-Cloud.
                    Nähere Infos findet ihr hier: https://bropat.github.io/ioBroker.eusec
                    Für jeweiligen Ratschläge und Verbesserungen bin ich sehr dankbar!
                    Grüße
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    schrieb am zuletzt editiert von Fabio
                    #649
                    @bropat falls jemand von euch die neue Homebase drei hat von Eufy, der könnte wenn er mag, seine Haustüre mit der Gesichtserkennung die die Homebase liefert öffnen.
                    der Kamera, die an der Homebase 3 hängt Person name der dann aktualisiert wird wenn eine bekannte Person erkannt wird, zum Beipiel über ein kleines Blockly die Haustüre aufschließen zum Beispiel mit dem Nukischloss.
                    Vorraussetzung ist das ihr bekannte Gesichter in der Eufy App hinzufügen müßt, plus der Namensvergabe. Das Eufy System lernt immer mehr dazu und um so mehr Bilder ihr von euch oder Partner etc. in der Homebase sprich App freigebt um so schneller arbeitet es.
                    Bei mir läuft das schon seit drei Wochen mehr oder weniger perfeckt. Das Problem ist wenn die Kameras die Person nicht beim ersten mal erkannt hat passiert natürlich bis zur nächsten Erkennung nix und ihr steht dann wie der Och·se vor der Tür. 😊
                    Wollte es euch nur mal mitteilen Spass mach das schon. ;-)
                    Ihr braucht aber auf jeden Fall die neue Homebase, die alten Kameras zum Beispiel C2 Doorbell etc. laufen auch mit ihr, müssen aber an die neue Homebase angelernt werden und natürlich ein Smartes Türschloss.
                    Grüße
                    Fabio
                    Iobroker:
                    • Matter over Thread Hilfe
                    • FabioF Fabio
                      Grüße
                      Fabio
                      locito09
                      #650
                      @fa-bio
                      Bekommst du auch einen Bild der Kamera im Adapter ?
                      • L locito09
                        @fa-bio
                        FabioF Offline
                        FabioF Offline
                        Fabio
                        #651
                        @locito09 ich glaube nicht weil ich in der App Miniaturansicht nicht gewählt habe. Ich schau mir das aber noch mal an.
                        Iobroker:
                        • FabioF Fabio
                          locito09
                          schrieb am zuletzt editiert von locito09
                          #652
                          @fa-bio
                          Habe Miniatur aber bekommen trotzdem kein Bild
                          • L locito09
                            @fa-bio
                            FabioF Offline
                            FabioF Offline
                            Fabio
                            #653
                            @locito09 keine Ahnung da kann ich dir leider nicht helfen. Hast du mal auf github geschaut ob jemand auch das Problem hat?
                            https://github.com/bropat/ioBroker.eusec/issues
                            Grüße
                            Iobroker:
                            • B bropat
                              Hallo an alle,
                              Grüße
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              #654
                              @bropat hat eine Latest raus gebracht 0.9.10 schaut bitte auf github was er gefixt hat:
                              https://github.com/bropat/ioBroker.eusec/releases/tag/0.9.10
                              darin lest ihr auch das Problem mit den Vorschaubildern.
                              Vielen Dank @bropat 👍
                              Iobroker:
                              • hollywootH Offline
                                hollywootH Offline
                                hollywoot
                                #655
                                Gibts schon Neuigkeiten, warum die Pfade mittlerweile so aussehen:
                                T8010N0000000000~/media/mmcblk0p1/video/20230113173145_c01.jpg
                                • FabioF Fabio
                                  MINKI
                                  #656
                                  @fa-bio Bin ich nicht würdig genug oder wieso wird mir die 0.9.10 nicht angeboten? Auch nicht über ein manuelles sudo iobroker uppdate/upgrade?
                                  M FabioF 2 Antworten Letzte Antwort
                                  • M MINKI
                                    MINKI
                                    #657
                                    @minki Ok! Ich habe unter System Settings angegeben das ich nur "stable" haben will und die neue Version ist ein latest. Ok, ich bin also eventuell doch würdig!
                                    • M MINKI
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #658
                                      @minki mir wurde es auch nicht angeboten, mußt du über die Katze installieren /Github.
                                      @bropat hat es noch nicht als stable gesetzt wahrscheinlich deshalb, bin mir aber nicht sicher.
                                      Grüße
                                      Fabio
                                      Iobroker:
                                      • M MINKI
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        #659
                                        @minki 👍 😊
                                        Iobroker:
                                        • FabioF Fabio
                                          @minki 👍 😊
                                          MINKI
                                          schrieb am zuletzt editiert von MINKI
                                          #660
                                          @fa-bio Ich habe mich dazu entschieden die Beta zu installieren. Hat wunderbar geklappt. Leider bleibt der Fehler weiterhin bestehen. Die Kamera ist online. Das überprüfe ich via Homekit. Jemand eine Idee was ich falsch mache?!Bildschirm­foto 2023-03-03 um 22.55.47.png
                                          Thomas BraunT FabioF 2 Antworten Letzte Antwort
