  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.2k Aufrufe 147 Beobachtet
  • LongbowL Longbow
    Bitte:-)
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Architecture:   x86_64
    Docker:         false
    Virtualization: lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.1 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.1 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.1 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
    06:35:50 up 1 day, 11:41,  2 users,  load average: 0.64, 0.55, 0.43
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Feb  1 06:35:50 UTC 2023
    UTC +0000
    Etc/UTC
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.2G        3.3G        3.6G        0.0K        1.3G        4.9G
    Swap:           512M          0B        512M
    Total:          8.7G        3.3G        4.1G
             8192 M total memory
             3272 M used memory
              568 M active memory
             3792 M inactive memory
             3584 M free memory
                0 M buffer memory
             1335 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--200--disk--0 ext4    20G  7.6G   11G  42% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.2G   96K  3.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    Messages in dmesg:
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--200--disk--0 ext4   rw,relatime,stripe=16
    /var:
    2.6G    /var/
    2.0G    /var/log/journal/678b65fc11864452957ca5b3828797d4
    2.0G    /var/log
    331M    /var/cache
    /opt/iobroker/backups:
    495M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    583M    /opt/iobroker/iobroker-data/
    365M    /opt/iobroker/iobroker-data/files
    74M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    46M     /opt/iobroker/iobroker-data/states.jsonl
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/vis.0/Iobroker/vis-views.json
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /root/.nvm/versions/node/v16.18.0/bin/node              v16.18.0
    /root/.nvm/versions/node/v16.18.0/bin/npm               9.4.0
    /root/.nvm/versions/node/v16.18.0/bin/npx               9.4.0
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
    *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.klf200.0                 : klf200                : iobroker                                 - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.operating-hours.0        : operating-hours       : iobroker                                 - disabled
      system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
      system.adapter.parser.0                 : parser                : iobroker                                 - disabled
      system.adapter.places.0                 : places                : iobroker                                 - disabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      system.adapter.rtspstream.0             : rtspstream            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
    + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 192.168.178.200
      system.adapter.youtube.0                : youtube               : iobroker                                 - disabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alpha-ess"    : 0.2.0    , installed 0.2.0
    Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "eusec"        : 0.9.9    , installed 0.9.9
    Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "followthesun" : 0.4.0    , installed 0.4.0
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hid-community": 0.3.0    , installed 0.3.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "klf200"       : 1.0.1    , installed 1.0.1
    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "operating-hours": 0.0.19 , installed 0.0.19
    Adapter    "parcel"       : 0.0.23   , installed 0.0.23
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "tankerkoenig" : 3.3.6    , installed 3.3.6
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "wolf"         : 1.5.0    , installed 1.5.0
    Adapter    "wolf-smartset": 1.0.0    , installed 1.0.0
    Adapter    "youtube"      : 4.1.0    , installed 4.1.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        51213
    States:         41765
    Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
    #631
    @longbow
    Zeitzone setzen und nodejs gescheit installieren.
    LongbowL 1 Antwort Letzte Antwort
      @longbow
      LongbowL Offline
      LongbowL Offline
      Longbow
      #632
      wie mache ich das bitte, bin neu Neuling auf dem Gebiet ioborker...
      • LongbowL Longbow
        #633
        @longbow
        Das hat mit iobroker nix zu tun, das hat damit zu tun wie du deinen Container administrierst. Mit den Dingern hab ich aber nix mit am Hut.
        Schau in die Anleitung, vielleicht steht da was drin:
        https://www.iobroker.net/#de/documentation/install/proxmox.md
        Zur NodeJS-Installation:
        Wo stand denn, das man nodejs als root per nvm installiert?
        Das ist nämlich Murks.
          @longbow
          LongbowL Offline
          LongbowL Offline
          Longbow
          #634
          wie kann ich das mit dem nodejs beheben? Oder ist es besser das man Iobroker neu installiert?
          • LongbowL Longbow
            #635
            @longbow sagte in [Neuer Adapter] EuSec:
            Schau in meiner Signatur, da wird das mit den falschen Pfaden bei nodejs erklärt.
              @longbow
              Alles.
              lustig29
              #636
              @thomas-braun Kannst du mir auch bei meinem Problem vom Post weiter oben helfen?
              • L lustig29
                #637
                @lustig29
                Bei welchem?
                  @lustig29
                  Bei welchem?
                  lustig29
                  #638
                  @thomas-braun Seit geraumer Zeit läuft der Adapter nicht mehr richtig. Die Verbindung wird immer wieder getrennt und wieder hergestellt. Hatte sowas schon mal jemand?
                  eusec.0
                  2023-01-29 11:24:22.280	info	Connected to station T8010P23220312FE on host 192.168.0.70 and port 22316
                  eusec.0
                  2023-01-29 11:24:17.255	info	Disconnected from station T8010P23220312FE
                  • L lustig29
                    #639
                    @lustig29 sagte in [Neuer Adapter] EuSec:
                    Nein. Keine Ahnung.
                    Ist halt auch was dünn, so'n Zweizeiler.
                      LongbowL Offline
                      LongbowL Offline
                      Longbow
                      #640
                      guten Morgen, habe es alles gemacht wie es dort beschrieben ist, eine Abhilfe hat es leider nicht gebracht.
                      Hab ein neues System nach den Anleitungen gemacht.
                      Habe es mit auch alles angeschaut mit Nodejs, aber ich bekomme nur Fehlermeldungen. Der Adpater bleibt ohne Daten und Verbindung rot
                      Debian GNU/Linux 11 iobroker-Test tty1
                      iobroker-Test login: root
                      Password:
                      Linux iobroker-Test 5.15.30-2-pve #1 SMP PVE 5.15.30-3 (Fri, 22 Apr 2022 18:08:27 +0200) x86_64
                      permitted by applicable law.
                      Last login: Thu Feb  2 08:28:34 CET 2023 on tty1
                      root@iobroker-Test:~# apt install sudo curl
                      Reading package lists... Done
                      The following additional packages will be installed:
                        libcurl4
                      The following NEW packages will be installed:
                        curl libcurl4 sudo
                      0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 1673 kB of archives.
                      After this operation, 5895 kB of additional disk space will be used.
                      Do you want to continue? [Y/n] y
                      Err:1 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u3
                        Temporary failure resolving 'deb.debian.org'
                      Err:2 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u3
                      Err:3 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                      E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/libcurl4_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                      E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/curl_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                      E: Failed to fetch http://deb.debian.org/debian/pool/main/s/sudo/sudo_1.9.5p2-3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                      root@iobroker-Test:~# curl libcurl4 sudo
                      -bash: curl: command not found
                      root@iobroker-Test:~# apt install curl
                        libcurl4
                        curl libcurl4
                      0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 615 kB of archives.
                      After this operation, 1196 kB of additional disk space will be used.
                        sudo
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 1059 kB of archives.
                      After this operation, 4699 kB of additional disk space will be used.
                      Err:1 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                      root@iobroker-Test:~# apt-get update
                      Err:1 http://deb.debian.org/debian bullseye InRelease
                      Err:2 http://security.debian.org bullseye-security InRelease
                        Temporary failure resolving 'security.debian.org'
                      Err:3 http://deb.debian.org/debian bullseye-updates InRelease
                      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
                      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
                      W: Failed to fetch http://security.debian.org/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                      root@iobroker-Test:~# apt update && apt upgrade
                      All packages are up to date.
                      Calculating upgrade... Done
                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      LongbowL Thomas BraunT 2 Antworten Letzte Antwort
                      • LongbowL Longbow
                        Password:
                          libcurl4
                          curl libcurl4 sudo
                          libcurl4
                          curl libcurl4
                          sudo
                        LongbowL Offline
                        LongbowL Offline
                        Longbow
                        #641
                        @Thomas-Braun
                        das war bei mir mit dem Befehl cd /opt/iobroker
                        npm ls | grep -E 'github|ERR'
                        cliffkirchhof@iobroker:/opt/iobroker$ npm ls | grep -E 'github|ERR'
                        +-- eufy-security-client@2.4.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#7fc2a45a75ee1bf69ced36d351d1ec6d623896f6)
                        +-- iobroker.klf200@1.0.1 (git+ssh://git@github.com/MiSchroe/ioBroker.klf200.git#c0799c01cca44762617b9fa5e709d60a83a80f24)
                        +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspstream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)e_text
                        • LongbowL Longbow
                          Password:
                            libcurl4
                            curl libcurl4 sudo
                            libcurl4
                            curl libcurl4
                            sudo
                          #642
                          Dein Netzwerk ist kaputt.
                          Und du möchstest nicht als root herumhampeln.
                            LongbowL Offline
                            LongbowL Offline
                            Longbow
                            #643
                            sorry, ich verstehe es leider nicht ganz, was ist kaputt der iobroker läuft, bis auf den Adapter EuSec.
                            Thomas BraunT L 2 Antworten Letzte Antwort
                            • LongbowL Longbow
                              #644
                              @longbow
                              Der Server deb.debian.org kann nicht erreicht werden. Warum auch immer. Vermutlich ein Knoten in deinem Netzwerk.
                              • LongbowL Longbow
                                locito09
                                #645
                                @longbow
                                Eusec hat bekanntlich Probleme mit jpeg download und disconnected, schaue auf github und /oder weiter oben lesen.
                                Es gibt noch keine Lösung die mir bekannt ist
                                Für nächste mal Informiere dich was für Issues offen sind für den Adapter, und bitte ein paar post weiter oben lesen, das Problem ist bekannt
                                  @longbow
                                  LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  #646
                                  @Thomas-Braun
                                  Danke für den Tipp, habe es neu gemacht, hatte ein IP Adressen Fehler.
                                  Aber jetzt geht der Adapter immer noch nicht.
                                  Skript v.2023-01-02
                                  *** BASE SYSTEM ***
                                  Docker:         false
                                  Virtualization: lxc
                                  Distributor ID: Debian
                                  Description:    Debian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="11"
                                  VERSION="11 (bullseye)"
                                  VERSION_CODENAME=bullseye
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                   19:36:02 up 11 min,  1 user,  load average: 0.33, 0.42, 0.48
                                  CPU threads: 4
                                  Thu Feb  2 18:36:02 UTC 2023
                                  Thu Feb  2 19:36:02 CET 2023
                                  CET +0100
                                  Europe/Berlin
                                  *** User and Groups ***
                                  cliffkirchhof
                                  /home/cliffkirchhof
                                  cliffkirchhof sudo iobroker
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Mem:            8.1G        492M        7.1G        0.0K        552M        7.6G
                                  Swap:           8.1G          0B        8.1G
                                  Total:           16G        492M         15G
                                           8096 M total memory
                                            492 M used memory
                                            313 M active memory
                                            665 M inactive memory
                                           7050 M free memory
                                              0 M buffer memory
                                            552 M swap cache
                                           8096 M total swap
                                              0 M used swap
                                           8096 M free swap
                                  *** FILESYSTEM ***
                                  /dev/mapper/pve-vm--210--disk--0 ext4       20G  2.2G   17G  12% /
                                  udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                  Messages in dmesg:
                                  /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
                                  /var:
                                  382M    /var/
                                  222M    /var/cache
                                  218M    /var/cache/apt
                                  151M    /var/cache/apt/archives
                                  135M    /var/lib
                                  4.0K    /opt/iobroker/backups/
                                  93M     /opt/iobroker/iobroker-data/
                                  86M     /opt/iobroker/iobroker-data/files
                                  32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                  6.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                  4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
                                  4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                                  /usr/bin/node           v16.19.0
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  nodejs:
                                    Version table:
                                          500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                       12.22.12~dfsg-1~deb11u3 500
                                          500 http://security.debian.org bullseye-security/main amd64 Packages
                                       12.22.5~dfsg-2~11u1 500
                                          500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapters from github:   1
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
                                  + system.adapter.chromecast.0             : chromecast            : iobroker-Final                           -  enabled
                                    system.adapter.cloud.0                  : cloud                 : iobroker-Final                           - disabled
                                  + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
                                  + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
                                    system.adapter.hue-extended.0           : hue-extended          : iobroker-Final                           - disabled
                                    system.adapter.hue.0                    : hue                   : iobroker-Final                           - disabled, port: 443
                                  + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                                    system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
                                    system.adapter.synology.0               : synology              : iobroker-Final                           - disabled, port: 5000
                                    system.adapter.synology.1               : synology              : iobroker-Final                           - disabled, port: 5000
                                    system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
                                  + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Objects and States
                                  Objects:        545
                                  States:         464
                                  Hit:1 http://security.debian.org bullseye-security InRelease
                                  Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Hit:3 http://deb.debian.org/debian bullseye InRelease
                                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          235092916  1/init
                                  tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        235093971  116/systemd-resolve
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          235095151  306/master
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       235094725  127/iobroker.js-con
                                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        235093977  116/systemd-resolve
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       235094718  127/iobroker.js-con
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          235095055  1/init
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          235092918  1/init
                                  tcp6       0      0 :::5355                 :::*                    LISTEN      104        235093974  116/systemd-resolve
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       235126555  2911/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       235112750  1107/io.admin.0
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          235095152  306/master
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       235096031  453/io.chromecast.0
                                  udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        235093970  116/systemd-resolve
                                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        235093976  116/systemd-resolve
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          235092917  1/init
                                  udp6       0      0 :::5355                 :::*                                104        235093973  116/systemd-resolve
                                  udp6       0      0 :::111                  :::*                                0          235092919  1/init
                                  2023-02-02 19:31:22.989  - info: web.0 (2911) socket.io server listening on port 8082
                                  2023-02-02 19:31:22.998  - info: web.0 (2911) Connect extension "eusec/build/lib/web.js"
                                  2023-02-02 19:31:23.000  - info: web.0 (2911) http server listening on port 8082
                                  2023-02-02 19:34:25.199  - info: host.iobroker-Final iobroker del eusec.0 --debug
                                  2023-02-02 19:34:25.796  - info: host.iobroker-Final iobroker Delete instance "eusec.0"
                                  2023-02-02 19:34:25.805  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 instances of eusec.0
                                  2023-02-02 19:34:25.812  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 14 states of system.adapter.eusec.0
                                  2023-02-02 19:34:25.817  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 3 states (system.adapter.eusec.0.*) from states
                                  2023-02-02 19:34:25.943  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 15 object(s).
                                  2023-02-02 19:34:25.981  - info: host.iobroker-Final object deleted system.adapter.eusec.0
                                  2023-02-02 19:34:25.982  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 state(s).
                                  2023-02-02 19:34:26.997  - info: host.iobroker-Final iobroker exit 0
                                  2023-02-02 19:35:24.489  - info: host.iobroker-Final iobroker del eusec --debug
                                  2023-02-02 19:35:25.022  - info: host.iobroker-Final iobroker Delete adapter "eusec"
                                  2023-02-02 19:35:25.040  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 2 meta of eusec
                                  2023-02-02 19:35:25.042  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 adapter for eusec
                                  2023-02-02 19:35:25.054  - info: host.iobroker-Final iobroker host.iobroker-Final Counted 1 states (system.adapter.eusec.*) from states
                                  2023-02-02 19:35:25.213  - info: host.iobroker-Final iobroker host.iobroker-Final file eusec.admin deleted
                                  2023-02-02 19:35:25.217  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec deleted
                                  2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final object eusec.admin deleted
                                  2023-02-02 19:35:25.221  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 3 object(s).
                                  2023-02-02 19:35:25.227  - info: host.iobroker-Final iobroker host.iobroker-Final Deleting 1 state(s).
                                  2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker removed 884 packages, and changed 1 package in 3s
                                  2023-02-02 19:35:28.863  - info: host.iobroker-Final iobroker 66 packages are looking for funding  run `npm fund` for details
                                  2023-02-02 19:35:29.892  - info: host.iobroker-Final iobroker exit 0```
                                  code_text
                                  • LongbowL Offline
                                    LongbowL Offline
                                    Longbow
                                    #647
                                    Gibt es was neues, der Adapter bleibt rot, wie schon berichtet. der neu aufgesetzte ioborker läuft super.
                                    • LongbowL Longbow
                                      #648
                                      @longbow
                                      Hier nix neues. Bei dir?
                                      • B bropat
                                        Hallo an alle,
                                        ich möchte euch meinen ersten ioBroker Adapter "euSec", an dem ich gerade Arbeite, vorstellen:
                                        https://github.com/bropat/ioBroker.euSec
                                        Dieser Adapter ermöglicht die Steuerung von Eufy-Sicherheitsgeräten (https://www.eufylife.com/de/products/643/sicherheit) durch die Verbindung mit der Eufy-Cloud.
                                        Nähere Infos findet ihr hier: https://bropat.github.io/ioBroker.eusec
                                        Für jeweiligen Ratschläge und Verbesserungen bin ich sehr dankbar!
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        schrieb am zuletzt editiert von Fabio
                                        #649
                                        @bropat falls jemand von euch die neue Homebase drei hat von Eufy, der könnte wenn er mag, seine Haustüre mit der Gesichtserkennung die die Homebase liefert öffnen.
                                        der Kamera, die an der Homebase 3 hängt Person name der dann aktualisiert wird wenn eine bekannte Person erkannt wird, zum Beipiel über ein kleines Blockly die Haustüre aufschließen zum Beispiel mit dem Nukischloss.
                                        Vorraussetzung ist das ihr bekannte Gesichter in der Eufy App hinzufügen müßt, plus der Namensvergabe. Das Eufy System lernt immer mehr dazu und um so mehr Bilder ihr von euch oder Partner etc. in der Homebase sprich App freigebt um so schneller arbeitet es.
                                        Bei mir läuft das schon seit drei Wochen mehr oder weniger perfeckt. Das Problem ist wenn die Kameras die Person nicht beim ersten mal erkannt hat passiert natürlich bis zur nächsten Erkennung nix und ihr steht dann wie der Och·se vor der Tür. 😊
                                        Wollte es euch nur mal mitteilen Spass mach das schon. ;-)
                                        Ihr braucht aber auf jeden Fall die neue Homebase, die alten Kameras zum Beispiel C2 Doorbell etc. laufen auch mit ihr, müssen aber an die neue Homebase angelernt werden und natürlich ein Smartes Türschloss.
                                        Fabio
                                        Iobroker:
                                        • Matter over Thread Hilfe
                                        • FabioF Fabio
                                          Fabio
                                          locito09
                                          #650
                                          @fa-bio
                                          Bekommst du auch einen Bild der Kamera im Adapter ?
                                          FabioF 1 Antwort Letzte Antwort
